Boot from SDCard with root on NFS
tiagogb
Im trying to boot from network with ORPI-One-Plus, but seems to be no support for boot direct from u-boot.
is possible to boot (kernel, uboot) from sdcard, and leave only / (root) on NFS?
When i try to compile/boot only u-boot-sunxi-with-spl.bin
Quote
U-Boot SPL 2020.04-gc1ab7274 (Feb 14 2021 - 22:26:03 -0300)
DRAM: 1024 MiB
Trying to boot from MMC1
NOTICE:  BL31: v2.4(debug):v2.4-358-gd3e145b4c
NOTICE:  BL31: Built : 21:02:09, Feb 14 2021
NOTICE:  BL31: Detected Allwinner H6 SoC (1728)
NOTICE:  BL31: Found U-Boot DTB at 0xc083fb8, model: OrangePi One Plus
INFO:    ARM GICv2 driver initialized
INFO:    Configuring SPC Controller
INFO:    PMIC: Probing AXP805 on RSB
INFO:    PMIC: aldo1 voltage: 3.300V
INFO:    PMIC: aldo3 voltage: 3.300V
INFO:    PMIC: bldo1 voltage: 1.800V
INFO:    PMIC: bldo2 voltage: 1.800V
INFO:    PMIC: bldo3 voltage: 1.800V
INFO:    PMIC: cldo1 voltage: 3.300V
INFO:    PMIC: dcdcd voltage: 0.960V
INFO:    PMIC: dcdce voltage: 1.200V
INFO:    BL31: Platform setup done
INFO:    BL31: Initializing runtime services
INFO:    BL31: cortex_a53: CPU workaround for 855873 was applied
INFO:    BL31: cortex_a53: CPU workaround for 1530924 was applied
NOTICE:  PSCI: System suspend is unavailable
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x4a000000
INFO:    SPSR = 0x3c9
U-Boot 2020.04-gc1ab7274 (Feb 14 2021 - 22:26:03 -0300) Allwinner Technology
CPU:   Allwinner H6 (SUN50I)
Model: OrangePi One Plus
DRAM:  1 GiB
MMC:   mmc@4020000: 0
Loading Environment from FAT... Unable to use mmc 0:0... In:    serial@5000000
Out:   serial@5000000
Err:   serial@5000000
Net:   No ethernet found.
starting USB...
Bus usb@5101000: USB EHCI 1.00
Bus usb@5101400: USB OHCI 1.0
Bus usb@5311000: USB EHCI 1.00
Bus usb@5311400: USB OHCI 1.0
scanning bus usb@5101000 for devices... 1 USB Device(s) found
scanning bus usb@5101400 for devices... 1 USB Device(s) found
scanning bus usb@5311000 for devices... 1 USB Device(s) found
scanning bus usb@5311400 for devices... 1 USB Device(s) found
Autoboot in 2 seconds, press <Space> to stop
switch to partitions #0, OK
mmc0 is current device
** No partition table - mmc 0 **
Device 0: unknown device
No ethernet found.
missing environment variable: pxeuuid
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/00000000
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Retrieving file: pxelinux.cfg/default-arm-sunxi-sunxi
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Config file not found
No ethernet found.
No ethernet found.
I'm not aware of any direct NFS support in u-boot. Though that support may exist in recent versions.
However, initramfs-tools does support NFS, and you may consider using that instead.
So, you may want to make a local boot partition, even if your root is NFS. And all you'd need is u-boot, your kernel, initramfs, and DTB.
You might start looking into the "nfsroot" and "ip" options of initramfs-tools:
http://manpages.ubuntu.com/manpages/trusty/man8/initramfs-tools.8.html
