capture codec i2s
Hi guys.  I would like at least 2 audio inputs and two audio outputs. I have a nanopi neo3 board, it has I2C and I2S and SPI bus available. Do you know if there are some drivers for  audio codec that could work with this board connecting directly the board pins (i2s bus) to codec. If yes can you tell me please which could I use, if not please can you tell me some tips to follow to build the bridge between the soc_rockchip_i2s and tlv320aic31xx (for example) or some other (codec) board available. Best regards.
