Failing to boot from EMMC
Hi, everyone. The Kobo site is kind of difficult to navigate if you're looking for relevant information, but I came to the conclusion that this is the right place for support. Forgive me if I'm mistaken.
I was wondering if someone could help me interpret these bootlogs from serial term when trying to boot my Helios64 from the EMMC. Following the instructions on Kobol's site, I flashed their u-boot image to an sd card, booted the Helios64 off of said sd, fetched the latest image of Armbian, unpacked that image, and flashed it from my laptop to the Helios64 via usbc to what I presume is the correct interface. Could it be that I messed up? Here's a quick example of the weird behaviour when I take the sd card out and turn on the machine:
Spoiler
DHCP client bound to address 192.168.1.135 (3009 ms)
*** Warning: no boot file name; using 'C0A80187.img'
Using ethernet@fe300000 device
TFTP from server 192.168.1.1; our IP address is 192.168.1.135
Filename 'C0A80187.img'.
Load address: 0x800800
Loading: T T T T T T T T T T
Retry count exceeded; starting again
missing environment variable: pxeuuid
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/01-64-62-66-d0-03-42
Speed: 1000, full duplex
Filename 'pxelinux.cfg/01-64-62-66-d0-03-42'.
Load address: 0x600000
Basicall, it keeps repeating this dialogue but with different files. So, for the one above, it says "Retrieving file: pxelinux.cfg/01-64-62-66-d0-03-42", but then it'll go on and say "Retrieving file: pxelinux.cfg/C0A8018", and so on. It'll keep doing that for a bunch of files, after which there's no boot screen or login prompt or anything. I haven't managed to ssh into it, either, but it may be my mistake that I can't figure out how to do so.
If I unplug the ethernet, it looks like this:
Spoiler
Device 0: unknown device
ethernet@fe300000 Waiting for PHY auto negotiation to complete......... TIMEOUT !
Could not initialize PHY ethernet@fe300000
Retrieving file: pxelinux.cfg/00000000
I'm really dreading the idea that I have to take apart the chassis and jump the board so that I can boot from the sd card. I don't understand why the sd card wouldn't be before the emmc in Helios64's boot order. That seems absurd to me.
Anyway, here's at least part of the log. I didn't feel like sitting around to let it go through all the files:
Spoiler
[qrthi@antelope:~]$ picocom -b 1500000 /dev/ttyUSB0
picocom v3.2a
port is        : /dev/ttyUSB0
flowcontrol    : none
baudrate is    : 1500000
parity is      : none
databits are   : 8
stopbits are   : 1
escape is      : C-a
local echo is  : no
noinit is      : no
noreset is     : no
hangup is      : no
nolock is      : no
send_cmd is    : /nix/store/99crijf5zsw6fvf23a3p782nwh81871s-lrzsz-0.12.20/bin/sz -vv
receive_cmd is : rz -vv -E
imap is        :
omap is        :
emap is        : crcrlf,delbs,
logfile is     : none
initstring     : none
exit_after is  : not set
exit is        : no
Type [C-a] [C-h] to see available commands
Terminal ready
DDR Version 1.24 20191016
In
channel 0
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0 training pass!
channel 1 training pass!
change freq to 416MHz 0,1
Channel 0: LPDDR4,416MHz
Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB
Channel 1: LPDDR4,416MHz
256B stride
channel 0
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0, cs 0, advanced training done
channel 1, cs 0, advanced training done
change freq to 856MHz 1,0
ch 0 ddrconfig = 0x101, ddrsize = 0x40
ch 1 ddrconfig = 0x101, ddrsize = 0x40
pmugrf_os_reg[2] = 0x32C1F2C1, stride = 0xD
ddr_set_rate to 328MHZ
ddr_set_rate to 666MHZ
ddr_set_rate to 928MHZ
ddr_set_rate to 416MHZ, ctl_index 0
ddr_set_rate to 856MHZ, ctl_index 1
support 416 856 328 666 928 MHz, current 856MHz
OUT
Boot1: 2019-03-14, version: 1.19
CPUId = 0x0
ChipType = 0x10, 254
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
FwPartOffset=2000 , 100000
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
SdmmcInit=0 1
StorageInit ok = 67911
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
SecureInit ret = 0, SecureMode = 0
atags_set_bootdev: ret:(0)
GPT 0x3380ec0 signature is wrong
recovery gpt...
recovery gpt fail!
LoadTrust Addr:0x4000
No find bl30.bin
No find bl32.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x200000, size=0xdd6b0
RunBL31 0x40000
NOTICE:  BL31: v1.3(debug):42583b6
NOTICE:  BL31: Built : 07:55:13, Oct 15 2019
NOTICE:  BL31: Rockchip release version: v1.1
INFO:    GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3
INFO:    Using opteed sec cpu_context!
INFO:    boot cpu mask: 0
INFO:    plat_rockchip_pmu_init(1190): pd status 3e
INFO:    BL31: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s de
stined for OPTEE will return SMC_UNK
ERROR:   Error initializing runtime service opteed_fast
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x200000
INFO:    SPSR = 0x3c9
U-Boot 2020.07-armbian (Dec 15 2020 - 08:45:45 +0100)
SoC: Rockchip rk3399
Reset cause: POR
DRAM:  3.9 GiB
PMIC:  RK808
SF: Detected w25q128 with page size 256 Bytes, erase size 4 KiB, total 16 MiB
MMC:   mmc@fe320000: 1, sdhci@fe330000: 0
Loading Environment from MMC... *** Warning - bad CRC, using default environment
In:    serial
Out:   serial
Err:   serial
Model: Helios64
Revision: 1.2 - 4GB non ECC
Net:   eth0: ethernet@fe300000
scanning bus for devices...
Hit any key to stop autoboot:  0
Card did not respond to voltage select!
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1...
3185 bytes read in 18 ms (171.9 KiB/s)
## Executing script at 00500000
Wrong image format for "source" command
SCRIPT FAILED: continuing...
starting USB...
Bus usb@fe380000: USB EHCI 1.00
Bus dwc3: usb maximum-speed not found
Register 2000140 NbrPorts 2
Starting the controller
USB XHCI 1.10
scanning bus usb@fe380000 for devices... 1 USB Device(s) found
scanning bus dwc3 for devices... cannot reset port 4!?
4 USB Device(s) found
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
Retrieving file: pxelinux.cfg/C0A80187
Filename 'pxelinux.cfg/C0A80187'.
Filename 'pxelinux.cfg/C0A8018'.
Filename 'pxelinux.cfg/C0A801'.
Filename 'pxelinux.cfg/C0A80'.
Loading: T T
@qrthi it seems something wrong during writing to eMMC.
Your log show these lines
How did you write the image? We recommend to use Etcher because it has write verification.
The boot mode jumper only needed if for some reason the bootloader corrupted and to fix it you need to completely bypass the boot device.
If the bootloader (u-boot) just fine, it will load Armbian from the sdcard first.
Quote
Scanning mmc 0:1...
The "Card did not respond to voltage select" is because you removed the sdcard.
If you put Armbian sdcard, the lines would be
mmc1 is current device
Scanning mmc 1:1...
3185 bytes read in 6 ms (517.6 KiB/s)
Boot script loaded from mmc 1
My suggestion,
1. Download latest Armbian image.
2. Since you already have u-boot on your eMMC, no need to download and write the helios64_sdcard_u-boot-only.img.xz into sdcard.
3. Power on and enter UMS recovery mode
4. Write the image using Etcher. No need to extract the image. Etcher can handle it just fine.
5. Reboot Helios64.
