Restore Bqeel M9C MAX
peppezic
Hi there,
I'm very knew to this forum. Yesterday I successfully installed armbian 20.10 on my bqeel M9C MAX on sd card following this thread (https://forum.armbian.com/topic/12162-single-armbian-image-for-rk-aml-aw-aarch64-armv8/page/48/)
I had no desktop manager available and tried several times to fix it by installing xfce4 and lightdm but with no success (I always had "xserverrc x not found" error). After that I accidentally run the script install-am.sh which properly completed the installation.
After removing the SD and reboot I can no longer access Android :-o
I surely went wrong running the script. The question is: there's any possibility to fix it and restore the access to android?
Any help would be appreciated.
Regards.
Hi SteeMan. Unfortunately I could not answer before than 24h from my last message because of the forum restrictions.
About your question: I just followed the thread I mentioned before. It means:
  • I downloaded armbian bionic 20.10 from the repository linked in the thread
  • I flashed it through balenaEtcher on my 64GB sd card.
  • I renamed the correct e-boot-S905xxx file to e-boot.ext
  • I edited /extlinux/extlinux.conf commented all the lines but FDT /dtb/amlogic/meson-gxl-s905x-p212.dtb and APPEND root=LABEL=ROOTFS rootflags=data=writeback rw console=ttyAML0...
  • Then I started the android box and manually update its firmware by selecting aml_autoscript.zip from the sd card
  • The box restarted a couple of times, then I set the root password and that's all.
After a couple of failed attempts to start a desktop manager I accidentaly run the install-am.sh script which might have overridden the MBR and now I no longer can access android even with sd card removed.
Regards.
You still didn't answer the question of which build you are using, i.e. what is the full name of the file you downloaded.  Also what dtb files did you try, all of the s905x files or only the one you mentioned.
By running install-am.sh script you have erased your emmc internal storage and replaced it with a copy of your armbian install from the sd card.  So yes your android install is gone.  To restore you will need to find an android firmware for your box and use the appropriate tools to reinstall that firmware.
9 minutes ago, peppezic said:
I was using Armbian_20.10_Arm-64_bionic_current_5.9.0.
To your original question, you are not seeing desktop support because you have installed a server build with no desktop support.  You need to install a build that has 'desktop' in the file name to have desktop support.  In the last set of builds from balbes that includes amlogic support you have the following two desktop builds:
Armbian_20.10_Arm-64_bullseye_current_5.9.0_desktop.img.xz
Armbian_20.10_Arm-64_focal_current_5.9.0_desktop.img.xz
(note no bionic desktop build)
Hi SteeMan,
I successfully installed Armbian_20.10_Arm-64_bullseye_current_5.9.0_desktop.img on my tv box. The desktop appeared with no problem.
The only problem now is the wifi adapter. I started, as I used to do on x86 linux desktops, to find out my hardware with lspci but I had no output :-/
Can you share a way to handle or analyze the wifi problem on armbian?
Edited by peppezic
As is stated in https://forum.armbian.com/topic/16407-please-read-first
which I linked to earlier:
"7. You really shouldn't expect things like Wi-Fi, bluetooth, remote control, etc. to work."
I have six different amlogic based TV boxes and wifi doesn't work on any of them.  If you really need wifi your best bet is to use a usb wifi adaptor.  Otherwise you can try different dtb files compatible with your cpu and see if you can find a better fit for your hardware or search the forums for others that have the same box as you and see if anyone has reported success in getting wifi working on a mainline kernel on your specific box.  Since I don't have your box, I can't provide any more guidance than that.
Hi peppezic!!
I know that this post is quite old, but I have the same TV BOX and I can't find the firmware anywhere.
Could you be so kind to tell me where you found it? Or if you still have it, please send to me.
Thanks!!
Hi SteeMan,
I did, without success. My problem is that I was previously running Coreelec, so according to the thread I have to flash the original firmware of the device which I don't have. That's why I am asking for the original android firmware of my device.
