Video : How to install OMV on Armbian Buster and set up a SMB share with it
10 minutes ago, ElizabethSasha said:
I have tried all steps in this videos but nothing help.
Due to the insane amount of detail you gave with your error description it will take quite a while to sort things out.
vor 21 Stunden schrieb horvat.kamca:
Similar issue here. Armbian-config actually didn't install openmediavault, it just configured apt so that openmediavault can be installed.
Therefore, after armbian-config was finished with configuration, i'd to drop back to shell and install OMV with
apt install openmediavault
Or you use the OMV install script at https://github.com/OpenMediaVault-Plugin-Developers/installScript installing OMV5 on Buster or OMV6 on Bullseye.
