RESOLVED: a64-pine64+ goodix touchscreen (i2c) fails to load on reboot
Learnincurve
Armbianmonitor:
 5.10.4-sunxi64 pine64 board with goodix 7" mipi-dsi LCD touchscreen.
The LCD output is working fine across reboots after enabling the dt overlay using armbian-config.
For the touchscreen, I have added "goodix" to /etc/modules and the digitizer works fine from all cold boots:
~$ dmesg | grep -i goodix
[    5.836601] Goodix-TS 1-005d: supply VDDIO not found, using dummy regulator
[    5.843605] Goodix-TS 1-005d: ID k}\xfa, version: 7b6f
[    5.866815] input: Goodix Capacitive TouchScreen as /devices/platform/soc/1c2ac00.i2c/i2c-1/1-005d/input/input5
but a reboot leads to either:
[    5.856172] Goodix-TS 1-005d: supply VDDIO not found, using dummy regulator
[    5.856668] Goodix-TS 1-005d: i2c test failed attempt 1: -6
[    5.886780] Goodix-TS 1-005d: ID k}\xfa, version: 7b6f
[    5.909817] input: Goodix Capacitive TouchScreen as /devices/platform/soc/1c2ac00.i2c/i2c-1/1-005d/input/input5
and the screen works
or:
[    5.862909] Goodix-TS 1-005d: supply VDDIO not found, using dummy regulator
[    5.864033] Goodix-TS 1-005d: i2c test failed attempt 1: -6
[    5.889397] Goodix-TS 1-005d: i2c test failed attempt 2: -6
[    5.925072] Goodix-TS 1-005d: I2C communication failure: -6
a double reboot works.
It looks like the i2c bus is not being completely reset in time, but that multiple connection attempts  sometimes succeed.
Can anyone suggest a workaround, to force a reset, add more i2c test iterations or provide more time to load from reboot?
BR.
Link to comment
Share on other sites
Hi There, I think I have made some progress
This is what I did:
0) Attach a mouse and keyboard so you can type command while the Desktop is running.
1)Open a termonal and type:
   sudo apt-get install libts-bin
2) Calibrate with this command:
   sudo ts_calibrate
3) Put these lines in /etc/X11/xorg.conf.d/99-touch.conf
Section "InputClass"
    Identifier "Goodix Capacitive TouchScreen"
    Driver "tslib"
    MatchDevicePath "/dev/input/event*"
    MatchProduct "goodix"
EndSection
4) Reboot
Now the position is correct but I miss the click :)
Link to comment
Actually to fix this, after step 2 I remove the 99-touch.conf file and added instead this file /etc/X11/xorg.conf.d/40-libinput.conf with this content:
    Identifier "libinput touchscreen catchall"
    MatchIsTouchscreen "on"
    MatchDevicePath "/dev/input/event0"
    Driver "libinput"
    Option "Ignore" "on"
EndSection
    MatchDevicePath "/dev/input/event1"
    Driver "libinput"
EndSection
    MatchDevicePath "/dev/input/event2"
    Driver "libinput"
EndSection
It seems that there are multiple devices and you need to disable some of them to make this reliably work.
PLease let me know if this works for you, I hope this may help other people struggling with this!
Link to comment
Hi Lucapinello,
Thank you for the tip to make sure ts_uinput -d is running.   For me, the problem with reboot seems to be at a lower level (at goodix module load and before tslib gets loaded).
 I am trying to work out how to unload the goodix module before reboot, as a manual removal of the module leads to a working reboot, but am having some trouble writing a systemd service that runs early, before reboot
BR.
Link to comment
This is resolved now.  After reading https://www.raspberrypi.org/forums/viewtopic.php?t=216901 I created the following systemd service file:
Unit]
Description=unload the goodix driver ahead of reboots to allow it to properly load again when the system restarts
[Service]
ExecStop=/sbin/rmmod goodix
Type=oneshot
RemainAfterExit=true
[Install]
WantedBy=multi-user.target
System now comes up with working touchscreen every time:)        ~        ~
Link to comment
  • Learnincurve changed the title to RESOLVED: a64-pine64+ goodix touchscreen (i2c) fails to load on reboot
