Problem with apt list
RockBian
Today I updated and upgraded my system, and after a reboot 'apt list' did no longer work. It shows 'Listing... done', and then uses 100% CPU on a single core, without producing anything. According to strace it's looping on reading a file:
openat(AT_FDCWD, "/var/lib/apt/lists/deb.debian.org_debian_dists_buster_main_binary-arm64_Packages.lz4", O_RDONLY) = 28
read(28, "\4\"M\30@@\300\206z\0\0\370\377\31Package: 0ad-data\n"..., 65536) = 65536
read(28, "ta$E\17p\2+\377\21c376d3f140540d9424753d"..., 65536) = 65536
read(28, "a5180e3e2d3f503ddcb5dd7b93\201\2\2\275\0\17"..., 65536) = 65536
read(28, "\2\3700071880bc23623a4ea3664b773a1b6"..., 65536) = 65536
read(28, "\f1'da?\2Jdan_\207\1\v=\2f215438\272\t\365\0213e4c"..., 65536) = 65536
read(28, "a6f6005b836871a9cc032472bbece3b7"..., 65536) = 65536
read(28, "3783a1460d749c6f887843fdd95ec981"..., 65536) = 65536
read(28, "\4\0032 - \16\1\0022\32\t?\27\177foreign\270\0041\370\21f1e69"..., 65536) = 65536
read(28, "dR\203\1\6\4\6T\37\3\324\0\",\ng_zplaying\2759\vt\203\1\233"..., 65536) = 65536
read(28, "\20u://ftp.\24'_nu/bc\2\3\0\363\20b8da7e3f11"..., 65536) = 65536
close(28)                               = 0
close(28)                               = 0
close(28)                               = 0
This repeats over and over. I checked the file /var/lib/apt/lists/deb.debian.org_debian_dists_buster_main_binary-arm64_Packages.lz4, and it seems valid, as in, lz4 decompresses it without complaints. When I put the decompressed /var/lib/apt/lists/deb.debian.org_debian_dists_buster_main_binary-arm64_Packages in the same directory, 'apt list' works.
What is going on? It might be size related. The file is the biggest *_Packages.lz4 file in that directory. There are bigger lz4 files, but according to strace they are not accessed. The timestamp of deb.debian.org_debian_dists_buster_main_binary-arm64_Packages.lz4 is Dec 5 11:03, so I don't think it grew, at last update.
The upgraded files are:
Start-Date: 2021-01-17  14:07:30
Commandline: apt upgrade
Requested-By: rockbian (1000)
Install: javascript-common:arm64 (11, automatic), php-symfony-yaml:arm64 (3.4.22+dfsg-2+deb10u1, automatic), libjs-codemirror:arm64 (5.43.0-1+deb10u1, automatic), libjs-popper.js:arm64 (1.14.6+ds2-1, automatic), libjs-jquery-mousewheel:arm64 (1:3.1.13-2, automatic), php-symfony-filesystem:arm64 (3.4.22+dfsg-2+deb10u1, automatic), libjs-jquery-timepicker:arm64 (1.2-1, automatic), php-symfony-dependency-injection:arm64 (3.4.22+dfsg-2+deb10u1, automatic), libjs-jquery-ui:arm64 (1.12.1+dfsg-5, automatic), libjs-bootstrap4:arm64 (4.3.1+dfsg2-1, automatic), php-symfony-config:arm64 (3.4.22+dfsg-2+deb10u1, automatic), php-twig-i18n-extension:arm64 (3.0.0-2~bpo10+1, automatic)
Upgrade: nodejs:arm64 (10.21.0~dfsg-1~deb10u1, 10.23.1~dfsg-1~deb10u1), python-apt-common:arm64 (1.8.4.2, 1.8.4.3), phpmyadmin:arm64 (4:4.9.7+dfsg1-1~bpo10+1, 4:5.0.4+dfsg2-1~bpo10+1), php-google-recaptcha:arm64 (1.2.4-1~bpo10+1, 1.2.4-3~bpo10+1), linux-buster-root-current-helios64:arm64 (20.11.4, 20.11.6), armbian-config:arm64 (20.11.3, 20.11.6), libnode64:arm64 (10.21.0~dfsg-1~deb10u1, 10.23.1~dfsg-1~deb10u1), libp11-kit0:arm64 (0.23.15-2, 0.23.15-2+deb10u1), php-mariadb-mysql-kbs:arm64 (1.2.11-1~bpo10+1, 1.2.12-1~bpo10+1), python3-apt:arm64 (1.8.4.2, 1.8.4.3), tzdata:arm64 (2020d-0+deb10u1, 2020e-0+deb10u1), linux-u-boot-helios64-current:arm64 (20.11.4, 20.11.6)
End-Date: 2021-01-17  14:08:10
If you want to speed it up, you can quick-fix it by doing the following:
sudo rm /etc/apt/apt.conf.d/02-armbian-compress-indexes
sudo rm -rf /var/lib/apt/lists/*
sudo apt update
If you don't want to remove 02-armbian-compress-indexes you can edit it and change true to false. Do note that these will, unfortunately, be overwritten/replaced by future updates to the linux-buster-root-current-helios64 package.
