Technicavolous Posted February 3, 2021 Share Posted February 3, 2021 It's been a while since I ran my VBox installed build system. apt-update gives the following error - Err:3 http://repo.aptly.info nightly InRelease The following signatures couldn't be verified because public key is not available: NO_PUBKEY ED75B5A4483DA07C but continues. Is there something I should do or ignore? I started from scratch and pulled the directory and ./compile'd again and everything seemed to go fine, produced output which I will test today. Link to comment Share on other sites More sharing options...
Technicavolous Posted February 6, 2021 Author Share Posted February 6, 2021 I've built several images that appear to run fine ... but the 'nightly' error leads me to believe I may be missing something important? Link to comment Share on other sites More sharing options...
Igor Posted February 6, 2021 Share Posted February 6, 2021 Partially related: We need this tool to manage repositories and Aptly is also use for advanced building, otherwise you don't need it. So far there are no critical problems in a process we have, but someday they might show up. Fixing (more of) 3rd party tools is last thing we need on our shoulders. Link to comment Share on other sites More sharing options...
Technicavolous Posted February 6, 2021 Author Share Posted February 6, 2021 I had no idea how to fix it so I built a new VM and started from scratch. so far so good...Same error and failed first build. Link to comment Share on other sites More sharing options...
