ploubi Posted March 2, 2021 Share Posted March 2, 2021 Hello, After I first installed my Helios64, I feared the 16Gb eMMC would be quickly filled. So when I used nand-sata-install, I chose to boot from eMMC but to have the root filesystem on a 500Gb sata drive. I have now second thoughts about it, since I realized that the OS take less than 8Gb, AND I'd like to add a 5th disk to my raid Halas nand-sata-install doesn't seem to work on an already moved filsystem. lsblk show this for the eMMC and the root partition peyo@helios64:~$ lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT sda 8:0 0 465,8G 0 disk └─sda1 8:1 0 465,8G 0 part / ... mmcblk2 179:0 0 14,6G 0 disk └─mmcblk2p1 179:1 0 14,4G 0 part /media/mmcboot And /etc/fstab shows this UUID=f2d7d6e7-902c-44dc-bdae-aedeb4495385 /media/mmcboot ext4 defaults,noatime,nodiratime,commit=600,errors=remount-ro,x-gvfs-hide 0 1 /media/mmcboot/boot /boot none bind 0 0 UUID=0fcd9a2c-9a46-4a5e-a0f5-e407bd34e8fb / ext4 defaults,noatime,nodiratime,commit=600,errors=remount-ro,x-gvfs-hide 0 1 ... And in /media I have this peyo@helios64:~$ ll /media/ total 8 drwxr-xr-x 3 root root 4096 déc. 6 11:31 mmcboot drwxr-xr-x 2 root root 4096 déc. 6 11:31 mmcroot Would it be so simple as 1 - rsync all that's on my present / (except for the NFS export and /tmp)? 2 - changin /etc/fstab to this UUID=f2d7d6e7-902c-44dc-bdae-aedeb4495385 / ext4 defaults,noatime,nodiratime,commit=600,errors=remount-ro,x-gvfs-hide 0 1 3 - reboot (with crossed fingers) Thanks for you help 1 Quote Link to comment Share on other sites More sharing options...
gprovost Posted March 3, 2021 Share Posted March 3, 2021 Yes unfortunately nand-sata-install does not work the other way around, I'm looking at it currently since there was another use case related to install on OS rootfs on HDD that wasn't also supported. The step for you case should be : 1. First boot the system on a microSD card with a fresh install of Armbian. 2. Copy rootfs from old destination (HDD) to new destination (eMMC) mkdir /mnt/rfs_new /mnt/rfs_old mount /dev/mmcblk2p1 /mnt/rfs_new/ mount /dev/sdX1 /mnt/rfs_old/ rsync -avrlt --delete --exclude-from=/usr/lib/nand-sata-install/exclude.txt /mnt/rfs_old/ /mnt/rfs_new/ 3. use command blkid to know the UUID of /dev/mmcblk2p1 4. Modify /mnt/rfs_new/boot/armbianEnv.txt to modify rootdev line with the UUID of /dev/mmcblk2p1 verbosity=1 bootlogo=false overlay_prefix=rockchip rootdev=UUID=075c8660-77ca-4048-a04b-be3364c60a40 rootfstype=ext4 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u 5. Modify /mnt/rfs_new/etc/fstab - Remove /media/mmcboot and /boot mount point lines - Edit / mount point to use the UUID of /dev/mmcblk2p1 # <file system> <mount point> <type> <options> <dump> <pass> tmpfs /tmp tmpfs defaults,nosuid 0 0 UUID=075c8660-77ca-4048-a04b-be3364c60a40 / ext4 defaults,noatime,nodiratime,commit=600,errors=remount-ro,x-gvfs-hide 0 1 6. Sync and Poweroff 7. Remove microSD and Poweron (maybe cross your finger also) 2 Quote Link to comment Share on other sites More sharing options...
ploubi Posted March 3, 2021 Author Share Posted March 3, 2021 (edited) Great thanks, I'll try that as soon as possible Update : Just did it, it worked like a charm, thanks a bunch! Edited March 4, 2021 by ploubi 0 Quote Link to comment Share on other sites More sharing options...
