Niglix Posted December 15, 2020 Share Posted December 15, 2020 I followed in detail the installation tutorial but I'm stuck at the installation of OMV. I can't access after the installation using the ip address or the generic link helios.local. I did try to reinstall the configuration. To go through a boot on the Micro SD... I don't know if there would be a command line to verify that OMV is installed? Or another way to install it? 1 Quote Link to comment Share on other sites More sharing options...
grek Posted December 15, 2020 Share Posted December 15, 2020 to install OMV You should login via SSH to your helios then: root@helios64:~# armbian-config root@helios64:~# armbian-config Software -> Softy -> OMV You can verify if it installed: root@helios64:~# dpkg -l |grep openmediavault ii openmediavault 5.5.17-3 all openmediavault - The open network attached storage solution ii openmediavault-fail2ban 5.0.5 all OpenMediaVault Fail2ban plugin ii openmediavault-flashmemory 5.0.7 all folder2ram plugin for OpenMediaVault ii openmediavault-keyring 1.0 all GnuPG archive keys of the OpenMediaVault archive ii openmediavault-luksencryption 5.0.2 all OpenMediaVault LUKS encryption plugin ii openmediavault-omvextrasorg 5.4.2 all OMV-Extras.org Package Repositories for OpenMediaVault ii openmediavault-zfs 5.0.5 arm64 OpenMediaVault plugin for ZFS root@helios64:~# 1 Quote Link to comment Share on other sites More sharing options...
aprayoga Posted December 16, 2020 Share Posted December 16, 2020 @Niglix How did you install the OMV? using armbian-config? The installation process took roughtly half an hour. You can use serial console to access your Helios64 if for some reason the network down. You would also see screen like this in serial console after OMV installed Spoiler Starting kernel ... openmediavault 5.5.17-3 (Usul) helios64 ttyS2 Copyright (C) 2009-2020 by Volker Theile. All rights reserved. To manage the system visit the openmediavault web control panel: eth0: 192.168.0.124 eth0: 2002:c0a8:10a:1:6662:66ff:fed0:17c eth0: fe80::6662:66ff:fed0:17c By default the web control panel administrator account has the username 'admin' and password 'openmediavault'. It is recommended that you change the password for this account within the web control panel or using the 'omv-firstaid' CLI command. For more information regarding this appliance, please visit the web site: https://www.openmediavault.org helios64 login: 0 Quote Link to comment Share on other sites More sharing options...
gprovost Posted December 16, 2020 Share Posted December 16, 2020 @Niglix OMV5 will wipe out any fixed IP configuration, so if you didn't use DHCP you will need to login via console to setup temporally an IP in order to then access the OMV web interface and reconfigure for good the network interface via the web interface. 0 Quote Link to comment Share on other sites More sharing options...
