rockpi4a @2GHz
dolphs
Hi,
Just noticed image " Linux rockpi-4a 5.9.14-rockchip64 #20.11.4 SMP PREEMPT Tue Dec 15 08:52:20 CET 2020 aarch64 GNU/Linux "  my rockpi4a runs at 2Ghz.
To radxa overclocking is possible so that 2GHz is not a real surprise ...
Though checked " armbianEnv.txt " but did not find any "overlays" option present overlocking this board, neither any other files in /boot ( or /boot/dtb/rockchip/overlay ).
However building a custom image ( kernel 5.10 ) it is running at 1,8GHz again, how can I set this to 2GHz ?
( as a side note - tehre is no need to enable panfrost BTW as I run this as a headless server )
Thanks
  • dolphs changed the title to rockpi4a @2GHz
no url to paste to, but 5.9.14 shows:
root@rockpi-4a:~# cpufreq-info | grep 2.02
  hardware limits: 408 MHz - 2.02 GHz
  available frequency steps: 408 MHz, 600 MHz, 816 MHz, 1.01 GHz, 1.20 GHz, 1.42 GHz, 1.61 GHz, 1.80 GHz, 2.02 GHz
  current policy: frequency should be within 408 MHz and 2.02 GHz.
  cpufreq stats: 408 MHz:77.49%, 600 MHz:2.96%, 816 MHz:0.26%, 1.01 GHz:0.17%, 1.20 GHz:0.13%, 1.42 GHz:0.12%, 1.61 GHz:0.04%, 1.80 GHz:0.07%, 2.02 GHz:18.76%  (288)
It is not a biggie, but just noticed and that is all.
So I suppose it is a WIP and will be overlay sooner or later ( similar back then with NEO2 board : cpu-clock-1.3GHz-1.3v )
If this is your test machine, you can check by switching to nightly / beta repository. It should work there ... and in next update.
