otlabs Posted January 24, 2021 Share Posted January 24, 2021 Armbianmonitor: http://ix.io/2N6Y Just flashed Armbian 20.11.9 for NanoPi Neo 2 with kernel 5.10.4. I have run armbian-config to install kernel 5.10.4 source, but there is no any option for 5.10.x kernel sources, I see only options for 5.8.x and 5.9.x. 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted January 24, 2021 Share Posted January 24, 2021 Dont know why it is not listed in armbian-config but try searching the classical way using apt search because there I can find it: linux-source-5.10.4-current-sunxi - This package provides the source code for the Linux kernel 5.10.4 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted January 24, 2021 Share Posted January 24, 2021 4 hours ago, Werner said: Dont know why it is not listed in armbian-config but try searching the classical way using apt search because there I can find it: So we have a bug related to armbian-config ... hmm. 0 Quote Link to comment Share on other sites More sharing options...
otlabs Posted January 29, 2021 Author Share Posted January 29, 2021 On 1/24/2021 at 1:05 AM, Werner said: Dont know why it is not listed in armbian-config but try searching the classical way using apt search because there I can find it: linux-source-5.10.4-current-sunxi - This package provides the source code for the Linux kernel 5.10.4 Shouldn't it be *-sunxi64 as uname -a reports "Linux nanopineo2 5.10.4-sunxi64 #20.11.7 SMP Tue Jan 5 23:28:09 CET 2021 aarch64 aarch64 aarch64 GNU/Linux"? 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted January 29, 2021 Share Posted January 29, 2021 Yeah obviously pbp@pinebook-pro:~$ apt-cache search sunxi64|grep source|grep 5.10.4 linux-source-5.10.4-current-sunxi64 - This package provides the source code for the Linux kernel 5.10.4 linux-source-5.10.4-dev-sunxi64 - This package provides the source code for the Linux kernel 5.10.4 Grab the current package 0 Quote Link to comment Share on other sites More sharing options...
otlabs Posted January 29, 2021 Author Share Posted January 29, 2021 Thank you! 0 Quote Link to comment Share on other sites More sharing options...
otlabs Posted March 28, 2021 Author Share Posted March 28, 2021 Just checked with Armbian 21.02.3, kernel 5.10.21 - the issue is still present. Kernel install lists 4 kernel-source-5.8.x and 1 kernel-source-5.9.14, no entry for kernel-source-5.10.21. Running "apt-cache search sunxi64|grep source|grep 5.10." returns 8 packages. 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted March 29, 2021 Share Posted March 29, 2021 Yes, it seems we have a bug in armbian-config ... which we would anyway like to write from scratch and establish proper maintaining. Until I am more or less alone doing that ... 0 Quote Link to comment Share on other sites More sharing options...
