Armbianmonitor:
http://ix.io/2M0f
5.10.4-sunxi64 pine64 board with goodix 7" mipi-dsi LCD touchscreen.
The LCD output is working fine across reboots after enabling the dt overlay using armbian-config.
For the touchscreen, I have added "goodix" to /etc/modules and the digitizer works fine from all cold boots:
~$ dmesg | grep -i goodix
[ 5.836601] Goodix-TS 1-005d: supply VDDIO not found, using dummy regulator
[ 5.843605] G
