How I can free 64MB of RAM?
manuti
(Please moderator feel free to move this topic whatever you think that
Hi, I'm running Rosetta@home in a TV box, MXQ4K with Amlogic 905x is a 2GB RAM unit. When I start boinc, sometime I have tasks and other times I have this message?
boinc-client  25-Mar-2021 11:22:31 [Rosetta@home] Rosetta needs 1716.61 MB RAM but only 1654.12 MB is available for use.
Is there anyway to shave 64GB of RAM?
Is correct to have 1,7GB in a 2GB unit?
Is this RAM dedicated to the GPU? In this case. How I can reduce the amount of dedicated RAM?
I paste the armbianmonitor -U dump:
Spoiler
     1
     2    ### Activated 1 lzo zram swap devices with 870 MB each
     3
     4
     5    dom mar 21 00:17:31 CET 2021 | AML-S9xxx | 20.02.0-rc1.037 | arm64 | aarch64 | 5.5.0-rc6-aml-s9xxx
     6
     7    ### dmesg:
     8
     9    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
    10    [    0.000000] Linux version 5.5.0-rc6-aml-s9xxx (root@vbox) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #rc1.037 SMP PREEMPT Wed Feb 5 15:59:04 MSK 2020
    11    [    0.000000] Machine model: Amlogic Meson GXL (S905X) P212 Development Board
    12    [    0.000000] efi: Getting EFI parameters from FDT:
    13    [    0.000000] efi: UEFI not found.
    14    [    0.000000] Reserved memory: created CMA memory pool at 0x0000000063400000, size 256 MiB
    15    [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
    16    [    0.000000] On node 0 totalpages: 477952
    17    [    0.000000]   DMA zone: 4032 pages used for memmap
    18    [    0.000000]   DMA zone: 0 pages reserved
    19    [    0.000000]   DMA zone: 248576 pages, LIFO batch:63
    20    [    0.000000]   DMA32 zone: 3584 pages used for memmap
    21    [    0.000000]   DMA32 zone: 229376 pages, LIFO batch:63
    22    [    0.000000] psci: probing for conduit method from DT.
    23    [    0.000000] psci: PSCIv0.2 detected in firmware.
    24    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    25    [    0.000000] psci: Trusted OS migration not required
    26    [    0.000000] percpu: Embedded 22 pages/cpu s50392 r8192 d31528 u90112
    27    [    0.000000] pcpu-alloc: s50392 r8192 d31528 u90112 alloc=22*4096
    28    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
    29    [    0.000000] Detected VIPT I-cache on CPU0
    30    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 470336
    31    [    0.000000] Kernel command line: root=LABEL=ROOTFS rootflags=data=writeback rw console=ttyAML0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 mac=00:df:06:00:00:0b
    32    [    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    33    [    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
    34    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    35    [    0.000000] software IO TLB: mapped [mem 0x3bfff000-0x3ffff000] (64MB)
    36    [    0.000000] Memory: 1509616K/1911808K available (14460K kernel code, 1434K rwdata, 5884K rodata, 960K init, 927K bss, 140048K reserved, 262144K cma-reserved)
    37    [    0.000000] random: get_random_u64 called from cache_random_seq_create+0x7c/0x150 with crng_init=0
    38    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    39    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    40    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
    41    [    0.000000]     Tasks RCU enabled.
    42    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    43    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
    44    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    45    [    0.000000] GIC: Using split EOI/Deactivate mode
    46    [    0.000000] irq_meson_gpio: 110 to 8 gpio interrupt mux initialized
    47    [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
    48    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
    49    [    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
    50    [    0.000357] Console: colour dummy device 80x25
    51    [    0.000658] printk: console [tty0] enabled
    52    [    0.000698] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
    53    [    0.000719] pid_max: default: 32768 minimum: 301
    54    [    0.000843] LSM: Security Framework initializing
    55    [    0.000893] SELinux:  Initializing.
    56    [    0.000973] *** VALIDATE SELinux ***
    57    [    0.001041] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    58    [    0.001067] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    59    [    0.001130] *** VALIDATE tmpfs ***
    60    [    0.001535] *** VALIDATE proc ***
    61    [    0.001762] *** VALIDATE cgroup1 ***
    62    [    0.001776] *** VALIDATE cgroup2 ***
    63    [    0.024017] ASID allocator initialised with 32768 entries
    64    [    0.031999] rcu: Hierarchical SRCU implementation.
    65    [    0.042087] EFI services will not be available.
    66    [    0.048056] smp: Bringing up secondary CPUs ...
    67    [    0.080283] Detected VIPT I-cache on CPU1
    68    [    0.080336] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    69    [    0.112323] Detected VIPT I-cache on CPU2
    70    [    0.112367] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
    71    [    0.144371] Detected VIPT I-cache on CPU3
    72    [    0.144414] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
    73    [    0.144488] smp: Brought up 1 node, 4 CPUs
    74    [    0.144556] SMP: Total of 4 processors activated.
    75    [    0.144567] CPU features: detected: 32-bit EL0 Support
    76    [    0.144579] CPU features: detected: CRC32 instructions
    77    [    0.144883] CPU: All CPU(s) started at EL2
    78    [    0.144906] alternatives: patching kernel code
    79    [    0.146005] devtmpfs: initialized
    80    [    0.151132] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    81    [    0.151173] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
    82    [    0.158028] xor: measuring software checksum speed
    83    [    0.196372]    8regs     :  2375.000 MB/sec
    84    [    0.236403]    32regs    :  2724.000 MB/sec
    85    [    0.276440]    arm64_neon:  2406.000 MB/sec
    86    [    0.276451] xor: using function: 32regs (2724.000 MB/sec)
    87    [    0.276506] pinctrl core: initialized pinctrl subsystem
    88    [    0.277171] thermal_sys: Registered thermal governor 'step_wise'
    89    [    0.277344] DMI not present or invalid.
    90    [    0.277704] NET: Registered protocol family 16
    91    [    0.281247] DMA: preallocated 256 KiB pool for atomic allocations
    92    [    0.281298] audit: initializing netlink subsys (disabled)
    93    [    0.281510] audit: type=2000 audit(0.280:1): state=initialized audit_enabled=0 res=1
    94    [    0.282595] cpuidle: using governor ladder
    95    [    0.282635] cpuidle: using governor menu
    96    [    0.283005] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    97    [    0.283728] Serial: AMBA PL011 UART driver
    98    [    0.297742] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
    99    [    0.297768] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
   100    [    0.297782] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
   101    [    0.297794] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
   102    [    0.301475] cryptd: max_cpu_qlen set to 1000
   103    [    0.376663] raid6: neonx8   gen()  1620 MB/s
   104    [    0.444705] raid6: neonx8   xor()  1505 MB/s
   105    [    0.512768] raid6: neonx4   gen()  1564 MB/s
   106    [    0.580822] raid6: neonx4   xor()  1471 MB/s
   107    [    0.648903] raid6: neonx2   gen()  1199 MB/s
   108    [    0.716957] raid6: neonx2   xor()  1217 MB/s
   109    [    0.785006] raid6: neonx1   gen()   786 MB/s
   110    [    0.853091] raid6: neonx1   xor()   915 MB/s
   111    [    0.921101] raid6: int64x8  gen()  1194 MB/s
   112    [    0.989168] raid6: int64x8  xor()   769 MB/s
   113    [    1.057245] raid6: int64x4  gen()  1029 MB/s
   114    [    1.125290] raid6: int64x4  xor()   752 MB/s
   115    [    1.193323] raid6: int64x2  gen()   728 MB/s
   116    [    1.261407] raid6: int64x2  xor()   615 MB/s
   117    [    1.329515] raid6: int64x1  gen()   486 MB/s
   118    [    1.397467] raid6: int64x1  xor()   468 MB/s
   119    [    1.397477] raid6: using algorithm neonx8 gen() 1620 MB/s
   120    [    1.397487] raid6: .... xor() 1505 MB/s, rmw enabled
   121    [    1.397498] raid6: using neon recovery algorithm
   122    [    1.397743] ACPI: Interpreter disabled.
   123    [    1.398940] iommu: Default domain type: Translated
   124    [    1.399209] vgaarb: loaded
   125    [    1.399757] SCSI subsystem initialized
   126    [    1.399934] libata version 3.00 loaded.
   127    [    1.400144] usbcore: registered new interface driver usbfs
   128    [    1.400192] usbcore: registered new interface driver hub
   129    [    1.400255] usbcore: registered new device driver usb
   130    [    1.400657] pps_core: LinuxPPS API ver. 1 registered
   131    [    1.400670] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
   132    [    1.400696] PTP clock support registered
   133    [    1.400724] EDAC MC: Ver: 3.0.0
   134    [    1.401299] FPGA manager framework
   135    [    1.401422] Advanced Linux Sound Architecture Driver Initialized.
   136    [    1.401892] NetLabel: Initializing
   137    [    1.401904] NetLabel:  domain hash size = 128
   138    [    1.401913] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
   139    [    1.401967] NetLabel:  unlabeled traffic allowed by default
   140    [    1.402449] clocksource: Switched to clocksource arch_sys_counter
   141    [    1.402471] *** VALIDATE bpf ***
   142    [    1.402725] VFS: Disk quotas dquot_6.6.0
   143    [    1.402785] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
   144    [    1.402914] FS-Cache: Loaded
   145    [    1.402924] *** VALIDATE ramfs ***
   146    [    1.402945] *** VALIDATE hugetlbfs ***
   147    [    1.403322] pnp: PnP ACPI: disabled
   148    [    1.408351] NET: Registered protocol family 2
   149    [    1.408850] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
   150    [    1.408895] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
   151    [    1.409012] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
   152    [    1.409232] TCP: Hash tables configured (established 16384 bind 16384)
   153    [    1.409392] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
   154    [    1.409444] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
   155    [    1.409668] NET: Registered protocol family 1
   156    [    1.410112] RPC: Registered named UNIX socket transport module.
   157    [    1.410133] RPC: Registered udp transport module.
   158    [    1.410143] RPC: Registered tcp transport module.
   159    [    1.410152] RPC: Registered tcp NFSv4.1 backchannel transport module.
   160    [    1.410168] NET: Registered protocol family 44
   161    [    1.410189] PCI: CLS 0 bytes, default 64
   162    [    1.410384] Trying to unpack rootfs image as initramfs...
   163    [    1.871991] Freeing initrd memory: 10248K
   164    [    1.872788] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
   165    [    2.086160] Initialise system trusted keyrings
   166    [    2.086373] workingset: timestamp_bits=46 max_order=19 bucket_order=0
   167    [    2.091523] zbud: loaded
   168    [    2.092745] squashfs: version 4.0 (2009/01/31) Phillip Lougher
   169    [    2.093051] FS-Cache: Netfs 'nfs' registered for caching
   170    [    2.093577] NFS: Registering the id_resolver key type
   171    [    2.093613] Key type id_resolver registered
   172    [    2.093623] Key type id_legacy registered
   173    [    2.093640] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
   174    [    2.093652] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
   175    [    2.094834] FS-Cache: Netfs 'cifs' registered for caching
   176    [    2.095176] Key type cifs.spnego registered
   177    [    2.095199] Key type cifs.idmap registered
   178    [    2.095223] ntfs: driver 2.1.32 [Flags: R/W].
   179    [    2.095810] JFS: nTxBlock = 8192, nTxLock = 65536
   180    [    2.101758] SGI XFS with ACLs, security attributes, realtime, quota, no debug enabled
   181    [    2.103205] *** VALIDATE xfs ***
   182    [    2.103493] ocfs2: Registered cluster interface o2cb
   183    [    2.103717] OCFS2 User DLM kernel interface loaded
   184    [    2.105117] *** VALIDATE gfs2 ***
   185    [    2.105401] gfs2: GFS2 installed
   186    [    2.106305] aufs 5.5-20200203
   187    [    2.127122] Key type asymmetric registered
   188    [    2.127147] Asymmetric key parser 'x509' registered
   189    [    2.127157] Asymmetric key parser 'pkcs8' registered
   190    [    2.127228] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
   191    [    2.127431] io scheduler mq-deadline registered
   192    [    2.127446] io scheduler kyber registered
   193    [    2.127639] io scheduler bfq registered
   194    [    2.140178] soc soc0: Amlogic Meson GXL (S905X) Revision 21:b (82:2) Detected
   195    [    2.143753] Serial: 8250/16550 driver, 5 ports, IRQ sharing enabled
   196    [    2.145442] Serial: AMBA driver
   197    [    2.145810] c11084c0.serial: ttyAML6 at MMIO 0xc11084c0 (irq = 10, base_baud = 1500000) is a meson_uart
   198    [    2.145963] serial serial0: tty port ttyAML6 registered
   199    [    2.146175] c81004c0.serial: ttyAML0 at MMIO 0xc81004c0 (irq = 13, base_baud = 1500000) is a meson_uart
   200    [    3.121643] printk: console [ttyAML0] enabled
   201    [    3.137733] brd: module loaded
   202    [    3.146278] loop: module loaded
   203    [    3.148724] libphy: Fixed MDIO Bus: probed
   204    [    3.149372] meson8b-dwmac c9410000.ethernet: IRQ eth_wake_irq not found
   205    [    3.154490] meson8b-dwmac c9410000.ethernet: IRQ eth_lpi not found
   206    [    3.160659] meson8b-dwmac c9410000.ethernet: PTP uses main clock
   207    [    3.166503] meson8b-dwmac c9410000.ethernet: no reset control found
   208    [    3.173207] meson8b-dwmac c9410000.ethernet: User ID: 0x11, Synopsys ID: 0x37
   209    [    3.179791] meson8b-dwmac c9410000.ethernet:     DWMAC1000
   210    [    3.184956] meson8b-dwmac c9410000.ethernet: DMA HW capability register supported
   211    [    3.192371] meson8b-dwmac c9410000.ethernet: RX Checksum Offload Engine supported
   212    [    3.199788] meson8b-dwmac c9410000.ethernet: COE Type 2
   213    [    3.204962] meson8b-dwmac c9410000.ethernet: TX Checksum insertion supported
   214    [    3.211949] meson8b-dwmac c9410000.ethernet: Wake-Up On Lan supported
   215    [    3.218362] meson8b-dwmac c9410000.ethernet: Normal descriptors
   216    [    3.224197] meson8b-dwmac c9410000.ethernet: Ring mode enabled
   217    [    3.229975] meson8b-dwmac c9410000.ethernet: Enable RX Mitigation via HW Watchdog Timer
   218    [    3.238093] libphy: stmmac: probed
   219    [    3.242604] VFIO - User Level meta-driver version: 0.3
   220    [    3.247889] dwc3 c9000000.dwc3: Failed to get clk 'ref': -2
   221    [    3.252824] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
   222    [    3.258383] ehci-pci: EHCI PCI platform driver
   223    [    3.262821] ehci-platform: EHCI generic platform driver
   224    [    3.268118] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
   225    [    3.274064] ohci-pci: OHCI PCI platform driver
   226    [    3.278498] ohci-platform: OHCI generic platform driver
   227    [    3.284238] usbcore: registered new interface driver usb-storage
   228    [    3.289806] mousedev: PS/2 mouse device common for all mice
   229    [    3.295758] i2c /dev entries driver
   230    [    3.301360] sdhci: Secure Digital Host Controller Interface driver
   231    [    3.304684] sdhci: Copyright(c) Pierre Ossman
   232    [    3.308998] Synopsys Designware Multimedia Card Interface Driver
   233    [    3.316270] meson-gx-mmc d0072000.mmc: Got CD GPIO
   234    [    3.346815] meson-gx-mmc d0074000.mmc: allocated mmc-pwrseq
   235    [    3.374325] sdhci-pltfm: SDHCI platform and OF driver helper
   236    [    3.375509] ledtrig-cpu: registered to indicate activity on CPUs
   237    [    3.380905] meson-sm: secure-monitor enabled
   238    [    3.385180] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
   239    [    3.386535] mmc0: new high speed SDHC card at address 59b4
   240    [    3.392509] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
   241    [    3.398655] mmcblk0: mmc0:59b4 SDU1  29.5 GiB
   242    [    3.416709]  mmcblk0: p1 p2
   243    [    3.422890] hid: raw HID events driver (C) Jiri Kosina
   244    [    3.423124] usbcore: registered new interface driver usbhid
   245    [    3.428032] usbhid: USB HID core driver
   246    [    3.432100] platform-mhu c883c404.mailbox: Platform MHU Mailbox registered
   247    [    3.449062] NET: Registered protocol family 17
   248    [    3.449316] Key type dns_resolver registered
   249    [    3.452656] registered taskstats version 1
   250    [    3.456205] Loading compiled-in X.509 certificates
   251    [    3.461156] zswap: loaded using pool lzo/zbud
   252    [    3.465437] Key type ._fscrypt registered
   253    [    3.469201] Key type .fscrypt registered
   254    [    3.474133] Btrfs loaded, crc32c=crc32c-generic
   255    [    3.496556] mmc1: new HS200 MMC card at address 0001
   256    [    3.497451] mmcblk1: mmc1:0001 016G92 14.7 GiB
   257    [    3.500892] mmcblk1boot0: mmc1:0001 016G92 partition 1 4.00 MiB
   258    [    3.502047] Key type encrypted registered
   259    [    3.506766] mmcblk1boot1: mmc1:0001 016G92 partition 2 4.00 MiB
   260    [    3.516603] mmcblk1gp0: mmc1:0001 016G92 partition 4 8.00 MiB
   261    [    3.522126] mmcblk1rpmb: mmc1:0001 016G92 partition 3 512 KiB, chardev (243:0)
   262    [    3.529870] meson-drm d0100000.vpu: Queued 3 outputs on vpu
   263    [    3.534840] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
   264    [    3.541118] [drm] No driver support for vblank timestamp query.
   265    [    3.574515] meson-dw-hdmi c883a000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
   266    [    3.579233] meson-dw-hdmi c883a000.hdmi-tx: registered DesignWare HDMI I2C bus driver
   267    [    3.587184] meson-drm d0100000.vpu: bound c883a000.hdmi-tx (ops meson_dw_hdmi_ops)
   268    [    3.594541] [drm] Initialized meson 1.0.0 20161109 for d0100000.vpu on minor 0
   269    [    3.631355] Console: switching to colour frame buffer device 90x36
   270    [    3.651576] meson-drm d0100000.vpu: fb0: mesondrmfb frame buffer device
   271    [    3.658841] libphy: mdio_mux: probed
   272    [    3.669389] libphy: mdio_mux: probed
   273    [    3.669879] phy phy-d0078080.phy.2: unsupported PHY mode 5
   274    [    3.674927] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
   275    [    3.678308] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
   276    [    3.686022] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228f664 hci version 0x100 quirks 0x0000000002010010
   277    [    3.695262] xhci-hcd xhci-hcd.0.auto: irq 39, io mem 0xc9000000
   278    [    3.701356] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.05
   279    [    3.709727] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   280    [    3.716869] usb usb1: Product: xHCI Host Controller
   281    [    3.721696] usb usb1: Manufacturer: Linux 5.5.0-rc6-aml-s9xxx xhci-hcd
   282    [    3.728169] usb usb1: SerialNumber: xhci-hcd.0.auto
   283    [    3.733493] hub 1-0:1.0: USB hub found
   284    [    3.736745] hub 1-0:1.0: 2 ports detected
   285    [    3.740969] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
   286    [    3.746124] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
   287    [    3.753728] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
   288    [    3.760237] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
   289    [    3.768522] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.05
   290    [    3.776916] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   291    [    3.784072] usb usb2: Product: xHCI Host Controller
   292    [    3.788908] usb usb2: Manufacturer: Linux 5.5.0-rc6-aml-s9xxx xhci-hcd
   293    [    3.795373] usb usb2: SerialNumber: xhci-hcd.0.auto
   294    [    3.800681] hub 2-0:1.0: USB hub found
   295    [    3.803950] hub 2-0:1.0: config failed, hub doesn't have any ports! (err -19)
   296    [    3.812806] meson-gx-mmc d0070000.mmc: allocated mmc-pwrseq
   297    [    3.843446] scpi_protocol scpi: SCP Protocol legacy pre-1.0 firmware
   298    [    3.860311] gx-sound-card sound: snd-soc-dummy-dai <-> c1105400.bus:audio-controller-0 mapping ok
   299    [    3.872049] gx-sound-card sound: i2s-hifi <-> c1105400.bus:audio-controller-2 mapping ok
   300    [    3.879785] gx-sound-card sound: ASoC: no DMI vendor name!
   301    [    3.885960] printk: console [netcon0] enabled
   302    [    3.889372] netconsole: network logging started
   303    [    3.893930] hctosys: unable to open rtc device (rtc0)
   304    [    3.899408] ALSA device list:
   305    [    3.901959]   #0: AMLGX
   306    [    3.905031] Freeing unused kernel memory: 960K
   307    [    3.908791] Run /init as init process
   308    [    3.920297] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
   309    [    3.926571] mmc2: queuing unknown CIS tuple 0x80 (6 bytes)
   310    [    3.933111] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
   311    [    3.945261] mmc2: queuing unknown CIS tuple 0x80 (19 bytes)
   312    [    3.970942] random: fast init done
   313    [    4.031650] mmc2: new high speed SDIO card at address 0001
   314    [    4.074519] usb 1-1: new high-speed USB device number 2 using xhci-hcd
   315    [    4.095824] usb 1-1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.36
   316    [    4.102658] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
   317    [    4.110273] usb 1-1: Product: USB2.0 Hub
   318    [    4.176691] hub 1-1:1.0: USB hub found
   319    [    4.179315] hub 1-1:1.0: 4 ports detected
   320    [    4.310532] usb 1-2: new high-speed USB device number 3 using xhci-hcd
   321    [    4.341017] usb 1-2: New USB device found, idVendor=148f, idProduct=7601, bcdDevice= 0.00
   322    [    4.347976] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
   323    [    4.355838] usb 1-2: Product: 802.11 n WLAN
   324    [    4.359565] usb 1-2: Manufacturer: MediaTek
   325    [    4.363631] usb 1-2: SerialNumber: 1.0
   326    [    5.110138] EXT4-fs (mmcblk0p2): mounted filesystem with writeback data mode. Opts: data=writeback
   327    [    6.052807] systemd[1]: System time before build time, advancing clock.
   328    [    6.200507] NET: Registered protocol family 10
   329    [    6.274520] Segment Routing with IPv6
   330    [    6.325154] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
   331    [    6.358527] systemd[1]: Detected architecture arm64.
   332    [    6.413903] systemd[1]: Set hostname to <mxqpro>.
   333    [    6.447693] systemd[1]: Couldn't move remaining userspace processes, ignoring: Input/output error
   334    [    7.138797] random: systemd: uninitialized urandom read (16 bytes read)
   335    [    7.153425] random: systemd: uninitialized urandom read (16 bytes read)
   336    [    7.156998] systemd[1]: Reached target Remote File Systems.
   337    [    7.165768] random: systemd: uninitialized urandom read (16 bytes read)
   338    [    7.169563] systemd[1]: Listening on initctl Compatibility Named Pipe.
   339    [    7.179002] systemd[1]: Listening on udev Kernel Socket.
   340    [    7.184570] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
   341    [    7.192779] systemd[1]: Listening on Syslog Socket.
   342    [    7.201447] systemd[1]: Created slice system-serial\x2dgetty.slice.
   343    [    7.429845] EXT4-fs (mmcblk0p2): re-mounted. Opts: commit=600,errors=remount-ro
   344    [    7.628140] systemd-journald[411]: Received request to flush runtime journal from PID 1
   345    [    8.125525] mc: Linux media interface: v0.10
   346    [    8.151775] videodev: Linux video capture interface: v2.00
   347    [    8.166795] Registered IR keymap rc-empty
   348    [    8.169397] rc rc0: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0
   349    [    8.186083] input: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0/input0
   350    [    8.197729] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
   351    [    8.208339] meson-ir c8100580.ir: receiver initialized
   352    [    8.308327] lima d00c0000.gpu: IRQ ppmmu3 not found
   353    [    8.310996] lima d00c0000.gpu: IRQ ppmmu4 not found
   354    [    8.314707] lima d00c0000.gpu: IRQ ppmmu5 not found
   355    [    8.319537] lima d00c0000.gpu: IRQ ppmmu6 not found
   356    [    8.324389] lima d00c0000.gpu: IRQ ppmmu7 not found
   357    [    8.334645] lima d00c0000.gpu: gp - mali450 version major 0 minor 0
   358    [    8.337703] lima d00c0000.gpu: pp0 - mali450 version major 0 minor 0
   359    [    8.346755] lima d00c0000.gpu: pp1 - mali450 version major 0 minor 0
   360    [    8.350021] lima d00c0000.gpu: pp2 - mali450 version major 0 minor 0
   361    [    8.359370] lima d00c0000.gpu: IRQ pp3 not found
   362    [    8.361255] lima d00c0000.gpu: IRQ pp4 not found
   363    [    8.365744] lima d00c0000.gpu: IRQ pp5 not found
   364    [    8.370349] lima d00c0000.gpu: IRQ pp6 not found
   365    [    8.374849] lima d00c0000.gpu: IRQ pp7 not found
   366    [    8.379326] lima d00c0000.gpu: l2 cache 8K, 4-way, 64byte cache line, 128bit external bus
   367    [    8.387575] lima d00c0000.gpu: l2 cache 64K, 4-way, 64byte cache line, 128bit external bus
   368    [    8.395757] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
   369    [    8.414186] lima d00c0000.gpu: bus rate = 166666667
   370    [    8.417450] lima d00c0000.gpu: mod rate = 744000000
   371    [    8.425573] [drm] Initialized lima 1.0.0 20190217 for d00c0000.gpu on minor 1
   372    [    8.432277] Bluetooth: Core ver 2.22
   373    [    8.434596] NET: Registered protocol family 31
   374    [    8.436947] Bluetooth: HCI device and connection manager initialized
   375    [    8.445229] Bluetooth: HCI socket layer initialized
   376    [    8.449221] Bluetooth: L2CAP socket layer initialized
   377    [    8.453394] Bluetooth: SCO socket layer initialized
   378    [    8.575514] cfg80211: Loading compiled-in X.509 certificates for regulatory database
   379    [    8.581098] Bluetooth: HCI UART driver ver 2.3
   380    [    8.592788] Bluetooth: HCI UART protocol H4 registered
   381    [    8.594644] Bluetooth: HCI UART protocol BCSP registered
   382    [    8.599514] Bluetooth: HCI UART protocol LL registered
   383    [    8.604491] Bluetooth: HCI UART protocol ATH3K registered
   384    [    8.610028] Bluetooth: HCI UART protocol Three-wire (H5) registered
   385    [    8.616590] Bluetooth: HCI UART protocol Intel registered
   386    [    8.629866] Bluetooth: HCI UART protocol Broadcom registered
   387    [    8.630006] hci_uart_bcm serial0-0: serial0-0 supply vbat not found, using dummy regulator
   388    [    8.631847] Bluetooth: HCI UART protocol QCA registered
   389    [    8.642148] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
   390    [    8.645138] Bluetooth: HCI UART protocol AG6XX registered
   391    [    8.651762] hci_uart_bcm serial0-0: serial0-0 supply vddio not found, using dummy regulator
   392    [    8.657080] Bluetooth: HCI UART protocol Marvell registered
   393    [    8.683291] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
   394    [    8.690778] cfg80211: failed to load regulatory.db
   395    [    8.794743] brcmfmac: F1 signature read @0x18000000=0x16034334
   396    [    8.798059] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4334-sdio for chip BCM4334/3
   397    [    8.805682] usbcore: registered new interface driver brcmfmac
   398    [    8.855976] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.amlogic,p212.txt failed with error -2
   399    [    8.866189] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.txt failed with error -2
   400    [    8.942799] usb 1-2: reset high-speed USB device number 3 using xhci-hcd
   401    [    8.965572] mt7601u 1-2:1.0: ASIC revision: 76010001 MAC revision: 76010500
   402    [    9.008611] mt7601u 1-2:1.0: EEPROM ver:0d fae:00
   403    [    9.051512] Bluetooth: hci0: BCM: chip id 68
   404    [    9.055464] Bluetooth: hci0: BCM: features 0x0f
   405    [    9.060643] Bluetooth: hci0: BCM4334B0
   406    [    9.063489] Bluetooth: hci0: BCM4334B0 (002.001.013) build 0000
   407    [    9.067647] bluetooth hci0: Direct firmware load for brcm/BCM4334B0.hcd failed with error -2
   408    [    9.075959] Bluetooth: hci0: BCM: Patch brcm/BCM4334B0.hcd not found
   409    [    9.223051] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
   410    [    9.225005] usbcore: registered new interface driver mt7601u
   411    [    9.878553] brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x50
   412    [    9.908340] zram: Added device: zram0
   413    [    9.911823] zram: Added device: zram1
   414    [    9.927131] zram: Added device: zram2
   415    [    9.975264] zram1: detected capacity change from 0 to 912879616
   416    [    9.993267] meson8b-dwmac c9410000.ethernet eth0: PHY [0.e40908ff:08] driver [Meson GXL Internal PHY]
   417    [   10.014535] meson8b-dwmac c9410000.ethernet eth0: No Safety Features support found
   418    [   10.019869] meson8b-dwmac c9410000.ethernet eth0: PTP not supported by HW
   419    [   10.019881] meson8b-dwmac c9410000.ethernet eth0: configuring for phy/rmii link mode
   420    [   10.596915] random: crng init done
   421    [   10.599535] random: 7 urandom warning(s) missed due to ratelimiting
   422    [   10.682808] Adding 891480k swap on /dev/zram1.  Priority:5 extents:1 across:891480k SSFS
   423
   424    ### armbian-release:
   425
   426    # PLEASE DO NOT EDIT THIS FILE
   427    BOARD=aml-s9xxx
   428    BOARD_NAME="AML-S9xxx"
   429    BOARDFAMILY=aml-s9xxx
   430    BUILD_REPOSITORY_URL=https://github.com/150balbes/Build-Armbian.git
   431    BUILD_REPOSITORY_COMMIT=62b8c07-dirty
   432    DISTRIBUTION_CODENAME=buster
   433    DISTRIBUTION_STATUS=supported
   434    VERSION=20.02.0-rc1.037
   435    LINUXFAMILY=aml-s9xxx
   436    BRANCH=current
   437    ARCH=arm64
   438    IMAGE_TYPE=nightly
   439    BOARD_TYPE=conf
   440    INITRD_ARCH=arm64
   441    KERNEL_IMAGE_TYPE=Image
   442
   443    ### boot environment:
   444
   445    ODROIDN2-UBOOT-CONFIG
   446    setenv env_addr 0x10400000
   447    setenv kernel_addr 0x11000000
   448    setenv initrd_addr 0x13000000
   449    setenv dtb_addr 0x1000000
   450    if test "${devtype}" = ""; then setenv devtype "mmc"; fi
   451    load ${devtype} ${devnum} ${env_addr} uEnv.txt && env import -t ${env_addr} ${filesize}
   452    setenv bootargs ${APPEND}
   453    load ${devtype} ${devnum} ${kernel_addr} ${LINUX}
   454    load ${devtype} ${devnum} ${initrd_addr} ${INITRD}
   455    load ${devtype} ${devnum} ${dtb_addr} ${FDT}
   456    fdt addr ${dtb_addr}
   457    booti ${kernel_addr} ${initrd_addr} ${dtb_addr}
   458
   459    ### lsusb:
   460
   461    Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
   462    Bus 001 Device 003: ID 148f:7601 Ralink Technology, Corp. MT7601U Wireless Adapter
   463    Bus 001 Device 002: ID 05e3:0608 Genesys Logic, Inc. Hub
   464    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
   465
   466    ### lscpu:
   467
   468    Architecture:        aarch64
   469    Byte Order:          Little Endian
   470    CPU(s):              4
   471    On-line CPU(s) list: 0-3
   472    Thread(s) per core:  1
   473    Core(s) per socket:  4
   474    Socket(s):           1
   475    Vendor ID:           ARM
   476    Model:               4
   477    Model name:          Cortex-A53
   478    Stepping:            r0p4
   479    CPU max MHz:         1512,0000
   480    CPU min MHz:         100,0000
   481    BogoMIPS:            48.00
   482    L1d cache:           unknown size
   483    L1i cache:           unknown size
   484    L2 cache:            unknown size
   485    Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
   486
   487    ### cpuinfo:
   488
   489    processor    : 0
   490    model name    : ARMv8 Processor rev 4 (v8l)
   491    BogoMIPS    : 48.00
   492    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
   493    CPU implementer    : 0x41
   494    CPU architecture: 8
   495    CPU variant    : 0x0
   496    CPU part    : 0xd03
   497    CPU revision    : 4
   498
   499    processor    : 1
   500    model name    : ARMv8 Processor rev 4 (v8l)
   501    BogoMIPS    : 48.00
   502    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
   503    CPU implementer    : 0x41
   504    CPU architecture: 8
   505    CPU variant    : 0x0
   506    CPU part    : 0xd03
   507    CPU revision    : 4
   508
   509    processor    : 2
   510    model name    : ARMv8 Processor rev 4 (v8l)
   511    BogoMIPS    : 48.00
   512    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
   513    CPU implementer    : 0x41
   514    CPU architecture: 8
   515    CPU variant    : 0x0
   516    CPU part    : 0xd03
   517    CPU revision    : 4
   518
   519    processor    : 3
   520    model name    : ARMv8 Processor rev 4 (v8l)
   521    BogoMIPS    : 48.00
   522    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
   523    CPU implementer    : 0x41
   524    CPU architecture: 8
   525    CPU variant    : 0x0
   526    CPU part    : 0xd03
   527    CPU revision    : 4
   528
   529
   530    ### meminfo:
   531
   532    MemTotal:        1782968 kB
   533    MemFree:         1609176 kB
   534    MemAvailable:    1666708 kB
   535    Buffers:           11832 kB
   536    Cached:            54040 kB
   537    SwapCached:            0 kB
   538    Active:            52492 kB
   539    Inactive:          34792 kB
   540    Active(anon):      21768 kB
   541    Inactive(anon):     2588 kB
   542    Active(file):      30724 kB
   543    Inactive(file):    32204 kB
   544    Unevictable:           0 kB
   545    Mlocked:               0 kB
   546    SwapTotal:        891480 kB
   547    SwapFree:         891480 kB
   548    Dirty:               708 kB
   549    Writeback:             0 kB
   550    AnonPages:         21532 kB
   551    Mapped:            21964 kB
   552    Shmem:              2688 kB
   553    KReclaimable:      17720 kB
   554    Slab:              52844 kB
   555    SReclaimable:      17720 kB
   556    SUnreclaim:        35124 kB
   557    KernelStack:        2752 kB
   558    PageTables:         1452 kB
   559    NFS_Unstable:          0 kB
   560    Bounce:                0 kB
   561    WritebackTmp:          0 kB
   562    CommitLimit:     1782964 kB
   563    Committed_AS:      53988 kB
   564    VmallocTotal:   135290159040 kB
   565    VmallocUsed:       16696 kB
   566    VmallocChunk:          0 kB
   567    Percpu:             1264 kB
   568    CmaTotal:         262144 kB
   569    CmaFree:          258460 kB
   570    HugePages_Total:       0
   571    HugePages_Free:        0
   572    HugePages_Rsvd:        0
   573    HugePages_Surp:        0
   574    Hugepagesize:       2048 kB
   575    Hugetlb:               0 kB
   576
   577    ### virtual memory:
   578
   579    vm.admin_reserve_kbytes = 8192
   580    vm.block_dump = 0
   581    vm.compact_unevictable_allowed = 1
   582    vm.dirty_background_bytes = 0
   583    vm.dirty_background_ratio = 10
   584    vm.dirty_bytes = 0
   585    vm.dirty_expire_centisecs = 3000
   586    vm.dirty_ratio = 20
   587    vm.dirtytime_expire_seconds = 43200
   588    vm.dirty_writeback_centisecs = 500
   589    vm.extfrag_threshold = 500
   590    vm.hugetlb_shm_group = 0
   591    vm.laptop_mode = 0
   592    vm.legacy_va_layout = 0
   593    vm.lowmem_reserve_ratio = 256    256    32    0
   594    vm.max_map_count = 65530
   595    vm.min_free_kbytes = 4914
   596    vm.mmap_min_addr = 4096
   597    vm.mmap_rnd_bits = 18
   598    vm.nr_hugepages = 0
   599    vm.nr_overcommit_hugepages = 0
   600    vm.oom_dump_tasks = 1
   601    vm.oom_kill_allocating_task = 0
   602    vm.overcommit_kbytes = 0
   603    vm.overcommit_memory = 0
   604    vm.overcommit_ratio = 50
   605    vm.page-cluster = 0
   606    vm.panic_on_oom = 0
   607    vm.percpu_pagelist_fraction = 0
   608    vm.stat_interval = 1
   609    vm.swappiness = 100
   610    vm.user_reserve_kbytes = 55239
   611    vm.vfs_cache_pressure = 100
   612    vm.watermark_boost_factor = 15000
   613    vm.watermark_scale_factor = 10
   614
   615    ### ip addr:
   616
   617    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
   618        link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
   619        inet XXX.XXX.0.1/8 scope host lo
   620           valid_lft forever preferred_lft forever
   621        inet6 ::1/128 scope host
   622           valid_lft forever preferred_lft forever
   623    2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
   624        link/ether 00:df:06:00:00:0b brd ff:ff:ff:ff:ff:ff
   625    3: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
   626        link/ether 00:36:76:61:0b:24 brd ff:ff:ff:ff:ff:ff
   627
   628    ### partitions:
   629
   630    major minor  #blocks  name
   631
   632     179        0   30924800 mmcblk0
   633     179        1     262144 mmcblk0p1
   634     179        2   30337024 mmcblk0p2
   635     179       32   15384576 mmcblk1
   636     179      128       8192 mmcblk1gp0
   637     254        1     891484 zram1
   638
   639    ### df:
   640
   641    udev             738M      0  738M   0% /dev
   642    tmpfs            175M   2,7M  172M   2% /run
   643    /dev/mmcblk0p2    29G    10G   19G  36% /
   644    tmpfs            871M      0  871M   0% /dev/shm
   645    tmpfs            5,0M   4,0K  5,0M   1% /run/lock
   646    tmpfs            871M      0  871M   0% /sys/fs/cgroup
   647    tmpfs            871M      0  871M   0% /tmp
   648    /dev/mmcblk0p1   256M    76M  180M  30% /boot
   649
   650    ### lsblk:
   651
   652    NAME         FSTYPE   SIZE MOUNTPOINT UUID
   653    mmcblk0              29,5G
   654    ├─mmcblk0p1  vfat     256M /boot      50FC-6AC8
   655    └─mmcblk0p2  ext4      29G /          3e297ac1-e4e4-4ab1-bc57-47c07d0422ba
   656    mmcblk1              14,7G
   657    mmcblk1boot0            4M
   658    mmcblk1boot1            4M
   659    mmcblk1gp0              8M
   660
   661    ### zramctl:
   662
   663    NAME       ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT
   664    /dev/zram1 lzo         870,6M   4K   81B   12K       4 [SWAP]
   665
   666    ### mtab:
   667
   668    /dev/mmcblk0p1 /boot vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro 0 0
   669    /dev/mmcblk0p2 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
   670
   671    ### mmc0:59b4 info:
   672
   673                   fwrev: 0x0
   674                  uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SDU1  MODALIAS=mmc:block
   675                     cid: 1b534d53445531201014a136d4013800
   676                     rca: 0x59b4
   677                     csd: 400e00325b590000ebef7f800a400000
   678                  manfid: 0x00001b
   679                     ocr: 0x00200000
   680    preferred_erase_size: 4194304
   681                    type: SD
   682                   hwrev: 0x1
   683                    date: 08/2019
   684                     dsr: 0x404
   685              erase_size: 512
   686                   oemid: 0x534d
   687                  serial: 0x14a136d4
   688                     ssr: 0000000005000000040090000811391e00089a342f01000000000000000000000000000000000000000000000000000000000000000000000000000000000000
   689                     scr: 0235844300000000
   690                    name: SDU1
   691
   692    ### mmc1:0001 info:
   693
   694                   fwrev: 0x0
   695                  uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=016G92 MODALIAS=mmc:block
   696                     cid: 11010030313647393201d3d1a4db1100
   697             rel_sectors: 0x10
   698                     rca: 0x0001
   699            pre_eol_info: 0x00
   700                     csd: d00e00320f5903ffffffffef92400000
   701                  manfid: 0x000011
   702                     ocr: 0x00200000
   703    preferred_erase_size: 4194304
   704    enhanced_area_offset: 18446744073709551594
   705      raw_rpmb_size_mult: 0x4
   706                    type: MMC
   707                   hwrev: 0x0
   708                    date: 01/2014
   709                     prv: 0x1
   710             ffu_capable: 0
   711                     dsr: 0x404
   712              erase_size: 4194304
   713               life_time: 0x00 0x00
   714      enhanced_area_size: 4294967274
   715                   oemid: 0x0100
   716                  serial: 0xd3d1a4db
   717                 cmdq_en: 0
   718                     rev: 0x6
   719                    name: 016G92
   720
   721    ### Boot system health:
   722
   723    Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU
   724    00:17:34: 1512MHz  0.39  52%  24%  15%   0%  11%   1% 41.0°C
   725    00:17:34: 1512MHz  0.39  73%  11%  18%   1%  40%   2% 42.0°C
   726    00:17:34: 1512MHz  0.39  68%  13%  20%   1%  31%   2% 41.0°C
   727    00:17:35: 1512MHz  0.39  52%   7%  11%   0%  30%   1% 41.0°C
   728    00:17:35: 1512MHz  0.39  42%   8%   8%   0%  23%   1% 40.0°C
   729
   730    ### Activated 1 lzo zram swap devices with 870 MB each
   731
   732
   733    lun mar 22 07:51:53 CET 2021 | AML-S9xxx | 20.02.0-rc1.037 | arm64 | aarch64 | 5.5.0-rc6-aml-s9xxx
   734
   735    ### dmesg:
   736
   737    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
   738    [    0.000000] Linux version 5.5.0-rc6-aml-s9xxx (root@vbox) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #rc1.037 SMP PREEMPT Wed Feb 5 15:59:04 MSK 2020
   739    [    0.000000] Machine model: Amlogic Meson GXL (S905X) P212 Development Board
   740    [    0.000000] efi: Getting EFI parameters from FDT:
   741    [    0.000000] efi: UEFI not found.
   742    [    0.000000] Reserved memory: created CMA memory pool at 0x0000000063400000, size 256 MiB
   743    [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
   744    [    0.000000] On node 0 totalpages: 477952
   745    [    0.000000]   DMA zone: 4032 pages used for memmap
   746    [    0.000000]   DMA zone: 0 pages reserved
   747    [    0.000000]   DMA zone: 248576 pages, LIFO batch:63
   748    [    0.000000]   DMA32 zone: 3584 pages used for memmap
   749    [    0.000000]   DMA32 zone: 229376 pages, LIFO batch:63
   750    [    0.000000] psci: probing for conduit method from DT.
   751    [    0.000000] psci: PSCIv0.2 detected in firmware.
   752    [    0.000000] psci: Using standard PSCI v0.2 function IDs
   753    [    0.000000] psci: Trusted OS migration not required
   754    [    0.000000] percpu: Embedded 22 pages/cpu s50392 r8192 d31528 u90112
   755    [    0.000000] pcpu-alloc: s50392 r8192 d31528 u90112 alloc=22*4096
   756    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
   757    [    0.000000] Detected VIPT I-cache on CPU0
   758    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 470336
   759    [    0.000000] Kernel command line: root=LABEL=ROOTFS rootflags=data=writeback rw console=ttyAML0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 mac=00:df:06:00:00:0b
   760    [    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
   761    [    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
   762    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
   763    [    0.000000] software IO TLB: mapped [mem 0x3bfff000-0x3ffff000] (64MB)
   764    [    0.000000] Memory: 1509616K/1911808K available (14460K kernel code, 1434K rwdata, 5884K rodata, 960K init, 927K bss, 140048K reserved, 262144K cma-reserved)
   765    [    0.000000] random: get_random_u64 called from cache_random_seq_create+0x7c/0x150 with crng_init=0
   766    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
   767    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
   768    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
   769    [    0.000000]     Tasks RCU enabled.
   770    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
   771    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
   772    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
   773    [    0.000000] GIC: Using split EOI/Deactivate mode
   774    [    0.000000] irq_meson_gpio: 110 to 8 gpio interrupt mux initialized
   775    [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
   776    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
   777    [    0.000003] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
   778    [    0.000352] Console: colour dummy device 80x25
   779    [    0.000652] printk: console [tty0] enabled
   780    [    0.000691] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
   781    [    0.000712] pid_max: default: 32768 minimum: 301
   782    [    0.000839] LSM: Security Framework initializing
   783    [    0.000889] SELinux:  Initializing.
   784    [    0.000967] *** VALIDATE SELinux ***
   785    [    0.001034] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
   786    [    0.001060] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
   787    [    0.001124] *** VALIDATE tmpfs ***
   788    [    0.001535] *** VALIDATE proc ***
   789    [    0.001758] *** VALIDATE cgroup1 ***
   790    [    0.001773] *** VALIDATE cgroup2 ***
   791    [    0.024017] ASID allocator initialised with 32768 entries
   792    [    0.031999] rcu: Hierarchical SRCU implementation.
   793    [    0.042089] EFI services will not be available.
   794    [    0.048056] smp: Bringing up secondary CPUs ...
   795    [    0.080285] Detected VIPT I-cache on CPU1
   796    [    0.080339] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
   797    [    0.112330] Detected VIPT I-cache on CPU2
   798    [    0.112377] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
   799    [    0.144374] Detected VIPT I-cache on CPU3
   800    [    0.144416] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
   801    [    0.144493] smp: Brought up 1 node, 4 CPUs
   802    [    0.144560] SMP: Total of 4 processors activated.
   803    [    0.144572] CPU features: detected: 32-bit EL0 Support
   804    [    0.144584] CPU features: detected: CRC32 instructions
   805    [    0.144887] CPU: All CPU(s) started at EL2
   806    [    0.144910] alternatives: patching kernel code
   807    [    0.146010] devtmpfs: initialized
   808    [    0.151131] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
   809    [    0.151173] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
   810    [    0.157999] xor: measuring software checksum speed
   811    [    0.196369]    8regs     :  2374.000 MB/sec
   812    [    0.236401]    32regs    :  2724.000 MB/sec
   813    [    0.276439]    arm64_neon:  2406.000 MB/sec
   814    [    0.276449] xor: using function: 32regs (2724.000 MB/sec)
   815    [    0.276505] pinctrl core: initialized pinctrl subsystem
   816    [    0.277159] thermal_sys: Registered thermal governor 'step_wise'
   817    [    0.277328] DMI not present or invalid.
   818    [    0.277690] NET: Registered protocol family 16
   819    [    0.281245] DMA: preallocated 256 KiB pool for atomic allocations
   820    [    0.281296] audit: initializing netlink subsys (disabled)
   821    [    0.281507] audit: type=2000 audit(0.280:1): state=initialized audit_enabled=0 res=1
   822    [    0.282585] cpuidle: using governor ladder
   823    [    0.282626] cpuidle: using governor menu
   824    [    0.282996] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
   825    [    0.283719] Serial: AMBA PL011 UART driver
   826    [    0.297732] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
   827    [    0.297758] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
   828    [    0.297771] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
   829    [    0.297784] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
   830    [    0.301432] cryptd: max_cpu_qlen set to 1000
   831    [    0.376690] raid6: neonx8   gen()  1616 MB/s
   832    [    0.444714] raid6: neonx8   xor()  1491 MB/s
   833    [    0.512772] raid6: neonx4   gen()  1564 MB/s
   834    [    0.580828] raid6: neonx4   xor()  1471 MB/s
   835    [    0.648908] raid6: neonx2   gen()  1201 MB/s
   836    [    0.716919] raid6: neonx2   xor()  1216 MB/s
   837    [    0.785015] raid6: neonx1   gen()   788 MB/s
   838    [    0.853082] raid6: neonx1   xor()   915 MB/s
   839    [    0.921130] raid6: int64x8  gen()  1195 MB/s
   840    [    0.989152] raid6: int64x8  xor()   769 MB/s
   841    [    1.057214] raid6: int64x4  gen()  1029 MB/s
   842    [    1.125269] raid6: int64x4  xor()   752 MB/s
   843    [    1.193304] raid6: int64x2  gen()   728 MB/s
   844    [    1.261341] raid6: int64x2  xor()   615 MB/s
   845    [    1.329490] raid6: int64x1  gen()   486 MB/s
   846    [    1.397458] raid6: int64x1  xor()   467 MB/s
   847    [    1.397469] raid6: using algorithm neonx8 gen() 1616 MB/s
   848    [    1.397479] raid6: .... xor() 1491 MB/s, rmw enabled
   849    [    1.397489] raid6: using neon recovery algorithm
   850    [    1.397731] ACPI: Interpreter disabled.
   851    [    1.398932] iommu: Default domain type: Translated
   852    [    1.399201] vgaarb: loaded
   853    [    1.399747] SCSI subsystem initialized
   854    [    1.399919] libata version 3.00 loaded.
   855    [    1.400129] usbcore: registered new interface driver usbfs
   856    [    1.400176] usbcore: registered new interface driver hub
   857    [    1.400238] usbcore: registered new device driver usb
   858    [    1.400648] pps_core: LinuxPPS API ver. 1 registered
   859    [    1.400660] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
   860    [    1.400685] PTP clock support registered
   861    [    1.400712] EDAC MC: Ver: 3.0.0
   862    [    1.401285] FPGA manager framework
   863    [    1.401409] Advanced Linux Sound Architecture Driver Initialized.
   864    [    1.401874] NetLabel: Initializing
   865    [    1.401887] NetLabel:  domain hash size = 128
   866    [    1.401896] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
   867    [    1.401950] NetLabel:  unlabeled traffic allowed by default
   868    [    1.402425] clocksource: Switched to clocksource arch_sys_counter
   869    [    1.402448] *** VALIDATE bpf ***
   870    [    1.402705] VFS: Disk quotas dquot_6.6.0
   871    [    1.402767] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
   872    [    1.402895] FS-Cache: Loaded
   873    [    1.402906] *** VALIDATE ramfs ***
   874    [    1.402927] *** VALIDATE hugetlbfs ***
   875    [    1.403302] pnp: PnP ACPI: disabled
   876    [    1.408331] NET: Registered protocol family 2
   877    [    1.408830] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
   878    [    1.408878] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
   879    [    1.408995] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
   880    [    1.409209] TCP: Hash tables configured (established 16384 bind 16384)
   881    [    1.409363] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
   882    [    1.409419] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
   883    [    1.409636] NET: Registered protocol family 1
   884    [    1.410100] RPC: Registered named UNIX socket transport module.
   885    [    1.410122] RPC: Registered udp transport module.
   886    [    1.410131] RPC: Registered tcp transport module.
   887    [    1.410140] RPC: Registered tcp NFSv4.1 backchannel transport module.
   888    [    1.410157] NET: Registered protocol family 44
   889    [    1.410178] PCI: CLS 0 bytes, default 64
   890    [    1.410379] Trying to unpack rootfs image as initramfs...
   891    [    1.872010] Freeing initrd memory: 10248K
   892    [    1.872812] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
   893    [    2.086312] Initialise system trusted keyrings
   894    [    2.086627] workingset: timestamp_bits=46 max_order=19 bucket_order=0
   895    [    2.091819] zbud: loaded
   896    [    2.093042] squashfs: version 4.0 (2009/01/31) Phillip Lougher
   897    [    2.093345] FS-Cache: Netfs 'nfs' registered for caching
   898    [    2.093872] NFS: Registering the id_resolver key type
   899    [    2.093909] Key type id_resolver registered
   900    [    2.093919] Key type id_legacy registered
   901    [    2.093935] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
   902    [    2.093947] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
   903    [    2.095154] FS-Cache: Netfs 'cifs' registered for caching
   904    [    2.095485] Key type cifs.spnego registered
   905    [    2.095509] Key type cifs.idmap registered
   906    [    2.095533] ntfs: driver 2.1.32 [Flags: R/W].
   907    [    2.096106] JFS: nTxBlock = 8192, nTxLock = 65536
   908    [    2.101997] SGI XFS with ACLs, security attributes, realtime, quota, no debug enabled
   909    [    2.103440] *** VALIDATE xfs ***
   910    [    2.103744] ocfs2: Registered cluster interface o2cb
   911    [    2.103958] OCFS2 User DLM kernel interface loaded
   912    [    2.105359] *** VALIDATE gfs2 ***
   913    [    2.105638] gfs2: GFS2 installed
   914    [    2.106589] aufs 5.5-20200203
   915    [    2.126560] Key type asymmetric registered
   916    [    2.126586] Asymmetric key parser 'x509' registered
   917    [    2.126597] Asymmetric key parser 'pkcs8' registered
   918    [    2.126668] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
   919    [    2.126849] io scheduler mq-deadline registered
   920    [    2.126864] io scheduler kyber registered
   921    [    2.127062] io scheduler bfq registered
   922    [    2.139630] soc soc0: Amlogic Meson GXL (S905X) Revision 21:b (82:2) Detected
   923    [    2.143192] Serial: 8250/16550 driver, 5 ports, IRQ sharing enabled
   924    [    2.144887] Serial: AMBA driver
   925    [    2.145264] c11084c0.serial: ttyAML6 at MMIO 0xc11084c0 (irq = 10, base_baud = 1500000) is a meson_uart
   926    [    2.145418] serial serial0: tty port ttyAML6 registered
   927    [    2.145624] c81004c0.serial: ttyAML0 at MMIO 0xc81004c0 (irq = 13, base_baud = 1500000) is a meson_uart
   928    [    3.121095] printk: console [ttyAML0] enabled
   929    [    3.137297] brd: module loaded
   930    [    3.145834] loop: module loaded
   931    [    3.148342] libphy: Fixed MDIO Bus: probed
   932    [    3.148995] meson8b-dwmac c9410000.ethernet: IRQ eth_wake_irq not found
   933    [    3.154017] meson8b-dwmac c9410000.ethernet: IRQ eth_lpi not found
   934    [    3.160208] meson8b-dwmac c9410000.ethernet: PTP uses main clock
   935    [    3.166067] meson8b-dwmac c9410000.ethernet: no reset control found
   936    [    3.172770] meson8b-dwmac c9410000.ethernet: User ID: 0x11, Synopsys ID: 0x37
   937    [    3.179368] meson8b-dwmac c9410000.ethernet:     DWMAC1000
   938    [    3.184536] meson8b-dwmac c9410000.ethernet: DMA HW capability register supported
   939    [    3.191936] meson8b-dwmac c9410000.ethernet: RX Checksum Offload Engine supported
   940    [    3.199353] meson8b-dwmac c9410000.ethernet: COE Type 2
   941    [    3.204525] meson8b-dwmac c9410000.ethernet: TX Checksum insertion supported
   942    [    3.211512] meson8b-dwmac c9410000.ethernet: Wake-Up On Lan supported
   943    [    3.217926] meson8b-dwmac c9410000.ethernet: Normal descriptors
   944    [    3.223761] meson8b-dwmac c9410000.ethernet: Ring mode enabled
   945    [    3.229538] meson8b-dwmac c9410000.ethernet: Enable RX Mitigation via HW Watchdog Timer
   946    [    3.237657] libphy: stmmac: probed
   947    [    3.242136] VFIO - User Level meta-driver version: 0.3
   948    [    3.247535] dwc3 c9000000.dwc3: Failed to get clk 'ref': -2
   949    [    3.252355] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
   950    [    3.257953] ehci-pci: EHCI PCI platform driver
   951    [    3.262382] ehci-platform: EHCI generic platform driver
   952    [    3.267684] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
   953    [    3.273628] ohci-pci: OHCI PCI platform driver
   954    [    3.278062] ohci-platform: OHCI generic platform driver
   955    [    3.283803] usbcore: registered new interface driver usb-storage
   956    [    3.289403] mousedev: PS/2 mouse device common for all mice
   957    [    3.295322] i2c /dev entries driver
   958    [    3.300958] sdhci: Secure Digital Host Controller Interface driver
   959    [    3.304247] sdhci: Copyright(c) Pierre Ossman
   960    [    3.308564] Synopsys Designware Multimedia Card Interface Driver
   961    [    3.315853] meson-gx-mmc d0072000.mmc: Got CD GPIO
   962    [    3.346332] meson-gx-mmc d0074000.mmc: allocated mmc-pwrseq
   963    [    3.377634] sdhci-pltfm: SDHCI platform and OF driver helper
   964    [    3.378540] ledtrig-cpu: registered to indicate activity on CPUs
   965    [    3.384520] meson-sm: secure-monitor enabled
   966    [    3.388582] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
   967    [    3.395889] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
   968    [    3.403825] mmc0: new high speed SDHC card at address 59b4
   969    [    3.413773] mmcblk0: mmc0:59b4 SDU1  29.5 GiB
   970    [    3.420178]  mmcblk0: p1 p2
   971    [    3.421997] hid: raw HID events driver (C) Jiri Kosina
   972    [    3.422720] usbcore: registered new interface driver usbhid
   973    [    3.428044] usbhid: USB HID core driver
   974    [    3.432131] platform-mhu c883c404.mailbox: Platform MHU Mailbox registered
   975    [    3.448747] NET: Registered protocol family 17
   976    [    3.449007] Key type dns_resolver registered
   977    [    3.452350] registered taskstats version 1
   978    [    3.455966] Loading compiled-in X.509 certificates
   979    [    3.460733] zswap: loaded using pool lzo/zbud
   980    [    3.465113] Key type ._fscrypt registered
   981    [    3.468949] Key type .fscrypt registered
   982    [    3.474301] Btrfs loaded, crc32c=crc32c-generic
   983    [    3.493643] mmc1: new HS200 MMC card at address 0001
   984    [    3.494529] mmcblk1: mmc1:0001 016G92 14.7 GiB
   985    [    3.497803] mmcblk1boot0: mmc1:0001 016G92 partition 1 4.00 MiB
   986    [    3.503797] mmcblk1boot1: mmc1:0001 016G92 partition 2 4.00 MiB
   987    [    3.506370] Key type encrypted registered
   988    [    3.509660] mmcblk1gp0: mmc1:0001 016G92 partition 4 8.00 MiB
   989    [    3.519153] mmcblk1rpmb: mmc1:0001 016G92 partition 3 512 KiB, chardev (243:0)
   990    [    3.532427] meson-drm d0100000.vpu: Queued 3 outputs on vpu
   991    [    3.532743] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
   992    [    3.538984] [drm] No driver support for vblank timestamp query.
   993    [    3.570490] meson-dw-hdmi c883a000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
   994    [    3.575196] meson-dw-hdmi c883a000.hdmi-tx: registered DesignWare HDMI I2C bus driver
   995    [    3.583155] meson-drm d0100000.vpu: bound c883a000.hdmi-tx (ops meson_dw_hdmi_ops)
   996    [    3.590506] [drm] Initialized meson 1.0.0 20161109 for d0100000.vpu on minor 0
   997    [    3.630979] Console: switching to colour frame buffer device 90x36
   998    [    3.651200] meson-drm d0100000.vpu: fb0: mesondrmfb frame buffer device
   999    [    3.658507] libphy: mdio_mux: probed
  1000    [    3.668973] libphy: mdio_mux: probed
  1001    [    3.669458] phy phy-d0078080.phy.2: unsupported PHY mode 5
  1002    [    3.674512] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  1003    [    3.677904] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
  1004    [    3.685612] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228f664 hci version 0x100 quirks 0x0000000002010010
  1005    [    3.694851] xhci-hcd xhci-hcd.0.auto: irq 39, io mem 0xc9000000
  1006    [    3.700956] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.05
  1007    [    3.709197] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1008    [    3.716338] usb usb1: Product: xHCI Host Controller
  1009    [    3.721166] usb usb1: Manufacturer: Linux 5.5.0-rc6-aml-s9xxx xhci-hcd
  1010    [    3.727638] usb usb1: SerialNumber: xhci-hcd.0.auto
  1011    [    3.732971] hub 1-0:1.0: USB hub found
  1012    [    3.736213] hub 1-0:1.0: 2 ports detected
  1013    [    3.740438] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  1014    [    3.745593] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
  1015    [    3.753190] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
  1016    [    3.759700] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
  1017    [    3.767965] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.05
  1018    [    3.776351] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1019    [    3.783507] usb usb2: Product: xHCI Host Controller
  1020    [    3.788342] usb usb2: Manufacturer: Linux 5.5.0-rc6-aml-s9xxx xhci-hcd
  1021    [    3.794807] usb usb2: SerialNumber: xhci-hcd.0.auto
  1022    [    3.800115] hub 2-0:1.0: USB hub found
  1023    [    3.803403] hub 2-0:1.0: config failed, hub doesn't have any ports! (err -19)
  1024    [    3.812210] meson-gx-mmc d0070000.mmc: allocated mmc-pwrseq
  1025    [    3.843436] scpi_protocol scpi: SCP Protocol legacy pre-1.0 firmware
  1026    [    3.860258] gx-sound-card sound: snd-soc-dummy-dai <-> c1105400.bus:audio-controller-0 mapping ok
  1027    [    3.871992] gx-sound-card sound: i2s-hifi <-> c1105400.bus:audio-controller-2 mapping ok
  1028    [    3.879733] gx-sound-card sound: ASoC: no DMI vendor name!
  1029    [    3.885968] printk: console [netcon0] enabled
  1030    [    3.889354] netconsole: network logging started
  1031    [    3.893810] hctosys: unable to open rtc device (rtc0)
  1032    [    3.896612] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
  1033    [    3.899028] ALSA device list:
  1034    [    3.907276]   #0: AMLGX
  1035    [    3.907521] mmc2: queuing unknown CIS tuple 0x80 (6 bytes)
  1036    [    3.915566] Freeing unused kernel memory: 960K
  1037    [    3.919452] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
  1038    [    3.919780] Run /init as init process
  1039    [    3.934273] mmc2: queuing unknown CIS tuple 0x80 (19 bytes)
  1040    [    3.961260] random: fast init done
  1041    [    4.017177] mmc2: new high speed SDIO card at address 0001
  1042    [    4.074520] usb 1-1: new high-speed USB device number 2 using xhci-hcd
  1043    [    4.095825] usb 1-1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.36
  1044    [    4.103271] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
  1045    [    4.110059] usb 1-1: Product: USB2.0 Hub
  1046    [    4.176186] hub 1-1:1.0: USB hub found
  1047    [    4.178935] hub 1-1:1.0: 4 ports detected
  1048    [    4.310488] usb 1-2: new high-speed USB device number 3 using xhci-hcd
  1049    [    4.340923] usb 1-2: New USB device found, idVendor=148f, idProduct=7601, bcdDevice= 0.00
  1050    [    4.348279] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
  1051    [    4.357563] usb 1-2: Product: 802.11 n WLAN
  1052    [    4.361305] usb 1-2: Manufacturer: MediaTek
  1053    [    4.364631] usb 1-2: SerialNumber: 1.0
  1054    [    5.096209] EXT4-fs (mmcblk0p2): mounted filesystem with writeback data mode. Opts: data=writeback
  1055    [    6.061107] systemd[1]: System time before build time, advancing clock.
  1056    [    6.207418] NET: Registered protocol family 10
  1057    [    6.281144] Segment Routing with IPv6
  1058    [    6.332035] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
  1059    [    6.365245] systemd[1]: Detected architecture arm64.
  1060    [    6.423428] systemd[1]: Set hostname to <mxqpro>.
  1061    [    6.457238] systemd[1]: Couldn't move remaining userspace processes, ignoring: Input/output error
  1062    [    7.168006] random: systemd: uninitialized urandom read (16 bytes read)
  1063    [    7.181362] random: systemd: uninitialized urandom read (16 bytes read)
  1064    [    7.185655] systemd[1]: Listening on udev Control Socket.
  1065    [    7.193341] random: systemd: uninitialized urandom read (16 bytes read)
  1066    [    7.200119] systemd[1]: Created slice system-systemd\x2dfsck.slice.
  1067    [    7.206197] systemd[1]: Reached target System Time Synchronized.
  1068    [    7.212326] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
  1069    [    7.220700] systemd[1]: Listening on Syslog Socket.
  1070    [    7.226206] systemd[1]: Condition check resulted in Arbitrary Executable File Formats File System Automount Point being skipped.
  1071    [    7.400684] EXT4-fs (mmcblk0p2): re-mounted. Opts: commit=600,errors=remount-ro
  1072    [    7.653696] systemd-journald[414]: Received request to flush runtime journal from PID 1
  1073    [    8.127667] mc: Linux media interface: v0.10
  1074    [    8.150658] videodev: Linux video capture interface: v2.00
  1075    [    8.190007] Registered IR keymap rc-empty
  1076    [    8.193464] rc rc0: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0
  1077    [    8.193567] input: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0/input0
  1078    [    8.196518] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
  1079    [    8.217739] meson-ir c8100580.ir: receiver initialized
  1080    [    8.256211] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
  1081    [    8.362349] Bluetooth: Core ver 2.22
  1082    [    8.364934] NET: Registered protocol family 31
  1083    [    8.368059] Bluetooth: HCI device and connection manager initialized
  1084    [    8.373468] Bluetooth: HCI socket layer initialized
  1085    [    8.378267] Bluetooth: L2CAP socket layer initialized
  1086    [    8.383632] lima d00c0000.gpu: IRQ ppmmu3 not found
  1087    [    8.388076] lima d00c0000.gpu: IRQ ppmmu4 not found
  1088    [    8.396142] lima d00c0000.gpu: IRQ ppmmu5 not found
  1089    [    8.398402] lima d00c0000.gpu: IRQ ppmmu6 not found
  1090    [    8.402910] Bluetooth: SCO socket layer initialized
  1091    [    8.406027] lima d00c0000.gpu: IRQ ppmmu7 not found
  1092    [    8.414208] lima d00c0000.gpu: gp - mali450 version major 0 minor 0
  1093    [    8.421823] lima d00c0000.gpu: pp0 - mali450 version major 0 minor 0
  1094    [    8.427037] lima d00c0000.gpu: pp1 - mali450 version major 0 minor 0
  1095    [    8.435164] lima d00c0000.gpu: pp2 - mali450 version major 0 minor 0
  1096    [    8.438062] lima d00c0000.gpu: IRQ pp3 not found
  1097    [    8.442570] lima d00c0000.gpu: IRQ pp4 not found
  1098    [    8.447234] lima d00c0000.gpu: IRQ pp5 not found
  1099    [    8.458533] lima d00c0000.gpu: IRQ pp6 not found
  1100    [    8.460376] lima d00c0000.gpu: IRQ pp7 not found
  1101    [    8.464141] lima d00c0000.gpu: l2 cache 8K, 4-way, 64byte cache line, 128bit external bus
  1102    [    8.472238] lima d00c0000.gpu: l2 cache 64K, 4-way, 64byte cache line, 128bit external bus
  1103    [    8.481502] lima d00c0000.gpu: bus rate = 166666667
  1104    [    8.485293] lima d00c0000.gpu: mod rate = 744000000
  1105    [    8.490607] [drm] Initialized lima 1.0.0 20190217 for d00c0000.gpu on minor 1
  1106    [    8.605049] Bluetooth: HCI UART driver ver 2.3
  1107    [    8.611953] Bluetooth: HCI UART protocol H4 registered
  1108    [    8.613635] Bluetooth: HCI UART protocol BCSP registered
  1109    [    8.626129] Bluetooth: HCI UART protocol LL registered
  1110    [    8.628225] Bluetooth: HCI UART protocol ATH3K registered
  1111    [    8.638573] Bluetooth: HCI UART protocol Three-wire (H5) registered
  1112    [    8.641023] Bluetooth: HCI UART protocol Intel registered
  1113    [    8.647141] Bluetooth: HCI UART protocol Broadcom registered
  1114    [    8.647275] hci_uart_bcm serial0-0: serial0-0 supply vbat not found, using dummy regulator
  1115    [    8.649068] cfg80211: Loading compiled-in X.509 certificates for regulatory database
  1116    [    8.658160] Bluetooth: HCI UART protocol QCA registered
  1117    [    8.666731] hci_uart_bcm serial0-0: serial0-0 supply vddio not found, using dummy regulator
  1118    [    8.672767] Bluetooth: HCI UART protocol AG6XX registered
  1119    [    8.672863] Bluetooth: HCI UART protocol Marvell registered
  1120    [    8.711963] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
  1121    [    8.715916] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
  1122    [    8.724809] cfg80211: failed to load regulatory.db
  1123    [    8.855376] brcmfmac: F1 signature read @0x18000000=0x16034334
  1124    [    8.862780] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4334-sdio for chip BCM4334/3
  1125    [    8.870669] usbcore: registered new interface driver brcmfmac
  1126    [    8.907337] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.amlogic,p212.txt failed with error -2
  1127    [    8.917543] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.txt failed with error -2
  1128    [    8.966861] usb 1-2: reset high-speed USB device number 3 using xhci-hcd
  1129    [    8.990168] mt7601u 1-2:1.0: ASIC revision: 76010001 MAC revision: 76010500
  1130    [    9.020609] mt7601u 1-2:1.0: EEPROM ver:0d fae:00
  1131    [    9.087757] Bluetooth: hci0: BCM: chip id 68
  1132    [    9.091308] Bluetooth: hci0: BCM: features 0x0f
  1133    [    9.093032] Bluetooth: hci0: BCM4334B0
  1134    [    9.097456] Bluetooth: hci0: BCM4334B0 (002.001.013) build 0000
  1135    [    9.097567] bluetooth hci0: Direct firmware load for brcm/BCM4334B0.hcd failed with error -2
  1136    [    9.111747] Bluetooth: hci0: BCM: Patch brcm/BCM4334B0.hcd not found
  1137    [    9.225190] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
  1138    [    9.226144] usbcore: registered new interface driver mt7601u
  1139    [    9.934519] brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x50
  1140    [   10.054188] zram: Added device: zram0
  1141    [   10.057679] zram: Added device: zram1
  1142    [   10.064074] zram: Added device: zram2
  1143    [   10.097602] meson8b-dwmac c9410000.ethernet eth0: PHY [0.e40908ff:08] driver [Meson GXL Internal PHY]
  1144    [   10.117679] zram1: detected capacity change from 0 to 912879616
  1145    [   10.122547] meson8b-dwmac c9410000.ethernet eth0: No Safety Features support found
  1146    [   10.128700] meson8b-dwmac c9410000.ethernet eth0: PTP not supported by HW
  1147    [   10.134755] meson8b-dwmac c9410000.ethernet eth0: configuring for phy/rmii link mode
  1148    [   10.792532] random: crng init done
  1149    [   10.795025] random: 7 urandom warning(s) missed due to ratelimiting
  1150    [   10.962942] Adding 891480k swap on /dev/zram1.  Priority:5 extents:1 across:891480k SSFS
  1151
  1152    ### armbian-release:
  1153
  1154    # PLEASE DO NOT EDIT THIS FILE
  1155    BOARD=aml-s9xxx
  1156    BOARD_NAME="AML-S9xxx"
  1157    BOARDFAMILY=aml-s9xxx
  1158    BUILD_REPOSITORY_URL=https://github.com/150balbes/Build-Armbian.git
  1159    BUILD_REPOSITORY_COMMIT=62b8c07-dirty
  1160    DISTRIBUTION_CODENAME=buster
  1161    DISTRIBUTION_STATUS=supported
  1162    VERSION=20.02.0-rc1.037
  1163    LINUXFAMILY=aml-s9xxx
  1164    BRANCH=current
  1165    ARCH=arm64
  1166    IMAGE_TYPE=nightly
  1167    BOARD_TYPE=conf
  1168    INITRD_ARCH=arm64
  1169    KERNEL_IMAGE_TYPE=Image
  1170
  1171    ### boot environment:
  1172
  1173    ODROIDN2-UBOOT-CONFIG
  1174    setenv env_addr 0x10400000
  1175    setenv kernel_addr 0x11000000
  1176    setenv initrd_addr 0x13000000
  1177    setenv dtb_addr 0x1000000
  1178    if test "${devtype}" = ""; then setenv devtype "mmc"; fi
  1179    load ${devtype} ${devnum} ${env_addr} uEnv.txt && env import -t ${env_addr} ${filesize}
  1180    setenv bootargs ${APPEND}
  1181    load ${devtype} ${devnum} ${kernel_addr} ${LINUX}
  1182    load ${devtype} ${devnum} ${initrd_addr} ${INITRD}
  1183    load ${devtype} ${devnum} ${dtb_addr} ${FDT}
  1184    fdt addr ${dtb_addr}
  1185    booti ${kernel_addr} ${initrd_addr} ${dtb_addr}
  1186
  1187    ### lsusb:
  1188
  1189    Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
  1190    Bus 001 Device 003: ID 148f:7601 Ralink Technology, Corp. MT7601U Wireless Adapter
  1191    Bus 001 Device 002: ID 05e3:0608 Genesys Logic, Inc. Hub
  1192    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  1193
  1194    ### lscpu:
  1195
  1196    Architecture:        aarch64
  1197    Byte Order:          Little Endian
  1198    CPU(s):              4
  1199    On-line CPU(s) list: 0-3
  1200    Thread(s) per core:  1
  1201    Core(s) per socket:  4
  1202    Socket(s):           1
  1203    Vendor ID:           ARM
  1204    Model:               4
  1205    Model name:          Cortex-A53
  1206    Stepping:            r0p4
  1207    CPU max MHz:         1512,0000
  1208    CPU min MHz:         100,0000
  1209    BogoMIPS:            48.00
  1210    L1d cache:           unknown size
  1211    L1i cache:           unknown size
  1212    L2 cache:            unknown size
  1213    Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1214
  1215    ### cpuinfo:
  1216
  1217    processor    : 0
  1218    model name    : ARMv8 Processor rev 4 (v8l)
  1219    BogoMIPS    : 48.00
  1220    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1221    CPU implementer    : 0x41
  1222    CPU architecture: 8
  1223    CPU variant    : 0x0
  1224    CPU part    : 0xd03
  1225    CPU revision    : 4
  1226
  1227    processor    : 1
  1228    model name    : ARMv8 Processor rev 4 (v8l)
  1229    BogoMIPS    : 48.00
  1230    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1231    CPU implementer    : 0x41
  1232    CPU architecture: 8
  1233    CPU variant    : 0x0
  1234    CPU part    : 0xd03
  1235    CPU revision    : 4
  1236
  1237    processor    : 2
  1238    model name    : ARMv8 Processor rev 4 (v8l)
  1239    BogoMIPS    : 48.00
  1240    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1241    CPU implementer    : 0x41
  1242    CPU architecture: 8
  1243    CPU variant    : 0x0
  1244    CPU part    : 0xd03
  1245    CPU revision    : 4
  1246
  1247    processor    : 3
  1248    model name    : ARMv8 Processor rev 4 (v8l)
  1249    BogoMIPS    : 48.00
  1250    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1251    CPU implementer    : 0x41
  1252    CPU architecture: 8
  1253    CPU variant    : 0x0
  1254    CPU part    : 0xd03
  1255    CPU revision    : 4
  1256
  1257
  1258    ### meminfo:
  1259
  1260    MemTotal:        1782968 kB
  1261    MemFree:         1610664 kB
  1262    MemAvailable:    1665824 kB
  1263    Buffers:           11472 kB
  1264    Cached:            52268 kB
  1265    SwapCached:            0 kB
  1266    Active:            50352 kB
  1267    Inactive:          33304 kB
  1268    Active(anon):      20552 kB
  1269    Inactive(anon):     2580 kB
  1270    Active(file):      29800 kB
  1271    Inactive(file):    30724 kB
  1272    Unevictable:           0 kB
  1273    Mlocked:               0 kB
  1274    SwapTotal:        891480 kB
  1275    SwapFree:         891480 kB
  1276    Dirty:               520 kB
  1277    Writeback:             0 kB
  1278    AnonPages:         20500 kB
  1279    Mapped:            21228 kB
  1280    Shmem:              2684 kB
  1281    KReclaimable:      17752 kB
  1282    Slab:              54268 kB
  1283    SReclaimable:      17752 kB
  1284    SUnreclaim:        36516 kB
  1285    KernelStack:        2780 kB
  1286    PageTables:         1568 kB
  1287    NFS_Unstable:          0 kB
  1288    Bounce:                0 kB
  1289    WritebackTmp:          0 kB
  1290    CommitLimit:     1782964 kB
  1291    Committed_AS:      77144 kB
  1292    VmallocTotal:   135290159040 kB
  1293    VmallocUsed:       16724 kB
  1294    VmallocChunk:          0 kB
  1295    Percpu:             1312 kB
  1296    CmaTotal:         262144 kB
  1297    CmaFree:          258460 kB
  1298    HugePages_Total:       0
  1299    HugePages_Free:        0
  1300    HugePages_Rsvd:        0
  1301    HugePages_Surp:        0
  1302    Hugepagesize:       2048 kB
  1303    Hugetlb:               0 kB
  1304
  1305    ### virtual memory:
  1306
  1307    vm.admin_reserve_kbytes = 8192
  1308    vm.block_dump = 0
  1309    vm.compact_unevictable_allowed = 1
  1310    vm.dirty_background_bytes = 0
  1311    vm.dirty_background_ratio = 10
  1312    vm.dirty_bytes = 0
  1313    vm.dirty_expire_centisecs = 3000
  1314    vm.dirty_ratio = 20
  1315    vm.dirtytime_expire_seconds = 43200
  1316    vm.dirty_writeback_centisecs = 500
  1317    vm.extfrag_threshold = 500
  1318    vm.hugetlb_shm_group = 0
  1319    vm.laptop_mode = 0
  1320    vm.legacy_va_layout = 0
  1321    vm.lowmem_reserve_ratio = 256    256    32    0
  1322    vm.max_map_count = 65530
  1323    vm.min_free_kbytes = 4914
  1324    vm.mmap_min_addr = 4096
  1325    vm.mmap_rnd_bits = 18
  1326    vm.nr_hugepages = 0
  1327    vm.nr_overcommit_hugepages = 0
  1328    vm.oom_dump_tasks = 1
  1329    vm.oom_kill_allocating_task = 0
  1330    vm.overcommit_kbytes = 0
  1331    vm.overcommit_memory = 0
  1332    vm.overcommit_ratio = 50
  1333    vm.page-cluster = 0
  1334    vm.panic_on_oom = 0
  1335    vm.percpu_pagelist_fraction = 0
  1336    vm.stat_interval = 1
  1337    vm.swappiness = 100
  1338    vm.user_reserve_kbytes = 55239
  1339    vm.vfs_cache_pressure = 100
  1340    vm.watermark_boost_factor = 15000
  1341    vm.watermark_scale_factor = 10
  1342
  1343    ### ip addr:
  1344
  1345    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
  1346        link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  1347        inet XXX.XXX.0.1/8 scope host lo
  1348           valid_lft forever preferred_lft forever
  1349        inet6 ::1/128 scope host
  1350           valid_lft forever preferred_lft forever
  1351    2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
  1352        link/ether 00:df:06:00:00:0b brd ff:ff:ff:ff:ff:ff
  1353    3: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  1354        link/ether 00:36:76:61:0b:24 brd ff:ff:ff:ff:ff:ff
  1355
  1356    ### partitions:
  1357
  1358    major minor  #blocks  name
  1359
  1360     179        0   30924800 mmcblk0
  1361     179        1     262144 mmcblk0p1
  1362     179        2   30337024 mmcblk0p2
  1363     179       32   15384576 mmcblk1
  1364     179      128       8192 mmcblk1gp0
  1365     254        1     891484 zram1
  1366
  1367    ### df:
  1368
  1369    udev             738M      0  738M   0% /dev
  1370    tmpfs            175M   2,7M  172M   2% /run
  1371    /dev/mmcblk0p2    29G    10G   19G  36% /
  1372    tmpfs            871M      0  871M   0% /dev/shm
  1373    tmpfs            5,0M   4,0K  5,0M   1% /run/lock
  1374    tmpfs            871M      0  871M   0% /sys/fs/cgroup
  1375    tmpfs            871M      0  871M   0% /tmp
  1376    /dev/mmcblk0p1   256M    76M  180M  30% /boot
  1377
  1378    ### lsblk:
  1379
  1380    NAME         FSTYPE   SIZE MOUNTPOINT UUID
  1381    mmcblk0              29,5G
  1382    ├─mmcblk0p1  vfat     256M /boot      50FC-6AC8
  1383    └─mmcblk0p2  ext4      29G /          3e297ac1-e4e4-4ab1-bc57-47c07d0422ba
  1384    mmcblk1              14,7G
  1385    mmcblk1boot0            4M
  1386    mmcblk1boot1            4M
  1387    mmcblk1gp0              8M
  1388
  1389    ### zramctl:
  1390
  1391    NAME       ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT
  1392    /dev/zram1 lzo         870,6M   4K   81B   12K       4 [SWAP]
  1393
  1394    ### mtab:
  1395
  1396    /dev/mmcblk0p1 /boot vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro 0 0
  1397    /dev/mmcblk0p2 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  1398
  1399    ### mmc0:59b4 info:
  1400
  1401                   fwrev: 0x0
  1402                  uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SDU1  MODALIAS=mmc:block
  1403                     cid: 1b534d53445531201014a136d4013800
  1404                     rca: 0x59b4
  1405                     csd: 400e00325b590000ebef7f800a400000
  1406                  manfid: 0x00001b
  1407                     ocr: 0x00200000
  1408    preferred_erase_size: 4194304
  1409                    type: SD
  1410                   hwrev: 0x1
  1411                    date: 08/2019
  1412                     dsr: 0x404
  1413              erase_size: 512
  1414                   oemid: 0x534d
  1415                  serial: 0x14a136d4
  1416                     ssr: 0000000005000000040090000811391e00089a342f01000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  1417                     scr: 0235844300000000
  1418                    name: SDU1
  1419
  1420    ### mmc1:0001 info:
  1421
  1422                   fwrev: 0x0
  1423                  uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=016G92 MODALIAS=mmc:block
  1424                     cid: 11010030313647393201d3d1a4db1100
  1425             rel_sectors: 0x10
  1426                     rca: 0x0001
  1427            pre_eol_info: 0x00
  1428                     csd: d00e00320f5903ffffffffef92400000
  1429                  manfid: 0x000011
  1430                     ocr: 0x00200000
  1431    preferred_erase_size: 4194304
  1432    enhanced_area_offset: 18446744073709551594
  1433      raw_rpmb_size_mult: 0x4
  1434                    type: MMC
  1435                   hwrev: 0x0
  1436                    date: 01/2014
  1437                     prv: 0x1
  1438             ffu_capable: 0
  1439                     dsr: 0x404
  1440              erase_size: 4194304
  1441               life_time: 0x00 0x00
  1442      enhanced_area_size: 4294967274
  1443                   oemid: 0x0100
  1444                  serial: 0xd3d1a4db
  1445                 cmdq_en: 0
  1446                     rev: 0x6
  1447                    name: 016G92
  1448
  1449    ### Boot system health:
  1450
  1451    Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU
  1452    07:51:56: 1512MHz  0.47  51%  24%  15%   0%  10%   1% 41.0°C
  1453    07:51:56: 1512MHz  0.47  60%   7%  11%   0%  40%   0% 40.0°C
  1454    07:51:57: 1512MHz  0.47  74%  12%  24%   0%  34%   2% 41.0°C
  1455    07:51:57: 1512MHz  0.47  52%   6%  12%   1%  30%   0% 41.0°C
  1456    07:51:57: 1512MHz  0.60  43%   5%  11%   0%  24%   1% 40.0°C
  1457
  1458    ### Activated 1 lzo zram swap devices with 870 MB each
  1459
  1460
  1461    lun mar 22 11:17:04 CET 2021 | AML-S9xxx | 20.02.0-rc1.037 | arm64 | aarch64 | 5.5.0-rc6-aml-s9xxx
  1462
  1463    ### dmesg:
  1464
  1465    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
  1466    [    0.000000] Linux version 5.5.0-rc6-aml-s9xxx (root@vbox) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #rc1.037 SMP PREEMPT Wed Feb 5 15:59:04 MSK 2020
  1467    [    0.000000] Machine model: Amlogic Meson GXL (S905X) P212 Development Board
  1468    [    0.000000] efi: Getting EFI parameters from FDT:
  1469    [    0.000000] efi: UEFI not found.
  1470    [    0.000000] Reserved memory: created CMA memory pool at 0x0000000063400000, size 256 MiB
  1471    [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
  1472    [    0.000000] On node 0 totalpages: 477952
  1473    [    0.000000]   DMA zone: 4032 pages used for memmap
  1474    [    0.000000]   DMA zone: 0 pages reserved
  1475    [    0.000000]   DMA zone: 248576 pages, LIFO batch:63
  1476    [    0.000000]   DMA32 zone: 3584 pages used for memmap
  1477    [    0.000000]   DMA32 zone: 229376 pages, LIFO batch:63
  1478    [    0.000000] psci: probing for conduit method from DT.
  1479    [    0.000000] psci: PSCIv0.2 detected in firmware.
  1480    [    0.000000] psci: Using standard PSCI v0.2 function IDs
  1481    [    0.000000] psci: Trusted OS migration not required
  1482    [    0.000000] percpu: Embedded 22 pages/cpu s50392 r8192 d31528 u90112
  1483    [    0.000000] pcpu-alloc: s50392 r8192 d31528 u90112 alloc=22*4096
  1484    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
  1485    [    0.000000] Detected VIPT I-cache on CPU0
  1486    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 470336
  1487    [    0.000000] Kernel command line: root=LABEL=ROOTFS rootflags=data=writeback rw console=ttyAML0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 mac=00:df:06:00:00:0b
  1488    [    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
  1489    [    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
  1490    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
  1491    [    0.000000] software IO TLB: mapped [mem 0x3bfff000-0x3ffff000] (64MB)
  1492    [    0.000000] Memory: 1509616K/1911808K available (14460K kernel code, 1434K rwdata, 5884K rodata, 960K init, 927K bss, 140048K reserved, 262144K cma-reserved)
  1493    [    0.000000] random: get_random_u64 called from cache_random_seq_create+0x7c/0x150 with crng_init=0
  1494    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
  1495    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
  1496    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
  1497    [    0.000000]     Tasks RCU enabled.
  1498    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
  1499    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
  1500    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
  1501    [    0.000000] GIC: Using split EOI/Deactivate mode
  1502    [    0.000000] irq_meson_gpio: 110 to 8 gpio interrupt mux initialized
  1503    [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
  1504    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
  1505    [    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
  1506    [    0.000353] Console: colour dummy device 80x25
  1507    [    0.000653] printk: console [tty0] enabled
  1508    [    0.000695] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
  1509    [    0.000715] pid_max: default: 32768 minimum: 301
  1510    [    0.000841] LSM: Security Framework initializing
  1511    [    0.000891] SELinux:  Initializing.
  1512    [    0.000968] *** VALIDATE SELinux ***
  1513    [    0.001032] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
  1514    [    0.001060] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
  1515    [    0.001125] *** VALIDATE tmpfs ***
  1516    [    0.001529] *** VALIDATE proc ***
  1517    [    0.001751] *** VALIDATE cgroup1 ***
  1518    [    0.001766] *** VALIDATE cgroup2 ***
  1519    [    0.024016] ASID allocator initialised with 32768 entries
  1520    [    0.032000] rcu: Hierarchical SRCU implementation.
  1521    [    0.042081] EFI services will not be available.
  1522    [    0.048055] smp: Bringing up secondary CPUs ...
  1523    [    0.080284] Detected VIPT I-cache on CPU1
  1524    [    0.080336] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
  1525    [    0.112321] Detected VIPT I-cache on CPU2
  1526    [    0.112364] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
  1527    [    0.144370] Detected VIPT I-cache on CPU3
  1528    [    0.144414] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
  1529    [    0.144492] smp: Brought up 1 node, 4 CPUs
  1530    [    0.144556] SMP: Total of 4 processors activated.
  1531    [    0.144568] CPU features: detected: 32-bit EL0 Support
  1532    [    0.144580] CPU features: detected: CRC32 instructions
  1533    [    0.144886] CPU: All CPU(s) started at EL2
  1534    [    0.144908] alternatives: patching kernel code
  1535    [    0.146008] devtmpfs: initialized
  1536    [    0.151153] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
  1537    [    0.151196] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
  1538    [    0.158017] xor: measuring software checksum speed
  1539    [    0.196363]    8regs     :  2375.000 MB/sec
  1540    [    0.236393]    32regs    :  2724.000 MB/sec
  1541    [    0.276431]    arm64_neon:  2406.000 MB/sec
  1542    [    0.276441] xor: using function: 32regs (2724.000 MB/sec)
  1543    [    0.276496] pinctrl core: initialized pinctrl subsystem
  1544    [    0.277148] thermal_sys: Registered thermal governor 'step_wise'
  1545    [    0.277317] DMI not present or invalid.
  1546    [    0.277677] NET: Registered protocol family 16
  1547    [    0.281248] DMA: preallocated 256 KiB pool for atomic allocations
  1548    [    0.281296] audit: initializing netlink subsys (disabled)
  1549    [    0.281515] audit: type=2000 audit(0.280:1): state=initialized audit_enabled=0 res=1
  1550    [    0.282597] cpuidle: using governor ladder
  1551    [    0.282638] cpuidle: using governor menu
  1552    [    0.283009] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
  1553    [    0.283728] Serial: AMBA PL011 UART driver
  1554    [    0.297704] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
  1555    [    0.297731] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
  1556    [    0.297744] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
  1557    [    0.297756] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
  1558    [    0.301423] cryptd: max_cpu_qlen set to 1000
  1559    [    0.376690] raid6: neonx8   gen()  1616 MB/s
  1560    [    0.444751] raid6: neonx8   xor()  1504 MB/s
  1561    [    0.512789] raid6: neonx4   gen()  1562 MB/s
  1562    [    0.580844] raid6: neonx4   xor()  1471 MB/s
  1563    [    0.648886] raid6: neonx2   gen()  1200 MB/s
  1564    [    0.716949] raid6: neonx2   xor()  1216 MB/s
  1565    [    0.784989] raid6: neonx1   gen()   787 MB/s
  1566    [    0.853076] raid6: neonx1   xor()   914 MB/s
  1567    [    0.921136] raid6: int64x8  gen()  1195 MB/s
  1568    [    0.989153] raid6: int64x8  xor()   769 MB/s
  1569    [    1.057220] raid6: int64x4  gen()  1029 MB/s
  1570    [    1.125263] raid6: int64x4  xor()   752 MB/s
  1571    [    1.193316] raid6: int64x2  gen()   728 MB/s
  1572    [    1.261380] raid6: int64x2  xor()   615 MB/s
  1573    [    1.329449] raid6: int64x1  gen()   485 MB/s
  1574    [    1.397480] raid6: int64x1  xor()   468 MB/s
  1575    [    1.397490] raid6: using algorithm neonx8 gen() 1616 MB/s
  1576    [    1.397501] raid6: .... xor() 1504 MB/s, rmw enabled
  1577    [    1.397511] raid6: using neon recovery algorithm
  1578    [    1.397791] ACPI: Interpreter disabled.
  1579    [    1.398966] iommu: Default domain type: Translated
  1580    [    1.399259] vgaarb: loaded
  1581    [    1.399805] SCSI subsystem initialized
  1582    [    1.400017] libata version 3.00 loaded.
  1583    [    1.400230] usbcore: registered new interface driver usbfs
  1584    [    1.400274] usbcore: registered new interface driver hub
  1585    [    1.400338] usbcore: registered new device driver usb
  1586    [    1.400735] pps_core: LinuxPPS API ver. 1 registered
  1587    [    1.400747] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
  1588    [    1.400771] PTP clock support registered
  1589    [    1.400804] EDAC MC: Ver: 3.0.0
  1590    [    1.401402] FPGA manager framework
  1591    [    1.401506] Advanced Linux Sound Architecture Driver Initialized.
  1592    [    1.401972] NetLabel: Initializing
  1593    [    1.401986] NetLabel:  domain hash size = 128
  1594    [    1.401995] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
  1595    [    1.402048] NetLabel:  unlabeled traffic allowed by default
  1596    [    1.402565] clocksource: Switched to clocksource arch_sys_counter
  1597    [    1.402591] *** VALIDATE bpf ***
  1598    [    1.402832] VFS: Disk quotas dquot_6.6.0
  1599    [    1.402892] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
  1600    [    1.403008] FS-Cache: Loaded
  1601    [    1.403019] *** VALIDATE ramfs ***
  1602    [    1.403040] *** VALIDATE hugetlbfs ***
  1603    [    1.403408] pnp: PnP ACPI: disabled
  1604    [    1.408468] NET: Registered protocol family 2
  1605    [    1.408965] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
  1606    [    1.409013] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
  1607    [    1.409131] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
  1608    [    1.409344] TCP: Hash tables configured (established 16384 bind 16384)
  1609    [    1.409501] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
  1610    [    1.409555] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
  1611    [    1.409773] NET: Registered protocol family 1
  1612    [    1.410262] RPC: Registered named UNIX socket transport module.
  1613    [    1.410284] RPC: Registered udp transport module.
  1614    [    1.410294] RPC: Registered tcp transport module.
  1615    [    1.410303] RPC: Registered tcp NFSv4.1 backchannel transport module.
  1616    [    1.410318] NET: Registered protocol family 44
  1617    [    1.410339] PCI: CLS 0 bytes, default 64
  1618    [    1.410535] Trying to unpack rootfs image as initramfs...
  1619    [    1.872260] Freeing initrd memory: 10248K
  1620    [    1.873053] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
  1621    [    2.086883] Initialise system trusted keyrings
  1622    [    2.087111] workingset: timestamp_bits=46 max_order=19 bucket_order=0
  1623    [    2.092264] zbud: loaded
  1624    [    2.093497] squashfs: version 4.0 (2009/01/31) Phillip Lougher
  1625    [    2.093774] FS-Cache: Netfs 'nfs' registered for caching
  1626    [    2.094296] NFS: Registering the id_resolver key type
  1627    [    2.094334] Key type id_resolver registered
  1628    [    2.094343] Key type id_legacy registered
  1629    [    2.094359] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
  1630    [    2.094372] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
  1631    [    2.095575] FS-Cache: Netfs 'cifs' registered for caching
  1632    [    2.095898] Key type cifs.spnego registered
  1633    [    2.095920] Key type cifs.idmap registered
  1634    [    2.095942] ntfs: driver 2.1.32 [Flags: R/W].
  1635    [    2.096545] JFS: nTxBlock = 8192, nTxLock = 65536
  1636    [    2.102466] SGI XFS with ACLs, security attributes, realtime, quota, no debug enabled
  1637    [    2.103899] *** VALIDATE xfs ***
  1638    [    2.104193] ocfs2: Registered cluster interface o2cb
  1639    [    2.104407] OCFS2 User DLM kernel interface loaded
  1640    [    2.105834] *** VALIDATE gfs2 ***
  1641    [    2.106104] gfs2: GFS2 installed
  1642    [    2.107087] aufs 5.5-20200203
  1643    [    2.127652] Key type asymmetric registered
  1644    [    2.127677] Asymmetric key parser 'x509' registered
  1645    [    2.127688] Asymmetric key parser 'pkcs8' registered
  1646    [    2.127758] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
  1647    [    2.127963] io scheduler mq-deadline registered
  1648    [    2.127978] io scheduler kyber registered
  1649    [    2.128172] io scheduler bfq registered
  1650    [    2.140736] soc soc0: Amlogic Meson GXL (S905X) Revision 21:b (82:2) Detected
  1651    [    2.144299] Serial: 8250/16550 driver, 5 ports, IRQ sharing enabled
  1652    [    2.145988] Serial: AMBA driver
  1653    [    2.146346] c11084c0.serial: ttyAML6 at MMIO 0xc11084c0 (irq = 10, base_baud = 1500000) is a meson_uart
  1654    [    2.146497] serial serial0: tty port ttyAML6 registered
  1655    [    2.146774] c81004c0.serial: ttyAML0 at MMIO 0xc81004c0 (irq = 13, base_baud = 1500000) is a meson_uart
  1656    [    3.122238] printk: console [ttyAML0] enabled
  1657    [    3.138300] brd: module loaded
  1658    [    3.146945] loop: module loaded
  1659    [    3.149310] libphy: Fixed MDIO Bus: probed
  1660    [    3.149970] meson8b-dwmac c9410000.ethernet: IRQ eth_wake_irq not found
  1661    [    3.155116] meson8b-dwmac c9410000.ethernet: IRQ eth_lpi not found
  1662    [    3.161324] meson8b-dwmac c9410000.ethernet: PTP uses main clock
  1663    [    3.167175] meson8b-dwmac c9410000.ethernet: no reset control found
  1664    [    3.173867] meson8b-dwmac c9410000.ethernet: User ID: 0x11, Synopsys ID: 0x37
  1665    [    3.180465] meson8b-dwmac c9410000.ethernet:     DWMAC1000
  1666    [    3.185628] meson8b-dwmac c9410000.ethernet: DMA HW capability register supported
  1667    [    3.193045] meson8b-dwmac c9410000.ethernet: RX Checksum Offload Engine supported
  1668    [    3.200463] meson8b-dwmac c9410000.ethernet: COE Type 2
  1669    [    3.205635] meson8b-dwmac c9410000.ethernet: TX Checksum insertion supported
  1670    [    3.212622] meson8b-dwmac c9410000.ethernet: Wake-Up On Lan supported
  1671    [    3.219035] meson8b-dwmac c9410000.ethernet: Normal descriptors
  1672    [    3.224871] meson8b-dwmac c9410000.ethernet: Ring mode enabled
  1673    [    3.230650] meson8b-dwmac c9410000.ethernet: Enable RX Mitigation via HW Watchdog Timer
  1674    [    3.238770] libphy: stmmac: probed
  1675    [    3.243317] VFIO - User Level meta-driver version: 0.3
  1676    [    3.248583] dwc3 c9000000.dwc3: Failed to get clk 'ref': -2
  1677    [    3.253459] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
  1678    [    3.259061] ehci-pci: EHCI PCI platform driver
  1679    [    3.263499] ehci-platform: EHCI generic platform driver
  1680    [    3.268798] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
  1681    [    3.274737] ohci-pci: OHCI PCI platform driver
  1682    [    3.279174] ohci-platform: OHCI generic platform driver
  1683    [    3.284915] usbcore: registered new interface driver usb-storage
  1684    [    3.290479] mousedev: PS/2 mouse device common for all mice
  1685    [    3.296429] i2c /dev entries driver
  1686    [    3.302079] sdhci: Secure Digital Host Controller Interface driver
  1687    [    3.305363] sdhci: Copyright(c) Pierre Ossman
  1688    [    3.309674] Synopsys Designware Multimedia Card Interface Driver
  1689    [    3.316973] meson-gx-mmc d0072000.mmc: Got CD GPIO
  1690    [    3.347434] meson-gx-mmc d0074000.mmc: allocated mmc-pwrseq
  1691    [    3.375068] sdhci-pltfm: SDHCI platform and OF driver helper
  1692    [    3.376044] ledtrig-cpu: registered to indicate activity on CPUs
  1693    [    3.381997] meson-sm: secure-monitor enabled
  1694    [    3.386196] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
  1695    [    3.393305] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
  1696    [    3.409504] mmc0: new high speed SDHC card at address 59b4
  1697    [    3.410552] mmcblk0: mmc0:59b4 SDU1  29.5 GiB
  1698    [    3.415991]  mmcblk0: p1 p2
  1699    [    3.418801] hid: raw HID events driver (C) Jiri Kosina
  1700    [    3.421870] usbcore: registered new interface driver usbhid
  1701    [    3.427236] usbhid: USB HID core driver
  1702    [    3.431362] platform-mhu c883c404.mailbox: Platform MHU Mailbox registered
  1703    [    3.447844] NET: Registered protocol family 17
  1704    [    3.448108] Key type dns_resolver registered
  1705    [    3.451482] registered taskstats version 1
  1706    [    3.454976] Loading compiled-in X.509 certificates
  1707    [    3.459843] zswap: loaded using pool lzo/zbud
  1708    [    3.464174] Key type ._fscrypt registered
  1709    [    3.467976] Key type .fscrypt registered
  1710    [    3.472893] Btrfs loaded, crc32c=crc32c-generic
  1711    [    3.493551] mmc1: new HS200 MMC card at address 0001
  1712    [    3.498597] mmcblk1: mmc1:0001 016G92 14.7 GiB
  1713    [    3.499083] mmcblk1boot0: mmc1:0001 016G92 partition 1 4.00 MiB
  1714    [    3.499576] Key type encrypted registered
  1715    [    3.503823] mmcblk1boot1: mmc1:0001 016G92 partition 2 4.00 MiB
  1716    [    3.513683] mmcblk1gp0: mmc1:0001 016G92 partition 4 8.00 MiB
  1717    [    3.519208] mmcblk1rpmb: mmc1:0001 016G92 partition 3 512 KiB, chardev (243:0)
  1718    [    3.527032] meson-drm d0100000.vpu: Queued 3 outputs on vpu
  1719    [    3.532002] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
  1720    [    3.538154] [drm] No driver support for vblank timestamp query.
  1721    [    3.570617] meson-dw-hdmi c883a000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
  1722    [    3.575269] meson-dw-hdmi c883a000.hdmi-tx: registered DesignWare HDMI I2C bus driver
  1723    [    3.583292] meson-drm d0100000.vpu: bound c883a000.hdmi-tx (ops meson_dw_hdmi_ops)
  1724    [    3.590598] [drm] Initialized meson 1.0.0 20161109 for d0100000.vpu on minor 0
  1725    [    3.632196] Console: switching to colour frame buffer device 90x36
  1726    [    3.652422] meson-drm d0100000.vpu: fb0: mesondrmfb frame buffer device
  1727    [    3.659677] libphy: mdio_mux: probed
  1728    [    3.670179] libphy: mdio_mux: probed
  1729    [    3.670701] phy phy-d0078080.phy.2: unsupported PHY mode 5
  1730    [    3.675722] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  1731    [    3.679109] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
  1732    [    3.686820] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228f664 hci version 0x100 quirks 0x0000000002010010
  1733    [    3.696039] xhci-hcd xhci-hcd.0.auto: irq 39, io mem 0xc9000000
  1734    [    3.702161] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.05
  1735    [    3.710506] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1736    [    3.717655] usb usb1: Product: xHCI Host Controller
  1737    [    3.722483] usb usb1: Manufacturer: Linux 5.5.0-rc6-aml-s9xxx xhci-hcd
  1738    [    3.728951] usb usb1: SerialNumber: xhci-hcd.0.auto
  1739    [    3.734300] hub 1-0:1.0: USB hub found
  1740    [    3.737543] hub 1-0:1.0: 2 ports detected
  1741    [    3.741744] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  1742    [    3.746908] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
  1743    [    3.754496] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
  1744    [    3.760997] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
  1745    [    3.769244] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.05
  1746    [    3.777616] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1747    [    3.784773] usb usb2: Product: xHCI Host Controller
  1748    [    3.789602] usb usb2: Manufacturer: Linux 5.5.0-rc6-aml-s9xxx xhci-hcd
  1749    [    3.796072] usb usb2: SerialNumber: xhci-hcd.0.auto
  1750    [    3.801371] hub 2-0:1.0: USB hub found
  1751    [    3.804657] hub 2-0:1.0: config failed, hub doesn't have any ports! (err -19)
  1752    [    3.813480] meson-gx-mmc d0070000.mmc: allocated mmc-pwrseq
  1753    [    3.843571] scpi_protocol scpi: SCP Protocol legacy pre-1.0 firmware
  1754    [    3.860329] gx-sound-card sound: snd-soc-dummy-dai <-> c1105400.bus:audio-controller-0 mapping ok
  1755    [    3.871876] gx-sound-card sound: i2s-hifi <-> c1105400.bus:audio-controller-2 mapping ok
  1756    [    3.879564] gx-sound-card sound: ASoC: no DMI vendor name!
  1757    [    3.885756] printk: console [netcon0] enabled
  1758    [    3.889196] netconsole: network logging started
  1759    [    3.893768] hctosys: unable to open rtc device (rtc0)
  1760    [    3.899074] ALSA device list:
  1761    [    3.901684]   #0: AMLGX
  1762    [    3.904696] Freeing unused kernel memory: 960K
  1763    [    3.908544] Run /init as init process
  1764    [    3.917231] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
  1765    [    3.924029] mmc2: queuing unknown CIS tuple 0x80 (6 bytes)
  1766    [    3.931091] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
  1767    [    3.942576] mmc2: queuing unknown CIS tuple 0x80 (19 bytes)
  1768    [    3.965156] random: fast init done
  1769    [    4.028824] mmc2: new high speed SDIO card at address 0001
  1770    [    4.078643] usb 1-1: new high-speed USB device number 2 using xhci-hcd
  1771    [    4.100299] usb 1-1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.36
  1772    [    4.107220] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
  1773    [    4.114599] usb 1-1: Product: USB2.0 Hub
  1774    [    4.177498] hub 1-1:1.0: USB hub found
  1775    [    4.180084] hub 1-1:1.0: 4 ports detected
  1776    [    4.310653] usb 1-2: new high-speed USB device number 3 using xhci-hcd
  1777    [    4.341205] usb 1-2: New USB device found, idVendor=148f, idProduct=7601, bcdDevice= 0.00
  1778    [    4.348256] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
  1779    [    4.355203] usb 1-2: Product: 802.11 n WLAN
  1780    [    4.359906] usb 1-2: Manufacturer: MediaTek
  1781    [    4.366181] usb 1-2: SerialNumber: 1.0
  1782    [    5.929977] EXT4-fs (mmcblk0p2): mounted filesystem with writeback data mode. Opts: data=writeback
  1783    [    6.863884] systemd[1]: System time before build time, advancing clock.
  1784    [    7.010117] NET: Registered protocol family 10
  1785    [    7.084053] Segment Routing with IPv6
  1786    [    7.133798] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
  1787    [    7.166249] systemd[1]: Detected architecture arm64.
  1788    [    7.220331] systemd[1]: Set hostname to <mxqpro>.
  1789    [    7.252129] systemd[1]: Couldn't move remaining userspace processes, ignoring: Input/output error
  1790    [    7.956616] random: systemd: uninitialized urandom read (16 bytes read)
  1791    [    7.969840] random: systemd: uninitialized urandom read (16 bytes read)
  1792    [    7.973996] systemd[1]: Listening on udev Control Socket.
  1793    [    7.981535] random: systemd: uninitialized urandom read (16 bytes read)
  1794    [    7.985645] systemd[1]: Listening on Syslog Socket.
  1795    [    7.993273] systemd[1]: Listening on Journal Socket (/dev/log).
  1796    [    8.002123] systemd[1]: Created slice system-getty.slice.
  1797    [    8.007503] systemd[1]: Condition check resulted in Arbitrary Executable File Formats File System Automount Point being skipped.
  1798    [    8.020080] systemd[1]: Created slice system-systemd\x2dfsck.slice.
  1799    [    8.238538] EXT4-fs (mmcblk0p2): re-mounted. Opts: commit=600,errors=remount-ro
  1800    [    8.363785] systemd-journald[401]: Received request to flush runtime journal from PID 1
  1801    [    8.923111] Registered IR keymap rc-empty
  1802    [    8.925284] rc rc0: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0
  1803    [    8.932461] input: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0/input0
  1804    [    8.932902] mc: Linux media interface: v0.10
  1805    [    8.943825] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
  1806    [    8.944046] meson-ir c8100580.ir: receiver initialized
  1807    [    8.989219] videodev: Linux video capture interface: v2.00
  1808    [    9.071859] lima d00c0000.gpu: IRQ ppmmu3 not found
  1809    [    9.074122] lima d00c0000.gpu: IRQ ppmmu4 not found
  1810    [    9.088435] lima d00c0000.gpu: IRQ ppmmu5 not found
  1811    [    9.092159] lima d00c0000.gpu: IRQ ppmmu6 not found
  1812    [    9.099697] lima d00c0000.gpu: IRQ ppmmu7 not found
  1813    [    9.111856] lima d00c0000.gpu: gp - mali450 version major 0 minor 0
  1814    [    9.114960] lima d00c0000.gpu: pp0 - mali450 version major 0 minor 0
  1815    [    9.121193] lima d00c0000.gpu: pp1 - mali450 version major 0 minor 0
  1816    [    9.137298] lima d00c0000.gpu: pp2 - mali450 version major 0 minor 0
  1817    [    9.143713] lima d00c0000.gpu: IRQ pp3 not found
  1818    [    9.145623] lima d00c0000.gpu: IRQ pp4 not found
  1819    [    9.151337] lima d00c0000.gpu: IRQ pp5 not found
  1820    [    9.154252] lima d00c0000.gpu: IRQ pp6 not found
  1821    [    9.160786] lima d00c0000.gpu: IRQ pp7 not found
  1822    [    9.164026] lima d00c0000.gpu: l2 cache 8K, 4-way, 64byte cache line, 128bit external bus
  1823    [    9.172789] lima d00c0000.gpu: l2 cache 64K, 4-way, 64byte cache line, 128bit external bus
  1824    [    9.181946] lima d00c0000.gpu: bus rate = 166666667
  1825    [    9.185335] lima d00c0000.gpu: mod rate = 744000000
  1826    [    9.189438] [drm] Initialized lima 1.0.0 20190217 for d00c0000.gpu on minor 1
  1827    [    9.249835] Bluetooth: Core ver 2.22
  1828    [    9.251794] NET: Registered protocol family 31
  1829    [    9.253961] Bluetooth: HCI device and connection manager initialized
  1830    [    9.260332] Bluetooth: HCI socket layer initialized
  1831    [    9.265170] Bluetooth: L2CAP socket layer initialized
  1832    [    9.270191] Bluetooth: SCO socket layer initialized
  1833    [    9.276369] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
  1834    [    9.359942] cfg80211: Loading compiled-in X.509 certificates for regulatory database
  1835    [    9.405540] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
  1836    [    9.419935] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
  1837    [    9.426671] cfg80211: failed to load regulatory.db
  1838    [    9.456704] Bluetooth: HCI UART driver ver 2.3
  1839    [    9.459129] Bluetooth: HCI UART protocol H4 registered
  1840    [    9.469525] Bluetooth: HCI UART protocol BCSP registered
  1841    [    9.472981] Bluetooth: HCI UART protocol LL registered
  1842    [    9.482704] Bluetooth: HCI UART protocol ATH3K registered
  1843    [    9.486032] Bluetooth: HCI UART protocol Three-wire (H5) registered
  1844    [    9.526538] Bluetooth: HCI UART protocol Intel registered
  1845    [    9.531615] hci_uart_bcm serial0-0: serial0-0 supply vbat not found, using dummy regulator
  1846    [    9.538846] hci_uart_bcm serial0-0: serial0-0 supply vddio not found, using dummy regulator
  1847    [    9.551114] Bluetooth: HCI UART protocol Broadcom registered
  1848    [    9.573794] Bluetooth: HCI UART protocol QCA registered
  1849    [    9.576715] Bluetooth: HCI UART protocol AG6XX registered
  1850    [    9.581285] brcmfmac: F1 signature read @0x18000000=0x16034334
  1851    [    9.582638] Bluetooth: HCI UART protocol Marvell registered
  1852    [    9.589720] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4334-sdio for chip BCM4334/3
  1853    [    9.599275] usbcore: registered new interface driver brcmfmac
  1854    [    9.652250] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.amlogic,p212.txt failed with error -2
  1855    [    9.662348] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.txt failed with error -2
  1856    [    9.730971] usb 1-2: reset high-speed USB device number 3 using xhci-hcd
  1857    [    9.753871] mt7601u 1-2:1.0: ASIC revision: 76010001 MAC revision: 76010500
  1858    [    9.798465] mt7601u 1-2:1.0: EEPROM ver:0d fae:00
  1859    [    9.956858] Bluetooth: hci0: BCM: chip id 68
  1860    [    9.965676] Bluetooth: hci0: BCM: features 0x0f
  1861    [    9.973632] Bluetooth: hci0: BCM4334B0
  1862    [    9.976380] Bluetooth: hci0: BCM4334B0 (002.001.013) build 0000
  1863    [    9.980456] bluetooth hci0: Direct firmware load for brcm/BCM4334B0.hcd failed with error -2
  1864    [    9.988712] Bluetooth: hci0: BCM: Patch brcm/BCM4334B0.hcd not found
  1865    [   10.027270] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
  1866    [   10.028288] usbcore: registered new interface driver mt7601u
  1867    [   10.666716] brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x50
  1868    [   10.717095] zram: Added device: zram0
  1869    [   10.723846] zram: Added device: zram1
  1870    [   10.730716] zram: Added device: zram2
  1871    [   10.766088] meson8b-dwmac c9410000.ethernet eth0: PHY [0.e40908ff:08] driver [Meson GXL Internal PHY]
  1872    [   10.783471] zram1: detected capacity change from 0 to 912879616
  1873    [   10.787344] meson8b-dwmac c9410000.ethernet eth0: No Safety Features support found
  1874    [   10.793812] meson8b-dwmac c9410000.ethernet eth0: PTP not supported by HW
  1875    [   10.800726] meson8b-dwmac c9410000.ethernet eth0: configuring for phy/rmii link mode
  1876    [   11.441161] random: crng init done
  1877    [   11.443690] random: 7 urandom warning(s) missed due to ratelimiting
  1878    [   11.494636] Adding 891480k swap on /dev/zram1.  Priority:5 extents:1 across:891480k SSFS
  1879
  1880    ### armbian-release:
  1881
  1882    # PLEASE DO NOT EDIT THIS FILE
  1883    BOARD=aml-s9xxx
  1884    BOARD_NAME="AML-S9xxx"
  1885    BOARDFAMILY=aml-s9xxx
  1886    BUILD_REPOSITORY_URL=https://github.com/150balbes/Build-Armbian.git
  1887    BUILD_REPOSITORY_COMMIT=62b8c07-dirty
  1888    DISTRIBUTION_CODENAME=buster
  1889    DISTRIBUTION_STATUS=supported
  1890    VERSION=20.02.0-rc1.037
  1891    LINUXFAMILY=aml-s9xxx
  1892    BRANCH=current
  1893    ARCH=arm64
  1894    IMAGE_TYPE=nightly
  1895    BOARD_TYPE=conf
  1896    INITRD_ARCH=arm64
  1897    KERNEL_IMAGE_TYPE=Image
  1898
  1899    ### boot environment:
  1900
  1901    ODROIDN2-UBOOT-CONFIG
  1902    setenv env_addr 0x10400000
  1903    setenv kernel_addr 0x11000000
  1904    setenv initrd_addr 0x13000000
  1905    setenv dtb_addr 0x1000000
  1906    if test "${devtype}" = ""; then setenv devtype "mmc"; fi
  1907    load ${devtype} ${devnum} ${env_addr} uEnv.txt && env import -t ${env_addr} ${filesize}
  1908    setenv bootargs ${APPEND}
  1909    load ${devtype} ${devnum} ${kernel_addr} ${LINUX}
  1910    load ${devtype} ${devnum} ${initrd_addr} ${INITRD}
  1911    load ${devtype} ${devnum} ${dtb_addr} ${FDT}
  1912    fdt addr ${dtb_addr}
  1913    booti ${kernel_addr} ${initrd_addr} ${dtb_addr}
  1914
  1915    ### lsusb:
  1916
  1917    Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
  1918    Bus 001 Device 003: ID 148f:7601 Ralink Technology, Corp. MT7601U Wireless Adapter
  1919    Bus 001 Device 002: ID 05e3:0608 Genesys Logic, Inc. Hub
  1920    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  1921
  1922    ### lscpu:
  1923
  1924    Architecture:        aarch64
  1925    Byte Order:          Little Endian
  1926    CPU(s):              4
  1927    On-line CPU(s) list: 0-3
  1928    Thread(s) per core:  1
  1929    Core(s) per socket:  4
  1930    Socket(s):           1
  1931    Vendor ID:           ARM
  1932    Model:               4
  1933    Model name:          Cortex-A53
  1934    Stepping:            r0p4
  1935    CPU max MHz:         1512,0000
  1936    CPU min MHz:         100,0000
  1937    BogoMIPS:            48.00
  1938    L1d cache:           unknown size
  1939    L1i cache:           unknown size
  1940    L2 cache:            unknown size
  1941    Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1942
  1943    ### cpuinfo:
  1944
  1945    processor    : 0
  1946    model name    : ARMv8 Processor rev 4 (v8l)
  1947    BogoMIPS    : 48.00
  1948    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1949    CPU implementer    : 0x41
  1950    CPU architecture: 8
  1951    CPU variant    : 0x0
  1952    CPU part    : 0xd03
  1953    CPU revision    : 4
  1954
  1955    processor    : 1
  1956    model name    : ARMv8 Processor rev 4 (v8l)
  1957    BogoMIPS    : 48.00
  1958    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1959    CPU implementer    : 0x41
  1960    CPU architecture: 8
  1961    CPU variant    : 0x0
  1962    CPU part    : 0xd03
  1963    CPU revision    : 4
  1964
  1965    processor    : 2
  1966    model name    : ARMv8 Processor rev 4 (v8l)
  1967    BogoMIPS    : 48.00
  1968    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1969    CPU implementer    : 0x41
  1970    CPU architecture: 8
  1971    CPU variant    : 0x0
  1972    CPU part    : 0xd03
  1973    CPU revision    : 4
  1974
  1975    processor    : 3
  1976    model name    : ARMv8 Processor rev 4 (v8l)
  1977    BogoMIPS    : 48.00
  1978    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1979    CPU implementer    : 0x41
  1980    CPU architecture: 8
  1981    CPU variant    : 0x0
  1982    CPU part    : 0xd03
  1983    CPU revision    : 4
  1984
  1985
  1986    ### meminfo:
  1987
  1988    MemTotal:        1782968 kB
  1989    MemFree:         1612468 kB
  1990    MemAvailable:    1666120 kB
  1991    Buffers:           11828 kB
  1992    Cached:            51068 kB
  1993    SwapCached:            0 kB
  1994    Active:            49940 kB
  1995    Inactive:          33288 kB
  1996    Active(anon):      20848 kB
  1997    Inactive(anon):     2620 kB
  1998    Active(file):      29092 kB
  1999    Inactive(file):    30668 kB
  2000    Unevictable:           0 kB
  2001    Mlocked:               0 kB
  2002    SwapTotal:        891480 kB
  2003    SwapFree:         891480 kB
  2004    Dirty:               704 kB
  2005    Writeback:             0 kB
  2006    AnonPages:         20748 kB
  2007    Mapped:            21148 kB
  2008    Shmem:              2720 kB
  2009    KReclaimable:      17008 kB
  2010    Slab:              52992 kB
  2011    SReclaimable:      17008 kB
  2012    SUnreclaim:        35984 kB
  2013    KernelStack:        2672 kB
  2014    PageTables:         1668 kB
  2015    NFS_Unstable:          0 kB
  2016    Bounce:                0 kB
  2017    WritebackTmp:          0 kB
  2018    CommitLimit:     1782964 kB
  2019    Committed_AS:      54464 kB
  2020    VmallocTotal:   135290159040 kB
  2021    VmallocUsed:       16600 kB
  2022    VmallocChunk:          0 kB
  2023    Percpu:             1312 kB
  2024    CmaTotal:         262144 kB
  2025    CmaFree:          258460 kB
  2026    HugePages_Total:       0
  2027    HugePages_Free:        0
  2028    HugePages_Rsvd:        0
  2029    HugePages_Surp:        0
  2030    Hugepagesize:       2048 kB
  2031    Hugetlb:               0 kB
  2032
  2033    ### virtual memory:
  2034
  2035    vm.admin_reserve_kbytes = 8192
  2036    vm.block_dump = 0
  2037    vm.compact_unevictable_allowed = 1
  2038    vm.dirty_background_bytes = 0
  2039    vm.dirty_background_ratio = 10
  2040    vm.dirty_bytes = 0
  2041    vm.dirty_expire_centisecs = 3000
  2042    vm.dirty_ratio = 20
  2043    vm.dirtytime_expire_seconds = 43200
  2044    vm.dirty_writeback_centisecs = 500
  2045    vm.extfrag_threshold = 500
  2046    vm.hugetlb_shm_group = 0
  2047    vm.laptop_mode = 0
  2048    vm.legacy_va_layout = 0
  2049    vm.lowmem_reserve_ratio = 256    256    32    0
  2050    vm.max_map_count = 65530
  2051    vm.min_free_kbytes = 4914
  2052    vm.mmap_min_addr = 4096
  2053    vm.mmap_rnd_bits = 18
  2054    vm.nr_hugepages = 0
  2055    vm.nr_overcommit_hugepages = 0
  2056    vm.oom_dump_tasks = 1
  2057    vm.oom_kill_allocating_task = 0
  2058    vm.overcommit_kbytes = 0
  2059    vm.overcommit_memory = 0
  2060    vm.overcommit_ratio = 50
  2061    vm.page-cluster = 0
  2062    vm.panic_on_oom = 0
  2063    vm.percpu_pagelist_fraction = 0
  2064    vm.stat_interval = 1
  2065    vm.swappiness = 100
  2066    vm.user_reserve_kbytes = 55239
  2067    vm.vfs_cache_pressure = 100
  2068    vm.watermark_boost_factor = 15000
  2069    vm.watermark_scale_factor = 10
  2070
  2071    ### ip addr:
  2072
  2073    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
  2074        link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  2075        inet XXX.XXX.0.1/8 scope host lo
  2076           valid_lft forever preferred_lft forever
  2077        inet6 ::1/128 scope host
  2078           valid_lft forever preferred_lft forever
  2079    2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
  2080        link/ether 00:df:06:00:00:0b brd ff:ff:ff:ff:ff:ff
  2081    3: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  2082        link/ether 00:36:76:61:0b:24 brd ff:ff:ff:ff:ff:ff
  2083
  2084    ### partitions:
  2085
  2086    major minor  #blocks  name
  2087
  2088     179        0   30924800 mmcblk0
  2089     179        1     262144 mmcblk0p1
  2090     179        2   30337024 mmcblk0p2
  2091     179       32   15384576 mmcblk1
  2092     179      128       8192 mmcblk1gp0
  2093     254        1     891484 zram1
  2094
  2095    ### df:
  2096
  2097    udev             738M      0  738M   0% /dev
  2098    tmpfs            175M   2,7M  172M   2% /run
  2099    /dev/mmcblk0p2    29G    10G   19G  36% /
  2100    tmpfs            871M      0  871M   0% /dev/shm
  2101    tmpfs            5,0M   4,0K  5,0M   1% /run/lock
  2102    tmpfs            871M      0  871M   0% /sys/fs/cgroup
  2103    tmpfs            871M      0  871M   0% /tmp
  2104    /dev/mmcblk0p1   256M    76M  180M  30% /boot
  2105
  2106    ### lsblk:
  2107
  2108    NAME         FSTYPE   SIZE MOUNTPOINT UUID
  2109    mmcblk0              29,5G
  2110    ├─mmcblk0p1  vfat     256M /boot      50FC-6AC8
  2111    └─mmcblk0p2  ext4      29G /          3e297ac1-e4e4-4ab1-bc57-47c07d0422ba
  2112    mmcblk1              14,7G
  2113    mmcblk1boot0            4M
  2114    mmcblk1boot1            4M
  2115    mmcblk1gp0              8M
  2116
  2117    ### zramctl:
  2118
  2119    NAME       ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT
  2120    /dev/zram1 lzo         870,6M   4K   81B   12K       4 [SWAP]
  2121
  2122    ### mtab:
  2123
  2124    /dev/mmcblk0p1 /boot vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro 0 0
  2125    /dev/mmcblk0p2 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  2126
  2127    ### mmc0:59b4 info:
  2128
  2129                   fwrev: 0x0
  2130                  uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SDU1  MODALIAS=mmc:block
  2131                     cid: 1b534d53445531201014a136d4013800
  2132                     rca: 0x59b4
  2133                     csd: 400e00325b590000ebef7f800a400000
  2134                  manfid: 0x00001b
  2135                     ocr: 0x00200000
  2136    preferred_erase_size: 4194304
  2137                    type: SD
  2138                   hwrev: 0x1
  2139                    date: 08/2019
  2140                     dsr: 0x404
  2141              erase_size: 512
  2142                   oemid: 0x534d
  2143                  serial: 0x14a136d4
  2144                     ssr: 0000000005000000040090000811391e00089a342f01000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  2145                     scr: 0235844300000000
  2146                    name: SDU1
  2147
  2148    ### mmc1:0001 info:
  2149
  2150                   fwrev: 0x0
  2151                  uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=016G92 MODALIAS=mmc:block
  2152                     cid: 11010030313647393201d3d1a4db1100
  2153             rel_sectors: 0x10
  2154                     rca: 0x0001
  2155            pre_eol_info: 0x00
  2156                     csd: d00e00320f5903ffffffffef92400000
  2157                  manfid: 0x000011
  2158                     ocr: 0x00200000
  2159    preferred_erase_size: 4194304
  2160    enhanced_area_offset: 18446744073709551594
  2161      raw_rpmb_size_mult: 0x4
  2162                    type: MMC
  2163                   hwrev: 0x0
  2164                    date: 01/2014
  2165                     prv: 0x1
  2166             ffu_capable: 0
  2167                     dsr: 0x404
  2168              erase_size: 4194304
  2169               life_time: 0x00 0x00
  2170      enhanced_area_size: 4294967274
  2171                   oemid: 0x0100
  2172                  serial: 0xd3d1a4db
  2173                 cmdq_en: 0
  2174                     rev: 0x6
  2175                    name: 016G92
  2176
  2177    ### Boot system health:
  2178
  2179    Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU
  2180    11:17:07: 1512MHz  0.79  50%  23%  14%   0%  10%   1% 54.0°C
  2181    11:17:07: 1512MHz  0.79  66%   5%  11%   1%  46%   1% 54.0°C
  2182    11:17:07: 1512MHz  0.79  77%  13%  27%   1%  33%   2% 54.0°C
  2183    11:17:08: 1512MHz  1.21  52%   6%   7%   1%  35%   1% 54.0°C
  2184    11:17:08: 1512MHz  1.21  50%   8%  13%   1%  25%   1% 53.0°C
  2185
  2186    ### Activated 1 lzo zram swap devices with 870 MB each
  2187
  2188
  2189    mar mar 23 09:17:04 CET 2021 | AML-S9xxx | 20.02.0-rc1.037 | arm64 | aarch64 | 5.5.0-rc6-aml-s9xxx
  2190
  2191    ### dmesg:
  2192
  2193    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
  2194    [    0.000000] Linux version 5.5.0-rc6-aml-s9xxx (root@vbox) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #rc1.037 SMP PREEMPT Wed Feb 5 15:59:04 MSK 2020
  2195    [    0.000000] Machine model: Amlogic Meson GXL (S905X) P212 Development Board
  2196    [    0.000000] efi: Getting EFI parameters from FDT:
  2197    [    0.000000] efi: UEFI not found.
  2198    [    0.000000] Reserved memory: created CMA memory pool at 0x0000000063400000, size 256 MiB
  2199    [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
  2200    [    0.000000] On node 0 totalpages: 477952
  2201    [    0.000000]   DMA zone: 4032 pages used for memmap
  2202    [    0.000000]   DMA zone: 0 pages reserved
  2203    [    0.000000]   DMA zone: 248576 pages, LIFO batch:63
  2204    [    0.000000]   DMA32 zone: 3584 pages used for memmap
  2205    [    0.000000]   DMA32 zone: 229376 pages, LIFO batch:63
  2206    [    0.000000] psci: probing for conduit method from DT.
  2207    [    0.000000] psci: PSCIv0.2 detected in firmware.
  2208    [    0.000000] psci: Using standard PSCI v0.2 function IDs
  2209    [    0.000000] psci: Trusted OS migration not required
  2210    [    0.000000] percpu: Embedded 22 pages/cpu s50392 r8192 d31528 u90112
  2211    [    0.000000] pcpu-alloc: s50392 r8192 d31528 u90112 alloc=22*4096
  2212    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
  2213    [    0.000000] Detected VIPT I-cache on CPU0
  2214    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 470336
  2215    [    0.000000] Kernel command line: root=LABEL=ROOTFS rootflags=data=writeback rw console=ttyAML0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 mac=00:df:06:00:00:0b
  2216    [    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
  2217    [    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
  2218    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
  2219    [    0.000000] software IO TLB: mapped [mem 0x3bfff000-0x3ffff000] (64MB)
  2220    [    0.000000] Memory: 1509616K/1911808K available (14460K kernel code, 1434K rwdata, 5884K rodata, 960K init, 927K bss, 140048K reserved, 262144K cma-reserved)
  2221    [    0.000000] random: get_random_u64 called from cache_random_seq_create+0x7c/0x150 with crng_init=0
  2222    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
  2223    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
  2224    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
  2225    [    0.000000]     Tasks RCU enabled.
  2226    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
  2227    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
  2228    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
  2229    [    0.000000] GIC: Using split EOI/Deactivate mode
  2230    [    0.000000] irq_meson_gpio: 110 to 8 gpio interrupt mux initialized
  2231    [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
  2232    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
  2233    [    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
  2234    [    0.000354] Console: colour dummy device 80x25
  2235    [    0.000655] printk: console [tty0] enabled
  2236    [    0.000696] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
  2237    [    0.000717] pid_max: default: 32768 minimum: 301
  2238    [    0.000841] LSM: Security Framework initializing
  2239    [    0.000893] SELinux:  Initializing.
  2240    [    0.000970] *** VALIDATE SELinux ***
  2241    [    0.001034] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
  2242    [    0.001060] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
  2243    [    0.001123] *** VALIDATE tmpfs ***
  2244    [    0.001529] *** VALIDATE proc ***
  2245    [    0.001749] *** VALIDATE cgroup1 ***
  2246    [    0.001763] *** VALIDATE cgroup2 ***
  2247    [    0.024016] ASID allocator initialised with 32768 entries
  2248    [    0.031997] rcu: Hierarchical SRCU implementation.
  2249    [    0.042088] EFI services will not be available.
  2250    [    0.048056] smp: Bringing up secondary CPUs ...
  2251    [    0.080281] Detected VIPT I-cache on CPU1
  2252    [    0.080336] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
  2253    [    0.112321] Detected VIPT I-cache on CPU2
  2254    [    0.112366] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
  2255    [    0.144373] Detected VIPT I-cache on CPU3
  2256    [    0.144414] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
  2257    [    0.144490] smp: Brought up 1 node, 4 CPUs
  2258    [    0.144561] SMP: Total of 4 processors activated.
  2259    [    0.144572] CPU features: detected: 32-bit EL0 Support
  2260    [    0.144584] CPU features: detected: CRC32 instructions
  2261    [    0.144889] CPU: All CPU(s) started at EL2
  2262    [    0.144910] alternatives: patching kernel code
  2263    [    0.146007] devtmpfs: initialized
  2264    [    0.151117] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
  2265    [    0.151158] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
  2266    [    0.158029] xor: measuring software checksum speed
  2267    [    0.196370]    8regs     :  2375.000 MB/sec
  2268    [    0.236402]    32regs    :  2724.000 MB/sec
  2269    [    0.276440]    arm64_neon:  2406.000 MB/sec
  2270    [    0.276450] xor: using function: 32regs (2724.000 MB/sec)
  2271    [    0.276505] pinctrl core: initialized pinctrl subsystem
  2272    [    0.277152] thermal_sys: Registered thermal governor 'step_wise'
  2273    [    0.277312] DMI not present or invalid.
  2274    [    0.277674] NET: Registered protocol family 16
  2275    [    0.281246] DMA: preallocated 256 KiB pool for atomic allocations
  2276    [    0.281295] audit: initializing netlink subsys (disabled)
  2277    [    0.281514] audit: type=2000 audit(0.280:1): state=initialized audit_enabled=0 res=1
  2278    [    0.282597] cpuidle: using governor ladder
  2279    [    0.282638] cpuidle: using governor menu
  2280    [    0.283008] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
  2281    [    0.283723] Serial: AMBA PL011 UART driver
  2282    [    0.297708] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
  2283    [    0.297736] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
  2284    [    0.297750] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
  2285    [    0.297762] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
  2286    [    0.301305] cryptd: max_cpu_qlen set to 1000
  2287    [    0.376675] raid6: neonx8   gen()  1617 MB/s
  2288    [    0.444712] raid6: neonx8   xor()  1505 MB/s
  2289    [    0.512788] raid6: neonx4   gen()  1564 MB/s
  2290    [    0.580814] raid6: neonx4   xor()  1471 MB/s
  2291    [    0.648899] raid6: neonx2   gen()  1199 MB/s
  2292    [    0.716941] raid6: neonx2   xor()  1216 MB/s
  2293    [    0.785050] raid6: neonx1   gen()   787 MB/s
  2294    [    0.853062] raid6: neonx1   xor()   916 MB/s
  2295    [    0.921116] raid6: int64x8  gen()  1194 MB/s
  2296    [    0.989169] raid6: int64x8  xor()   769 MB/s
  2297    [    1.057240] raid6: int64x4  gen()  1029 MB/s
  2298    [    1.125289] raid6: int64x4  xor()   752 MB/s
  2299    [    1.193337] raid6: int64x2  gen()   728 MB/s
  2300    [    1.261360] raid6: int64x2  xor()   618 MB/s
  2301    [    1.329530] raid6: int64x1  gen()   487 MB/s
  2302    [    1.397482] raid6: int64x1  xor()   468 MB/s
  2303    [    1.397492] raid6: using algorithm neonx8 gen() 1617 MB/s
  2304    [    1.397503] raid6: .... xor() 1505 MB/s, rmw enabled
  2305    [    1.397513] raid6: using neon recovery algorithm
  2306    [    1.397789] ACPI: Interpreter disabled.
  2307    [    1.398974] iommu: Default domain type: Translated
  2308    [    1.399253] vgaarb: loaded
  2309    [    1.399784] SCSI subsystem initialized
  2310    [    1.399986] libata version 3.00 loaded.
  2311    [    1.400200] usbcore: registered new interface driver usbfs
  2312    [    1.400244] usbcore: registered new interface driver hub
  2313    [    1.400308] usbcore: registered new device driver usb
  2314    [    1.400708] pps_core: LinuxPPS API ver. 1 registered
  2315    [    1.400720] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
  2316    [    1.400744] PTP clock support registered
  2317    [    1.400779] EDAC MC: Ver: 3.0.0
  2318    [    1.401353] FPGA manager framework
  2319    [    1.401474] Advanced Linux Sound Architecture Driver Initialized.
  2320    [    1.401942] NetLabel: Initializing
  2321    [    1.401955] NetLabel:  domain hash size = 128
  2322    [    1.401964] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
  2323    [    1.402020] NetLabel:  unlabeled traffic allowed by default
  2324    [    1.402522] clocksource: Switched to clocksource arch_sys_counter
  2325    [    1.402548] *** VALIDATE bpf ***
  2326    [    1.402790] VFS: Disk quotas dquot_6.6.0
  2327    [    1.402851] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
  2328    [    1.402967] FS-Cache: Loaded
  2329    [    1.402977] *** VALIDATE ramfs ***
  2330    [    1.402999] *** VALIDATE hugetlbfs ***
  2331    [    1.403369] pnp: PnP ACPI: disabled
  2332    [    1.408382] NET: Registered protocol family 2
  2333    [    1.408878] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
  2334    [    1.408927] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
  2335    [    1.409047] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
  2336    [    1.409262] TCP: Hash tables configured (established 16384 bind 16384)
  2337    [    1.409418] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
  2338    [    1.409470] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
  2339    [    1.409685] NET: Registered protocol family 1
  2340    [    1.410162] RPC: Registered named UNIX socket transport module.
  2341    [    1.410182] RPC: Registered udp transport module.
  2342    [    1.410192] RPC: Registered tcp transport module.
  2343    [    1.410201] RPC: Registered tcp NFSv4.1 backchannel transport module.
  2344    [    1.410217] NET: Registered protocol family 44
  2345    [    1.410238] PCI: CLS 0 bytes, default 64
  2346    [    1.410428] Trying to unpack rootfs image as initramfs...
  2347    [    1.871868] Freeing initrd memory: 10248K
  2348    [    1.872648] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
  2349    [    2.086163] Initialise system trusted keyrings
  2350    [    2.086390] workingset: timestamp_bits=46 max_order=19 bucket_order=0
  2351    [    2.091505] zbud: loaded
  2352    [    2.092750] squashfs: version 4.0 (2009/01/31) Phillip Lougher
  2353    [    2.093050] FS-Cache: Netfs 'nfs' registered for caching
  2354    [    2.093595] NFS: Registering the id_resolver key type
  2355    [    2.093634] Key type id_resolver registered
  2356    [    2.093644] Key type id_legacy registered
  2357    [    2.093660] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
  2358    [    2.093672] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
  2359    [    2.094843] FS-Cache: Netfs 'cifs' registered for caching
  2360    [    2.095181] Key type cifs.spnego registered
  2361    [    2.095201] Key type cifs.idmap registered
  2362    [    2.095226] ntfs: driver 2.1.32 [Flags: R/W].
  2363    [    2.095800] JFS: nTxBlock = 8192, nTxLock = 65536
  2364    [    2.101705] SGI XFS with ACLs, security attributes, realtime, quota, no debug enabled
  2365    [    2.103218] *** VALIDATE xfs ***
  2366    [    2.103502] ocfs2: Registered cluster interface o2cb
  2367    [    2.103713] OCFS2 User DLM kernel interface loaded
  2368    [    2.105087] *** VALIDATE gfs2 ***
  2369    [    2.105361] gfs2: GFS2 installed
  2370    [    2.106285] aufs 5.5-20200203
  2371    [    2.126790] Key type asymmetric registered
  2372    [    2.126817] Asymmetric key parser 'x509' registered
  2373    [    2.126827] Asymmetric key parser 'pkcs8' registered
  2374    [    2.126897] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
  2375    [    2.127091] io scheduler mq-deadline registered
  2376    [    2.127105] io scheduler kyber registered
  2377    [    2.127304] io scheduler bfq registered
  2378    [    2.139846] soc soc0: Amlogic Meson GXL (S905X) Revision 21:b (82:2) Detected
  2379    [    2.143423] Serial: 8250/16550 driver, 5 ports, IRQ sharing enabled
  2380    [    2.145118] Serial: AMBA driver
  2381    [    2.145479] c11084c0.serial: ttyAML6 at MMIO 0xc11084c0 (irq = 10, base_baud = 1500000) is a meson_uart
  2382    [    2.145632] serial serial0: tty port ttyAML6 registered
  2383    [    2.145845] c81004c0.serial: ttyAML0 at MMIO 0xc81004c0 (irq = 13, base_baud = 1500000) is a meson_uart
  2384    [    3.121312] printk: console [ttyAML0] enabled
  2385    [    3.137613] brd: module loaded
  2386    [    3.146122] loop: module loaded
  2387    [    3.148619] libphy: Fixed MDIO Bus: probed
  2388    [    3.149270] meson8b-dwmac c9410000.ethernet: IRQ eth_wake_irq not found
  2389    [    3.154294] meson8b-dwmac c9410000.ethernet: IRQ eth_lpi not found
  2390    [    3.160507] meson8b-dwmac c9410000.ethernet: PTP uses main clock
  2391    [    3.166354] meson8b-dwmac c9410000.ethernet: no reset control found
  2392    [    3.173033] meson8b-dwmac c9410000.ethernet: User ID: 0x11, Synopsys ID: 0x37
  2393    [    3.179663] meson8b-dwmac c9410000.ethernet:     DWMAC1000
  2394    [    3.184822] meson8b-dwmac c9410000.ethernet: DMA HW capability register supported
  2395    [    3.192223] meson8b-dwmac c9410000.ethernet: RX Checksum Offload Engine supported
  2396    [    3.199640] meson8b-dwmac c9410000.ethernet: COE Type 2
  2397    [    3.204812] meson8b-dwmac c9410000.ethernet: TX Checksum insertion supported
  2398    [    3.211799] meson8b-dwmac c9410000.ethernet: Wake-Up On Lan supported
  2399    [    3.218216] meson8b-dwmac c9410000.ethernet: Normal descriptors
  2400    [    3.224048] meson8b-dwmac c9410000.ethernet: Ring mode enabled
  2401    [    3.229825] meson8b-dwmac c9410000.ethernet: Enable RX Mitigation via HW Watchdog Timer
  2402    [    3.237948] libphy: stmmac: probed
  2403    [    3.242413] VFIO - User Level meta-driver version: 0.3
  2404    [    3.247770] dwc3 c9000000.dwc3: Failed to get clk 'ref': -2
  2405    [    3.252618] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
  2406    [    3.258263] ehci-pci: EHCI PCI platform driver
  2407    [    3.262672] ehci-platform: EHCI generic platform driver
  2408    [    3.267971] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
  2409    [    3.273918] ohci-pci: OHCI PCI platform driver
  2410    [    3.278351] ohci-platform: OHCI generic platform driver
  2411    [    3.284100] usbcore: registered new interface driver usb-storage
  2412    [    3.289677] mousedev: PS/2 mouse device common for all mice
  2413    [    3.295614] i2c /dev entries driver
  2414    [    3.301246] sdhci: Secure Digital Host Controller Interface driver
  2415    [    3.304535] sdhci: Copyright(c) Pierre Ossman
  2416    [    3.308851] Synopsys Designware Multimedia Card Interface Driver
  2417    [    3.316105] meson-gx-mmc d0072000.mmc: Got CD GPIO
  2418    [    3.346807] meson-gx-mmc d0074000.mmc: allocated mmc-pwrseq
  2419    [    3.374378] sdhci-pltfm: SDHCI platform and OF driver helper
  2420    [    3.375595] ledtrig-cpu: registered to indicate activity on CPUs
  2421    [    3.380953] meson-sm: secure-monitor enabled
  2422    [    3.385242] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
  2423    [    3.386495] mmc0: new high speed SDHC card at address 59b4
  2424    [    3.392598] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
  2425    [    3.398722] mmcblk0: mmc0:59b4 SDU1  29.5 GiB
  2426    [    3.416767]  mmcblk0: p1 p2
  2427    [    3.422958] hid: raw HID events driver (C) Jiri Kosina
  2428    [    3.423198] usbcore: registered new interface driver usbhid
  2429    [    3.428109] usbhid: USB HID core driver
  2430    [    3.432169] platform-mhu c883c404.mailbox: Platform MHU Mailbox registered
  2431    [    3.449257] NET: Registered protocol family 17
  2432    [    3.449514] Key type dns_resolver registered
  2433    [    3.452841] registered taskstats version 1
  2434    [    3.456379] Loading compiled-in X.509 certificates
  2435    [    3.461360] zswap: loaded using pool lzo/zbud
  2436    [    3.465615] Key type ._fscrypt registered
  2437    [    3.469396] Key type .fscrypt registered
  2438    [    3.474317] Btrfs loaded, crc32c=crc32c-generic
  2439    [    3.496751] mmc1: new HS200 MMC card at address 0001
  2440    [    3.497658] mmcblk1: mmc1:0001 016G92 14.7 GiB
  2441    [    3.501075] mmcblk1boot0: mmc1:0001 016G92 partition 1 4.00 MiB
  2442    [    3.502154] Key type encrypted registered
  2443    [    3.506938] mmcblk1boot1: mmc1:0001 016G92 partition 2 4.00 MiB
  2444    [    3.516793] mmcblk1gp0: mmc1:0001 016G92 partition 4 8.00 MiB
  2445    [    3.522333] mmcblk1rpmb: mmc1:0001 016G92 partition 3 512 KiB, chardev (243:0)
  2446    [    3.530034] meson-drm d0100000.vpu: Queued 3 outputs on vpu
  2447    [    3.535035] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
  2448    [    3.541307] [drm] No driver support for vblank timestamp query.
  2449    [    3.574588] meson-dw-hdmi c883a000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
  2450    [    3.579301] meson-dw-hdmi c883a000.hdmi-tx: registered DesignWare HDMI I2C bus driver
  2451    [    3.587263] meson-drm d0100000.vpu: bound c883a000.hdmi-tx (ops meson_dw_hdmi_ops)
  2452    [    3.594604] [drm] Initialized meson 1.0.0 20161109 for d0100000.vpu on minor 0
  2453    [    3.631915] Console: switching to colour frame buffer device 90x36
  2454    [    3.652134] meson-drm d0100000.vpu: fb0: mesondrmfb frame buffer device
  2455    [    3.659390] libphy: mdio_mux: probed
  2456    [    3.669964] libphy: mdio_mux: probed
  2457    [    3.670454] phy phy-d0078080.phy.2: unsupported PHY mode 5
  2458    [    3.675581] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  2459    [    3.678893] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
  2460    [    3.686599] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228f664 hci version 0x100 quirks 0x0000000002010010
  2461    [    3.695838] xhci-hcd xhci-hcd.0.auto: irq 39, io mem 0xc9000000
  2462    [    3.701934] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.05
  2463    [    3.710305] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  2464    [    3.717444] usb usb1: Product: xHCI Host Controller
  2465    [    3.722271] usb usb1: Manufacturer: Linux 5.5.0-rc6-aml-s9xxx xhci-hcd
  2466    [    3.728744] usb usb1: SerialNumber: xhci-hcd.0.auto
  2467    [    3.734073] hub 1-0:1.0: USB hub found
  2468    [    3.737319] hub 1-0:1.0: 2 ports detected
  2469    [    3.741542] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  2470    [    3.746704] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
  2471    [    3.754302] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
  2472    [    3.760808] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
  2473    [    3.769076] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.05
  2474    [    3.777458] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  2475    [    3.784613] usb usb2: Product: xHCI Host Controller
  2476    [    3.789449] usb usb2: Manufacturer: Linux 5.5.0-rc6-aml-s9xxx xhci-hcd
  2477    [    3.795913] usb usb2: SerialNumber: xhci-hcd.0.auto
  2478    [    3.801213] hub 2-0:1.0: USB hub found
  2479    [    3.804489] hub 2-0:1.0: config failed, hub doesn't have any ports! (err -19)
  2480    [    3.813355] meson-gx-mmc d0070000.mmc: allocated mmc-pwrseq
  2481    [    3.843529] scpi_protocol scpi: SCP Protocol legacy pre-1.0 firmware
  2482    [    3.860387] gx-sound-card sound: snd-soc-dummy-dai <-> c1105400.bus:audio-controller-0 mapping ok
  2483    [    3.872096] gx-sound-card sound: i2s-hifi <-> c1105400.bus:audio-controller-2 mapping ok
  2484    [    3.879822] gx-sound-card sound: ASoC: no DMI vendor name!
  2485    [    3.886001] printk: console [netcon0] enabled
  2486    [    3.889412] netconsole: network logging started
  2487    [    3.893971] hctosys: unable to open rtc device (rtc0)
  2488    [    3.899446] ALSA device list:
  2489    [    3.901990]   #0: AMLGX
  2490    [    3.905060] Freeing unused kernel memory: 960K
  2491    [    3.908830] Run /init as init process
  2492    [    3.920322] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
  2493    [    3.926636] mmc2: queuing unknown CIS tuple 0x80 (6 bytes)
  2494    [    3.933204] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
  2495    [    3.945335] mmc2: queuing unknown CIS tuple 0x80 (19 bytes)
  2496    [    3.972003] random: fast init done
  2497    [    4.036841] mmc2: new high speed SDIO card at address 0001
  2498    [    4.074598] usb 1-1: new high-speed USB device number 2 using xhci-hcd
  2499    [    4.095827] usb 1-1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.36
  2500    [    4.102693] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
  2501    [    4.110264] usb 1-1: Product: USB2.0 Hub
  2502    [    4.177263] hub 1-1:1.0: USB hub found
  2503    [    4.179875] hub 1-1:1.0: 4 ports detected
  2504    [    4.310595] usb 1-2: new high-speed USB device number 3 using xhci-hcd
  2505    [    4.341103] usb 1-2: New USB device found, idVendor=148f, idProduct=7601, bcdDevice= 0.00
  2506    [    4.348045] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
  2507    [    4.358711] usb 1-2: Product: 802.11 n WLAN
  2508    [    4.362184] usb 1-2: Manufacturer: MediaTek
  2509    [    4.365243] usb 1-2: SerialNumber: 1.0
  2510    [    5.767106] EXT4-fs (mmcblk0p2): mounted filesystem with writeback data mode. Opts: data=writeback
  2511    [    6.716386] systemd[1]: System time before build time, advancing clock.
  2512    [    6.862930] NET: Registered protocol family 10
  2513    [    6.937655] Segment Routing with IPv6
  2514    [    6.989321] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
  2515    [    7.024610] systemd[1]: Detected architecture arm64.
  2516    [    7.078067] systemd[1]: Set hostname to <mxqpro>.
  2517    [    7.108068] systemd[1]: Couldn't move remaining userspace processes, ignoring: Input/output error
  2518    [    7.822405] random: systemd: uninitialized urandom read (16 bytes read)
  2519    [    7.835139] random: systemd: uninitialized urandom read (16 bytes read)
  2520    [    7.839481] systemd[1]: Listening on udev Kernel Socket.
  2521    [    7.846966] random: systemd: uninitialized urandom read (16 bytes read)
  2522    [    7.850893] systemd[1]: Listening on initctl Compatibility Named Pipe.
  2523    [    7.859927] systemd[1]: Reached target System Time Synchronized.
  2524    [    7.866451] systemd[1]: Listening on Journal Socket.
  2525    [    7.891079] systemd[1]: Starting Set the console keyboard layout...
  2526    [    7.901680] systemd[1]: Mounting Huge Pages File System...
  2527    [    8.066045] EXT4-fs (mmcblk0p2): re-mounted. Opts: commit=600,errors=remount-ro
  2528    [    8.369388] systemd-journald[416]: Received request to flush runtime journal from PID 1
  2529    [    8.796070] mc: Linux media interface: v0.10
  2530    [    8.830991] videodev: Linux video capture interface: v2.00
  2531    [    8.883011] Registered IR keymap rc-empty
  2532    [    8.883125] rc rc0: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0
  2533    [    8.883217] input: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0/input0
  2534    [    8.883527] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
  2535    [    8.883735] meson-ir c8100580.ir: receiver initialized
  2536    [    9.043577] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
  2537    [    9.060891] Bluetooth: Core ver 2.22
  2538    [    9.067627] NET: Registered protocol family 31
  2539    [    9.069981] Bluetooth: HCI device and connection manager initialized
  2540    [    9.075308] Bluetooth: HCI socket layer initialized
  2541    [    9.080002] Bluetooth: L2CAP socket layer initialized
  2542    [    9.081040] lima d00c0000.gpu: IRQ ppmmu3 not found
  2543    [    9.086296] Bluetooth: SCO socket layer initialized
  2544    [    9.091519] lima d00c0000.gpu: IRQ ppmmu4 not found
  2545    [    9.099899] lima d00c0000.gpu: IRQ ppmmu5 not found
  2546    [    9.114758] lima d00c0000.gpu: IRQ ppmmu6 not found
  2547    [    9.123908] lima d00c0000.gpu: IRQ ppmmu7 not found
  2548    [    9.126204] lima d00c0000.gpu: gp - mali450 version major 0 minor 0
  2549    [    9.134190] lima d00c0000.gpu: pp0 - mali450 version major 0 minor 0
  2550    [    9.138418] lima d00c0000.gpu: pp1 - mali450 version major 0 minor 0
  2551    [    9.145016] lima d00c0000.gpu: pp2 - mali450 version major 0 minor 0
  2552    [    9.154102] lima d00c0000.gpu: IRQ pp3 not found
  2553    [    9.157559] lima d00c0000.gpu: IRQ pp4 not found
  2554    [    9.160780] lima d00c0000.gpu: IRQ pp5 not found
  2555    [    9.165780] lima d00c0000.gpu: IRQ pp6 not found
  2556    [    9.170690] lima d00c0000.gpu: IRQ pp7 not found
  2557    [    9.174623] lima d00c0000.gpu: l2 cache 8K, 4-way, 64byte cache line, 128bit external bus
  2558    [    9.182694] lima d00c0000.gpu: l2 cache 64K, 4-way, 64byte cache line, 128bit external bus
  2559    [    9.191551] lima d00c0000.gpu: bus rate = 166666667
  2560    [    9.194479] lima d00c0000.gpu: mod rate = 744000000
  2561    [    9.202058] [drm] Initialized lima 1.0.0 20190217 for d00c0000.gpu on minor 1
  2562    [    9.262421] cfg80211: Loading compiled-in X.509 certificates for regulatory database
  2563    [    9.298592] Bluetooth: HCI UART driver ver 2.3
  2564    [    9.301253] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
  2565    [    9.308220] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
  2566    [    9.309086] Bluetooth: HCI UART protocol H4 registered
  2567    [    9.314715] cfg80211: failed to load regulatory.db
  2568    [    9.323096] Bluetooth: HCI UART protocol BCSP registered
  2569    [    9.366727] Bluetooth: HCI UART protocol LL registered
  2570    [    9.368546] Bluetooth: HCI UART protocol ATH3K registered
  2571    [    9.394317] Bluetooth: HCI UART protocol Three-wire (H5) registered
  2572    [    9.408539] Bluetooth: HCI UART protocol Intel registered
  2573    [    9.413646] hci_uart_bcm serial0-0: serial0-0 supply vbat not found, using dummy regulator
  2574    [    9.420243] hci_uart_bcm serial0-0: serial0-0 supply vddio not found, using dummy regulator
  2575    [    9.431376] Bluetooth: HCI UART protocol Broadcom registered
  2576    [    9.442681] Bluetooth: HCI UART protocol QCA registered
  2577    [    9.444862] Bluetooth: HCI UART protocol AG6XX registered
  2578    [    9.452767] Bluetooth: HCI UART protocol Marvell registered
  2579    [    9.468106] brcmfmac: F1 signature read @0x18000000=0x16034334
  2580    [    9.478721] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4334-sdio for chip BCM4334/3
  2581    [    9.486437] usbcore: registered new interface driver brcmfmac
  2582    [    9.533602] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.amlogic,p212.txt failed with error -2
  2583    [    9.545525] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.txt failed with error -2
  2584    [    9.566965] usb 1-2: reset high-speed USB device number 3 using xhci-hcd
  2585    [    9.604605] mt7601u 1-2:1.0: ASIC revision: 76010001 MAC revision: 76010500
  2586    [    9.639613] mt7601u 1-2:1.0: EEPROM ver:0d fae:00
  2587    [    9.819587] Bluetooth: hci0: BCM: chip id 68
  2588    [    9.824102] Bluetooth: hci0: BCM: features 0x0f
  2589    [    9.829909] Bluetooth: hci0: BCM4334B0
  2590    [    9.833466] Bluetooth: hci0: BCM4334B0 (002.001.013) build 0000
  2591    [    9.837535] bluetooth hci0: Direct firmware load for brcm/BCM4334B0.hcd failed with error -2
  2592    [    9.846552] Bluetooth: hci0: BCM: Patch brcm/BCM4334B0.hcd not found
  2593    [    9.850943] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
  2594    [    9.853803] usbcore: registered new interface driver mt7601u
  2595    [   10.566663] brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x50
  2596    [   10.672746] zram: Added device: zram0
  2597    [   10.676197] zram: Added device: zram1
  2598    [   10.679381] zram: Added device: zram2
  2599    [   10.701076] meson8b-dwmac c9410000.ethernet eth0: PHY [0.e40908ff:08] driver [Meson GXL Internal PHY]
  2600    [   10.718825] meson8b-dwmac c9410000.ethernet eth0: No Safety Features support found
  2601    [   10.723273] meson8b-dwmac c9410000.ethernet eth0: PTP not supported by HW
  2602    [   10.730069] meson8b-dwmac c9410000.ethernet eth0: configuring for phy/rmii link mode
  2603    [   10.738434] zram1: detected capacity change from 0 to 912879616
  2604    [   11.380719] random: crng init done
  2605    [   11.383194] random: 7 urandom warning(s) missed due to ratelimiting
  2606    [   11.438589] Adding 891480k swap on /dev/zram1.  Priority:5 extents:1 across:891480k SSFS
  2607
  2608    ### armbian-release:
  2609
  2610    # PLEASE DO NOT EDIT THIS FILE
  2611    BOARD=aml-s9xxx
  2612    BOARD_NAME="AML-S9xxx"
  2613    BOARDFAMILY=aml-s9xxx
  2614    BUILD_REPOSITORY_URL=https://github.com/150balbes/Build-Armbian.git
  2615    BUILD_REPOSITORY_COMMIT=62b8c07-dirty
  2616    DISTRIBUTION_CODENAME=buster
  2617    DISTRIBUTION_STATUS=supported
  2618    VERSION=20.02.0-rc1.037
  2619    LINUXFAMILY=aml-s9xxx
  2620    BRANCH=current
  2621    ARCH=arm64
  2622    IMAGE_TYPE=nightly
  2623    BOARD_TYPE=conf
  2624    INITRD_ARCH=arm64
  2625    KERNEL_IMAGE_TYPE=Image
  2626
  2627    ### boot environment:
  2628
  2629    ODROIDN2-UBOOT-CONFIG
  2630    setenv env_addr 0x10400000
  2631    setenv kernel_addr 0x11000000
  2632    setenv initrd_addr 0x13000000
  2633    setenv dtb_addr 0x1000000
  2634    if test "${devtype}" = ""; then setenv devtype "mmc"; fi
  2635    load ${devtype} ${devnum} ${env_addr} uEnv.txt && env import -t ${env_addr} ${filesize}
  2636    setenv bootargs ${APPEND}
  2637    load ${devtype} ${devnum} ${kernel_addr} ${LINUX}
  2638    load ${devtype} ${devnum} ${initrd_addr} ${INITRD}
  2639    load ${devtype} ${devnum} ${dtb_addr} ${FDT}
  2640    fdt addr ${dtb_addr}
  2641    booti ${kernel_addr} ${initrd_addr} ${dtb_addr}
  2642
  2643    ### lsusb:
  2644
  2645    Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
  2646    Bus 001 Device 003: ID 148f:7601 Ralink Technology, Corp. MT7601U Wireless Adapter
  2647    Bus 001 Device 002: ID 05e3:0608 Genesys Logic, Inc. Hub
  2648    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  2649
  2650    ### lscpu:
  2651
  2652    Architecture:        aarch64
  2653    Byte Order:          Little Endian
  2654    CPU(s):              4
  2655    On-line CPU(s) list: 0-3
  2656    Thread(s) per core:  1
  2657    Core(s) per socket:  4
  2658    Socket(s):           1
  2659    Vendor ID:           ARM
  2660    Model:               4
  2661    Model name:          Cortex-A53
  2662    Stepping:            r0p4
  2663    CPU max MHz:         1512,0000
  2664    CPU min MHz:         100,0000
  2665    BogoMIPS:            48.00
  2666    L1d cache:           unknown size
  2667    L1i cache:           unknown size
  2668    L2 cache:            unknown size
  2669    Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  2670
  2671    ### cpuinfo:
  2672
  2673    processor    : 0
  2674    model name    : ARMv8 Processor rev 4 (v8l)
  2675    BogoMIPS    : 48.00
  2676    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  2677    CPU implementer    : 0x41
  2678    CPU architecture: 8
  2679    CPU variant    : 0x0
  2680    CPU part    : 0xd03
  2681    CPU revision    : 4
  2682
  2683    processor    : 1
  2684    model name    : ARMv8 Processor rev 4 (v8l)
  2685    BogoMIPS    : 48.00
  2686    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  2687    CPU implementer    : 0x41
  2688    CPU architecture: 8
  2689    CPU variant    : 0x0
  2690    CPU part    : 0xd03
  2691    CPU revision    : 4
  2692
  2693    processor    : 2
  2694    model name    : ARMv8 Processor rev 4 (v8l)
  2695    BogoMIPS    : 48.00
  2696    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  2697    CPU implementer    : 0x41
  2698    CPU architecture: 8
  2699    CPU variant    : 0x0
  2700    CPU part    : 0xd03
  2701    CPU revision    : 4
  2702
  2703    processor    : 3
  2704    model name    : ARMv8 Processor rev 4 (v8l)
  2705    BogoMIPS    : 48.00
  2706    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  2707    CPU implementer    : 0x41
  2708    CPU architecture: 8
  2709    CPU variant    : 0x0
  2710    CPU part    : 0xd03
  2711    CPU revision    : 4
  2712
  2713
  2714    ### meminfo:
  2715
  2716    MemTotal:        1782968 kB
  2717    MemFree:         1610676 kB
  2718    MemAvailable:    1666844 kB
  2719    Buffers:           11640 kB
  2720    Cached:            52980 kB
  2721    SwapCached:            0 kB
  2722    Active:            51084 kB
  2723    Inactive:          34584 kB
  2724    Active(anon):      21292 kB
  2725    Inactive(anon):     2636 kB
  2726    Active(file):      29792 kB
  2727    Inactive(file):    31948 kB
  2728    Unevictable:          16 kB
  2729    Mlocked:              16 kB
  2730    SwapTotal:        891480 kB
  2731    SwapFree:         891480 kB
  2732    Dirty:               616 kB
  2733    Writeback:             0 kB
  2734    AnonPages:         21268 kB
  2735    Mapped:            22136 kB
  2736    Shmem:              2752 kB
  2737    KReclaimable:      17544 kB
  2738    Slab:              52484 kB
  2739    SReclaimable:      17544 kB
  2740    SUnreclaim:        34940 kB
  2741    KernelStack:        2760 kB
  2742    PageTables:         1640 kB
  2743    NFS_Unstable:          0 kB
  2744    Bounce:                0 kB
  2745    WritebackTmp:          0 kB
  2746    CommitLimit:     1782964 kB
  2747    Committed_AS:      74504 kB
  2748    VmallocTotal:   135290159040 kB
  2749    VmallocUsed:       16712 kB
  2750    VmallocChunk:          0 kB
  2751    Percpu:             1264 kB
  2752    CmaTotal:         262144 kB
  2753    CmaFree:          258460 kB
  2754    HugePages_Total:       0
  2755    HugePages_Free:        0
  2756    HugePages_Rsvd:        0
  2757    HugePages_Surp:        0
  2758    Hugepagesize:       2048 kB
  2759    Hugetlb:               0 kB
  2760
  2761    ### virtual memory:
  2762
  2763    vm.admin_reserve_kbytes = 8192
  2764    vm.block_dump = 0
  2765    vm.compact_unevictable_allowed = 1
  2766    vm.dirty_background_bytes = 0
  2767    vm.dirty_background_ratio = 10
  2768    vm.dirty_bytes = 0
  2769    vm.dirty_expire_centisecs = 3000
  2770    vm.dirty_ratio = 20
  2771    vm.dirtytime_expire_seconds = 43200
  2772    vm.dirty_writeback_centisecs = 500
  2773    vm.extfrag_threshold = 500
  2774    vm.hugetlb_shm_group = 0
  2775    vm.laptop_mode = 0
  2776    vm.legacy_va_layout = 0
  2777    vm.lowmem_reserve_ratio = 256    256    32    0
  2778    vm.max_map_count = 65530
  2779    vm.min_free_kbytes = 4914
  2780    vm.mmap_min_addr = 4096
  2781    vm.mmap_rnd_bits = 18
  2782    vm.nr_hugepages = 0
  2783    vm.nr_overcommit_hugepages = 0
  2784    vm.oom_dump_tasks = 1
  2785    vm.oom_kill_allocating_task = 0
  2786    vm.overcommit_kbytes = 0
  2787    vm.overcommit_memory = 0
  2788    vm.overcommit_ratio = 50
  2789    vm.page-cluster = 0
  2790    vm.panic_on_oom = 0
  2791    vm.percpu_pagelist_fraction = 0
  2792    vm.stat_interval = 1
  2793    vm.swappiness = 100
  2794    vm.user_reserve_kbytes = 55239
  2795    vm.vfs_cache_pressure = 100
  2796    vm.watermark_boost_factor = 15000
  2797    vm.watermark_scale_factor = 10
  2798
  2799    ### ip addr:
  2800
  2801    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
  2802        link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  2803        inet XXX.XXX.0.1/8 scope host lo
  2804           valid_lft forever preferred_lft forever
  2805        inet6 ::1/128 scope host
  2806           valid_lft forever preferred_lft forever
  2807    2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
  2808        link/ether 00:df:06:00:00:0b brd ff:ff:ff:ff:ff:ff
  2809    3: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  2810        link/ether 00:36:76:61:0b:24 brd ff:ff:ff:ff:ff:ff
  2811
  2812    ### partitions:
  2813
  2814    major minor  #blocks  name
  2815
  2816     179        0   30924800 mmcblk0
  2817     179        1     262144 mmcblk0p1
  2818     179        2   30337024 mmcblk0p2
  2819     179       32   15384576 mmcblk1
  2820     179      128       8192 mmcblk1gp0
  2821     254        1     891484 zram1
  2822
  2823    ### df:
  2824
  2825    udev             738M      0  738M   0% /dev
  2826    tmpfs            175M   2,7M  172M   2% /run
  2827    /dev/mmcblk0p2    29G    10G   19G  36% /
  2828    tmpfs            871M      0  871M   0% /dev/shm
  2829    tmpfs            5,0M   4,0K  5,0M   1% /run/lock
  2830    tmpfs            871M      0  871M   0% /sys/fs/cgroup
  2831    tmpfs            871M      0  871M   0% /tmp
  2832    /dev/mmcblk0p1   256M    76M  180M  30% /boot
  2833
  2834    ### lsblk:
  2835
  2836    NAME         FSTYPE   SIZE MOUNTPOINT UUID
  2837    mmcblk0              29,5G
  2838    ├─mmcblk0p1  vfat     256M /boot      50FC-6AC8
  2839    └─mmcblk0p2  ext4      29G /          3e297ac1-e4e4-4ab1-bc57-47c07d0422ba
  2840    mmcblk1              14,7G
  2841    mmcblk1boot0            4M
  2842    mmcblk1boot1            4M
  2843    mmcblk1gp0              8M
  2844
  2845    ### zramctl:
  2846
  2847    NAME       ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT
  2848    /dev/zram1 lzo         870,6M   4K   81B   12K       4 [SWAP]
  2849
  2850    ### mtab:
  2851
  2852    /dev/mmcblk0p1 /boot vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro 0 0
  2853    /dev/mmcblk0p2 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  2854
  2855    ### mmc0:59b4 info:
  2856
  2857                   fwrev: 0x0
  2858                  uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SDU1  MODALIAS=mmc:block
  2859                     cid: 1b534d53445531201014a136d4013800
  2860                     rca: 0x59b4
  2861                     csd: 400e00325b590000ebef7f800a400000
  2862                  manfid: 0x00001b
  2863                     ocr: 0x00200000
  2864    preferred_erase_size: 4194304
  2865                    type: SD
  2866                   hwrev: 0x1
  2867                    date: 08/2019
  2868                     dsr: 0x404
  2869              erase_size: 512
  2870                   oemid: 0x534d
  2871                  serial: 0x14a136d4
  2872                     ssr: 0000000005000000040090000811391e00089a342f01000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  2873                     scr: 0235844300000000
  2874                    name: SDU1
  2875
  2876    ### mmc1:0001 info:
  2877
  2878                   fwrev: 0x0
  2879                  uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=016G92 MODALIAS=mmc:block
  2880                     cid: 11010030313647393201d3d1a4db1100
  2881             rel_sectors: 0x10
  2882                     rca: 0x0001
  2883            pre_eol_info: 0x00
  2884                     csd: d00e00320f5903ffffffffef92400000
  2885                  manfid: 0x000011
  2886                     ocr: 0x00200000
  2887    preferred_erase_size: 4194304
  2888    enhanced_area_offset: 18446744073709551594
  2889      raw_rpmb_size_mult: 0x4
  2890                    type: MMC
  2891                   hwrev: 0x0
  2892                    date: 01/2014
  2893                     prv: 0x1
  2894             ffu_capable: 0
  2895                     dsr: 0x404
  2896              erase_size: 4194304
  2897               life_time: 0x00 0x00
  2898      enhanced_area_size: 4294967274
  2899                   oemid: 0x0100
  2900                  serial: 0xd3d1a4db
  2901                 cmdq_en: 0
  2902                     rev: 0x6
  2903                    name: 016G92
  2904
  2905    ### Boot system health:
  2906
  2907    Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU
  2908    09:17:07: 1512MHz  0.62  50%  24%  14%   0%  10%   1% 57.0°C
  2909    09:17:07: 1512MHz  0.62  64%   6%  10%   0%  44%   1% 57.0°C
  2910    09:17:07: 1512MHz  0.62  70%  10%  22%   2%  34%   2% 57.0°C
  2911    09:17:08: 1512MHz  0.89  56%   9%  13%   0%  30%   1% 57.0°C
  2912    09:17:08: 1512MHz  0.89  33%   5%   4%   1%  20%   1% 56.0°C
  2913
  2914    ### Activated 1 lzo zram swap devices with 870 MB each
  2915
  2916
  2917    mar mar 23 21:19:42 CET 2021 | AML-S9xxx | 20.02.0-rc1.037 | arm64 | aarch64 | 5.5.0-rc6-aml-s9xxx
  2918
  2919    ### dmesg:
  2920
  2921    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
  2922    [    0.000000] Linux version 5.5.0-rc6-aml-s9xxx (root@vbox) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #rc1.037 SMP PREEMPT Wed Feb 5 15:59:04 MSK 2020
  2923    [    0.000000] Machine model: Amlogic Meson GXL (S905X) P212 Development Board
  2924    [    0.000000] efi: Getting EFI parameters from FDT:
  2925    [    0.000000] efi: UEFI not found.
  2926    [    0.000000] Reserved memory: created CMA memory pool at 0x0000000063400000, size 256 MiB
  2927    [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
  2928    [    0.000000] On node 0 totalpages: 477952
  2929    [    0.000000]   DMA zone: 4032 pages used for memmap
  2930    [    0.000000]   DMA zone: 0 pages reserved
  2931    [    0.000000]   DMA zone: 248576 pages, LIFO batch:63
  2932    [    0.000000]   DMA32 zone: 3584 pages used for memmap
  2933    [    0.000000]   DMA32 zone: 229376 pages, LIFO batch:63
  2934    [    0.000000] psci: probing for conduit method from DT.
  2935    [    0.000000] psci: PSCIv0.2 detected in firmware.
  2936    [    0.000000] psci: Using standard PSCI v0.2 function IDs
  2937    [    0.000000] psci: Trusted OS migration not required
  2938    [    0.000000] percpu: Embedded 22 pages/cpu s50392 r8192 d31528 u90112
  2939    [    0.000000] pcpu-alloc: s50392 r8192 d31528 u90112 alloc=22*4096
  2940    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
  2941    [    0.000000] Detected VIPT I-cache on CPU0
  2942    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 470336
  2943    [    0.000000] Kernel command line: root=LABEL=ROOTFS rootflags=data=writeback rw console=ttyAML0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 mac=00:df:06:00:00:0b
  2944    [    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
  2945    [    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
  2946    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
  2947    [    0.000000] software IO TLB: mapped [mem 0x3bfff000-0x3ffff000] (64MB)
  2948    [    0.000000] Memory: 1509616K/1911808K available (14460K kernel code, 1434K rwdata, 5884K rodata, 960K init, 927K bss, 140048K reserved, 262144K cma-reserved)
  2949    [    0.000000] random: get_random_u64 called from cache_random_seq_create+0x7c/0x150 with crng_init=0
  2950    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
  2951    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
  2952    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
  2953    [    0.000000]     Tasks RCU enabled.
  2954    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
  2955    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
  2956    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
  2957    [    0.000000] GIC: Using split EOI/Deactivate mode
  2958    [    0.000000] irq_meson_gpio: 110 to 8 gpio interrupt mux initialized
  2959    [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
  2960    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
  2961    [    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
  2962    [    0.000355] Console: colour dummy device 80x25
  2963    [    0.000657] printk: console [tty0] enabled
  2964    [    0.000697] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
  2965    [    0.000718] pid_max: default: 32768 minimum: 301
  2966    [    0.000841] LSM: Security Framework initializing
  2967    [    0.000892] SELinux:  Initializing.
  2968    [    0.000969] *** VALIDATE SELinux ***
  2969    [    0.001035] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
  2970    [    0.001061] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
  2971    [    0.001123] *** VALIDATE tmpfs ***
  2972    [    0.001531] *** VALIDATE proc ***
  2973    [    0.001753] *** VALIDATE cgroup1 ***
  2974    [    0.001768] *** VALIDATE cgroup2 ***
  2975    [    0.024018] ASID allocator initialised with 32768 entries
  2976    [    0.032003] rcu: Hierarchical SRCU implementation.
  2977    [    0.042089] EFI services will not be available.
  2978    [    0.048059] smp: Bringing up secondary CPUs ...
  2979    [    0.080286] Detected VIPT I-cache on CPU1
  2980    [    0.080340] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
  2981    [    0.112325] Detected VIPT I-cache on CPU2
  2982    [    0.112371] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
  2983    [    0.144375] Detected VIPT I-cache on CPU3
  2984    [    0.144415] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
  2985    [    0.144492] smp: Brought up 1 node, 4 CPUs
  2986    [    0.144559] SMP: Total of 4 processors activated.
  2987    [    0.144570] CPU features: detected: 32-bit EL0 Support
  2988    [    0.144582] CPU features: detected: CRC32 instructions
  2989    [    0.144885] CPU: All CPU(s) started at EL2
  2990    [    0.144908] alternatives: patching kernel code
  2991    [    0.146007] devtmpfs: initialized
  2992    [    0.151117] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
  2993    [    0.151158] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
  2994    [    0.158013] xor: measuring software checksum speed
  2995    [    0.196376]    8regs     :  2375.000 MB/sec
  2996    [    0.236407]    32regs    :  2724.000 MB/sec
  2997    [    0.276446]    arm64_neon:  2406.000 MB/sec
  2998    [    0.276456] xor: using function: 32regs (2724.000 MB/sec)
  2999    [    0.276513] pinctrl core: initialized pinctrl subsystem
  3000    [    0.277174] thermal_sys: Registered thermal governor 'step_wise'
  3001    [    0.277340] DMI not present or invalid.
  3002    [    0.277701] NET: Registered protocol family 16
  3003    [    0.281251] DMA: preallocated 256 KiB pool for atomic allocations
  3004    [    0.281299] audit: initializing netlink subsys (disabled)
  3005    [    0.281513] audit: type=2000 audit(0.280:1): state=initialized audit_enabled=0 res=1
  3006    [    0.282591] cpuidle: using governor ladder
  3007    [    0.282633] cpuidle: using governor menu
  3008    [    0.283004] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
  3009    [    0.283717] Serial: AMBA PL011 UART driver
  3010    [    0.297724] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
  3011    [    0.297751] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
  3012    [    0.297764] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
  3013    [    0.297777] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
  3014    [    0.301295] cryptd: max_cpu_qlen set to 1000
  3015    [    0.376682] raid6: neonx8   gen()  1621 MB/s
  3016    [    0.444706] raid6: neonx8   xor()  1493 MB/s
  3017    [    0.512771] raid6: neonx4   gen()  1563 MB/s
  3018    [    0.580813] raid6: neonx4   xor()  1469 MB/s
  3019    [    0.648868] raid6: neonx2   gen()  1200 MB/s
  3020    [    0.716918] raid6: neonx2   xor()  1217 MB/s
  3021    [    0.784985] raid6: neonx1   gen()   788 MB/s
  3022    [    0.853045] raid6: neonx1   xor()   914 MB/s
  3023    [    0.921081] raid6: int64x8  gen()  1194 MB/s
  3024    [    0.989136] raid6: int64x8  xor()   769 MB/s
  3025    [    1.057201] raid6: int64x4  gen()  1029 MB/s
  3026    [    1.125252] raid6: int64x4  xor()   752 MB/s
  3027    [    1.193278] raid6: int64x2  gen()   728 MB/s
  3028    [    1.261329] raid6: int64x2  xor()   618 MB/s
  3029    [    1.329460] raid6: int64x1  gen()   486 MB/s
  3030    [    1.397431] raid6: int64x1  xor()   468 MB/s
  3031    [    1.397441] raid6: using algorithm neonx8 gen() 1621 MB/s
  3032    [    1.397451] raid6: .... xor() 1493 MB/s, rmw enabled
  3033    [    1.397467] raid6: using neon recovery algorithm
  3034    [    1.397715] ACPI: Interpreter disabled.
  3035    [    1.398887] iommu: Default domain type: Translated
  3036    [    1.399164] vgaarb: loaded
  3037    [    1.399744] SCSI subsystem initialized
  3038    [    1.399927] libata version 3.00 loaded.
  3039    [    1.400133] usbcore: registered new interface driver usbfs
  3040    [    1.400178] usbcore: registered new interface driver hub
  3041    [    1.400241] usbcore: registered new device driver usb
  3042    [    1.400645] pps_core: LinuxPPS API ver. 1 registered
  3043    [    1.400658] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
  3044    [    1.400680] PTP clock support registered
  3045    [    1.400707] EDAC MC: Ver: 3.0.0
  3046    [    1.401303] FPGA manager framework
  3047    [    1.401392] Advanced Linux Sound Architecture Driver Initialized.
  3048    [    1.401881] NetLabel: Initializing
  3049    [    1.401895] NetLabel:  domain hash size = 128
  3050    [    1.401904] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
  3051    [    1.401957] NetLabel:  unlabeled traffic allowed by default
  3052    [    1.402438] clocksource: Switched to clocksource arch_sys_counter
  3053    [    1.402460] *** VALIDATE bpf ***
  3054    [    1.402710] VFS: Disk quotas dquot_6.6.0
  3055    [    1.402769] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
  3056    [    1.402892] FS-Cache: Loaded
  3057    [    1.402903] *** VALIDATE ramfs ***
  3058    [    1.402925] *** VALIDATE hugetlbfs ***
  3059    [    1.403296] pnp: PnP ACPI: disabled
  3060    [    1.408322] NET: Registered protocol family 2
  3061    [    1.408821] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
  3062    [    1.408871] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
  3063    [    1.408988] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
  3064    [    1.409233] TCP: Hash tables configured (established 16384 bind 16384)
  3065    [    1.409395] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
  3066    [    1.409450] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
  3067    [    1.409667] NET: Registered protocol family 1
  3068    [    1.410120] RPC: Registered named UNIX socket transport module.
  3069    [    1.410140] RPC: Registered udp transport module.
  3070    [    1.410149] RPC: Registered tcp transport module.
  3071    [    1.410159] RPC: Registered tcp NFSv4.1 backchannel transport module.
  3072    [    1.410175] NET: Registered protocol family 44
  3073    [    1.410196] PCI: CLS 0 bytes, default 64
  3074    [    1.410388] Trying to unpack rootfs image as initramfs...
  3075    [    1.871864] Freeing initrd memory: 10248K
  3076    [    1.872664] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
  3077    [    2.086306] Initialise system trusted keyrings
  3078    [    2.086595] workingset: timestamp_bits=46 max_order=19 bucket_order=0
  3079    [    2.091765] zbud: loaded
  3080    [    2.093008] squashfs: version 4.0 (2009/01/31) Phillip Lougher
  3081    [    2.093291] FS-Cache: Netfs 'nfs' registered for caching
  3082    [    2.093830] NFS: Registering the id_resolver key type
  3083    [    2.093870] Key type id_resolver registered
  3084    [    2.093880] Key type id_legacy registered
  3085    [    2.093896] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
  3086    [    2.093908] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
  3087    [    2.095063] FS-Cache: Netfs 'cifs' registered for caching
  3088    [    2.095384] Key type cifs.spnego registered
  3089    [    2.095403] Key type cifs.idmap registered
  3090    [    2.095425] ntfs: driver 2.1.32 [Flags: R/W].
  3091    [    2.095992] JFS: nTxBlock = 8192, nTxLock = 65536
  3092    [    2.101852] SGI XFS with ACLs, security attributes, realtime, quota, no debug enabled
  3093    [    2.103292] *** VALIDATE xfs ***
  3094    [    2.103576] ocfs2: Registered cluster interface o2cb
  3095    [    2.103788] OCFS2 User DLM kernel interface loaded
  3096    [    2.105194] *** VALIDATE gfs2 ***
  3097    [    2.105475] gfs2: GFS2 installed
  3098    [    2.106400] aufs 5.5-20200203
  3099    [    2.126670] Key type asymmetric registered
  3100    [    2.126695] Asymmetric key parser 'x509' registered
  3101    [    2.126706] Asymmetric key parser 'pkcs8' registered
  3102    [    2.126775] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
  3103    [    2.126970] io scheduler mq-deadline registered
  3104    [    2.126984] io scheduler kyber registered
  3105    [    2.127183] io scheduler bfq registered
  3106    [    2.139800] soc soc0: Amlogic Meson GXL (S905X) Revision 21:b (82:2) Detected
  3107    [    2.143368] Serial: 8250/16550 driver, 5 ports, IRQ sharing enabled
  3108    [    2.145047] Serial: AMBA driver
  3109    [    2.145418] c11084c0.serial: ttyAML6 at MMIO 0xc11084c0 (irq = 10, base_baud = 1500000) is a meson_uart
  3110    [    2.145573] serial serial0: tty port ttyAML6 registered
  3111    [    2.145782] c81004c0.serial: ttyAML0 at MMIO 0xc81004c0 (irq = 13, base_baud = 1500000) is a meson_uart
  3112    [    3.121269] printk: console [ttyAML0] enabled
  3113    [    3.137363] brd: module loaded
  3114    [    3.145840] loop: module loaded
  3115    [    3.148319] libphy: Fixed MDIO Bus: probed
  3116    [    3.148969] meson8b-dwmac c9410000.ethernet: IRQ eth_wake_irq not found
  3117    [    3.154019] meson8b-dwmac c9410000.ethernet: IRQ eth_lpi not found
  3118    [    3.160213] meson8b-dwmac c9410000.ethernet: PTP uses main clock
  3119    [    3.166069] meson8b-dwmac c9410000.ethernet: no reset control found
  3120    [    3.172767] meson8b-dwmac c9410000.ethernet: User ID: 0x11, Synopsys ID: 0x37
  3121    [    3.179371] meson8b-dwmac c9410000.ethernet:     DWMAC1000
  3122    [    3.184538] meson8b-dwmac c9410000.ethernet: DMA HW capability register supported
  3123    [    3.191939] meson8b-dwmac c9410000.ethernet: RX Checksum Offload Engine supported
  3124    [    3.199356] meson8b-dwmac c9410000.ethernet: COE Type 2
  3125    [    3.204529] meson8b-dwmac c9410000.ethernet: TX Checksum insertion supported
  3126    [    3.211515] meson8b-dwmac c9410000.ethernet: Wake-Up On Lan supported
  3127    [    3.217929] meson8b-dwmac c9410000.ethernet: Normal descriptors
  3128    [    3.223764] meson8b-dwmac c9410000.ethernet: Ring mode enabled
  3129    [    3.229541] meson8b-dwmac c9410000.ethernet: Enable RX Mitigation via HW Watchdog Timer
  3130    [    3.237658] libphy: stmmac: probed
  3131    [    3.242151] VFIO - User Level meta-driver version: 0.3
  3132    [    3.247500] dwc3 c9000000.dwc3: Failed to get clk 'ref': -2
  3133    [    3.252360] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
  3134    [    3.257950] ehci-pci: EHCI PCI platform driver
  3135    [    3.262384] ehci-platform: EHCI generic platform driver
  3136    [    3.267686] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
  3137    [    3.273632] ohci-pci: OHCI PCI platform driver
  3138    [    3.278060] ohci-platform: OHCI generic platform driver
  3139    [    3.283798] usbcore: registered new interface driver usb-storage
  3140    [    3.289396] mousedev: PS/2 mouse device common for all mice
  3141    [    3.295328] i2c /dev entries driver
  3142    [    3.300944] sdhci: Secure Digital Host Controller Interface driver
  3143    [    3.304251] sdhci: Copyright(c) Pierre Ossman
  3144    [    3.308566] Synopsys Designware Multimedia Card Interface Driver
  3145    [    3.315828] meson-gx-mmc d0072000.mmc: Got CD GPIO
  3146    [    3.346475] meson-gx-mmc d0074000.mmc: allocated mmc-pwrseq
  3147    [    3.377729] sdhci-pltfm: SDHCI platform and OF driver helper
  3148    [    3.378609] ledtrig-cpu: registered to indicate activity on CPUs
  3149    [    3.384289] meson-sm: secure-monitor enabled
  3150    [    3.386108] mmc0: new high speed SDHC card at address 59b4
  3151    [    3.388806] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
  3152    [    3.398316] mmcblk0: mmc0:59b4 SDU1  29.5 GiB
  3153    [    3.401395] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
  3154    [    3.416240]  mmcblk0: p1 p2
  3155    [    3.428925] hid: raw HID events driver (C) Jiri Kosina
  3156    [    3.429163] usbcore: registered new interface driver usbhid
  3157    [    3.433982] usbhid: USB HID core driver
  3158    [    3.438122] platform-mhu c883c404.mailbox: Platform MHU Mailbox registered
  3159    [    3.454817] NET: Registered protocol family 17
  3160    [    3.455072] Key type dns_resolver registered
  3161    [    3.458374] registered taskstats version 1
  3162    [    3.461943] Loading compiled-in X.509 certificates
  3163    [    3.466872] zswap: loaded using pool lzo/zbud
  3164    [    3.471179] Key type ._fscrypt registered
  3165    [    3.474951] Key type .fscrypt registered
  3166    [    3.480317] Btrfs loaded, crc32c=crc32c-generic
  3167    [    3.500162] mmc1: new HS200 MMC card at address 0001
  3168    [    3.501003] mmcblk1: mmc1:0001 016G92 14.7 GiB
  3169    [    3.504604] mmcblk1boot0: mmc1:0001 016G92 partition 1 4.00 MiB
  3170    [    3.510331] mmcblk1boot1: mmc1:0001 016G92 partition 2 4.00 MiB
  3171    [    3.510548] Key type encrypted registered
  3172    [    3.516162] mmcblk1gp0: mmc1:0001 016G92 partition 4 8.00 MiB
  3173    [    3.525704] mmcblk1rpmb: mmc1:0001 016G92 partition 3 512 KiB, chardev (243:0)
  3174    [    3.539703] meson-drm d0100000.vpu: Queued 3 outputs on vpu
  3175    [    3.540066] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
  3176    [    3.546244] [drm] No driver support for vblank timestamp query.
  3177    [    3.582486] meson-dw-hdmi c883a000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
  3178    [    3.587175] meson-dw-hdmi c883a000.hdmi-tx: registered DesignWare HDMI I2C bus driver
  3179    [    3.595134] meson-drm d0100000.vpu: bound c883a000.hdmi-tx (ops meson_dw_hdmi_ops)
  3180    [    3.602524] [drm] Initialized meson 1.0.0 20161109 for d0100000.vpu on minor 0
  3181    [    3.654111] Console: switching to colour frame buffer device 90x36
  3182    [    3.674471] meson-drm d0100000.vpu: fb0: mesondrmfb frame buffer device
  3183    [    3.681729] libphy: mdio_mux: probed
  3184    [    3.692306] libphy: mdio_mux: probed
  3185    [    3.692784] phy phy-d0078080.phy.2: unsupported PHY mode 5
  3186    [    3.697838] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  3187    [    3.701238] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
  3188    [    3.708956] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228f664 hci version 0x100 quirks 0x0000000002010010
  3189    [    3.718176] xhci-hcd xhci-hcd.0.auto: irq 39, io mem 0xc9000000
  3190    [    3.724300] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.05
  3191    [    3.732533] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  3192    [    3.739680] usb usb1: Product: xHCI Host Controller
  3193    [    3.744508] usb usb1: Manufacturer: Linux 5.5.0-rc6-aml-s9xxx xhci-hcd
  3194    [    3.750977] usb usb1: SerialNumber: xhci-hcd.0.auto
  3195    [    3.756314] hub 1-0:1.0: USB hub found
  3196    [    3.759557] hub 1-0:1.0: 2 ports detected
  3197    [    3.763784] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  3198    [    3.768936] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
  3199    [    3.776520] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
  3200    [    3.783023] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
  3201    [    3.791282] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.05
  3202    [    3.799659] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  3203    [    3.806815] usb usb2: Product: xHCI Host Controller
  3204    [    3.811644] usb usb2: Manufacturer: Linux 5.5.0-rc6-aml-s9xxx xhci-hcd
  3205    [    3.818118] usb usb2: SerialNumber: xhci-hcd.0.auto
  3206    [    3.823409] hub 2-0:1.0: USB hub found
  3207    [    3.826691] hub 2-0:1.0: config failed, hub doesn't have any ports! (err -19)
  3208    [    3.835635] meson-gx-mmc d0070000.mmc: allocated mmc-pwrseq
  3209    [    3.866756] scpi_protocol scpi: SCP Protocol legacy pre-1.0 firmware
  3210    [    3.881694] gx-sound-card sound: snd-soc-dummy-dai <-> c1105400.bus:audio-controller-0 mapping ok
  3211    [    3.893501] gx-sound-card sound: i2s-hifi <-> c1105400.bus:audio-controller-2 mapping ok
  3212    [    3.906981] gx-sound-card sound: ASoC: no DMI vendor name!
  3213    [    3.914094] printk: console [netcon0] enabled
  3214    [    3.916762] netconsole: network logging started
  3215    [    3.921257] hctosys: unable to open rtc device (rtc0)
  3216    [    3.926646] ALSA device list:
  3217    [    3.929147]   #0: AMLGX
  3218    [    3.932152] Freeing unused kernel memory: 960K
  3219    [    3.936019] Run /init as init process
  3220    [    3.952150] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
  3221    [    3.958983] mmc2: queuing unknown CIS tuple 0x80 (6 bytes)
  3222    [    3.966057] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
  3223    [    3.978108] mmc2: queuing unknown CIS tuple 0x80 (19 bytes)
  3224    [    4.004629] random: fast init done
  3225    [    4.063607] mmc2: new high speed SDIO card at address 0001
  3226    [    4.106519] usb 1-1: new high-speed USB device number 2 using xhci-hcd
  3227    [    4.127848] usb 1-1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.36
  3228    [    4.135524] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
  3229    [    4.141775] usb 1-1: Product: USB2.0 Hub
  3230    [    4.199533] hub 1-1:1.0: USB hub found
  3231    [    4.202102] hub 1-1:1.0: 4 ports detected
  3232    [    4.338530] usb 1-2: new high-speed USB device number 3 using xhci-hcd
  3233    [    4.368971] usb 1-2: New USB device found, idVendor=148f, idProduct=7601, bcdDevice= 0.00
  3234    [    4.376432] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
  3235    [    4.390570] usb 1-2: Product: 802.11 n WLAN
  3236    [    4.392787] usb 1-2: Manufacturer: MediaTek
  3237    [    4.395474] usb 1-2: SerialNumber: 1.0
  3238    [    5.099822] EXT4-fs (mmcblk0p2): mounted filesystem with writeback data mode. Opts: data=writeback
  3239    [    6.048820] systemd[1]: System time before build time, advancing clock.
  3240    [    6.196333] NET: Registered protocol family 10
  3241    [    6.270105] Segment Routing with IPv6
  3242    [    6.320855] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
  3243    [    6.354372] systemd[1]: Detected architecture arm64.
  3244    [    6.407432] systemd[1]: Set hostname to <mxqpro>.
  3245    [    6.440906] systemd[1]: Couldn't move remaining userspace processes, ignoring: Input/output error
  3246    [    7.139111] random: systemd: uninitialized urandom read (16 bytes read)
  3247    [    7.151443] random: systemd: uninitialized urandom read (16 bytes read)
  3248    [    7.155058] systemd[1]: Reached target Swap.
  3249    [    7.162373] random: systemd: uninitialized urandom read (16 bytes read)
  3250    [    7.166618] systemd[1]: Listening on Journal Socket.
  3251    [    7.179338] systemd[1]: Mounting Huge Pages File System...
  3252    [    7.185005] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
  3253    [    7.193947] systemd[1]: Created slice User and Session Slice.
  3254    [    7.204144] systemd[1]: Starting Restore / save the current clock...
  3255    [    7.347072] EXT4-fs (mmcblk0p2): re-mounted. Opts: commit=600,errors=remount-ro
  3256    [    7.629413] systemd-journald[414]: Received request to flush runtime journal from PID 1
  3257    [    8.162338] Registered IR keymap rc-empty
  3258    [    8.167562] rc rc0: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0
  3259    [    8.167715] input: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0/input0
  3260    [    8.168779] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
  3261    [    8.168977] meson-ir c8100580.ir: receiver initialized
  3262    [    8.197964] mc: Linux media interface: v0.10
  3263    [    8.225407] videodev: Linux video capture interface: v2.00
  3264    [    8.337571] Bluetooth: Core ver 2.22
  3265    [    8.341132] NET: Registered protocol family 31
  3266    [    8.344095] Bluetooth: HCI device and connection manager initialized
  3267    [    8.348947] Bluetooth: HCI socket layer initialized
  3268    [    8.353709] Bluetooth: L2CAP socket layer initialized
  3269    [    8.359498] Bluetooth: SCO socket layer initialized
  3270    [    8.360538] lima d00c0000.gpu: IRQ ppmmu3 not found
  3271    [    8.368178] lima d00c0000.gpu: IRQ ppmmu4 not found
  3272    [    8.372908] lima d00c0000.gpu: IRQ ppmmu5 not found
  3273    [    8.377853] lima d00c0000.gpu: IRQ ppmmu6 not found
  3274    [    8.382529] lima d00c0000.gpu: IRQ ppmmu7 not found
  3275    [    8.387445] lima d00c0000.gpu: gp - mali450 version major 0 minor 0
  3276    [    8.395703] lima d00c0000.gpu: pp0 - mali450 version major 0 minor 0
  3277    [    8.401955] lima d00c0000.gpu: pp1 - mali450 version major 0 minor 0
  3278    [    8.408416] lima d00c0000.gpu: pp2 - mali450 version major 0 minor 0
  3279    [    8.414739] lima d00c0000.gpu: IRQ pp3 not found
  3280    [    8.417351] lima d00c0000.gpu: IRQ pp4 not found
  3281    [    8.424486] lima d00c0000.gpu: IRQ pp5 not found
  3282    [    8.427863] lima d00c0000.gpu: IRQ pp6 not found
  3283    [    8.432895] lima d00c0000.gpu: IRQ pp7 not found
  3284    [    8.436839] lima d00c0000.gpu: l2 cache 8K, 4-way, 64byte cache line, 128bit external bus
  3285    [    8.444957] lima d00c0000.gpu: l2 cache 64K, 4-way, 64byte cache line, 128bit external bus
  3286    [    8.453791] lima d00c0000.gpu: bus rate = 166666667
  3287    [    8.456591] lima d00c0000.gpu: mod rate = 744000000
  3288    [    8.466237] [drm] Initialized lima 1.0.0 20190217 for d00c0000.gpu on minor 1
  3289    [    8.578496] Bluetooth: HCI UART driver ver 2.3
  3290    [    8.580103] Bluetooth: HCI UART protocol H4 registered
  3291    [    8.590577] Bluetooth: HCI UART protocol BCSP registered
  3292    [    8.592215] Bluetooth: HCI UART protocol LL registered
  3293    [    8.604950] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
  3294    [    8.607957] Bluetooth: HCI UART protocol ATH3K registered
  3295    [    8.625058] Bluetooth: HCI UART protocol Three-wire (H5) registered
  3296    [    8.641264] cfg80211: Loading compiled-in X.509 certificates for regulatory database
  3297    [    8.671320] Bluetooth: HCI UART protocol Intel registered
  3298    [    8.673562] hci_uart_bcm serial0-0: serial0-0 supply vbat not found, using dummy regulator
  3299    [    8.681406] hci_uart_bcm serial0-0: serial0-0 supply vddio not found, using dummy regulator
  3300    [    8.694377] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
  3301    [    8.697434] Bluetooth: HCI UART protocol Broadcom registered
  3302    [    8.710645] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
  3303    [    8.718241] cfg80211: failed to load regulatory.db
  3304    [    8.729581] Bluetooth: HCI UART protocol QCA registered
  3305    [    8.745239] Bluetooth: HCI UART protocol AG6XX registered
  3306    [    8.757175] Bluetooth: HCI UART protocol Marvell registered
  3307    [    8.874079] brcmfmac: F1 signature read @0x18000000=0x16034334
  3308    [    8.877379] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4334-sdio for chip BCM4334/3
  3309    [    8.885521] usbcore: registered new interface driver brcmfmac
  3310    [    8.934980] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.amlogic,p212.txt failed with error -2
  3311    [    8.945342] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.txt failed with error -2
  3312    [    8.982983] usb 1-2: reset high-speed USB device number 3 using xhci-hcd
  3313    [    9.006286] mt7601u 1-2:1.0: ASIC revision: 76010001 MAC revision: 76010500
  3314    [    9.075576] mt7601u 1-2:1.0: EEPROM ver:0d fae:00
  3315    [    9.083475] Bluetooth: hci0: BCM: chip id 68
  3316    [    9.087249] Bluetooth: hci0: BCM: features 0x0f
  3317    [    9.091998] Bluetooth: hci0: BCM4334B0
  3318    [    9.095099] Bluetooth: hci0: BCM4334B0 (002.001.013) build 0000
  3319    [    9.099318] bluetooth hci0: Direct firmware load for brcm/BCM4334B0.hcd failed with error -2
  3320    [    9.108322] Bluetooth: hci0: BCM: Patch brcm/BCM4334B0.hcd not found
  3321    [    9.286109] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
  3322    [    9.287337] usbcore: registered new interface driver mt7601u
  3323    [    9.921115] zram: Added device: zram0
  3324    [    9.924739] zram: Added device: zram1
  3325    [    9.928700] zram: Added device: zram2
  3326    [    9.970535] brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x50
  3327    [    9.981194] zram1: detected capacity change from 0 to 912879616
  3328    [   10.037232] meson8b-dwmac c9410000.ethernet eth0: PHY [0.e40908ff:08] driver [Meson GXL Internal PHY]
  3329    [   10.058536] meson8b-dwmac c9410000.ethernet eth0: No Safety Features support found
  3330    [   10.063028] meson8b-dwmac c9410000.ethernet eth0: PTP not supported by HW
  3331    [   10.069766] meson8b-dwmac c9410000.ethernet eth0: configuring for phy/rmii link mode
  3332    [   10.701039] random: crng init done
  3333    [   10.703560] random: 7 urandom warning(s) missed due to ratelimiting
  3334    [   10.810732] Adding 891480k swap on /dev/zram1.  Priority:5 extents:1 across:891480k SSFS
  3335
  3336    ### armbian-release:
  3337
  3338    # PLEASE DO NOT EDIT THIS FILE
  3339    BOARD=aml-s9xxx
  3340    BOARD_NAME="AML-S9xxx"
  3341    BOARDFAMILY=aml-s9xxx
  3342    BUILD_REPOSITORY_URL=https://github.com/150balbes/Build-Armbian.git
  3343    BUILD_REPOSITORY_COMMIT=62b8c07-dirty
  3344    DISTRIBUTION_CODENAME=buster
  3345    DISTRIBUTION_STATUS=supported
  3346    VERSION=20.02.0-rc1.037
  3347    LINUXFAMILY=aml-s9xxx
  3348    BRANCH=current
  3349    ARCH=arm64
  3350    IMAGE_TYPE=nightly
  3351    BOARD_TYPE=conf
  3352    INITRD_ARCH=arm64
  3353    KERNEL_IMAGE_TYPE=Image
  3354
  3355    ### boot environment:
  3356
  3357    ODROIDN2-UBOOT-CONFIG
  3358    setenv env_addr 0x10400000
  3359    setenv kernel_addr 0x11000000
  3360    setenv initrd_addr 0x13000000
  3361    setenv dtb_addr 0x1000000
  3362    if test "${devtype}" = ""; then setenv devtype "mmc"; fi
  3363    load ${devtype} ${devnum} ${env_addr} uEnv.txt && env import -t ${env_addr} ${filesize}
  3364    setenv bootargs ${APPEND}
  3365    load ${devtype} ${devnum} ${kernel_addr} ${LINUX}
  3366    load ${devtype} ${devnum} ${initrd_addr} ${INITRD}
  3367    load ${devtype} ${devnum} ${dtb_addr} ${FDT}
  3368    fdt addr ${dtb_addr}
  3369    booti ${kernel_addr} ${initrd_addr} ${dtb_addr}
  3370
  3371    ### lsusb:
  3372
  3373    Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
  3374    Bus 001 Device 003: ID 148f:7601 Ralink Technology, Corp. MT7601U Wireless Adapter
  3375    Bus 001 Device 002: ID 05e3:0608 Genesys Logic, Inc. Hub
  3376    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  3377
  3378    ### lscpu:
  3379
  3380    Architecture:        aarch64
  3381    Byte Order:          Little Endian
  3382    CPU(s):              4
  3383    On-line CPU(s) list: 0-3
  3384    Thread(s) per core:  1
  3385    Core(s) per socket:  4
  3386    Socket(s):           1
  3387    Vendor ID:           ARM
  3388    Model:               4
  3389    Model name:          Cortex-A53
  3390    Stepping:            r0p4
  3391    CPU max MHz:         1512,0000
  3392    CPU min MHz:         100,0000
  3393    BogoMIPS:            48.00
  3394    L1d cache:           unknown size
  3395    L1i cache:           unknown size
  3396    L2 cache:            unknown size
  3397    Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  3398
  3399    ### cpuinfo:
  3400
  3401    processor    : 0
  3402    model name    : ARMv8 Processor rev 4 (v8l)
  3403    BogoMIPS    : 48.00
  3404    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  3405    CPU implementer    : 0x41
  3406    CPU architecture: 8
  3407    CPU variant    : 0x0
  3408    CPU part    : 0xd03
  3409    CPU revision    : 4
  3410
  3411    processor    : 1
  3412    model name    : ARMv8 Processor rev 4 (v8l)
  3413    BogoMIPS    : 48.00
  3414    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  3415    CPU implementer    : 0x41
  3416    CPU architecture: 8
  3417    CPU variant    : 0x0
  3418    CPU part    : 0xd03
  3419    CPU revision    : 4
  3420
  3421    processor    : 2
  3422    model name    : ARMv8 Processor rev 4 (v8l)
  3423    BogoMIPS    : 48.00
  3424    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  3425    CPU implementer    : 0x41
  3426    CPU architecture: 8
  3427    CPU variant    : 0x0
  3428    CPU part    : 0xd03
  3429    CPU revision    : 4
  3430
  3431    processor    : 3
  3432    model name    : ARMv8 Processor rev 4 (v8l)
  3433    BogoMIPS    : 48.00
  3434    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  3435    CPU implementer    : 0x41
  3436    CPU architecture: 8
  3437    CPU variant    : 0x0
  3438    CPU part    : 0xd03
  3439    CPU revision    : 4
  3440
  3441
  3442    ### meminfo:
  3443
  3444    MemTotal:        1782968 kB
  3445    MemFree:         1606100 kB
  3446    MemAvailable:    1663936 kB
  3447    Buffers:           11616 kB
  3448    Cached:            54224 kB
  3449    SwapCached:            0 kB
  3450    Active:            52488 kB
  3451    Inactive:          35056 kB
  3452    Active(anon):      22012 kB
  3453    Inactive(anon):     2616 kB
  3454    Active(file):      30476 kB
  3455    Inactive(file):    32440 kB
  3456    Unevictable:          16 kB
  3457    Mlocked:              16 kB
  3458    SwapTotal:        891480 kB
  3459    SwapFree:         891480 kB
  3460    Dirty:               672 kB
  3461    Writeback:             0 kB
  3462    AnonPages:         21924 kB
  3463    Mapped:            23660 kB
  3464    Shmem:              2728 kB
  3465    KReclaimable:      18036 kB
  3466    Slab:              53316 kB
  3467    SReclaimable:      18036 kB
  3468    SUnreclaim:        35280 kB
  3469    KernelStack:        2784 kB
  3470    PageTables:         1628 kB
  3471    NFS_Unstable:          0 kB
  3472    Bounce:                0 kB
  3473    WritebackTmp:          0 kB
  3474    CommitLimit:     1782964 kB
  3475    Committed_AS:      79772 kB
  3476    VmallocTotal:   135290159040 kB
  3477    VmallocUsed:       16776 kB
  3478    VmallocChunk:          0 kB
  3479    Percpu:             1264 kB
  3480    CmaTotal:         262144 kB
  3481    CmaFree:          258460 kB
  3482    HugePages_Total:       0
  3483    HugePages_Free:        0
  3484    HugePages_Rsvd:        0
  3485    HugePages_Surp:        0
  3486    Hugepagesize:       2048 kB
  3487    Hugetlb:               0 kB
  3488
  3489    ### virtual memory:
  3490
  3491    vm.admin_reserve_kbytes = 8192
  3492    vm.block_dump = 0
  3493    vm.compact_unevictable_allowed = 1
  3494    vm.dirty_background_bytes = 0
  3495    vm.dirty_background_ratio = 10
  3496    vm.dirty_bytes = 0
  3497    vm.dirty_expire_centisecs = 3000
  3498    vm.dirty_ratio = 20
  3499    vm.dirtytime_expire_seconds = 43200
  3500    vm.dirty_writeback_centisecs = 500
  3501    vm.extfrag_threshold = 500
  3502    vm.hugetlb_shm_group = 0
  3503    vm.laptop_mode = 0
  3504    vm.legacy_va_layout = 0
  3505    vm.lowmem_reserve_ratio = 256    256    32    0
  3506    vm.max_map_count = 65530
  3507    vm.min_free_kbytes = 4914
  3508    vm.mmap_min_addr = 4096
  3509    vm.mmap_rnd_bits = 18
  3510    vm.nr_hugepages = 0
  3511    vm.nr_overcommit_hugepages = 0
  3512    vm.oom_dump_tasks = 1
  3513    vm.oom_kill_allocating_task = 0
  3514    vm.overcommit_kbytes = 0
  3515    vm.overcommit_memory = 0
  3516    vm.overcommit_ratio = 50
  3517    vm.page-cluster = 0
  3518    vm.panic_on_oom = 0
  3519    vm.percpu_pagelist_fraction = 0
  3520    vm.stat_interval = 1
  3521    vm.swappiness = 100
  3522    vm.user_reserve_kbytes = 55239
  3523    vm.vfs_cache_pressure = 100
  3524    vm.watermark_boost_factor = 15000
  3525    vm.watermark_scale_factor = 10
  3526
  3527    ### ip addr:
  3528
  3529    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
  3530        link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  3531        inet XXX.XXX.0.1/8 scope host lo
  3532           valid_lft forever preferred_lft forever
  3533        inet6 ::1/128 scope host
  3534           valid_lft forever preferred_lft forever
  3535    2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
  3536        link/ether 00:df:06:00:00:0b brd ff:ff:ff:ff:ff:ff
  3537    3: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  3538        link/ether 00:36:76:61:0b:24 brd ff:ff:ff:ff:ff:ff
  3539
  3540    ### partitions:
  3541
  3542    major minor  #blocks  name
  3543
  3544     179        0   30924800 mmcblk0
  3545     179        1     262144 mmcblk0p1
  3546     179        2   30337024 mmcblk0p2
  3547     179       32   15384576 mmcblk1
  3548     179      128       8192 mmcblk1gp0
  3549     254        1     891484 zram1
  3550
  3551    ### df:
  3552
  3553    udev             738M      0  738M   0% /dev
  3554    tmpfs            175M   2,7M  172M   2% /run
  3555    /dev/mmcblk0p2    29G    10G   19G  36% /
  3556    tmpfs            871M      0  871M   0% /dev/shm
  3557    tmpfs            5,0M   4,0K  5,0M   1% /run/lock
  3558    tmpfs            871M      0  871M   0% /sys/fs/cgroup
  3559    tmpfs            871M      0  871M   0% /tmp
  3560    /dev/mmcblk0p1   256M    76M  180M  30% /boot
  3561
  3562    ### lsblk:
  3563
  3564    NAME         FSTYPE   SIZE MOUNTPOINT UUID
  3565    mmcblk0              29,5G
  3566    ├─mmcblk0p1  vfat     256M /boot      50FC-6AC8
  3567    └─mmcblk0p2  ext4      29G /          3e297ac1-e4e4-4ab1-bc57-47c07d0422ba
  3568    mmcblk1              14,7G
  3569    mmcblk1boot0            4M
  3570    mmcblk1boot1            4M
  3571    mmcblk1gp0              8M
  3572
  3573    ### zramctl:
  3574
  3575    NAME       ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT
  3576    /dev/zram1 lzo         870,6M   4K   81B   12K       4 [SWAP]
  3577
  3578    ### mtab:
  3579
  3580    /dev/mmcblk0p1 /boot vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro 0 0
  3581    /dev/mmcblk0p2 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  3582
  3583    ### mmc0:59b4 info:
  3584
  3585                   fwrev: 0x0
  3586                  uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SDU1  MODALIAS=mmc:block
  3587                     cid: 1b534d53445531201014a136d4013800
  3588                     rca: 0x59b4
  3589                     csd: 400e00325b590000ebef7f800a400000
  3590                  manfid: 0x00001b
  3591                     ocr: 0x00200000
  3592    preferred_erase_size: 4194304
  3593                    type: SD
  3594                   hwrev: 0x1
  3595                    date: 08/2019
  3596                     dsr: 0x404
  3597              erase_size: 512
  3598                   oemid: 0x534d
  3599                  serial: 0x14a136d4
  3600                     ssr: 0000000005000000040090000811391e00089a342f01000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  3601                     scr: 0235844300000000
  3602                    name: SDU1
  3603
  3604    ### mmc1:0001 info:
  3605
  3606                   fwrev: 0x0
  3607                  uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=016G92 MODALIAS=mmc:block
  3608                     cid: 11010030313647393201d3d1a4db1100
  3609             rel_sectors: 0x10
  3610                     rca: 0x0001
  3611            pre_eol_info: 0x00
  3612                     csd: d00e00320f5903ffffffffef92400000
  3613                  manfid: 0x000011
  3614                     ocr: 0x00200000
  3615    preferred_erase_size: 4194304
  3616    enhanced_area_offset: 18446744073709551594
  3617      raw_rpmb_size_mult: 0x4
  3618                    type: MMC
  3619                   hwrev: 0x0
  3620                    date: 01/2014
  3621                     prv: 0x1
  3622             ffu_capable: 0
  3623                     dsr: 0x404
  3624              erase_size: 4194304
  3625               life_time: 0x00 0x00
  3626      enhanced_area_size: 4294967274
  3627                   oemid: 0x0100
  3628                  serial: 0xd3d1a4db
  3629                 cmdq_en: 0
  3630                     rev: 0x6
  3631                    name: 016G92
  3632
  3633    ### Boot system health:
  3634
  3635    Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU
  3636    21:19:45: 1512MHz  0.55  51%  24%  15%   0%  10%   1% 53.0°C
  3637    21:19:45: 1512MHz  0.55  61%   8%  15%   0%  34%   1% 54.0°C
  3638    21:19:46: 1512MHz  0.55  76%  13%  16%   0%  43%   1% 53.0°C
  3639    21:19:46: 1512MHz  0.55  52%   9%  14%   1%  26%   0% 53.0°C
  3640    21:19:46:  500MHz  0.67  31%   6%   8%   1%  12%   1% 52.0°C
  3641
  3642    ### Activated 1 lzo zram swap devices with 870 MB each
  3643
  3644
  3645    mié mar 24 08:01:46 CET 2021 | AML-S9xxx | 20.02.0-rc1.037 | arm64 | aarch64 | 5.5.0-rc6-aml-s9xxx
  3646
  3647    ### dmesg:
  3648
  3649    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
  3650    [    0.000000] Linux version 5.5.0-rc6-aml-s9xxx (root@vbox) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #rc1.037 SMP PREEMPT Wed Feb 5 15:59:04 MSK 2020
  3651    [    0.000000] Machine model: Amlogic Meson GXL (S905X) P212 Development Board
  3652    [    0.000000] efi: Getting EFI parameters from FDT:
  3653    [    0.000000] efi: UEFI not found.
  3654    [    0.000000] Reserved memory: created CMA memory pool at 0x0000000063400000, size 256 MiB
  3655    [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
  3656    [    0.000000] On node 0 totalpages: 477952
  3657    [    0.000000]   DMA zone: 4032 pages used for memmap
  3658    [    0.000000]   DMA zone: 0 pages reserved
  3659    [    0.000000]   DMA zone: 248576 pages, LIFO batch:63
  3660    [    0.000000]   DMA32 zone: 3584 pages used for memmap
  3661    [    0.000000]   DMA32 zone: 229376 pages, LIFO batch:63
  3662    [    0.000000] psci: probing for conduit method from DT.
  3663    [    0.000000] psci: PSCIv0.2 detected in firmware.
  3664    [    0.000000] psci: Using standard PSCI v0.2 function IDs
  3665    [    0.000000] psci: Trusted OS migration not required
  3666    [    0.000000] percpu: Embedded 22 pages/cpu s50392 r8192 d31528 u90112
  3667    [    0.000000] pcpu-alloc: s50392 r8192 d31528 u90112 alloc=22*4096
  3668    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
  3669    [    0.000000] Detected VIPT I-cache on CPU0
  3670    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 470336
  3671    [    0.000000] Kernel command line: root=LABEL=ROOTFS rootflags=data=writeback rw console=ttyAML0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 mac=00:df:06:00:00:0b
  3672    [    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
  3673    [    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
  3674    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
  3675    [    0.000000] software IO TLB: mapped [mem 0x3bfff000-0x3ffff000] (64MB)
  3676    [    0.000000] Memory: 1509616K/1911808K available (14460K kernel code, 1434K rwdata, 5884K rodata, 960K init, 927K bss, 140048K reserved, 262144K cma-reserved)
  3677    [    0.000000] random: get_random_u64 called from cache_random_seq_create+0x7c/0x150 with crng_init=0
  3678    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
  3679    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
  3680    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
  3681    [    0.000000]     Tasks RCU enabled.
  3682    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
  3683    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
  3684    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
  3685    [    0.000000] GIC: Using split EOI/Deactivate mode
  3686    [    0.000000] irq_meson_gpio: 110 to 8 gpio interrupt mux initialized
  3687    [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
  3688    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
  3689    [    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
  3690    [    0.000355] Console: colour dummy device 80x25
  3691    [    0.000655] printk: console [tty0] enabled
  3692    [    0.000697] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
  3693    [    0.000718] pid_max: default: 32768 minimum: 301
  3694    [    0.000841] LSM: Security Framework initializing
  3695    [    0.000891] SELinux:  Initializing.
  3696    [    0.000970] *** VALIDATE SELinux ***
  3697    [    0.001034] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
  3698    [    0.001064] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
  3699    [    0.001128] *** VALIDATE tmpfs ***
  3700    [    0.001531] *** VALIDATE proc ***
  3701    [    0.001754] *** VALIDATE cgroup1 ***
  3702    [    0.001770] *** VALIDATE cgroup2 ***
  3703    [    0.024017] ASID allocator initialised with 32768 entries
  3704    [    0.032002] rcu: Hierarchical SRCU implementation.
  3705    [    0.042102] EFI services will not be available.
  3706    [    0.048058] smp: Bringing up secondary CPUs ...
  3707    [    0.080287] Detected VIPT I-cache on CPU1
  3708    [    0.080340] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
  3709    [    0.112326] Detected VIPT I-cache on CPU2
  3710    [    0.112373] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
  3711    [    0.144370] Detected VIPT I-cache on CPU3
  3712    [    0.144411] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
  3713    [    0.144485] smp: Brought up 1 node, 4 CPUs
  3714    [    0.144552] SMP: Total of 4 processors activated.
  3715    [    0.144564] CPU features: detected: 32-bit EL0 Support
  3716    [    0.144576] CPU features: detected: CRC32 instructions
  3717    [    0.144879] CPU: All CPU(s) started at EL2
  3718    [    0.144901] alternatives: patching kernel code
  3719    [    0.146000] devtmpfs: initialized
  3720    [    0.151134] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
  3721    [    0.151175] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
  3722    [    0.157994] xor: measuring software checksum speed
  3723    [    0.196365]    8regs     :  2375.000 MB/sec
  3724    [    0.236396]    32regs    :  2724.000 MB/sec
  3725    [    0.276434]    arm64_neon:  2406.000 MB/sec
  3726    [    0.276444] xor: using function: 32regs (2724.000 MB/sec)
  3727    [    0.276499] pinctrl core: initialized pinctrl subsystem
  3728    [    0.277168] thermal_sys: Registered thermal governor 'step_wise'
  3729    [    0.277339] DMI not present or invalid.
  3730    [    0.277699] NET: Registered protocol family 16
  3731    [    0.281233] DMA: preallocated 256 KiB pool for atomic allocations
  3732    [    0.281281] audit: initializing netlink subsys (disabled)
  3733    [    0.281468] audit: type=2000 audit(0.280:1): state=initialized audit_enabled=0 res=1
  3734    [    0.282515] cpuidle: using governor ladder
  3735    [    0.282555] cpuidle: using governor menu
  3736    [    0.282888] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
  3737    [    0.283581] Serial: AMBA PL011 UART driver
  3738    [    0.297615] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
  3739    [    0.297644] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
  3740    [    0.297657] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
  3741    [    0.297669] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
  3742    [    0.301361] cryptd: max_cpu_qlen set to 1000
  3743    [    0.376709] raid6: neonx8   gen()  1623 MB/s
  3744    [    0.444778] raid6: neonx8   xor()  1490 MB/s
  3745    [    0.512860] raid6: neonx4   gen()  1564 MB/s
  3746    [    0.580921] raid6: neonx4   xor()  1470 MB/s
  3747    [    0.648998] raid6: neonx2   gen()  1199 MB/s
  3748    [    0.717076] raid6: neonx2   xor()  1216 MB/s
  3749    [    0.785202] raid6: neonx1   gen()   787 MB/s
  3750    [    0.853268] raid6: neonx1   xor()   915 MB/s
  3751    [    0.921327] raid6: int64x8  gen()  1195 MB/s
  3752    [    0.989332] raid6: int64x8  xor()   769 MB/s
  3753    [    1.057385] raid6: int64x4  gen()  1029 MB/s
  3754    [    1.125444] raid6: int64x4  xor()   752 MB/s
  3755    [    1.193556] raid6: int64x2  gen()   729 MB/s
  3756    [    1.261544] raid6: int64x2  xor()   615 MB/s
  3757    [    1.329690] raid6: int64x1  gen()   486 MB/s
  3758    [    1.397647] raid6: int64x1  xor()   468 MB/s
  3759    [    1.397658] raid6: using algorithm neonx8 gen() 1623 MB/s
  3760    [    1.397668] raid6: .... xor() 1490 MB/s, rmw enabled
  3761    [    1.397678] raid6: using neon recovery algorithm
  3762    [    1.397963] ACPI: Interpreter disabled.
  3763    [    1.399153] iommu: Default domain type: Translated
  3764    [    1.399435] vgaarb: loaded
  3765    [    1.400028] SCSI subsystem initialized
  3766    [    1.400214] libata version 3.00 loaded.
  3767    [    1.400425] usbcore: registered new interface driver usbfs
  3768    [    1.400473] usbcore: registered new interface driver hub
  3769    [    1.400539] usbcore: registered new device driver usb
  3770    [    1.400937] pps_core: LinuxPPS API ver. 1 registered
  3771    [    1.400949] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
  3772    [    1.400973] PTP clock support registered
  3773    [    1.401003] EDAC MC: Ver: 3.0.0
  3774    [    1.401599] FPGA manager framework
  3775    [    1.401710] Advanced Linux Sound Architecture Driver Initialized.
  3776    [    1.402173] NetLabel: Initializing
  3777    [    1.402185] NetLabel:  domain hash size = 128
  3778    [    1.402194] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
  3779    [    1.402254] NetLabel:  unlabeled traffic allowed by default
  3780    [    1.402764] clocksource: Switched to clocksource arch_sys_counter
  3781    [    1.402791] *** VALIDATE bpf ***
  3782    [    1.403040] VFS: Disk quotas dquot_6.6.0
  3783    [    1.403103] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
  3784    [    1.403225] FS-Cache: Loaded
  3785    [    1.403235] *** VALIDATE ramfs ***
  3786    [    1.403256] *** VALIDATE hugetlbfs ***
  3787    [    1.403646] pnp: PnP ACPI: disabled
  3788    [    1.408761] NET: Registered protocol family 2
  3789    [    1.409264] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
  3790    [    1.409312] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
  3791    [    1.409431] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
  3792    [    1.409647] TCP: Hash tables configured (established 16384 bind 16384)
  3793    [    1.409800] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
  3794    [    1.409852] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
  3795    [    1.410064] NET: Registered protocol family 1
  3796    [    1.410539] RPC: Registered named UNIX socket transport module.
  3797    [    1.410559] RPC: Registered udp transport module.
  3798    [    1.410569] RPC: Registered tcp transport module.
  3799    [    1.410578] RPC: Registered tcp NFSv4.1 backchannel transport module.
  3800    [    1.410594] NET: Registered protocol family 44
  3801    [    1.410613] PCI: CLS 0 bytes, default 64
  3802    [    1.410872] Trying to unpack rootfs image as initramfs...
  3803    [    1.872487] Freeing initrd memory: 10248K
  3804    [    1.873283] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
  3805    [    2.087101] Initialise system trusted keyrings
  3806    [    2.087337] workingset: timestamp_bits=46 max_order=19 bucket_order=0
  3807    [    2.092516] zbud: loaded
  3808    [    2.093742] squashfs: version 4.0 (2009/01/31) Phillip Lougher
  3809    [    2.094022] FS-Cache: Netfs 'nfs' registered for caching
  3810    [    2.094544] NFS: Registering the id_resolver key type
  3811    [    2.094581] Key type id_resolver registered
  3812    [    2.094591] Key type id_legacy registered
  3813    [    2.094607] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
  3814    [    2.094619] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
  3815    [    2.095805] FS-Cache: Netfs 'cifs' registered for caching
  3816    [    2.096136] Key type cifs.spnego registered
  3817    [    2.096156] Key type cifs.idmap registered
  3818    [    2.096178] ntfs: driver 2.1.32 [Flags: R/W].
  3819    [    2.096791] JFS: nTxBlock = 8192, nTxLock = 65536
  3820    [    2.102738] SGI XFS with ACLs, security attributes, realtime, quota, no debug enabled
  3821    [    2.104167] *** VALIDATE xfs ***
  3822    [    2.104480] ocfs2: Registered cluster interface o2cb
  3823    [    2.104696] OCFS2 User DLM kernel interface loaded
  3824    [    2.106116] *** VALIDATE gfs2 ***
  3825    [    2.106391] gfs2: GFS2 installed
  3826    [    2.107424] aufs 5.5-20200203
  3827    [    2.128183] Key type asymmetric registered
  3828    [    2.128210] Asymmetric key parser 'x509' registered
  3829    [    2.128220] Asymmetric key parser 'pkcs8' registered
  3830    [    2.128289] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
  3831    [    2.128467] io scheduler mq-deadline registered
  3832    [    2.128483] io scheduler kyber registered
  3833    [    2.128682] io scheduler bfq registered
  3834    [    2.141268] soc soc0: Amlogic Meson GXL (S905X) Revision 21:b (82:2) Detected
  3835    [    2.144819] Serial: 8250/16550 driver, 5 ports, IRQ sharing enabled
  3836    [    2.146498] Serial: AMBA driver
  3837    [    2.146931] c11084c0.serial: ttyAML6 at MMIO 0xc11084c0 (irq = 10, base_baud = 1500000) is a meson_uart
  3838    [    2.147103] serial serial0: tty port ttyAML6 registered
  3839    [    2.147339] c81004c0.serial: ttyAML0 at MMIO 0xc81004c0 (irq = 13, base_baud = 1500000) is a meson_uart
  3840    [    3.122811] printk: console [ttyAML0] enabled
  3841    [    3.138835] brd: module loaded
  3842    [    3.147354] loop: module loaded
  3843    [    3.149722] libphy: Fixed MDIO Bus: probed
  3844    [    3.150378] meson8b-dwmac c9410000.ethernet: IRQ eth_wake_irq not found
  3845    [    3.155554] meson8b-dwmac c9410000.ethernet: IRQ eth_lpi not found
  3846    [    3.161739] meson8b-dwmac c9410000.ethernet: PTP uses main clock
  3847    [    3.167586] meson8b-dwmac c9410000.ethernet: no reset control found
  3848    [    3.174260] meson8b-dwmac c9410000.ethernet: User ID: 0x11, Synopsys ID: 0x37
  3849    [    3.180872] meson8b-dwmac c9410000.ethernet:     DWMAC1000
  3850    [    3.186038] meson8b-dwmac c9410000.ethernet: DMA HW capability register supported
  3851    [    3.193453] meson8b-dwmac c9410000.ethernet: RX Checksum Offload Engine supported
  3852    [    3.200870] meson8b-dwmac c9410000.ethernet: COE Type 2
  3853    [    3.206045] meson8b-dwmac c9410000.ethernet: TX Checksum insertion supported
  3854    [    3.213031] meson8b-dwmac c9410000.ethernet: Wake-Up On Lan supported
  3855    [    3.219446] meson8b-dwmac c9410000.ethernet: Normal descriptors
  3856    [    3.225280] meson8b-dwmac c9410000.ethernet: Ring mode enabled
  3857    [    3.231058] meson8b-dwmac c9410000.ethernet: Enable RX Mitigation via HW Watchdog Timer
  3858    [    3.239174] libphy: stmmac: probed
  3859    [    3.243681] VFIO - User Level meta-driver version: 0.3
  3860    [    3.248997] dwc3 c9000000.dwc3: Failed to get clk 'ref': -2
  3861    [    3.253832] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
  3862    [    3.259463] ehci-pci: EHCI PCI platform driver
  3863    [    3.263921] ehci-platform: EHCI generic platform driver
  3864    [    3.269208] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
  3865    [    3.275147] ohci-pci: OHCI PCI platform driver
  3866    [    3.279575] ohci-platform: OHCI generic platform driver
  3867    [    3.285324] usbcore: registered new interface driver usb-storage
  3868    [    3.290908] mousedev: PS/2 mouse device common for all mice
  3869    [    3.296837] i2c /dev entries driver
  3870    [    3.302494] sdhci: Secure Digital Host Controller Interface driver
  3871    [    3.305766] sdhci: Copyright(c) Pierre Ossman
  3872    [    3.310080] Synopsys Designware Multimedia Card Interface Driver
  3873    [    3.317365] meson-gx-mmc d0072000.mmc: Got CD GPIO
  3874    [    3.347902] meson-gx-mmc d0074000.mmc: allocated mmc-pwrseq
  3875    [    3.379258] sdhci-pltfm: SDHCI platform and OF driver helper
  3876    [    3.380195] ledtrig-cpu: registered to indicate activity on CPUs
  3877    [    3.386163] meson-sm: secure-monitor enabled
  3878    [    3.390227] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
  3879    [    3.397534] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
  3880    [    3.405380] mmc0: new high speed SDHC card at address 59b4
  3881    [    3.415490] mmcblk0: mmc0:59b4 SDU1  29.5 GiB
  3882    [    3.418164]  mmcblk0: p1 p2
  3883    [    3.424070] hid: raw HID events driver (C) Jiri Kosina
  3884    [    3.424303] usbcore: registered new interface driver usbhid
  3885    [    3.429122] usbhid: USB HID core driver
  3886    [    3.433276] platform-mhu c883c404.mailbox: Platform MHU Mailbox registered
  3887    [    3.449845] NET: Registered protocol family 17
  3888    [    3.450134] Key type dns_resolver registered
  3889    [    3.453440] registered taskstats version 1
  3890    [    3.456979] Loading compiled-in X.509 certificates
  3891    [    3.461845] zswap: loaded using pool lzo/zbud
  3892    [    3.466219] Key type ._fscrypt registered
  3893    [    3.469989] Key type .fscrypt registered
  3894    [    3.474963] Btrfs loaded, crc32c=crc32c-generic
  3895    [    3.489771] mmc1: new HS200 MMC card at address 0001
  3896    [    3.490699] mmcblk1: mmc1:0001 016G92 14.7 GiB
  3897    [    3.494114] mmcblk1boot0: mmc1:0001 016G92 partition 1 4.00 MiB
  3898    [    3.499947] mmcblk1boot1: mmc1:0001 016G92 partition 2 4.00 MiB
  3899    [    3.504253] Key type encrypted registered
  3900    [    3.505814] mmcblk1gp0: mmc1:0001 016G92 partition 4 8.00 MiB
  3901    [    3.515269] mmcblk1rpmb: mmc1:0001 016G92 partition 3 512 KiB, chardev (243:0)
  3902    [    3.529028] meson-drm d0100000.vpu: Queued 3 outputs on vpu
  3903    [    3.529479] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
  3904    [    3.535570] [drm] No driver support for vblank timestamp query.
  3905    [    3.566821] meson-dw-hdmi c883a000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
  3906    [    3.571474] meson-dw-hdmi c883a000.hdmi-tx: registered DesignWare HDMI I2C bus driver
  3907    [    3.579490] meson-drm d0100000.vpu: bound c883a000.hdmi-tx (ops meson_dw_hdmi_ops)
  3908    [    3.586839] [drm] Initialized meson 1.0.0 20161109 for d0100000.vpu on minor 0
  3909    [    3.632176] Console: switching to colour frame buffer device 90x36
  3910    [    3.652390] meson-drm d0100000.vpu: fb0: mesondrmfb frame buffer device
  3911    [    3.659669] libphy: mdio_mux: probed
  3912    [    3.670160] libphy: mdio_mux: probed
  3913    [    3.670655] phy phy-d0078080.phy.2: unsupported PHY mode 5
  3914    [    3.675737] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  3915    [    3.679104] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
  3916    [    3.686808] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228f664 hci version 0x100 quirks 0x0000000002010010
  3917    [    3.696018] xhci-hcd xhci-hcd.0.auto: irq 39, io mem 0xc9000000
  3918    [    3.702129] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.05
  3919    [    3.710361] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  3920    [    3.717511] usb usb1: Product: xHCI Host Controller
  3921    [    3.722338] usb usb1: Manufacturer: Linux 5.5.0-rc6-aml-s9xxx xhci-hcd
  3922    [    3.728807] usb usb1: SerialNumber: xhci-hcd.0.auto
  3923    [    3.734135] hub 1-0:1.0: USB hub found
  3924    [    3.737394] hub 1-0:1.0: 2 ports detected
  3925    [    3.741605] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  3926    [    3.746771] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
  3927    [    3.754351] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
  3928    [    3.760866] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
  3929    [    3.769115] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.05
  3930    [    3.777492] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  3931    [    3.784648] usb usb2: Product: xHCI Host Controller
  3932    [    3.789475] usb usb2: Manufacturer: Linux 5.5.0-rc6-aml-s9xxx xhci-hcd
  3933    [    3.795945] usb usb2: SerialNumber: xhci-hcd.0.auto
  3934    [    3.801257] hub 2-0:1.0: USB hub found
  3935    [    3.804513] hub 2-0:1.0: config failed, hub doesn't have any ports! (err -19)
  3936    [    3.813379] meson-gx-mmc d0070000.mmc: allocated mmc-pwrseq
  3937    [    3.843766] scpi_protocol scpi: SCP Protocol legacy pre-1.0 firmware
  3938    [    3.860346] gx-sound-card sound: snd-soc-dummy-dai <-> c1105400.bus:audio-controller-0 mapping ok
  3939    [    3.871872] gx-sound-card sound: i2s-hifi <-> c1105400.bus:audio-controller-2 mapping ok
  3940    [    3.879545] gx-sound-card sound: ASoC: no DMI vendor name!
  3941    [    3.885716] printk: console [netcon0] enabled
  3942    [    3.889181] netconsole: network logging started
  3943    [    3.893749] hctosys: unable to open rtc device (rtc0)
  3944    [    3.899168] ALSA device list:
  3945    [    3.901666]   #0: AMLGX
  3946    [    3.904671] Freeing unused kernel memory: 960K
  3947    [    3.908544] Run /init as init process
  3948    [    3.920532] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
  3949    [    3.928985] mmc2: queuing unknown CIS tuple 0x80 (6 bytes)
  3950    [    3.935916] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
  3951    [    3.947155] mmc2: queuing unknown CIS tuple 0x80 (19 bytes)
  3952    [    3.973021] random: fast init done
  3953    [    4.036133] mmc2: new high speed SDIO card at address 0001
  3954    [    4.078829] usb 1-1: new high-speed USB device number 2 using xhci-hcd
  3955    [    4.100075] usb 1-1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.36
  3956    [    4.106975] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
  3957    [    4.114457] usb 1-1: Product: USB2.0 Hub
  3958    [    4.177348] hub 1-1:1.0: USB hub found
  3959    [    4.179988] hub 1-1:1.0: 4 ports detected
  3960    [    4.310853] usb 1-2: new high-speed USB device number 3 using xhci-hcd
  3961    [    4.341408] usb 1-2: New USB device found, idVendor=148f, idProduct=7601, bcdDevice= 0.00
  3962    [    4.348554] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
  3963    [    4.357117] usb 1-2: Product: 802.11 n WLAN
  3964    [    4.360635] usb 1-2: Manufacturer: MediaTek
  3965    [    4.363813] usb 1-2: SerialNumber: 1.0
  3966    [    5.060678] EXT4-fs (mmcblk0p2): mounted filesystem with writeback data mode. Opts: data=writeback
  3967    [    6.009519] systemd[1]: System time before build time, advancing clock.
  3968    [    6.155845] NET: Registered protocol family 10
  3969    [    6.237468] Segment Routing with IPv6
  3970    [    6.287593] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
  3971    [    6.317767] systemd[1]: Detected architecture arm64.
  3972    [    6.369656] systemd[1]: Set hostname to <mxqpro>.
  3973    [    6.402019] systemd[1]: Couldn't move remaining userspace processes, ignoring: Input/output error
  3974    [    7.079227] random: systemd: uninitialized urandom read (16 bytes read)
  3975    [    7.091773] random: systemd: uninitialized urandom read (16 bytes read)
  3976    [    7.098133] systemd[1]: Created slice User and Session Slice.
  3977    [    7.104512] random: systemd: uninitialized urandom read (16 bytes read)
  3978    [    7.108123] systemd[1]: Reached target System Time Synchronized.
  3979    [    7.119630] systemd[1]: Created slice system-serial\x2dgetty.slice.
  3980    [    7.125760] systemd[1]: Condition check resulted in Arbitrary Executable File Formats File System Automount Point being skipped.
  3981    [    7.137238] systemd[1]: Listening on udev Kernel Socket.
  3982    [    7.145531] systemd[1]: Listening on Journal Socket.
  3983    [    7.312959] EXT4-fs (mmcblk0p2): re-mounted. Opts: commit=600,errors=remount-ro
  3984    [    7.588585] systemd-journald[419]: Received request to flush runtime journal from PID 1
  3985    [    8.119491] mc: Linux media interface: v0.10
  3986    [    8.146808] Registered IR keymap rc-empty
  3987    [    8.150257] rc rc0: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0
  3988    [    8.159027] input: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0/input0
  3989    [    8.159385] videodev: Linux video capture interface: v2.00
  3990    [    8.166155] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
  3991    [    8.180718] meson-ir c8100580.ir: receiver initialized
  3992    [    8.281207] lima d00c0000.gpu: IRQ ppmmu3 not found
  3993    [    8.295039] lima d00c0000.gpu: IRQ ppmmu4 not found
  3994    [    8.297230] lima d00c0000.gpu: IRQ ppmmu5 not found
  3995    [    8.305523] lima d00c0000.gpu: IRQ ppmmu6 not found
  3996    [    8.309379] lima d00c0000.gpu: IRQ ppmmu7 not found
  3997    [    8.311785] lima d00c0000.gpu: gp - mali450 version major 0 minor 0
  3998    [    8.318274] lima d00c0000.gpu: pp0 - mali450 version major 0 minor 0
  3999    [    8.324514] lima d00c0000.gpu: pp1 - mali450 version major 0 minor 0
  4000    [    8.330821] lima d00c0000.gpu: pp2 - mali450 version major 0 minor 0
  4001    [    8.337079] lima d00c0000.gpu: IRQ pp3 not found
  4002    [    8.341548] lima d00c0000.gpu: IRQ pp4 not found
  4003    [    8.346159] lima d00c0000.gpu: IRQ pp5 not found
  4004    [    8.350732] lima d00c0000.gpu: IRQ pp6 not found
  4005    [    8.355163] lima d00c0000.gpu: IRQ pp7 not found
  4006    [    8.359745] lima d00c0000.gpu: l2 cache 8K, 4-way, 64byte cache line, 128bit external bus
  4007    [    8.367982] lima d00c0000.gpu: l2 cache 64K, 4-way, 64byte cache line, 128bit external bus
  4008    [    8.376648] lima d00c0000.gpu: bus rate = 166666667
  4009    [    8.381060] lima d00c0000.gpu: mod rate = 744000000
  4010    [    8.386261] [drm] Initialized lima 1.0.0 20190217 for d00c0000.gpu on minor 1
  4011    [    8.429850] Bluetooth: Core ver 2.22
  4012    [    8.431929] NET: Registered protocol family 31
  4013    [    8.434004] Bluetooth: HCI device and connection manager initialized
  4014    [    8.440509] Bluetooth: HCI socket layer initialized
  4015    [    8.445254] Bluetooth: L2CAP socket layer initialized
  4016    [    8.450381] Bluetooth: SCO socket layer initialized
  4017    [    8.539528] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
  4018    [    8.580125] cfg80211: Loading compiled-in X.509 certificates for regulatory database
  4019    [    8.620889] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
  4020    [    8.629699] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
  4021    [    8.636595] cfg80211: failed to load regulatory.db
  4022    [    8.668217] Bluetooth: HCI UART driver ver 2.3
  4023    [    8.672254] Bluetooth: HCI UART protocol H4 registered
  4024    [    8.674344] Bluetooth: HCI UART protocol BCSP registered
  4025    [    8.687230] Bluetooth: HCI UART protocol LL registered
  4026    [    8.689350] Bluetooth: HCI UART protocol ATH3K registered
  4027    [    8.716365] Bluetooth: HCI UART protocol Three-wire (H5) registered
  4028    [    8.729446] Bluetooth: HCI UART protocol Intel registered
  4029    [    8.732136] Bluetooth: HCI UART protocol Broadcom registered
  4030    [    8.732261] hci_uart_bcm serial0-0: serial0-0 supply vbat not found, using dummy regulator
  4031    [    8.745690] Bluetooth: HCI UART protocol QCA registered
  4032    [    8.748247] hci_uart_bcm serial0-0: serial0-0 supply vddio not found, using dummy regulator
  4033    [    8.761994] Bluetooth: HCI UART protocol AG6XX registered
  4034    [    8.765651] brcmfmac: F1 signature read @0x18000000=0x16034334
  4035    [    8.772888] Bluetooth: HCI UART protocol Marvell registered
  4036    [    8.773290] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4334-sdio for chip BCM4334/3
  4037    [    8.783828] usbcore: registered new interface driver brcmfmac
  4038    [    8.826705] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.amlogic,p212.txt failed with error -2
  4039    [    8.839833] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.txt failed with error -2
  4040    [    8.887159] usb 1-2: reset high-speed USB device number 3 using xhci-hcd
  4041    [    8.910409] mt7601u 1-2:1.0: ASIC revision: 76010001 MAC revision: 76010500
  4042    [    8.944847] mt7601u 1-2:1.0: EEPROM ver:0d fae:00
  4043    [    9.148163] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
  4044    [    9.149051] usbcore: registered new interface driver mt7601u
  4045    [    9.151922] Bluetooth: hci0: BCM: chip id 68
  4046    [    9.156726] Bluetooth: hci0: BCM: features 0x0f
  4047    [    9.162455] Bluetooth: hci0: BCM4334B0
  4048    [    9.166033] Bluetooth: hci0: BCM4334B0 (002.001.013) build 0000
  4049    [    9.170302] bluetooth hci0: Direct firmware load for brcm/BCM4334B0.hcd failed with error -2
  4050    [    9.178556] Bluetooth: hci0: BCM: Patch brcm/BCM4334B0.hcd not found
  4051    [    9.858954] brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x50
  4052    [    9.971908] zram: Added device: zram0
  4053    [    9.977684] zram: Added device: zram1
  4054    [    9.981120] zram: Added device: zram2
  4055    [   10.006027] meson8b-dwmac c9410000.ethernet eth0: PHY [0.e40908ff:08] driver [Meson GXL Internal PHY]
  4056    [   10.036616] zram1: detected capacity change from 0 to 912879616
  4057    [   10.050917] meson8b-dwmac c9410000.ethernet eth0: No Safety Features support found
  4058    [   10.055400] meson8b-dwmac c9410000.ethernet eth0: PTP not supported by HW
  4059    [   10.062116] meson8b-dwmac c9410000.ethernet eth0: configuring for phy/rmii link mode
  4060    [   10.672031] random: crng init done
  4061    [   10.674521] random: 7 urandom warning(s) missed due to ratelimiting
  4062    [   10.723040] Adding 891480k swap on /dev/zram1.  Priority:5 extents:1 across:891480k SSFS
  4063
  4064    ### armbian-release:
  4065
  4066    # PLEASE DO NOT EDIT THIS FILE
  4067    BOARD=aml-s9xxx
  4068    BOARD_NAME="AML-S9xxx"
  4069    BOARDFAMILY=aml-s9xxx
  4070    BUILD_REPOSITORY_URL=https://github.com/150balbes/Build-Armbian.git
  4071    BUILD_REPOSITORY_COMMIT=62b8c07-dirty
  4072    DISTRIBUTION_CODENAME=buster
  4073    DISTRIBUTION_STATUS=supported
  4074    VERSION=20.02.0-rc1.037
  4075    LINUXFAMILY=aml-s9xxx
  4076    BRANCH=current
  4077    ARCH=arm64
  4078    IMAGE_TYPE=nightly
  4079    BOARD_TYPE=conf
  4080    INITRD_ARCH=arm64
  4081    KERNEL_IMAGE_TYPE=Image
  4082
  4083    ### boot environment:
  4084
  4085    ODROIDN2-UBOOT-CONFIG
  4086    setenv env_addr 0x10400000
  4087    setenv kernel_addr 0x11000000
  4088    setenv initrd_addr 0x13000000
  4089    setenv dtb_addr 0x1000000
  4090    if test "${devtype}" = ""; then setenv devtype "mmc"; fi
  4091    load ${devtype} ${devnum} ${env_addr} uEnv.txt && env import -t ${env_addr} ${filesize}
  4092    setenv bootargs ${APPEND}
  4093    load ${devtype} ${devnum} ${kernel_addr} ${LINUX}
  4094    load ${devtype} ${devnum} ${initrd_addr} ${INITRD}
  4095    load ${devtype} ${devnum} ${dtb_addr} ${FDT}
  4096    fdt addr ${dtb_addr}
  4097    booti ${kernel_addr} ${initrd_addr} ${dtb_addr}
  4098
  4099    ### lsusb:
  4100
  4101    Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
  4102    Bus 001 Device 003: ID 148f:7601 Ralink Technology, Corp. MT7601U Wireless Adapter
  4103    Bus 001 Device 002: ID 05e3:0608 Genesys Logic, Inc. Hub
  4104    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  4105
  4106    ### lscpu:
  4107
  4108    Architecture:        aarch64
  4109    Byte Order:          Little Endian
  4110    CPU(s):              4
  4111    On-line CPU(s) list: 0-3
  4112    Thread(s) per core:  1
  4113    Core(s) per socket:  4
  4114    Socket(s):           1
  4115    Vendor ID:           ARM
  4116    Model:               4
  4117    Model name:          Cortex-A53
  4118    Stepping:            r0p4
  4119    CPU max MHz:         1512,0000
  4120    CPU min MHz:         100,0000
  4121    BogoMIPS:            48.00
  4122    L1d cache:           unknown size
  4123    L1i cache:           unknown size
  4124    L2 cache:            unknown size
  4125    Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  4126
  4127    ### cpuinfo:
  4128
  4129    processor    : 0
  4130    model name    : ARMv8 Processor rev 4 (v8l)
  4131    BogoMIPS    : 48.00
  4132    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  4133    CPU implementer    : 0x41
  4134    CPU architecture: 8
  4135    CPU variant    : 0x0
  4136    CPU part    : 0xd03
  4137    CPU revision    : 4
  4138
  4139    processor    : 1
  4140    model name    : ARMv8 Processor rev 4 (v8l)
  4141    BogoMIPS    : 48.00
  4142    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  4143    CPU implementer    : 0x41
  4144    CPU architecture: 8
  4145    CPU variant    : 0x0
  4146    CPU part    : 0xd03
  4147    CPU revision    : 4
  4148
  4149    processor    : 2
  4150    model name    : ARMv8 Processor rev 4 (v8l)
  4151    BogoMIPS    : 48.00
  4152    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  4153    CPU implementer    : 0x41
  4154    CPU architecture: 8
  4155    CPU variant    : 0x0
  4156    CPU part    : 0xd03
  4157    CPU revision    : 4
  4158
  4159    processor    : 3
  4160    model name    : ARMv8 Processor rev 4 (v8l)
  4161    BogoMIPS    : 48.00
  4162    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  4163    CPU implementer    : 0x41
  4164    CPU architecture: 8
  4165    CPU variant    : 0x0
  4166    CPU part    : 0xd03
  4167    CPU revision    : 4
  4168
  4169
  4170    ### meminfo:
  4171
  4172    MemTotal:        1782968 kB
  4173    MemFree:         1609204 kB
  4174    MemAvailable:    1666596 kB
  4175    Buffers:           11472 kB
  4176    Cached:            54512 kB
  4177    SwapCached:            0 kB
  4178    Active:            51108 kB
  4179    Inactive:          35432 kB
  4180    Active(anon):      21068 kB
  4181    Inactive(anon):     2592 kB
  4182    Active(file):      30040 kB
  4183    Inactive(file):    32840 kB
  4184    Unevictable:           0 kB
  4185    Mlocked:               0 kB
  4186    SwapTotal:        891480 kB
  4187    SwapFree:         891480 kB
  4188    Dirty:               500 kB
  4189    Writeback:             4 kB
  4190    AnonPages:         20960 kB
  4191    Mapped:            22916 kB
  4192    Shmem:              2696 kB
  4193    KReclaimable:      17628 kB
  4194    Slab:              52720 kB
  4195    SReclaimable:      17628 kB
  4196    SUnreclaim:        35092 kB
  4197    KernelStack:        2748 kB
  4198    PageTables:         1632 kB
  4199    NFS_Unstable:          0 kB
  4200    Bounce:                0 kB
  4201    WritebackTmp:          0 kB
  4202    CommitLimit:     1782964 kB
  4203    Committed_AS:      77316 kB
  4204    VmallocTotal:   135290159040 kB
  4205    VmallocUsed:       16708 kB
  4206    VmallocChunk:          0 kB
  4207    Percpu:             1264 kB
  4208    CmaTotal:         262144 kB
  4209    CmaFree:          258460 kB
  4210    HugePages_Total:       0
  4211    HugePages_Free:        0
  4212    HugePages_Rsvd:        0
  4213    HugePages_Surp:        0
  4214    Hugepagesize:       2048 kB
  4215    Hugetlb:               0 kB
  4216
  4217    ### virtual memory:
  4218
  4219    vm.admin_reserve_kbytes = 8192
  4220    vm.block_dump = 0
  4221    vm.compact_unevictable_allowed = 1
  4222    vm.dirty_background_bytes = 0
  4223    vm.dirty_background_ratio = 10
  4224    vm.dirty_bytes = 0
  4225    vm.dirty_expire_centisecs = 3000
  4226    vm.dirty_ratio = 20
  4227    vm.dirtytime_expire_seconds = 43200
  4228    vm.dirty_writeback_centisecs = 500
  4229    vm.extfrag_threshold = 500
  4230    vm.hugetlb_shm_group = 0
  4231    vm.laptop_mode = 0
  4232    vm.legacy_va_layout = 0
  4233    vm.lowmem_reserve_ratio = 256    256    32    0
  4234    vm.max_map_count = 65530
  4235    vm.min_free_kbytes = 4914
  4236    vm.mmap_min_addr = 4096
  4237    vm.mmap_rnd_bits = 18
  4238    vm.nr_hugepages = 0
  4239    vm.nr_overcommit_hugepages = 0
  4240    vm.oom_dump_tasks = 1
  4241    vm.oom_kill_allocating_task = 0
  4242    vm.overcommit_kbytes = 0
  4243    vm.overcommit_memory = 0
  4244    vm.overcommit_ratio = 50
  4245    vm.page-cluster = 0
  4246    vm.panic_on_oom = 0
  4247    vm.percpu_pagelist_fraction = 0
  4248    vm.stat_interval = 1
  4249    vm.swappiness = 100
  4250    vm.user_reserve_kbytes = 55254
  4251    vm.vfs_cache_pressure = 100
  4252    vm.watermark_boost_factor = 15000
  4253    vm.watermark_scale_factor = 10
  4254
  4255    ### ip addr:
  4256
  4257    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
  4258        link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  4259        inet XXX.XXX.0.1/8 scope host lo
  4260           valid_lft forever preferred_lft forever
  4261        inet6 ::1/128 scope host
  4262           valid_lft forever preferred_lft forever
  4263    2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
  4264        link/ether 00:df:06:00:00:0b brd ff:ff:ff:ff:ff:ff
  4265    3: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  4266        link/ether 00:36:76:61:0b:24 brd ff:ff:ff:ff:ff:ff
  4267
  4268    ### partitions:
  4269
  4270    major minor  #blocks  name
  4271
  4272     179        0   30924800 mmcblk0
  4273     179        1     262144 mmcblk0p1
  4274     179        2   30337024 mmcblk0p2
  4275     179       32   15384576 mmcblk1
  4276     179      128       8192 mmcblk1gp0
  4277     254        1     891484 zram1
  4278
  4279    ### df:
  4280
  4281    udev             738M      0  738M   0% /dev
  4282    tmpfs            175M   2,7M  172M   2% /run
  4283    /dev/mmcblk0p2    29G    10G   19G  36% /
  4284    tmpfs            871M      0  871M   0% /dev/shm
  4285    tmpfs            5,0M   4,0K  5,0M   1% /run/lock
  4286    tmpfs            871M      0  871M   0% /sys/fs/cgroup
  4287    tmpfs            871M      0  871M   0% /tmp
  4288    /dev/mmcblk0p1   256M    76M  180M  30% /boot
  4289
  4290    ### lsblk:
  4291
  4292    NAME         FSTYPE   SIZE MOUNTPOINT UUID
  4293    mmcblk0              29,5G
  4294    ├─mmcblk0p1  vfat     256M /boot      50FC-6AC8
  4295    └─mmcblk0p2  ext4      29G /          3e297ac1-e4e4-4ab1-bc57-47c07d0422ba
  4296    mmcblk1              14,7G
  4297    mmcblk1boot0            4M
  4298    mmcblk1boot1            4M
  4299    mmcblk1gp0              8M
  4300
  4301    ### zramctl:
  4302
  4303    NAME       ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT
  4304    /dev/zram1 lzo         870,6M   4K   81B   12K       4 [SWAP]
  4305
  4306    ### mtab:
  4307
  4308    /dev/mmcblk0p1 /boot vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro 0 0
  4309    /dev/mmcblk0p2 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  4310
  4311    ### mmc0:59b4 info:
  4312
  4313                   fwrev: 0x0
  4314                  uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SDU1  MODALIAS=mmc:block
  4315                     cid: 1b534d53445531201014a136d4013800
  4316                     rca: 0x59b4
  4317                     csd: 400e00325b590000ebef7f800a400000
  4318                  manfid: 0x00001b
  4319                     ocr: 0x00200000
  4320    preferred_erase_size: 4194304
  4321                    type: SD
  4322                   hwrev: 0x1
  4323                    date: 08/2019
  4324                     dsr: 0x404
  4325              erase_size: 512
  4326                   oemid: 0x534d
  4327                  serial: 0x14a136d4
  4328                     ssr: 0000000005000000040090000811391e00089a342f01000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  4329                     scr: 0235844300000000
  4330                    name: SDU1
  4331
  4332    ### mmc1:0001 info:
  4333
  4334                   fwrev: 0x0
  4335                  uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=016G92 MODALIAS=mmc:block
  4336                     cid: 11010030313647393201d3d1a4db1100
  4337             rel_sectors: 0x10
  4338                     rca: 0x0001
  4339            pre_eol_info: 0x00
  4340                     csd: d00e00320f5903ffffffffef92400000
  4341                  manfid: 0x000011
  4342                     ocr: 0x00200000
  4343    preferred_erase_size: 4194304
  4344    enhanced_area_offset: 18446744073709551594
  4345      raw_rpmb_size_mult: 0x4
  4346                    type: MMC
  4347                   hwrev: 0x0
  4348                    date: 01/2014
  4349                     prv: 0x1
  4350             ffu_capable: 0
  4351                     dsr: 0x404
  4352              erase_size: 4194304
  4353               life_time: 0x00 0x00
  4354      enhanced_area_size: 4294967274
  4355                   oemid: 0x0100
  4356                  serial: 0xd3d1a4db
  4357                 cmdq_en: 0
  4358                     rev: 0x6
  4359                    name: 016G92
  4360
  4361    ### Boot system health:
  4362
  4363    Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU
  4364    08:01:49: 1512MHz  0.55  51%  24%  15%   0%  10%   1% 45.0°C
  4365    08:01:49: 1512MHz  0.55  64%  12%  21%   1%  28%   1% 45.0°C
  4366    08:01:50: 1512MHz  0.55  63%  10%   7%   0%  43%   1% 44.0°C
  4367    08:01:50: 1512MHz  0.55  53%   8%  15%   1%  26%   2% 44.0°C
  4368    08:01:50: 1512MHz  0.55  25%   6%   6%   0%  11%   0% 44.0°C
  4369
  4370    ### Activated 1 lzo zram swap devices with 870 MB each
  4371
  4372
  4373    jue mar 25 08:29:09 CET 2021 | AML-S9xxx | 20.02.0-rc1.037 | arm64 | aarch64 | 5.5.0-rc6-aml-s9xxx
  4374
  4375    ### dmesg:
  4376
  4377    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
  4378    [    0.000000] Linux version 5.5.0-rc6-aml-s9xxx (root@vbox) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #rc1.037 SMP PREEMPT Wed Feb 5 15:59:04 MSK 2020
  4379    [    0.000000] Machine model: Amlogic Meson GXL (S905X) P212 Development Board
  4380    [    0.000000] efi: Getting EFI parameters from FDT:
  4381    [    0.000000] efi: UEFI not found.
  4382    [    0.000000] Reserved memory: created CMA memory pool at 0x0000000063400000, size 256 MiB
  4383    [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
  4384    [    0.000000] On node 0 totalpages: 477952
  4385    [    0.000000]   DMA zone: 4032 pages used for memmap
  4386    [    0.000000]   DMA zone: 0 pages reserved
  4387    [    0.000000]   DMA zone: 248576 pages, LIFO batch:63
  4388    [    0.000000]   DMA32 zone: 3584 pages used for memmap
  4389    [    0.000000]   DMA32 zone: 229376 pages, LIFO batch:63
  4390    [    0.000000] psci: probing for conduit method from DT.
  4391    [    0.000000] psci: PSCIv0.2 detected in firmware.
  4392    [    0.000000] psci: Using standard PSCI v0.2 function IDs
  4393    [    0.000000] psci: Trusted OS migration not required
  4394    [    0.000000] percpu: Embedded 22 pages/cpu s50392 r8192 d31528 u90112
  4395    [    0.000000] pcpu-alloc: s50392 r8192 d31528 u90112 alloc=22*4096
  4396    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
  4397    [    0.000000] Detected VIPT I-cache on CPU0
  4398    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 470336
  4399    [    0.000000] Kernel command line: root=LABEL=ROOTFS rootflags=data=writeback rw console=ttyAML0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 mac=00:df:06:00:00:0b
  4400    [    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
  4401    [    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
  4402    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
  4403    [    0.000000] software IO TLB: mapped [mem 0x3bfff000-0x3ffff000] (64MB)
  4404    [    0.000000] Memory: 1509616K/1911808K available (14460K kernel code, 1434K rwdata, 5884K rodata, 960K init, 927K bss, 140048K reserved, 262144K cma-reserved)
  4405    [    0.000000] random: get_random_u64 called from cache_random_seq_create+0x7c/0x150 with crng_init=0
  4406    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
  4407    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
  4408    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
  4409    [    0.000000]     Tasks RCU enabled.
  4410    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
  4411    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
  4412    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
  4413    [    0.000000] GIC: Using split EOI/Deactivate mode
  4414    [    0.000000] irq_meson_gpio: 110 to 8 gpio interrupt mux initialized
  4415    [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
  4416    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
  4417    [    0.000003] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
  4418    [    0.000353] Console: colour dummy device 80x25
  4419    [    0.000654] printk: console [tty0] enabled
  4420    [    0.000694] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
  4421    [    0.000715] pid_max: default: 32768 minimum: 301
  4422    [    0.000842] LSM: Security Framework initializing
  4423    [    0.000892] SELinux:  Initializing.
  4424    [    0.000969] *** VALIDATE SELinux ***
  4425    [    0.001032] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
  4426    [    0.001058] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
  4427    [    0.001120] *** VALIDATE tmpfs ***
  4428    [    0.001529] *** VALIDATE proc ***
  4429    [    0.001749] *** VALIDATE cgroup1 ***
  4430    [    0.001764] *** VALIDATE cgroup2 ***
  4431    [    0.024017] ASID allocator initialised with 32768 entries
  4432    [    0.032000] rcu: Hierarchical SRCU implementation.
  4433    [    0.042069] EFI services will not be available.
  4434    [    0.048055] smp: Bringing up secondary CPUs ...
  4435    [    0.080281] Detected VIPT I-cache on CPU1
  4436    [    0.080335] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
  4437    [    0.112323] Detected VIPT I-cache on CPU2
  4438    [    0.112370] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
  4439    [    0.144370] Detected VIPT I-cache on CPU3
  4440    [    0.144414] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
  4441    [    0.144491] smp: Brought up 1 node, 4 CPUs
  4442    [    0.144556] SMP: Total of 4 processors activated.
  4443    [    0.144567] CPU features: detected: 32-bit EL0 Support
  4444    [    0.144579] CPU features: detected: CRC32 instructions
  4445    [    0.144884] CPU: All CPU(s) started at EL2
  4446    [    0.144909] alternatives: patching kernel code
  4447    [    0.145995] devtmpfs: initialized
  4448    [    0.151117] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
  4449    [    0.151157] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
  4450    [    0.158019] xor: measuring software checksum speed
  4451    [    0.196360]    8regs     :  2374.000 MB/sec
  4452    [    0.236390]    32regs    :  2724.000 MB/sec
  4453    [    0.276430]    arm64_neon:  2406.000 MB/sec
  4454    [    0.276441] xor: using function: 32regs (2724.000 MB/sec)
  4455    [    0.276496] pinctrl core: initialized pinctrl subsystem
  4456    [    0.277166] thermal_sys: Registered thermal governor 'step_wise'
  4457    [    0.277333] DMI not present or invalid.
  4458    [    0.277696] NET: Registered protocol family 16
  4459    [    0.281243] DMA: preallocated 256 KiB pool for atomic allocations
  4460    [    0.281293] audit: initializing netlink subsys (disabled)
  4461    [    0.281508] audit: type=2000 audit(0.280:1): state=initialized audit_enabled=0 res=1
  4462    [    0.282589] cpuidle: using governor ladder
  4463    [    0.282628] cpuidle: using governor menu
  4464    [    0.282998] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
  4465    [    0.283714] Serial: AMBA PL011 UART driver
  4466    [    0.297728] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
  4467    [    0.297756] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
  4468    [    0.297769] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
  4469    [    0.297781] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
  4470    [    0.301495] cryptd: max_cpu_qlen set to 1000
  4471    [    0.376682] raid6: neonx8   gen()  1621 MB/s
  4472    [    0.444703] raid6: neonx8   xor()  1491 MB/s
  4473    [    0.512752] raid6: neonx4   gen()  1565 MB/s
  4474    [    0.580824] raid6: neonx4   xor()  1471 MB/s
  4475    [    0.648889] raid6: neonx2   gen()  1200 MB/s
  4476    [    0.716938] raid6: neonx2   xor()  1217 MB/s
  4477    [    0.785034] raid6: neonx1   gen()   787 MB/s
  4478    [    0.853075] raid6: neonx1   xor()   915 MB/s
  4479    [    0.921126] raid6: int64x8  gen()  1194 MB/s
  4480    [    0.989166] raid6: int64x8  xor()   769 MB/s
  4481    [    1.057211] raid6: int64x4  gen()  1029 MB/s
  4482    [    1.125279] raid6: int64x4  xor()   752 MB/s
  4483    [    1.193381] raid6: int64x2  gen()   729 MB/s
  4484    [    1.261389] raid6: int64x2  xor()   618 MB/s
  4485    [    1.329481] raid6: int64x1  gen()   486 MB/s
  4486    [    1.397499] raid6: int64x1  xor()   468 MB/s
  4487    [    1.397510] raid6: using algorithm neonx8 gen() 1621 MB/s
  4488    [    1.397520] raid6: .... xor() 1491 MB/s, rmw enabled
  4489    [    1.397530] raid6: using neon recovery algorithm
  4490    [    1.397818] ACPI: Interpreter disabled.
  4491    [    1.399000] iommu: Default domain type: Translated
  4492    [    1.399268] vgaarb: loaded
  4493    [    1.399829] SCSI subsystem initialized
  4494    [    1.399993] libata version 3.00 loaded.
  4495    [    1.400201] usbcore: registered new interface driver usbfs
  4496    [    1.400248] usbcore: registered new interface driver hub
  4497    [    1.400314] usbcore: registered new device driver usb
  4498    [    1.400712] pps_core: LinuxPPS API ver. 1 registered
  4499    [    1.400725] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
  4500    [    1.400748] PTP clock support registered
  4501    [    1.400778] EDAC MC: Ver: 3.0.0
  4502    [    1.401386] FPGA manager framework
  4503    [    1.401500] Advanced Linux Sound Architecture Driver Initialized.
  4504    [    1.401953] NetLabel: Initializing
  4505    [    1.401966] NetLabel:  domain hash size = 128
  4506    [    1.401975] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
  4507    [    1.402039] NetLabel:  unlabeled traffic allowed by default
  4508    [    1.402529] clocksource: Switched to clocksource arch_sys_counter
  4509    [    1.402552] *** VALIDATE bpf ***
  4510    [    1.402804] VFS: Disk quotas dquot_6.6.0
  4511    [    1.402866] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
  4512    [    1.402985] FS-Cache: Loaded
  4513    [    1.402996] *** VALIDATE ramfs ***
  4514    [    1.403016] *** VALIDATE hugetlbfs ***
  4515    [    1.403391] pnp: PnP ACPI: disabled
  4516    [    1.408430] NET: Registered protocol family 2
  4517    [    1.408913] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
  4518    [    1.408959] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
  4519    [    1.409076] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
  4520    [    1.409292] TCP: Hash tables configured (established 16384 bind 16384)
  4521    [    1.409446] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
  4522    [    1.409499] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
  4523    [    1.409708] NET: Registered protocol family 1
  4524    [    1.410157] RPC: Registered named UNIX socket transport module.
  4525    [    1.410178] RPC: Registered udp transport module.
  4526    [    1.410188] RPC: Registered tcp transport module.
  4527    [    1.410197] RPC: Registered tcp NFSv4.1 backchannel transport module.
  4528    [    1.410213] NET: Registered protocol family 44
  4529    [    1.410233] PCI: CLS 0 bytes, default 64
  4530    [    1.410425] Trying to unpack rootfs image as initramfs...
  4531    [    1.871277] Freeing initrd memory: 10248K
  4532    [    1.872066] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
  4533    [    2.086060] Initialise system trusted keyrings
  4534    [    2.086296] workingset: timestamp_bits=46 max_order=19 bucket_order=0
  4535    [    2.091541] zbud: loaded
  4536    [    2.092796] squashfs: version 4.0 (2009/01/31) Phillip Lougher
  4537    [    2.093082] FS-Cache: Netfs 'nfs' registered for caching
  4538    [    2.093600] NFS: Registering the id_resolver key type
  4539    [    2.093640] Key type id_resolver registered
  4540    [    2.093650] Key type id_legacy registered
  4541    [    2.093666] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
  4542    [    2.093679] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
  4543    [    2.094913] FS-Cache: Netfs 'cifs' registered for caching
  4544    [    2.095244] Key type cifs.spnego registered
  4545    [    2.095265] Key type cifs.idmap registered
  4546    [    2.095288] ntfs: driver 2.1.32 [Flags: R/W].
  4547    [    2.095851] JFS: nTxBlock = 8192, nTxLock = 65536
  4548    [    2.101816] SGI XFS with ACLs, security attributes, realtime, quota, no debug enabled
  4549    [    2.103213] *** VALIDATE xfs ***
  4550    [    2.103499] ocfs2: Registered cluster interface o2cb
  4551    [    2.103716] OCFS2 User DLM kernel interface loaded
  4552    [    2.105103] *** VALIDATE gfs2 ***
  4553    [    2.105373] gfs2: GFS2 installed
  4554    [    2.106270] aufs 5.5-20200203
  4555    [    2.127038] Key type asymmetric registered
  4556    [    2.127065] Asymmetric key parser 'x509' registered
  4557    [    2.127075] Asymmetric key parser 'pkcs8' registered
  4558    [    2.127146] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
  4559    [    2.127335] io scheduler mq-deadline registered
  4560    [    2.127350] io scheduler kyber registered
  4561    [    2.127555] io scheduler bfq registered
  4562    [    2.140235] soc soc0: Amlogic Meson GXL (S905X) Revision 21:b (82:2) Detected
  4563    [    2.143898] Serial: 8250/16550 driver, 5 ports, IRQ sharing enabled
  4564    [    2.145597] Serial: AMBA driver
  4565    [    2.145969] c11084c0.serial: ttyAML6 at MMIO 0xc11084c0 (irq = 10, base_baud = 1500000) is a meson_uart
  4566    [    2.146132] serial serial0: tty port ttyAML6 registered
  4567    [    2.146346] c81004c0.serial: ttyAML0 at MMIO 0xc81004c0 (irq = 13, base_baud = 1500000) is a meson_uart
  4568    [    3.121815] printk: console [ttyAML0] enabled
  4569    [    3.137867] brd: module loaded
  4570    [    3.146325] loop: module loaded
  4571    [    3.148799] libphy: Fixed MDIO Bus: probed
  4572    [    3.149454] meson8b-dwmac c9410000.ethernet: IRQ eth_wake_irq not found
  4573    [    3.154596] meson8b-dwmac c9410000.ethernet: IRQ eth_lpi not found
  4574    [    3.160701] meson8b-dwmac c9410000.ethernet: PTP uses main clock
  4575    [    3.166553] meson8b-dwmac c9410000.ethernet: no reset control found
  4576    [    3.173233] meson8b-dwmac c9410000.ethernet: User ID: 0x11, Synopsys ID: 0x37
  4577    [    3.179850] meson8b-dwmac c9410000.ethernet:     DWMAC1000
  4578    [    3.185006] meson8b-dwmac c9410000.ethernet: DMA HW capability register supported
  4579    [    3.192423] meson8b-dwmac c9410000.ethernet: RX Checksum Offload Engine supported
  4580    [    3.199839] meson8b-dwmac c9410000.ethernet: COE Type 2
  4581    [    3.205013] meson8b-dwmac c9410000.ethernet: TX Checksum insertion supported
  4582    [    3.211999] meson8b-dwmac c9410000.ethernet: Wake-Up On Lan supported
  4583    [    3.218412] meson8b-dwmac c9410000.ethernet: Normal descriptors
  4584    [    3.224247] meson8b-dwmac c9410000.ethernet: Ring mode enabled
  4585    [    3.230027] meson8b-dwmac c9410000.ethernet: Enable RX Mitigation via HW Watchdog Timer
  4586    [    3.238142] libphy: stmmac: probed
  4587    [    3.242704] VFIO - User Level meta-driver version: 0.3
  4588    [    3.247954] dwc3 c9000000.dwc3: Failed to get clk 'ref': -2
  4589    [    3.252807] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
  4590    [    3.258433] ehci-pci: EHCI PCI platform driver
  4591    [    3.262869] ehci-platform: EHCI generic platform driver
  4592    [    3.268172] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
  4593    [    3.274113] ohci-pci: OHCI PCI platform driver
  4594    [    3.278547] ohci-platform: OHCI generic platform driver
  4595    [    3.284299] usbcore: registered new interface driver usb-storage
  4596    [    3.289855] mousedev: PS/2 mouse device common for all mice
  4597    [    3.295807] i2c /dev entries driver
  4598    [    3.301483] sdhci: Secure Digital Host Controller Interface driver
  4599    [    3.304736] sdhci: Copyright(c) Pierre Ossman
  4600    [    3.309049] Synopsys Designware Multimedia Card Interface Driver
  4601    [    3.316343] meson-gx-mmc d0072000.mmc: Got CD GPIO
  4602    [    3.346863] meson-gx-mmc d0074000.mmc: allocated mmc-pwrseq
  4603    [    3.374376] sdhci-pltfm: SDHCI platform and OF driver helper
  4604    [    3.375320] ledtrig-cpu: registered to indicate activity on CPUs
  4605    [    3.380976] meson-sm: secure-monitor enabled
  4606    [    3.385250] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
  4607    [    3.386581] mmc0: new high speed SDHC card at address 59b4
  4608    [    3.392576] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
  4609    [    3.398708] mmcblk0: mmc0:59b4 SDU1  29.5 GiB
  4610    [    3.420838]  mmcblk0: p1 p2
  4611    [    3.422850] hid: raw HID events driver (C) Jiri Kosina
  4612    [    3.423311] usbcore: registered new interface driver usbhid
  4613    [    3.428747] usbhid: USB HID core driver
  4614    [    3.432818] platform-mhu c883c404.mailbox: Platform MHU Mailbox registered
  4615    [    3.449810] NET: Registered protocol family 17
  4616    [    3.450093] Key type dns_resolver registered
  4617    [    3.453483] registered taskstats version 1
  4618    [    3.456943] Loading compiled-in X.509 certificates
  4619    [    3.461866] zswap: loaded using pool lzo/zbud
  4620    [    3.466146] Key type ._fscrypt registered
  4621    [    3.469948] Key type .fscrypt registered
  4622    [    3.475100] Btrfs loaded, crc32c=crc32c-generic
  4623    [    3.496281] mmc1: new HS200 MMC card at address 0001
  4624    [    3.501282] mmcblk1: mmc1:0001 016G92 14.7 GiB
  4625    [    3.501719] mmcblk1boot0: mmc1:0001 016G92 partition 1 4.00 MiB
  4626    [    3.501972] Key type encrypted registered
  4627    [    3.506485] mmcblk1boot1: mmc1:0001 016G92 partition 2 4.00 MiB
  4628    [    3.516412] mmcblk1gp0: mmc1:0001 016G92 partition 4 8.00 MiB
  4629    [    3.521893] mmcblk1rpmb: mmc1:0001 016G92 partition 3 512 KiB, chardev (243:0)
  4630    [    3.529751] meson-drm d0100000.vpu: Queued 3 outputs on vpu
  4631    [    3.534814] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
  4632    [    3.540845] [drm] No driver support for vblank timestamp query.
  4633    [    3.574586] meson-dw-hdmi c883a000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
  4634    [    3.579242] meson-dw-hdmi c883a000.hdmi-tx: registered DesignWare HDMI I2C bus driver
  4635    [    3.587261] meson-drm d0100000.vpu: bound c883a000.hdmi-tx (ops meson_dw_hdmi_ops)
  4636    [    3.594608] [drm] Initialized meson 1.0.0 20161109 for d0100000.vpu on minor 0
  4637    [    3.630094] Console: switching to colour frame buffer device 90x36
  4638    [    3.650314] meson-drm d0100000.vpu: fb0: mesondrmfb frame buffer device
  4639    [    3.657576] libphy: mdio_mux: probed
  4640    [    3.668137] libphy: mdio_mux: probed
  4641    [    3.668622] phy phy-d0078080.phy.2: unsupported PHY mode 5
  4642    [    3.673649] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  4643    [    3.677062] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
  4644    [    3.684768] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228f664 hci version 0x100 quirks 0x0000000002010010
  4645    [    3.693998] xhci-hcd xhci-hcd.0.auto: irq 39, io mem 0xc9000000
  4646    [    3.700098] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.05
  4647    [    3.708441] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  4648    [    3.715591] usb usb1: Product: xHCI Host Controller
  4649    [    3.720419] usb usb1: Manufacturer: Linux 5.5.0-rc6-aml-s9xxx xhci-hcd
  4650    [    3.726887] usb usb1: SerialNumber: xhci-hcd.0.auto
  4651    [    3.732245] hub 1-0:1.0: USB hub found
  4652    [    3.735462] hub 1-0:1.0: 2 ports detected
  4653    [    3.739681] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  4654    [    3.744847] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
  4655    [    3.752437] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
  4656    [    3.758938] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
  4657    [    3.767192] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.05
  4658    [    3.775570] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  4659    [    3.782726] usb usb2: Product: xHCI Host Controller
  4660    [    3.787555] usb usb2: Manufacturer: Linux 5.5.0-rc6-aml-s9xxx xhci-hcd
  4661    [    3.794024] usb usb2: SerialNumber: xhci-hcd.0.auto
  4662    [    3.799320] hub 2-0:1.0: USB hub found
  4663    [    3.802602] hub 2-0:1.0: config failed, hub doesn't have any ports! (err -19)
  4664    [    3.811539] meson-gx-mmc d0070000.mmc: allocated mmc-pwrseq
  4665    [    3.842657] scpi_protocol scpi: SCP Protocol legacy pre-1.0 firmware
  4666    [    3.860111] gx-sound-card sound: snd-soc-dummy-dai <-> c1105400.bus:audio-controller-0 mapping ok
  4667    [    3.869332] gx-sound-card sound: i2s-hifi <-> c1105400.bus:audio-controller-2 mapping ok
  4668    [    3.877017] gx-sound-card sound: ASoC: no DMI vendor name!
  4669    [    3.883196] printk: console [netcon0] enabled
  4670    [    3.886653] netconsole: network logging started
  4671    [    3.891215] hctosys: unable to open rtc device (rtc0)
  4672    [    3.896449] ALSA device list:
  4673    [    3.899588]   #0: AMLGX
  4674    [    3.903113] Freeing unused kernel memory: 960K
  4675    [    3.906194] Run /init as init process
  4676    [    3.906862] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
  4677    [    3.918736] mmc2: queuing unknown CIS tuple 0x80 (6 bytes)
  4678    [    3.925288] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
  4679    [    3.937311] mmc2: queuing unknown CIS tuple 0x80 (19 bytes)
  4680    [    3.964376] random: fast init done
  4681    [    4.022156] mmc2: new high speed SDIO card at address 0001
  4682    [    4.078608] usb 1-1: new high-speed USB device number 2 using xhci-hcd
  4683    [    4.100400] usb 1-1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.36
  4684    [    4.107205] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
  4685    [    4.114252] usb 1-1: Product: USB2.0 Hub
  4686    [    4.175438] hub 1-1:1.0: USB hub found
  4687    [    4.177914] hub 1-1:1.0: 4 ports detected
  4688    [    4.310606] usb 1-2: new high-speed USB device number 3 using xhci-hcd
  4689    [    4.341180] usb 1-2: New USB device found, idVendor=148f, idProduct=7601, bcdDevice= 0.00
  4690    [    4.348015] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
  4691    [    4.355977] usb 1-2: Product: 802.11 n WLAN
  4692    [    4.359219] usb 1-2: Manufacturer: MediaTek
  4693    [    4.363298] usb 1-2: SerialNumber: 1.0
  4694    [    5.040612] EXT4-fs (mmcblk0p2): mounted filesystem with writeback data mode. Opts: data=writeback
  4695    [    5.995866] systemd[1]: System time before build time, advancing clock.
  4696    [    6.149780] NET: Registered protocol family 10
  4697    [    6.221058] Segment Routing with IPv6
  4698    [    6.272439] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
  4699    [    6.308765] systemd[1]: Detected architecture arm64.
  4700    [    6.360408] systemd[1]: Set hostname to <mxqpro>.
  4701    [    6.392837] systemd[1]: Couldn't move remaining userspace processes, ignoring: Input/output error
  4702    [    7.078770] random: systemd: uninitialized urandom read (16 bytes read)
  4703    [    7.091350] random: systemd: uninitialized urandom read (16 bytes read)
  4704    [    7.099361] systemd[1]: Created slice system-systemd\x2dfsck.slice.
  4705    [    7.105688] random: systemd: uninitialized urandom read (16 bytes read)
  4706    [    7.109844] systemd[1]: Listening on Journal Socket.
  4707    [    7.121041] systemd[1]: Mounting Kernel Debug File System...
  4708    [    7.128262] systemd[1]: Created slice system-serial\x2dgetty.slice.
  4709    [    7.138153] systemd[1]: Starting Nameserver information manager...
  4710    [    7.144520] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
  4711    [    7.325631] EXT4-fs (mmcblk0p2): re-mounted. Opts: commit=600,errors=remount-ro
  4712    [    7.596933] systemd-journald[414]: Received request to flush runtime journal from PID 1
  4713    [    8.082747] mc: Linux media interface: v0.10
  4714    [    8.109912] videodev: Linux video capture interface: v2.00
  4715    [    8.134829] Registered IR keymap rc-empty
  4716    [    8.136908] rc rc0: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0
  4717    [    8.143380] input: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0/input0
  4718    [    8.150768] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
  4719    [    8.166190] meson-ir c8100580.ir: receiver initialized
  4720    [    8.231729] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
  4721    [    8.246786] lima d00c0000.gpu: IRQ ppmmu3 not found
  4722    [    8.249267] lima d00c0000.gpu: IRQ ppmmu4 not found
  4723    [    8.262760] lima d00c0000.gpu: IRQ ppmmu5 not found
  4724    [    8.265124] lima d00c0000.gpu: IRQ ppmmu6 not found
  4725    [    8.276242] lima d00c0000.gpu: IRQ ppmmu7 not found
  4726    [    8.281140] lima d00c0000.gpu: gp - mali450 version major 0 minor 0
  4727    [    8.289232] lima d00c0000.gpu: pp0 - mali450 version major 0 minor 0
  4728    [    8.292584] lima d00c0000.gpu: pp1 - mali450 version major 0 minor 0
  4729    [    8.301737] lima d00c0000.gpu: pp2 - mali450 version major 0 minor 0
  4730    [    8.306700] lima d00c0000.gpu: IRQ pp3 not found
  4731    [    8.309479] lima d00c0000.gpu: IRQ pp4 not found
  4732    [    8.317008] lima d00c0000.gpu: IRQ pp5 not found
  4733    [    8.320573] lima d00c0000.gpu: IRQ pp6 not found
  4734    [    8.324550] lima d00c0000.gpu: IRQ pp7 not found
  4735    [    8.329196] lima d00c0000.gpu: l2 cache 8K, 4-way, 64byte cache line, 128bit external bus
  4736    [    8.337366] lima d00c0000.gpu: l2 cache 64K, 4-way, 64byte cache line, 128bit external bus
  4737    [    8.347139] lima d00c0000.gpu: bus rate = 166666667
  4738    [    8.349365] lima d00c0000.gpu: mod rate = 744000000
  4739    [    8.356470] [drm] Initialized lima 1.0.0 20190217 for d00c0000.gpu on minor 1
  4740    [    8.447229] Bluetooth: Core ver 2.22
  4741    [    8.449868] NET: Registered protocol family 31
  4742    [    8.451911] Bluetooth: HCI device and connection manager initialized
  4743    [    8.458128] Bluetooth: HCI socket layer initialized
  4744    [    8.462854] Bluetooth: L2CAP socket layer initialized
  4745    [    8.467896] Bluetooth: SCO socket layer initialized
  4746    [    8.520770] cfg80211: Loading compiled-in X.509 certificates for regulatory database
  4747    [    8.556595] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
  4748    [    8.561226] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
  4749    [    8.568938] cfg80211: failed to load regulatory.db
  4750    [    8.694760] Bluetooth: HCI UART driver ver 2.3
  4751    [    8.697128] Bluetooth: HCI UART protocol H4 registered
  4752    [    8.700667] brcmfmac: F1 signature read @0x18000000=0x16034334
  4753    [    8.706070] Bluetooth: HCI UART protocol BCSP registered
  4754    [    8.708106] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4334-sdio for chip BCM4334/3
  4755    [    8.708403] Bluetooth: HCI UART protocol LL registered
  4756    [    8.716487] usbcore: registered new interface driver brcmfmac
  4757    [    8.721404] Bluetooth: HCI UART protocol ATH3K registered
  4758    [    8.736563] Bluetooth: HCI UART protocol Three-wire (H5) registered
  4759    [    8.739900] Bluetooth: HCI UART protocol Intel registered
  4760    [    8.745480] hci_uart_bcm serial0-0: serial0-0 supply vbat not found, using dummy regulator
  4761    [    8.753237] hci_uart_bcm serial0-0: serial0-0 supply vddio not found, using dummy regulator
  4762    [    8.761540] Bluetooth: HCI UART protocol Broadcom registered
  4763    [    8.767107] Bluetooth: HCI UART protocol QCA registered
  4764    [    8.772212] Bluetooth: HCI UART protocol AG6XX registered
  4765    [    8.777638] Bluetooth: HCI UART protocol Marvell registered
  4766    [    8.827167] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.amlogic,p212.txt failed with error -2
  4767    [    8.827232] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.txt failed with error -2
  4768    [    8.862911] usb 1-2: reset high-speed USB device number 3 using xhci-hcd
  4769    [    8.893347] mt7601u 1-2:1.0: ASIC revision: 76010001 MAC revision: 76010500
  4770    [    8.919367] mt7601u 1-2:1.0: EEPROM ver:0d fae:00
  4771    [    9.130069] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
  4772    [    9.132833] usbcore: registered new interface driver mt7601u
  4773    [    9.147542] Bluetooth: hci0: BCM: chip id 68
  4774    [    9.150833] Bluetooth: hci0: BCM: features 0x0f
  4775    [    9.158784] Bluetooth: hci0: BCM4334B0
  4776    [    9.163806] Bluetooth: hci0: BCM4334B0 (002.001.013) build 0000
  4777    [    9.167835] bluetooth hci0: Direct firmware load for brcm/BCM4334B0.hcd failed with error -2
  4778    [    9.177450] Bluetooth: hci0: BCM: Patch brcm/BCM4334B0.hcd not found
  4779    [    9.830624] brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x50
  4780    [    9.886451] zram: Added device: zram0
  4781    [    9.891176] zram: Added device: zram1
  4782    [    9.894404] zram: Added device: zram2
  4783    [    9.925547] meson8b-dwmac c9410000.ethernet eth0: PHY [0.e40908ff:08] driver [Meson GXL Internal PHY]
  4784    [    9.945386] zram1: detected capacity change from 0 to 912879616
  4785    [    9.950673] meson8b-dwmac c9410000.ethernet eth0: No Safety Features support found
  4786    [    9.957268] meson8b-dwmac c9410000.ethernet eth0: PTP not supported by HW
  4787    [    9.962462] meson8b-dwmac c9410000.ethernet eth0: configuring for phy/rmii link mode
  4788    [   10.586495] random: crng init done
  4789    [   10.588901] random: 7 urandom warning(s) missed due to ratelimiting
  4790    [   10.790775] Adding 891480k swap on /dev/zram1.  Priority:5 extents:1 across:891480k SSFS
  4791
  4792    ### armbian-release:
  4793
  4794    # PLEASE DO NOT EDIT THIS FILE
  4795    BOARD=aml-s9xxx
  4796    BOARD_NAME="AML-S9xxx"
  4797    BOARDFAMILY=aml-s9xxx
  4798    BUILD_REPOSITORY_URL=https://github.com/150balbes/Build-Armbian.git
  4799    BUILD_REPOSITORY_COMMIT=62b8c07-dirty
  4800    DISTRIBUTION_CODENAME=buster
  4801    DISTRIBUTION_STATUS=supported
  4802    VERSION=20.02.0-rc1.037
  4803    LINUXFAMILY=aml-s9xxx
  4804    BRANCH=current
  4805    ARCH=arm64
  4806    IMAGE_TYPE=nightly
  4807    BOARD_TYPE=conf
  4808    INITRD_ARCH=arm64
  4809    KERNEL_IMAGE_TYPE=Image
  4810
  4811    ### boot environment:
  4812
  4813    ODROIDN2-UBOOT-CONFIG
  4814    setenv env_addr 0x10400000
  4815    setenv kernel_addr 0x11000000
  4816    setenv initrd_addr 0x13000000
  4817    setenv dtb_addr 0x1000000
  4818    if test "${devtype}" = ""; then setenv devtype "mmc"; fi
  4819    load ${devtype} ${devnum} ${env_addr} uEnv.txt && env import -t ${env_addr} ${filesize}
  4820    setenv bootargs ${APPEND}
  4821    load ${devtype} ${devnum} ${kernel_addr} ${LINUX}
  4822    load ${devtype} ${devnum} ${initrd_addr} ${INITRD}
  4823    load ${devtype} ${devnum} ${dtb_addr} ${FDT}
  4824    fdt addr ${dtb_addr}
  4825    booti ${kernel_addr} ${initrd_addr} ${dtb_addr}
  4826
  4827    ### lsusb:
  4828
  4829    Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
  4830    Bus 001 Device 003: ID 148f:7601 Ralink Technology, Corp. MT7601U Wireless Adapter
  4831    Bus 001 Device 002: ID 05e3:0608 Genesys Logic, Inc. Hub
  4832    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  4833
  4834    ### lscpu:
  4835
  4836    Architecture:        aarch64
  4837    Byte Order:          Little Endian
  4838    CPU(s):              4
  4839    On-line CPU(s) list: 0-3
  4840    Thread(s) per core:  1
  4841    Core(s) per socket:  4
  4842    Socket(s):           1
  4843    Vendor ID:           ARM
  4844    Model:               4
  4845    Model name:          Cortex-A53
  4846    Stepping:            r0p4
  4847    CPU max MHz:         1512,0000
  4848    CPU min MHz:         100,0000
  4849    BogoMIPS:            48.00
  4850    L1d cache:           unknown size
  4851    L1i cache:           unknown size
  4852    L2 cache:            unknown size
  4853    Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  4854
  4855    ### cpuinfo:
  4856
  4857    processor    : 0
  4858    model name    : ARMv8 Processor rev 4 (v8l)
  4859    BogoMIPS    : 48.00
  4860    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  4861    CPU implementer    : 0x41
  4862    CPU architecture: 8
  4863    CPU variant    : 0x0
  4864    CPU part    : 0xd03
  4865    CPU revision    : 4
  4866
  4867    processor    : 1
  4868    model name    : ARMv8 Processor rev 4 (v8l)
  4869    BogoMIPS    : 48.00
  4870    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  4871    CPU implementer    : 0x41
  4872    CPU architecture: 8
  4873    CPU variant    : 0x0
  4874    CPU part    : 0xd03
  4875    CPU revision    : 4
  4876
  4877    processor    : 2
  4878    model name    : ARMv8 Processor rev 4 (v8l)
  4879    BogoMIPS    : 48.00
  4880    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  4881    CPU implementer    : 0x41
  4882    CPU architecture: 8
  4883    CPU variant    : 0x0
  4884    CPU part    : 0xd03
  4885    CPU revision    : 4
  4886
  4887    processor    : 3
  4888    model name    : ARMv8 Processor rev 4 (v8l)
  4889    BogoMIPS    : 48.00
  4890    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  4891    CPU implementer    : 0x41
  4892    CPU architecture: 8
  4893    CPU variant    : 0x0
  4894    CPU part    : 0xd03
  4895    CPU revision    : 4
  4896
  4897
  4898    ### meminfo:
  4899
  4900    MemTotal:        1782968 kB
  4901    MemFree:         1606640 kB
  4902    MemAvailable:    1665088 kB
  4903    Buffers:           11628 kB
  4904    Cached:            54492 kB
  4905    SwapCached:            0 kB
  4906    Active:            52744 kB
  4907    Inactive:          35564 kB
  4908    Active(anon):      22256 kB
  4909    Inactive(anon):     2596 kB
  4910    Active(file):      30488 kB
  4911    Inactive(file):    32968 kB
  4912    Unevictable:           0 kB
  4913    Mlocked:               0 kB
  4914    SwapTotal:        891480 kB
  4915    SwapFree:         891480 kB
  4916    Dirty:               428 kB
  4917    Writeback:             0 kB
  4918    AnonPages:         21932 kB
  4919    Mapped:            22784 kB
  4920    Shmem:              2696 kB
  4921    KReclaimable:      18108 kB
  4922    Slab:              53388 kB
  4923    SReclaimable:      18108 kB
  4924    SUnreclaim:        35280 kB
  4925    KernelStack:        2752 kB
  4926    PageTables:         1432 kB
  4927    NFS_Unstable:          0 kB
  4928    Bounce:                0 kB
  4929    WritebackTmp:          0 kB
  4930    CommitLimit:     1782964 kB
  4931    Committed_AS:      77968 kB
  4932    VmallocTotal:   135290159040 kB
  4933    VmallocUsed:       16740 kB
  4934    VmallocChunk:          0 kB
  4935    Percpu:             1264 kB
  4936    CmaTotal:         262144 kB
  4937    CmaFree:          258460 kB
  4938    HugePages_Total:       0
  4939    HugePages_Free:        0
  4940    HugePages_Rsvd:        0
  4941    HugePages_Surp:        0
  4942    Hugepagesize:       2048 kB
  4943    Hugetlb:               0 kB
  4944
  4945    ### virtual memory:
  4946
  4947    vm.admin_reserve_kbytes = 8192
  4948    vm.block_dump = 0
  4949    vm.compact_unevictable_allowed = 1
  4950    vm.dirty_background_bytes = 0
  4951    vm.dirty_background_ratio = 10
  4952    vm.dirty_bytes = 0
  4953    vm.dirty_expire_centisecs = 3000
  4954    vm.dirty_ratio = 20
  4955    vm.dirtytime_expire_seconds = 43200
  4956    vm.dirty_writeback_centisecs = 500
  4957    vm.extfrag_threshold = 500
  4958    vm.hugetlb_shm_group = 0
  4959    vm.laptop_mode = 0
  4960    vm.legacy_va_layout = 0
  4961    vm.lowmem_reserve_ratio = 256    256    32    0
  4962    vm.max_map_count = 65530
  4963    vm.min_free_kbytes = 4914
  4964    vm.mmap_min_addr = 4096
  4965    vm.mmap_rnd_bits = 18
  4966    vm.nr_hugepages = 0
  4967    vm.nr_overcommit_hugepages = 0
  4968    vm.oom_dump_tasks = 1
  4969    vm.oom_kill_allocating_task = 0
  4970    vm.overcommit_kbytes = 0
  4971    vm.overcommit_memory = 0
  4972    vm.overcommit_ratio = 50
  4973    vm.page-cluster = 0
  4974    vm.panic_on_oom = 0
  4975    vm.percpu_pagelist_fraction = 0
  4976    vm.stat_interval = 1
  4977    vm.swappiness = 100
  4978    vm.user_reserve_kbytes = 55239
  4979    vm.vfs_cache_pressure = 100
  4980    vm.watermark_boost_factor = 15000
  4981    vm.watermark_scale_factor = 10
  4982
  4983    ### ip addr:
  4984
  4985    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
  4986        link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  4987        inet XXX.XXX.0.1/8 scope host lo
  4988           valid_lft forever preferred_lft forever
  4989        inet6 ::1/128 scope host
  4990           valid_lft forever preferred_lft forever
  4991    2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
  4992        link/ether 00:df:06:00:00:0b brd ff:ff:ff:ff:ff:ff
  4993    3: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  4994        link/ether 00:36:76:61:0b:24 brd ff:ff:ff:ff:ff:ff
  4995
  4996    ### partitions:
  4997
  4998    major minor  #blocks  name
  4999
  5000     179        0   30924800 mmcblk0
  5001     179        1     262144 mmcblk0p1
  5002     179        2   30337024 mmcblk0p2
  5003     179       32   15384576 mmcblk1
  5004     179      128       8192 mmcblk1gp0
  5005     254        1     891484 zram1
  5006
  5007    ### df:
  5008
  5009    udev             738M      0  738M   0% /dev
  5010    tmpfs            175M   2,7M  172M   2% /run
  5011    /dev/mmcblk0p2    29G    10G   19G  36% /
  5012    tmpfs            871M      0  871M   0% /dev/shm
  5013    tmpfs            5,0M   4,0K  5,0M   1% /run/lock
  5014    tmpfs            871M      0  871M   0% /sys/fs/cgroup
  5015    tmpfs            871M      0  871M   0% /tmp
  5016    /dev/mmcblk0p1   256M    76M  180M  30% /boot
  5017
  5018    ### lsblk:
  5019
  5020    NAME         FSTYPE   SIZE MOUNTPOINT UUID
  5021    mmcblk0              29,5G
  5022    ├─mmcblk0p1  vfat     256M /boot      50FC-6AC8
  5023    └─mmcblk0p2  ext4      29G /          3e297ac1-e4e4-4ab1-bc57-47c07d0422ba
  5024    mmcblk1              14,7G
  5025    mmcblk1boot0            4M
  5026    mmcblk1boot1            4M
  5027    mmcblk1gp0              8M
  5028
  5029    ### zramctl:
  5030
  5031    NAME       ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT
  5032    /dev/zram1 lzo         870,6M   4K   81B   12K       4 [SWAP]
  5033
  5034    ### mtab:
  5035
  5036    /dev/mmcblk0p1 /boot vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro 0 0
  5037    /dev/mmcblk0p2 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  5038
  5039    ### mmc0:59b4 info:
  5040
  5041                   fwrev: 0x0
  5042                  uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SDU1  MODALIAS=mmc:block
  5043                     cid: 1b534d53445531201014a136d4013800
  5044                     rca: 0x59b4
  5045                     csd: 400e00325b590000ebef7f800a400000
  5046                  manfid: 0x00001b
  5047                     ocr: 0x00200000
  5048    preferred_erase_size: 4194304
  5049                    type: SD
  5050                   hwrev: 0x1
  5051                    date: 08/2019
  5052                     dsr: 0x404
  5053              erase_size: 512
  5054                   oemid: 0x534d
  5055                  serial: 0x14a136d4
  5056                     ssr: 0000000005000000040090000811391e00089a342f01000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  5057                     scr: 0235844300000000
  5058                    name: SDU1
  5059
  5060    ### mmc1:0001 info:
  5061
  5062                   fwrev: 0x0
  5063                  uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=016G92 MODALIAS=mmc:block
  5064                     cid: 11010030313647393201d3d1a4db1100
  5065             rel_sectors: 0x10
  5066                     rca: 0x0001
  5067            pre_eol_info: 0x00
  5068                     csd: d00e00320f5903ffffffffef92400000
  5069                  manfid: 0x000011
  5070                     ocr: 0x00200000
  5071    preferred_erase_size: 4194304
  5072    enhanced_area_offset: 18446744073709551594
  5073      raw_rpmb_size_mult: 0x4
  5074                    type: MMC
  5075                   hwrev: 0x0
  5076                    date: 01/2014
  5077                     prv: 0x1
  5078             ffu_capable: 0
  5079                     dsr: 0x404
  5080              erase_size: 4194304
  5081               life_time: 0x00 0x00
  5082      enhanced_area_size: 4294967274
  5083                   oemid: 0x0100
  5084                  serial: 0xd3d1a4db
  5085                 cmdq_en: 0
  5086                     rev: 0x6
  5087                    name: 016G92
  5088
  5089    ### Boot system health:
  5090
  5091    Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU
  5092    08:29:12: 1512MHz  0.15  51%  24%  14%   0%  10%   1% 60.0°C
  5093    08:29:12: 1512MHz  0.15  71%   8%  18%   1%  40%   1% 60.0°C
  5094    08:29:12: 1512MHz  0.15  68%   9%  12%   0%  44%   1% 59.0°C
  5095    08:29:13: 1512MHz  0.15  52%  10%  15%   1%  23%   2% 59.0°C
  5096    08:29:13: 1512MHz  0.15  25%   3%   4%   1%  14%   0% 58.0°C
  5097
  5098    ### lsusb:
  5099
  5100    Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
  5101    Bus 001 Device 003: ID 148f:7601 Ralink Technology, Corp. MT7601U Wireless Adapter
  5102    Bus 001 Device 002: ID 05e3:0608 Genesys Logic, Inc. Hub
  5103    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  5104
  5105    /:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/0p, 5000M
  5106    /:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/2p, 480M
  5107        |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
  5108        |__ Port 2: Dev 3, If 0, Class=Vendor Specific Class, Driver=mt7601u, 480M
  5109
  5110    ### lspci:
  5111
  5112
  5113    ### Installed packages:
  5114
  5115    ii  armbian-buster-desktop                21.02.2                              all          Armbian desktop for Debian buster
  5116    ii  armbian-config                        21.02.3                              all          Armbian configuration utility
  5117    ii  armbian-firmware                      21.02.3                              all          Linux firmware
  5118    ii  hostapd                               3:2.9-102~armbian20.05.2+1           arm64        IEEE 802.11 AP and IEEE 802.1X/WPA/WPA2/EAP Authenticator
  5119    ii  htop                                  3.1.0-0~armbian20.08.2+1             arm64        interactive processes viewer
  5120    ii  linux-base                            4.6                                  all          Linux image base package
  5121    ii  linux-buster-root-current-aml-s9xxx   20.02.0-rc1.037                      arm64        Armbian tweaks for buster on aml-s9xxx (current branch)
  5122    ii  linux-image-current-aml-s9xxx         20.02.0-rc1.037                      arm64        Linux kernel, version 5.5.0-rc6-aml-s9xxx
  5123    ii  linux-libc-dev:arm64                  4.19.171-2                           arm64        Linux support headers for userspace development
  5124    ii  linux-u-boot-aml-s9xxx-current        20.02.0-rc1.037                      arm64        Uboot loader 2019.10
  5125
  5126    ### Loaded modules:
  5127
  5128    Module                  Size  Used by
  5129    ip6t_REJECT            16384  2
  5130    nf_reject_ipv6         20480  1 ip6t_REJECT
  5131    ip6table_filter        16384  1
  5132    xt_state               16384  0
  5133    ipt_REJECT             16384  2
  5134    nf_reject_ipv4         16384  1 ipt_REJECT
  5135    ip6_tables             28672  1 ip6table_filter
  5136    xt_nat                 16384  11
  5137    xt_tcpudp              20480  35
  5138    tun                    53248  2
  5139    iptable_filter         16384  1
  5140    iptable_nat            16384  3
  5141    bpfilter               28672  0
  5142    veth                   28672  0
  5143    xt_conntrack           16384  6
  5144    xt_MASQUERADE          20480  7
  5145    nf_conntrack_netlink    49152  0
  5146    xfrm_user              36864  2
  5147    xfrm_algo              16384  1 xfrm_user
  5148    nft_counter            16384  15
  5149    xt_addrtype            16384  8
  5150    nft_compat             20480  4
  5151    nft_chain_nat          16384  4
  5152    nf_nat                 53248  4 xt_nat,nft_chain_nat,iptable_nat,xt_MASQUERADE
  5153    nf_conntrack          176128  6 xt_conntrack,nf_nat,xt_state,xt_nat,nf_conntrack_netlink,xt_MASQUERADE
  5154    nf_defrag_ipv4         16384  1 nf_conntrack
  5155    nf_tables             163840  45 nft_compat,nft_counter,nft_chain_nat
  5156    nfnetlink              16384  5 nft_compat,nf_conntrack_netlink,nf_tables
  5157    br_netfilter           28672  0
  5158    bridge                208896  1 br_netfilter
  5159    stp                    16384  1 bridge
  5160    llc                    16384  2 bridge,stp
  5161    bnep                   32768  2
  5162    zram                   36864  1
  5163    nls_ascii              16384  1
  5164    mt7601u                77824  0
  5165    hci_uart              143360  0
  5166    brcmfmac              376832  0
  5167    mac80211              569344  1 mt7601u
  5168    btqca                  20480  1 hci_uart
  5169    btrtl                  24576  1 hci_uart
  5170    brcmutil               24576  1 brcmfmac
  5171    btbcm                  16384  1 hci_uart
  5172    btintel                32768  1 hci_uart
  5173    cfg80211              417792  3 mt7601u,brcmfmac,mac80211
  5174    bluetooth             598016  27 btrtl,btqca,btintel,hci_uart,btbcm,bnep
  5175    ecdh_generic           16384  2 bluetooth
  5176    ecc                    32768  1 ecdh_generic
  5177    crct10dif_ce           16384  1
  5178    meson_vdec             86016  0
  5179    rfkill                 36864  5 bluetooth,cfg80211
  5180    lima                   45056  0
  5181    gpu_sched              28672  1 lima
  5182    v4l2_mem2mem           40960  1 meson_vdec
  5183    dw_hdmi_cec            16384  0
  5184    videobuf2_dma_contig    24576  1 meson_vdec
  5185    meson_rng              16384  0
  5186    meson_ir               16384  0
  5187    videobuf2_memops       20480  1 videobuf2_dma_contig
  5188    rc_core                61440  2 meson_ir
  5189    videobuf2_v4l2         36864  2 meson_vdec,v4l2_mem2mem
  5190    videobuf2_common       61440  3 meson_vdec,videobuf2_v4l2,v4l2_mem2mem
  5191    ao_cec                 20480  0
  5192    videodev              233472  4 meson_vdec,videobuf2_v4l2,videobuf2_common,v4l2_mem2mem
  5193    mc                     61440  4 videodev,videobuf2_v4l2,videobuf2_common,v4l2_mem2mem
  5194    ip_tables              28672  2 iptable_filter,iptable_nat
  5195    x_tables               40960  13 ip6table_filter,xt_conntrack,iptable_filter,nft_compat,xt_state,xt_tcpudp,xt_addrtype,xt_nat,ip6_tables,ipt_REJECT,ip_tables,xt_MASQUERADE,ip6t_REJECT
  5196    ipv6                  585728  111 bridge,br_netfilter,nf_reject_ipv6
  5197    nf_defrag_ipv6         24576  2 nf_conntrack,ipv6
  5198
  5199    ### Current system health:
  5200
  5201    Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU
  5202    12:39:13:   ---      1.13  27%   1%   1%  24%   0%   0% 62.0°C
  5203    12:39:13:   ---      1.12  29%   3%   0%  25%   0%   0% 61.0°C
  5204    12:39:14:   ---      1.12  30%   3%   0%  25%   0%   0% 61.0°C
  5205    12:39:14:   ---      1.12  29%   2%   0%  26%   0%   0% 61.0°C
  5206    12:39:14:   ---      1.12  29%   2%   0%  25%   0%   1% 61.0°C
  5207    12:39:15:   ---      1.12  27%   1%   1%  24%   0%   0% 63.0°C
  5208    12:39:17:   ---      1.12  99%   2%  76%  19%   0%   0% 66.0°C
  5209    12:39:18:   ---      1.12  99%   0%  75%  23%   0%   0% 66.0°C
  5210    12:39:18:   ---      1.12  30%   3%   0%  25%   0%   0% 63.0°C
  5211    12:39:19:   ---      1.11  43%  11%   5%  25%   0%   1% 63.0°C
  5212
  5213    ### resolv.conf
  5214
  5215    -rw-r--r-- 1 root root 93 mar 25 08:29 /etc/resolv.conf
  5216    # Generated by NetworkManager
  5217    search lan
  5218    nameserver XXX.XXX.1.1
  5219    nameserver fde6:471f:148a::1
  5220
  5221    ### Current sysinfo:
  5222
  5223    Linux 5.5.0-rc6-aml-s9xxx (mxqpro)     25/03/21     _aarch64_    (4 CPU)
  5224
  5225    avg-cpu:  %user   %nice %system %iowait  %steal   %idle
  5226               1,29   24,57    1,83    0,05    0,00   72,26
  5227
  5228    Device             tps    kB_read/s    kB_wrtn/s    kB_read    kB_wrtn
  5229    ram0              0,00         0,00         0,00          0          0
  5230    ram1              0,00         0,00         0,00          0          0
  5231    ram2              0,00         0,00         0,00          0          0
  5232    ram3              0,00         0,00         0,00          0          0
  5233    ram4              0,00         0,00         0,00          0          0
  5234    ram5              0,00         0,00         0,00          0          0
  5235    ram6              0,00         0,00         0,00          0          0
  5236    ram7              0,00         0,00         0,00          0          0
  5237    ram8              0,00         0,00         0,00          0          0
  5238    ram9              0,00         0,00         0,00          0          0
  5239    ram10             0,00         0,00         0,00          0          0
  5240    ram11             0,00         0,00         0,00          0          0
  5241    ram12             0,00         0,00         0,00          0          0
  5242    ram13             0,00         0,00         0,00          0          0
  5243    ram14             0,00         0,00         0,00          0          0
  5244    ram15             0,00         0,00         0,00          0          0
  5245    mmcblk0           1,92        91,64         4,88    1373515      73123
  5246    mmcblk0p1         0,01         0,40         0,00       6034          3
  5247    mmcblk0p2         1,89        91,03         4,88    1364333      73120
  5248    mmcblk1           0,02         0,35         0,00       5216          0
  5249    mmcblk1gp0        0,01         0,04         0,00        592          0
  5250    mmcblk1boot1      0,01         0,03         0,00        456          0
  5251    mmcblk1boot0      0,01         0,03         0,00        456          0
  5252    zram0             0,00         0,00         0,00          0          0
  5253    zram1            36,50        69,76        76,25    1045512    1142804
  5254    zram2             0,00         0,00         0,00          0          0
  5255
  5256    procs -----------------------memory---------------------- ---swap-- -----io---- -system-- --------cpu--------
  5257     r  b         swpd         free         buff        cache   si   so    bi    bo   in   cs  us  sy  id  wa  st
  5258     2  0        42240       125292        41252       809384   17   19    23     1  238  257  26   2  72   0   0
  5259
  5260                  total        used        free      shared  buff/cache   available
  5261    Mem:          1,7Gi       788Mi       122Mi        19Mi       830Mi       922Mi
  5262    Swap:         870Mi        41Mi       829Mi
  5263
  5264    NAME       ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT
  5265    /dev/zram1 lzo         870,6M  41M 13,2M 14,8M       4 [SWAP]
  5266
  5267     12:39:19 up  4:09,  1 user,  load average: 1,11, 1,11, 1,04
  5268
  5269    [    3.386581] mmc0: new high speed SDHC card at address 59b4
  5270    [    3.392576] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
  5271    [    3.398708] mmcblk0: mmc0:59b4 SDU1  29.5 GiB
  5272    [    3.420838]  mmcblk0: p1 p2
  5273    [    3.422850] hid: raw HID events driver (C) Jiri Kosina
  5274    [    3.423311] usbcore: registered new interface driver usbhid
  5275    [    3.428747] usbhid: USB HID core driver
  5276    [    3.432818] platform-mhu c883c404.mailbox: Platform MHU Mailbox registered
  5277    [    3.449810] NET: Registered protocol family 17
  5278    [    3.450093] Key type dns_resolver registered
  5279    [    3.453483] registered taskstats version 1
  5280    [    3.456943] Loading compiled-in X.509 certificates
  5281    [    3.461866] zswap: loaded using pool lzo/zbud
  5282    [    3.466146] Key type ._fscrypt registered
  5283    [    3.469948] Key type .fscrypt registered
  5284    [    3.475100] Btrfs loaded, crc32c=crc32c-generic
  5285    [    3.496281] mmc1: new HS200 MMC card at address 0001
  5286    [    3.501282] mmcblk1: mmc1:0001 016G92 14.7 GiB
  5287    [    3.501719] mmcblk1boot0: mmc1:0001 016G92 partition 1 4.00 MiB
  5288    [    3.501972] Key type encrypted registered
  5289    [    3.506485] mmcblk1boot1: mmc1:0001 016G92 partition 2 4.00 MiB
  5290    [    3.516412] mmcblk1gp0: mmc1:0001 016G92 partition 4 8.00 MiB
  5291    [    3.521893] mmcblk1rpmb: mmc1:0001 016G92 partition 3 512 KiB, chardev (243:0)
  5292    [    3.529751] meson-drm d0100000.vpu: Queued 3 outputs on vpu
  5293    [    3.534814] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
  5294    [    3.540845] [drm] No driver support for vblank timestamp query.
  5295    [    3.574586] meson-dw-hdmi c883a000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
  5296    [    3.579242] meson-dw-hdmi c883a000.hdmi-tx: registered DesignWare HDMI I2C bus driver
  5297    [    3.587261] meson-drm d0100000.vpu: bound c883a000.hdmi-tx (ops meson_dw_hdmi_ops)
  5298    [    3.594608] [drm] Initialized meson 1.0.0 20161109 for d0100000.vpu on minor 0
  5299    [    3.630094] Console: switching to colour frame buffer device 90x36
  5300    [    3.650314] meson-drm d0100000.vpu: fb0: mesondrmfb frame buffer device
  5301    [    3.657576] libphy: mdio_mux: probed
  5302    [    3.668137] libphy: mdio_mux: probed
  5303    [    3.668622] phy phy-d0078080.phy.2: unsupported PHY mode 5
  5304    [    3.673649] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  5305    [    3.677062] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
  5306    [    3.684768] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228f664 hci version 0x100 quirks 0x0000000002010010
  5307    [    3.693998] xhci-hcd xhci-hcd.0.auto: irq 39, io mem 0xc9000000
  5308    [    3.700098] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.05
  5309    [    3.708441] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  5310    [    3.715591] usb usb1: Product: xHCI Host Controller
  5311    [    3.720419] usb usb1: Manufacturer: Linux 5.5.0-rc6-aml-s9xxx xhci-hcd
  5312    [    3.726887] usb usb1: SerialNumber: xhci-hcd.0.auto
  5313    [    3.732245] hub 1-0:1.0: USB hub found
  5314    [    3.735462] hub 1-0:1.0: 2 ports detected
  5315    [    3.739681] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  5316    [    3.744847] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
  5317    [    3.752437] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
  5318    [    3.758938] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
  5319    [    3.767192] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.05
  5320    [    3.775570] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  5321    [    3.782726] usb usb2: Product: xHCI Host Controller
  5322    [    3.787555] usb usb2: Manufacturer: Linux 5.5.0-rc6-aml-s9xxx xhci-hcd
  5323    [    3.794024] usb usb2: SerialNumber: xhci-hcd.0.auto
  5324    [    3.799320] hub 2-0:1.0: USB hub found
  5325    [    3.802602] hub 2-0:1.0: config failed, hub doesn't have any ports! (err -19)
  5326    [    3.811539] meson-gx-mmc d0070000.mmc: allocated mmc-pwrseq
  5327    [    3.842657] scpi_protocol scpi: SCP Protocol legacy pre-1.0 firmware
  5328    [    3.860111] gx-sound-card sound: snd-soc-dummy-dai <-> c1105400.bus:audio-controller-0 mapping ok
  5329    [    3.869332] gx-sound-card sound: i2s-hifi <-> c1105400.bus:audio-controller-2 mapping ok
  5330    [    3.877017] gx-sound-card sound: ASoC: no DMI vendor name!
  5331    [    3.883196] printk: console [netcon0] enabled
  5332    [    3.886653] netconsole: network logging started
  5333    [    3.891215] hctosys: unable to open rtc device (rtc0)
  5334    [    3.896449] ALSA device list:
  5335    [    3.899588]   #0: AMLGX
  5336    [    3.903113] Freeing unused kernel memory: 960K
  5337    [    3.906194] Run /init as init process
  5338    [    3.906862] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
  5339    [    3.918736] mmc2: queuing unknown CIS tuple 0x80 (6 bytes)
  5340    [    3.925288] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
  5341    [    3.937311] mmc2: queuing unknown CIS tuple 0x80 (19 bytes)
  5342    [    3.964376] random: fast init done
  5343    [    4.022156] mmc2: new high speed SDIO card at address 0001
  5344    [    4.078608] usb 1-1: new high-speed USB device number 2 using xhci-hcd
  5345    [    4.100400] usb 1-1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.36
  5346    [    4.107205] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
  5347    [    4.114252] usb 1-1: Product: USB2.0 Hub
  5348    [    4.175438] hub 1-1:1.0: USB hub found
  5349    [    4.177914] hub 1-1:1.0: 4 ports detected
  5350    [    4.310606] usb 1-2: new high-speed USB device number 3 using xhci-hcd
  5351    [    4.341180] usb 1-2: New USB device found, idVendor=148f, idProduct=7601, bcdDevice= 0.00
  5352    [    4.348015] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
  5353    [    4.355977] usb 1-2: Product: 802.11 n WLAN
  5354    [    4.359219] usb 1-2: Manufacturer: MediaTek
  5355    [    4.363298] usb 1-2: SerialNumber: 1.0
  5356    [    5.040612] EXT4-fs (mmcblk0p2): mounted filesystem with writeback data mode. Opts: data=writeback
  5357    [    5.995866] systemd[1]: System time before build time, advancing clock.
  5358    [    6.149780] NET: Registered protocol family 10
  5359    [    6.221058] Segment Routing with IPv6
  5360    [    6.272439] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
  5361    [    6.308765] systemd[1]: Detected architecture arm64.
  5362    [    6.360408] systemd[1]: Set hostname to <mxqpro>.
  5363    [    6.392837] systemd[1]: Couldn't move remaining userspace processes, ignoring: Input/output error
  5364    [    7.078770] random: systemd: uninitialized urandom read (16 bytes read)
  5365    [    7.091350] random: systemd: uninitialized urandom read (16 bytes read)
  5366    [    7.099361] systemd[1]: Created slice system-systemd-fsck.slice.
  5367    [    7.105688] random: systemd: uninitialized urandom read (16 bytes read)
  5368    [    7.109844] systemd[1]: Listening on Journal Socket.
  5369    [    7.121041] systemd[1]: Mounting Kernel Debug File System...
  5370    [    7.128262] systemd[1]: Created slice system-serial-getty.slice.
  5371    [    7.138153] systemd[1]: Starting Nameserver information manager...
  5372    [    7.144520] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
  5373    [    7.325631] EXT4-fs (mmcblk0p2): re-mounted. Opts: commit=600,errors=remount-ro
  5374    [    7.596933] systemd-journald[414]: Received request to flush runtime journal from PID 1
  5375    [    8.082747] mc: Linux media interface: v0.10
  5376    [    8.109912] videodev: Linux video capture interface: v2.00
  5377    [    8.134829] Registered IR keymap rc-empty
  5378    [    8.136908] rc rc0: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0
  5379    [    8.143380] input: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0/input0
  5380    [    8.150768] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
  5381    [    8.166190] meson-ir c8100580.ir: receiver initialized
  5382    [    8.231729] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
  5383    [    8.246786] lima d00c0000.gpu: IRQ ppmmu3 not found
  5384    [    8.249267] lima d00c0000.gpu: IRQ ppmmu4 not found
  5385    [    8.262760] lima d00c0000.gpu: IRQ ppmmu5 not found
  5386    [    8.265124] lima d00c0000.gpu: IRQ ppmmu6 not found
  5387    [    8.276242] lima d00c0000.gpu: IRQ ppmmu7 not found
  5388    [    8.281140] lima d00c0000.gpu: gp - mali450 version major 0 minor 0
  5389    [    8.289232] lima d00c0000.gpu: pp0 - mali450 version major 0 minor 0
  5390    [    8.292584] lima d00c0000.gpu: pp1 - mali450 version major 0 minor 0
  5391    [    8.301737] lima d00c0000.gpu: pp2 - mali450 version major 0 minor 0
  5392    [    8.306700] lima d00c0000.gpu: IRQ pp3 not found
  5393    [    8.309479] lima d00c0000.gpu: IRQ pp4 not found
  5394    [    8.317008] lima d00c0000.gpu: IRQ pp5 not found
  5395    [    8.320573] lima d00c0000.gpu: IRQ pp6 not found
  5396    [    8.324550] lima d00c0000.gpu: IRQ pp7 not found
  5397    [    8.329196] lima d00c0000.gpu: l2 cache 8K, 4-way, 64byte cache line, 128bit external bus
  5398    [    8.337366] lima d00c0000.gpu: l2 cache 64K, 4-way, 64byte cache line, 128bit external bus
  5399    [    8.347139] lima d00c0000.gpu: bus rate = 166666667
  5400    [    8.349365] lima d00c0000.gpu: mod rate = 744000000
  5401    [    8.356470] [drm] Initialized lima 1.0.0 20190217 for d00c0000.gpu on minor 1
  5402    [    8.447229] Bluetooth: Core ver 2.22
  5403    [    8.449868] NET: Registered protocol family 31
  5404    [    8.451911] Bluetooth: HCI device and connection manager initialized
  5405    [    8.458128] Bluetooth: HCI socket layer initialized
  5406    [    8.462854] Bluetooth: L2CAP socket layer initialized
  5407    [    8.467896] Bluetooth: SCO socket layer initialized
  5408    [    8.520770] cfg80211: Loading compiled-in X.509 certificates for regulatory database
  5409    [    8.556595] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
  5410    [    8.561226] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
  5411    [    8.568938] cfg80211: failed to load regulatory.db
  5412    [    8.694760] Bluetooth: HCI UART driver ver 2.3
  5413    [    8.697128] Bluetooth: HCI UART protocol H4 registered
  5414    [    8.700667] brcmfmac: F1 signature read @0x18000000=0x16034334
  5415    [    8.706070] Bluetooth: HCI UART protocol BCSP registered
  5416    [    8.708106] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4334-sdio for chip BCM4334/3
  5417    [    8.708403] Bluetooth: HCI UART protocol LL registered
  5418    [    8.716487] usbcore: registered new interface driver brcmfmac
  5419    [    8.721404] Bluetooth: HCI UART protocol ATH3K registered
  5420    [    8.736563] Bluetooth: HCI UART protocol Three-wire (H5) registered
  5421    [    8.739900] Bluetooth: HCI UART protocol Intel registered
  5422    [    8.745480] hci_uart_bcm serial0-0: serial0-0 supply vbat not found, using dummy regulator
  5423    [    8.753237] hci_uart_bcm serial0-0: serial0-0 supply vddio not found, using dummy regulator
  5424    [    8.761540] Bluetooth: HCI UART protocol Broadcom registered
  5425    [    8.767107] Bluetooth: HCI UART protocol QCA registered
  5426    [    8.772212] Bluetooth: HCI UART protocol AG6XX registered
  5427    [    8.777638] Bluetooth: HCI UART protocol Marvell registered
  5428    [    8.827167] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.amlogic,p212.txt failed with error -2
  5429    [    8.827232] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.txt failed with error -2
  5430    [    8.862911] usb 1-2: reset high-speed USB device number 3 using xhci-hcd
  5431    [    8.893347] mt7601u 1-2:1.0: ASIC revision: 76010001 MAC revision: 76010500
  5432    [    8.919367] mt7601u 1-2:1.0: EEPROM ver:0d fae:00
  5433    [    9.130069] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
  5434    [    9.132833] usbcore: registered new interface driver mt7601u
  5435    [    9.147542] Bluetooth: hci0: BCM: chip id 68
  5436    [    9.150833] Bluetooth: hci0: BCM: features 0x0f
  5437    [    9.158784] Bluetooth: hci0: BCM4334B0
  5438    [    9.163806] Bluetooth: hci0: BCM4334B0 (002.001.013) build 0000
  5439    [    9.167835] bluetooth hci0: Direct firmware load for brcm/BCM4334B0.hcd failed with error -2
  5440    [    9.177450] Bluetooth: hci0: BCM: Patch brcm/BCM4334B0.hcd not found
  5441    [    9.830624] brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x50
  5442    [    9.886451] zram: Added device: zram0
  5443    [    9.891176] zram: Added device: zram1
  5444    [    9.894404] zram: Added device: zram2
  5445    [    9.925547] meson8b-dwmac c9410000.ethernet eth0: PHY [0.e40908ff:08] driver [Meson GXL Internal PHY]
  5446    [    9.945386] zram1: detected capacity change from 0 to 912879616
  5447    [    9.950673] meson8b-dwmac c9410000.ethernet eth0: No Safety Features support found
  5448    [    9.957268] meson8b-dwmac c9410000.ethernet eth0: PTP not supported by HW
  5449    [    9.962462] meson8b-dwmac c9410000.ethernet eth0: configuring for phy/rmii link mode
  5450    [   10.586495] random: crng init done
  5451    [   10.588901] random: 7 urandom warning(s) missed due to ratelimiting
  5452    [   10.790775] Adding 891480k swap on /dev/zram1.  Priority:5 extents:1 across:891480k SSFS
  5453    [   12.136732] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
  5454    [   12.138728] Bluetooth: BNEP filters: protocol multicast
  5455    [   12.143569] Bluetooth: BNEP socket layer initialized
  5456    [   16.825508] wlan0: authenticate with 9c:9d:7e:12:20:57
  5457    [   16.848850] wlan0: send auth to 9c:9d:7e:12:20:57 (try 1/3)
  5458    [   16.853918] wlan0: authenticated
  5459    [   16.862528] wlan0: associate with 9c:9d:7e:12:20:57 (try 1/3)
  5460    [   16.870609] wlan0: RX AssocResp from 9c:9d:7e:12:20:57 (capab=0x431 status=0 aid=1)
  5461    [   16.901632] wlan0: associated
  5462    [   16.914204] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
  5463    [   21.562400] rc rc0: two consecutive events of type space
  5464    [   26.095659] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
  5465    [   26.111368] Bridge firewalling registered
  5466    [   26.708674] Initializing XFRM netlink socket
  5467    [   32.179898] overlayfs: NFS export requires "index=on", falling back to nfs_export=off.
  5468    [   32.305394] overlayfs: NFS export requires "index=on", falling back to nfs_export=off.
  5469    [   32.408250] overlayfs: NFS export requires "index=on", falling back to nfs_export=off.
  5470    [   32.435578] docker0: port 1(veth7774459) entered blocking state
  5471    [   32.439498] docker0: port 1(veth7774459) entered disabled state
  5472    [   32.445453] device veth7774459 entered promiscuous mode
  5473    [   33.882831] eth0: renamed from veth73c0ffb
  5474    [   33.914547] IPv6: ADDRCONF(NETDEV_CHANGE): veth7774459: link becomes ready
  5475    [   33.918938] docker0: port 1(veth7774459) entered blocking state
  5476    [   33.924651] docker0: port 1(veth7774459) entered forwarding state
  5477    [   33.930994] IPv6: ADDRCONF(NETDEV_CHANGE): docker0: link becomes ready
  5478    [   38.958397] bpfilter: Loaded bpfilter_umh pid 2101
  5479    [   41.975717] tun: Universal TUN/TAP device driver, 1.6
  5480    [   42.832779] br-d68f2303413d: port 1(vethbb873ae) entered blocking state
  5481    [   42.838047] br-d68f2303413d: port 1(vethbb873ae) entered disabled state
  5482    [   42.843521] device vethbb873ae entered promiscuous mode
  5483    [   42.849349] br-d68f2303413d: port 1(vethbb873ae) entered blocking state
  5484    [   42.854842] br-d68f2303413d: port 1(vethbb873ae) entered forwarding state
  5485    [   42.864886] br-d68f2303413d: port 1(vethbb873ae) entered disabled state
  5486    [   42.899230] br-d68f2303413d: port 2(veth03c84e8) entered blocking state
  5487    [   42.904982] br-d68f2303413d: port 2(veth03c84e8) entered disabled state
  5488    [   42.910620] device veth03c84e8 entered promiscuous mode
  5489    [   42.916878] br-d68f2303413d: port 2(veth03c84e8) entered blocking state
  5490    [   42.921124] br-d68f2303413d: port 2(veth03c84e8) entered forwarding state
  5491    [   42.930733] br-d68f2303413d: port 2(veth03c84e8) entered disabled state
  5492    [   43.392604] supervisor0: port 1(vethc9f5b57) entered blocking state
  5493    [   43.397261] supervisor0: port 1(vethc9f5b57) entered disabled state
  5494    [   43.402873] device vethc9f5b57 entered promiscuous mode
  5495    [   43.409622] supervisor0: port 1(vethc9f5b57) entered blocking state
  5496    [   43.413068] supervisor0: port 1(vethc9f5b57) entered forwarding state
  5497    [   43.421438] supervisor0: port 1(vethc9f5b57) entered disabled state
  5498    [   43.743084] kmem.limit_in_bytes is deprecated and will be removed. Please report your usecase to linux-mm@kvack.org if you depend on this functionality.
  5499    [   43.907714] eth0: renamed from veth06c1be1
  5500    [   43.938421] br-d68f2303413d: port 1(vethbb873ae) entered blocking state
  5501    [   43.941607] br-d68f2303413d: port 1(vethbb873ae) entered forwarding state
  5502    [   44.170855] eth0: renamed from veth9e3845e
  5503    [   44.202186] br-d68f2303413d: port 2(veth03c84e8) entered blocking state
  5504    [   44.205412] br-d68f2303413d: port 2(veth03c84e8) entered forwarding state
  5505    [   44.258557] eth1: renamed from vetha0e69f6
  5506    [   44.286490] supervisor0: port 1(vethc9f5b57) entered blocking state
  5507    [   44.289455] supervisor0: port 1(vethc9f5b57) entered forwarding state
  5508    [   56.613270] br-d68f2303413d: port 3(veth0d502f2) entered blocking state
  5509    [   56.614449] br-d68f2303413d: port 3(veth0d502f2) entered disabled state
  5510    [   56.622802] device veth0d502f2 entered promiscuous mode
  5511    [   57.610501] eth0: renamed from veth24e07be
  5512    [   57.637964] br-d68f2303413d: port 3(veth0d502f2) entered blocking state
  5513    [   57.639079] br-d68f2303413d: port 3(veth0d502f2) entered forwarding state
  5514    [   58.426654] br-d68f2303413d: port 3(veth0d502f2) entered disabled state
  5515    [   58.428322] veth24e07be: renamed from eth0
  5516    [   58.531976] br-d68f2303413d: port 3(veth0d502f2) entered disabled state
  5517    [   58.535813] device veth0d502f2 left promiscuous mode
  5518    [   58.544026] br-d68f2303413d: port 3(veth0d502f2) entered disabled state
  5519
  5520
  5521    vm.admin_reserve_kbytes = 8192
  5522    vm.block_dump = 0
  5523    vm.compact_unevictable_allowed = 1
  5524    vm.dirty_background_bytes = 0
  5525    vm.dirty_background_ratio = 10
  5526    vm.dirty_bytes = 0
  5527    vm.dirty_expire_centisecs = 3000
  5528    vm.dirty_ratio = 20
  5529    vm.dirtytime_expire_seconds = 43200
  5530    vm.dirty_writeback_centisecs = 500
  5531    vm.extfrag_threshold = 500
  5532    vm.hugetlb_shm_group = 0
  5533    vm.laptop_mode = 0
  5534    vm.legacy_va_layout = 0
  5535    vm.lowmem_reserve_ratio = 256    256    32    0
  5536    vm.max_map_count = 65530
  5537    vm.min_free_kbytes = 4914
  5538    vm.mmap_min_addr = 4096
  5539    vm.nr_hugepages = 0
  5540    vm.nr_overcommit_hugepages = 0
  5541    vm.oom_dump_tasks = 1
  5542    vm.oom_kill_allocating_task = 0
  5543    vm.overcommit_kbytes = 0
  5544    vm.overcommit_memory = 0
  5545    vm.overcommit_ratio = 50
  5546    vm.page-cluster = 0
  5547    vm.panic_on_oom = 0
  5548    vm.percpu_pagelist_fraction = 0
  5549    vm.stat_interval = 1
  5550    vm.swappiness = 100
  5551    vm.user_reserve_kbytes = 55239
  5552    vm.vfs_cache_pressure = 100
  5553    vm.watermark_boost_factor = 15000
  5554    vm.watermark_scale_factor = 10
  5555
  5556    ### interrupts:
  5557               CPU0       CPU1       CPU2       CPU3
  5558      3:    1254321    2410573    2447602    1517135     GICv2  30 Level     arch_timer
  5559      6:          0          0          0          0     GICv2 169 Level     arm-pmu
  5560      7:          0          0          0          0     GICv2 170 Level     arm-pmu
  5561      8:          0          0          0          0     GICv2 185 Level     arm-pmu
  5562      9:          0          0          0          0     GICv2 186 Level     arm-pmu
  5563     10:       1181          0          0          0     GICv2  58 Edge      ttyAML6
  5564     11:          7          0          0          0     GICv2 105 Edge      c1108680.adc
  5565     12:          0          0          0          0     GICv2 231 Edge      c8100100.cec
  5566     13:        126          0          0          0     GICv2 225 Edge      ttyAML0
  5567     14:        230          0          0          0     GICv2 228 Edge      c8100580.ir
  5568     15:          0          0          0          0     GICv2  76 Edge      vdec
  5569     16:          0          0          0          0     GICv2  64 Edge      esparserirq
  5570     18:       4903          0          0          0     GICv2 241 Edge      platform_mhu_link
  5571     19:        627          0          0          0     GICv2 242 Edge      platform_mhu_link
  5572     20:          0          0          0          0     GICv2  40 Level     eth0
  5573     21:        723          0          0          0     GICv2 248 Edge      d0070000.mmc
  5574     22:      79456          0          0          0     GICv2 249 Edge      d0072000.mmc
  5575     23:       1598          0          0          0     GICv2 250 Edge      d0074000.mmc
  5576     25:          0          0          0          0     GICv2 192 Level     gp
  5577     26:          0          0          0          0     GICv2 193 Level     gpmmu
  5578     27:          0          0          0          0     GICv2 194 Level     pp_bcast
  5579     29:          0          0          0          0     GICv2 196 Level     pp0
  5580     30:          0          0          0          0     GICv2 197 Level     ppmmu0
  5581     31:          0          0          0          0     GICv2 198 Level     pp1
  5582     32:          0          0          0          0     GICv2 199 Level     ppmmu1
  5583     33:          0          0          0          0     GICv2 200 Level     pp2
  5584     34:          0          0          0          0     GICv2 201 Level     ppmmu2
  5585     35:       1037          0          0          0     GICv2  35 Edge      meson
  5586     36:          0          0          0          0     GICv2  89 Edge      dw_hdmi_top_irq, c883a000.hdmi-tx, dw-hdmi-cec
  5587     37:          0          0          0          0     GICv2 220 Edge      gxl-crypto
  5588     38:          0          0          0          0     GICv2 221 Edge      gxl-crypto
  5589     39:    2572248          0          0          0     GICv2  62 Level     xhci-hcd:usb1
  5590     42:          0          0          0          0     GICv2  41 Level     0.e40908ff:08
  5591    IPI0:    924290     907592     915848    1179209       Rescheduling interrupts
  5592    IPI1:       863        740        676        840       Function call interrupts
  5593    IPI2:         0          0          0          0       CPU stop interrupts
  5594    IPI3:         0          0          0          0       CPU stop (for crash dump) interrupts
  5595    IPI4:         0          0          0          0       Timer broadcast interrupts
  5596    IPI5:      2307       1722       2600       1567       IRQ work interrupts
  5597    IPI6:         0          0          0          0       CPU wake-up interrupts
  5598    Err:          0
Please upload the whole output above to an online pasteboard service
and provide the URL in the forum where you have been asked for this.
Thanks in advance.
OK, following with info found in the forum.
Using info from this post above to create my own dtb file:
and using info from this other post above, to change from 256MB (0x10000000) to 32MB (0x2000000)
After create the new dtb I changed the path in uEnv.txt to point to new one.
After reboot everythig looks the same. This is the output from armbianmonitor -U:
Spoiler
     1
     2    ### Activated 1 lzo zram swap devices with 870 MB each
     3
     4
     5    dom mar 21 00:17:31 CET 2021 | AML-S9xxx | 20.02.0-rc1.037 | arm64 | aarch64 | 5.5.0-rc6-aml-s9xxx
     6
     7    ### dmesg:
     8
     9    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
    10    [    0.000000] Linux version 5.5.0-rc6-aml-s9xxx (root@vbox) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #rc1.037 SMP PREEMPT Wed Feb 5 15:59:04 MSK 2020
    11    [    0.000000] Machine model: Amlogic Meson GXL (S905X) P212 Development Board
    12    [    0.000000] efi: Getting EFI parameters from FDT:
    13    [    0.000000] efi: UEFI not found.
    14    [    0.000000] Reserved memory: created CMA memory pool at 0x0000000063400000, size 256 MiB
    15    [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
    16    [    0.000000] On node 0 totalpages: 477952
    17    [    0.000000]   DMA zone: 4032 pages used for memmap
    18    [    0.000000]   DMA zone: 0 pages reserved
    19    [    0.000000]   DMA zone: 248576 pages, LIFO batch:63
    20    [    0.000000]   DMA32 zone: 3584 pages used for memmap
    21    [    0.000000]   DMA32 zone: 229376 pages, LIFO batch:63
    22    [    0.000000] psci: probing for conduit method from DT.
    23    [    0.000000] psci: PSCIv0.2 detected in firmware.
    24    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    25    [    0.000000] psci: Trusted OS migration not required
    26    [    0.000000] percpu: Embedded 22 pages/cpu s50392 r8192 d31528 u90112
    27    [    0.000000] pcpu-alloc: s50392 r8192 d31528 u90112 alloc=22*4096
    28    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
    29    [    0.000000] Detected VIPT I-cache on CPU0
    30    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 470336
    31    [    0.000000] Kernel command line: root=LABEL=ROOTFS rootflags=data=writeback rw console=ttyAML0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 mac=00:df:06:00:00:0b
    32    [    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    33    [    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
    34    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    35    [    0.000000] software IO TLB: mapped [mem 0x3bfff000-0x3ffff000] (64MB)
    36    [    0.000000] Memory: 1509616K/1911808K available (14460K kernel code, 1434K rwdata, 5884K rodata, 960K init, 927K bss, 140048K reserved, 262144K cma-reserved)
    37    [    0.000000] random: get_random_u64 called from cache_random_seq_create+0x7c/0x150 with crng_init=0
    38    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    39    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    40    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
    41    [    0.000000]     Tasks RCU enabled.
    42    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    43    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
    44    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    45    [    0.000000] GIC: Using split EOI/Deactivate mode
    46    [    0.000000] irq_meson_gpio: 110 to 8 gpio interrupt mux initialized
    47    [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
    48    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
    49    [    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
    50    [    0.000357] Console: colour dummy device 80x25
    51    [    0.000658] printk: console [tty0] enabled
    52    [    0.000698] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
    53    [    0.000719] pid_max: default: 32768 minimum: 301
    54    [    0.000843] LSM: Security Framework initializing
    55    [    0.000893] SELinux:  Initializing.
    56    [    0.000973] *** VALIDATE SELinux ***
    57    [    0.001041] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    58    [    0.001067] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    59    [    0.001130] *** VALIDATE tmpfs ***
    60    [    0.001535] *** VALIDATE proc ***
    61    [    0.001762] *** VALIDATE cgroup1 ***
    62    [    0.001776] *** VALIDATE cgroup2 ***
    63    [    0.024017] ASID allocator initialised with 32768 entries
    64    [    0.031999] rcu: Hierarchical SRCU implementation.
    65    [    0.042087] EFI services will not be available.
    66    [    0.048056] smp: Bringing up secondary CPUs ...
    67    [    0.080283] Detected VIPT I-cache on CPU1
    68    [    0.080336] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    69    [    0.112323] Detected VIPT I-cache on CPU2
    70    [    0.112367] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
    71    [    0.144371] Detected VIPT I-cache on CPU3
    72    [    0.144414] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
    73    [    0.144488] smp: Brought up 1 node, 4 CPUs
    74    [    0.144556] SMP: Total of 4 processors activated.
    75    [    0.144567] CPU features: detected: 32-bit EL0 Support
    76    [    0.144579] CPU features: detected: CRC32 instructions
    77    [    0.144883] CPU: All CPU(s) started at EL2
    78    [    0.144906] alternatives: patching kernel code
    79    [    0.146005] devtmpfs: initialized
    80    [    0.151132] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    81    [    0.151173] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
    82    [    0.158028] xor: measuring software checksum speed
    83    [    0.196372]    8regs     :  2375.000 MB/sec
    84    [    0.236403]    32regs    :  2724.000 MB/sec
    85    [    0.276440]    arm64_neon:  2406.000 MB/sec
    86    [    0.276451] xor: using function: 32regs (2724.000 MB/sec)
    87    [    0.276506] pinctrl core: initialized pinctrl subsystem
    88    [    0.277171] thermal_sys: Registered thermal governor 'step_wise'
    89    [    0.277344] DMI not present or invalid.
    90    [    0.277704] NET: Registered protocol family 16
    91    [    0.281247] DMA: preallocated 256 KiB pool for atomic allocations
    92    [    0.281298] audit: initializing netlink subsys (disabled)
    93    [    0.281510] audit: type=2000 audit(0.280:1): state=initialized audit_enabled=0 res=1
    94    [    0.282595] cpuidle: using governor ladder
    95    [    0.282635] cpuidle: using governor menu
    96    [    0.283005] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    97    [    0.283728] Serial: AMBA PL011 UART driver
    98    [    0.297742] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
    99    [    0.297768] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
   100    [    0.297782] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
   101    [    0.297794] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
   102    [    0.301475] cryptd: max_cpu_qlen set to 1000
   103    [    0.376663] raid6: neonx8   gen()  1620 MB/s
   104    [    0.444705] raid6: neonx8   xor()  1505 MB/s
   105    [    0.512768] raid6: neonx4   gen()  1564 MB/s
   106    [    0.580822] raid6: neonx4   xor()  1471 MB/s
   107    [    0.648903] raid6: neonx2   gen()  1199 MB/s
   108    [    0.716957] raid6: neonx2   xor()  1217 MB/s
   109    [    0.785006] raid6: neonx1   gen()   786 MB/s
   110    [    0.853091] raid6: neonx1   xor()   915 MB/s
   111    [    0.921101] raid6: int64x8  gen()  1194 MB/s
   112    [    0.989168] raid6: int64x8  xor()   769 MB/s
   113    [    1.057245] raid6: int64x4  gen()  1029 MB/s
   114    [    1.125290] raid6: int64x4  xor()   752 MB/s
   115    [    1.193323] raid6: int64x2  gen()   728 MB/s
   116    [    1.261407] raid6: int64x2  xor()   615 MB/s
   117    [    1.329515] raid6: int64x1  gen()   486 MB/s
   118    [    1.397467] raid6: int64x1  xor()   468 MB/s
   119    [    1.397477] raid6: using algorithm neonx8 gen() 1620 MB/s
   120    [    1.397487] raid6: .... xor() 1505 MB/s, rmw enabled
   121    [    1.397498] raid6: using neon recovery algorithm
   122    [    1.397743] ACPI: Interpreter disabled.
   123    [    1.398940] iommu: Default domain type: Translated
   124    [    1.399209] vgaarb: loaded
   125    [    1.399757] SCSI subsystem initialized
   126    [    1.399934] libata version 3.00 loaded.
   127    [    1.400144] usbcore: registered new interface driver usbfs
   128    [    1.400192] usbcore: registered new interface driver hub
   129    [    1.400255] usbcore: registered new device driver usb
   130    [    1.400657] pps_core: LinuxPPS API ver. 1 registered
   131    [    1.400670] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
   132    [    1.400696] PTP clock support registered
   133    [    1.400724] EDAC MC: Ver: 3.0.0
   134    [    1.401299] FPGA manager framework
   135    [    1.401422] Advanced Linux Sound Architecture Driver Initialized.
   136    [    1.401892] NetLabel: Initializing
   137    [    1.401904] NetLabel:  domain hash size = 128
   138    [    1.401913] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
   139    [    1.401967] NetLabel:  unlabeled traffic allowed by default
   140    [    1.402449] clocksource: Switched to clocksource arch_sys_counter
   141    [    1.402471] *** VALIDATE bpf ***
   142    [    1.402725] VFS: Disk quotas dquot_6.6.0
   143    [    1.402785] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
   144    [    1.402914] FS-Cache: Loaded
   145    [    1.402924] *** VALIDATE ramfs ***
   146    [    1.402945] *** VALIDATE hugetlbfs ***
   147    [    1.403322] pnp: PnP ACPI: disabled
   148    [    1.408351] NET: Registered protocol family 2
   149    [    1.408850] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
   150    [    1.408895] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
   151    [    1.409012] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
   152    [    1.409232] TCP: Hash tables configured (established 16384 bind 16384)
   153    [    1.409392] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
   154    [    1.409444] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
   155    [    1.409668] NET: Registered protocol family 1
   156    [    1.410112] RPC: Registered named UNIX socket transport module.
   157    [    1.410133] RPC: Registered udp transport module.
   158    [    1.410143] RPC: Registered tcp transport module.
   159    [    1.410152] RPC: Registered tcp NFSv4.1 backchannel transport module.
   160    [    1.410168] NET: Registered protocol family 44
   161    [    1.410189] PCI: CLS 0 bytes, default 64
   162    [    1.410384] Trying to unpack rootfs image as initramfs...
   163    [    1.871991] Freeing initrd memory: 10248K
   164    [    1.872788] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
   165    [    2.086160] Initialise system trusted keyrings
   166    [    2.086373] workingset: timestamp_bits=46 max_order=19 bucket_order=0
   167    [    2.091523] zbud: loaded
   168    [    2.092745] squashfs: version 4.0 (2009/01/31) Phillip Lougher
   169    [    2.093051] FS-Cache: Netfs 'nfs' registered for caching
   170    [    2.093577] NFS: Registering the id_resolver key type
   171    [    2.093613] Key type id_resolver registered
   172    [    2.093623] Key type id_legacy registered
   173    [    2.093640] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
   174    [    2.093652] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
   175    [    2.094834] FS-Cache: Netfs 'cifs' registered for caching
   176    [    2.095176] Key type cifs.spnego registered
   177    [    2.095199] Key type cifs.idmap registered
   178    [    2.095223] ntfs: driver 2.1.32 [Flags: R/W].
   179    [    2.095810] JFS: nTxBlock = 8192, nTxLock = 65536
   180    [    2.101758] SGI XFS with ACLs, security attributes, realtime, quota, no debug enabled
   181    [    2.103205] *** VALIDATE xfs ***
   182    [    2.103493] ocfs2: Registered cluster interface o2cb
   183    [    2.103717] OCFS2 User DLM kernel interface loaded
   184    [    2.105117] *** VALIDATE gfs2 ***
   185    [    2.105401] gfs2: GFS2 installed
   186    [    2.106305] aufs 5.5-20200203
   187    [    2.127122] Key type asymmetric registered
   188    [    2.127147] Asymmetric key parser 'x509' registered
   189    [    2.127157] Asymmetric key parser 'pkcs8' registered
   190    [    2.127228] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
   191    [    2.127431] io scheduler mq-deadline registered
   192    [    2.127446] io scheduler kyber registered
   193    [    2.127639] io scheduler bfq registered
   194    [    2.140178] soc soc0: Amlogic Meson GXL (S905X) Revision 21:b (82:2) Detected
   195    [    2.143753] Serial: 8250/16550 driver, 5 ports, IRQ sharing enabled
   196    [    2.145442] Serial: AMBA driver
   197    [    2.145810] c11084c0.serial: ttyAML6 at MMIO 0xc11084c0 (irq = 10, base_baud = 1500000) is a meson_uart
   198    [    2.145963] serial serial0: tty port ttyAML6 registered
   199    [    2.146175] c81004c0.serial: ttyAML0 at MMIO 0xc81004c0 (irq = 13, base_baud = 1500000) is a meson_uart
   200    [    3.121643] printk: console [ttyAML0] enabled
   201    [    3.137733] brd: module loaded
   202    [    3.146278] loop: module loaded
   203    [    3.148724] libphy: Fixed MDIO Bus: probed
   204    [    3.149372] meson8b-dwmac c9410000.ethernet: IRQ eth_wake_irq not found
   205    [    3.154490] meson8b-dwmac c9410000.ethernet: IRQ eth_lpi not found
   206    [    3.160659] meson8b-dwmac c9410000.ethernet: PTP uses main clock
   207    [    3.166503] meson8b-dwmac c9410000.ethernet: no reset control found
   208    [    3.173207] meson8b-dwmac c9410000.ethernet: User ID: 0x11, Synopsys ID: 0x37
   209    [    3.179791] meson8b-dwmac c9410000.ethernet:     DWMAC1000
   210    [    3.184956] meson8b-dwmac c9410000.ethernet: DMA HW capability register supported
   211    [    3.192371] meson8b-dwmac c9410000.ethernet: RX Checksum Offload Engine supported
   212    [    3.199788] meson8b-dwmac c9410000.ethernet: COE Type 2
   213    [    3.204962] meson8b-dwmac c9410000.ethernet: TX Checksum insertion supported
   214    [    3.211949] meson8b-dwmac c9410000.ethernet: Wake-Up On Lan supported
   215    [    3.218362] meson8b-dwmac c9410000.ethernet: Normal descriptors
   216    [    3.224197] meson8b-dwmac c9410000.ethernet: Ring mode enabled
   217    [    3.229975] meson8b-dwmac c9410000.ethernet: Enable RX Mitigation via HW Watchdog Timer
   218    [    3.238093] libphy: stmmac: probed
   219    [    3.242604] VFIO - User Level meta-driver version: 0.3
   220    [    3.247889] dwc3 c9000000.dwc3: Failed to get clk 'ref': -2
   221    [    3.252824] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
   222    [    3.258383] ehci-pci: EHCI PCI platform driver
   223    [    3.262821] ehci-platform: EHCI generic platform driver
   224    [    3.268118] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
   225    [    3.274064] ohci-pci: OHCI PCI platform driver
   226    [    3.278498] ohci-platform: OHCI generic platform driver
   227    [    3.284238] usbcore: registered new interface driver usb-storage
   228    [    3.289806] mousedev: PS/2 mouse device common for all mice
   229    [    3.295758] i2c /dev entries driver
   230    [    3.301360] sdhci: Secure Digital Host Controller Interface driver
   231    [    3.304684] sdhci: Copyright(c) Pierre Ossman
   232    [    3.308998] Synopsys Designware Multimedia Card Interface Driver
   233    [    3.316270] meson-gx-mmc d0072000.mmc: Got CD GPIO
   234    [    3.346815] meson-gx-mmc d0074000.mmc: allocated mmc-pwrseq
   235    [    3.374325] sdhci-pltfm: SDHCI platform and OF driver helper
   236    [    3.375509] ledtrig-cpu: registered to indicate activity on CPUs
   237    [    3.380905] meson-sm: secure-monitor enabled
   238    [    3.385180] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
   239    [    3.386535] mmc0: new high speed SDHC card at address 59b4
   240    [    3.392509] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
   241    [    3.398655] mmcblk0: mmc0:59b4 SDU1  29.5 GiB
   242    [    3.416709]  mmcblk0: p1 p2
   243    [    3.422890] hid: raw HID events driver (C) Jiri Kosina
   244    [    3.423124] usbcore: registered new interface driver usbhid
   245    [    3.428032] usbhid: USB HID core driver
   246    [    3.432100] platform-mhu c883c404.mailbox: Platform MHU Mailbox registered
   247    [    3.449062] NET: Registered protocol family 17
   248    [    3.449316] Key type dns_resolver registered
   249    [    3.452656] registered taskstats version 1
   250    [    3.456205] Loading compiled-in X.509 certificates
   251    [    3.461156] zswap: loaded using pool lzo/zbud
   252    [    3.465437] Key type ._fscrypt registered
   253    [    3.469201] Key type .fscrypt registered
   254    [    3.474133] Btrfs loaded, crc32c=crc32c-generic
   255    [    3.496556] mmc1: new HS200 MMC card at address 0001
   256    [    3.497451] mmcblk1: mmc1:0001 016G92 14.7 GiB
   257    [    3.500892] mmcblk1boot0: mmc1:0001 016G92 partition 1 4.00 MiB
   258    [    3.502047] Key type encrypted registered
   259    [    3.506766] mmcblk1boot1: mmc1:0001 016G92 partition 2 4.00 MiB
   260    [    3.516603] mmcblk1gp0: mmc1:0001 016G92 partition 4 8.00 MiB
   261    [    3.522126] mmcblk1rpmb: mmc1:0001 016G92 partition 3 512 KiB, chardev (243:0)
   262    [    3.529870] meson-drm d0100000.vpu: Queued 3 outputs on vpu
   263    [    3.534840] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
   264    [    3.541118] [drm] No driver support for vblank timestamp query.
   265    [    3.574515] meson-dw-hdmi c883a000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
   266    [    3.579233] meson-dw-hdmi c883a000.hdmi-tx: registered DesignWare HDMI I2C bus driver
   267    [    3.587184] meson-drm d0100000.vpu: bound c883a000.hdmi-tx (ops meson_dw_hdmi_ops)
   268    [    3.594541] [drm] Initialized meson 1.0.0 20161109 for d0100000.vpu on minor 0
   269    [    3.631355] Console: switching to colour frame buffer device 90x36
   270    [    3.651576] meson-drm d0100000.vpu: fb0: mesondrmfb frame buffer device
   271    [    3.658841] libphy: mdio_mux: probed
   272    [    3.669389] libphy: mdio_mux: probed
   273    [    3.669879] phy phy-d0078080.phy.2: unsupported PHY mode 5
   274    [    3.674927] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
   275    [    3.678308] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
   276    [    3.686022] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228f664 hci version 0x100 quirks 0x0000000002010010
   277    [    3.695262] xhci-hcd xhci-hcd.0.auto: irq 39, io mem 0xc9000000
   278    [    3.701356] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.05
   279    [    3.709727] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   280    [    3.716869] usb usb1: Product: xHCI Host Controller
   281    [    3.721696] usb usb1: Manufacturer: Linux 5.5.0-rc6-aml-s9xxx xhci-hcd
   282    [    3.728169] usb usb1: SerialNumber: xhci-hcd.0.auto
   283    [    3.733493] hub 1-0:1.0: USB hub found
   284    [    3.736745] hub 1-0:1.0: 2 ports detected
   285    [    3.740969] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
   286    [    3.746124] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
   287    [    3.753728] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
   288    [    3.760237] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
   289    [    3.768522] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.05
   290    [    3.776916] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   291    [    3.784072] usb usb2: Product: xHCI Host Controller
   292    [    3.788908] usb usb2: Manufacturer: Linux 5.5.0-rc6-aml-s9xxx xhci-hcd
   293    [    3.795373] usb usb2: SerialNumber: xhci-hcd.0.auto
   294    [    3.800681] hub 2-0:1.0: USB hub found
   295    [    3.803950] hub 2-0:1.0: config failed, hub doesn't have any ports! (err -19)
   296    [    3.812806] meson-gx-mmc d0070000.mmc: allocated mmc-pwrseq
   297    [    3.843446] scpi_protocol scpi: SCP Protocol legacy pre-1.0 firmware
   298    [    3.860311] gx-sound-card sound: snd-soc-dummy-dai <-> c1105400.bus:audio-controller-0 mapping ok
   299    [    3.872049] gx-sound-card sound: i2s-hifi <-> c1105400.bus:audio-controller-2 mapping ok
   300    [    3.879785] gx-sound-card sound: ASoC: no DMI vendor name!
   301    [    3.885960] printk: console [netcon0] enabled
   302    [    3.889372] netconsole: network logging started
   303    [    3.893930] hctosys: unable to open rtc device (rtc0)
   304    [    3.899408] ALSA device list:
   305    [    3.901959]   #0: AMLGX
   306    [    3.905031] Freeing unused kernel memory: 960K
   307    [    3.908791] Run /init as init process
   308    [    3.920297] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
   309    [    3.926571] mmc2: queuing unknown CIS tuple 0x80 (6 bytes)
   310    [    3.933111] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
   311    [    3.945261] mmc2: queuing unknown CIS tuple 0x80 (19 bytes)
   312    [    3.970942] random: fast init done
   313    [    4.031650] mmc2: new high speed SDIO card at address 0001
   314    [    4.074519] usb 1-1: new high-speed USB device number 2 using xhci-hcd
   315    [    4.095824] usb 1-1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.36
   316    [    4.102658] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
   317    [    4.110273] usb 1-1: Product: USB2.0 Hub
   318    [    4.176691] hub 1-1:1.0: USB hub found
   319    [    4.179315] hub 1-1:1.0: 4 ports detected
   320    [    4.310532] usb 1-2: new high-speed USB device number 3 using xhci-hcd
   321    [    4.341017] usb 1-2: New USB device found, idVendor=148f, idProduct=7601, bcdDevice= 0.00
   322    [    4.347976] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
   323    [    4.355838] usb 1-2: Product: 802.11 n WLAN
   324    [    4.359565] usb 1-2: Manufacturer: MediaTek
   325    [    4.363631] usb 1-2: SerialNumber: 1.0
   326    [    5.110138] EXT4-fs (mmcblk0p2): mounted filesystem with writeback data mode. Opts: data=writeback
   327    [    6.052807] systemd[1]: System time before build time, advancing clock.
   328    [    6.200507] NET: Registered protocol family 10
   329    [    6.274520] Segment Routing with IPv6
   330    [    6.325154] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
   331    [    6.358527] systemd[1]: Detected architecture arm64.
   332    [    6.413903] systemd[1]: Set hostname to <mxqpro>.
   333    [    6.447693] systemd[1]: Couldn't move remaining userspace processes, ignoring: Input/output error
   334    [    7.138797] random: systemd: uninitialized urandom read (16 bytes read)
   335    [    7.153425] random: systemd: uninitialized urandom read (16 bytes read)
   336    [    7.156998] systemd[1]: Reached target Remote File Systems.
   337    [    7.165768] random: systemd: uninitialized urandom read (16 bytes read)
   338    [    7.169563] systemd[1]: Listening on initctl Compatibility Named Pipe.
   339    [    7.179002] systemd[1]: Listening on udev Kernel Socket.
   340    [    7.184570] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
   341    [    7.192779] systemd[1]: Listening on Syslog Socket.
   342    [    7.201447] systemd[1]: Created slice system-serial\x2dgetty.slice.
   343    [    7.429845] EXT4-fs (mmcblk0p2): re-mounted. Opts: commit=600,errors=remount-ro
   344    [    7.628140] systemd-journald[411]: Received request to flush runtime journal from PID 1
   345    [    8.125525] mc: Linux media interface: v0.10
   346    [    8.151775] videodev: Linux video capture interface: v2.00
   347    [    8.166795] Registered IR keymap rc-empty
   348    [    8.169397] rc rc0: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0
   349    [    8.186083] input: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0/input0
   350    [    8.197729] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
   351    [    8.208339] meson-ir c8100580.ir: receiver initialized
   352    [    8.308327] lima d00c0000.gpu: IRQ ppmmu3 not found
   353    [    8.310996] lima d00c0000.gpu: IRQ ppmmu4 not found
   354    [    8.314707] lima d00c0000.gpu: IRQ ppmmu5 not found
   355    [    8.319537] lima d00c0000.gpu: IRQ ppmmu6 not found
   356    [    8.324389] lima d00c0000.gpu: IRQ ppmmu7 not found
   357    [    8.334645] lima d00c0000.gpu: gp - mali450 version major 0 minor 0
   358    [    8.337703] lima d00c0000.gpu: pp0 - mali450 version major 0 minor 0
   359    [    8.346755] lima d00c0000.gpu: pp1 - mali450 version major 0 minor 0
   360    [    8.350021] lima d00c0000.gpu: pp2 - mali450 version major 0 minor 0
   361    [    8.359370] lima d00c0000.gpu: IRQ pp3 not found
   362    [    8.361255] lima d00c0000.gpu: IRQ pp4 not found
   363    [    8.365744] lima d00c0000.gpu: IRQ pp5 not found
   364    [    8.370349] lima d00c0000.gpu: IRQ pp6 not found
   365    [    8.374849] lima d00c0000.gpu: IRQ pp7 not found
   366    [    8.379326] lima d00c0000.gpu: l2 cache 8K, 4-way, 64byte cache line, 128bit external bus
   367    [    8.387575] lima d00c0000.gpu: l2 cache 64K, 4-way, 64byte cache line, 128bit external bus
   368    [    8.395757] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
   369    [    8.414186] lima d00c0000.gpu: bus rate = 166666667
   370    [    8.417450] lima d00c0000.gpu: mod rate = 744000000
   371    [    8.425573] [drm] Initialized lima 1.0.0 20190217 for d00c0000.gpu on minor 1
   372    [    8.432277] Bluetooth: Core ver 2.22
   373    [    8.434596] NET: Registered protocol family 31
   374    [    8.436947] Bluetooth: HCI device and connection manager initialized
   375    [    8.445229] Bluetooth: HCI socket layer initialized
   376    [    8.449221] Bluetooth: L2CAP socket layer initialized
   377    [    8.453394] Bluetooth: SCO socket layer initialized
   378    [    8.575514] cfg80211: Loading compiled-in X.509 certificates for regulatory database
   379    [    8.581098] Bluetooth: HCI UART driver ver 2.3
   380    [    8.592788] Bluetooth: HCI UART protocol H4 registered
   381    [    8.594644] Bluetooth: HCI UART protocol BCSP registered
   382    [    8.599514] Bluetooth: HCI UART protocol LL registered
   383    [    8.604491] Bluetooth: HCI UART protocol ATH3K registered
   384    [    8.610028] Bluetooth: HCI UART protocol Three-wire (H5) registered
   385    [    8.616590] Bluetooth: HCI UART protocol Intel registered
   386    [    8.629866] Bluetooth: HCI UART protocol Broadcom registered
   387    [    8.630006] hci_uart_bcm serial0-0: serial0-0 supply vbat not found, using dummy regulator
   388    [    8.631847] Bluetooth: HCI UART protocol QCA registered
   389    [    8.642148] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
   390    [    8.645138] Bluetooth: HCI UART protocol AG6XX registered
   391    [    8.651762] hci_uart_bcm serial0-0: serial0-0 supply vddio not found, using dummy regulator
   392    [    8.657080] Bluetooth: HCI UART protocol Marvell registered
   393    [    8.683291] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
   394    [    8.690778] cfg80211: failed to load regulatory.db
   395    [    8.794743] brcmfmac: F1 signature read @0x18000000=0x16034334
   396    [    8.798059] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4334-sdio for chip BCM4334/3
   397    [    8.805682] usbcore: registered new interface driver brcmfmac
   398    [    8.855976] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.amlogic,p212.txt failed with error -2
   399    [    8.866189] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.txt failed with error -2
   400    [    8.942799] usb 1-2: reset high-speed USB device number 3 using xhci-hcd
   401    [    8.965572] mt7601u 1-2:1.0: ASIC revision: 76010001 MAC revision: 76010500
   402    [    9.008611] mt7601u 1-2:1.0: EEPROM ver:0d fae:00
   403    [    9.051512] Bluetooth: hci0: BCM: chip id 68
   404    [    9.055464] Bluetooth: hci0: BCM: features 0x0f
   405    [    9.060643] Bluetooth: hci0: BCM4334B0
   406    [    9.063489] Bluetooth: hci0: BCM4334B0 (002.001.013) build 0000
   407    [    9.067647] bluetooth hci0: Direct firmware load for brcm/BCM4334B0.hcd failed with error -2
   408    [    9.075959] Bluetooth: hci0: BCM: Patch brcm/BCM4334B0.hcd not found
   409    [    9.223051] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
   410    [    9.225005] usbcore: registered new interface driver mt7601u
   411    [    9.878553] brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x50
   412    [    9.908340] zram: Added device: zram0
   413    [    9.911823] zram: Added device: zram1
   414    [    9.927131] zram: Added device: zram2
   415    [    9.975264] zram1: detected capacity change from 0 to 912879616
   416    [    9.993267] meson8b-dwmac c9410000.ethernet eth0: PHY [0.e40908ff:08] driver [Meson GXL Internal PHY]
   417    [   10.014535] meson8b-dwmac c9410000.ethernet eth0: No Safety Features support found
   418    [   10.019869] meson8b-dwmac c9410000.ethernet eth0: PTP not supported by HW
   419    [   10.019881] meson8b-dwmac c9410000.ethernet eth0: configuring for phy/rmii link mode
   420    [   10.596915] random: crng init done
   421    [   10.599535] random: 7 urandom warning(s) missed due to ratelimiting
   422    [   10.682808] Adding 891480k swap on /dev/zram1.  Priority:5 extents:1 across:891480k SSFS
   423
   424    ### armbian-release:
   425
   426    # PLEASE DO NOT EDIT THIS FILE
   427    BOARD=aml-s9xxx
   428    BOARD_NAME="AML-S9xxx"
   429    BOARDFAMILY=aml-s9xxx
   430    BUILD_REPOSITORY_URL=https://github.com/150balbes/Build-Armbian.git
   431    BUILD_REPOSITORY_COMMIT=62b8c07-dirty
   432    DISTRIBUTION_CODENAME=buster
   433    DISTRIBUTION_STATUS=supported
   434    VERSION=20.02.0-rc1.037
   435    LINUXFAMILY=aml-s9xxx
   436    BRANCH=current
   437    ARCH=arm64
   438    IMAGE_TYPE=nightly
   439    BOARD_TYPE=conf
   440    INITRD_ARCH=arm64
   441    KERNEL_IMAGE_TYPE=Image
   442
   443    ### boot environment:
   444
   445    ODROIDN2-UBOOT-CONFIG
   446    setenv env_addr 0x10400000
   447    setenv kernel_addr 0x11000000
   448    setenv initrd_addr 0x13000000
   449    setenv dtb_addr 0x1000000
   450    if test "${devtype}" = ""; then setenv devtype "mmc"; fi
   451    load ${devtype} ${devnum} ${env_addr} uEnv.txt && env import -t ${env_addr} ${filesize}
   452    setenv bootargs ${APPEND}
   453    load ${devtype} ${devnum} ${kernel_addr} ${LINUX}
   454    load ${devtype} ${devnum} ${initrd_addr} ${INITRD}
   455    load ${devtype} ${devnum} ${dtb_addr} ${FDT}
   456    fdt addr ${dtb_addr}
   457    booti ${kernel_addr} ${initrd_addr} ${dtb_addr}
   458
   459    ### lsusb:
   460
   461    Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
   462    Bus 001 Device 003: ID 148f:7601 Ralink Technology, Corp. MT7601U Wireless Adapter
   463    Bus 001 Device 002: ID 05e3:0608 Genesys Logic, Inc. Hub
   464    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
   465
   466    ### lscpu:
   467
   468    Architecture:        aarch64
   469    Byte Order:          Little Endian
   470    CPU(s):              4
   471    On-line CPU(s) list: 0-3
   472    Thread(s) per core:  1
   473    Core(s) per socket:  4
   474    Socket(s):           1
   475    Vendor ID:           ARM
   476    Model:               4
   477    Model name:          Cortex-A53
   478    Stepping:            r0p4
   479    CPU max MHz:         1512,0000
   480    CPU min MHz:         100,0000
   481    BogoMIPS:            48.00
   482    L1d cache:           unknown size
   483    L1i cache:           unknown size
   484    L2 cache:            unknown size
   485    Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
   486
   487    ### cpuinfo:
   488
   489    processor    : 0
   490    model name    : ARMv8 Processor rev 4 (v8l)
   491    BogoMIPS    : 48.00
   492    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
   493    CPU implementer    : 0x41
   494    CPU architecture: 8
   495    CPU variant    : 0x0
   496    CPU part    : 0xd03
   497    CPU revision    : 4
   498
   499    processor    : 1
   500    model name    : ARMv8 Processor rev 4 (v8l)
   501    BogoMIPS    : 48.00
   502    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
   503    CPU implementer    : 0x41
   504    CPU architecture: 8
   505    CPU variant    : 0x0
   506    CPU part    : 0xd03
   507    CPU revision    : 4
   508
   509    processor    : 2
   510    model name    : ARMv8 Processor rev 4 (v8l)
   511    BogoMIPS    : 48.00
   512    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
   513    CPU implementer    : 0x41
   514    CPU architecture: 8
   515    CPU variant    : 0x0
   516    CPU part    : 0xd03
   517    CPU revision    : 4
   518
   519    processor    : 3
   520    model name    : ARMv8 Processor rev 4 (v8l)
   521    BogoMIPS    : 48.00
   522    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
   523    CPU implementer    : 0x41
   524    CPU architecture: 8
   525    CPU variant    : 0x0
   526    CPU part    : 0xd03
   527    CPU revision    : 4
   528
   529
   530    ### meminfo:
   531
   532    MemTotal:        1782968 kB
   533    MemFree:         1609176 kB
   534    MemAvailable:    1666708 kB
   535    Buffers:           11832 kB
   536    Cached:            54040 kB
   537    SwapCached:            0 kB
   538    Active:            52492 kB
   539    Inactive:          34792 kB
   540    Active(anon):      21768 kB
   541    Inactive(anon):     2588 kB
   542    Active(file):      30724 kB
   543    Inactive(file):    32204 kB
   544    Unevictable:           0 kB
   545    Mlocked:               0 kB
   546    SwapTotal:        891480 kB
   547    SwapFree:         891480 kB
   548    Dirty:               708 kB
   549    Writeback:             0 kB
   550    AnonPages:         21532 kB
   551    Mapped:            21964 kB
   552    Shmem:              2688 kB
   553    KReclaimable:      17720 kB
   554    Slab:              52844 kB
   555    SReclaimable:      17720 kB
   556    SUnreclaim:        35124 kB
   557    KernelStack:        2752 kB
   558    PageTables:         1452 kB
   559    NFS_Unstable:          0 kB
   560    Bounce:                0 kB
   561    WritebackTmp:          0 kB
   562    CommitLimit:     1782964 kB
   563    Committed_AS:      53988 kB
   564    VmallocTotal:   135290159040 kB
   565    VmallocUsed:       16696 kB
   566    VmallocChunk:          0 kB
   567    Percpu:             1264 kB
   568    CmaTotal:         262144 kB
   569    CmaFree:          258460 kB
   570    HugePages_Total:       0
   571    HugePages_Free:        0
   572    HugePages_Rsvd:        0
   573    HugePages_Surp:        0
   574    Hugepagesize:       2048 kB
   575    Hugetlb:               0 kB
   576
   577    ### virtual memory:
   578
   579    vm.admin_reserve_kbytes = 8192
   580    vm.block_dump = 0
   581    vm.compact_unevictable_allowed = 1
   582    vm.dirty_background_bytes = 0
   583    vm.dirty_background_ratio = 10
   584    vm.dirty_bytes = 0
   585    vm.dirty_expire_centisecs = 3000
   586    vm.dirty_ratio = 20
   587    vm.dirtytime_expire_seconds = 43200
   588    vm.dirty_writeback_centisecs = 500
   589    vm.extfrag_threshold = 500
   590    vm.hugetlb_shm_group = 0
   591    vm.laptop_mode = 0
   592    vm.legacy_va_layout = 0
   593    vm.lowmem_reserve_ratio = 256    256    32    0
   594    vm.max_map_count = 65530
   595    vm.min_free_kbytes = 4914
   596    vm.mmap_min_addr = 4096
   597    vm.mmap_rnd_bits = 18
   598    vm.nr_hugepages = 0
   599    vm.nr_overcommit_hugepages = 0
   600    vm.oom_dump_tasks = 1
   601    vm.oom_kill_allocating_task = 0
   602    vm.overcommit_kbytes = 0
   603    vm.overcommit_memory = 0
   604    vm.overcommit_ratio = 50
   605    vm.page-cluster = 0
   606    vm.panic_on_oom = 0
   607    vm.percpu_pagelist_fraction = 0
   608    vm.stat_interval = 1
   609    vm.swappiness = 100
   610    vm.user_reserve_kbytes = 55239
   611    vm.vfs_cache_pressure = 100
   612    vm.watermark_boost_factor = 15000
   613    vm.watermark_scale_factor = 10
   614
   615    ### ip addr:
   616
   617    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
   618        link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
   619        inet XXX.XXX.0.1/8 scope host lo
   620           valid_lft forever preferred_lft forever
   621        inet6 ::1/128 scope host
   622           valid_lft forever preferred_lft forever
   623    2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
   624        link/ether 00:df:06:00:00:0b brd ff:ff:ff:ff:ff:ff
   625    3: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
   626        link/ether 00:36:76:61:0b:24 brd ff:ff:ff:ff:ff:ff
   627
   628    ### partitions:
   629
   630    major minor  #blocks  name
   631
   632     179        0   30924800 mmcblk0
   633     179        1     262144 mmcblk0p1
   634     179        2   30337024 mmcblk0p2
   635     179       32   15384576 mmcblk1
   636     179      128       8192 mmcblk1gp0
   637     254        1     891484 zram1
   638
   639    ### df:
   640
   641    udev             738M      0  738M   0% /dev
   642    tmpfs            175M   2,7M  172M   2% /run
   643    /dev/mmcblk0p2    29G    10G   19G  36% /
   644    tmpfs            871M      0  871M   0% /dev/shm
   645    tmpfs            5,0M   4,0K  5,0M   1% /run/lock
   646    tmpfs            871M      0  871M   0% /sys/fs/cgroup
   647    tmpfs            871M      0  871M   0% /tmp
   648    /dev/mmcblk0p1   256M    76M  180M  30% /boot
   649
   650    ### lsblk:
   651
   652    NAME         FSTYPE   SIZE MOUNTPOINT UUID
   653    mmcblk0              29,5G
   654    ├─mmcblk0p1  vfat     256M /boot      50FC-6AC8
   655    └─mmcblk0p2  ext4      29G /          3e297ac1-e4e4-4ab1-bc57-47c07d0422ba
   656    mmcblk1              14,7G
   657    mmcblk1boot0            4M
   658    mmcblk1boot1            4M
   659    mmcblk1gp0              8M
   660
   661    ### zramctl:
   662
   663    NAME       ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT
   664    /dev/zram1 lzo         870,6M   4K   81B   12K       4 [SWAP]
   665
   666    ### mtab:
   667
   668    /dev/mmcblk0p1 /boot vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro 0 0
   669    /dev/mmcblk0p2 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
   670
   671    ### mmc0:59b4 info:
   672
   673                   fwrev: 0x0
   674                  uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SDU1  MODALIAS=mmc:block
   675                     cid: 1b534d53445531201014a136d4013800
   676                     rca: 0x59b4
   677                     csd: 400e00325b590000ebef7f800a400000
   678                  manfid: 0x00001b
   679                     ocr: 0x00200000
   680    preferred_erase_size: 4194304
   681                    type: SD
   682                   hwrev: 0x1
   683                    date: 08/2019
   684                     dsr: 0x404
   685              erase_size: 512
   686                   oemid: 0x534d
   687                  serial: 0x14a136d4
   688                     ssr: 0000000005000000040090000811391e00089a342f01000000000000000000000000000000000000000000000000000000000000000000000000000000000000
   689                     scr: 0235844300000000
   690                    name: SDU1
   691
   692    ### mmc1:0001 info:
   693
   694                   fwrev: 0x0
   695                  uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=016G92 MODALIAS=mmc:block
   696                     cid: 11010030313647393201d3d1a4db1100
   697             rel_sectors: 0x10
   698                     rca: 0x0001
   699            pre_eol_info: 0x00
   700                     csd: d00e00320f5903ffffffffef92400000
   701                  manfid: 0x000011
   702                     ocr: 0x00200000
   703    preferred_erase_size: 4194304
   704    enhanced_area_offset: 18446744073709551594
   705      raw_rpmb_size_mult: 0x4
   706                    type: MMC
   707                   hwrev: 0x0
   708                    date: 01/2014
   709                     prv: 0x1
   710             ffu_capable: 0
   711                     dsr: 0x404
   712              erase_size: 4194304
   713               life_time: 0x00 0x00
   714      enhanced_area_size: 4294967274
   715                   oemid: 0x0100
   716                  serial: 0xd3d1a4db
   717                 cmdq_en: 0
   718                     rev: 0x6
   719                    name: 016G92
   720
   721    ### Boot system health:
   722
   723    Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU
   724    00:17:34: 1512MHz  0.39  52%  24%  15%   0%  11%   1% 41.0°C
   725    00:17:34: 1512MHz  0.39  73%  11%  18%   1%  40%   2% 42.0°C
   726    00:17:34: 1512MHz  0.39  68%  13%  20%   1%  31%   2% 41.0°C
   727    00:17:35: 1512MHz  0.39  52%   7%  11%   0%  30%   1% 41.0°C
   728    00:17:35: 1512MHz  0.39  42%   8%   8%   0%  23%   1% 40.0°C
   729
   730    ### Activated 1 lzo zram swap devices with 870 MB each
   731
   732
   733    lun mar 22 07:51:53 CET 2021 | AML-S9xxx | 20.02.0-rc1.037 | arm64 | aarch64 | 5.5.0-rc6-aml-s9xxx
   734
   735    ### dmesg:
   736
   737    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
   738    [    0.000000] Linux version 5.5.0-rc6-aml-s9xxx (root@vbox) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #rc1.037 SMP PREEMPT Wed Feb 5 15:59:04 MSK 2020
   739    [    0.000000] Machine model: Amlogic Meson GXL (S905X) P212 Development Board
   740    [    0.000000] efi: Getting EFI parameters from FDT:
   741    [    0.000000] efi: UEFI not found.
   742    [    0.000000] Reserved memory: created CMA memory pool at 0x0000000063400000, size 256 MiB
   743    [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
   744    [    0.000000] On node 0 totalpages: 477952
   745    [    0.000000]   DMA zone: 4032 pages used for memmap
   746    [    0.000000]   DMA zone: 0 pages reserved
   747    [    0.000000]   DMA zone: 248576 pages, LIFO batch:63
   748    [    0.000000]   DMA32 zone: 3584 pages used for memmap
   749    [    0.000000]   DMA32 zone: 229376 pages, LIFO batch:63
   750    [    0.000000] psci: probing for conduit method from DT.
   751    [    0.000000] psci: PSCIv0.2 detected in firmware.
   752    [    0.000000] psci: Using standard PSCI v0.2 function IDs
   753    [    0.000000] psci: Trusted OS migration not required
   754    [    0.000000] percpu: Embedded 22 pages/cpu s50392 r8192 d31528 u90112
   755    [    0.000000] pcpu-alloc: s50392 r8192 d31528 u90112 alloc=22*4096
   756    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
   757    [    0.000000] Detected VIPT I-cache on CPU0
   758    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 470336
   759    [    0.000000] Kernel command line: root=LABEL=ROOTFS rootflags=data=writeback rw console=ttyAML0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 mac=00:df:06:00:00:0b
   760    [    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
   761    [    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
   762    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
   763    [    0.000000] software IO TLB: mapped [mem 0x3bfff000-0x3ffff000] (64MB)
   764    [    0.000000] Memory: 1509616K/1911808K available (14460K kernel code, 1434K rwdata, 5884K rodata, 960K init, 927K bss, 140048K reserved, 262144K cma-reserved)
   765    [    0.000000] random: get_random_u64 called from cache_random_seq_create+0x7c/0x150 with crng_init=0
   766    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
   767    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
   768    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
   769    [    0.000000]     Tasks RCU enabled.
   770    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
   771    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
   772    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
   773    [    0.000000] GIC: Using split EOI/Deactivate mode
   774    [    0.000000] irq_meson_gpio: 110 to 8 gpio interrupt mux initialized
   775    [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
   776    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
   777    [    0.000003] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
   778    [    0.000352] Console: colour dummy device 80x25
   779    [    0.000652] printk: console [tty0] enabled
   780    [    0.000691] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
   781    [    0.000712] pid_max: default: 32768 minimum: 301
   782    [    0.000839] LSM: Security Framework initializing
   783    [    0.000889] SELinux:  Initializing.
   784    [    0.000967] *** VALIDATE SELinux ***
   785    [    0.001034] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
   786    [    0.001060] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
   787    [    0.001124] *** VALIDATE tmpfs ***
   788    [    0.001535] *** VALIDATE proc ***
   789    [    0.001758] *** VALIDATE cgroup1 ***
   790    [    0.001773] *** VALIDATE cgroup2 ***
   791    [    0.024017] ASID allocator initialised with 32768 entries
   792    [    0.031999] rcu: Hierarchical SRCU implementation.
   793    [    0.042089] EFI services will not be available.
   794    [    0.048056] smp: Bringing up secondary CPUs ...
   795    [    0.080285] Detected VIPT I-cache on CPU1
   796    [    0.080339] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
   797    [    0.112330] Detected VIPT I-cache on CPU2
   798    [    0.112377] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
   799    [    0.144374] Detected VIPT I-cache on CPU3
   800    [    0.144416] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
   801    [    0.144493] smp: Brought up 1 node, 4 CPUs
   802    [    0.144560] SMP: Total of 4 processors activated.
   803    [    0.144572] CPU features: detected: 32-bit EL0 Support
   804    [    0.144584] CPU features: detected: CRC32 instructions
   805    [    0.144887] CPU: All CPU(s) started at EL2
   806    [    0.144910] alternatives: patching kernel code
   807    [    0.146010] devtmpfs: initialized
   808    [    0.151131] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
   809    [    0.151173] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
   810    [    0.157999] xor: measuring software checksum speed
   811    [    0.196369]    8regs     :  2374.000 MB/sec
   812    [    0.236401]    32regs    :  2724.000 MB/sec
   813    [    0.276439]    arm64_neon:  2406.000 MB/sec
   814    [    0.276449] xor: using function: 32regs (2724.000 MB/sec)
   815    [    0.276505] pinctrl core: initialized pinctrl subsystem
   816    [    0.277159] thermal_sys: Registered thermal governor 'step_wise'
   817    [    0.277328] DMI not present or invalid.
   818    [    0.277690] NET: Registered protocol family 16
   819    [    0.281245] DMA: preallocated 256 KiB pool for atomic allocations
   820    [    0.281296] audit: initializing netlink subsys (disabled)
   821    [    0.281507] audit: type=2000 audit(0.280:1): state=initialized audit_enabled=0 res=1
   822    [    0.282585] cpuidle: using governor ladder
   823    [    0.282626] cpuidle: using governor menu
   824    [    0.282996] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
   825    [    0.283719] Serial: AMBA PL011 UART driver
   826    [    0.297732] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
   827    [    0.297758] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
   828    [    0.297771] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
   829    [    0.297784] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
   830    [    0.301432] cryptd: max_cpu_qlen set to 1000
   831    [    0.376690] raid6: neonx8   gen()  1616 MB/s
   832    [    0.444714] raid6: neonx8   xor()  1491 MB/s
   833    [    0.512772] raid6: neonx4   gen()  1564 MB/s
   834    [    0.580828] raid6: neonx4   xor()  1471 MB/s
   835    [    0.648908] raid6: neonx2   gen()  1201 MB/s
   836    [    0.716919] raid6: neonx2   xor()  1216 MB/s
   837    [    0.785015] raid6: neonx1   gen()   788 MB/s
   838    [    0.853082] raid6: neonx1   xor()   915 MB/s
   839    [    0.921130] raid6: int64x8  gen()  1195 MB/s
   840    [    0.989152] raid6: int64x8  xor()   769 MB/s
   841    [    1.057214] raid6: int64x4  gen()  1029 MB/s
   842    [    1.125269] raid6: int64x4  xor()   752 MB/s
   843    [    1.193304] raid6: int64x2  gen()   728 MB/s
   844    [    1.261341] raid6: int64x2  xor()   615 MB/s
   845    [    1.329490] raid6: int64x1  gen()   486 MB/s
   846    [    1.397458] raid6: int64x1  xor()   467 MB/s
   847    [    1.397469] raid6: using algorithm neonx8 gen() 1616 MB/s
   848    [    1.397479] raid6: .... xor() 1491 MB/s, rmw enabled
   849    [    1.397489] raid6: using neon recovery algorithm
   850    [    1.397731] ACPI: Interpreter disabled.
   851    [    1.398932] iommu: Default domain type: Translated
   852    [    1.399201] vgaarb: loaded
   853    [    1.399747] SCSI subsystem initialized
   854    [    1.399919] libata version 3.00 loaded.
   855    [    1.400129] usbcore: registered new interface driver usbfs
   856    [    1.400176] usbcore: registered new interface driver hub
   857    [    1.400238] usbcore: registered new device driver usb
   858    [    1.400648] pps_core: LinuxPPS API ver. 1 registered
   859    [    1.400660] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
   860    [    1.400685] PTP clock support registered
   861    [    1.400712] EDAC MC: Ver: 3.0.0
   862    [    1.401285] FPGA manager framework
   863    [    1.401409] Advanced Linux Sound Architecture Driver Initialized.
   864    [    1.401874] NetLabel: Initializing
   865    [    1.401887] NetLabel:  domain hash size = 128
   866    [    1.401896] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
   867    [    1.401950] NetLabel:  unlabeled traffic allowed by default
   868    [    1.402425] clocksource: Switched to clocksource arch_sys_counter
   869    [    1.402448] *** VALIDATE bpf ***
   870    [    1.402705] VFS: Disk quotas dquot_6.6.0
   871    [    1.402767] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
   872    [    1.402895] FS-Cache: Loaded
   873    [    1.402906] *** VALIDATE ramfs ***
   874    [    1.402927] *** VALIDATE hugetlbfs ***
   875    [    1.403302] pnp: PnP ACPI: disabled
   876    [    1.408331] NET: Registered protocol family 2
   877    [    1.408830] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
   878    [    1.408878] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
   879    [    1.408995] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
   880    [    1.409209] TCP: Hash tables configured (established 16384 bind 16384)
   881    [    1.409363] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
   882    [    1.409419] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
   883    [    1.409636] NET: Registered protocol family 1
   884    [    1.410100] RPC: Registered named UNIX socket transport module.
   885    [    1.410122] RPC: Registered udp transport module.
   886    [    1.410131] RPC: Registered tcp transport module.
   887    [    1.410140] RPC: Registered tcp NFSv4.1 backchannel transport module.
   888    [    1.410157] NET: Registered protocol family 44
   889    [    1.410178] PCI: CLS 0 bytes, default 64
   890    [    1.410379] Trying to unpack rootfs image as initramfs...
   891    [    1.872010] Freeing initrd memory: 10248K
   892    [    1.872812] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
   893    [    2.086312] Initialise system trusted keyrings
   894    [    2.086627] workingset: timestamp_bits=46 max_order=19 bucket_order=0
   895    [    2.091819] zbud: loaded
   896    [    2.093042] squashfs: version 4.0 (2009/01/31) Phillip Lougher
   897    [    2.093345] FS-Cache: Netfs 'nfs' registered for caching
   898    [    2.093872] NFS: Registering the id_resolver key type
   899    [    2.093909] Key type id_resolver registered
   900    [    2.093919] Key type id_legacy registered
   901    [    2.093935] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
   902    [    2.093947] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
   903    [    2.095154] FS-Cache: Netfs 'cifs' registered for caching
   904    [    2.095485] Key type cifs.spnego registered
   905    [    2.095509] Key type cifs.idmap registered
   906    [    2.095533] ntfs: driver 2.1.32 [Flags: R/W].
   907    [    2.096106] JFS: nTxBlock = 8192, nTxLock = 65536
   908    [    2.101997] SGI XFS with ACLs, security attributes, realtime, quota, no debug enabled
   909    [    2.103440] *** VALIDATE xfs ***
   910    [    2.103744] ocfs2: Registered cluster interface o2cb
   911    [    2.103958] OCFS2 User DLM kernel interface loaded
   912    [    2.105359] *** VALIDATE gfs2 ***
   913    [    2.105638] gfs2: GFS2 installed
   914    [    2.106589] aufs 5.5-20200203
   915    [    2.126560] Key type asymmetric registered
   916    [    2.126586] Asymmetric key parser 'x509' registered
   917    [    2.126597] Asymmetric key parser 'pkcs8' registered
   918    [    2.126668] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
   919    [    2.126849] io scheduler mq-deadline registered
   920    [    2.126864] io scheduler kyber registered
   921    [    2.127062] io scheduler bfq registered
   922    [    2.139630] soc soc0: Amlogic Meson GXL (S905X) Revision 21:b (82:2) Detected
   923    [    2.143192] Serial: 8250/16550 driver, 5 ports, IRQ sharing enabled
   924    [    2.144887] Serial: AMBA driver
   925    [    2.145264] c11084c0.serial: ttyAML6 at MMIO 0xc11084c0 (irq = 10, base_baud = 1500000) is a meson_uart
   926    [    2.145418] serial serial0: tty port ttyAML6 registered
   927    [    2.145624] c81004c0.serial: ttyAML0 at MMIO 0xc81004c0 (irq = 13, base_baud = 1500000) is a meson_uart
   928    [    3.121095] printk: console [ttyAML0] enabled
   929    [    3.137297] brd: module loaded
   930    [    3.145834] loop: module loaded
   931    [    3.148342] libphy: Fixed MDIO Bus: probed
   932    [    3.148995] meson8b-dwmac c9410000.ethernet: IRQ eth_wake_irq not found
   933    [    3.154017] meson8b-dwmac c9410000.ethernet: IRQ eth_lpi not found
   934    [    3.160208] meson8b-dwmac c9410000.ethernet: PTP uses main clock
   935    [    3.166067] meson8b-dwmac c9410000.ethernet: no reset control found
   936    [    3.172770] meson8b-dwmac c9410000.ethernet: User ID: 0x11, Synopsys ID: 0x37
   937    [    3.179368] meson8b-dwmac c9410000.ethernet:     DWMAC1000
   938    [    3.184536] meson8b-dwmac c9410000.ethernet: DMA HW capability register supported
   939    [    3.191936] meson8b-dwmac c9410000.ethernet: RX Checksum Offload Engine supported
   940    [    3.199353] meson8b-dwmac c9410000.ethernet: COE Type 2
   941    [    3.204525] meson8b-dwmac c9410000.ethernet: TX Checksum insertion supported
   942    [    3.211512] meson8b-dwmac c9410000.ethernet: Wake-Up On Lan supported
   943    [    3.217926] meson8b-dwmac c9410000.ethernet: Normal descriptors
   944    [    3.223761] meson8b-dwmac c9410000.ethernet: Ring mode enabled
   945    [    3.229538] meson8b-dwmac c9410000.ethernet: Enable RX Mitigation via HW Watchdog Timer
   946    [    3.237657] libphy: stmmac: probed
   947    [    3.242136] VFIO - User Level meta-driver version: 0.3
   948    [    3.247535] dwc3 c9000000.dwc3: Failed to get clk 'ref': -2
   949    [    3.252355] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
   950    [    3.257953] ehci-pci: EHCI PCI platform driver
   951    [    3.262382] ehci-platform: EHCI generic platform driver
   952    [    3.267684] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
   953    [    3.273628] ohci-pci: OHCI PCI platform driver
   954    [    3.278062] ohci-platform: OHCI generic platform driver
   955    [    3.283803] usbcore: registered new interface driver usb-storage
   956    [    3.289403] mousedev: PS/2 mouse device common for all mice
   957    [    3.295322] i2c /dev entries driver
   958    [    3.300958] sdhci: Secure Digital Host Controller Interface driver
   959    [    3.304247] sdhci: Copyright(c) Pierre Ossman
   960    [    3.308564] Synopsys Designware Multimedia Card Interface Driver
   961    [    3.315853] meson-gx-mmc d0072000.mmc: Got CD GPIO
   962    [    3.346332] meson-gx-mmc d0074000.mmc: allocated mmc-pwrseq
   963    [    3.377634] sdhci-pltfm: SDHCI platform and OF driver helper
   964    [    3.378540] ledtrig-cpu: registered to indicate activity on CPUs
   965    [    3.384520] meson-sm: secure-monitor enabled
   966    [    3.388582] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
   967    [    3.395889] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
   968    [    3.403825] mmc0: new high speed SDHC card at address 59b4
   969    [    3.413773] mmcblk0: mmc0:59b4 SDU1  29.5 GiB
   970    [    3.420178]  mmcblk0: p1 p2
   971    [    3.421997] hid: raw HID events driver (C) Jiri Kosina
   972    [    3.422720] usbcore: registered new interface driver usbhid
   973    [    3.428044] usbhid: USB HID core driver
   974    [    3.432131] platform-mhu c883c404.mailbox: Platform MHU Mailbox registered
   975    [    3.448747] NET: Registered protocol family 17
   976    [    3.449007] Key type dns_resolver registered
   977    [    3.452350] registered taskstats version 1
   978    [    3.455966] Loading compiled-in X.509 certificates
   979    [    3.460733] zswap: loaded using pool lzo/zbud
   980    [    3.465113] Key type ._fscrypt registered
   981    [    3.468949] Key type .fscrypt registered
   982    [    3.474301] Btrfs loaded, crc32c=crc32c-generic
   983    [    3.493643] mmc1: new HS200 MMC card at address 0001
   984    [    3.494529] mmcblk1: mmc1:0001 016G92 14.7 GiB
   985    [    3.497803] mmcblk1boot0: mmc1:0001 016G92 partition 1 4.00 MiB
   986    [    3.503797] mmcblk1boot1: mmc1:0001 016G92 partition 2 4.00 MiB
   987    [    3.506370] Key type encrypted registered
   988    [    3.509660] mmcblk1gp0: mmc1:0001 016G92 partition 4 8.00 MiB
   989    [    3.519153] mmcblk1rpmb: mmc1:0001 016G92 partition 3 512 KiB, chardev (243:0)
   990    [    3.532427] meson-drm d0100000.vpu: Queued 3 outputs on vpu
   991    [    3.532743] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
   992    [    3.538984] [drm] No driver support for vblank timestamp query.
   993    [    3.570490] meson-dw-hdmi c883a000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
   994    [    3.575196] meson-dw-hdmi c883a000.hdmi-tx: registered DesignWare HDMI I2C bus driver
   995    [    3.583155] meson-drm d0100000.vpu: bound c883a000.hdmi-tx (ops meson_dw_hdmi_ops)
   996    [    3.590506] [drm] Initialized meson 1.0.0 20161109 for d0100000.vpu on minor 0
   997    [    3.630979] Console: switching to colour frame buffer device 90x36
   998    [    3.651200] meson-drm d0100000.vpu: fb0: mesondrmfb frame buffer device
   999    [    3.658507] libphy: mdio_mux: probed
  1000    [    3.668973] libphy: mdio_mux: probed
  1001    [    3.669458] phy phy-d0078080.phy.2: unsupported PHY mode 5
  1002    [    3.674512] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  1003    [    3.677904] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
  1004    [    3.685612] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228f664 hci version 0x100 quirks 0x0000000002010010
  1005    [    3.694851] xhci-hcd xhci-hcd.0.auto: irq 39, io mem 0xc9000000
  1006    [    3.700956] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.05
  1007    [    3.709197] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1008    [    3.716338] usb usb1: Product: xHCI Host Controller
  1009    [    3.721166] usb usb1: Manufacturer: Linux 5.5.0-rc6-aml-s9xxx xhci-hcd
  1010    [    3.727638] usb usb1: SerialNumber: xhci-hcd.0.auto
  1011    [    3.732971] hub 1-0:1.0: USB hub found
  1012    [    3.736213] hub 1-0:1.0: 2 ports detected
  1013    [    3.740438] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  1014    [    3.745593] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
  1015    [    3.753190] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
  1016    [    3.759700] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
  1017    [    3.767965] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.05
  1018    [    3.776351] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1019    [    3.783507] usb usb2: Product: xHCI Host Controller
  1020    [    3.788342] usb usb2: Manufacturer: Linux 5.5.0-rc6-aml-s9xxx xhci-hcd
  1021    [    3.794807] usb usb2: SerialNumber: xhci-hcd.0.auto
  1022    [    3.800115] hub 2-0:1.0: USB hub found
  1023    [    3.803403] hub 2-0:1.0: config failed, hub doesn't have any ports! (err -19)
  1024    [    3.812210] meson-gx-mmc d0070000.mmc: allocated mmc-pwrseq
  1025    [    3.843436] scpi_protocol scpi: SCP Protocol legacy pre-1.0 firmware
  1026    [    3.860258] gx-sound-card sound: snd-soc-dummy-dai <-> c1105400.bus:audio-controller-0 mapping ok
  1027    [    3.871992] gx-sound-card sound: i2s-hifi <-> c1105400.bus:audio-controller-2 mapping ok
  1028    [    3.879733] gx-sound-card sound: ASoC: no DMI vendor name!
  1029    [    3.885968] printk: console [netcon0] enabled
  1030    [    3.889354] netconsole: network logging started
  1031    [    3.893810] hctosys: unable to open rtc device (rtc0)
  1032    [    3.896612] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
  1033    [    3.899028] ALSA device list:
  1034    [    3.907276]   #0: AMLGX
  1035    [    3.907521] mmc2: queuing unknown CIS tuple 0x80 (6 bytes)
  1036    [    3.915566] Freeing unused kernel memory: 960K
  1037    [    3.919452] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
  1038    [    3.919780] Run /init as init process
  1039    [    3.934273] mmc2: queuing unknown CIS tuple 0x80 (19 bytes)
  1040    [    3.961260] random: fast init done
  1041    [    4.017177] mmc2: new high speed SDIO card at address 0001
  1042    [    4.074520] usb 1-1: new high-speed USB device number 2 using xhci-hcd
  1043    [    4.095825] usb 1-1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.36
  1044    [    4.103271] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
  1045    [    4.110059] usb 1-1: Product: USB2.0 Hub
  1046    [    4.176186] hub 1-1:1.0: USB hub found
  1047    [    4.178935] hub 1-1:1.0: 4 ports detected
  1048    [    4.310488] usb 1-2: new high-speed USB device number 3 using xhci-hcd
  1049    [    4.340923] usb 1-2: New USB device found, idVendor=148f, idProduct=7601, bcdDevice= 0.00
  1050    [    4.348279] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
  1051    [    4.357563] usb 1-2: Product: 802.11 n WLAN
  1052    [    4.361305] usb 1-2: Manufacturer: MediaTek
  1053    [    4.364631] usb 1-2: SerialNumber: 1.0
  1054    [    5.096209] EXT4-fs (mmcblk0p2): mounted filesystem with writeback data mode. Opts: data=writeback
  1055    [    6.061107] systemd[1]: System time before build time, advancing clock.
  1056    [    6.207418] NET: Registered protocol family 10
  1057    [    6.281144] Segment Routing with IPv6
  1058    [    6.332035] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
  1059    [    6.365245] systemd[1]: Detected architecture arm64.
  1060    [    6.423428] systemd[1]: Set hostname to <mxqpro>.
  1061    [    6.457238] systemd[1]: Couldn't move remaining userspace processes, ignoring: Input/output error
  1062    [    7.168006] random: systemd: uninitialized urandom read (16 bytes read)
  1063    [    7.181362] random: systemd: uninitialized urandom read (16 bytes read)
  1064    [    7.185655] systemd[1]: Listening on udev Control Socket.
  1065    [    7.193341] random: systemd: uninitialized urandom read (16 bytes read)
  1066    [    7.200119] systemd[1]: Created slice system-systemd\x2dfsck.slice.
  1067    [    7.206197] systemd[1]: Reached target System Time Synchronized.
  1068    [    7.212326] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
  1069    [    7.220700] systemd[1]: Listening on Syslog Socket.
  1070    [    7.226206] systemd[1]: Condition check resulted in Arbitrary Executable File Formats File System Automount Point being skipped.
  1071    [    7.400684] EXT4-fs (mmcblk0p2): re-mounted. Opts: commit=600,errors=remount-ro
  1072    [    7.653696] systemd-journald[414]: Received request to flush runtime journal from PID 1
  1073    [    8.127667] mc: Linux media interface: v0.10
  1074    [    8.150658] videodev: Linux video capture interface: v2.00
  1075    [    8.190007] Registered IR keymap rc-empty
  1076    [    8.193464] rc rc0: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0
  1077    [    8.193567] input: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0/input0
  1078    [    8.196518] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
  1079    [    8.217739] meson-ir c8100580.ir: receiver initialized
  1080    [    8.256211] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
  1081    [    8.362349] Bluetooth: Core ver 2.22
  1082    [    8.364934] NET: Registered protocol family 31
  1083    [    8.368059] Bluetooth: HCI device and connection manager initialized
  1084    [    8.373468] Bluetooth: HCI socket layer initialized
  1085    [    8.378267] Bluetooth: L2CAP socket layer initialized
  1086    [    8.383632] lima d00c0000.gpu: IRQ ppmmu3 not found
  1087    [    8.388076] lima d00c0000.gpu: IRQ ppmmu4 not found
  1088    [    8.396142] lima d00c0000.gpu: IRQ ppmmu5 not found
  1089    [    8.398402] lima d00c0000.gpu: IRQ ppmmu6 not found
  1090    [    8.402910] Bluetooth: SCO socket layer initialized
  1091    [    8.406027] lima d00c0000.gpu: IRQ ppmmu7 not found
  1092    [    8.414208] lima d00c0000.gpu: gp - mali450 version major 0 minor 0
  1093    [    8.421823] lima d00c0000.gpu: pp0 - mali450 version major 0 minor 0
  1094    [    8.427037] lima d00c0000.gpu: pp1 - mali450 version major 0 minor 0
  1095    [    8.435164] lima d00c0000.gpu: pp2 - mali450 version major 0 minor 0
  1096    [    8.438062] lima d00c0000.gpu: IRQ pp3 not found
  1097    [    8.442570] lima d00c0000.gpu: IRQ pp4 not found
  1098    [    8.447234] lima d00c0000.gpu: IRQ pp5 not found
  1099    [    8.458533] lima d00c0000.gpu: IRQ pp6 not found
  1100    [    8.460376] lima d00c0000.gpu: IRQ pp7 not found
  1101    [    8.464141] lima d00c0000.gpu: l2 cache 8K, 4-way, 64byte cache line, 128bit external bus
  1102    [    8.472238] lima d00c0000.gpu: l2 cache 64K, 4-way, 64byte cache line, 128bit external bus
  1103    [    8.481502] lima d00c0000.gpu: bus rate = 166666667
  1104    [    8.485293] lima d00c0000.gpu: mod rate = 744000000
  1105    [    8.490607] [drm] Initialized lima 1.0.0 20190217 for d00c0000.gpu on minor 1
  1106    [    8.605049] Bluetooth: HCI UART driver ver 2.3
  1107    [    8.611953] Bluetooth: HCI UART protocol H4 registered
  1108    [    8.613635] Bluetooth: HCI UART protocol BCSP registered
  1109    [    8.626129] Bluetooth: HCI UART protocol LL registered
  1110    [    8.628225] Bluetooth: HCI UART protocol ATH3K registered
  1111    [    8.638573] Bluetooth: HCI UART protocol Three-wire (H5) registered
  1112    [    8.641023] Bluetooth: HCI UART protocol Intel registered
  1113    [    8.647141] Bluetooth: HCI UART protocol Broadcom registered
  1114    [    8.647275] hci_uart_bcm serial0-0: serial0-0 supply vbat not found, using dummy regulator
  1115    [    8.649068] cfg80211: Loading compiled-in X.509 certificates for regulatory database
  1116    [    8.658160] Bluetooth: HCI UART protocol QCA registered
  1117    [    8.666731] hci_uart_bcm serial0-0: serial0-0 supply vddio not found, using dummy regulator
  1118    [    8.672767] Bluetooth: HCI UART protocol AG6XX registered
  1119    [    8.672863] Bluetooth: HCI UART protocol Marvell registered
  1120    [    8.711963] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
  1121    [    8.715916] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
  1122    [    8.724809] cfg80211: failed to load regulatory.db
  1123    [    8.855376] brcmfmac: F1 signature read @0x18000000=0x16034334
  1124    [    8.862780] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4334-sdio for chip BCM4334/3
  1125    [    8.870669] usbcore: registered new interface driver brcmfmac
  1126    [    8.907337] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.amlogic,p212.txt failed with error -2
  1127    [    8.917543] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.txt failed with error -2
  1128    [    8.966861] usb 1-2: reset high-speed USB device number 3 using xhci-hcd
  1129    [    8.990168] mt7601u 1-2:1.0: ASIC revision: 76010001 MAC revision: 76010500
  1130    [    9.020609] mt7601u 1-2:1.0: EEPROM ver:0d fae:00
  1131    [    9.087757] Bluetooth: hci0: BCM: chip id 68
  1132    [    9.091308] Bluetooth: hci0: BCM: features 0x0f
  1133    [    9.093032] Bluetooth: hci0: BCM4334B0
  1134    [    9.097456] Bluetooth: hci0: BCM4334B0 (002.001.013) build 0000
  1135    [    9.097567] bluetooth hci0: Direct firmware load for brcm/BCM4334B0.hcd failed with error -2
  1136    [    9.111747] Bluetooth: hci0: BCM: Patch brcm/BCM4334B0.hcd not found
  1137    [    9.225190] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
  1138    [    9.226144] usbcore: registered new interface driver mt7601u
  1139    [    9.934519] brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x50
  1140    [   10.054188] zram: Added device: zram0
  1141    [   10.057679] zram: Added device: zram1
  1142    [   10.064074] zram: Added device: zram2
  1143    [   10.097602] meson8b-dwmac c9410000.ethernet eth0: PHY [0.e40908ff:08] driver [Meson GXL Internal PHY]
  1144    [   10.117679] zram1: detected capacity change from 0 to 912879616
  1145    [   10.122547] meson8b-dwmac c9410000.ethernet eth0: No Safety Features support found
  1146    [   10.128700] meson8b-dwmac c9410000.ethernet eth0: PTP not supported by HW
  1147    [   10.134755] meson8b-dwmac c9410000.ethernet eth0: configuring for phy/rmii link mode
  1148    [   10.792532] random: crng init done
  1149    [   10.795025] random: 7 urandom warning(s) missed due to ratelimiting
  1150    [   10.962942] Adding 891480k swap on /dev/zram1.  Priority:5 extents:1 across:891480k SSFS
  1151
  1152    ### armbian-release:
  1153
  1154    # PLEASE DO NOT EDIT THIS FILE
  1155    BOARD=aml-s9xxx
  1156    BOARD_NAME="AML-S9xxx"
  1157    BOARDFAMILY=aml-s9xxx
  1158    BUILD_REPOSITORY_URL=https://github.com/150balbes/Build-Armbian.git
  1159    BUILD_REPOSITORY_COMMIT=62b8c07-dirty
  1160    DISTRIBUTION_CODENAME=buster
  1161    DISTRIBUTION_STATUS=supported
  1162    VERSION=20.02.0-rc1.037
  1163    LINUXFAMILY=aml-s9xxx
  1164    BRANCH=current
  1165    ARCH=arm64
  1166    IMAGE_TYPE=nightly
  1167    BOARD_TYPE=conf
  1168    INITRD_ARCH=arm64
  1169    KERNEL_IMAGE_TYPE=Image
  1170
  1171    ### boot environment:
  1172
  1173    ODROIDN2-UBOOT-CONFIG
  1174    setenv env_addr 0x10400000
  1175    setenv kernel_addr 0x11000000
  1176    setenv initrd_addr 0x13000000
  1177    setenv dtb_addr 0x1000000
  1178    if test "${devtype}" = ""; then setenv devtype "mmc"; fi
  1179    load ${devtype} ${devnum} ${env_addr} uEnv.txt && env import -t ${env_addr} ${filesize}
  1180    setenv bootargs ${APPEND}
  1181    load ${devtype} ${devnum} ${kernel_addr} ${LINUX}
  1182    load ${devtype} ${devnum} ${initrd_addr} ${INITRD}
  1183    load ${devtype} ${devnum} ${dtb_addr} ${FDT}
  1184    fdt addr ${dtb_addr}
  1185    booti ${kernel_addr} ${initrd_addr} ${dtb_addr}
  1186
  1187    ### lsusb:
  1188
  1189    Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
  1190    Bus 001 Device 003: ID 148f:7601 Ralink Technology, Corp. MT7601U Wireless Adapter
  1191    Bus 001 Device 002: ID 05e3:0608 Genesys Logic, Inc. Hub
  1192    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  1193
  1194    ### lscpu:
  1195
  1196    Architecture:        aarch64
  1197    Byte Order:          Little Endian
  1198    CPU(s):              4
  1199    On-line CPU(s) list: 0-3
  1200    Thread(s) per core:  1
  1201    Core(s) per socket:  4
  1202    Socket(s):           1
  1203    Vendor ID:           ARM
  1204    Model:               4
  1205    Model name:          Cortex-A53
  1206    Stepping:            r0p4
  1207    CPU max MHz:         1512,0000
  1208    CPU min MHz:         100,0000
  1209    BogoMIPS:            48.00
  1210    L1d cache:           unknown size
  1211    L1i cache:           unknown size
  1212    L2 cache:            unknown size
  1213    Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1214
  1215    ### cpuinfo:
  1216
  1217    processor    : 0
  1218    model name    : ARMv8 Processor rev 4 (v8l)
  1219    BogoMIPS    : 48.00
  1220    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1221    CPU implementer    : 0x41
  1222    CPU architecture: 8
  1223    CPU variant    : 0x0
  1224    CPU part    : 0xd03
  1225    CPU revision    : 4
  1226
  1227    processor    : 1
  1228    model name    : ARMv8 Processor rev 4 (v8l)
  1229    BogoMIPS    : 48.00
  1230    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1231    CPU implementer    : 0x41
  1232    CPU architecture: 8
  1233    CPU variant    : 0x0
  1234    CPU part    : 0xd03
  1235    CPU revision    : 4
  1236
  1237    processor    : 2
  1238    model name    : ARMv8 Processor rev 4 (v8l)
  1239    BogoMIPS    : 48.00
  1240    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1241    CPU implementer    : 0x41
  1242    CPU architecture: 8
  1243    CPU variant    : 0x0
  1244    CPU part    : 0xd03
  1245    CPU revision    : 4
  1246
  1247    processor    : 3
  1248    model name    : ARMv8 Processor rev 4 (v8l)
  1249    BogoMIPS    : 48.00
  1250    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1251    CPU implementer    : 0x41
  1252    CPU architecture: 8
  1253    CPU variant    : 0x0
  1254    CPU part    : 0xd03
  1255    CPU revision    : 4
  1256
  1257
  1258    ### meminfo:
  1259
  1260    MemTotal:        1782968 kB
  1261    MemFree:         1610664 kB
  1262    MemAvailable:    1665824 kB
  1263    Buffers:           11472 kB
  1264    Cached:            52268 kB
  1265    SwapCached:            0 kB
  1266    Active:            50352 kB
  1267    Inactive:          33304 kB
  1268    Active(anon):      20552 kB
  1269    Inactive(anon):     2580 kB
  1270    Active(file):      29800 kB
  1271    Inactive(file):    30724 kB
  1272    Unevictable:           0 kB
  1273    Mlocked:               0 kB
  1274    SwapTotal:        891480 kB
  1275    SwapFree:         891480 kB
  1276    Dirty:               520 kB
  1277    Writeback:             0 kB
  1278    AnonPages:         20500 kB
  1279    Mapped:            21228 kB
  1280    Shmem:              2684 kB
  1281    KReclaimable:      17752 kB
  1282    Slab:              54268 kB
  1283    SReclaimable:      17752 kB
  1284    SUnreclaim:        36516 kB
  1285    KernelStack:        2780 kB
  1286    PageTables:         1568 kB
  1287    NFS_Unstable:          0 kB
  1288    Bounce:                0 kB
  1289    WritebackTmp:          0 kB
  1290    CommitLimit:     1782964 kB
  1291    Committed_AS:      77144 kB
  1292    VmallocTotal:   135290159040 kB
  1293    VmallocUsed:       16724 kB
  1294    VmallocChunk:          0 kB
  1295    Percpu:             1312 kB
  1296    CmaTotal:         262144 kB
  1297    CmaFree:          258460 kB
  1298    HugePages_Total:       0
  1299    HugePages_Free:        0
  1300    HugePages_Rsvd:        0
  1301    HugePages_Surp:        0
  1302    Hugepagesize:       2048 kB
  1303    Hugetlb:               0 kB
  1304
  1305    ### virtual memory:
  1306
  1307    vm.admin_reserve_kbytes = 8192
  1308    vm.block_dump = 0
  1309    vm.compact_unevictable_allowed = 1
  1310    vm.dirty_background_bytes = 0
  1311    vm.dirty_background_ratio = 10
  1312    vm.dirty_bytes = 0
  1313    vm.dirty_expire_centisecs = 3000
  1314    vm.dirty_ratio = 20
  1315    vm.dirtytime_expire_seconds = 43200
  1316    vm.dirty_writeback_centisecs = 500
  1317    vm.extfrag_threshold = 500
  1318    vm.hugetlb_shm_group = 0
  1319    vm.laptop_mode = 0
  1320    vm.legacy_va_layout = 0
  1321    vm.lowmem_reserve_ratio = 256    256    32    0
  1322    vm.max_map_count = 65530
  1323    vm.min_free_kbytes = 4914
  1324    vm.mmap_min_addr = 4096
  1325    vm.mmap_rnd_bits = 18
  1326    vm.nr_hugepages = 0
  1327    vm.nr_overcommit_hugepages = 0
  1328    vm.oom_dump_tasks = 1
  1329    vm.oom_kill_allocating_task = 0
  1330    vm.overcommit_kbytes = 0
  1331    vm.overcommit_memory = 0
  1332    vm.overcommit_ratio = 50
  1333    vm.page-cluster = 0
  1334    vm.panic_on_oom = 0
  1335    vm.percpu_pagelist_fraction = 0
  1336    vm.stat_interval = 1
  1337    vm.swappiness = 100
  1338    vm.user_reserve_kbytes = 55239
  1339    vm.vfs_cache_pressure = 100
  1340    vm.watermark_boost_factor = 15000
  1341    vm.watermark_scale_factor = 10
  1342
  1343    ### ip addr:
  1344
  1345    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
  1346        link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  1347        inet XXX.XXX.0.1/8 scope host lo
  1348           valid_lft forever preferred_lft forever
  1349        inet6 ::1/128 scope host
  1350           valid_lft forever preferred_lft forever
  1351    2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
  1352        link/ether 00:df:06:00:00:0b brd ff:ff:ff:ff:ff:ff
  1353    3: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  1354        link/ether 00:36:76:61:0b:24 brd ff:ff:ff:ff:ff:ff
  1355
  1356    ### partitions:
  1357
  1358    major minor  #blocks  name
  1359
  1360     179        0   30924800 mmcblk0
  1361     179        1     262144 mmcblk0p1
  1362     179        2   30337024 mmcblk0p2
  1363     179       32   15384576 mmcblk1
  1364     179      128       8192 mmcblk1gp0
  1365     254        1     891484 zram1
  1366
  1367    ### df:
  1368
  1369    udev             738M      0  738M   0% /dev
  1370    tmpfs            175M   2,7M  172M   2% /run
  1371    /dev/mmcblk0p2    29G    10G   19G  36% /
  1372    tmpfs            871M      0  871M   0% /dev/shm
  1373    tmpfs            5,0M   4,0K  5,0M   1% /run/lock
  1374    tmpfs            871M      0  871M   0% /sys/fs/cgroup
  1375    tmpfs            871M      0  871M   0% /tmp
  1376    /dev/mmcblk0p1   256M    76M  180M  30% /boot
  1377
  1378    ### lsblk:
  1379
  1380    NAME         FSTYPE   SIZE MOUNTPOINT UUID
  1381    mmcblk0              29,5G
  1382    ├─mmcblk0p1  vfat     256M /boot      50FC-6AC8
  1383    └─mmcblk0p2  ext4      29G /          3e297ac1-e4e4-4ab1-bc57-47c07d0422ba
  1384    mmcblk1              14,7G
  1385    mmcblk1boot0            4M
  1386    mmcblk1boot1            4M
  1387    mmcblk1gp0              8M
  1388
  1389    ### zramctl:
  1390
  1391    NAME       ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT
  1392    /dev/zram1 lzo         870,6M   4K   81B   12K       4 [SWAP]
  1393
  1394    ### mtab:
  1395
  1396    /dev/mmcblk0p1 /boot vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro 0 0
  1397    /dev/mmcblk0p2 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  1398
  1399    ### mmc0:59b4 info:
  1400
  1401                   fwrev: 0x0
  1402                  uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SDU1  MODALIAS=mmc:block
  1403                     cid: 1b534d53445531201014a136d4013800
  1404                     rca: 0x59b4
  1405                     csd: 400e00325b590000ebef7f800a400000
  1406                  manfid: 0x00001b
  1407                     ocr: 0x00200000
  1408    preferred_erase_size: 4194304
  1409                    type: SD
  1410                   hwrev: 0x1
  1411                    date: 08/2019
  1412                     dsr: 0x404
  1413              erase_size: 512
  1414                   oemid: 0x534d
  1415                  serial: 0x14a136d4
  1416                     ssr: 0000000005000000040090000811391e00089a342f01000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  1417                     scr: 0235844300000000
  1418                    name: SDU1
  1419
  1420    ### mmc1:0001 info:
  1421
  1422                   fwrev: 0x0
  1423                  uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=016G92 MODALIAS=mmc:block
  1424                     cid: 11010030313647393201d3d1a4db1100
  1425             rel_sectors: 0x10
  1426                     rca: 0x0001
  1427            pre_eol_info: 0x00
  1428                     csd: d00e00320f5903ffffffffef92400000
  1429                  manfid: 0x000011
  1430                     ocr: 0x00200000
  1431    preferred_erase_size: 4194304
  1432    enhanced_area_offset: 18446744073709551594
  1433      raw_rpmb_size_mult: 0x4
  1434                    type: MMC
  1435                   hwrev: 0x0
  1436                    date: 01/2014
  1437                     prv: 0x1
  1438             ffu_capable: 0
  1439                     dsr: 0x404
  1440              erase_size: 4194304
  1441               life_time: 0x00 0x00
  1442      enhanced_area_size: 4294967274
  1443                   oemid: 0x0100
  1444                  serial: 0xd3d1a4db
  1445                 cmdq_en: 0
  1446                     rev: 0x6
  1447                    name: 016G92
  1448
  1449    ### Boot system health:
  1450
  1451    Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU
  1452    07:51:56: 1512MHz  0.47  51%  24%  15%   0%  10%   1% 41.0°C
  1453    07:51:56: 1512MHz  0.47  60%   7%  11%   0%  40%   0% 40.0°C
  1454    07:51:57: 1512MHz  0.47  74%  12%  24%   0%  34%   2% 41.0°C
  1455    07:51:57: 1512MHz  0.47  52%   6%  12%   1%  30%   0% 41.0°C
  1456    07:51:57: 1512MHz  0.60  43%   5%  11%   0%  24%   1% 40.0°C
  1457
  1458    ### Activated 1 lzo zram swap devices with 870 MB each
  1459
  1460
  1461    lun mar 22 11:17:04 CET 2021 | AML-S9xxx | 20.02.0-rc1.037 | arm64 | aarch64 | 5.5.0-rc6-aml-s9xxx
  1462
  1463    ### dmesg:
  1464
  1465    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
  1466    [    0.000000] Linux version 5.5.0-rc6-aml-s9xxx (root@vbox) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #rc1.037 SMP PREEMPT Wed Feb 5 15:59:04 MSK 2020
  1467    [    0.000000] Machine model: Amlogic Meson GXL (S905X) P212 Development Board
  1468    [    0.000000] efi: Getting EFI parameters from FDT:
  1469    [    0.000000] efi: UEFI not found.
  1470    [    0.000000] Reserved memory: created CMA memory pool at 0x0000000063400000, size 256 MiB
  1471    [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
  1472    [    0.000000] On node 0 totalpages: 477952
  1473    [    0.000000]   DMA zone: 4032 pages used for memmap
  1474    [    0.000000]   DMA zone: 0 pages reserved
  1475    [    0.000000]   DMA zone: 248576 pages, LIFO batch:63
  1476    [    0.000000]   DMA32 zone: 3584 pages used for memmap
  1477    [    0.000000]   DMA32 zone: 229376 pages, LIFO batch:63
  1478    [    0.000000] psci: probing for conduit method from DT.
  1479    [    0.000000] psci: PSCIv0.2 detected in firmware.
  1480    [    0.000000] psci: Using standard PSCI v0.2 function IDs
  1481    [    0.000000] psci: Trusted OS migration not required
  1482    [    0.000000] percpu: Embedded 22 pages/cpu s50392 r8192 d31528 u90112
  1483    [    0.000000] pcpu-alloc: s50392 r8192 d31528 u90112 alloc=22*4096
  1484    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
  1485    [    0.000000] Detected VIPT I-cache on CPU0
  1486    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 470336
  1487    [    0.000000] Kernel command line: root=LABEL=ROOTFS rootflags=data=writeback rw console=ttyAML0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 mac=00:df:06:00:00:0b
  1488    [    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
  1489    [    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
  1490    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
  1491    [    0.000000] software IO TLB: mapped [mem 0x3bfff000-0x3ffff000] (64MB)
  1492    [    0.000000] Memory: 1509616K/1911808K available (14460K kernel code, 1434K rwdata, 5884K rodata, 960K init, 927K bss, 140048K reserved, 262144K cma-reserved)
  1493    [    0.000000] random: get_random_u64 called from cache_random_seq_create+0x7c/0x150 with crng_init=0
  1494    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
  1495    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
  1496    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
  1497    [    0.000000]     Tasks RCU enabled.
  1498    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
  1499    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
  1500    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
  1501    [    0.000000] GIC: Using split EOI/Deactivate mode
  1502    [    0.000000] irq_meson_gpio: 110 to 8 gpio interrupt mux initialized
  1503    [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
  1504    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
  1505    [    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
  1506    [    0.000353] Console: colour dummy device 80x25
  1507    [    0.000653] printk: console [tty0] enabled
  1508    [    0.000695] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
  1509    [    0.000715] pid_max: default: 32768 minimum: 301
  1510    [    0.000841] LSM: Security Framework initializing
  1511    [    0.000891] SELinux:  Initializing.
  1512    [    0.000968] *** VALIDATE SELinux ***
  1513    [    0.001032] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
  1514    [    0.001060] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
  1515    [    0.001125] *** VALIDATE tmpfs ***
  1516    [    0.001529] *** VALIDATE proc ***
  1517    [    0.001751] *** VALIDATE cgroup1 ***
  1518    [    0.001766] *** VALIDATE cgroup2 ***
  1519    [    0.024016] ASID allocator initialised with 32768 entries
  1520    [    0.032000] rcu: Hierarchical SRCU implementation.
  1521    [    0.042081] EFI services will not be available.
  1522    [    0.048055] smp: Bringing up secondary CPUs ...
  1523    [    0.080284] Detected VIPT I-cache on CPU1
  1524    [    0.080336] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
  1525    [    0.112321] Detected VIPT I-cache on CPU2
  1526    [    0.112364] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
  1527    [    0.144370] Detected VIPT I-cache on CPU3
  1528    [    0.144414] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
  1529    [    0.144492] smp: Brought up 1 node, 4 CPUs
  1530    [    0.144556] SMP: Total of 4 processors activated.
  1531    [    0.144568] CPU features: detected: 32-bit EL0 Support
  1532    [    0.144580] CPU features: detected: CRC32 instructions
  1533    [    0.144886] CPU: All CPU(s) started at EL2
  1534    [    0.144908] alternatives: patching kernel code
  1535    [    0.146008] devtmpfs: initialized
  1536    [    0.151153] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
  1537    [    0.151196] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
  1538    [    0.158017] xor: measuring software checksum speed
  1539    [    0.196363]    8regs     :  2375.000 MB/sec
  1540    [    0.236393]    32regs    :  2724.000 MB/sec
  1541    [    0.276431]    arm64_neon:  2406.000 MB/sec
  1542    [    0.276441] xor: using function: 32regs (2724.000 MB/sec)
  1543    [    0.276496] pinctrl core: initialized pinctrl subsystem
  1544    [    0.277148] thermal_sys: Registered thermal governor 'step_wise'
  1545    [    0.277317] DMI not present or invalid.
  1546    [    0.277677] NET: Registered protocol family 16
  1547    [    0.281248] DMA: preallocated 256 KiB pool for atomic allocations
  1548    [    0.281296] audit: initializing netlink subsys (disabled)
  1549    [    0.281515] audit: type=2000 audit(0.280:1): state=initialized audit_enabled=0 res=1
  1550    [    0.282597] cpuidle: using governor ladder
  1551    [    0.282638] cpuidle: using governor menu
  1552    [    0.283009] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
  1553    [    0.283728] Serial: AMBA PL011 UART driver
  1554    [    0.297704] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
  1555    [    0.297731] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
  1556    [    0.297744] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
  1557    [    0.297756] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
  1558    [    0.301423] cryptd: max_cpu_qlen set to 1000
  1559    [    0.376690] raid6: neonx8   gen()  1616 MB/s
  1560    [    0.444751] raid6: neonx8   xor()  1504 MB/s
  1561    [    0.512789] raid6: neonx4   gen()  1562 MB/s
  1562    [    0.580844] raid6: neonx4   xor()  1471 MB/s
  1563    [    0.648886] raid6: neonx2   gen()  1200 MB/s
  1564    [    0.716949] raid6: neonx2   xor()  1216 MB/s
  1565    [    0.784989] raid6: neonx1   gen()   787 MB/s
  1566    [    0.853076] raid6: neonx1   xor()   914 MB/s
  1567    [    0.921136] raid6: int64x8  gen()  1195 MB/s
  1568    [    0.989153] raid6: int64x8  xor()   769 MB/s
  1569    [    1.057220] raid6: int64x4  gen()  1029 MB/s
  1570    [    1.125263] raid6: int64x4  xor()   752 MB/s
  1571    [    1.193316] raid6: int64x2  gen()   728 MB/s
  1572    [    1.261380] raid6: int64x2  xor()   615 MB/s
  1573    [    1.329449] raid6: int64x1  gen()   485 MB/s
  1574    [    1.397480] raid6: int64x1  xor()   468 MB/s
  1575    [    1.397490] raid6: using algorithm neonx8 gen() 1616 MB/s
  1576    [    1.397501] raid6: .... xor() 1504 MB/s, rmw enabled
  1577    [    1.397511] raid6: using neon recovery algorithm
  1578    [    1.397791] ACPI: Interpreter disabled.
  1579    [    1.398966] iommu: Default domain type: Translated
  1580    [    1.399259] vgaarb: loaded
  1581    [    1.399805] SCSI subsystem initialized
  1582    [    1.400017] libata version 3.00 loaded.
  1583    [    1.400230] usbcore: registered new interface driver usbfs
  1584    [    1.400274] usbcore: registered new interface driver hub
  1585    [    1.400338] usbcore: registered new device driver usb
  1586    [    1.400735] pps_core: LinuxPPS API ver. 1 registered
  1587    [    1.400747] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
  1588    [    1.400771] PTP clock support registered
  1589    [    1.400804] EDAC MC: Ver: 3.0.0
  1590    [    1.401402] FPGA manager framework
  1591    [    1.401506] Advanced Linux Sound Architecture Driver Initialized.
  1592    [    1.401972] NetLabel: Initializing
  1593    [    1.401986] NetLabel:  domain hash size = 128
  1594    [    1.401995] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
  1595    [    1.402048] NetLabel:  unlabeled traffic allowed by default
  1596    [    1.402565] clocksource: Switched to clocksource arch_sys_counter
  1597    [    1.402591] *** VALIDATE bpf ***
  1598    [    1.402832] VFS: Disk quotas dquot_6.6.0
  1599    [    1.402892] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
  1600    [    1.403008] FS-Cache: Loaded
  1601    [    1.403019] *** VALIDATE ramfs ***
  1602    [    1.403040] *** VALIDATE hugetlbfs ***
  1603    [    1.403408] pnp: PnP ACPI: disabled
  1604    [    1.408468] NET: Registered protocol family 2
  1605    [    1.408965] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
  1606    [    1.409013] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
  1607    [    1.409131] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
  1608    [    1.409344] TCP: Hash tables configured (established 16384 bind 16384)
  1609    [    1.409501] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
  1610    [    1.409555] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
  1611    [    1.409773] NET: Registered protocol family 1
  1612    [    1.410262] RPC: Registered named UNIX socket transport module.
  1613    [    1.410284] RPC: Registered udp transport module.
  1614    [    1.410294] RPC: Registered tcp transport module.
  1615    [    1.410303] RPC: Registered tcp NFSv4.1 backchannel transport module.
  1616    [    1.410318] NET: Registered protocol family 44
  1617    [    1.410339] PCI: CLS 0 bytes, default 64
  1618    [    1.410535] Trying to unpack rootfs image as initramfs...
  1619    [    1.872260] Freeing initrd memory: 10248K
  1620    [    1.873053] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
  1621    [    2.086883] Initialise system trusted keyrings
  1622    [    2.087111] workingset: timestamp_bits=46 max_order=19 bucket_order=0
  1623    [    2.092264] zbud: loaded
  1624    [    2.093497] squashfs: version 4.0 (2009/01/31) Phillip Lougher
  1625    [    2.093774] FS-Cache: Netfs 'nfs' registered for caching
  1626    [    2.094296] NFS: Registering the id_resolver key type
  1627    [    2.094334] Key type id_resolver registered
  1628    [    2.094343] Key type id_legacy registered
  1629    [    2.094359] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
  1630    [    2.094372] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
  1631    [    2.095575] FS-Cache: Netfs 'cifs' registered for caching
  1632    [    2.095898] Key type cifs.spnego registered
  1633    [    2.095920] Key type cifs.idmap registered
  1634    [    2.095942] ntfs: driver 2.1.32 [Flags: R/W].
  1635    [    2.096545] JFS: nTxBlock = 8192, nTxLock = 65536
  1636    [    2.102466] SGI XFS with ACLs, security attributes, realtime, quota, no debug enabled
  1637    [    2.103899] *** VALIDATE xfs ***
  1638    [    2.104193] ocfs2: Registered cluster interface o2cb
  1639    [    2.104407] OCFS2 User DLM kernel interface loaded
  1640    [    2.105834] *** VALIDATE gfs2 ***
  1641    [    2.106104] gfs2: GFS2 installed
  1642    [    2.107087] aufs 5.5-20200203
  1643    [    2.127652] Key type asymmetric registered
  1644    [    2.127677] Asymmetric key parser 'x509' registered
  1645    [    2.127688] Asymmetric key parser 'pkcs8' registered
  1646    [    2.127758] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
  1647    [    2.127963] io scheduler mq-deadline registered
  1648    [    2.127978] io scheduler kyber registered
  1649    [    2.128172] io scheduler bfq registered
  1650    [    2.140736] soc soc0: Amlogic Meson GXL (S905X) Revision 21:b (82:2) Detected
  1651    [    2.144299] Serial: 8250/16550 driver, 5 ports, IRQ sharing enabled
  1652    [    2.145988] Serial: AMBA driver
  1653    [    2.146346] c11084c0.serial: ttyAML6 at MMIO 0xc11084c0 (irq = 10, base_baud = 1500000) is a meson_uart
  1654    [    2.146497] serial serial0: tty port ttyAML6 registered
  1655    [    2.146774] c81004c0.serial: ttyAML0 at MMIO 0xc81004c0 (irq = 13, base_baud = 1500000) is a meson_uart
  1656    [    3.122238] printk: console [ttyAML0] enabled
  1657    [    3.138300] brd: module loaded
  1658    [    3.146945] loop: module loaded
  1659    [    3.149310] libphy: Fixed MDIO Bus: probed
  1660    [    3.149970] meson8b-dwmac c9410000.ethernet: IRQ eth_wake_irq not found
  1661    [    3.155116] meson8b-dwmac c9410000.ethernet: IRQ eth_lpi not found
  1662    [    3.161324] meson8b-dwmac c9410000.ethernet: PTP uses main clock
  1663    [    3.167175] meson8b-dwmac c9410000.ethernet: no reset control found
  1664    [    3.173867] meson8b-dwmac c9410000.ethernet: User ID: 0x11, Synopsys ID: 0x37
  1665    [    3.180465] meson8b-dwmac c9410000.ethernet:     DWMAC1000
  1666    [    3.185628] meson8b-dwmac c9410000.ethernet: DMA HW capability register supported
  1667    [    3.193045] meson8b-dwmac c9410000.ethernet: RX Checksum Offload Engine supported
  1668    [    3.200463] meson8b-dwmac c9410000.ethernet: COE Type 2
  1669    [    3.205635] meson8b-dwmac c9410000.ethernet: TX Checksum insertion supported
  1670    [    3.212622] meson8b-dwmac c9410000.ethernet: Wake-Up On Lan supported
  1671    [    3.219035] meson8b-dwmac c9410000.ethernet: Normal descriptors
  1672    [    3.224871] meson8b-dwmac c9410000.ethernet: Ring mode enabled
  1673    [    3.230650] meson8b-dwmac c9410000.ethernet: Enable RX Mitigation via HW Watchdog Timer
  1674    [    3.238770] libphy: stmmac: probed
  1675    [    3.243317] VFIO - User Level meta-driver version: 0.3
  1676    [    3.248583] dwc3 c9000000.dwc3: Failed to get clk 'ref': -2
  1677    [    3.253459] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
  1678    [    3.259061] ehci-pci: EHCI PCI platform driver
  1679    [    3.263499] ehci-platform: EHCI generic platform driver
  1680    [    3.268798] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
  1681    [    3.274737] ohci-pci: OHCI PCI platform driver
  1682    [    3.279174] ohci-platform: OHCI generic platform driver
  1683    [    3.284915] usbcore: registered new interface driver usb-storage
  1684    [    3.290479] mousedev: PS/2 mouse device common for all mice
  1685    [    3.296429] i2c /dev entries driver
  1686    [    3.302079] sdhci: Secure Digital Host Controller Interface driver
  1687    [    3.305363] sdhci: Copyright(c) Pierre Ossman
  1688    [    3.309674] Synopsys Designware Multimedia Card Interface Driver
  1689    [    3.316973] meson-gx-mmc d0072000.mmc: Got CD GPIO
  1690    [    3.347434] meson-gx-mmc d0074000.mmc: allocated mmc-pwrseq
  1691    [    3.375068] sdhci-pltfm: SDHCI platform and OF driver helper
  1692    [    3.376044] ledtrig-cpu: registered to indicate activity on CPUs
  1693    [    3.381997] meson-sm: secure-monitor enabled
  1694    [    3.386196] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
  1695    [    3.393305] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
  1696    [    3.409504] mmc0: new high speed SDHC card at address 59b4
  1697    [    3.410552] mmcblk0: mmc0:59b4 SDU1  29.5 GiB
  1698    [    3.415991]  mmcblk0: p1 p2
  1699    [    3.418801] hid: raw HID events driver (C) Jiri Kosina
  1700    [    3.421870] usbcore: registered new interface driver usbhid
  1701    [    3.427236] usbhid: USB HID core driver
  1702    [    3.431362] platform-mhu c883c404.mailbox: Platform MHU Mailbox registered
  1703    [    3.447844] NET: Registered protocol family 17
  1704    [    3.448108] Key type dns_resolver registered
  1705    [    3.451482] registered taskstats version 1
  1706    [    3.454976] Loading compiled-in X.509 certificates
  1707    [    3.459843] zswap: loaded using pool lzo/zbud
  1708    [    3.464174] Key type ._fscrypt registered
  1709    [    3.467976] Key type .fscrypt registered
  1710    [    3.472893] Btrfs loaded, crc32c=crc32c-generic
  1711    [    3.493551] mmc1: new HS200 MMC card at address 0001
  1712    [    3.498597] mmcblk1: mmc1:0001 016G92 14.7 GiB
  1713    [    3.499083] mmcblk1boot0: mmc1:0001 016G92 partition 1 4.00 MiB
  1714    [    3.499576] Key type encrypted registered
  1715    [    3.503823] mmcblk1boot1: mmc1:0001 016G92 partition 2 4.00 MiB
  1716    [    3.513683] mmcblk1gp0: mmc1:0001 016G92 partition 4 8.00 MiB
  1717    [    3.519208] mmcblk1rpmb: mmc1:0001 016G92 partition 3 512 KiB, chardev (243:0)
  1718    [    3.527032] meson-drm d0100000.vpu: Queued 3 outputs on vpu
  1719    [    3.532002] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
  1720    [    3.538154] [drm] No driver support for vblank timestamp query.
  1721    [    3.570617] meson-dw-hdmi c883a000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
  1722    [    3.575269] meson-dw-hdmi c883a000.hdmi-tx: registered DesignWare HDMI I2C bus driver
  1723    [    3.583292] meson-drm d0100000.vpu: bound c883a000.hdmi-tx (ops meson_dw_hdmi_ops)
  1724    [    3.590598] [drm] Initialized meson 1.0.0 20161109 for d0100000.vpu on minor 0
  1725    [    3.632196] Console: switching to colour frame buffer device 90x36
  1726    [    3.652422] meson-drm d0100000.vpu: fb0: mesondrmfb frame buffer device
  1727    [    3.659677] libphy: mdio_mux: probed
  1728    [    3.670179] libphy: mdio_mux: probed
  1729    [    3.670701] phy phy-d0078080.phy.2: unsupported PHY mode 5
  1730    [    3.675722] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  1731    [    3.679109] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
  1732    [    3.686820] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228f664 hci version 0x100 quirks 0x0000000002010010
  1733    [    3.696039] xhci-hcd xhci-hcd.0.auto: irq 39, io mem 0xc9000000
  1734    [    3.702161] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.05
  1735    [    3.710506] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1736    [    3.717655] usb usb1: Product: xHCI Host Controller
  1737    [    3.722483] usb usb1: Manufacturer: Linux 5.5.0-rc6-aml-s9xxx xhci-hcd
  1738    [    3.728951] usb usb1: SerialNumber: xhci-hcd.0.auto
  1739    [    3.734300] hub 1-0:1.0: USB hub found
  1740    [    3.737543] hub 1-0:1.0: 2 ports detected
  1741    [    3.741744] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  1742    [    3.746908] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
  1743    [    3.754496] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
  1744    [    3.760997] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
  1745    [    3.769244] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.05
  1746    [    3.777616] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1747    [    3.784773] usb usb2: Product: xHCI Host Controller
  1748    [    3.789602] usb usb2: Manufacturer: Linux 5.5.0-rc6-aml-s9xxx xhci-hcd
  1749    [    3.796072] usb usb2: SerialNumber: xhci-hcd.0.auto
  1750    [    3.801371] hub 2-0:1.0: USB hub found
  1751    [    3.804657] hub 2-0:1.0: config failed, hub doesn't have any ports! (err -19)
  1752    [    3.813480] meson-gx-mmc d0070000.mmc: allocated mmc-pwrseq
  1753    [    3.843571] scpi_protocol scpi: SCP Protocol legacy pre-1.0 firmware
  1754    [    3.860329] gx-sound-card sound: snd-soc-dummy-dai <-> c1105400.bus:audio-controller-0 mapping ok
  1755    [    3.871876] gx-sound-card sound: i2s-hifi <-> c1105400.bus:audio-controller-2 mapping ok
  1756    [    3.879564] gx-sound-card sound: ASoC: no DMI vendor name!
  1757    [    3.885756] printk: console [netcon0] enabled
  1758    [    3.889196] netconsole: network logging started
  1759    [    3.893768] hctosys: unable to open rtc device (rtc0)
  1760    [    3.899074] ALSA device list:
  1761    [    3.901684]   #0: AMLGX
  1762    [    3.904696] Freeing unused kernel memory: 960K
  1763    [    3.908544] Run /init as init process
  1764    [    3.917231] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
  1765    [    3.924029] mmc2: queuing unknown CIS tuple 0x80 (6 bytes)
  1766    [    3.931091] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
  1767    [    3.942576] mmc2: queuing unknown CIS tuple 0x80 (19 bytes)
  1768    [    3.965156] random: fast init done
  1769    [    4.028824] mmc2: new high speed SDIO card at address 0001
  1770    [    4.078643] usb 1-1: new high-speed USB device number 2 using xhci-hcd
  1771    [    4.100299] usb 1-1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.36
  1772    [    4.107220] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
  1773    [    4.114599] usb 1-1: Product: USB2.0 Hub
  1774    [    4.177498] hub 1-1:1.0: USB hub found
  1775    [    4.180084] hub 1-1:1.0: 4 ports detected
  1776    [    4.310653] usb 1-2: new high-speed USB device number 3 using xhci-hcd
  1777    [    4.341205] usb 1-2: New USB device found, idVendor=148f, idProduct=7601, bcdDevice= 0.00
  1778    [    4.348256] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
  1779    [    4.355203] usb 1-2: Product: 802.11 n WLAN
  1780    [    4.359906] usb 1-2: Manufacturer: MediaTek
  1781    [    4.366181] usb 1-2: SerialNumber: 1.0
  1782    [    5.929977] EXT4-fs (mmcblk0p2): mounted filesystem with writeback data mode. Opts: data=writeback
  1783    [    6.863884] systemd[1]: System time before build time, advancing clock.
  1784    [    7.010117] NET: Registered protocol family 10
  1785    [    7.084053] Segment Routing with IPv6
  1786    [    7.133798] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
  1787    [    7.166249] systemd[1]: Detected architecture arm64.
  1788    [    7.220331] systemd[1]: Set hostname to <mxqpro>.
  1789    [    7.252129] systemd[1]: Couldn't move remaining userspace processes, ignoring: Input/output error
  1790    [    7.956616] random: systemd: uninitialized urandom read (16 bytes read)
  1791    [    7.969840] random: systemd: uninitialized urandom read (16 bytes read)
  1792    [    7.973996] systemd[1]: Listening on udev Control Socket.
  1793    [    7.981535] random: systemd: uninitialized urandom read (16 bytes read)
  1794    [    7.985645] systemd[1]: Listening on Syslog Socket.
  1795    [    7.993273] systemd[1]: Listening on Journal Socket (/dev/log).
  1796    [    8.002123] systemd[1]: Created slice system-getty.slice.
  1797    [    8.007503] systemd[1]: Condition check resulted in Arbitrary Executable File Formats File System Automount Point being skipped.
  1798    [    8.020080] systemd[1]: Created slice system-systemd\x2dfsck.slice.
  1799    [    8.238538] EXT4-fs (mmcblk0p2): re-mounted. Opts: commit=600,errors=remount-ro
  1800    [    8.363785] systemd-journald[401]: Received request to flush runtime journal from PID 1
  1801    [    8.923111] Registered IR keymap rc-empty
  1802    [    8.925284] rc rc0: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0
  1803    [    8.932461] input: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0/input0
  1804    [    8.932902] mc: Linux media interface: v0.10
  1805    [    8.943825] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
  1806    [    8.944046] meson-ir c8100580.ir: receiver initialized
  1807    [    8.989219] videodev: Linux video capture interface: v2.00
  1808    [    9.071859] lima d00c0000.gpu: IRQ ppmmu3 not found
  1809    [    9.074122] lima d00c0000.gpu: IRQ ppmmu4 not found
  1810    [    9.088435] lima d00c0000.gpu: IRQ ppmmu5 not found
  1811    [    9.092159] lima d00c0000.gpu: IRQ ppmmu6 not found
  1812    [    9.099697] lima d00c0000.gpu: IRQ ppmmu7 not found
  1813    [    9.111856] lima d00c0000.gpu: gp - mali450 version major 0 minor 0
  1814    [    9.114960] lima d00c0000.gpu: pp0 - mali450 version major 0 minor 0
  1815    [    9.121193] lima d00c0000.gpu: pp1 - mali450 version major 0 minor 0
  1816    [    9.137298] lima d00c0000.gpu: pp2 - mali450 version major 0 minor 0
  1817    [    9.143713] lima d00c0000.gpu: IRQ pp3 not found
  1818    [    9.145623] lima d00c0000.gpu: IRQ pp4 not found
  1819    [    9.151337] lima d00c0000.gpu: IRQ pp5 not found
  1820    [    9.154252] lima d00c0000.gpu: IRQ pp6 not found
  1821    [    9.160786] lima d00c0000.gpu: IRQ pp7 not found
  1822    [    9.164026] lima d00c0000.gpu: l2 cache 8K, 4-way, 64byte cache line, 128bit external bus
  1823    [    9.172789] lima d00c0000.gpu: l2 cache 64K, 4-way, 64byte cache line, 128bit external bus
  1824    [    9.181946] lima d00c0000.gpu: bus rate = 166666667
  1825    [    9.185335] lima d00c0000.gpu: mod rate = 744000000
  1826    [    9.189438] [drm] Initialized lima 1.0.0 20190217 for d00c0000.gpu on minor 1
  1827    [    9.249835] Bluetooth: Core ver 2.22
  1828    [    9.251794] NET: Registered protocol family 31
  1829    [    9.253961] Bluetooth: HCI device and connection manager initialized
  1830    [    9.260332] Bluetooth: HCI socket layer initialized
  1831    [    9.265170] Bluetooth: L2CAP socket layer initialized
  1832    [    9.270191] Bluetooth: SCO socket layer initialized
  1833    [    9.276369] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
  1834    [    9.359942] cfg80211: Loading compiled-in X.509 certificates for regulatory database
  1835    [    9.405540] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
  1836    [    9.419935] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
  1837    [    9.426671] cfg80211: failed to load regulatory.db
  1838    [    9.456704] Bluetooth: HCI UART driver ver 2.3
  1839    [    9.459129] Bluetooth: HCI UART protocol H4 registered
  1840    [    9.469525] Bluetooth: HCI UART protocol BCSP registered
  1841    [    9.472981] Bluetooth: HCI UART protocol LL registered
  1842    [    9.482704] Bluetooth: HCI UART protocol ATH3K registered
  1843    [    9.486032] Bluetooth: HCI UART protocol Three-wire (H5) registered
  1844    [    9.526538] Bluetooth: HCI UART protocol Intel registered
  1845    [    9.531615] hci_uart_bcm serial0-0: serial0-0 supply vbat not found, using dummy regulator
  1846    [    9.538846] hci_uart_bcm serial0-0: serial0-0 supply vddio not found, using dummy regulator
  1847    [    9.551114] Bluetooth: HCI UART protocol Broadcom registered
  1848    [    9.573794] Bluetooth: HCI UART protocol QCA registered
  1849    [    9.576715] Bluetooth: HCI UART protocol AG6XX registered
  1850    [    9.581285] brcmfmac: F1 signature read @0x18000000=0x16034334
  1851    [    9.582638] Bluetooth: HCI UART protocol Marvell registered
  1852    [    9.589720] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4334-sdio for chip BCM4334/3
  1853    [    9.599275] usbcore: registered new interface driver brcmfmac
  1854    [    9.652250] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.amlogic,p212.txt failed with error -2
  1855    [    9.662348] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.txt failed with error -2
  1856    [    9.730971] usb 1-2: reset high-speed USB device number 3 using xhci-hcd
  1857    [    9.753871] mt7601u 1-2:1.0: ASIC revision: 76010001 MAC revision: 76010500
  1858    [    9.798465] mt7601u 1-2:1.0: EEPROM ver:0d fae:00
  1859    [    9.956858] Bluetooth: hci0: BCM: chip id 68
  1860    [    9.965676] Bluetooth: hci0: BCM: features 0x0f
  1861    [    9.973632] Bluetooth: hci0: BCM4334B0
  1862    [    9.976380] Bluetooth: hci0: BCM4334B0 (002.001.013) build 0000
  1863    [    9.980456] bluetooth hci0: Direct firmware load for brcm/BCM4334B0.hcd failed with error -2
  1864    [    9.988712] Bluetooth: hci0: BCM: Patch brcm/BCM4334B0.hcd not found
  1865    [   10.027270] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
  1866    [   10.028288] usbcore: registered new interface driver mt7601u
  1867    [   10.666716] brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x50
  1868    [   10.717095] zram: Added device: zram0
  1869    [   10.723846] zram: Added device: zram1
  1870    [   10.730716] zram: Added device: zram2
  1871    [   10.766088] meson8b-dwmac c9410000.ethernet eth0: PHY [0.e40908ff:08] driver [Meson GXL Internal PHY]
  1872    [   10.783471] zram1: detected capacity change from 0 to 912879616
  1873    [   10.787344] meson8b-dwmac c9410000.ethernet eth0: No Safety Features support found
  1874    [   10.793812] meson8b-dwmac c9410000.ethernet eth0: PTP not supported by HW
  1875    [   10.800726] meson8b-dwmac c9410000.ethernet eth0: configuring for phy/rmii link mode
  1876    [   11.441161] random: crng init done
  1877    [   11.443690] random: 7 urandom warning(s) missed due to ratelimiting
  1878    [   11.494636] Adding 891480k swap on /dev/zram1.  Priority:5 extents:1 across:891480k SSFS
  1879
  1880    ### armbian-release:
  1881
  1882    # PLEASE DO NOT EDIT THIS FILE
  1883    BOARD=aml-s9xxx
  1884    BOARD_NAME="AML-S9xxx"
  1885    BOARDFAMILY=aml-s9xxx
  1886    BUILD_REPOSITORY_URL=https://github.com/150balbes/Build-Armbian.git
  1887    BUILD_REPOSITORY_COMMIT=62b8c07-dirty
  1888    DISTRIBUTION_CODENAME=buster
  1889    DISTRIBUTION_STATUS=supported
  1890    VERSION=20.02.0-rc1.037
  1891    LINUXFAMILY=aml-s9xxx
  1892    BRANCH=current
  1893    ARCH=arm64
  1894    IMAGE_TYPE=nightly
  1895    BOARD_TYPE=conf
  1896    INITRD_ARCH=arm64
  1897    KERNEL_IMAGE_TYPE=Image
  1898
  1899    ### boot environment:
  1900
  1901    ODROIDN2-UBOOT-CONFIG
  1902    setenv env_addr 0x10400000
  1903    setenv kernel_addr 0x11000000
  1904    setenv initrd_addr 0x13000000
  1905    setenv dtb_addr 0x1000000
  1906    if test "${devtype}" = ""; then setenv devtype "mmc"; fi
  1907    load ${devtype} ${devnum} ${env_addr} uEnv.txt && env import -t ${env_addr} ${filesize}
  1908    setenv bootargs ${APPEND}
  1909    load ${devtype} ${devnum} ${kernel_addr} ${LINUX}
  1910    load ${devtype} ${devnum} ${initrd_addr} ${INITRD}
  1911    load ${devtype} ${devnum} ${dtb_addr} ${FDT}
  1912    fdt addr ${dtb_addr}
  1913    booti ${kernel_addr} ${initrd_addr} ${dtb_addr}
  1914
  1915    ### lsusb:
  1916
  1917    Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
  1918    Bus 001 Device 003: ID 148f:7601 Ralink Technology, Corp. MT7601U Wireless Adapter
  1919    Bus 001 Device 002: ID 05e3:0608 Genesys Logic, Inc. Hub
  1920    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  1921
  1922    ### lscpu:
  1923
  1924    Architecture:        aarch64
  1925    Byte Order:          Little Endian
  1926    CPU(s):              4
  1927    On-line CPU(s) list: 0-3
  1928    Thread(s) per core:  1
  1929    Core(s) per socket:  4
  1930    Socket(s):           1
  1931    Vendor ID:           ARM
  1932    Model:               4
  1933    Model name:          Cortex-A53
  1934    Stepping:            r0p4
  1935    CPU max MHz:         1512,0000
  1936    CPU min MHz:         100,0000
  1937    BogoMIPS:            48.00
  1938    L1d cache:           unknown size
  1939    L1i cache:           unknown size
  1940    L2 cache:            unknown size
  1941    Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1942
  1943    ### cpuinfo:
  1944
  1945    processor    : 0
  1946    model name    : ARMv8 Processor rev 4 (v8l)
  1947    BogoMIPS    : 48.00
  1948    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1949    CPU implementer    : 0x41
  1950    CPU architecture: 8
  1951    CPU variant    : 0x0
  1952    CPU part    : 0xd03
  1953    CPU revision    : 4
  1954
  1955    processor    : 1
  1956    model name    : ARMv8 Processor rev 4 (v8l)
  1957    BogoMIPS    : 48.00
  1958    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1959    CPU implementer    : 0x41
  1960    CPU architecture: 8
  1961    CPU variant    : 0x0
  1962    CPU part    : 0xd03
  1963    CPU revision    : 4
  1964
  1965    processor    : 2
  1966    model name    : ARMv8 Processor rev 4 (v8l)
  1967    BogoMIPS    : 48.00
  1968    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1969    CPU implementer    : 0x41
  1970    CPU architecture: 8
  1971    CPU variant    : 0x0
  1972    CPU part    : 0xd03
  1973    CPU revision    : 4
  1974
  1975    processor    : 3
  1976    model name    : ARMv8 Processor rev 4 (v8l)
  1977    BogoMIPS    : 48.00
  1978    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1979    CPU implementer    : 0x41
  1980    CPU architecture: 8
  1981    CPU variant    : 0x0
  1982    CPU part    : 0xd03
  1983    CPU revision    : 4
  1984
  1985
  1986    ### meminfo:
  1987
  1988    MemTotal:        1782968 kB
  1989    MemFree:         1612468 kB
  1990    MemAvailable:    1666120 kB
  1991    Buffers:           11828 kB
  1992    Cached:            51068 kB
  1993    SwapCached:            0 kB
  1994    Active:            49940 kB
  1995    Inactive:          33288 kB
  1996    Active(anon):      20848 kB
  1997    Inactive(anon):     2620 kB
  1998    Active(file):      29092 kB
  1999    Inactive(file):    30668 kB
  2000    Unevictable:           0 kB
  2001    Mlocked:               0 kB
  2002    SwapTotal:        891480 kB
  2003    SwapFree:         891480 kB
  2004    Dirty:               704 kB
  2005    Writeback:             0 kB
  2006    AnonPages:         20748 kB
  2007    Mapped:            21148 kB
  2008    Shmem:              2720 kB
  2009    KReclaimable:      17008 kB
  2010    Slab:              52992 kB
  2011    SReclaimable:      17008 kB
  2012    SUnreclaim:        35984 kB
  2013    KernelStack:        2672 kB
  2014    PageTables:         1668 kB
  2015    NFS_Unstable:          0 kB
  2016    Bounce:                0 kB
  2017    WritebackTmp:          0 kB
  2018    CommitLimit:     1782964 kB
  2019    Committed_AS:      54464 kB
  2020    VmallocTotal:   135290159040 kB
  2021    VmallocUsed:       16600 kB
  2022    VmallocChunk:          0 kB
  2023    Percpu:             1312 kB
  2024    CmaTotal:         262144 kB
  2025    CmaFree:          258460 kB
  2026    HugePages_Total:       0
  2027    HugePages_Free:        0
  2028    HugePages_Rsvd:        0
  2029    HugePages_Surp:        0
  2030    Hugepagesize:       2048 kB
  2031    Hugetlb:               0 kB
  2032
  2033    ### virtual memory:
  2034
  2035    vm.admin_reserve_kbytes = 8192
  2036    vm.block_dump = 0
  2037    vm.compact_unevictable_allowed = 1
  2038    vm.dirty_background_bytes = 0
  2039    vm.dirty_background_ratio = 10
  2040    vm.dirty_bytes = 0
  2041    vm.dirty_expire_centisecs = 3000
  2042    vm.dirty_ratio = 20
  2043    vm.dirtytime_expire_seconds = 43200
  2044    vm.dirty_writeback_centisecs = 500
  2045    vm.extfrag_threshold = 500
  2046    vm.hugetlb_shm_group = 0
  2047    vm.laptop_mode = 0
  2048    vm.legacy_va_layout = 0
  2049    vm.lowmem_reserve_ratio = 256    256    32    0
  2050    vm.max_map_count = 65530
  2051    vm.min_free_kbytes = 4914
  2052    vm.mmap_min_addr = 4096
  2053    vm.mmap_rnd_bits = 18
  2054    vm.nr_hugepages = 0
  2055    vm.nr_overcommit_hugepages = 0
  2056    vm.oom_dump_tasks = 1
  2057    vm.oom_kill_allocating_task = 0
  2058    vm.overcommit_kbytes = 0
  2059    vm.overcommit_memory = 0
  2060    vm.overcommit_ratio = 50
  2061    vm.page-cluster = 0
  2062    vm.panic_on_oom = 0
  2063    vm.percpu_pagelist_fraction = 0
  2064    vm.stat_interval = 1
  2065    vm.swappiness = 100
  2066    vm.user_reserve_kbytes = 55239
  2067    vm.vfs_cache_pressure = 100
  2068    vm.watermark_boost_factor = 15000
  2069    vm.watermark_scale_factor = 10
  2070
  2071    ### ip addr:
  2072
  2073    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
  2074        link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  2075        inet XXX.XXX.0.1/8 scope host lo
  2076           valid_lft forever preferred_lft forever
  2077        inet6 ::1/128 scope host
  2078           valid_lft forever preferred_lft forever
  2079    2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
  2080        link/ether 00:df:06:00:00:0b brd ff:ff:ff:ff:ff:ff
  2081    3: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  2082        link/ether 00:36:76:61:0b:24 brd ff:ff:ff:ff:ff:ff
  2083
  2084    ### partitions:
  2085
  2086    major minor  #blocks  name
  2087
  2088     179        0   30924800 mmcblk0
  2089     179        1     262144 mmcblk0p1
  2090     179        2   30337024 mmcblk0p2
  2091     179       32   15384576 mmcblk1
  2092     179      128       8192 mmcblk1gp0
  2093     254        1     891484 zram1
  2094
  2095    ### df:
  2096
  2097    udev             738M      0  738M   0% /dev
  2098    tmpfs            175M   2,7M  172M   2% /run
  2099    /dev/mmcblk0p2    29G    10G   19G  36% /
  2100    tmpfs            871M      0  871M   0% /dev/shm
  2101    tmpfs            5,0M   4,0K  5,0M   1% /run/lock
  2102    tmpfs            871M      0  871M   0% /sys/fs/cgroup
  2103    tmpfs            871M      0  871M   0% /tmp
  2104    /dev/mmcblk0p1   256M    76M  180M  30% /boot
  2105
  2106    ### lsblk:
  2107
  2108    NAME         FSTYPE   SIZE MOUNTPOINT UUID
  2109    mmcblk0              29,5G
  2110    ├─mmcblk0p1  vfat     256M /boot      50FC-6AC8
  2111    └─mmcblk0p2  ext4      29G /          3e297ac1-e4e4-4ab1-bc57-47c07d0422ba
  2112    mmcblk1              14,7G
  2113    mmcblk1boot0            4M
  2114    mmcblk1boot1            4M
  2115    mmcblk1gp0              8M
  2116
  2117    ### zramctl:
  2118
  2119    NAME       ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT
  2120    /dev/zram1 lzo         870,6M   4K   81B   12K       4 [SWAP]
  2121
  2122    ### mtab:
  2123
  2124    /dev/mmcblk0p1 /boot vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro 0 0
  2125    /dev/mmcblk0p2 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  2126
  2127    ### mmc0:59b4 info:
  2128
  2129                   fwrev: 0x0
  2130                  uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SDU1  MODALIAS=mmc:block
  2131                     cid: 1b534d53445531201014a136d4013800
  2132                     rca: 0x59b4
  2133                     csd: 400e00325b590000ebef7f800a400000
  2134                  manfid: 0x00001b
  2135                     ocr: 0x00200000
  2136    preferred_erase_size: 4194304
  2137                    type: SD
  2138                   hwrev: 0x1
  2139                    date: 08/2019
  2140                     dsr: 0x404
  2141              erase_size: 512
  2142                   oemid: 0x534d
  2143                  serial: 0x14a136d4
  2144                     ssr: 0000000005000000040090000811391e00089a342f01000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  2145                     scr: 0235844300000000
  2146                    name: SDU1
  2147
  2148    ### mmc1:0001 info:
  2149
  2150                   fwrev: 0x0
  2151                  uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=016G92 MODALIAS=mmc:block
  2152                     cid: 11010030313647393201d3d1a4db1100
  2153             rel_sectors: 0x10
  2154                     rca: 0x0001
  2155            pre_eol_info: 0x00
  2156                     csd: d00e00320f5903ffffffffef92400000
  2157                  manfid: 0x000011
  2158                     ocr: 0x00200000
  2159    preferred_erase_size: 4194304
  2160    enhanced_area_offset: 18446744073709551594
  2161      raw_rpmb_size_mult: 0x4
  2162                    type: MMC
  2163                   hwrev: 0x0
  2164                    date: 01/2014
  2165                     prv: 0x1
  2166             ffu_capable: 0
  2167                     dsr: 0x404
  2168              erase_size: 4194304
  2169               life_time: 0x00 0x00
  2170      enhanced_area_size: 4294967274
  2171                   oemid: 0x0100
  2172                  serial: 0xd3d1a4db
  2173                 cmdq_en: 0
  2174                     rev: 0x6
  2175                    name: 016G92
  2176
  2177    ### Boot system health:
  2178
  2179    Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU
  2180    11:17:07: 1512MHz  0.79  50%  23%  14%   0%  10%   1% 54.0°C
  2181    11:17:07: 1512MHz  0.79  66%   5%  11%   1%  46%   1% 54.0°C
  2182    11:17:07: 1512MHz  0.79  77%  13%  27%   1%  33%   2% 54.0°C
  2183    11:17:08: 1512MHz  1.21  52%   6%   7%   1%  35%   1% 54.0°C
  2184    11:17:08: 1512MHz  1.21  50%   8%  13%   1%  25%   1% 53.0°C
  2185
  2186    ### Activated 1 lzo zram swap devices with 870 MB each
  2187
  2188
  2189    mar mar 23 09:17:04 CET 2021 | AML-S9xxx | 20.02.0-rc1.037 | arm64 | aarch64 | 5.5.0-rc6-aml-s9xxx
  2190
  2191    ### dmesg:
  2192
  2193    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
  2194    [    0.000000] Linux version 5.5.0-rc6-aml-s9xxx (root@vbox) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #rc1.037 SMP PREEMPT Wed Feb 5 15:59:04 MSK 2020
  2195    [    0.000000] Machine model: Amlogic Meson GXL (S905X) P212 Development Board
  2196    [    0.000000] efi: Getting EFI parameters from FDT:
  2197    [    0.000000] efi: UEFI not found.
  2198    [    0.000000] Reserved memory: created CMA memory pool at 0x0000000063400000, size 256 MiB
  2199    [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
  2200    [    0.000000] On node 0 totalpages: 477952
  2201    [    0.000000]   DMA zone: 4032 pages used for memmap
  2202    [    0.000000]   DMA zone: 0 pages reserved
  2203    [    0.000000]   DMA zone: 248576 pages, LIFO batch:63
  2204    [    0.000000]   DMA32 zone: 3584 pages used for memmap
  2205    [    0.000000]   DMA32 zone: 229376 pages, LIFO batch:63
  2206    [    0.000000] psci: probing for conduit method from DT.
  2207    [    0.000000] psci: PSCIv0.2 detected in firmware.
  2208    [    0.000000] psci: Using standard PSCI v0.2 function IDs
  2209    [    0.000000] psci: Trusted OS migration not required
  2210    [    0.000000] percpu: Embedded 22 pages/cpu s50392 r8192 d31528 u90112
  2211    [    0.000000] pcpu-alloc: s50392 r8192 d31528 u90112 alloc=22*4096
  2212    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
  2213    [    0.000000] Detected VIPT I-cache on CPU0
  2214    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 470336
  2215    [    0.000000] Kernel command line: root=LABEL=ROOTFS rootflags=data=writeback rw console=ttyAML0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 mac=00:df:06:00:00:0b
  2216    [    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
  2217    [    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
  2218    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
  2219    [    0.000000] software IO TLB: mapped [mem 0x3bfff000-0x3ffff000] (64MB)
  2220    [    0.000000] Memory: 1509616K/1911808K available (14460K kernel code, 1434K rwdata, 5884K rodata, 960K init, 927K bss, 140048K reserved, 262144K cma-reserved)
  2221    [    0.000000] random: get_random_u64 called from cache_random_seq_create+0x7c/0x150 with crng_init=0
  2222    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
  2223    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
  2224    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
  2225    [    0.000000]     Tasks RCU enabled.
  2226    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
  2227    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
  2228    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
  2229    [    0.000000] GIC: Using split EOI/Deactivate mode
  2230    [    0.000000] irq_meson_gpio: 110 to 8 gpio interrupt mux initialized
  2231    [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
  2232    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
  2233    [    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
  2234    [    0.000354] Console: colour dummy device 80x25
  2235    [    0.000655] printk: console [tty0] enabled
  2236    [    0.000696] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
  2237    [    0.000717] pid_max: default: 32768 minimum: 301
  2238    [    0.000841] LSM: Security Framework initializing
  2239    [    0.000893] SELinux:  Initializing.
  2240    [    0.000970] *** VALIDATE SELinux ***
  2241    [    0.001034] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
  2242    [    0.001060] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
  2243    [    0.001123] *** VALIDATE tmpfs ***
  2244    [    0.001529] *** VALIDATE proc ***
  2245    [    0.001749] *** VALIDATE cgroup1 ***
  2246    [    0.001763] *** VALIDATE cgroup2 ***
  2247    [    0.024016] ASID allocator initialised with 32768 entries
  2248    [    0.031997] rcu: Hierarchical SRCU implementation.
  2249    [    0.042088] EFI services will not be available.
  2250    [    0.048056] smp: Bringing up secondary CPUs ...
  2251    [    0.080281] Detected VIPT I-cache on CPU1
  2252    [    0.080336] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
  2253    [    0.112321] Detected VIPT I-cache on CPU2
  2254    [    0.112366] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
  2255    [    0.144373] Detected VIPT I-cache on CPU3
  2256    [    0.144414] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
  2257    [    0.144490] smp: Brought up 1 node, 4 CPUs
  2258    [    0.144561] SMP: Total of 4 processors activated.
  2259    [    0.144572] CPU features: detected: 32-bit EL0 Support
  2260    [    0.144584] CPU features: detected: CRC32 instructions
  2261    [    0.144889] CPU: All CPU(s) started at EL2
  2262    [    0.144910] alternatives: patching kernel code
  2263    [    0.146007] devtmpfs: initialized
  2264    [    0.151117] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
  2265    [    0.151158] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
  2266    [    0.158029] xor: measuring software checksum speed
  2267    [    0.196370]    8regs     :  2375.000 MB/sec
  2268    [    0.236402]    32regs    :  2724.000 MB/sec
  2269    [    0.276440]    arm64_neon:  2406.000 MB/sec
  2270    [    0.276450] xor: using function: 32regs (2724.000 MB/sec)
  2271    [    0.276505] pinctrl core: initialized pinctrl subsystem
  2272    [    0.277152] thermal_sys: Registered thermal governor 'step_wise'
  2273    [    0.277312] DMI not present or invalid.
  2274    [    0.277674] NET: Registered protocol family 16
  2275    [    0.281246] DMA: preallocated 256 KiB pool for atomic allocations
  2276    [    0.281295] audit: initializing netlink subsys (disabled)
  2277    [    0.281514] audit: type=2000 audit(0.280:1): state=initialized audit_enabled=0 res=1
  2278    [    0.282597] cpuidle: using governor ladder
  2279    [    0.282638] cpuidle: using governor menu
  2280    [    0.283008] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
  2281    [    0.283723] Serial: AMBA PL011 UART driver
  2282    [    0.297708] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
  2283    [    0.297736] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
  2284    [    0.297750] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
  2285    [    0.297762] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
  2286    [    0.301305] cryptd: max_cpu_qlen set to 1000
  2287    [    0.376675] raid6: neonx8   gen()  1617 MB/s
  2288    [    0.444712] raid6: neonx8   xor()  1505 MB/s
  2289    [    0.512788] raid6: neonx4   gen()  1564 MB/s
  2290    [    0.580814] raid6: neonx4   xor()  1471 MB/s
  2291    [    0.648899] raid6: neonx2   gen()  1199 MB/s
  2292    [    0.716941] raid6: neonx2   xor()  1216 MB/s
  2293    [    0.785050] raid6: neonx1   gen()   787 MB/s
  2294    [    0.853062] raid6: neonx1   xor()   916 MB/s
  2295    [    0.921116] raid6: int64x8  gen()  1194 MB/s
  2296    [    0.989169] raid6: int64x8  xor()   769 MB/s
  2297    [    1.057240] raid6: int64x4  gen()  1029 MB/s
  2298    [    1.125289] raid6: int64x4  xor()   752 MB/s
  2299    [    1.193337] raid6: int64x2  gen()   728 MB/s
  2300    [    1.261360] raid6: int64x2  xor()   618 MB/s
  2301    [    1.329530] raid6: int64x1  gen()   487 MB/s
  2302    [    1.397482] raid6: int64x1  xor()   468 MB/s
  2303    [    1.397492] raid6: using algorithm neonx8 gen() 1617 MB/s
  2304    [    1.397503] raid6: .... xor() 1505 MB/s, rmw enabled
  2305    [    1.397513] raid6: using neon recovery algorithm
  2306    [    1.397789] ACPI: Interpreter disabled.
  2307    [    1.398974] iommu: Default domain type: Translated
  2308    [    1.399253] vgaarb: loaded
  2309    [    1.399784] SCSI subsystem initialized
  2310    [    1.399986] libata version 3.00 loaded.
  2311    [    1.400200] usbcore: registered new interface driver usbfs
  2312    [    1.400244] usbcore: registered new interface driver hub
  2313    [    1.400308] usbcore: registered new device driver usb
  2314    [    1.400708] pps_core: LinuxPPS API ver. 1 registered
  2315    [    1.400720] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
  2316    [    1.400744] PTP clock support registered
  2317    [    1.400779] EDAC MC: Ver: 3.0.0
  2318    [    1.401353] FPGA manager framework
  2319    [    1.401474] Advanced Linux Sound Architecture Driver Initialized.
  2320    [    1.401942] NetLabel: Initializing
  2321    [    1.401955] NetLabel:  domain hash size = 128
  2322    [    1.401964] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
  2323    [    1.402020] NetLabel:  unlabeled traffic allowed by default
  2324    [    1.402522] clocksource: Switched to clocksource arch_sys_counter
  2325    [    1.402548] *** VALIDATE bpf ***
  2326    [    1.402790] VFS: Disk quotas dquot_6.6.0
  2327    [    1.402851] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
  2328    [    1.402967] FS-Cache: Loaded
  2329    [    1.402977] *** VALIDATE ramfs ***
  2330    [    1.402999] *** VALIDATE hugetlbfs ***
  2331    [    1.403369] pnp: PnP ACPI: disabled
  2332    [    1.408382] NET: Registered protocol family 2
  2333    [    1.408878] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
  2334    [    1.408927] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
  2335    [    1.409047] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
  2336    [    1.409262] TCP: Hash tables configured (established 16384 bind 16384)
  2337    [    1.409418] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
  2338    [    1.409470] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
  2339    [    1.409685] NET: Registered protocol family 1
  2340    [    1.410162] RPC: Registered named UNIX socket transport module.
  2341    [    1.410182] RPC: Registered udp transport module.
  2342    [    1.410192] RPC: Registered tcp transport module.
  2343    [    1.410201] RPC: Registered tcp NFSv4.1 backchannel transport module.
  2344    [    1.410217] NET: Registered protocol family 44
  2345    [    1.410238] PCI: CLS 0 bytes, default 64
  2346    [    1.410428] Trying to unpack rootfs image as initramfs...
  2347    [    1.871868] Freeing initrd memory: 10248K
  2348    [    1.872648] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
  2349    [    2.086163] Initialise system trusted keyrings
  2350    [    2.086390] workingset: timestamp_bits=46 max_order=19 bucket_order=0
  2351    [    2.091505] zbud: loaded
  2352    [    2.092750] squashfs: version 4.0 (2009/01/31) Phillip Lougher
  2353    [    2.093050] FS-Cache: Netfs 'nfs' registered for caching
  2354    [    2.093595] NFS: Registering the id_resolver key type
  2355    [    2.093634] Key type id_resolver registered
  2356    [    2.093644] Key type id_legacy registered
  2357    [    2.093660] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
  2358    [    2.093672] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
  2359    [    2.094843] FS-Cache: Netfs 'cifs' registered for caching
  2360    [    2.095181] Key type cifs.spnego registered
  2361    [    2.095201] Key type cifs.idmap registered
  2362    [    2.095226] ntfs: driver 2.1.32 [Flags: R/W].
  2363    [    2.095800] JFS: nTxBlock = 8192, nTxLock = 65536
  2364    [    2.101705] SGI XFS with ACLs, security attributes, realtime, quota, no debug enabled
  2365    [    2.103218] *** VALIDATE xfs ***
  2366    [    2.103502] ocfs2: Registered cluster interface o2cb
  2367    [    2.103713] OCFS2 User DLM kernel interface loaded
  2368    [    2.105087] *** VALIDATE gfs2 ***
  2369    [    2.105361] gfs2: GFS2 installed
  2370    [    2.106285] aufs 5.5-20200203
  2371    [    2.126790] Key type asymmetric registered
  2372    [    2.126817] Asymmetric key parser 'x509' registered
  2373    [    2.126827] Asymmetric key parser 'pkcs8' registered
  2374    [    2.126897] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
  2375    [    2.127091] io scheduler mq-deadline registered
  2376    [    2.127105] io scheduler kyber registered
  2377    [    2.127304] io scheduler bfq registered
  2378    [    2.139846] soc soc0: Amlogic Meson GXL (S905X) Revision 21:b (82:2) Detected
  2379    [    2.143423] Serial: 8250/16550 driver, 5 ports, IRQ sharing enabled
  2380    [    2.145118] Serial: AMBA driver
  2381    [    2.145479] c11084c0.serial: ttyAML6 at MMIO 0xc11084c0 (irq = 10, base_baud = 1500000) is a meson_uart
  2382    [    2.145632] serial serial0: tty port ttyAML6 registered
  2383    [    2.145845] c81004c0.serial: ttyAML0 at MMIO 0xc81004c0 (irq = 13, base_baud = 1500000) is a meson_uart
  2384    [    3.121312] printk: console [ttyAML0] enabled
  2385    [    3.137613] brd: module loaded
  2386    [    3.146122] loop: module loaded
  2387    [    3.148619] libphy: Fixed MDIO Bus: probed
  2388    [    3.149270] meson8b-dwmac c9410000.ethernet: IRQ eth_wake_irq not found
  2389    [    3.154294] meson8b-dwmac c9410000.ethernet: IRQ eth_lpi not found
  2390    [    3.160507] meson8b-dwmac c9410000.ethernet: PTP uses main clock
  2391    [    3.166354] meson8b-dwmac c9410000.ethernet: no reset control found
  2392    [    3.173033] meson8b-dwmac c9410000.ethernet: User ID: 0x11, Synopsys ID: 0x37
  2393    [    3.179663] meson8b-dwmac c9410000.ethernet:     DWMAC1000
  2394    [    3.184822] meson8b-dwmac c9410000.ethernet: DMA HW capability register supported
  2395    [    3.192223] meson8b-dwmac c9410000.ethernet: RX Checksum Offload Engine supported
  2396    [    3.199640] meson8b-dwmac c9410000.ethernet: COE Type 2
  2397    [    3.204812] meson8b-dwmac c9410000.ethernet: TX Checksum insertion supported
  2398    [    3.211799] meson8b-dwmac c9410000.ethernet: Wake-Up On Lan supported
  2399    [    3.218216] meson8b-dwmac c9410000.ethernet: Normal descriptors
  2400    [    3.224048] meson8b-dwmac c9410000.ethernet: Ring mode enabled
  2401    [    3.229825] meson8b-dwmac c9410000.ethernet: Enable RX Mitigation via HW Watchdog Timer
  2402    [    3.237948] libphy: stmmac: probed
  2403    [    3.242413] VFIO - User Level meta-driver version: 0.3
  2404    [    3.247770] dwc3 c9000000.dwc3: Failed to get clk 'ref': -2
  2405    [    3.252618] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
  2406    [    3.258263] ehci-pci: EHCI PCI platform driver
  2407    [    3.262672] ehci-platform: EHCI generic platform driver
  2408    [    3.267971] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
  2409    [    3.273918] ohci-pci: OHCI PCI platform driver
  2410    [    3.278351] ohci-platform: OHCI generic platform driver
  2411    [    3.284100] usbcore: registered new interface driver usb-storage
  2412    [    3.289677] mousedev: PS/2 mouse device common for all mice
  2413    [    3.295614] i2c /dev entries driver
  2414    [    3.301246] sdhci: Secure Digital Host Controller Interface driver
  2415    [    3.304535] sdhci: Copyright(c) Pierre Ossman
  2416    [    3.308851] Synopsys Designware Multimedia Card Interface Driver
  2417    [    3.316105] meson-gx-mmc d0072000.mmc: Got CD GPIO
  2418    [    3.346807] meson-gx-mmc d0074000.mmc: allocated mmc-pwrseq
  2419    [    3.374378] sdhci-pltfm: SDHCI platform and OF driver helper
  2420    [    3.375595] ledtrig-cpu: registered to indicate activity on CPUs
  2421    [    3.380953] meson-sm: secure-monitor enabled
  2422    [    3.385242] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
  2423    [    3.386495] mmc0: new high speed SDHC card at address 59b4
  2424    [    3.392598] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
  2425    [    3.398722] mmcblk0: mmc0:59b4 SDU1  29.5 GiB
  2426    [    3.416767]  mmcblk0: p1 p2
  2427    [    3.422958] hid: raw HID events driver (C) Jiri Kosina
  2428    [    3.423198] usbcore: registered new interface driver usbhid
  2429    [    3.428109] usbhid: USB HID core driver
  2430    [    3.432169] platform-mhu c883c404.mailbox: Platform MHU Mailbox registered
  2431    [    3.449257] NET: Registered protocol family 17
  2432    [    3.449514] Key type dns_resolver registered
  2433    [    3.452841] registered taskstats version 1
  2434    [    3.456379] Loading compiled-in X.509 certificates
  2435    [    3.461360] zswap: loaded using pool lzo/zbud
  2436    [    3.465615] Key type ._fscrypt registered
  2437    [    3.469396] Key type .fscrypt registered
  2438    [    3.474317] Btrfs loaded, crc32c=crc32c-generic
  2439    [    3.496751] mmc1: new HS200 MMC card at address 0001
  2440    [    3.497658] mmcblk1: mmc1:0001 016G92 14.7 GiB
  2441    [    3.501075] mmcblk1boot0: mmc1:0001 016G92 partition 1 4.00 MiB
  2442    [    3.502154] Key type encrypted registered
  2443    [    3.506938] mmcblk1boot1: mmc1:0001 016G92 partition 2 4.00 MiB
  2444    [    3.516793] mmcblk1gp0: mmc1:0001 016G92 partition 4 8.00 MiB
  2445    [    3.522333] mmcblk1rpmb: mmc1:0001 016G92 partition 3 512 KiB, chardev (243:0)
  2446    [    3.530034] meson-drm d0100000.vpu: Queued 3 outputs on vpu
  2447    [    3.535035] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
  2448    [    3.541307] [drm] No driver support for vblank timestamp query.
  2449    [    3.574588] meson-dw-hdmi c883a000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
  2450    [    3.579301] meson-dw-hdmi c883a000.hdmi-tx: registered DesignWare HDMI I2C bus driver
  2451    [    3.587263] meson-drm d0100000.vpu: bound c883a000.hdmi-tx (ops meson_dw_hdmi_ops)
  2452    [    3.594604] [drm] Initialized meson 1.0.0 20161109 for d0100000.vpu on minor 0
  2453    [    3.631915] Console: switching to colour frame buffer device 90x36
  2454    [    3.652134] meson-drm d0100000.vpu: fb0: mesondrmfb frame buffer device
  2455    [    3.659390] libphy: mdio_mux: probed
  2456    [    3.669964] libphy: mdio_mux: probed
  2457    [    3.670454] phy phy-d0078080.phy.2: unsupported PHY mode 5
  2458    [    3.675581] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  2459    [    3.678893] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
  2460    [    3.686599] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228f664 hci version 0x100 quirks 0x0000000002010010
  2461    [    3.695838] xhci-hcd xhci-hcd.0.auto: irq 39, io mem 0xc9000000
  2462    [    3.701934] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.05
  2463    [    3.710305] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  2464    [    3.717444] usb usb1: Product: xHCI Host Controller
  2465    [    3.722271] usb usb1: Manufacturer: Linux 5.5.0-rc6-aml-s9xxx xhci-hcd
  2466    [    3.728744] usb usb1: SerialNumber: xhci-hcd.0.auto
  2467    [    3.734073] hub 1-0:1.0: USB hub found
  2468    [    3.737319] hub 1-0:1.0: 2 ports detected
  2469    [    3.741542] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  2470    [    3.746704] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
  2471    [    3.754302] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
  2472    [    3.760808] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
  2473    [    3.769076] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.05
  2474    [    3.777458] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  2475    [    3.784613] usb usb2: Product: xHCI Host Controller
  2476    [    3.789449] usb usb2: Manufacturer: Linux 5.5.0-rc6-aml-s9xxx xhci-hcd
  2477    [    3.795913] usb usb2: SerialNumber: xhci-hcd.0.auto
  2478    [    3.801213] hub 2-0:1.0: USB hub found
  2479    [    3.804489] hub 2-0:1.0: config failed, hub doesn't have any ports! (err -19)
  2480    [    3.813355] meson-gx-mmc d0070000.mmc: allocated mmc-pwrseq
  2481    [    3.843529] scpi_protocol scpi: SCP Protocol legacy pre-1.0 firmware
  2482    [    3.860387] gx-sound-card sound: snd-soc-dummy-dai <-> c1105400.bus:audio-controller-0 mapping ok
  2483    [    3.872096] gx-sound-card sound: i2s-hifi <-> c1105400.bus:audio-controller-2 mapping ok
  2484    [    3.879822] gx-sound-card sound: ASoC: no DMI vendor name!
  2485    [    3.886001] printk: console [netcon0] enabled
  2486    [    3.889412] netconsole: network logging started
  2487    [    3.893971] hctosys: unable to open rtc device (rtc0)
  2488    [    3.899446] ALSA device list:
  2489    [    3.901990]   #0: AMLGX
  2490    [    3.905060] Freeing unused kernel memory: 960K
  2491    [    3.908830] Run /init as init process
  2492    [    3.920322] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
  2493    [    3.926636] mmc2: queuing unknown CIS tuple 0x80 (6 bytes)
  2494    [    3.933204] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
  2495    [    3.945335] mmc2: queuing unknown CIS tuple 0x80 (19 bytes)
  2496    [    3.972003] random: fast init done
  2497    [    4.036841] mmc2: new high speed SDIO card at address 0001
  2498    [    4.074598] usb 1-1: new high-speed USB device number 2 using xhci-hcd
  2499    [    4.095827] usb 1-1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.36
  2500    [    4.102693] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
  2501    [    4.110264] usb 1-1: Product: USB2.0 Hub
  2502    [    4.177263] hub 1-1:1.0: USB hub found
  2503    [    4.179875] hub 1-1:1.0: 4 ports detected
  2504    [    4.310595] usb 1-2: new high-speed USB device number 3 using xhci-hcd
  2505    [    4.341103] usb 1-2: New USB device found, idVendor=148f, idProduct=7601, bcdDevice= 0.00
  2506    [    4.348045] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
  2507    [    4.358711] usb 1-2: Product: 802.11 n WLAN
  2508    [    4.362184] usb 1-2: Manufacturer: MediaTek
  2509    [    4.365243] usb 1-2: SerialNumber: 1.0
  2510    [    5.767106] EXT4-fs (mmcblk0p2): mounted filesystem with writeback data mode. Opts: data=writeback
  2511    [    6.716386] systemd[1]: System time before build time, advancing clock.
  2512    [    6.862930] NET: Registered protocol family 10
  2513    [    6.937655] Segment Routing with IPv6
  2514    [    6.989321] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
  2515    [    7.024610] systemd[1]: Detected architecture arm64.
  2516    [    7.078067] systemd[1]: Set hostname to <mxqpro>.
  2517    [    7.108068] systemd[1]: Couldn't move remaining userspace processes, ignoring: Input/output error
  2518    [    7.822405] random: systemd: uninitialized urandom read (16 bytes read)
  2519    [    7.835139] random: systemd: uninitialized urandom read (16 bytes read)
  2520    [    7.839481] systemd[1]: Listening on udev Kernel Socket.
  2521    [    7.846966] random: systemd: uninitialized urandom read (16 bytes read)
  2522    [    7.850893] systemd[1]: Listening on initctl Compatibility Named Pipe.
  2523    [    7.859927] systemd[1]: Reached target System Time Synchronized.
  2524    [    7.866451] systemd[1]: Listening on Journal Socket.
  2525    [    7.891079] systemd[1]: Starting Set the console keyboard layout...
  2526    [    7.901680] systemd[1]: Mounting Huge Pages File System...
  2527    [    8.066045] EXT4-fs (mmcblk0p2): re-mounted. Opts: commit=600,errors=remount-ro
  2528    [    8.369388] systemd-journald[416]: Received request to flush runtime journal from PID 1
  2529    [    8.796070] mc: Linux media interface: v0.10
  2530    [    8.830991] videodev: Linux video capture interface: v2.00
  2531    [    8.883011] Registered IR keymap rc-empty
  2532    [    8.883125] rc rc0: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0
  2533    [    8.883217] input: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0/input0
  2534    [    8.883527] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
  2535    [    8.883735] meson-ir c8100580.ir: receiver initialized
  2536    [    9.043577] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
  2537    [    9.060891] Bluetooth: Core ver 2.22
  2538    [    9.067627] NET: Registered protocol family 31
  2539    [    9.069981] Bluetooth: HCI device and connection manager initialized
  2540    [    9.075308] Bluetooth: HCI socket layer initialized
  2541    [    9.080002] Bluetooth: L2CAP socket layer initialized
  2542    [    9.081040] lima d00c0000.gpu: IRQ ppmmu3 not found
  2543    [    9.086296] Bluetooth: SCO socket layer initialized
  2544    [    9.091519] lima d00c0000.gpu: IRQ ppmmu4 not found
  2545    [    9.099899] lima d00c0000.gpu: IRQ ppmmu5 not found
  2546    [    9.114758] lima d00c0000.gpu: IRQ ppmmu6 not found
  2547    [    9.123908] lima d00c0000.gpu: IRQ ppmmu7 not found
  2548    [    9.126204] lima d00c0000.gpu: gp - mali450 version major 0 minor 0
  2549    [    9.134190] lima d00c0000.gpu: pp0 - mali450 version major 0 minor 0
  2550    [    9.138418] lima d00c0000.gpu: pp1 - mali450 version major 0 minor 0
  2551    [    9.145016] lima d00c0000.gpu: pp2 - mali450 version major 0 minor 0
  2552    [    9.154102] lima d00c0000.gpu: IRQ pp3 not found
  2553    [    9.157559] lima d00c0000.gpu: IRQ pp4 not found
  2554    [    9.160780] lima d00c0000.gpu: IRQ pp5 not found
  2555    [    9.165780] lima d00c0000.gpu: IRQ pp6 not found
  2556    [    9.170690] lima d00c0000.gpu: IRQ pp7 not found
  2557    [    9.174623] lima d00c0000.gpu: l2 cache 8K, 4-way, 64byte cache line, 128bit external bus
  2558    [    9.182694] lima d00c0000.gpu: l2 cache 64K, 4-way, 64byte cache line, 128bit external bus
  2559    [    9.191551] lima d00c0000.gpu: bus rate = 166666667
  2560    [    9.194479] lima d00c0000.gpu: mod rate = 744000000
  2561    [    9.202058] [drm] Initialized lima 1.0.0 20190217 for d00c0000.gpu on minor 1
  2562    [    9.262421] cfg80211: Loading compiled-in X.509 certificates for regulatory database
  2563    [    9.298592] Bluetooth: HCI UART driver ver 2.3
  2564    [    9.301253] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
  2565    [    9.308220] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
  2566    [    9.309086] Bluetooth: HCI UART protocol H4 registered
  2567    [    9.314715] cfg80211: failed to load regulatory.db
  2568    [    9.323096] Bluetooth: HCI UART protocol BCSP registered
  2569    [    9.366727] Bluetooth: HCI UART protocol LL registered
  2570    [    9.368546] Bluetooth: HCI UART protocol ATH3K registered
  2571    [    9.394317] Bluetooth: HCI UART protocol Three-wire (H5) registered
  2572    [    9.408539] Bluetooth: HCI UART protocol Intel registered
  2573    [    9.413646] hci_uart_bcm serial0-0: serial0-0 supply vbat not found, using dummy regulator
  2574    [    9.420243] hci_uart_bcm serial0-0: serial0-0 supply vddio not found, using dummy regulator
  2575    [    9.431376] Bluetooth: HCI UART protocol Broadcom registered
  2576    [    9.442681] Bluetooth: HCI UART protocol QCA registered
  2577    [    9.444862] Bluetooth: HCI UART protocol AG6XX registered
  2578    [    9.452767] Bluetooth: HCI UART protocol Marvell registered
  2579    [    9.468106] brcmfmac: F1 signature read @0x18000000=0x16034334
  2580    [    9.478721] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4334-sdio for chip BCM4334/3
  2581    [    9.486437] usbcore: registered new interface driver brcmfmac
  2582    [    9.533602] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.amlogic,p212.txt failed with error -2
  2583    [    9.545525] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.txt failed with error -2
  2584    [    9.566965] usb 1-2: reset high-speed USB device number 3 using xhci-hcd
  2585    [    9.604605] mt7601u 1-2:1.0: ASIC revision: 76010001 MAC revision: 76010500
  2586    [    9.639613] mt7601u 1-2:1.0: EEPROM ver:0d fae:00
  2587    [    9.819587] Bluetooth: hci0: BCM: chip id 68
  2588    [    9.824102] Bluetooth: hci0: BCM: features 0x0f
  2589    [    9.829909] Bluetooth: hci0: BCM4334B0
  2590    [    9.833466] Bluetooth: hci0: BCM4334B0 (002.001.013) build 0000
  2591    [    9.837535] bluetooth hci0: Direct firmware load for brcm/BCM4334B0.hcd failed with error -2
  2592    [    9.846552] Bluetooth: hci0: BCM: Patch brcm/BCM4334B0.hcd not found
  2593    [    9.850943] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
  2594    [    9.853803] usbcore: registered new interface driver mt7601u
  2595    [   10.566663] brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x50
  2596    [   10.672746] zram: Added device: zram0
  2597    [   10.676197] zram: Added device: zram1
  2598    [   10.679381] zram: Added device: zram2
  2599    [   10.701076] meson8b-dwmac c9410000.ethernet eth0: PHY [0.e40908ff:08] driver [Meson GXL Internal PHY]
  2600    [   10.718825] meson8b-dwmac c9410000.ethernet eth0: No Safety Features support found
  2601    [   10.723273] meson8b-dwmac c9410000.ethernet eth0: PTP not supported by HW
  2602    [   10.730069] meson8b-dwmac c9410000.ethernet eth0: configuring for phy/rmii link mode
  2603    [   10.738434] zram1: detected capacity change from 0 to 912879616
  2604    [   11.380719] random: crng init done
  2605    [   11.383194] random: 7 urandom warning(s) missed due to ratelimiting
  2606    [   11.438589] Adding 891480k swap on /dev/zram1.  Priority:5 extents:1 across:891480k SSFS
  2607
  2608    ### armbian-release:
  2609
  2610    # PLEASE DO NOT EDIT THIS FILE
  2611    BOARD=aml-s9xxx
  2612    BOARD_NAME="AML-S9xxx"
  2613    BOARDFAMILY=aml-s9xxx
  2614    BUILD_REPOSITORY_URL=https://github.com/150balbes/Build-Armbian.git
  2615    BUILD_REPOSITORY_COMMIT=62b8c07-dirty
  2616    DISTRIBUTION_CODENAME=buster
  2617    DISTRIBUTION_STATUS=supported
  2618    VERSION=20.02.0-rc1.037
  2619    LINUXFAMILY=aml-s9xxx
  2620    BRANCH=current
  2621    ARCH=arm64
  2622    IMAGE_TYPE=nightly
  2623    BOARD_TYPE=conf
  2624    INITRD_ARCH=arm64
  2625    KERNEL_IMAGE_TYPE=Image
  2626
  2627    ### boot environment:
  2628
  2629    ODROIDN2-UBOOT-CONFIG
  2630    setenv env_addr 0x10400000
  2631    setenv kernel_addr 0x11000000
  2632    setenv initrd_addr 0x13000000
  2633    setenv dtb_addr 0x1000000
  2634    if test "${devtype}" = ""; then setenv devtype "mmc"; fi
  2635    load ${devtype} ${devnum} ${env_addr} uEnv.txt && env import -t ${env_addr} ${filesize}
  2636    setenv bootargs ${APPEND}
  2637    load ${devtype} ${devnum} ${kernel_addr} ${LINUX}
  2638    load ${devtype} ${devnum} ${initrd_addr} ${INITRD}
  2639    load ${devtype} ${devnum} ${dtb_addr} ${FDT}
  2640    fdt addr ${dtb_addr}
  2641    booti ${kernel_addr} ${initrd_addr} ${dtb_addr}
  2642
  2643    ### lsusb:
  2644
  2645    Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
  2646    Bus 001 Device 003: ID 148f:7601 Ralink Technology, Corp. MT7601U Wireless Adapter
  2647    Bus 001 Device 002: ID 05e3:0608 Genesys Logic, Inc. Hub
  2648    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  2649
  2650    ### lscpu:
  2651
  2652    Architecture:        aarch64
  2653    Byte Order:          Little Endian
  2654    CPU(s):              4
  2655    On-line CPU(s) list: 0-3
  2656    Thread(s) per core:  1
  2657    Core(s) per socket:  4
  2658    Socket(s):           1
  2659    Vendor ID:           ARM
  2660    Model:               4
  2661    Model name:          Cortex-A53
  2662    Stepping:            r0p4
  2663    CPU max MHz:         1512,0000
  2664    CPU min MHz:         100,0000
  2665    BogoMIPS:            48.00
  2666    L1d cache:           unknown size
  2667    L1i cache:           unknown size
  2668    L2 cache:            unknown size
  2669    Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  2670
  2671    ### cpuinfo:
  2672
  2673    processor    : 0
  2674    model name    : ARMv8 Processor rev 4 (v8l)
  2675    BogoMIPS    : 48.00
  2676    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  2677    CPU implementer    : 0x41
  2678    CPU architecture: 8
  2679    CPU variant    : 0x0
  2680    CPU part    : 0xd03
  2681    CPU revision    : 4
  2682
  2683    processor    : 1
  2684    model name    : ARMv8 Processor rev 4 (v8l)
  2685    BogoMIPS    : 48.00
  2686    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  2687    CPU implementer    : 0x41
  2688    CPU architecture: 8
  2689    CPU variant    : 0x0
  2690    CPU part    : 0xd03
  2691    CPU revision    : 4
  2692
  2693    processor    : 2
  2694    model name    : ARMv8 Processor rev 4 (v8l)
  2695    BogoMIPS    : 48.00
  2696    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  2697    CPU implementer    : 0x41
  2698    CPU architecture: 8
  2699    CPU variant    : 0x0
  2700    CPU part    : 0xd03
  2701    CPU revision    : 4
  2702
  2703    processor    : 3
  2704    model name    : ARMv8 Processor rev 4 (v8l)
  2705    BogoMIPS    : 48.00
  2706    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  2707    CPU implementer    : 0x41
  2708    CPU architecture: 8
  2709    CPU variant    : 0x0
  2710    CPU part    : 0xd03
  2711    CPU revision    : 4
  2712
  2713
  2714    ### meminfo:
  2715
  2716    MemTotal:        1782968 kB
  2717    MemFree:         1610676 kB
  2718    MemAvailable:    1666844 kB
  2719    Buffers:           11640 kB
  2720    Cached:            52980 kB
  2721    SwapCached:            0 kB
  2722    Active:            51084 kB
  2723    Inactive:          34584 kB
  2724    Active(anon):      21292 kB
  2725    Inactive(anon):     2636 kB
  2726    Active(file):      29792 kB
  2727    Inactive(file):    31948 kB
  2728    Unevictable:          16 kB
  2729    Mlocked:              16 kB
  2730    SwapTotal:        891480 kB
  2731    SwapFree:         891480 kB
  2732    Dirty:               616 kB
  2733    Writeback:             0 kB
  2734    AnonPages:         21268 kB
  2735    Mapped:            22136 kB
  2736    Shmem:              2752 kB
  2737    KReclaimable:      17544 kB
  2738    Slab:              52484 kB
  2739    SReclaimable:      17544 kB
  2740    SUnreclaim:        34940 kB
  2741    KernelStack:        2760 kB
  2742    PageTables:         1640 kB
  2743    NFS_Unstable:          0 kB
  2744    Bounce:                0 kB
  2745    WritebackTmp:          0 kB
  2746    CommitLimit:     1782964 kB
  2747    Committed_AS:      74504 kB
  2748    VmallocTotal:   135290159040 kB
  2749    VmallocUsed:       16712 kB
  2750    VmallocChunk:          0 kB
  2751    Percpu:             1264 kB
  2752    CmaTotal:         262144 kB
  2753    CmaFree:          258460 kB
  2754    HugePages_Total:       0
  2755    HugePages_Free:        0
  2756    HugePages_Rsvd:        0
  2757    HugePages_Surp:        0
  2758    Hugepagesize:       2048 kB
  2759    Hugetlb:               0 kB
  2760
  2761    ### virtual memory:
  2762
  2763    vm.admin_reserve_kbytes = 8192
  2764    vm.block_dump = 0
  2765    vm.compact_unevictable_allowed = 1
  2766    vm.dirty_background_bytes = 0
  2767    vm.dirty_background_ratio = 10
  2768    vm.dirty_bytes = 0
  2769    vm.dirty_expire_centisecs = 3000
  2770    vm.dirty_ratio = 20
  2771    vm.dirtytime_expire_seconds = 43200
  2772    vm.dirty_writeback_centisecs = 500
  2773    vm.extfrag_threshold = 500
  2774    vm.hugetlb_shm_group = 0
  2775    vm.laptop_mode = 0
  2776    vm.legacy_va_layout = 0
  2777    vm.lowmem_reserve_ratio = 256    256    32    0
  2778    vm.max_map_count = 65530
  2779    vm.min_free_kbytes = 4914
  2780    vm.mmap_min_addr = 4096
  2781    vm.mmap_rnd_bits = 18
  2782    vm.nr_hugepages = 0
  2783    vm.nr_overcommit_hugepages = 0
  2784    vm.oom_dump_tasks = 1
  2785    vm.oom_kill_allocating_task = 0
  2786    vm.overcommit_kbytes = 0
  2787    vm.overcommit_memory = 0
  2788    vm.overcommit_ratio = 50
  2789    vm.page-cluster = 0
  2790    vm.panic_on_oom = 0
  2791    vm.percpu_pagelist_fraction = 0
  2792    vm.stat_interval = 1
  2793    vm.swappiness = 100
  2794    vm.user_reserve_kbytes = 55239
  2795    vm.vfs_cache_pressure = 100
  2796    vm.watermark_boost_factor = 15000
  2797    vm.watermark_scale_factor = 10
  2798
  2799    ### ip addr:
  2800
  2801    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
  2802        link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  2803        inet XXX.XXX.0.1/8 scope host lo
  2804           valid_lft forever preferred_lft forever
  2805        inet6 ::1/128 scope host
  2806           valid_lft forever preferred_lft forever
  2807    2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
  2808        link/ether 00:df:06:00:00:0b brd ff:ff:ff:ff:ff:ff
  2809    3: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  2810        link/ether 00:36:76:61:0b:24 brd ff:ff:ff:ff:ff:ff
  2811
  2812    ### partitions:
  2813
  2814    major minor  #blocks  name
  2815
  2816     179        0   30924800 mmcblk0
  2817     179        1     262144 mmcblk0p1
  2818     179        2   30337024 mmcblk0p2
  2819     179       32   15384576 mmcblk1
  2820     179      128       8192 mmcblk1gp0
  2821     254        1     891484 zram1
  2822
  2823    ### df:
  2824
  2825    udev             738M      0  738M   0% /dev
  2826    tmpfs            175M   2,7M  172M   2% /run
  2827    /dev/mmcblk0p2    29G    10G   19G  36% /
  2828    tmpfs            871M      0  871M   0% /dev/shm
  2829    tmpfs            5,0M   4,0K  5,0M   1% /run/lock
  2830    tmpfs            871M      0  871M   0% /sys/fs/cgroup
  2831    tmpfs            871M      0  871M   0% /tmp
  2832    /dev/mmcblk0p1   256M    76M  180M  30% /boot
  2833
  2834    ### lsblk:
  2835
  2836    NAME         FSTYPE   SIZE MOUNTPOINT UUID
  2837    mmcblk0              29,5G
  2838    ├─mmcblk0p1  vfat     256M /boot      50FC-6AC8
  2839    └─mmcblk0p2  ext4      29G /          3e297ac1-e4e4-4ab1-bc57-47c07d0422ba
  2840    mmcblk1              14,7G
  2841    mmcblk1boot0            4M
  2842    mmcblk1boot1            4M
  2843    mmcblk1gp0              8M
  2844
  2845    ### zramctl:
  2846
  2847    NAME       ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT
  2848    /dev/zram1 lzo         870,6M   4K   81B   12K       4 [SWAP]
  2849
  2850    ### mtab:
  2851
  2852    /dev/mmcblk0p1 /boot vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro 0 0
  2853    /dev/mmcblk0p2 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  2854
  2855    ### mmc0:59b4 info:
  2856
  2857                   fwrev: 0x0
  2858                  uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SDU1  MODALIAS=mmc:block
  2859                     cid: 1b534d53445531201014a136d4013800
  2860                     rca: 0x59b4
  2861                     csd: 400e00325b590000ebef7f800a400000
  2862                  manfid: 0x00001b
  2863                     ocr: 0x00200000
  2864    preferred_erase_size: 4194304
  2865                    type: SD
  2866                   hwrev: 0x1
  2867                    date: 08/2019
  2868                     dsr: 0x404
  2869              erase_size: 512
  2870                   oemid: 0x534d
  2871                  serial: 0x14a136d4
  2872                     ssr: 0000000005000000040090000811391e00089a342f01000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  2873                     scr: 0235844300000000
  2874                    name: SDU1
  2875
  2876    ### mmc1:0001 info:
  2877
  2878                   fwrev: 0x0
  2879                  uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=016G92 MODALIAS=mmc:block
  2880                     cid: 11010030313647393201d3d1a4db1100
  2881             rel_sectors: 0x10
  2882                     rca: 0x0001
  2883            pre_eol_info: 0x00
  2884                     csd: d00e00320f5903ffffffffef92400000
  2885                  manfid: 0x000011
  2886                     ocr: 0x00200000
  2887    preferred_erase_size: 4194304
  2888    enhanced_area_offset: 18446744073709551594
  2889      raw_rpmb_size_mult: 0x4
  2890                    type: MMC
  2891                   hwrev: 0x0
  2892                    date: 01/2014
  2893                     prv: 0x1
  2894             ffu_capable: 0
  2895                     dsr: 0x404
  2896              erase_size: 4194304
  2897               life_time: 0x00 0x00
  2898      enhanced_area_size: 4294967274
  2899                   oemid: 0x0100
  2900                  serial: 0xd3d1a4db
  2901                 cmdq_en: 0
  2902                     rev: 0x6
  2903                    name: 016G92
  2904
  2905    ### Boot system health:
  2906
  2907    Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU
  2908    09:17:07: 1512MHz  0.62  50%  24%  14%   0%  10%   1% 57.0°C
  2909    09:17:07: 1512MHz  0.62  64%   6%  10%   0%  44%   1% 57.0°C
  2910    09:17:07: 1512MHz  0.62  70%  10%  22%   2%  34%   2% 57.0°C
  2911    09:17:08: 1512MHz  0.89  56%   9%  13%   0%  30%   1% 57.0°C
  2912    09:17:08: 1512MHz  0.89  33%   5%   4%   1%  20%   1% 56.0°C
  2913
  2914    ### Activated 1 lzo zram swap devices with 870 MB each
  2915
  2916
  2917    mar mar 23 21:19:42 CET 2021 | AML-S9xxx | 20.02.0-rc1.037 | arm64 | aarch64 | 5.5.0-rc6-aml-s9xxx
  2918
  2919    ### dmesg:
  2920
  2921    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
  2922    [    0.000000] Linux version 5.5.0-rc6-aml-s9xxx (root@vbox) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #rc1.037 SMP PREEMPT Wed Feb 5 15:59:04 MSK 2020
  2923    [    0.000000] Machine model: Amlogic Meson GXL (S905X) P212 Development Board
  2924    [    0.000000] efi: Getting EFI parameters from FDT:
  2925    [    0.000000] efi: UEFI not found.
  2926    [    0.000000] Reserved memory: created CMA memory pool at 0x0000000063400000, size 256 MiB
  2927    [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
  2928    [    0.000000] On node 0 totalpages: 477952
  2929    [    0.000000]   DMA zone: 4032 pages used for memmap
  2930    [    0.000000]   DMA zone: 0 pages reserved
  2931    [    0.000000]   DMA zone: 248576 pages, LIFO batch:63
  2932    [    0.000000]   DMA32 zone: 3584 pages used for memmap
  2933    [    0.000000]   DMA32 zone: 229376 pages, LIFO batch:63
  2934    [    0.000000] psci: probing for conduit method from DT.
  2935    [    0.000000] psci: PSCIv0.2 detected in firmware.
  2936    [    0.000000] psci: Using standard PSCI v0.2 function IDs
  2937    [    0.000000] psci: Trusted OS migration not required
  2938    [    0.000000] percpu: Embedded 22 pages/cpu s50392 r8192 d31528 u90112
  2939    [    0.000000] pcpu-alloc: s50392 r8192 d31528 u90112 alloc=22*4096
  2940    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
  2941    [    0.000000] Detected VIPT I-cache on CPU0
  2942    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 470336
  2943    [    0.000000] Kernel command line: root=LABEL=ROOTFS rootflags=data=writeback rw console=ttyAML0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 mac=00:df:06:00:00:0b
  2944    [    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
  2945    [    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
  2946    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
  2947    [    0.000000] software IO TLB: mapped [mem 0x3bfff000-0x3ffff000] (64MB)
  2948    [    0.000000] Memory: 1509616K/1911808K available (14460K kernel code, 1434K rwdata, 5884K rodata, 960K init, 927K bss, 140048K reserved, 262144K cma-reserved)
  2949    [    0.000000] random: get_random_u64 called from cache_random_seq_create+0x7c/0x150 with crng_init=0
  2950    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
  2951    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
  2952    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
  2953    [    0.000000]     Tasks RCU enabled.
  2954    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
  2955    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
  2956    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
  2957    [    0.000000] GIC: Using split EOI/Deactivate mode
  2958    [    0.000000] irq_meson_gpio: 110 to 8 gpio interrupt mux initialized
  2959    [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
  2960    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
  2961    [    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
  2962    [    0.000355] Console: colour dummy device 80x25
  2963    [    0.000657] printk: console [tty0] enabled
  2964    [    0.000697] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
  2965    [    0.000718] pid_max: default: 32768 minimum: 301
  2966    [    0.000841] LSM: Security Framework initializing
  2967    [    0.000892] SELinux:  Initializing.
  2968    [    0.000969] *** VALIDATE SELinux ***
  2969    [    0.001035] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
  2970    [    0.001061] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
  2971    [    0.001123] *** VALIDATE tmpfs ***
  2972    [    0.001531] *** VALIDATE proc ***
  2973    [    0.001753] *** VALIDATE cgroup1 ***
  2974    [    0.001768] *** VALIDATE cgroup2 ***
  2975    [    0.024018] ASID allocator initialised with 32768 entries
  2976    [    0.032003] rcu: Hierarchical SRCU implementation.
  2977    [    0.042089] EFI services will not be available.
  2978    [    0.048059] smp: Bringing up secondary CPUs ...
  2979    [    0.080286] Detected VIPT I-cache on CPU1
  2980    [    0.080340] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
  2981    [    0.112325] Detected VIPT I-cache on CPU2
  2982    [    0.112371] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
  2983    [    0.144375] Detected VIPT I-cache on CPU3
  2984    [    0.144415] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
  2985    [    0.144492] smp: Brought up 1 node, 4 CPUs
  2986    [    0.144559] SMP: Total of 4 processors activated.
  2987    [    0.144570] CPU features: detected: 32-bit EL0 Support
  2988    [    0.144582] CPU features: detected: CRC32 instructions
  2989    [    0.144885] CPU: All CPU(s) started at EL2
  2990    [    0.144908] alternatives: patching kernel code
  2991    [    0.146007] devtmpfs: initialized
  2992    [    0.151117] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
  2993    [    0.151158] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
  2994    [    0.158013] xor: measuring software checksum speed
  2995    [    0.196376]    8regs     :  2375.000 MB/sec
  2996    [    0.236407]    32regs    :  2724.000 MB/sec
  2997    [    0.276446]    arm64_neon:  2406.000 MB/sec
  2998    [    0.276456] xor: using function: 32regs (2724.000 MB/sec)
  2999    [    0.276513] pinctrl core: initialized pinctrl subsystem
  3000    [    0.277174] thermal_sys: Registered thermal governor 'step_wise'
  3001    [    0.277340] DMI not present or invalid.
  3002    [    0.277701] NET: Registered protocol family 16
  3003    [    0.281251] DMA: preallocated 256 KiB pool for atomic allocations
  3004    [    0.281299] audit: initializing netlink subsys (disabled)
  3005    [    0.281513] audit: type=2000 audit(0.280:1): state=initialized audit_enabled=0 res=1
  3006    [    0.282591] cpuidle: using governor ladder
  3007    [    0.282633] cpuidle: using governor menu
  3008    [    0.283004] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
  3009    [    0.283717] Serial: AMBA PL011 UART driver
  3010    [    0.297724] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
  3011    [    0.297751] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
  3012    [    0.297764] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
  3013    [    0.297777] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
  3014    [    0.301295] cryptd: max_cpu_qlen set to 1000
  3015    [    0.376682] raid6: neonx8   gen()  1621 MB/s
  3016    [    0.444706] raid6: neonx8   xor()  1493 MB/s
  3017    [    0.512771] raid6: neonx4   gen()  1563 MB/s
  3018    [    0.580813] raid6: neonx4   xor()  1469 MB/s
  3019    [    0.648868] raid6: neonx2   gen()  1200 MB/s
  3020    [    0.716918] raid6: neonx2   xor()  1217 MB/s
  3021    [    0.784985] raid6: neonx1   gen()   788 MB/s
  3022    [    0.853045] raid6: neonx1   xor()   914 MB/s
  3023    [    0.921081] raid6: int64x8  gen()  1194 MB/s
  3024    [    0.989136] raid6: int64x8  xor()   769 MB/s
  3025    [    1.057201] raid6: int64x4  gen()  1029 MB/s
  3026    [    1.125252] raid6: int64x4  xor()   752 MB/s
  3027    [    1.193278] raid6: int64x2  gen()   728 MB/s
  3028    [    1.261329] raid6: int64x2  xor()   618 MB/s
  3029    [    1.329460] raid6: int64x1  gen()   486 MB/s
  3030    [    1.397431] raid6: int64x1  xor()   468 MB/s
  3031    [    1.397441] raid6: using algorithm neonx8 gen() 1621 MB/s
  3032    [    1.397451] raid6: .... xor() 1493 MB/s, rmw enabled
  3033    [    1.397467] raid6: using neon recovery algorithm
  3034    [    1.397715] ACPI: Interpreter disabled.
  3035    [    1.398887] iommu: Default domain type: Translated
  3036    [    1.399164] vgaarb: loaded
  3037    [    1.399744] SCSI subsystem initialized
  3038    [    1.399927] libata version 3.00 loaded.
  3039    [    1.400133] usbcore: registered new interface driver usbfs
  3040    [    1.400178] usbcore: registered new interface driver hub
  3041    [    1.400241] usbcore: registered new device driver usb
  3042    [    1.400645] pps_core: LinuxPPS API ver. 1 registered
  3043    [    1.400658] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
  3044    [    1.400680] PTP clock support registered
  3045    [    1.400707] EDAC MC: Ver: 3.0.0
  3046    [    1.401303] FPGA manager framework
  3047    [    1.401392] Advanced Linux Sound Architecture Driver Initialized.
  3048    [    1.401881] NetLabel: Initializing
  3049    [    1.401895] NetLabel:  domain hash size = 128
  3050    [    1.401904] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
  3051    [    1.401957] NetLabel:  unlabeled traffic allowed by default
  3052    [    1.402438] clocksource: Switched to clocksource arch_sys_counter
  3053    [    1.402460] *** VALIDATE bpf ***
  3054    [    1.402710] VFS: Disk quotas dquot_6.6.0
  3055    [    1.402769] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
  3056    [    1.402892] FS-Cache: Loaded
  3057    [    1.402903] *** VALIDATE ramfs ***
  3058    [    1.402925] *** VALIDATE hugetlbfs ***
  3059    [    1.403296] pnp: PnP ACPI: disabled
  3060    [    1.408322] NET: Registered protocol family 2
  3061    [    1.408821] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
  3062    [    1.408871] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
  3063    [    1.408988] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
  3064    [    1.409233] TCP: Hash tables configured (established 16384 bind 16384)
  3065    [    1.409395] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
  3066    [    1.409450] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
  3067    [    1.409667] NET: Registered protocol family 1
  3068    [    1.410120] RPC: Registered named UNIX socket transport module.
  3069    [    1.410140] RPC: Registered udp transport module.
  3070    [    1.410149] RPC: Registered tcp transport module.
  3071    [    1.410159] RPC: Registered tcp NFSv4.1 backchannel transport module.
  3072    [    1.410175] NET: Registered protocol family 44
  3073    [    1.410196] PCI: CLS 0 bytes, default 64
  3074    [    1.410388] Trying to unpack rootfs image as initramfs...
  3075    [    1.871864] Freeing initrd memory: 10248K
  3076    [    1.872664] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
  3077    [    2.086306] Initialise system trusted keyrings
  3078    [    2.086595] workingset: timestamp_bits=46 max_order=19 bucket_order=0
  3079    [    2.091765] zbud: loaded
  3080    [    2.093008] squashfs: version 4.0 (2009/01/31) Phillip Lougher
  3081    [    2.093291] FS-Cache: Netfs 'nfs' registered for caching
  3082    [    2.093830] NFS: Registering the id_resolver key type
  3083    [    2.093870] Key type id_resolver registered
  3084    [    2.093880] Key type id_legacy registered
  3085    [    2.093896] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
  3086    [    2.093908] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
  3087    [    2.095063] FS-Cache: Netfs 'cifs' registered for caching
  3088    [    2.095384] Key type cifs.spnego registered
  3089    [    2.095403] Key type cifs.idmap registered
  3090    [    2.095425] ntfs: driver 2.1.32 [Flags: R/W].
  3091    [    2.095992] JFS: nTxBlock = 8192, nTxLock = 65536
  3092    [    2.101852] SGI XFS with ACLs, security attributes, realtime, quota, no debug enabled
  3093    [    2.103292] *** VALIDATE xfs ***
  3094    [    2.103576] ocfs2: Registered cluster interface o2cb
  3095    [    2.103788] OCFS2 User DLM kernel interface loaded
  3096    [    2.105194] *** VALIDATE gfs2 ***
  3097    [    2.105475] gfs2: GFS2 installed
  3098    [    2.106400] aufs 5.5-20200203
  3099    [    2.126670] Key type asymmetric registered
  3100    [    2.126695] Asymmetric key parser 'x509' registered
  3101    [    2.126706] Asymmetric key parser 'pkcs8' registered
  3102    [    2.126775] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
  3103    [    2.126970] io scheduler mq-deadline registered
  3104    [    2.126984] io scheduler kyber registered
  3105    [    2.127183] io scheduler bfq registered
  3106    [    2.139800] soc soc0: Amlogic Meson GXL (S905X) Revision 21:b (82:2) Detected
  3107    [    2.143368] Serial: 8250/16550 driver, 5 ports, IRQ sharing enabled
  3108    [    2.145047] Serial: AMBA driver
  3109    [    2.145418] c11084c0.serial: ttyAML6 at MMIO 0xc11084c0 (irq = 10, base_baud = 1500000) is a meson_uart
  3110    [    2.145573] serial serial0: tty port ttyAML6 registered
  3111    [    2.145782] c81004c0.serial: ttyAML0 at MMIO 0xc81004c0 (irq = 13, base_baud = 1500000) is a meson_uart
  3112    [    3.121269] printk: console [ttyAML0] enabled
  3113    [    3.137363] brd: module loaded
  3114    [    3.145840] loop: module loaded
  3115    [    3.148319] libphy: Fixed MDIO Bus: probed
  3116    [    3.148969] meson8b-dwmac c9410000.ethernet: IRQ eth_wake_irq not found
  3117    [    3.154019] meson8b-dwmac c9410000.ethernet: IRQ eth_lpi not found
  3118    [    3.160213] meson8b-dwmac c9410000.ethernet: PTP uses main clock
  3119    [    3.166069] meson8b-dwmac c9410000.ethernet: no reset control found
  3120    [    3.172767] meson8b-dwmac c9410000.ethernet: User ID: 0x11, Synopsys ID: 0x37
  3121    [    3.179371] meson8b-dwmac c9410000.ethernet:     DWMAC1000
  3122    [    3.184538] meson8b-dwmac c9410000.ethernet: DMA HW capability register supported
  3123    [    3.191939] meson8b-dwmac c9410000.ethernet: RX Checksum Offload Engine supported
  3124    [    3.199356] meson8b-dwmac c9410000.ethernet: COE Type 2
  3125    [    3.204529] meson8b-dwmac c9410000.ethernet: TX Checksum insertion supported
  3126    [    3.211515] meson8b-dwmac c9410000.ethernet: Wake-Up On Lan supported
  3127    [    3.217929] meson8b-dwmac c9410000.ethernet: Normal descriptors
  3128    [    3.223764] meson8b-dwmac c9410000.ethernet: Ring mode enabled
  3129    [    3.229541] meson8b-dwmac c9410000.ethernet: Enable RX Mitigation via HW Watchdog Timer
  3130    [    3.237658] libphy: stmmac: probed
  3131    [    3.242151] VFIO - User Level meta-driver version: 0.3
  3132    [    3.247500] dwc3 c9000000.dwc3: Failed to get clk 'ref': -2
  3133    [    3.252360] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
  3134    [    3.257950] ehci-pci: EHCI PCI platform driver
  3135    [    3.262384] ehci-platform: EHCI generic platform driver
  3136    [    3.267686] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
  3137    [    3.273632] ohci-pci: OHCI PCI platform driver
  3138    [    3.278060] ohci-platform: OHCI generic platform driver
  3139    [    3.283798] usbcore: registered new interface driver usb-storage
  3140    [    3.289396] mousedev: PS/2 mouse device common for all mice
  3141    [    3.295328] i2c /dev entries driver
  3142    [    3.300944] sdhci: Secure Digital Host Controller Interface driver
  3143    [    3.304251] sdhci: Copyright(c) Pierre Ossman
  3144    [    3.308566] Synopsys Designware Multimedia Card Interface Driver
  3145    [    3.315828] meson-gx-mmc d0072000.mmc: Got CD GPIO
  3146    [    3.346475] meson-gx-mmc d0074000.mmc: allocated mmc-pwrseq
  3147    [    3.377729] sdhci-pltfm: SDHCI platform and OF driver helper
  3148    [    3.378609] ledtrig-cpu: registered to indicate activity on CPUs
  3149    [    3.384289] meson-sm: secure-monitor enabled
  3150    [    3.386108] mmc0: new high speed SDHC card at address 59b4
  3151    [    3.388806] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
  3152    [    3.398316] mmcblk0: mmc0:59b4 SDU1  29.5 GiB
  3153    [    3.401395] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
  3154    [    3.416240]  mmcblk0: p1 p2
  3155    [    3.428925] hid: raw HID events driver (C) Jiri Kosina
  3156    [    3.429163] usbcore: registered new interface driver usbhid
  3157    [    3.433982] usbhid: USB HID core driver
  3158    [    3.438122] platform-mhu c883c404.mailbox: Platform MHU Mailbox registered
  3159    [    3.454817] NET: Registered protocol family 17
  3160    [    3.455072] Key type dns_resolver registered
  3161    [    3.458374] registered taskstats version 1
  3162    [    3.461943] Loading compiled-in X.509 certificates
  3163    [    3.466872] zswap: loaded using pool lzo/zbud
  3164    [    3.471179] Key type ._fscrypt registered
  3165    [    3.474951] Key type .fscrypt registered
  3166    [    3.480317] Btrfs loaded, crc32c=crc32c-generic
  3167    [    3.500162] mmc1: new HS200 MMC card at address 0001
  3168    [    3.501003] mmcblk1: mmc1:0001 016G92 14.7 GiB
  3169    [    3.504604] mmcblk1boot0: mmc1:0001 016G92 partition 1 4.00 MiB
  3170    [    3.510331] mmcblk1boot1: mmc1:0001 016G92 partition 2 4.00 MiB
  3171    [    3.510548] Key type encrypted registered
  3172    [    3.516162] mmcblk1gp0: mmc1:0001 016G92 partition 4 8.00 MiB
  3173    [    3.525704] mmcblk1rpmb: mmc1:0001 016G92 partition 3 512 KiB, chardev (243:0)
  3174    [    3.539703] meson-drm d0100000.vpu: Queued 3 outputs on vpu
  3175    [    3.540066] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
  3176    [    3.546244] [drm] No driver support for vblank timestamp query.
  3177    [    3.582486] meson-dw-hdmi c883a000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
  3178    [    3.587175] meson-dw-hdmi c883a000.hdmi-tx: registered DesignWare HDMI I2C bus driver
  3179    [    3.595134] meson-drm d0100000.vpu: bound c883a000.hdmi-tx (ops meson_dw_hdmi_ops)
  3180    [    3.602524] [drm] Initialized meson 1.0.0 20161109 for d0100000.vpu on minor 0
  3181    [    3.654111] Console: switching to colour frame buffer device 90x36
  3182    [    3.674471] meson-drm d0100000.vpu: fb0: mesondrmfb frame buffer device
  3183    [    3.681729] libphy: mdio_mux: probed
  3184    [    3.692306] libphy: mdio_mux: probed
  3185    [    3.692784] phy phy-d0078080.phy.2: unsupported PHY mode 5
  3186    [    3.697838] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  3187    [    3.701238] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
  3188    [    3.708956] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228f664 hci version 0x100 quirks 0x0000000002010010
  3189    [    3.718176] xhci-hcd xhci-hcd.0.auto: irq 39, io mem 0xc9000000
  3190    [    3.724300] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.05
  3191    [    3.732533] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  3192    [    3.739680] usb usb1: Product: xHCI Host Controller
  3193    [    3.744508] usb usb1: Manufacturer: Linux 5.5.0-rc6-aml-s9xxx xhci-hcd
  3194    [    3.750977] usb usb1: SerialNumber: xhci-hcd.0.auto
  3195    [    3.756314] hub 1-0:1.0: USB hub found
  3196    [    3.759557] hub 1-0:1.0: 2 ports detected
  3197    [    3.763784] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  3198    [    3.768936] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
  3199    [    3.776520] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
  3200    [    3.783023] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
  3201    [    3.791282] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.05
  3202    [    3.799659] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  3203    [    3.806815] usb usb2: Product: xHCI Host Controller
  3204    [    3.811644] usb usb2: Manufacturer: Linux 5.5.0-rc6-aml-s9xxx xhci-hcd
  3205    [    3.818118] usb usb2: SerialNumber: xhci-hcd.0.auto
  3206    [    3.823409] hub 2-0:1.0: USB hub found
  3207    [    3.826691] hub 2-0:1.0: config failed, hub doesn't have any ports! (err -19)
  3208    [    3.835635] meson-gx-mmc d0070000.mmc: allocated mmc-pwrseq
  3209    [    3.866756] scpi_protocol scpi: SCP Protocol legacy pre-1.0 firmware
  3210    [    3.881694] gx-sound-card sound: snd-soc-dummy-dai <-> c1105400.bus:audio-controller-0 mapping ok
  3211    [    3.893501] gx-sound-card sound: i2s-hifi <-> c1105400.bus:audio-controller-2 mapping ok
  3212    [    3.906981] gx-sound-card sound: ASoC: no DMI vendor name!
  3213    [    3.914094] printk: console [netcon0] enabled
  3214    [    3.916762] netconsole: network logging started
  3215    [    3.921257] hctosys: unable to open rtc device (rtc0)
  3216    [    3.926646] ALSA device list:
  3217    [    3.929147]   #0: AMLGX
  3218    [    3.932152] Freeing unused kernel memory: 960K
  3219    [    3.936019] Run /init as init process
  3220    [    3.952150] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
  3221    [    3.958983] mmc2: queuing unknown CIS tuple 0x80 (6 bytes)
  3222    [    3.966057] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
  3223    [    3.978108] mmc2: queuing unknown CIS tuple 0x80 (19 bytes)
  3224    [    4.004629] random: fast init done
  3225    [    4.063607] mmc2: new high speed SDIO card at address 0001
  3226    [    4.106519] usb 1-1: new high-speed USB device number 2 using xhci-hcd
  3227    [    4.127848] usb 1-1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.36
  3228    [    4.135524] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
  3229    [    4.141775] usb 1-1: Product: USB2.0 Hub
  3230    [    4.199533] hub 1-1:1.0: USB hub found
  3231    [    4.202102] hub 1-1:1.0: 4 ports detected
  3232    [    4.338530] usb 1-2: new high-speed USB device number 3 using xhci-hcd
  3233    [    4.368971] usb 1-2: New USB device found, idVendor=148f, idProduct=7601, bcdDevice= 0.00
  3234    [    4.376432] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
  3235    [    4.390570] usb 1-2: Product: 802.11 n WLAN
  3236    [    4.392787] usb 1-2: Manufacturer: MediaTek
  3237    [    4.395474] usb 1-2: SerialNumber: 1.0
  3238    [    5.099822] EXT4-fs (mmcblk0p2): mounted filesystem with writeback data mode. Opts: data=writeback
  3239    [    6.048820] systemd[1]: System time before build time, advancing clock.
  3240    [    6.196333] NET: Registered protocol family 10
  3241    [    6.270105] Segment Routing with IPv6
  3242    [    6.320855] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
  3243    [    6.354372] systemd[1]: Detected architecture arm64.
  3244    [    6.407432] systemd[1]: Set hostname to <mxqpro>.
  3245    [    6.440906] systemd[1]: Couldn't move remaining userspace processes, ignoring: Input/output error
  3246    [    7.139111] random: systemd: uninitialized urandom read (16 bytes read)
  3247    [    7.151443] random: systemd: uninitialized urandom read (16 bytes read)
  3248    [    7.155058] systemd[1]: Reached target Swap.
  3249    [    7.162373] random: systemd: uninitialized urandom read (16 bytes read)
  3250    [    7.166618] systemd[1]: Listening on Journal Socket.
  3251    [    7.179338] systemd[1]: Mounting Huge Pages File System...
  3252    [    7.185005] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
  3253    [    7.193947] systemd[1]: Created slice User and Session Slice.
  3254    [    7.204144] systemd[1]: Starting Restore / save the current clock...
  3255    [    7.347072] EXT4-fs (mmcblk0p2): re-mounted. Opts: commit=600,errors=remount-ro
  3256    [    7.629413] systemd-journald[414]: Received request to flush runtime journal from PID 1
  3257    [    8.162338] Registered IR keymap rc-empty
  3258    [    8.167562] rc rc0: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0
  3259    [    8.167715] input: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0/input0
  3260    [    8.168779] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
  3261    [    8.168977] meson-ir c8100580.ir: receiver initialized
  3262    [    8.197964] mc: Linux media interface: v0.10
  3263    [    8.225407] videodev: Linux video capture interface: v2.00
  3264    [    8.337571] Bluetooth: Core ver 2.22
  3265    [    8.341132] NET: Registered protocol family 31
  3266    [    8.344095] Bluetooth: HCI device and connection manager initialized
  3267    [    8.348947] Bluetooth: HCI socket layer initialized
  3268    [    8.353709] Bluetooth: L2CAP socket layer initialized
  3269    [    8.359498] Bluetooth: SCO socket layer initialized
  3270    [    8.360538] lima d00c0000.gpu: IRQ ppmmu3 not found
  3271    [    8.368178] lima d00c0000.gpu: IRQ ppmmu4 not found
  3272    [    8.372908] lima d00c0000.gpu: IRQ ppmmu5 not found
  3273    [    8.377853] lima d00c0000.gpu: IRQ ppmmu6 not found
  3274    [    8.382529] lima d00c0000.gpu: IRQ ppmmu7 not found
  3275    [    8.387445] lima d00c0000.gpu: gp - mali450 version major 0 minor 0
  3276    [    8.395703] lima d00c0000.gpu: pp0 - mali450 version major 0 minor 0
  3277    [    8.401955] lima d00c0000.gpu: pp1 - mali450 version major 0 minor 0
  3278    [    8.408416] lima d00c0000.gpu: pp2 - mali450 version major 0 minor 0
  3279    [    8.414739] lima d00c0000.gpu: IRQ pp3 not found
  3280    [    8.417351] lima d00c0000.gpu: IRQ pp4 not found
  3281    [    8.424486] lima d00c0000.gpu: IRQ pp5 not found
  3282    [    8.427863] lima d00c0000.gpu: IRQ pp6 not found
  3283    [    8.432895] lima d00c0000.gpu: IRQ pp7 not found
  3284    [    8.436839] lima d00c0000.gpu: l2 cache 8K, 4-way, 64byte cache line, 128bit external bus
  3285    [    8.444957] lima d00c0000.gpu: l2 cache 64K, 4-way, 64byte cache line, 128bit external bus
  3286    [    8.453791] lima d00c0000.gpu: bus rate = 166666667
  3287    [    8.456591] lima d00c0000.gpu: mod rate = 744000000
  3288    [    8.466237] [drm] Initialized lima 1.0.0 20190217 for d00c0000.gpu on minor 1
  3289    [    8.578496] Bluetooth: HCI UART driver ver 2.3
  3290    [    8.580103] Bluetooth: HCI UART protocol H4 registered
  3291    [    8.590577] Bluetooth: HCI UART protocol BCSP registered
  3292    [    8.592215] Bluetooth: HCI UART protocol LL registered
  3293    [    8.604950] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
  3294    [    8.607957] Bluetooth: HCI UART protocol ATH3K registered
  3295    [    8.625058] Bluetooth: HCI UART protocol Three-wire (H5) registered
  3296    [    8.641264] cfg80211: Loading compiled-in X.509 certificates for regulatory database
  3297    [    8.671320] Bluetooth: HCI UART protocol Intel registered
  3298    [    8.673562] hci_uart_bcm serial0-0: serial0-0 supply vbat not found, using dummy regulator
  3299    [    8.681406] hci_uart_bcm serial0-0: serial0-0 supply vddio not found, using dummy regulator
  3300    [    8.694377] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
  3301    [    8.697434] Bluetooth: HCI UART protocol Broadcom registered
  3302    [    8.710645] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
  3303    [    8.718241] cfg80211: failed to load regulatory.db
  3304    [    8.729581] Bluetooth: HCI UART protocol QCA registered
  3305    [    8.745239] Bluetooth: HCI UART protocol AG6XX registered
  3306    [    8.757175] Bluetooth: HCI UART protocol Marvell registered
  3307    [    8.874079] brcmfmac: F1 signature read @0x18000000=0x16034334
  3308    [    8.877379] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4334-sdio for chip BCM4334/3
  3309    [    8.885521] usbcore: registered new interface driver brcmfmac
  3310    [    8.934980] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.amlogic,p212.txt failed with error -2
  3311    [    8.945342] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.txt failed with error -2
  3312    [    8.982983] usb 1-2: reset high-speed USB device number 3 using xhci-hcd
  3313    [    9.006286] mt7601u 1-2:1.0: ASIC revision: 76010001 MAC revision: 76010500
  3314    [    9.075576] mt7601u 1-2:1.0: EEPROM ver:0d fae:00
  3315    [    9.083475] Bluetooth: hci0: BCM: chip id 68
  3316    [    9.087249] Bluetooth: hci0: BCM: features 0x0f
  3317    [    9.091998] Bluetooth: hci0: BCM4334B0
  3318    [    9.095099] Bluetooth: hci0: BCM4334B0 (002.001.013) build 0000
  3319    [    9.099318] bluetooth hci0: Direct firmware load for brcm/BCM4334B0.hcd failed with error -2
  3320    [    9.108322] Bluetooth: hci0: BCM: Patch brcm/BCM4334B0.hcd not found
  3321    [    9.286109] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
  3322    [    9.287337] usbcore: registered new interface driver mt7601u
  3323    [    9.921115] zram: Added device: zram0
  3324    [    9.924739] zram: Added device: zram1
  3325    [    9.928700] zram: Added device: zram2
  3326    [    9.970535] brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x50
  3327    [    9.981194] zram1: detected capacity change from 0 to 912879616
  3328    [   10.037232] meson8b-dwmac c9410000.ethernet eth0: PHY [0.e40908ff:08] driver [Meson GXL Internal PHY]
  3329    [   10.058536] meson8b-dwmac c9410000.ethernet eth0: No Safety Features support found
  3330    [   10.063028] meson8b-dwmac c9410000.ethernet eth0: PTP not supported by HW
  3331    [   10.069766] meson8b-dwmac c9410000.ethernet eth0: configuring for phy/rmii link mode
  3332    [   10.701039] random: crng init done
  3333    [   10.703560] random: 7 urandom warning(s) missed due to ratelimiting
  3334    [   10.810732] Adding 891480k swap on /dev/zram1.  Priority:5 extents:1 across:891480k SSFS
  3335
  3336    ### armbian-release:
  3337
  3338    # PLEASE DO NOT EDIT THIS FILE
  3339    BOARD=aml-s9xxx
  3340    BOARD_NAME="AML-S9xxx"
  3341    BOARDFAMILY=aml-s9xxx
  3342    BUILD_REPOSITORY_URL=https://github.com/150balbes/Build-Armbian.git
  3343    BUILD_REPOSITORY_COMMIT=62b8c07-dirty
  3344    DISTRIBUTION_CODENAME=buster
  3345    DISTRIBUTION_STATUS=supported
  3346    VERSION=20.02.0-rc1.037
  3347    LINUXFAMILY=aml-s9xxx
  3348    BRANCH=current
  3349    ARCH=arm64
  3350    IMAGE_TYPE=nightly
  3351    BOARD_TYPE=conf
  3352    INITRD_ARCH=arm64
  3353    KERNEL_IMAGE_TYPE=Image
  3354
  3355    ### boot environment:
  3356
  3357    ODROIDN2-UBOOT-CONFIG
  3358    setenv env_addr 0x10400000
  3359    setenv kernel_addr 0x11000000
  3360    setenv initrd_addr 0x13000000
  3361    setenv dtb_addr 0x1000000
  3362    if test "${devtype}" = ""; then setenv devtype "mmc"; fi
  3363    load ${devtype} ${devnum} ${env_addr} uEnv.txt && env import -t ${env_addr} ${filesize}
  3364    setenv bootargs ${APPEND}
  3365    load ${devtype} ${devnum} ${kernel_addr} ${LINUX}
  3366    load ${devtype} ${devnum} ${initrd_addr} ${INITRD}
  3367    load ${devtype} ${devnum} ${dtb_addr} ${FDT}
  3368    fdt addr ${dtb_addr}
  3369    booti ${kernel_addr} ${initrd_addr} ${dtb_addr}
  3370
  3371    ### lsusb:
  3372
  3373    Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
  3374    Bus 001 Device 003: ID 148f:7601 Ralink Technology, Corp. MT7601U Wireless Adapter
  3375    Bus 001 Device 002: ID 05e3:0608 Genesys Logic, Inc. Hub
  3376    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  3377
  3378    ### lscpu:
  3379
  3380    Architecture:        aarch64
  3381    Byte Order:          Little Endian
  3382    CPU(s):              4
  3383    On-line CPU(s) list: 0-3
  3384    Thread(s) per core:  1
  3385    Core(s) per socket:  4
  3386    Socket(s):           1
  3387    Vendor ID:           ARM
  3388    Model:               4
  3389    Model name:          Cortex-A53
  3390    Stepping:            r0p4
  3391    CPU max MHz:         1512,0000
  3392    CPU min MHz:         100,0000
  3393    BogoMIPS:            48.00
  3394    L1d cache:           unknown size
  3395    L1i cache:           unknown size
  3396    L2 cache:            unknown size
  3397    Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  3398
  3399    ### cpuinfo:
  3400
  3401    processor    : 0
  3402    model name    : ARMv8 Processor rev 4 (v8l)
  3403    BogoMIPS    : 48.00
  3404    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  3405    CPU implementer    : 0x41
  3406    CPU architecture: 8
  3407    CPU variant    : 0x0
  3408    CPU part    : 0xd03
  3409    CPU revision    : 4
  3410
  3411    processor    : 1
  3412    model name    : ARMv8 Processor rev 4 (v8l)
  3413    BogoMIPS    : 48.00
  3414    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  3415    CPU implementer    : 0x41
  3416    CPU architecture: 8
  3417    CPU variant    : 0x0
  3418    CPU part    : 0xd03
  3419    CPU revision    : 4
  3420
  3421    processor    : 2
  3422    model name    : ARMv8 Processor rev 4 (v8l)
  3423    BogoMIPS    : 48.00
  3424    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  3425    CPU implementer    : 0x41
  3426    CPU architecture: 8
  3427    CPU variant    : 0x0
  3428    CPU part    : 0xd03
  3429    CPU revision    : 4
  3430
  3431    processor    : 3
  3432    model name    : ARMv8 Processor rev 4 (v8l)
  3433    BogoMIPS    : 48.00
  3434    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  3435    CPU implementer    : 0x41
  3436    CPU architecture: 8
  3437    CPU variant    : 0x0
  3438    CPU part    : 0xd03
  3439    CPU revision    : 4
  3440
  3441
  3442    ### meminfo:
  3443
  3444    MemTotal:        1782968 kB
  3445    MemFree:         1606100 kB
  3446    MemAvailable:    1663936 kB
  3447    Buffers:           11616 kB
  3448    Cached:            54224 kB
  3449    SwapCached:            0 kB
  3450    Active:            52488 kB
  3451    Inactive:          35056 kB
  3452    Active(anon):      22012 kB
  3453    Inactive(anon):     2616 kB
  3454    Active(file):      30476 kB
  3455    Inactive(file):    32440 kB
  3456    Unevictable:          16 kB
  3457    Mlocked:              16 kB
  3458    SwapTotal:        891480 kB
  3459    SwapFree:         891480 kB
  3460    Dirty:               672 kB
  3461    Writeback:             0 kB
  3462    AnonPages:         21924 kB
  3463    Mapped:            23660 kB
  3464    Shmem:              2728 kB
  3465    KReclaimable:      18036 kB
  3466    Slab:              53316 kB
  3467    SReclaimable:      18036 kB
  3468    SUnreclaim:        35280 kB
  3469    KernelStack:        2784 kB
  3470    PageTables:         1628 kB
  3471    NFS_Unstable:          0 kB
  3472    Bounce:                0 kB
  3473    WritebackTmp:          0 kB
  3474    CommitLimit:     1782964 kB
  3475    Committed_AS:      79772 kB
  3476    VmallocTotal:   135290159040 kB
  3477    VmallocUsed:       16776 kB
  3478    VmallocChunk:          0 kB
  3479    Percpu:             1264 kB
  3480    CmaTotal:         262144 kB
  3481    CmaFree:          258460 kB
  3482    HugePages_Total:       0
  3483    HugePages_Free:        0
  3484    HugePages_Rsvd:        0
  3485    HugePages_Surp:        0
  3486    Hugepagesize:       2048 kB
  3487    Hugetlb:               0 kB
  3488
  3489    ### virtual memory:
  3490
  3491    vm.admin_reserve_kbytes = 8192
  3492    vm.block_dump = 0
  3493    vm.compact_unevictable_allowed = 1
  3494    vm.dirty_background_bytes = 0
  3495    vm.dirty_background_ratio = 10
  3496    vm.dirty_bytes = 0
  3497    vm.dirty_expire_centisecs = 3000
  3498    vm.dirty_ratio = 20
  3499    vm.dirtytime_expire_seconds = 43200
  3500    vm.dirty_writeback_centisecs = 500
  3501    vm.extfrag_threshold = 500
  3502    vm.hugetlb_shm_group = 0
  3503    vm.laptop_mode = 0
  3504    vm.legacy_va_layout = 0
  3505    vm.lowmem_reserve_ratio = 256    256    32    0
  3506    vm.max_map_count = 65530
  3507    vm.min_free_kbytes = 4914
  3508    vm.mmap_min_addr = 4096
  3509    vm.mmap_rnd_bits = 18
  3510    vm.nr_hugepages = 0
  3511    vm.nr_overcommit_hugepages = 0
  3512    vm.oom_dump_tasks = 1
  3513    vm.oom_kill_allocating_task = 0
  3514    vm.overcommit_kbytes = 0
  3515    vm.overcommit_memory = 0
  3516    vm.overcommit_ratio = 50
  3517    vm.page-cluster = 0
  3518    vm.panic_on_oom = 0
  3519    vm.percpu_pagelist_fraction = 0
  3520    vm.stat_interval = 1
  3521    vm.swappiness = 100
  3522    vm.user_reserve_kbytes = 55239
  3523    vm.vfs_cache_pressure = 100
  3524    vm.watermark_boost_factor = 15000
  3525    vm.watermark_scale_factor = 10
  3526
  3527    ### ip addr:
  3528
  3529    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
  3530        link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  3531        inet XXX.XXX.0.1/8 scope host lo
  3532           valid_lft forever preferred_lft forever
  3533        inet6 ::1/128 scope host
  3534           valid_lft forever preferred_lft forever
  3535    2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
  3536        link/ether 00:df:06:00:00:0b brd ff:ff:ff:ff:ff:ff
  3537    3: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  3538        link/ether 00:36:76:61:0b:24 brd ff:ff:ff:ff:ff:ff
  3539
  3540    ### partitions:
  3541
  3542    major minor  #blocks  name
  3543
  3544     179        0   30924800 mmcblk0
  3545     179        1     262144 mmcblk0p1
  3546     179        2   30337024 mmcblk0p2
  3547     179       32   15384576 mmcblk1
  3548     179      128       8192 mmcblk1gp0
  3549     254        1     891484 zram1
  3550
  3551    ### df:
  3552
  3553    udev             738M      0  738M   0% /dev
  3554    tmpfs            175M   2,7M  172M   2% /run
  3555    /dev/mmcblk0p2    29G    10G   19G  36% /
  3556    tmpfs            871M      0  871M   0% /dev/shm
  3557    tmpfs            5,0M   4,0K  5,0M   1% /run/lock
  3558    tmpfs            871M      0  871M   0% /sys/fs/cgroup
  3559    tmpfs            871M      0  871M   0% /tmp
  3560    /dev/mmcblk0p1   256M    76M  180M  30% /boot
  3561
  3562    ### lsblk:
  3563
  3564    NAME         FSTYPE   SIZE MOUNTPOINT UUID
  3565    mmcblk0              29,5G
  3566    ├─mmcblk0p1  vfat     256M /boot      50FC-6AC8
  3567    └─mmcblk0p2  ext4      29G /          3e297ac1-e4e4-4ab1-bc57-47c07d0422ba
  3568    mmcblk1              14,7G
  3569    mmcblk1boot0            4M
  3570    mmcblk1boot1            4M
  3571    mmcblk1gp0              8M
  3572
  3573    ### zramctl:
  3574
  3575    NAME       ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT
  3576    /dev/zram1 lzo         870,6M   4K   81B   12K       4 [SWAP]
  3577
  3578    ### mtab:
  3579
  3580    /dev/mmcblk0p1 /boot vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro 0 0
  3581    /dev/mmcblk0p2 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  3582
  3583    ### mmc0:59b4 info:
  3584
  3585                   fwrev: 0x0
  3586                  uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SDU1  MODALIAS=mmc:block
  3587                     cid: 1b534d53445531201014a136d4013800
  3588                     rca: 0x59b4
  3589                     csd: 400e00325b590000ebef7f800a400000
  3590                  manfid: 0x00001b
  3591                     ocr: 0x00200000
  3592    preferred_erase_size: 4194304
  3593                    type: SD
  3594                   hwrev: 0x1
  3595                    date: 08/2019
  3596                     dsr: 0x404
  3597              erase_size: 512
  3598                   oemid: 0x534d
  3599                  serial: 0x14a136d4
  3600                     ssr: 0000000005000000040090000811391e00089a342f01000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  3601                     scr: 0235844300000000
  3602                    name: SDU1
  3603
  3604    ### mmc1:0001 info:
  3605
  3606                   fwrev: 0x0
  3607                  uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=016G92 MODALIAS=mmc:block
  3608                     cid: 11010030313647393201d3d1a4db1100
  3609             rel_sectors: 0x10
  3610                     rca: 0x0001
  3611            pre_eol_info: 0x00
  3612                     csd: d00e00320f5903ffffffffef92400000
  3613                  manfid: 0x000011
  3614                     ocr: 0x00200000
  3615    preferred_erase_size: 4194304
  3616    enhanced_area_offset: 18446744073709551594
  3617      raw_rpmb_size_mult: 0x4
  3618                    type: MMC
  3619                   hwrev: 0x0
  3620                    date: 01/2014
  3621                     prv: 0x1
  3622             ffu_capable: 0
  3623                     dsr: 0x404
  3624              erase_size: 4194304
  3625               life_time: 0x00 0x00
  3626      enhanced_area_size: 4294967274
  3627                   oemid: 0x0100
  3628                  serial: 0xd3d1a4db
  3629                 cmdq_en: 0
  3630                     rev: 0x6
  3631                    name: 016G92
  3632
  3633    ### Boot system health:
  3634
  3635    Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU
  3636    21:19:45: 1512MHz  0.55  51%  24%  15%   0%  10%   1% 53.0°C
  3637    21:19:45: 1512MHz  0.55  61%   8%  15%   0%  34%   1% 54.0°C
  3638    21:19:46: 1512MHz  0.55  76%  13%  16%   0%  43%   1% 53.0°C
  3639    21:19:46: 1512MHz  0.55  52%   9%  14%   1%  26%   0% 53.0°C
  3640    21:19:46:  500MHz  0.67  31%   6%   8%   1%  12%   1% 52.0°C
  3641
  3642    ### Activated 1 lzo zram swap devices with 870 MB each
  3643
  3644
  3645    mié mar 24 08:01:46 CET 2021 | AML-S9xxx | 20.02.0-rc1.037 | arm64 | aarch64 | 5.5.0-rc6-aml-s9xxx
  3646
  3647    ### dmesg:
  3648
  3649    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
  3650    [    0.000000] Linux version 5.5.0-rc6-aml-s9xxx (root@vbox) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #rc1.037 SMP PREEMPT Wed Feb 5 15:59:04 MSK 2020
  3651    [    0.000000] Machine model: Amlogic Meson GXL (S905X) P212 Development Board
  3652    [    0.000000] efi: Getting EFI parameters from FDT:
  3653    [    0.000000] efi: UEFI not found.
  3654    [    0.000000] Reserved memory: created CMA memory pool at 0x0000000063400000, size 256 MiB
  3655    [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
  3656    [    0.000000] On node 0 totalpages: 477952
  3657    [    0.000000]   DMA zone: 4032 pages used for memmap
  3658    [    0.000000]   DMA zone: 0 pages reserved
  3659    [    0.000000]   DMA zone: 248576 pages, LIFO batch:63
  3660    [    0.000000]   DMA32 zone: 3584 pages used for memmap
  3661    [    0.000000]   DMA32 zone: 229376 pages, LIFO batch:63
  3662    [    0.000000] psci: probing for conduit method from DT.
  3663    [    0.000000] psci: PSCIv0.2 detected in firmware.
  3664    [    0.000000] psci: Using standard PSCI v0.2 function IDs
  3665    [    0.000000] psci: Trusted OS migration not required
  3666    [    0.000000] percpu: Embedded 22 pages/cpu s50392 r8192 d31528 u90112
  3667    [    0.000000] pcpu-alloc: s50392 r8192 d31528 u90112 alloc=22*4096
  3668    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
  3669    [    0.000000] Detected VIPT I-cache on CPU0
  3670    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 470336
  3671    [    0.000000] Kernel command line: root=LABEL=ROOTFS rootflags=data=writeback rw console=ttyAML0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 mac=00:df:06:00:00:0b
  3672    [    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
  3673    [    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
  3674    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
  3675    [    0.000000] software IO TLB: mapped [mem 0x3bfff000-0x3ffff000] (64MB)
  3676    [    0.000000] Memory: 1509616K/1911808K available (14460K kernel code, 1434K rwdata, 5884K rodata, 960K init, 927K bss, 140048K reserved, 262144K cma-reserved)
  3677    [    0.000000] random: get_random_u64 called from cache_random_seq_create+0x7c/0x150 with crng_init=0
  3678    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
  3679    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
  3680    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
  3681    [    0.000000]     Tasks RCU enabled.
  3682    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
  3683    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
  3684    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
  3685    [    0.000000] GIC: Using split EOI/Deactivate mode
  3686    [    0.000000] irq_meson_gpio: 110 to 8 gpio interrupt mux initialized
  3687    [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
  3688    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
  3689    [    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
  3690    [    0.000355] Console: colour dummy device 80x25
  3691    [    0.000655] printk: console [tty0] enabled
  3692    [    0.000697] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
  3693    [    0.000718] pid_max: default: 32768 minimum: 301
  3694    [    0.000841] LSM: Security Framework initializing
  3695    [    0.000891] SELinux:  Initializing.
  3696    [    0.000970] *** VALIDATE SELinux ***
  3697    [    0.001034] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
  3698    [    0.001064] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
  3699    [    0.001128] *** VALIDATE tmpfs ***
  3700    [    0.001531] *** VALIDATE proc ***
  3701    [    0.001754] *** VALIDATE cgroup1 ***
  3702    [    0.001770] *** VALIDATE cgroup2 ***
  3703    [    0.024017] ASID allocator initialised with 32768 entries
  3704    [    0.032002] rcu: Hierarchical SRCU implementation.
  3705    [    0.042102] EFI services will not be available.
  3706    [    0.048058] smp: Bringing up secondary CPUs ...
  3707    [    0.080287] Detected VIPT I-cache on CPU1
  3708    [    0.080340] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
  3709    [    0.112326] Detected VIPT I-cache on CPU2
  3710    [    0.112373] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
  3711    [    0.144370] Detected VIPT I-cache on CPU3
  3712    [    0.144411] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
  3713    [    0.144485] smp: Brought up 1 node, 4 CPUs
  3714    [    0.144552] SMP: Total of 4 processors activated.
  3715    [    0.144564] CPU features: detected: 32-bit EL0 Support
  3716    [    0.144576] CPU features: detected: CRC32 instructions
  3717    [    0.144879] CPU: All CPU(s) started at EL2
  3718    [    0.144901] alternatives: patching kernel code
  3719    [    0.146000] devtmpfs: initialized
  3720    [    0.151134] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
  3721    [    0.151175] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
  3722    [    0.157994] xor: measuring software checksum speed
  3723    [    0.196365]    8regs     :  2375.000 MB/sec
  3724    [    0.236396]    32regs    :  2724.000 MB/sec
  3725    [    0.276434]    arm64_neon:  2406.000 MB/sec
  3726    [    0.276444] xor: using function: 32regs (2724.000 MB/sec)
  3727    [    0.276499] pinctrl core: initialized pinctrl subsystem
  3728    [    0.277168] thermal_sys: Registered thermal governor 'step_wise'
  3729    [    0.277339] DMI not present or invalid.
  3730    [    0.277699] NET: Registered protocol family 16
  3731    [    0.281233] DMA: preallocated 256 KiB pool for atomic allocations
  3732    [    0.281281] audit: initializing netlink subsys (disabled)
  3733    [    0.281468] audit: type=2000 audit(0.280:1): state=initialized audit_enabled=0 res=1
  3734    [    0.282515] cpuidle: using governor ladder
  3735    [    0.282555] cpuidle: using governor menu
  3736    [    0.282888] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
  3737    [    0.283581] Serial: AMBA PL011 UART driver
  3738    [    0.297615] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
  3739    [    0.297644] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
  3740    [    0.297657] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
  3741    [    0.297669] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
  3742    [    0.301361] cryptd: max_cpu_qlen set to 1000
  3743    [    0.376709] raid6: neonx8   gen()  1623 MB/s
  3744    [    0.444778] raid6: neonx8   xor()  1490 MB/s
  3745    [    0.512860] raid6: neonx4   gen()  1564 MB/s
  3746    [    0.580921] raid6: neonx4   xor()  1470 MB/s
  3747    [    0.648998] raid6: neonx2   gen()  1199 MB/s
  3748    [    0.717076] raid6: neonx2   xor()  1216 MB/s
  3749    [    0.785202] raid6: neonx1   gen()   787 MB/s
  3750    [    0.853268] raid6: neonx1   xor()   915 MB/s
  3751    [    0.921327] raid6: int64x8  gen()  1195 MB/s
  3752    [    0.989332] raid6: int64x8  xor()   769 MB/s
  3753    [    1.057385] raid6: int64x4  gen()  1029 MB/s
  3754    [    1.125444] raid6: int64x4  xor()   752 MB/s
  3755    [    1.193556] raid6: int64x2  gen()   729 MB/s
  3756    [    1.261544] raid6: int64x2  xor()   615 MB/s
  3757    [    1.329690] raid6: int64x1  gen()   486 MB/s
  3758    [    1.397647] raid6: int64x1  xor()   468 MB/s
  3759    [    1.397658] raid6: using algorithm neonx8 gen() 1623 MB/s
  3760    [    1.397668] raid6: .... xor() 1490 MB/s, rmw enabled
  3761    [    1.397678] raid6: using neon recovery algorithm
  3762    [    1.397963] ACPI: Interpreter disabled.
  3763    [    1.399153] iommu: Default domain type: Translated
  3764    [    1.399435] vgaarb: loaded
  3765    [    1.400028] SCSI subsystem initialized
  3766    [    1.400214] libata version 3.00 loaded.
  3767    [    1.400425] usbcore: registered new interface driver usbfs
  3768    [    1.400473] usbcore: registered new interface driver hub
  3769    [    1.400539] usbcore: registered new device driver usb
  3770    [    1.400937] pps_core: LinuxPPS API ver. 1 registered
  3771    [    1.400949] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
  3772    [    1.400973] PTP clock support registered
  3773    [    1.401003] EDAC MC: Ver: 3.0.0
  3774    [    1.401599] FPGA manager framework
  3775    [    1.401710] Advanced Linux Sound Architecture Driver Initialized.
  3776    [    1.402173] NetLabel: Initializing
  3777    [    1.402185] NetLabel:  domain hash size = 128
  3778    [    1.402194] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
  3779    [    1.402254] NetLabel:  unlabeled traffic allowed by default
  3780    [    1.402764] clocksource: Switched to clocksource arch_sys_counter
  3781    [    1.402791] *** VALIDATE bpf ***
  3782    [    1.403040] VFS: Disk quotas dquot_6.6.0
  3783    [    1.403103] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
  3784    [    1.403225] FS-Cache: Loaded
  3785    [    1.403235] *** VALIDATE ramfs ***
  3786    [    1.403256] *** VALIDATE hugetlbfs ***
  3787    [    1.403646] pnp: PnP ACPI: disabled
  3788    [    1.408761] NET: Registered protocol family 2
  3789    [    1.409264] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
  3790    [    1.409312] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
  3791    [    1.409431] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
  3792    [    1.409647] TCP: Hash tables configured (established 16384 bind 16384)
  3793    [    1.409800] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
  3794    [    1.409852] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
  3795    [    1.410064] NET: Registered protocol family 1
  3796    [    1.410539] RPC: Registered named UNIX socket transport module.
  3797    [    1.410559] RPC: Registered udp transport module.
  3798    [    1.410569] RPC: Registered tcp transport module.
  3799    [    1.410578] RPC: Registered tcp NFSv4.1 backchannel transport module.
  3800    [    1.410594] NET: Registered protocol family 44
  3801    [    1.410613] PCI: CLS 0 bytes, default 64
  3802    [    1.410872] Trying to unpack rootfs image as initramfs...
  3803    [    1.872487] Freeing initrd memory: 10248K
  3804    [    1.873283] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
  3805    [    2.087101] Initialise system trusted keyrings
  3806    [    2.087337] workingset: timestamp_bits=46 max_order=19 bucket_order=0
  3807    [    2.092516] zbud: loaded
  3808    [    2.093742] squashfs: version 4.0 (2009/01/31) Phillip Lougher
  3809    [    2.094022] FS-Cache: Netfs 'nfs' registered for caching
  3810    [    2.094544] NFS: Registering the id_resolver key type
  3811    [    2.094581] Key type id_resolver registered
  3812    [    2.094591] Key type id_legacy registered
  3813    [    2.094607] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
  3814    [    2.094619] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
  3815    [    2.095805] FS-Cache: Netfs 'cifs' registered for caching
  3816    [    2.096136] Key type cifs.spnego registered
  3817    [    2.096156] Key type cifs.idmap registered
  3818    [    2.096178] ntfs: driver 2.1.32 [Flags: R/W].
  3819    [    2.096791] JFS: nTxBlock = 8192, nTxLock = 65536
  3820    [    2.102738] SGI XFS with ACLs, security attributes, realtime, quota, no debug enabled
  3821    [    2.104167] *** VALIDATE xfs ***
  3822    [    2.104480] ocfs2: Registered cluster interface o2cb
  3823    [    2.104696] OCFS2 User DLM kernel interface loaded
  3824    [    2.106116] *** VALIDATE gfs2 ***
  3825    [    2.106391] gfs2: GFS2 installed
  3826    [    2.107424] aufs 5.5-20200203
  3827    [    2.128183] Key type asymmetric registered
  3828    [    2.128210] Asymmetric key parser 'x509' registered
  3829    [    2.128220] Asymmetric key parser 'pkcs8' registered
  3830    [    2.128289] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
  3831    [    2.128467] io scheduler mq-deadline registered
  3832    [    2.128483] io scheduler kyber registered
  3833    [    2.128682] io scheduler bfq registered
  3834    [    2.141268] soc soc0: Amlogic Meson GXL (S905X) Revision 21:b (82:2) Detected
  3835    [    2.144819] Serial: 8250/16550 driver, 5 ports, IRQ sharing enabled
  3836    [    2.146498] Serial: AMBA driver
  3837    [    2.146931] c11084c0.serial: ttyAML6 at MMIO 0xc11084c0 (irq = 10, base_baud = 1500000) is a meson_uart
  3838    [    2.147103] serial serial0: tty port ttyAML6 registered
  3839    [    2.147339] c81004c0.serial: ttyAML0 at MMIO 0xc81004c0 (irq = 13, base_baud = 1500000) is a meson_uart
  3840    [    3.122811] printk: console [ttyAML0] enabled
  3841    [    3.138835] brd: module loaded
  3842    [    3.147354] loop: module loaded
  3843    [    3.149722] libphy: Fixed MDIO Bus: probed
  3844    [    3.150378] meson8b-dwmac c9410000.ethernet: IRQ eth_wake_irq not found
  3845    [    3.155554] meson8b-dwmac c9410000.ethernet: IRQ eth_lpi not found
  3846    [    3.161739] meson8b-dwmac c9410000.ethernet: PTP uses main clock
  3847    [    3.167586] meson8b-dwmac c9410000.ethernet: no reset control found
  3848    [    3.174260] meson8b-dwmac c9410000.ethernet: User ID: 0x11, Synopsys ID: 0x37
  3849    [    3.180872] meson8b-dwmac c9410000.ethernet:     DWMAC1000
  3850    [    3.186038] meson8b-dwmac c9410000.ethernet: DMA HW capability register supported
  3851    [    3.193453] meson8b-dwmac c9410000.ethernet: RX Checksum Offload Engine supported
  3852    [    3.200870] meson8b-dwmac c9410000.ethernet: COE Type 2
  3853    [    3.206045] meson8b-dwmac c9410000.ethernet: TX Checksum insertion supported
  3854    [    3.213031] meson8b-dwmac c9410000.ethernet: Wake-Up On Lan supported
  3855    [    3.219446] meson8b-dwmac c9410000.ethernet: Normal descriptors
  3856    [    3.225280] meson8b-dwmac c9410000.ethernet: Ring mode enabled
  3857    [    3.231058] meson8b-dwmac c9410000.ethernet: Enable RX Mitigation via HW Watchdog Timer
  3858    [    3.239174] libphy: stmmac: probed
  3859    [    3.243681] VFIO - User Level meta-driver version: 0.3
  3860    [    3.248997] dwc3 c9000000.dwc3: Failed to get clk 'ref': -2
  3861    [    3.253832] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
  3862    [    3.259463] ehci-pci: EHCI PCI platform driver
  3863    [    3.263921] ehci-platform: EHCI generic platform driver
  3864    [    3.269208] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
  3865    [    3.275147] ohci-pci: OHCI PCI platform driver
  3866    [    3.279575] ohci-platform: OHCI generic platform driver
  3867    [    3.285324] usbcore: registered new interface driver usb-storage
  3868    [    3.290908] mousedev: PS/2 mouse device common for all mice
  3869    [    3.296837] i2c /dev entries driver
  3870    [    3.302494] sdhci: Secure Digital Host Controller Interface driver
  3871    [    3.305766] sdhci: Copyright(c) Pierre Ossman
  3872    [    3.310080] Synopsys Designware Multimedia Card Interface Driver
  3873    [    3.317365] meson-gx-mmc d0072000.mmc: Got CD GPIO
  3874    [    3.347902] meson-gx-mmc d0074000.mmc: allocated mmc-pwrseq
  3875    [    3.379258] sdhci-pltfm: SDHCI platform and OF driver helper
  3876    [    3.380195] ledtrig-cpu: registered to indicate activity on CPUs
  3877    [    3.386163] meson-sm: secure-monitor enabled
  3878    [    3.390227] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
  3879    [    3.397534] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
  3880    [    3.405380] mmc0: new high speed SDHC card at address 59b4
  3881    [    3.415490] mmcblk0: mmc0:59b4 SDU1  29.5 GiB
  3882    [    3.418164]  mmcblk0: p1 p2
  3883    [    3.424070] hid: raw HID events driver (C) Jiri Kosina
  3884    [    3.424303] usbcore: registered new interface driver usbhid
  3885    [    3.429122] usbhid: USB HID core driver
  3886    [    3.433276] platform-mhu c883c404.mailbox: Platform MHU Mailbox registered
  3887    [    3.449845] NET: Registered protocol family 17
  3888    [    3.450134] Key type dns_resolver registered
  3889    [    3.453440] registered taskstats version 1
  3890    [    3.456979] Loading compiled-in X.509 certificates
  3891    [    3.461845] zswap: loaded using pool lzo/zbud
  3892    [    3.466219] Key type ._fscrypt registered
  3893    [    3.469989] Key type .fscrypt registered
  3894    [    3.474963] Btrfs loaded, crc32c=crc32c-generic
  3895    [    3.489771] mmc1: new HS200 MMC card at address 0001
  3896    [    3.490699] mmcblk1: mmc1:0001 016G92 14.7 GiB
  3897    [    3.494114] mmcblk1boot0: mmc1:0001 016G92 partition 1 4.00 MiB
  3898    [    3.499947] mmcblk1boot1: mmc1:0001 016G92 partition 2 4.00 MiB
  3899    [    3.504253] Key type encrypted registered
  3900    [    3.505814] mmcblk1gp0: mmc1:0001 016G92 partition 4 8.00 MiB
  3901    [    3.515269] mmcblk1rpmb: mmc1:0001 016G92 partition 3 512 KiB, chardev (243:0)
  3902    [    3.529028] meson-drm d0100000.vpu: Queued 3 outputs on vpu
  3903    [    3.529479] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
  3904    [    3.535570] [drm] No driver support for vblank timestamp query.
  3905    [    3.566821] meson-dw-hdmi c883a000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
  3906    [    3.571474] meson-dw-hdmi c883a000.hdmi-tx: registered DesignWare HDMI I2C bus driver
  3907    [    3.579490] meson-drm d0100000.vpu: bound c883a000.hdmi-tx (ops meson_dw_hdmi_ops)
  3908    [    3.586839] [drm] Initialized meson 1.0.0 20161109 for d0100000.vpu on minor 0
  3909    [    3.632176] Console: switching to colour frame buffer device 90x36
  3910    [    3.652390] meson-drm d0100000.vpu: fb0: mesondrmfb frame buffer device
  3911    [    3.659669] libphy: mdio_mux: probed
  3912    [    3.670160] libphy: mdio_mux: probed
  3913    [    3.670655] phy phy-d0078080.phy.2: unsupported PHY mode 5
  3914    [    3.675737] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  3915    [    3.679104] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
  3916    [    3.686808] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228f664 hci version 0x100 quirks 0x0000000002010010
  3917    [    3.696018] xhci-hcd xhci-hcd.0.auto: irq 39, io mem 0xc9000000
  3918    [    3.702129] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.05
  3919    [    3.710361] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  3920    [    3.717511] usb usb1: Product: xHCI Host Controller
  3921    [    3.722338] usb usb1: Manufacturer: Linux 5.5.0-rc6-aml-s9xxx xhci-hcd
  3922    [    3.728807] usb usb1: SerialNumber: xhci-hcd.0.auto
  3923    [    3.734135] hub 1-0:1.0: USB hub found
  3924    [    3.737394] hub 1-0:1.0: 2 ports detected
  3925    [    3.741605] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  3926    [    3.746771] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
  3927    [    3.754351] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
  3928    [    3.760866] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
  3929    [    3.769115] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.05
  3930    [    3.777492] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  3931    [    3.784648] usb usb2: Product: xHCI Host Controller
  3932    [    3.789475] usb usb2: Manufacturer: Linux 5.5.0-rc6-aml-s9xxx xhci-hcd
  3933    [    3.795945] usb usb2: SerialNumber: xhci-hcd.0.auto
  3934    [    3.801257] hub 2-0:1.0: USB hub found
  3935    [    3.804513] hub 2-0:1.0: config failed, hub doesn't have any ports! (err -19)
  3936    [    3.813379] meson-gx-mmc d0070000.mmc: allocated mmc-pwrseq
  3937    [    3.843766] scpi_protocol scpi: SCP Protocol legacy pre-1.0 firmware
  3938    [    3.860346] gx-sound-card sound: snd-soc-dummy-dai <-> c1105400.bus:audio-controller-0 mapping ok
  3939    [    3.871872] gx-sound-card sound: i2s-hifi <-> c1105400.bus:audio-controller-2 mapping ok
  3940    [    3.879545] gx-sound-card sound: ASoC: no DMI vendor name!
  3941    [    3.885716] printk: console [netcon0] enabled
  3942    [    3.889181] netconsole: network logging started
  3943    [    3.893749] hctosys: unable to open rtc device (rtc0)
  3944    [    3.899168] ALSA device list:
  3945    [    3.901666]   #0: AMLGX
  3946    [    3.904671] Freeing unused kernel memory: 960K
  3947    [    3.908544] Run /init as init process
  3948    [    3.920532] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
  3949    [    3.928985] mmc2: queuing unknown CIS tuple 0x80 (6 bytes)
  3950    [    3.935916] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
  3951    [    3.947155] mmc2: queuing unknown CIS tuple 0x80 (19 bytes)
  3952    [    3.973021] random: fast init done
  3953    [    4.036133] mmc2: new high speed SDIO card at address 0001
  3954    [    4.078829] usb 1-1: new high-speed USB device number 2 using xhci-hcd
  3955    [    4.100075] usb 1-1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.36
  3956    [    4.106975] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
  3957    [    4.114457] usb 1-1: Product: USB2.0 Hub
  3958    [    4.177348] hub 1-1:1.0: USB hub found
  3959    [    4.179988] hub 1-1:1.0: 4 ports detected
  3960    [    4.310853] usb 1-2: new high-speed USB device number 3 using xhci-hcd
  3961    [    4.341408] usb 1-2: New USB device found, idVendor=148f, idProduct=7601, bcdDevice= 0.00
  3962    [    4.348554] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
  3963    [    4.357117] usb 1-2: Product: 802.11 n WLAN
  3964    [    4.360635] usb 1-2: Manufacturer: MediaTek
  3965    [    4.363813] usb 1-2: SerialNumber: 1.0
  3966    [    5.060678] EXT4-fs (mmcblk0p2): mounted filesystem with writeback data mode. Opts: data=writeback
  3967    [    6.009519] systemd[1]: System time before build time, advancing clock.
  3968    [    6.155845] NET: Registered protocol family 10
  3969    [    6.237468] Segment Routing with IPv6
  3970    [    6.287593] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
  3971    [    6.317767] systemd[1]: Detected architecture arm64.
  3972    [    6.369656] systemd[1]: Set hostname to <mxqpro>.
  3973    [    6.402019] systemd[1]: Couldn't move remaining userspace processes, ignoring: Input/output error
  3974    [    7.079227] random: systemd: uninitialized urandom read (16 bytes read)
  3975    [    7.091773] random: systemd: uninitialized urandom read (16 bytes read)
  3976    [    7.098133] systemd[1]: Created slice User and Session Slice.
  3977    [    7.104512] random: systemd: uninitialized urandom read (16 bytes read)
  3978    [    7.108123] systemd[1]: Reached target System Time Synchronized.
  3979    [    7.119630] systemd[1]: Created slice system-serial\x2dgetty.slice.
  3980    [    7.125760] systemd[1]: Condition check resulted in Arbitrary Executable File Formats File System Automount Point being skipped.
  3981    [    7.137238] systemd[1]: Listening on udev Kernel Socket.
  3982    [    7.145531] systemd[1]: Listening on Journal Socket.
  3983    [    7.312959] EXT4-fs (mmcblk0p2): re-mounted. Opts: commit=600,errors=remount-ro
  3984    [    7.588585] systemd-journald[419]: Received request to flush runtime journal from PID 1
  3985    [    8.119491] mc: Linux media interface: v0.10
  3986    [    8.146808] Registered IR keymap rc-empty
  3987    [    8.150257] rc rc0: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0
  3988    [    8.159027] input: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0/input0
  3989    [    8.159385] videodev: Linux video capture interface: v2.00
  3990    [    8.166155] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
  3991    [    8.180718] meson-ir c8100580.ir: receiver initialized
  3992    [    8.281207] lima d00c0000.gpu: IRQ ppmmu3 not found
  3993    [    8.295039] lima d00c0000.gpu: IRQ ppmmu4 not found
  3994    [    8.297230] lima d00c0000.gpu: IRQ ppmmu5 not found
  3995    [    8.305523] lima d00c0000.gpu: IRQ ppmmu6 not found
  3996    [    8.309379] lima d00c0000.gpu: IRQ ppmmu7 not found
  3997    [    8.311785] lima d00c0000.gpu: gp - mali450 version major 0 minor 0
  3998    [    8.318274] lima d00c0000.gpu: pp0 - mali450 version major 0 minor 0
  3999    [    8.324514] lima d00c0000.gpu: pp1 - mali450 version major 0 minor 0
  4000    [    8.330821] lima d00c0000.gpu: pp2 - mali450 version major 0 minor 0
  4001    [    8.337079] lima d00c0000.gpu: IRQ pp3 not found
  4002    [    8.341548] lima d00c0000.gpu: IRQ pp4 not found
  4003    [    8.346159] lima d00c0000.gpu: IRQ pp5 not found
  4004    [    8.350732] lima d00c0000.gpu: IRQ pp6 not found
  4005    [    8.355163] lima d00c0000.gpu: IRQ pp7 not found
  4006    [    8.359745] lima d00c0000.gpu: l2 cache 8K, 4-way, 64byte cache line, 128bit external bus
  4007    [    8.367982] lima d00c0000.gpu: l2 cache 64K, 4-way, 64byte cache line, 128bit external bus
  4008    [    8.376648] lima d00c0000.gpu: bus rate = 166666667
  4009    [    8.381060] lima d00c0000.gpu: mod rate = 744000000
  4010    [    8.386261] [drm] Initialized lima 1.0.0 20190217 for d00c0000.gpu on minor 1
  4011    [    8.429850] Bluetooth: Core ver 2.22
  4012    [    8.431929] NET: Registered protocol family 31
  4013    [    8.434004] Bluetooth: HCI device and connection manager initialized
  4014    [    8.440509] Bluetooth: HCI socket layer initialized
  4015    [    8.445254] Bluetooth: L2CAP socket layer initialized
  4016    [    8.450381] Bluetooth: SCO socket layer initialized
  4017    [    8.539528] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
  4018    [    8.580125] cfg80211: Loading compiled-in X.509 certificates for regulatory database
  4019    [    8.620889] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
  4020    [    8.629699] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
  4021    [    8.636595] cfg80211: failed to load regulatory.db
  4022    [    8.668217] Bluetooth: HCI UART driver ver 2.3
  4023    [    8.672254] Bluetooth: HCI UART protocol H4 registered
  4024    [    8.674344] Bluetooth: HCI UART protocol BCSP registered
  4025    [    8.687230] Bluetooth: HCI UART protocol LL registered
  4026    [    8.689350] Bluetooth: HCI UART protocol ATH3K registered
  4027    [    8.716365] Bluetooth: HCI UART protocol Three-wire (H5) registered
  4028    [    8.729446] Bluetooth: HCI UART protocol Intel registered
  4029    [    8.732136] Bluetooth: HCI UART protocol Broadcom registered
  4030    [    8.732261] hci_uart_bcm serial0-0: serial0-0 supply vbat not found, using dummy regulator
  4031    [    8.745690] Bluetooth: HCI UART protocol QCA registered
  4032    [    8.748247] hci_uart_bcm serial0-0: serial0-0 supply vddio not found, using dummy regulator
  4033    [    8.761994] Bluetooth: HCI UART protocol AG6XX registered
  4034    [    8.765651] brcmfmac: F1 signature read @0x18000000=0x16034334
  4035    [    8.772888] Bluetooth: HCI UART protocol Marvell registered
  4036    [    8.773290] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4334-sdio for chip BCM4334/3
  4037    [    8.783828] usbcore: registered new interface driver brcmfmac
  4038    [    8.826705] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.amlogic,p212.txt failed with error -2
  4039    [    8.839833] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.txt failed with error -2
  4040    [    8.887159] usb 1-2: reset high-speed USB device number 3 using xhci-hcd
  4041    [    8.910409] mt7601u 1-2:1.0: ASIC revision: 76010001 MAC revision: 76010500
  4042    [    8.944847] mt7601u 1-2:1.0: EEPROM ver:0d fae:00
  4043    [    9.148163] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
  4044    [    9.149051] usbcore: registered new interface driver mt7601u
  4045    [    9.151922] Bluetooth: hci0: BCM: chip id 68
  4046    [    9.156726] Bluetooth: hci0: BCM: features 0x0f
  4047    [    9.162455] Bluetooth: hci0: BCM4334B0
  4048    [    9.166033] Bluetooth: hci0: BCM4334B0 (002.001.013) build 0000
  4049    [    9.170302] bluetooth hci0: Direct firmware load for brcm/BCM4334B0.hcd failed with error -2
  4050    [    9.178556] Bluetooth: hci0: BCM: Patch brcm/BCM4334B0.hcd not found
  4051    [    9.858954] brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x50
  4052    [    9.971908] zram: Added device: zram0
  4053    [    9.977684] zram: Added device: zram1
  4054    [    9.981120] zram: Added device: zram2
  4055    [   10.006027] meson8b-dwmac c9410000.ethernet eth0: PHY [0.e40908ff:08] driver [Meson GXL Internal PHY]
  4056    [   10.036616] zram1: detected capacity change from 0 to 912879616
  4057    [   10.050917] meson8b-dwmac c9410000.ethernet eth0: No Safety Features support found
  4058    [   10.055400] meson8b-dwmac c9410000.ethernet eth0: PTP not supported by HW
  4059    [   10.062116] meson8b-dwmac c9410000.ethernet eth0: configuring for phy/rmii link mode
  4060    [   10.672031] random: crng init done
  4061    [   10.674521] random: 7 urandom warning(s) missed due to ratelimiting
  4062    [   10.723040] Adding 891480k swap on /dev/zram1.  Priority:5 extents:1 across:891480k SSFS
  4063
  4064    ### armbian-release:
  4065
  4066    # PLEASE DO NOT EDIT THIS FILE
  4067    BOARD=aml-s9xxx
  4068    BOARD_NAME="AML-S9xxx"
  4069    BOARDFAMILY=aml-s9xxx
  4070    BUILD_REPOSITORY_URL=https://github.com/150balbes/Build-Armbian.git
  4071    BUILD_REPOSITORY_COMMIT=62b8c07-dirty
  4072    DISTRIBUTION_CODENAME=buster
  4073    DISTRIBUTION_STATUS=supported
  4074    VERSION=20.02.0-rc1.037
  4075    LINUXFAMILY=aml-s9xxx
  4076    BRANCH=current
  4077    ARCH=arm64
  4078    IMAGE_TYPE=nightly
  4079    BOARD_TYPE=conf
  4080    INITRD_ARCH=arm64
  4081    KERNEL_IMAGE_TYPE=Image
  4082
  4083    ### boot environment:
  4084
  4085    ODROIDN2-UBOOT-CONFIG
  4086    setenv env_addr 0x10400000
  4087    setenv kernel_addr 0x11000000
  4088    setenv initrd_addr 0x13000000
  4089    setenv dtb_addr 0x1000000
  4090    if test "${devtype}" = ""; then setenv devtype "mmc"; fi
  4091    load ${devtype} ${devnum} ${env_addr} uEnv.txt && env import -t ${env_addr} ${filesize}
  4092    setenv bootargs ${APPEND}
  4093    load ${devtype} ${devnum} ${kernel_addr} ${LINUX}
  4094    load ${devtype} ${devnum} ${initrd_addr} ${INITRD}
  4095    load ${devtype} ${devnum} ${dtb_addr} ${FDT}
  4096    fdt addr ${dtb_addr}
  4097    booti ${kernel_addr} ${initrd_addr} ${dtb_addr}
  4098
  4099    ### lsusb:
  4100
  4101    Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
  4102    Bus 001 Device 003: ID 148f:7601 Ralink Technology, Corp. MT7601U Wireless Adapter
  4103    Bus 001 Device 002: ID 05e3:0608 Genesys Logic, Inc. Hub
  4104    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  4105
  4106    ### lscpu:
  4107
  4108    Architecture:        aarch64
  4109    Byte Order:          Little Endian
  4110    CPU(s):              4
  4111    On-line CPU(s) list: 0-3
  4112    Thread(s) per core:  1
  4113    Core(s) per socket:  4
  4114    Socket(s):           1
  4115    Vendor ID:           ARM
  4116    Model:               4
  4117    Model name:          Cortex-A53
  4118    Stepping:            r0p4
  4119    CPU max MHz:         1512,0000
  4120    CPU min MHz:         100,0000
  4121    BogoMIPS:            48.00
  4122    L1d cache:           unknown size
  4123    L1i cache:           unknown size
  4124    L2 cache:            unknown size
  4125    Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  4126
  4127    ### cpuinfo:
  4128
  4129    processor    : 0
  4130    model name    : ARMv8 Processor rev 4 (v8l)
  4131    BogoMIPS    : 48.00
  4132    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  4133    CPU implementer    : 0x41
  4134    CPU architecture: 8
  4135    CPU variant    : 0x0
  4136    CPU part    : 0xd03
  4137    CPU revision    : 4
  4138
  4139    processor    : 1
  4140    model name    : ARMv8 Processor rev 4 (v8l)
  4141    BogoMIPS    : 48.00
  4142    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  4143    CPU implementer    : 0x41
  4144    CPU architecture: 8
  4145    CPU variant    : 0x0
  4146    CPU part    : 0xd03
  4147    CPU revision    : 4
  4148
  4149    processor    : 2
  4150    model name    : ARMv8 Processor rev 4 (v8l)
  4151    BogoMIPS    : 48.00
  4152    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  4153    CPU implementer    : 0x41
  4154    CPU architecture: 8
  4155    CPU variant    : 0x0
  4156    CPU part    : 0xd03
  4157    CPU revision    : 4
  4158
  4159    processor    : 3
  4160    model name    : ARMv8 Processor rev 4 (v8l)
  4161    BogoMIPS    : 48.00
  4162    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  4163    CPU implementer    : 0x41
  4164    CPU architecture: 8
  4165    CPU variant    : 0x0
  4166    CPU part    : 0xd03
  4167    CPU revision    : 4
  4168
  4169
  4170    ### meminfo:
  4171
  4172    MemTotal:        1782968 kB
  4173    MemFree:         1609204 kB
  4174    MemAvailable:    1666596 kB
  4175    Buffers:           11472 kB
  4176    Cached:            54512 kB
  4177    SwapCached:            0 kB
  4178    Active:            51108 kB
  4179    Inactive:          35432 kB
  4180    Active(anon):      21068 kB
  4181    Inactive(anon):     2592 kB
  4182    Active(file):      30040 kB
  4183    Inactive(file):    32840 kB
  4184    Unevictable:           0 kB
  4185    Mlocked:               0 kB
  4186    SwapTotal:        891480 kB
  4187    SwapFree:         891480 kB
  4188    Dirty:               500 kB
  4189    Writeback:             4 kB
  4190    AnonPages:         20960 kB
  4191    Mapped:            22916 kB
  4192    Shmem:              2696 kB
  4193    KReclaimable:      17628 kB
  4194    Slab:              52720 kB
  4195    SReclaimable:      17628 kB
  4196    SUnreclaim:        35092 kB
  4197    KernelStack:        2748 kB
  4198    PageTables:         1632 kB
  4199    NFS_Unstable:          0 kB
  4200    Bounce:                0 kB
  4201    WritebackTmp:          0 kB
  4202    CommitLimit:     1782964 kB
  4203    Committed_AS:      77316 kB
  4204    VmallocTotal:   135290159040 kB
  4205    VmallocUsed:       16708 kB
  4206    VmallocChunk:          0 kB
  4207    Percpu:             1264 kB
  4208    CmaTotal:         262144 kB
  4209    CmaFree:          258460 kB
  4210    HugePages_Total:       0
  4211    HugePages_Free:        0
  4212    HugePages_Rsvd:        0
  4213    HugePages_Surp:        0
  4214    Hugepagesize:       2048 kB
  4215    Hugetlb:               0 kB
  4216
  4217    ### virtual memory:
  4218
  4219    vm.admin_reserve_kbytes = 8192
  4220    vm.block_dump = 0
  4221    vm.compact_unevictable_allowed = 1
  4222    vm.dirty_background_bytes = 0
  4223    vm.dirty_background_ratio = 10
  4224    vm.dirty_bytes = 0
  4225    vm.dirty_expire_centisecs = 3000
  4226    vm.dirty_ratio = 20
  4227    vm.dirtytime_expire_seconds = 43200
  4228    vm.dirty_writeback_centisecs = 500
  4229    vm.extfrag_threshold = 500
  4230    vm.hugetlb_shm_group = 0
  4231    vm.laptop_mode = 0
  4232    vm.legacy_va_layout = 0
  4233    vm.lowmem_reserve_ratio = 256    256    32    0
  4234    vm.max_map_count = 65530
  4235    vm.min_free_kbytes = 4914
  4236    vm.mmap_min_addr = 4096
  4237    vm.mmap_rnd_bits = 18
  4238    vm.nr_hugepages = 0
  4239    vm.nr_overcommit_hugepages = 0
  4240    vm.oom_dump_tasks = 1
  4241    vm.oom_kill_allocating_task = 0
  4242    vm.overcommit_kbytes = 0
  4243    vm.overcommit_memory = 0
  4244    vm.overcommit_ratio = 50
  4245    vm.page-cluster = 0
  4246    vm.panic_on_oom = 0
  4247    vm.percpu_pagelist_fraction = 0
  4248    vm.stat_interval = 1
  4249    vm.swappiness = 100
  4250    vm.user_reserve_kbytes = 55254
  4251    vm.vfs_cache_pressure = 100
  4252    vm.watermark_boost_factor = 15000
  4253    vm.watermark_scale_factor = 10
  4254
  4255    ### ip addr:
  4256
  4257    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
  4258        link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  4259        inet XXX.XXX.0.1/8 scope host lo
  4260           valid_lft forever preferred_lft forever
  4261        inet6 ::1/128 scope host
  4262           valid_lft forever preferred_lft forever
  4263    2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
  4264        link/ether 00:df:06:00:00:0b brd ff:ff:ff:ff:ff:ff
  4265    3: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  4266        link/ether 00:36:76:61:0b:24 brd ff:ff:ff:ff:ff:ff
  4267
  4268    ### partitions:
  4269
  4270    major minor  #blocks  name
  4271
  4272     179        0   30924800 mmcblk0
  4273     179        1     262144 mmcblk0p1
  4274     179        2   30337024 mmcblk0p2
  4275     179       32   15384576 mmcblk1
  4276     179      128       8192 mmcblk1gp0
  4277     254        1     891484 zram1
  4278
  4279    ### df:
  4280
  4281    udev             738M      0  738M   0% /dev
  4282    tmpfs            175M   2,7M  172M   2% /run
  4283    /dev/mmcblk0p2    29G    10G   19G  36% /
  4284    tmpfs            871M      0  871M   0% /dev/shm
  4285    tmpfs            5,0M   4,0K  5,0M   1% /run/lock
  4286    tmpfs            871M      0  871M   0% /sys/fs/cgroup
  4287    tmpfs            871M      0  871M   0% /tmp
  4288    /dev/mmcblk0p1   256M    76M  180M  30% /boot
  4289
  4290    ### lsblk:
  4291
  4292    NAME         FSTYPE   SIZE MOUNTPOINT UUID
  4293    mmcblk0              29,5G
  4294    ├─mmcblk0p1  vfat     256M /boot      50FC-6AC8
  4295    └─mmcblk0p2  ext4      29G /          3e297ac1-e4e4-4ab1-bc57-47c07d0422ba
  4296    mmcblk1              14,7G
  4297    mmcblk1boot0            4M
  4298    mmcblk1boot1            4M
  4299    mmcblk1gp0              8M
  4300
  4301    ### zramctl:
  4302
  4303    NAME       ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT
  4304    /dev/zram1 lzo         870,6M   4K   81B   12K       4 [SWAP]
  4305
  4306    ### mtab:
  4307
  4308    /dev/mmcblk0p1 /boot vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro 0 0
  4309    /dev/mmcblk0p2 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  4310
  4311    ### mmc0:59b4 info:
  4312
  4313                   fwrev: 0x0
  4314                  uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SDU1  MODALIAS=mmc:block
  4315                     cid: 1b534d53445531201014a136d4013800
  4316                     rca: 0x59b4
  4317                     csd: 400e00325b590000ebef7f800a400000
  4318                  manfid: 0x00001b
  4319                     ocr: 0x00200000
  4320    preferred_erase_size: 4194304
  4321                    type: SD
  4322                   hwrev: 0x1
  4323                    date: 08/2019
  4324                     dsr: 0x404
  4325              erase_size: 512
  4326                   oemid: 0x534d
  4327                  serial: 0x14a136d4
  4328                     ssr: 0000000005000000040090000811391e00089a342f01000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  4329                     scr: 0235844300000000
  4330                    name: SDU1
  4331
  4332    ### mmc1:0001 info:
  4333
  4334                   fwrev: 0x0
  4335                  uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=016G92 MODALIAS=mmc:block
  4336                     cid: 11010030313647393201d3d1a4db1100
  4337             rel_sectors: 0x10
  4338                     rca: 0x0001
  4339            pre_eol_info: 0x00
  4340                     csd: d00e00320f5903ffffffffef92400000
  4341                  manfid: 0x000011
  4342                     ocr: 0x00200000
  4343    preferred_erase_size: 4194304
  4344    enhanced_area_offset: 18446744073709551594
  4345      raw_rpmb_size_mult: 0x4
  4346                    type: MMC
  4347                   hwrev: 0x0
  4348                    date: 01/2014
  4349                     prv: 0x1
  4350             ffu_capable: 0
  4351                     dsr: 0x404
  4352              erase_size: 4194304
  4353               life_time: 0x00 0x00
  4354      enhanced_area_size: 4294967274
  4355                   oemid: 0x0100
  4356                  serial: 0xd3d1a4db
  4357                 cmdq_en: 0
  4358                     rev: 0x6
  4359                    name: 016G92
  4360
  4361    ### Boot system health:
  4362
  4363    Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU
  4364    08:01:49: 1512MHz  0.55  51%  24%  15%   0%  10%   1% 45.0°C
  4365    08:01:49: 1512MHz  0.55  64%  12%  21%   1%  28%   1% 45.0°C
  4366    08:01:50: 1512MHz  0.55  63%  10%   7%   0%  43%   1% 44.0°C
  4367    08:01:50: 1512MHz  0.55  53%   8%  15%   1%  26%   2% 44.0°C
  4368    08:01:50: 1512MHz  0.55  25%   6%   6%   0%  11%   0% 44.0°C
  4369
  4370    ### Activated 1 lzo zram swap devices with 870 MB each
  4371
  4372
  4373    jue mar 25 08:29:09 CET 2021 | AML-S9xxx | 20.02.0-rc1.037 | arm64 | aarch64 | 5.5.0-rc6-aml-s9xxx
  4374
  4375    ### dmesg:
  4376
  4377    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
  4378    [    0.000000] Linux version 5.5.0-rc6-aml-s9xxx (root@vbox) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #rc1.037 SMP PREEMPT Wed Feb 5 15:59:04 MSK 2020
  4379    [    0.000000] Machine model: Amlogic Meson GXL (S905X) P212 Development Board
  4380    [    0.000000] efi: Getting EFI parameters from FDT:
  4381    [    0.000000] efi: UEFI not found.
  4382    [    0.000000] Reserved memory: created CMA memory pool at 0x0000000063400000, size 256 MiB
  4383    [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
  4384    [    0.000000] On node 0 totalpages: 477952
  4385    [    0.000000]   DMA zone: 4032 pages used for memmap
  4386    [    0.000000]   DMA zone: 0 pages reserved
  4387    [    0.000000]   DMA zone: 248576 pages, LIFO batch:63
  4388    [    0.000000]   DMA32 zone: 3584 pages used for memmap
  4389    [    0.000000]   DMA32 zone: 229376 pages, LIFO batch:63
  4390    [    0.000000] psci: probing for conduit method from DT.
  4391    [    0.000000] psci: PSCIv0.2 detected in firmware.
  4392    [    0.000000] psci: Using standard PSCI v0.2 function IDs
  4393    [    0.000000] psci: Trusted OS migration not required
  4394    [    0.000000] percpu: Embedded 22 pages/cpu s50392 r8192 d31528 u90112
  4395    [    0.000000] pcpu-alloc: s50392 r8192 d31528 u90112 alloc=22*4096
  4396    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
  4397    [    0.000000] Detected VIPT I-cache on CPU0
  4398    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 470336
  4399    [    0.000000] Kernel command line: root=LABEL=ROOTFS rootflags=data=writeback rw console=ttyAML0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 mac=00:df:06:00:00:0b
  4400    [    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
  4401    [    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
  4402    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
  4403    [    0.000000] software IO TLB: mapped [mem 0x3bfff000-0x3ffff000] (64MB)
  4404    [    0.000000] Memory: 1509616K/1911808K available (14460K kernel code, 1434K rwdata, 5884K rodata, 960K init, 927K bss, 140048K reserved, 262144K cma-reserved)
  4405    [    0.000000] random: get_random_u64 called from cache_random_seq_create+0x7c/0x150 with crng_init=0
  4406    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
  4407    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
  4408    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
  4409    [    0.000000]     Tasks RCU enabled.
  4410    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
  4411    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
  4412    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
  4413    [    0.000000] GIC: Using split EOI/Deactivate mode
  4414    [    0.000000] irq_meson_gpio: 110 to 8 gpio interrupt mux initialized
  4415    [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
  4416    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
  4417    [    0.000003] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
  4418    [    0.000353] Console: colour dummy device 80x25
  4419    [    0.000654] printk: console [tty0] enabled
  4420    [    0.000694] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
  4421    [    0.000715] pid_max: default: 32768 minimum: 301
  4422    [    0.000842] LSM: Security Framework initializing
  4423    [    0.000892] SELinux:  Initializing.
  4424    [    0.000969] *** VALIDATE SELinux ***
  4425    [    0.001032] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
  4426    [    0.001058] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
  4427    [    0.001120] *** VALIDATE tmpfs ***
  4428    [    0.001529] *** VALIDATE proc ***
  4429    [    0.001749] *** VALIDATE cgroup1 ***
  4430    [    0.001764] *** VALIDATE cgroup2 ***
  4431    [    0.024017] ASID allocator initialised with 32768 entries
  4432    [    0.032000] rcu: Hierarchical SRCU implementation.
  4433    [    0.042069] EFI services will not be available.
  4434    [    0.048055] smp: Bringing up secondary CPUs ...
  4435    [    0.080281] Detected VIPT I-cache on CPU1
  4436    [    0.080335] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
  4437    [    0.112323] Detected VIPT I-cache on CPU2
  4438    [    0.112370] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
  4439    [    0.144370] Detected VIPT I-cache on CPU3
  4440    [    0.144414] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
  4441    [    0.144491] smp: Brought up 1 node, 4 CPUs
  4442    [    0.144556] SMP: Total of 4 processors activated.
  4443    [    0.144567] CPU features: detected: 32-bit EL0 Support
  4444    [    0.144579] CPU features: detected: CRC32 instructions
  4445    [    0.144884] CPU: All CPU(s) started at EL2
  4446    [    0.144909] alternatives: patching kernel code
  4447    [    0.145995] devtmpfs: initialized
  4448    [    0.151117] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
  4449    [    0.151157] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
  4450    [    0.158019] xor: measuring software checksum speed
  4451    [    0.196360]    8regs     :  2374.000 MB/sec
  4452    [    0.236390]    32regs    :  2724.000 MB/sec
  4453    [    0.276430]    arm64_neon:  2406.000 MB/sec
  4454    [    0.276441] xor: using function: 32regs (2724.000 MB/sec)
  4455    [    0.276496] pinctrl core: initialized pinctrl subsystem
  4456    [    0.277166] thermal_sys: Registered thermal governor 'step_wise'
  4457    [    0.277333] DMI not present or invalid.
  4458    [    0.277696] NET: Registered protocol family 16
  4459    [    0.281243] DMA: preallocated 256 KiB pool for atomic allocations
  4460    [    0.281293] audit: initializing netlink subsys (disabled)
  4461    [    0.281508] audit: type=2000 audit(0.280:1): state=initialized audit_enabled=0 res=1
  4462    [    0.282589] cpuidle: using governor ladder
  4463    [    0.282628] cpuidle: using governor menu
  4464    [    0.282998] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
  4465    [    0.283714] Serial: AMBA PL011 UART driver
  4466    [    0.297728] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
  4467    [    0.297756] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
  4468    [    0.297769] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
  4469    [    0.297781] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
  4470    [    0.301495] cryptd: max_cpu_qlen set to 1000
  4471    [    0.376682] raid6: neonx8   gen()  1621 MB/s
  4472    [    0.444703] raid6: neonx8   xor()  1491 MB/s
  4473    [    0.512752] raid6: neonx4   gen()  1565 MB/s
  4474    [    0.580824] raid6: neonx4   xor()  1471 MB/s
  4475    [    0.648889] raid6: neonx2   gen()  1200 MB/s
  4476    [    0.716938] raid6: neonx2   xor()  1217 MB/s
  4477    [    0.785034] raid6: neonx1   gen()   787 MB/s
  4478    [    0.853075] raid6: neonx1   xor()   915 MB/s
  4479    [    0.921126] raid6: int64x8  gen()  1194 MB/s
  4480    [    0.989166] raid6: int64x8  xor()   769 MB/s
  4481    [    1.057211] raid6: int64x4  gen()  1029 MB/s
  4482    [    1.125279] raid6: int64x4  xor()   752 MB/s
  4483    [    1.193381] raid6: int64x2  gen()   729 MB/s
  4484    [    1.261389] raid6: int64x2  xor()   618 MB/s
  4485    [    1.329481] raid6: int64x1  gen()   486 MB/s
  4486    [    1.397499] raid6: int64x1  xor()   468 MB/s
  4487    [    1.397510] raid6: using algorithm neonx8 gen() 1621 MB/s
  4488    [    1.397520] raid6: .... xor() 1491 MB/s, rmw enabled
  4489    [    1.397530] raid6: using neon recovery algorithm
  4490    [    1.397818] ACPI: Interpreter disabled.
  4491    [    1.399000] iommu: Default domain type: Translated
  4492    [    1.399268] vgaarb: loaded
  4493    [    1.399829] SCSI subsystem initialized
  4494    [    1.399993] libata version 3.00 loaded.
  4495    [    1.400201] usbcore: registered new interface driver usbfs
  4496    [    1.400248] usbcore: registered new interface driver hub
  4497    [    1.400314] usbcore: registered new device driver usb
  4498    [    1.400712] pps_core: LinuxPPS API ver. 1 registered
  4499    [    1.400725] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
  4500    [    1.400748] PTP clock support registered
  4501    [    1.400778] EDAC MC: Ver: 3.0.0
  4502    [    1.401386] FPGA manager framework
  4503    [    1.401500] Advanced Linux Sound Architecture Driver Initialized.
  4504    [    1.401953] NetLabel: Initializing
  4505    [    1.401966] NetLabel:  domain hash size = 128
  4506    [    1.401975] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
  4507    [    1.402039] NetLabel:  unlabeled traffic allowed by default
  4508    [    1.402529] clocksource: Switched to clocksource arch_sys_counter
  4509    [    1.402552] *** VALIDATE bpf ***
  4510    [    1.402804] VFS: Disk quotas dquot_6.6.0
  4511    [    1.402866] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
  4512    [    1.402985] FS-Cache: Loaded
  4513    [    1.402996] *** VALIDATE ramfs ***
  4514    [    1.403016] *** VALIDATE hugetlbfs ***
  4515    [    1.403391] pnp: PnP ACPI: disabled
  4516    [    1.408430] NET: Registered protocol family 2
  4517    [    1.408913] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
  4518    [    1.408959] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
  4519    [    1.409076] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
  4520    [    1.409292] TCP: Hash tables configured (established 16384 bind 16384)
  4521    [    1.409446] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
  4522    [    1.409499] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
  4523    [    1.409708] NET: Registered protocol family 1
  4524    [    1.410157] RPC: Registered named UNIX socket transport module.
  4525    [    1.410178] RPC: Registered udp transport module.
  4526    [    1.410188] RPC: Registered tcp transport module.
  4527    [    1.410197] RPC: Registered tcp NFSv4.1 backchannel transport module.
  4528    [    1.410213] NET: Registered protocol family 44
  4529    [    1.410233] PCI: CLS 0 bytes, default 64
  4530    [    1.410425] Trying to unpack rootfs image as initramfs...
  4531    [    1.871277] Freeing initrd memory: 10248K
  4532    [    1.872066] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
  4533    [    2.086060] Initialise system trusted keyrings
  4534    [    2.086296] workingset: timestamp_bits=46 max_order=19 bucket_order=0
  4535    [    2.091541] zbud: loaded
  4536    [    2.092796] squashfs: version 4.0 (2009/01/31) Phillip Lougher
  4537    [    2.093082] FS-Cache: Netfs 'nfs' registered for caching
  4538    [    2.093600] NFS: Registering the id_resolver key type
  4539    [    2.093640] Key type id_resolver registered
  4540    [    2.093650] Key type id_legacy registered
  4541    [    2.093666] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
  4542    [    2.093679] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
  4543    [    2.094913] FS-Cache: Netfs 'cifs' registered for caching
  4544    [    2.095244] Key type cifs.spnego registered
  4545    [    2.095265] Key type cifs.idmap registered
  4546    [    2.095288] ntfs: driver 2.1.32 [Flags: R/W].
  4547    [    2.095851] JFS: nTxBlock = 8192, nTxLock = 65536
  4548    [    2.101816] SGI XFS with ACLs, security attributes, realtime, quota, no debug enabled
  4549    [    2.103213] *** VALIDATE xfs ***
  4550    [    2.103499] ocfs2: Registered cluster interface o2cb
  4551    [    2.103716] OCFS2 User DLM kernel interface loaded
  4552    [    2.105103] *** VALIDATE gfs2 ***
  4553    [    2.105373] gfs2: GFS2 installed
  4554    [    2.106270] aufs 5.5-20200203
  4555    [    2.127038] Key type asymmetric registered
  4556    [    2.127065] Asymmetric key parser 'x509' registered
  4557    [    2.127075] Asymmetric key parser 'pkcs8' registered
  4558    [    2.127146] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
  4559    [    2.127335] io scheduler mq-deadline registered
  4560    [    2.127350] io scheduler kyber registered
  4561    [    2.127555] io scheduler bfq registered
  4562    [    2.140235] soc soc0: Amlogic Meson GXL (S905X) Revision 21:b (82:2) Detected
  4563    [    2.143898] Serial: 8250/16550 driver, 5 ports, IRQ sharing enabled
  4564    [    2.145597] Serial: AMBA driver
  4565    [    2.145969] c11084c0.serial: ttyAML6 at MMIO 0xc11084c0 (irq = 10, base_baud = 1500000) is a meson_uart
  4566    [    2.146132] serial serial0: tty port ttyAML6 registered
  4567    [    2.146346] c81004c0.serial: ttyAML0 at MMIO 0xc81004c0 (irq = 13, base_baud = 1500000) is a meson_uart
  4568    [    3.121815] printk: console [ttyAML0] enabled
  4569    [    3.137867] brd: module loaded
  4570    [    3.146325] loop: module loaded
  4571    [    3.148799] libphy: Fixed MDIO Bus: probed
  4572    [    3.149454] meson8b-dwmac c9410000.ethernet: IRQ eth_wake_irq not found
  4573    [    3.154596] meson8b-dwmac c9410000.ethernet: IRQ eth_lpi not found
  4574    [    3.160701] meson8b-dwmac c9410000.ethernet: PTP uses main clock
  4575    [    3.166553] meson8b-dwmac c9410000.ethernet: no reset control found
  4576    [    3.173233] meson8b-dwmac c9410000.ethernet: User ID: 0x11, Synopsys ID: 0x37
  4577    [    3.179850] meson8b-dwmac c9410000.ethernet:     DWMAC1000
  4578    [    3.185006] meson8b-dwmac c9410000.ethernet: DMA HW capability register supported
  4579    [    3.192423] meson8b-dwmac c9410000.ethernet: RX Checksum Offload Engine supported
  4580    [    3.199839] meson8b-dwmac c9410000.ethernet: COE Type 2
  4581    [    3.205013] meson8b-dwmac c9410000.ethernet: TX Checksum insertion supported
  4582    [    3.211999] meson8b-dwmac c9410000.ethernet: Wake-Up On Lan supported
  4583    [    3.218412] meson8b-dwmac c9410000.ethernet: Normal descriptors
  4584    [    3.224247] meson8b-dwmac c9410000.ethernet: Ring mode enabled
  4585    [    3.230027] meson8b-dwmac c9410000.ethernet: Enable RX Mitigation via HW Watchdog Timer
  4586    [    3.238142] libphy: stmmac: probed
  4587    [    3.242704] VFIO - User Level meta-driver version: 0.3
  4588    [    3.247954] dwc3 c9000000.dwc3: Failed to get clk 'ref': -2
  4589    [    3.252807] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
  4590    [    3.258433] ehci-pci: EHCI PCI platform driver
  4591    [    3.262869] ehci-platform: EHCI generic platform driver
  4592    [    3.268172] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
  4593    [    3.274113] ohci-pci: OHCI PCI platform driver
  4594    [    3.278547] ohci-platform: OHCI generic platform driver
  4595    [    3.284299] usbcore: registered new interface driver usb-storage
  4596    [    3.289855] mousedev: PS/2 mouse device common for all mice
  4597    [    3.295807] i2c /dev entries driver
  4598    [    3.301483] sdhci: Secure Digital Host Controller Interface driver
  4599    [    3.304736] sdhci: Copyright(c) Pierre Ossman
  4600    [    3.309049] Synopsys Designware Multimedia Card Interface Driver
  4601    [    3.316343] meson-gx-mmc d0072000.mmc: Got CD GPIO
  4602    [    3.346863] meson-gx-mmc d0074000.mmc: allocated mmc-pwrseq
  4603    [    3.374376] sdhci-pltfm: SDHCI platform and OF driver helper
  4604    [    3.375320] ledtrig-cpu: registered to indicate activity on CPUs
  4605    [    3.380976] meson-sm: secure-monitor enabled
  4606    [    3.385250] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
  4607    [    3.386581] mmc0: new high speed SDHC card at address 59b4
  4608    [    3.392576] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
  4609    [    3.398708] mmcblk0: mmc0:59b4 SDU1  29.5 GiB
  4610    [    3.420838]  mmcblk0: p1 p2
  4611    [    3.422850] hid: raw HID events driver (C) Jiri Kosina
  4612    [    3.423311] usbcore: registered new interface driver usbhid
  4613    [    3.428747] usbhid: USB HID core driver
  4614    [    3.432818] platform-mhu c883c404.mailbox: Platform MHU Mailbox registered
  4615    [    3.449810] NET: Registered protocol family 17
  4616    [    3.450093] Key type dns_resolver registered
  4617    [    3.453483] registered taskstats version 1
  4618    [    3.456943] Loading compiled-in X.509 certificates
  4619    [    3.461866] zswap: loaded using pool lzo/zbud
  4620    [    3.466146] Key type ._fscrypt registered
  4621    [    3.469948] Key type .fscrypt registered
  4622    [    3.475100] Btrfs loaded, crc32c=crc32c-generic
  4623    [    3.496281] mmc1: new HS200 MMC card at address 0001
  4624    [    3.501282] mmcblk1: mmc1:0001 016G92 14.7 GiB
  4625    [    3.501719] mmcblk1boot0: mmc1:0001 016G92 partition 1 4.00 MiB
  4626    [    3.501972] Key type encrypted registered
  4627    [    3.506485] mmcblk1boot1: mmc1:0001 016G92 partition 2 4.00 MiB
  4628    [    3.516412] mmcblk1gp0: mmc1:0001 016G92 partition 4 8.00 MiB
  4629    [    3.521893] mmcblk1rpmb: mmc1:0001 016G92 partition 3 512 KiB, chardev (243:0)
  4630    [    3.529751] meson-drm d0100000.vpu: Queued 3 outputs on vpu
  4631    [    3.534814] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
  4632    [    3.540845] [drm] No driver support for vblank timestamp query.
  4633    [    3.574586] meson-dw-hdmi c883a000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
  4634    [    3.579242] meson-dw-hdmi c883a000.hdmi-tx: registered DesignWare HDMI I2C bus driver
  4635    [    3.587261] meson-drm d0100000.vpu: bound c883a000.hdmi-tx (ops meson_dw_hdmi_ops)
  4636    [    3.594608] [drm] Initialized meson 1.0.0 20161109 for d0100000.vpu on minor 0
  4637    [    3.630094] Console: switching to colour frame buffer device 90x36
  4638    [    3.650314] meson-drm d0100000.vpu: fb0: mesondrmfb frame buffer device
  4639    [    3.657576] libphy: mdio_mux: probed
  4640    [    3.668137] libphy: mdio_mux: probed
  4641    [    3.668622] phy phy-d0078080.phy.2: unsupported PHY mode 5
  4642    [    3.673649] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  4643    [    3.677062] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
  4644    [    3.684768] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228f664 hci version 0x100 quirks 0x0000000002010010
  4645    [    3.693998] xhci-hcd xhci-hcd.0.auto: irq 39, io mem 0xc9000000
  4646    [    3.700098] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.05
  4647    [    3.708441] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  4648    [    3.715591] usb usb1: Product: xHCI Host Controller
  4649    [    3.720419] usb usb1: Manufacturer: Linux 5.5.0-rc6-aml-s9xxx xhci-hcd
  4650    [    3.726887] usb usb1: SerialNumber: xhci-hcd.0.auto
  4651    [    3.732245] hub 1-0:1.0: USB hub found
  4652    [    3.735462] hub 1-0:1.0: 2 ports detected
  4653    [    3.739681] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  4654    [    3.744847] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
  4655    [    3.752437] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
  4656    [    3.758938] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
  4657    [    3.767192] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.05
  4658    [    3.775570] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  4659    [    3.782726] usb usb2: Product: xHCI Host Controller
  4660    [    3.787555] usb usb2: Manufacturer: Linux 5.5.0-rc6-aml-s9xxx xhci-hcd
  4661    [    3.794024] usb usb2: SerialNumber: xhci-hcd.0.auto
  4662    [    3.799320] hub 2-0:1.0: USB hub found
  4663    [    3.802602] hub 2-0:1.0: config failed, hub doesn't have any ports! (err -19)
  4664    [    3.811539] meson-gx-mmc d0070000.mmc: allocated mmc-pwrseq
  4665    [    3.842657] scpi_protocol scpi: SCP Protocol legacy pre-1.0 firmware
  4666    [    3.860111] gx-sound-card sound: snd-soc-dummy-dai <-> c1105400.bus:audio-controller-0 mapping ok
  4667    [    3.869332] gx-sound-card sound: i2s-hifi <-> c1105400.bus:audio-controller-2 mapping ok
  4668    [    3.877017] gx-sound-card sound: ASoC: no DMI vendor name!
  4669    [    3.883196] printk: console [netcon0] enabled
  4670    [    3.886653] netconsole: network logging started
  4671    [    3.891215] hctosys: unable to open rtc device (rtc0)
  4672    [    3.896449] ALSA device list:
  4673    [    3.899588]   #0: AMLGX
  4674    [    3.903113] Freeing unused kernel memory: 960K
  4675    [    3.906194] Run /init as init process
  4676    [    3.906862] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
  4677    [    3.918736] mmc2: queuing unknown CIS tuple 0x80 (6 bytes)
  4678    [    3.925288] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
  4679    [    3.937311] mmc2: queuing unknown CIS tuple 0x80 (19 bytes)
  4680    [    3.964376] random: fast init done
  4681    [    4.022156] mmc2: new high speed SDIO card at address 0001
  4682    [    4.078608] usb 1-1: new high-speed USB device number 2 using xhci-hcd
  4683    [    4.100400] usb 1-1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.36
  4684    [    4.107205] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
  4685    [    4.114252] usb 1-1: Product: USB2.0 Hub
  4686    [    4.175438] hub 1-1:1.0: USB hub found
  4687    [    4.177914] hub 1-1:1.0: 4 ports detected
  4688    [    4.310606] usb 1-2: new high-speed USB device number 3 using xhci-hcd
  4689    [    4.341180] usb 1-2: New USB device found, idVendor=148f, idProduct=7601, bcdDevice= 0.00
  4690    [    4.348015] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
  4691    [    4.355977] usb 1-2: Product: 802.11 n WLAN
  4692    [    4.359219] usb 1-2: Manufacturer: MediaTek
  4693    [    4.363298] usb 1-2: SerialNumber: 1.0
  4694    [    5.040612] EXT4-fs (mmcblk0p2): mounted filesystem with writeback data mode. Opts: data=writeback
  4695    [    5.995866] systemd[1]: System time before build time, advancing clock.
  4696    [    6.149780] NET: Registered protocol family 10
  4697    [    6.221058] Segment Routing with IPv6
  4698    [    6.272439] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
  4699    [    6.308765] systemd[1]: Detected architecture arm64.
  4700    [    6.360408] systemd[1]: Set hostname to <mxqpro>.
  4701    [    6.392837] systemd[1]: Couldn't move remaining userspace processes, ignoring: Input/output error
  4702    [    7.078770] random: systemd: uninitialized urandom read (16 bytes read)
  4703    [    7.091350] random: systemd: uninitialized urandom read (16 bytes read)
  4704    [    7.099361] systemd[1]: Created slice system-systemd\x2dfsck.slice.
  4705    [    7.105688] random: systemd: uninitialized urandom read (16 bytes read)
  4706    [    7.109844] systemd[1]: Listening on Journal Socket.
  4707    [    7.121041] systemd[1]: Mounting Kernel Debug File System...
  4708    [    7.128262] systemd[1]: Created slice system-serial\x2dgetty.slice.
  4709    [    7.138153] systemd[1]: Starting Nameserver information manager...
  4710    [    7.144520] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
  4711    [    7.325631] EXT4-fs (mmcblk0p2): re-mounted. Opts: commit=600,errors=remount-ro
  4712    [    7.596933] systemd-journald[414]: Received request to flush runtime journal from PID 1
  4713    [    8.082747] mc: Linux media interface: v0.10
  4714    [    8.109912] videodev: Linux video capture interface: v2.00
  4715    [    8.134829] Registered IR keymap rc-empty
  4716    [    8.136908] rc rc0: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0
  4717    [    8.143380] input: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0/input0
  4718    [    8.150768] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
  4719    [    8.166190] meson-ir c8100580.ir: receiver initialized
  4720    [    8.231729] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
  4721    [    8.246786] lima d00c0000.gpu: IRQ ppmmu3 not found
  4722    [    8.249267] lima d00c0000.gpu: IRQ ppmmu4 not found
  4723    [    8.262760] lima d00c0000.gpu: IRQ ppmmu5 not found
  4724    [    8.265124] lima d00c0000.gpu: IRQ ppmmu6 not found
  4725    [    8.276242] lima d00c0000.gpu: IRQ ppmmu7 not found
  4726    [    8.281140] lima d00c0000.gpu: gp - mali450 version major 0 minor 0
  4727    [    8.289232] lima d00c0000.gpu: pp0 - mali450 version major 0 minor 0
  4728    [    8.292584] lima d00c0000.gpu: pp1 - mali450 version major 0 minor 0
  4729    [    8.301737] lima d00c0000.gpu: pp2 - mali450 version major 0 minor 0
  4730    [    8.306700] lima d00c0000.gpu: IRQ pp3 not found
  4731    [    8.309479] lima d00c0000.gpu: IRQ pp4 not found
  4732    [    8.317008] lima d00c0000.gpu: IRQ pp5 not found
  4733    [    8.320573] lima d00c0000.gpu: IRQ pp6 not found
  4734    [    8.324550] lima d00c0000.gpu: IRQ pp7 not found
  4735    [    8.329196] lima d00c0000.gpu: l2 cache 8K, 4-way, 64byte cache line, 128bit external bus
  4736    [    8.337366] lima d00c0000.gpu: l2 cache 64K, 4-way, 64byte cache line, 128bit external bus
  4737    [    8.347139] lima d00c0000.gpu: bus rate = 166666667
  4738    [    8.349365] lima d00c0000.gpu: mod rate = 744000000
  4739    [    8.356470] [drm] Initialized lima 1.0.0 20190217 for d00c0000.gpu on minor 1
  4740    [    8.447229] Bluetooth: Core ver 2.22
  4741    [    8.449868] NET: Registered protocol family 31
  4742    [    8.451911] Bluetooth: HCI device and connection manager initialized
  4743    [    8.458128] Bluetooth: HCI socket layer initialized
  4744    [    8.462854] Bluetooth: L2CAP socket layer initialized
  4745    [    8.467896] Bluetooth: SCO socket layer initialized
  4746    [    8.520770] cfg80211: Loading compiled-in X.509 certificates for regulatory database
  4747    [    8.556595] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
  4748    [    8.561226] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
  4749    [    8.568938] cfg80211: failed to load regulatory.db
  4750    [    8.694760] Bluetooth: HCI UART driver ver 2.3
  4751    [    8.697128] Bluetooth: HCI UART protocol H4 registered
  4752    [    8.700667] brcmfmac: F1 signature read @0x18000000=0x16034334
  4753    [    8.706070] Bluetooth: HCI UART protocol BCSP registered
  4754    [    8.708106] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4334-sdio for chip BCM4334/3
  4755    [    8.708403] Bluetooth: HCI UART protocol LL registered
  4756    [    8.716487] usbcore: registered new interface driver brcmfmac
  4757    [    8.721404] Bluetooth: HCI UART protocol ATH3K registered
  4758    [    8.736563] Bluetooth: HCI UART protocol Three-wire (H5) registered
  4759    [    8.739900] Bluetooth: HCI UART protocol Intel registered
  4760    [    8.745480] hci_uart_bcm serial0-0: serial0-0 supply vbat not found, using dummy regulator
  4761    [    8.753237] hci_uart_bcm serial0-0: serial0-0 supply vddio not found, using dummy regulator
  4762    [    8.761540] Bluetooth: HCI UART protocol Broadcom registered
  4763    [    8.767107] Bluetooth: HCI UART protocol QCA registered
  4764    [    8.772212] Bluetooth: HCI UART protocol AG6XX registered
  4765    [    8.777638] Bluetooth: HCI UART protocol Marvell registered
  4766    [    8.827167] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.amlogic,p212.txt failed with error -2
  4767    [    8.827232] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.txt failed with error -2
  4768    [    8.862911] usb 1-2: reset high-speed USB device number 3 using xhci-hcd
  4769    [    8.893347] mt7601u 1-2:1.0: ASIC revision: 76010001 MAC revision: 76010500
  4770    [    8.919367] mt7601u 1-2:1.0: EEPROM ver:0d fae:00
  4771    [    9.130069] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
  4772    [    9.132833] usbcore: registered new interface driver mt7601u
  4773    [    9.147542] Bluetooth: hci0: BCM: chip id 68
  4774    [    9.150833] Bluetooth: hci0: BCM: features 0x0f
  4775    [    9.158784] Bluetooth: hci0: BCM4334B0
  4776    [    9.163806] Bluetooth: hci0: BCM4334B0 (002.001.013) build 0000
  4777    [    9.167835] bluetooth hci0: Direct firmware load for brcm/BCM4334B0.hcd failed with error -2
  4778    [    9.177450] Bluetooth: hci0: BCM: Patch brcm/BCM4334B0.hcd not found
  4779    [    9.830624] brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x50
  4780    [    9.886451] zram: Added device: zram0
  4781    [    9.891176] zram: Added device: zram1
  4782    [    9.894404] zram: Added device: zram2
  4783    [    9.925547] meson8b-dwmac c9410000.ethernet eth0: PHY [0.e40908ff:08] driver [Meson GXL Internal PHY]
  4784    [    9.945386] zram1: detected capacity change from 0 to 912879616
  4785    [    9.950673] meson8b-dwmac c9410000.ethernet eth0: No Safety Features support found
  4786    [    9.957268] meson8b-dwmac c9410000.ethernet eth0: PTP not supported by HW
  4787    [    9.962462] meson8b-dwmac c9410000.ethernet eth0: configuring for phy/rmii link mode
  4788    [   10.586495] random: crng init done
  4789    [   10.588901] random: 7 urandom warning(s) missed due to ratelimiting
  4790    [   10.790775] Adding 891480k swap on /dev/zram1.  Priority:5 extents:1 across:891480k SSFS
  4791
  4792    ### armbian-release:
  4793
  4794    # PLEASE DO NOT EDIT THIS FILE
  4795    BOARD=aml-s9xxx
  4796    BOARD_NAME="AML-S9xxx"
  4797    BOARDFAMILY=aml-s9xxx
  4798    BUILD_REPOSITORY_URL=https://github.com/150balbes/Build-Armbian.git
  4799    BUILD_REPOSITORY_COMMIT=62b8c07-dirty
  4800    DISTRIBUTION_CODENAME=buster
  4801    DISTRIBUTION_STATUS=supported
  4802    VERSION=20.02.0-rc1.037
  4803    LINUXFAMILY=aml-s9xxx
  4804    BRANCH=current
  4805    ARCH=arm64
  4806    IMAGE_TYPE=nightly
  4807    BOARD_TYPE=conf
  4808    INITRD_ARCH=arm64
  4809    KERNEL_IMAGE_TYPE=Image
  4810
  4811    ### boot environment:
  4812
  4813    ODROIDN2-UBOOT-CONFIG
  4814    setenv env_addr 0x10400000
  4815    setenv kernel_addr 0x11000000
  4816    setenv initrd_addr 0x13000000
  4817    setenv dtb_addr 0x1000000
  4818    if test "${devtype}" = ""; then setenv devtype "mmc"; fi
  4819    load ${devtype} ${devnum} ${env_addr} uEnv.txt && env import -t ${env_addr} ${filesize}
  4820    setenv bootargs ${APPEND}
  4821    load ${devtype} ${devnum} ${kernel_addr} ${LINUX}
  4822    load ${devtype} ${devnum} ${initrd_addr} ${INITRD}
  4823    load ${devtype} ${devnum} ${dtb_addr} ${FDT}
  4824    fdt addr ${dtb_addr}
  4825    booti ${kernel_addr} ${initrd_addr} ${dtb_addr}
  4826
  4827    ### lsusb:
  4828
  4829    Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
  4830    Bus 001 Device 003: ID 148f:7601 Ralink Technology, Corp. MT7601U Wireless Adapter
  4831    Bus 001 Device 002: ID 05e3:0608 Genesys Logic, Inc. Hub
  4832    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  4833
  4834    ### lscpu:
  4835
  4836    Architecture:        aarch64
  4837    Byte Order:          Little Endian
  4838    CPU(s):              4
  4839    On-line CPU(s) list: 0-3
  4840    Thread(s) per core:  1
  4841    Core(s) per socket:  4
  4842    Socket(s):           1
  4843    Vendor ID:           ARM
  4844    Model:               4
  4845    Model name:          Cortex-A53
  4846    Stepping:            r0p4
  4847    CPU max MHz:         1512,0000
  4848    CPU min MHz:         100,0000
  4849    BogoMIPS:            48.00
  4850    L1d cache:           unknown size
  4851    L1i cache:           unknown size
  4852    L2 cache:            unknown size
  4853    Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  4854
  4855    ### cpuinfo:
  4856
  4857    processor    : 0
  4858    model name    : ARMv8 Processor rev 4 (v8l)
  4859    BogoMIPS    : 48.00
  4860    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  4861    CPU implementer    : 0x41
  4862    CPU architecture: 8
  4863    CPU variant    : 0x0
  4864    CPU part    : 0xd03
  4865    CPU revision    : 4
  4866
  4867    processor    : 1
  4868    model name    : ARMv8 Processor rev 4 (v8l)
  4869    BogoMIPS    : 48.00
  4870    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  4871    CPU implementer    : 0x41
  4872    CPU architecture: 8
  4873    CPU variant    : 0x0
  4874    CPU part    : 0xd03
  4875    CPU revision    : 4
  4876
  4877    processor    : 2
  4878    model name    : ARMv8 Processor rev 4 (v8l)
  4879    BogoMIPS    : 48.00
  4880    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  4881    CPU implementer    : 0x41
  4882    CPU architecture: 8
  4883    CPU variant    : 0x0
  4884    CPU part    : 0xd03
  4885    CPU revision    : 4
  4886
  4887    processor    : 3
  4888    model name    : ARMv8 Processor rev 4 (v8l)
  4889    BogoMIPS    : 48.00
  4890    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  4891    CPU implementer    : 0x41
  4892    CPU architecture: 8
  4893    CPU variant    : 0x0
  4894    CPU part    : 0xd03
  4895    CPU revision    : 4
  4896
  4897
  4898    ### meminfo:
  4899
  4900    MemTotal:        1782968 kB
  4901    MemFree:         1606640 kB
  4902    MemAvailable:    1665088 kB
  4903    Buffers:           11628 kB
  4904    Cached:            54492 kB
  4905    SwapCached:            0 kB
  4906    Active:            52744 kB
  4907    Inactive:          35564 kB
  4908    Active(anon):      22256 kB
  4909    Inactive(anon):     2596 kB
  4910    Active(file):      30488 kB
  4911    Inactive(file):    32968 kB
  4912    Unevictable:           0 kB
  4913    Mlocked:               0 kB
  4914    SwapTotal:        891480 kB
  4915    SwapFree:         891480 kB
  4916    Dirty:               428 kB
  4917    Writeback:             0 kB
  4918    AnonPages:         21932 kB
  4919    Mapped:            22784 kB
  4920    Shmem:              2696 kB
  4921    KReclaimable:      18108 kB
  4922    Slab:              53388 kB
  4923    SReclaimable:      18108 kB
  4924    SUnreclaim:        35280 kB
  4925    KernelStack:        2752 kB
  4926    PageTables:         1432 kB
  4927    NFS_Unstable:          0 kB
  4928    Bounce:                0 kB
  4929    WritebackTmp:          0 kB
  4930    CommitLimit:     1782964 kB
  4931    Committed_AS:      77968 kB
  4932    VmallocTotal:   135290159040 kB
  4933    VmallocUsed:       16740 kB
  4934    VmallocChunk:          0 kB
  4935    Percpu:             1264 kB
  4936    CmaTotal:         262144 kB
  4937    CmaFree:          258460 kB
  4938    HugePages_Total:       0
  4939    HugePages_Free:        0
  4940    HugePages_Rsvd:        0
  4941    HugePages_Surp:        0
  4942    Hugepagesize:       2048 kB
  4943    Hugetlb:               0 kB
  4944
  4945    ### virtual memory:
  4946
  4947    vm.admin_reserve_kbytes = 8192
  4948    vm.block_dump = 0
  4949    vm.compact_unevictable_allowed = 1
  4950    vm.dirty_background_bytes = 0
  4951    vm.dirty_background_ratio = 10
  4952    vm.dirty_bytes = 0
  4953    vm.dirty_expire_centisecs = 3000
  4954    vm.dirty_ratio = 20
  4955    vm.dirtytime_expire_seconds = 43200
  4956    vm.dirty_writeback_centisecs = 500
  4957    vm.extfrag_threshold = 500
  4958    vm.hugetlb_shm_group = 0
  4959    vm.laptop_mode = 0
  4960    vm.legacy_va_layout = 0
  4961    vm.lowmem_reserve_ratio = 256    256    32    0
  4962    vm.max_map_count = 65530
  4963    vm.min_free_kbytes = 4914
  4964    vm.mmap_min_addr = 4096
  4965    vm.mmap_rnd_bits = 18
  4966    vm.nr_hugepages = 0
  4967    vm.nr_overcommit_hugepages = 0
  4968    vm.oom_dump_tasks = 1
  4969    vm.oom_kill_allocating_task = 0
  4970    vm.overcommit_kbytes = 0
  4971    vm.overcommit_memory = 0
  4972    vm.overcommit_ratio = 50
  4973    vm.page-cluster = 0
  4974    vm.panic_on_oom = 0
  4975    vm.percpu_pagelist_fraction = 0
  4976    vm.stat_interval = 1
  4977    vm.swappiness = 100
  4978    vm.user_reserve_kbytes = 55239
  4979    vm.vfs_cache_pressure = 100
  4980    vm.watermark_boost_factor = 15000
  4981    vm.watermark_scale_factor = 10
  4982
  4983    ### ip addr:
  4984
  4985    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
  4986        link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  4987        inet XXX.XXX.0.1/8 scope host lo
  4988           valid_lft forever preferred_lft forever
  4989        inet6 ::1/128 scope host
  4990           valid_lft forever preferred_lft forever
  4991    2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
  4992        link/ether 00:df:06:00:00:0b brd ff:ff:ff:ff:ff:ff
  4993    3: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  4994        link/ether 00:36:76:61:0b:24 brd ff:ff:ff:ff:ff:ff
  4995
  4996    ### partitions:
  4997
  4998    major minor  #blocks  name
  4999
  5000     179        0   30924800 mmcblk0
  5001     179        1     262144 mmcblk0p1
  5002     179        2   30337024 mmcblk0p2
  5003     179       32   15384576 mmcblk1
  5004     179      128       8192 mmcblk1gp0
  5005     254        1     891484 zram1
  5006
  5007    ### df:
  5008
  5009    udev             738M      0  738M   0% /dev
  5010    tmpfs            175M   2,7M  172M   2% /run
  5011    /dev/mmcblk0p2    29G    10G   19G  36% /
  5012    tmpfs            871M      0  871M   0% /dev/shm
  5013    tmpfs            5,0M   4,0K  5,0M   1% /run/lock
  5014    tmpfs            871M      0  871M   0% /sys/fs/cgroup
  5015    tmpfs            871M      0  871M   0% /tmp
  5016    /dev/mmcblk0p1   256M    76M  180M  30% /boot
  5017
  5018    ### lsblk:
  5019
  5020    NAME         FSTYPE   SIZE MOUNTPOINT UUID
  5021    mmcblk0              29,5G
  5022    ├─mmcblk0p1  vfat     256M /boot      50FC-6AC8
  5023    └─mmcblk0p2  ext4      29G /          3e297ac1-e4e4-4ab1-bc57-47c07d0422ba
  5024    mmcblk1              14,7G
  5025    mmcblk1boot0            4M
  5026    mmcblk1boot1            4M
  5027    mmcblk1gp0              8M
  5028
  5029    ### zramctl:
  5030
  5031    NAME       ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT
  5032    /dev/zram1 lzo         870,6M   4K   81B   12K       4 [SWAP]
  5033
  5034    ### mtab:
  5035
  5036    /dev/mmcblk0p1 /boot vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro 0 0
  5037    /dev/mmcblk0p2 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  5038
  5039    ### mmc0:59b4 info:
  5040
  5041                   fwrev: 0x0
  5042                  uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SDU1  MODALIAS=mmc:block
  5043                     cid: 1b534d53445531201014a136d4013800
  5044                     rca: 0x59b4
  5045                     csd: 400e00325b590000ebef7f800a400000
  5046                  manfid: 0x00001b
  5047                     ocr: 0x00200000
  5048    preferred_erase_size: 4194304
  5049                    type: SD
  5050                   hwrev: 0x1
  5051                    date: 08/2019
  5052                     dsr: 0x404
  5053              erase_size: 512
  5054                   oemid: 0x534d
  5055                  serial: 0x14a136d4
  5056                     ssr: 0000000005000000040090000811391e00089a342f01000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  5057                     scr: 0235844300000000
  5058                    name: SDU1
  5059
  5060    ### mmc1:0001 info:
  5061
  5062                   fwrev: 0x0
  5063                  uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=016G92 MODALIAS=mmc:block
  5064                     cid: 11010030313647393201d3d1a4db1100
  5065             rel_sectors: 0x10
  5066                     rca: 0x0001
  5067            pre_eol_info: 0x00
  5068                     csd: d00e00320f5903ffffffffef92400000
  5069                  manfid: 0x000011
  5070                     ocr: 0x00200000
  5071    preferred_erase_size: 4194304
  5072    enhanced_area_offset: 18446744073709551594
  5073      raw_rpmb_size_mult: 0x4
  5074                    type: MMC
  5075                   hwrev: 0x0
  5076                    date: 01/2014
  5077                     prv: 0x1
  5078             ffu_capable: 0
  5079                     dsr: 0x404
  5080              erase_size: 4194304
  5081               life_time: 0x00 0x00
  5082      enhanced_area_size: 4294967274
  5083                   oemid: 0x0100
  5084                  serial: 0xd3d1a4db
  5085                 cmdq_en: 0
  5086                     rev: 0x6
  5087                    name: 016G92
  5088
  5089    ### Boot system health:
  5090
  5091    Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU
  5092    08:29:12: 1512MHz  0.15  51%  24%  14%   0%  10%   1% 60.0°C
  5093    08:29:12: 1512MHz  0.15  71%   8%  18%   1%  40%   1% 60.0°C
  5094    08:29:12: 1512MHz  0.15  68%   9%  12%   0%  44%   1% 59.0°C
  5095    08:29:13: 1512MHz  0.15  52%  10%  15%   1%  23%   2% 59.0°C
  5096    08:29:13: 1512MHz  0.15  25%   3%   4%   1%  14%   0% 58.0°C
  5097
  5098    ### Activated 1 lzo zram swap devices with 870 MB each
  5099
  5100
  5101    jue mar 25 13:14:09 CET 2021 | AML-S9xxx | 20.02.0-rc1.037 | arm64 | aarch64 | 5.5.0-rc6-aml-s9xxx
  5102
  5103    ### dmesg:
  5104
  5105    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
  5106    [    0.000000] Linux version 5.5.0-rc6-aml-s9xxx (root@vbox) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #rc1.037 SMP PREEMPT Wed Feb 5 15:59:04 MSK 2020
  5107    [    0.000000] Machine model: Amlogic Meson GXL (S905X) P212 Development Board
  5108    [    0.000000] efi: Getting EFI parameters from FDT:
  5109    [    0.000000] efi: UEFI not found.
  5110    [    0.000000] Reserved memory: created CMA memory pool at 0x0000000076000000, size 32 MiB
  5111    [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
  5112    [    0.000000] On node 0 totalpages: 477952
  5113    [    0.000000]   DMA zone: 4032 pages used for memmap
  5114    [    0.000000]   DMA zone: 0 pages reserved
  5115    [    0.000000]   DMA zone: 248576 pages, LIFO batch:63
  5116    [    0.000000]   DMA32 zone: 3584 pages used for memmap
  5117    [    0.000000]   DMA32 zone: 229376 pages, LIFO batch:63
  5118    [    0.000000] psci: probing for conduit method from DT.
  5119    [    0.000000] psci: PSCIv0.2 detected in firmware.
  5120    [    0.000000] psci: Using standard PSCI v0.2 function IDs
  5121    [    0.000000] psci: Trusted OS migration not required
  5122    [    0.000000] percpu: Embedded 22 pages/cpu s50392 r8192 d31528 u90112
  5123    [    0.000000] pcpu-alloc: s50392 r8192 d31528 u90112 alloc=22*4096
  5124    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
  5125    [    0.000000] Detected VIPT I-cache on CPU0
  5126    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 470336
  5127    [    0.000000] Kernel command line: root=LABEL=ROOTFS rootflags=data=writeback rw console=ttyAML0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 mac=00:df:06:00:00:0b
  5128    [    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
  5129    [    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
  5130    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
  5131    [    0.000000] software IO TLB: mapped [mem 0x3bfff000-0x3ffff000] (64MB)
  5132    [    0.000000] Memory: 1738992K/1911808K available (14460K kernel code, 1434K rwdata, 5884K rodata, 960K init, 927K bss, 140048K reserved, 32768K cma-reserved)
  5133    [    0.000000] random: get_random_u64 called from cache_random_seq_create+0x7c/0x150 with crng_init=0
  5134    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
  5135    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
  5136    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
  5137    [    0.000000]     Tasks RCU enabled.
  5138    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
  5139    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
  5140    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
  5141    [    0.000000] GIC: Using split EOI/Deactivate mode
  5142    [    0.000000] irq_meson_gpio: 110 to 8 gpio interrupt mux initialized
  5143    [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
  5144    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
  5145    [    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
  5146    [    0.000355] Console: colour dummy device 80x25
  5147    [    0.000656] printk: console [tty0] enabled
  5148    [    0.000698] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
  5149    [    0.000718] pid_max: default: 32768 minimum: 301
  5150    [    0.000847] LSM: Security Framework initializing
  5151    [    0.000898] SELinux:  Initializing.
  5152    [    0.000975] *** VALIDATE SELinux ***
  5153    [    0.001039] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
  5154    [    0.001066] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
  5155    [    0.001129] *** VALIDATE tmpfs ***
  5156    [    0.001540] *** VALIDATE proc ***
  5157    [    0.001761] *** VALIDATE cgroup1 ***
  5158    [    0.001776] *** VALIDATE cgroup2 ***
  5159    [    0.024016] ASID allocator initialised with 32768 entries
  5160    [    0.032000] rcu: Hierarchical SRCU implementation.
  5161    [    0.042094] EFI services will not be available.
  5162    [    0.048058] smp: Bringing up secondary CPUs ...
  5163    [    0.080286] Detected VIPT I-cache on CPU1
  5164    [    0.080340] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
  5165    [    0.112322] Detected VIPT I-cache on CPU2
  5166    [    0.112368] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
  5167    [    0.144373] Detected VIPT I-cache on CPU3
  5168    [    0.144418] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
  5169    [    0.144496] smp: Brought up 1 node, 4 CPUs
  5170    [    0.144561] SMP: Total of 4 processors activated.
  5171    [    0.144572] CPU features: detected: 32-bit EL0 Support
  5172    [    0.144584] CPU features: detected: CRC32 instructions
  5173    [    0.144888] CPU: All CPU(s) started at EL2
  5174    [    0.144910] alternatives: patching kernel code
  5175    [    0.146013] devtmpfs: initialized
  5176    [    0.151162] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
  5177    [    0.151203] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
  5178    [    0.152372] xor: measuring software checksum speed
  5179    [    0.192317]    8regs     :  2375.000 MB/sec
  5180    [    0.232347]    32regs    :  2724.000 MB/sec
  5181    [    0.272388]    arm64_neon:  2406.000 MB/sec
  5182    [    0.272399] xor: using function: 32regs (2724.000 MB/sec)
  5183    [    0.272453] pinctrl core: initialized pinctrl subsystem
  5184    [    0.273089] thermal_sys: Registered thermal governor 'step_wise'
  5185    [    0.273251] DMI not present or invalid.
  5186    [    0.273606] NET: Registered protocol family 16
  5187    [    0.277268] DMA: preallocated 256 KiB pool for atomic allocations
  5188    [    0.277317] audit: initializing netlink subsys (disabled)
  5189    [    0.277544] audit: type=2000 audit(0.276:1): state=initialized audit_enabled=0 res=1
  5190    [    0.278623] cpuidle: using governor ladder
  5191    [    0.278655] cpuidle: using governor menu
  5192    [    0.278982] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
  5193    [    0.279706] Serial: AMBA PL011 UART driver
  5194    [    0.293714] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
  5195    [    0.293741] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
  5196    [    0.293754] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
  5197    [    0.293767] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
  5198    [    0.297435] cryptd: max_cpu_qlen set to 1000
  5199    [    0.372652] raid6: neonx8   gen()  1621 MB/s
  5200    [    0.440686] raid6: neonx8   xor()  1491 MB/s
  5201    [    0.508757] raid6: neonx4   gen()  1564 MB/s
  5202    [    0.576773] raid6: neonx4   xor()  1470 MB/s
  5203    [    0.644832] raid6: neonx2   gen()  1199 MB/s
  5204    [    0.712890] raid6: neonx2   xor()  1216 MB/s
  5205    [    0.780931] raid6: neonx1   gen()   786 MB/s
  5206    [    0.849035] raid6: neonx1   xor()   915 MB/s
  5207    [    0.917050] raid6: int64x8  gen()  1194 MB/s
  5208    [    0.985108] raid6: int64x8  xor()   769 MB/s
  5209    [    1.053172] raid6: int64x4  gen()  1029 MB/s
  5210    [    1.121227] raid6: int64x4  xor()   752 MB/s
  5211    [    1.189254] raid6: int64x2  gen()   728 MB/s
  5212    [    1.257302] raid6: int64x2  xor()   613 MB/s
  5213    [    1.325388] raid6: int64x1  gen()   486 MB/s
  5214    [    1.393431] raid6: int64x1  xor()   467 MB/s
  5215    [    1.393442] raid6: using algorithm neonx8 gen() 1621 MB/s
  5216    [    1.393452] raid6: .... xor() 1491 MB/s, rmw enabled
  5217    [    1.393462] raid6: using neon recovery algorithm
  5218    [    1.393745] ACPI: Interpreter disabled.
  5219    [    1.394922] iommu: Default domain type: Translated
  5220    [    1.395191] vgaarb: loaded
  5221    [    1.395771] SCSI subsystem initialized
  5222    [    1.395952] libata version 3.00 loaded.
  5223    [    1.396163] usbcore: registered new interface driver usbfs
  5224    [    1.396210] usbcore: registered new interface driver hub
  5225    [    1.396271] usbcore: registered new device driver usb
  5226    [    1.396665] pps_core: LinuxPPS API ver. 1 registered
  5227    [    1.396678] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
  5228    [    1.396701] PTP clock support registered
  5229    [    1.396729] EDAC MC: Ver: 3.0.0
  5230    [    1.397269] FPGA manager framework
  5231    [    1.397397] Advanced Linux Sound Architecture Driver Initialized.
  5232    [    1.397857] NetLabel: Initializing
  5233    [    1.397870] NetLabel:  domain hash size = 128
  5234    [    1.397880] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
  5235    [    1.397940] NetLabel:  unlabeled traffic allowed by default
  5236    [    1.398444] clocksource: Switched to clocksource arch_sys_counter
  5237    [    1.398470] *** VALIDATE bpf ***
  5238    [    1.398726] VFS: Disk quotas dquot_6.6.0
  5239    [    1.398788] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
  5240    [    1.398909] FS-Cache: Loaded
  5241    [    1.398919] *** VALIDATE ramfs ***
  5242    [    1.398940] *** VALIDATE hugetlbfs ***
  5243    [    1.399309] pnp: PnP ACPI: disabled
  5244    [    1.404399] NET: Registered protocol family 2
  5245    [    1.404891] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
  5246    [    1.404941] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
  5247    [    1.405060] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
  5248    [    1.405273] TCP: Hash tables configured (established 16384 bind 16384)
  5249    [    1.405429] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
  5250    [    1.405481] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
  5251    [    1.405693] NET: Registered protocol family 1
  5252    [    1.406167] RPC: Registered named UNIX socket transport module.
  5253    [    1.406191] RPC: Registered udp transport module.
  5254    [    1.406201] RPC: Registered tcp transport module.
  5255    [    1.406210] RPC: Registered tcp NFSv4.1 backchannel transport module.
  5256    [    1.406226] NET: Registered protocol family 44
  5257    [    1.406247] PCI: CLS 0 bytes, default 64
  5258    [    1.406512] Trying to unpack rootfs image as initramfs...
  5259    [    1.867660] Freeing initrd memory: 10248K
  5260    [    1.868457] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
  5261    [    2.081826] Initialise system trusted keyrings
  5262    [    2.082041] workingset: timestamp_bits=46 max_order=19 bucket_order=0
  5263    [    2.087265] zbud: loaded
  5264    [    2.088499] squashfs: version 4.0 (2009/01/31) Phillip Lougher
  5265    [    2.088776] FS-Cache: Netfs 'nfs' registered for caching
  5266    [    2.089309] NFS: Registering the id_resolver key type
  5267    [    2.089348] Key type id_resolver registered
  5268    [    2.089358] Key type id_legacy registered
  5269    [    2.089375] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
  5270    [    2.089388] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
  5271    [    2.090632] FS-Cache: Netfs 'cifs' registered for caching
  5272    [    2.090984] Key type cifs.spnego registered
  5273    [    2.091006] Key type cifs.idmap registered
  5274    [    2.091031] ntfs: driver 2.1.32 [Flags: R/W].
  5275    [    2.091626] JFS: nTxBlock = 8192, nTxLock = 65536
  5276    [    2.097468] SGI XFS with ACLs, security attributes, realtime, quota, no debug enabled
  5277    [    2.098907] *** VALIDATE xfs ***
  5278    [    2.099219] ocfs2: Registered cluster interface o2cb
  5279    [    2.099432] OCFS2 User DLM kernel interface loaded
  5280    [    2.100780] *** VALIDATE gfs2 ***
  5281    [    2.101044] gfs2: GFS2 installed
  5282    [    2.101952] aufs 5.5-20200203
  5283    [    2.122493] Key type asymmetric registered
  5284    [    2.122519] Asymmetric key parser 'x509' registered
  5285    [    2.122530] Asymmetric key parser 'pkcs8' registered
  5286    [    2.122600] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
  5287    [    2.122789] io scheduler mq-deadline registered
  5288    [    2.122803] io scheduler kyber registered
  5289    [    2.123002] io scheduler bfq registered
  5290    [    2.135623] soc soc0: Amlogic Meson GXL (S905X) Revision 21:b (82:2) Detected
  5291    [    2.139232] Serial: 8250/16550 driver, 5 ports, IRQ sharing enabled
  5292    [    2.140940] Serial: AMBA driver
  5293    [    2.141302] c11084c0.serial: ttyAML6 at MMIO 0xc11084c0 (irq = 10, base_baud = 1500000) is a meson_uart
  5294    [    2.141459] serial serial0: tty port ttyAML6 registered
  5295    [    2.141665] c81004c0.serial: ttyAML0 at MMIO 0xc81004c0 (irq = 13, base_baud = 1500000) is a meson_uart
  5296    [    3.116963] printk: console [ttyAML0] enabled
  5297    [    3.133135] brd: module loaded
  5298    [    3.141592] loop: module loaded
  5299    [    3.144065] libphy: Fixed MDIO Bus: probed
  5300    [    3.144711] meson8b-dwmac c9410000.ethernet: IRQ eth_wake_irq not found
  5301    [    3.149763] meson8b-dwmac c9410000.ethernet: IRQ eth_lpi not found
  5302    [    3.155968] meson8b-dwmac c9410000.ethernet: PTP uses main clock
  5303    [    3.161823] meson8b-dwmac c9410000.ethernet: no reset control found
  5304    [    3.168506] meson8b-dwmac c9410000.ethernet: User ID: 0x11, Synopsys ID: 0x37
  5305    [    3.175126] meson8b-dwmac c9410000.ethernet:     DWMAC1000
  5306    [    3.180291] meson8b-dwmac c9410000.ethernet: DMA HW capability register supported
  5307    [    3.187691] meson8b-dwmac c9410000.ethernet: RX Checksum Offload Engine supported
  5308    [    3.195109] meson8b-dwmac c9410000.ethernet: COE Type 2
  5309    [    3.200281] meson8b-dwmac c9410000.ethernet: TX Checksum insertion supported
  5310    [    3.207268] meson8b-dwmac c9410000.ethernet: Wake-Up On Lan supported
  5311    [    3.213690] meson8b-dwmac c9410000.ethernet: Normal descriptors
  5312    [    3.219518] meson8b-dwmac c9410000.ethernet: Ring mode enabled
  5313    [    3.225294] meson8b-dwmac c9410000.ethernet: Enable RX Mitigation via HW Watchdog Timer
  5314    [    3.233411] libphy: stmmac: probed
  5315    [    3.237901] VFIO - User Level meta-driver version: 0.3
  5316    [    3.243237] dwc3 c9000000.dwc3: Failed to get clk 'ref': -2
  5317    [    3.248117] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
  5318    [    3.253700] ehci-pci: EHCI PCI platform driver
  5319    [    3.258139] ehci-platform: EHCI generic platform driver
  5320    [    3.263428] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
  5321    [    3.269385] ohci-pci: OHCI PCI platform driver
  5322    [    3.273812] ohci-platform: OHCI generic platform driver
  5323    [    3.279572] usbcore: registered new interface driver usb-storage
  5324    [    3.285150] mousedev: PS/2 mouse device common for all mice
  5325    [    3.291102] i2c /dev entries driver
  5326    [    3.296705] sdhci: Secure Digital Host Controller Interface driver
  5327    [    3.300011] sdhci: Copyright(c) Pierre Ossman
  5328    [    3.304321] Synopsys Designware Multimedia Card Interface Driver
  5329    [    3.311644] meson-gx-mmc d0072000.mmc: Got CD GPIO
  5330    [    3.342280] meson-gx-mmc d0074000.mmc: allocated mmc-pwrseq
  5331    [    3.369861] sdhci-pltfm: SDHCI platform and OF driver helper
  5332    [    3.370759] ledtrig-cpu: registered to indicate activity on CPUs
  5333    [    3.376438] meson-sm: secure-monitor enabled
  5334    [    3.380756] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
  5335    [    3.381969] mmc0: new high speed SDHC card at address 59b4
  5336    [    3.388054] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
  5337    [    3.394158] mmcblk0: mmc0:59b4 SDU1  29.5 GiB
  5338    [    3.408285]  mmcblk0: p1 p2
  5339    [    3.418535] hid: raw HID events driver (C) Jiri Kosina
  5340    [    3.418784] usbcore: registered new interface driver usbhid
  5341    [    3.423655] usbhid: USB HID core driver
  5342    [    3.427748] platform-mhu c883c404.mailbox: Platform MHU Mailbox registered
  5343    [    3.444100] NET: Registered protocol family 17
  5344    [    3.444361] Key type dns_resolver registered
  5345    [    3.447805] registered taskstats version 1
  5346    [    3.451268] Loading compiled-in X.509 certificates
  5347    [    3.456140] zswap: loaded using pool lzo/zbud
  5348    [    3.460468] Key type ._fscrypt registered
  5349    [    3.464236] Key type .fscrypt registered
  5350    [    3.469606] Btrfs loaded, crc32c=crc32c-generic
  5351    [    3.489471] mmc1: new HS200 MMC card at address 0001
  5352    [    3.494493] mmcblk1: mmc1:0001 016G92 14.7 GiB
  5353    [    3.494948] mmcblk1boot0: mmc1:0001 016G92 partition 1 4.00 MiB
  5354    [    3.495962] Key type encrypted registered
  5355    [    3.499744] mmcblk1boot1: mmc1:0001 016G92 partition 2 4.00 MiB
  5356    [    3.509598] mmcblk1gp0: mmc1:0001 016G92 partition 4 8.00 MiB
  5357    [    3.515089] mmcblk1rpmb: mmc1:0001 016G92 partition 3 512 KiB, chardev (243:0)
  5358    [    3.522962] meson-drm d0100000.vpu: Queued 3 outputs on vpu
  5359    [    3.527799] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
  5360    [    3.534071] [drm] No driver support for vblank timestamp query.
  5361    [    3.566497] meson-dw-hdmi c883a000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
  5362    [    3.571144] meson-dw-hdmi c883a000.hdmi-tx: registered DesignWare HDMI I2C bus driver
  5363    [    3.579162] meson-drm d0100000.vpu: bound c883a000.hdmi-tx (ops meson_dw_hdmi_ops)
  5364    [    3.586477] [drm] Initialized meson 1.0.0 20161109 for d0100000.vpu on minor 0
  5365    [    3.632479] Console: switching to colour frame buffer device 90x36
  5366    [    3.652708] meson-drm d0100000.vpu: fb0: mesondrmfb frame buffer device
  5367    [    3.659974] libphy: mdio_mux: probed
  5368    [    3.670593] libphy: mdio_mux: probed
  5369    [    3.671080] phy phy-d0078080.phy.2: unsupported PHY mode 5
  5370    [    3.676176] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  5371    [    3.679517] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
  5372    [    3.687223] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228f664 hci version 0x100 quirks 0x0000000002010010
  5373    [    3.696450] xhci-hcd xhci-hcd.0.auto: irq 39, io mem 0xc9000000
  5374    [    3.702598] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.05
  5375    [    3.710958] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  5376    [    3.718112] usb usb1: Product: xHCI Host Controller
  5377    [    3.722942] usb usb1: Manufacturer: Linux 5.5.0-rc6-aml-s9xxx xhci-hcd
  5378    [    3.729411] usb usb1: SerialNumber: xhci-hcd.0.auto
  5379    [    3.734773] hub 1-0:1.0: USB hub found
  5380    [    3.737971] hub 1-0:1.0: 2 ports detected
  5381    [    3.742210] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  5382    [    3.747369] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
  5383    [    3.754954] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
  5384    [    3.761457] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
  5385    [    3.769721] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.05
  5386    [    3.778101] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  5387    [    3.785258] usb usb2: Product: xHCI Host Controller
  5388    [    3.790086] usb usb2: Manufacturer: Linux 5.5.0-rc6-aml-s9xxx xhci-hcd
  5389    [    3.796556] usb usb2: SerialNumber: xhci-hcd.0.auto
  5390    [    3.801861] hub 2-0:1.0: USB hub found
  5391    [    3.805137] hub 2-0:1.0: config failed, hub doesn't have any ports! (err -19)
  5392    [    3.813943] meson-gx-mmc d0070000.mmc: allocated mmc-pwrseq
  5393    [    3.843440] scpi_protocol scpi: SCP Protocol legacy pre-1.0 firmware
  5394    [    3.860948] gx-sound-card sound: snd-soc-dummy-dai <-> c1105400.bus:audio-controller-0 mapping ok
  5395    [    3.870166] gx-sound-card sound: i2s-hifi <-> c1105400.bus:audio-controller-2 mapping ok
  5396    [    3.877878] gx-sound-card sound: ASoC: no DMI vendor name!
  5397    [    3.884153] printk: console [netcon0] enabled
  5398    [    3.887584] netconsole: network logging started
  5399    [    3.892043] hctosys: unable to open rtc device (rtc0)
  5400    [    3.897359] ALSA device list:
  5401    [    3.899986]   #0: AMLGX
  5402    [    3.903050] Freeing unused kernel memory: 960K
  5403    [    3.906903] Run /init as init process
  5404    [    3.918929] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
  5405    [    3.925087] mmc2: queuing unknown CIS tuple 0x80 (6 bytes)
  5406    [    3.931686] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
  5407    [    3.943271] mmc2: queuing unknown CIS tuple 0x80 (19 bytes)
  5408    [    3.970936] random: fast init done
  5409    [    4.029018] mmc2: new high speed SDIO card at address 0001
  5410    [    4.074524] usb 1-1: new high-speed USB device number 2 using xhci-hcd
  5411    [    4.095866] usb 1-1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.36
  5412    [    4.102548] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
  5413    [    4.109638] usb 1-1: Product: USB2.0 Hub
  5414    [    4.177958] hub 1-1:1.0: USB hub found
  5415    [    4.180503] hub 1-1:1.0: 4 ports detected
  5416    [    4.314536] usb 1-2: new high-speed USB device number 3 using xhci-hcd
  5417    [    4.344949] usb 1-2: New USB device found, idVendor=148f, idProduct=7601, bcdDevice= 0.00
  5418    [    4.351851] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
  5419    [    4.358930] usb 1-2: Product: 802.11 n WLAN
  5420    [    4.362957] usb 1-2: Manufacturer: MediaTek
  5421    [    4.367037] usb 1-2: SerialNumber: 1.0
  5422    [    5.080597] EXT4-fs (mmcblk0p2): mounted filesystem with writeback data mode. Opts: data=writeback
  5423    [    6.016593] systemd[1]: System time before build time, advancing clock.
  5424    [    6.176071] NET: Registered protocol family 10
  5425    [    6.244830] Segment Routing with IPv6
  5426    [    6.296213] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
  5427    [    6.329732] systemd[1]: Detected architecture arm64.
  5428    [    6.381795] systemd[1]: Set hostname to <mxqpro>.
  5429    [    6.411797] systemd[1]: Couldn't move remaining userspace processes, ignoring: Input/output error
  5430    [    7.098310] random: systemd: uninitialized urandom read (16 bytes read)
  5431    [    7.110626] random: systemd: uninitialized urandom read (16 bytes read)
  5432    [    7.116481] systemd[1]: Created slice User and Session Slice.
  5433    [    7.122955] random: systemd: uninitialized urandom read (16 bytes read)
  5434    [    7.126508] systemd[1]: Reached target System Time Synchronized.
  5435    [    7.135754] systemd[1]: Listening on fsck to fsckd communication Socket.
  5436    [    7.142958] systemd[1]: Listening on Journal Audit Socket.
  5437    [    7.148678] systemd[1]: Listening on initctl Compatibility Named Pipe.
  5438    [    7.155046] systemd[1]: Reached target Swap.
  5439    [    7.315648] EXT4-fs (mmcblk0p2): re-mounted. Opts: commit=600,errors=remount-ro
  5440    [    7.514419] systemd-journald[400]: Received request to flush runtime journal from PID 1
  5441    [    8.087822] mc: Linux media interface: v0.10
  5442    [    8.112987] videodev: Linux video capture interface: v2.00
  5443    [    8.173973] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
  5444    [    8.187330] Registered IR keymap rc-empty
  5445    [    8.189629] rc rc0: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0
  5446    [    8.196349] input: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0/input0
  5447    [    8.204475] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
  5448    [    8.213462] meson-ir c8100580.ir: receiver initialized
  5449    [    8.330428] lima d00c0000.gpu: IRQ ppmmu3 not found
  5450    [    8.332928] lima d00c0000.gpu: IRQ ppmmu4 not found
  5451    [    8.337055] lima d00c0000.gpu: IRQ ppmmu5 not found
  5452    [    8.342276] lima d00c0000.gpu: IRQ ppmmu6 not found
  5453    [    8.346674] lima d00c0000.gpu: IRQ ppmmu7 not found
  5454    [    8.351906] lima d00c0000.gpu: gp - mali450 version major 0 minor 0
  5455    [    8.358310] lima d00c0000.gpu: pp0 - mali450 version major 0 minor 0
  5456    [    8.364132] lima d00c0000.gpu: pp1 - mali450 version major 0 minor 0
  5457    [    8.392798] lima d00c0000.gpu: pp2 - mali450 version major 0 minor 0
  5458    [    8.404030] lima d00c0000.gpu: IRQ pp3 not found
  5459    [    8.406071] lima d00c0000.gpu: IRQ pp4 not found
  5460    [    8.411195] Bluetooth: Core ver 2.22
  5461    [    8.414163] NET: Registered protocol family 31
  5462    [    8.418076] Bluetooth: HCI device and connection manager initialized
  5463    [    8.424169] lima d00c0000.gpu: IRQ pp5 not found
  5464    [    8.429610] lima d00c0000.gpu: IRQ pp6 not found
  5465    [    8.433371] Bluetooth: HCI socket layer initialized
  5466    [    8.435704] lima d00c0000.gpu: IRQ pp7 not found
  5467    [    8.437881] Bluetooth: L2CAP socket layer initialized
  5468    [    8.448502] Bluetooth: SCO socket layer initialized
  5469    [    8.449879] lima d00c0000.gpu: l2 cache 8K, 4-way, 64byte cache line, 128bit external bus
  5470    [    8.465305] lima d00c0000.gpu: l2 cache 64K, 4-way, 64byte cache line, 128bit external bus
  5471    [    8.476283] lima d00c0000.gpu: bus rate = 166666667
  5472    [    8.481353] lima d00c0000.gpu: mod rate = 744000000
  5473    [    8.484713] [drm] Initialized lima 1.0.0 20190217 for d00c0000.gpu on minor 1
  5474    [    8.507606] cfg80211: Loading compiled-in X.509 certificates for regulatory database
  5475    [    8.554437] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
  5476    [    8.568272] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
  5477    [    8.574785] cfg80211: failed to load regulatory.db
  5478    [    8.636201] Bluetooth: HCI UART driver ver 2.3
  5479    [    8.638158] Bluetooth: HCI UART protocol H4 registered
  5480    [    8.642130] Bluetooth: HCI UART protocol BCSP registered
  5481    [    8.647604] Bluetooth: HCI UART protocol LL registered
  5482    [    8.652481] Bluetooth: HCI UART protocol ATH3K registered
  5483    [    8.657961] Bluetooth: HCI UART protocol Three-wire (H5) registered
  5484    [    8.666809] Bluetooth: HCI UART protocol Intel registered
  5485    [    8.676166] Bluetooth: HCI UART protocol Broadcom registered
  5486    [    8.676295] hci_uart_bcm serial0-0: serial0-0 supply vbat not found, using dummy regulator
  5487    [    8.678753] Bluetooth: HCI UART protocol QCA registered
  5488    [    8.686964] hci_uart_bcm serial0-0: serial0-0 supply vddio not found, using dummy regulator
  5489    [    8.692817] Bluetooth: HCI UART protocol AG6XX registered
  5490    [    8.706966] Bluetooth: HCI UART protocol Marvell registered
  5491    [    8.771672] brcmfmac: F1 signature read @0x18000000=0x16034334
  5492    [    8.776191] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4334-sdio for chip BCM4334/3
  5493    [    8.784002] usbcore: registered new interface driver brcmfmac
  5494    [    8.832472] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.amlogic,p212.txt failed with error -2
  5495    [    8.842654] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.txt failed with error -2
  5496    [    8.898795] usb 1-2: reset high-speed USB device number 3 using xhci-hcd
  5497    [    8.921533] mt7601u 1-2:1.0: ASIC revision: 76010001 MAC revision: 76010500
  5498    [    8.954204] mt7601u 1-2:1.0: EEPROM ver:0d fae:00
  5499    [    9.087505] Bluetooth: hci0: BCM: chip id 68
  5500    [    9.090826] Bluetooth: hci0: BCM: features 0x0f
  5501    [    9.095328] Bluetooth: hci0: BCM4334B0
  5502    [    9.099208] Bluetooth: hci0: BCM4334B0 (002.001.013) build 0000
  5503    [    9.103571] bluetooth hci0: Direct firmware load for brcm/BCM4334B0.hcd failed with error -2
  5504    [    9.112576] Bluetooth: hci0: BCM: Patch brcm/BCM4334B0.hcd not found
  5505    [    9.161029] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
  5506    [    9.162083] usbcore: registered new interface driver mt7601u
  5507    [    9.858558] brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x50
  5508    [    9.924476] zram: Added device: zram0
  5509    [    9.929425] zram: Added device: zram1
  5510    [    9.932756] zram: Added device: zram2
  5511    [    9.969596] zram1: detected capacity change from 0 to 912879616
  5512    [    9.977617] meson8b-dwmac c9410000.ethernet eth0: PHY [0.e40908ff:08] driver [Meson GXL Internal PHY]
  5513    [    9.998576] meson8b-dwmac c9410000.ethernet eth0: No Safety Features support found
  5514    [   10.003018] meson8b-dwmac c9410000.ethernet eth0: PTP not supported by HW
  5515    [   10.016025] meson8b-dwmac c9410000.ethernet eth0: configuring for phy/rmii link mode
  5516    [   10.577428] random: crng init done
  5517    [   10.580005] random: 7 urandom warning(s) missed due to ratelimiting
  5518    [   10.674782] Adding 891480k swap on /dev/zram1.  Priority:5 extents:1 across:891480k SSFS
  5519
  5520    ### armbian-release:
  5521
  5522    # PLEASE DO NOT EDIT THIS FILE
  5523    BOARD=aml-s9xxx
  5524    BOARD_NAME="AML-S9xxx"
  5525    BOARDFAMILY=aml-s9xxx
  5526    BUILD_REPOSITORY_URL=https://github.com/150balbes/Build-Armbian.git
  5527    BUILD_REPOSITORY_COMMIT=62b8c07-dirty
  5528    DISTRIBUTION_CODENAME=buster
  5529    DISTRIBUTION_STATUS=supported
  5530    VERSION=20.02.0-rc1.037
  5531    LINUXFAMILY=aml-s9xxx
  5532    BRANCH=current
  5533    ARCH=arm64
  5534    IMAGE_TYPE=nightly
  5535    BOARD_TYPE=conf
  5536    INITRD_ARCH=arm64
  5537    KERNEL_IMAGE_TYPE=Image
  5538
  5539    ### boot environment:
  5540
  5541    ODROIDN2-UBOOT-CONFIG
  5542    setenv env_addr 0x10400000
  5543    setenv kernel_addr 0x11000000
  5544    setenv initrd_addr 0x13000000
  5545    setenv dtb_addr 0x1000000
  5546    if test "${devtype}" = ""; then setenv devtype "mmc"; fi
  5547    load ${devtype} ${devnum} ${env_addr} uEnv.txt && env import -t ${env_addr} ${filesize}
  5548    setenv bootargs ${APPEND}
  5549    load ${devtype} ${devnum} ${kernel_addr} ${LINUX}
  5550    load ${devtype} ${devnum} ${initrd_addr} ${INITRD}
  5551    load ${devtype} ${devnum} ${dtb_addr} ${FDT}
  5552    fdt addr ${dtb_addr}
  5553    booti ${kernel_addr} ${initrd_addr} ${dtb_addr}
  5554
  5555    ### lsusb:
  5556
  5557    Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
  5558    Bus 001 Device 003: ID 148f:7601 Ralink Technology, Corp. MT7601U Wireless Adapter
  5559    Bus 001 Device 002: ID 05e3:0608 Genesys Logic, Inc. Hub
  5560    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  5561
  5562    ### lscpu:
  5563
  5564    Architecture:        aarch64
  5565    Byte Order:          Little Endian
  5566    CPU(s):              4
  5567    On-line CPU(s) list: 0-3
  5568    Thread(s) per core:  1
  5569    Core(s) per socket:  4
  5570    Socket(s):           1
  5571    Vendor ID:           ARM
  5572    Model:               4
  5573    Model name:          Cortex-A53
  5574    Stepping:            r0p4
  5575    CPU max MHz:         1512,0000
  5576    CPU min MHz:         100,0000
  5577    BogoMIPS:            48.00
  5578    L1d cache:           unknown size
  5579    L1i cache:           unknown size
  5580    L2 cache:            unknown size
  5581    Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  5582
  5583    ### cpuinfo:
  5584
  5585    processor    : 0
  5586    model name    : ARMv8 Processor rev 4 (v8l)
  5587    BogoMIPS    : 48.00
  5588    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  5589    CPU implementer    : 0x41
  5590    CPU architecture: 8
  5591    CPU variant    : 0x0
  5592    CPU part    : 0xd03
  5593    CPU revision    : 4
  5594
  5595    processor    : 1
  5596    model name    : ARMv8 Processor rev 4 (v8l)
  5597    BogoMIPS    : 48.00
  5598    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  5599    CPU implementer    : 0x41
  5600    CPU architecture: 8
  5601    CPU variant    : 0x0
  5602    CPU part    : 0xd03
  5603    CPU revision    : 4
  5604
  5605    processor    : 2
  5606    model name    : ARMv8 Processor rev 4 (v8l)
  5607    BogoMIPS    : 48.00
  5608    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  5609    CPU implementer    : 0x41
  5610    CPU architecture: 8
  5611    CPU variant    : 0x0
  5612    CPU part    : 0xd03
  5613    CPU revision    : 4
  5614
  5615    processor    : 3
  5616    model name    : ARMv8 Processor rev 4 (v8l)
  5617    BogoMIPS    : 48.00
  5618    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  5619    CPU implementer    : 0x41
  5620    CPU architecture: 8
  5621    CPU variant    : 0x0
  5622    CPU part    : 0xd03
  5623    CPU revision    : 4
  5624
  5625
  5626    ### meminfo:
  5627
  5628    MemTotal:        1782968 kB
  5629    MemFree:         1602384 kB
  5630    MemAvailable:    1658892 kB
  5631    Buffers:           11628 kB
  5632    Cached:            58260 kB
  5633    SwapCached:            0 kB
  5634    Active:            53124 kB
  5635    Inactive:          39252 kB
  5636    Active(anon):      22828 kB
  5637    Inactive(anon):     4816 kB
  5638    Active(file):      30296 kB
  5639    Inactive(file):    34436 kB
  5640    Unevictable:           0 kB
  5641    Mlocked:               0 kB
  5642    SwapTotal:        891480 kB
  5643    SwapFree:         891480 kB
  5644    Dirty:               376 kB
  5645    Writeback:             0 kB
  5646    AnonPages:         22532 kB
  5647    Mapped:            24720 kB
  5648    Shmem:              4916 kB
  5649    KReclaimable:      17780 kB
  5650    Slab:              53304 kB
  5651    SReclaimable:      17780 kB
  5652    SUnreclaim:        35524 kB
  5653    KernelStack:        2836 kB
  5654    PageTables:         1724 kB
  5655    NFS_Unstable:          0 kB
  5656    Bounce:                0 kB
  5657    WritebackTmp:          0 kB
  5658    CommitLimit:     1782964 kB
  5659    Committed_AS:      92168 kB
  5660    VmallocTotal:   135290159040 kB
  5661    VmallocUsed:       16820 kB
  5662    VmallocChunk:          0 kB
  5663    Percpu:             1264 kB
  5664    CmaTotal:          32768 kB
  5665    CmaFree:           29084 kB
  5666    HugePages_Total:       0
  5667    HugePages_Free:        0
  5668    HugePages_Rsvd:        0
  5669    HugePages_Surp:        0
  5670    Hugepagesize:       2048 kB
  5671    Hugetlb:               0 kB
  5672
  5673    ### virtual memory:
  5674
  5675    vm.admin_reserve_kbytes = 8192
  5676    vm.block_dump = 0
  5677    vm.compact_unevictable_allowed = 1
  5678    vm.dirty_background_bytes = 0
  5679    vm.dirty_background_ratio = 10
  5680    vm.dirty_bytes = 0
  5681    vm.dirty_expire_centisecs = 3000
  5682    vm.dirty_ratio = 20
  5683    vm.dirtytime_expire_seconds = 43200
  5684    vm.dirty_writeback_centisecs = 500
  5685    vm.extfrag_threshold = 500
  5686    vm.hugetlb_shm_group = 0
  5687    vm.laptop_mode = 0
  5688    vm.legacy_va_layout = 0
  5689    vm.lowmem_reserve_ratio = 256    256    32    0
  5690    vm.max_map_count = 65530
  5691    vm.min_free_kbytes = 5274
  5692    vm.mmap_min_addr = 4096
  5693    vm.mmap_rnd_bits = 18
  5694    vm.nr_hugepages = 0
  5695    vm.nr_overcommit_hugepages = 0
  5696    vm.oom_dump_tasks = 1
  5697    vm.oom_kill_allocating_task = 0
  5698    vm.overcommit_kbytes = 0
  5699    vm.overcommit_memory = 0
  5700    vm.overcommit_ratio = 50
  5701    vm.page-cluster = 0
  5702    vm.panic_on_oom = 0
  5703    vm.percpu_pagelist_fraction = 0
  5704    vm.stat_interval = 1
  5705    vm.swappiness = 100
  5706    vm.user_reserve_kbytes = 55239
  5707    vm.vfs_cache_pressure = 100
  5708    vm.watermark_boost_factor = 15000
  5709    vm.watermark_scale_factor = 10
  5710
  5711    ### ip addr:
  5712
  5713    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
  5714        link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  5715        inet XXX.XXX.0.1/8 scope host lo
  5716           valid_lft forever preferred_lft forever
  5717        inet6 ::1/128 scope host
  5718           valid_lft forever preferred_lft forever
  5719    2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
  5720        link/ether 00:df:06:00:00:0b brd ff:ff:ff:ff:ff:ff
  5721    3: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  5722        link/ether 00:36:76:61:0b:24 brd ff:ff:ff:ff:ff:ff
  5723
  5724    ### partitions:
  5725
  5726    major minor  #blocks  name
  5727
  5728     179        0   30924800 mmcblk0
  5729     179        1     262144 mmcblk0p1
  5730     179        2   30337024 mmcblk0p2
  5731     179       32   15384576 mmcblk1
  5732     179      128       8192 mmcblk1gp0
  5733     254        1     891484 zram1
  5734
  5735    ### df:
  5736
  5737    udev             850M      0  850M   0% /dev
  5738    tmpfs            175M   4,9M  170M   3% /run
  5739    /dev/mmcblk0p2    29G    10G   19G  36% /
  5740    tmpfs            871M      0  871M   0% /dev/shm
  5741    tmpfs            5,0M   4,0K  5,0M   1% /run/lock
  5742    tmpfs            871M      0  871M   0% /sys/fs/cgroup
  5743    tmpfs            871M      0  871M   0% /tmp
  5744    /dev/mmcblk0p1   256M    76M  180M  30% /boot
  5745
  5746    ### lsblk:
  5747
  5748    NAME         FSTYPE   SIZE MOUNTPOINT UUID
  5749    mmcblk0              29,5G
  5750    ├─mmcblk0p1  vfat     256M /boot      50FC-6AC8
  5751    └─mmcblk0p2  ext4      29G /          3e297ac1-e4e4-4ab1-bc57-47c07d0422ba
  5752    mmcblk1              14,7G
  5753    mmcblk1boot0            4M
  5754    mmcblk1boot1            4M
  5755    mmcblk1gp0              8M
  5756
  5757    ### zramctl:
  5758
  5759    NAME       ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT
  5760    /dev/zram1 lzo         870,6M   4K   81B   12K       4 [SWAP]
  5761
  5762    ### mtab:
  5763
  5764    /dev/mmcblk0p1 /boot vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro 0 0
  5765    /dev/mmcblk0p2 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  5766
  5767    ### mmc0:59b4 info:
  5768
  5769                   fwrev: 0x0
  5770                  uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SDU1  MODALIAS=mmc:block
  5771                     cid: 1b534d53445531201014a136d4013800
  5772                     rca: 0x59b4
  5773                     csd: 400e00325b590000ebef7f800a400000
  5774                  manfid: 0x00001b
  5775                     ocr: 0x00200000
  5776    preferred_erase_size: 4194304
  5777                    type: SD
  5778                   hwrev: 0x1
  5779                    date: 08/2019
  5780                     dsr: 0x404
  5781              erase_size: 512
  5782                   oemid: 0x534d
  5783                  serial: 0x14a136d4
  5784                     ssr: 0000000005000000040090000811391e00089a342f01000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  5785                     scr: 0235844300000000
  5786                    name: SDU1
  5787
  5788    ### mmc1:0001 info:
  5789
  5790                   fwrev: 0x0
  5791                  uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=016G92 MODALIAS=mmc:block
  5792                     cid: 11010030313647393201d3d1a4db1100
  5793             rel_sectors: 0x10
  5794                     rca: 0x0001
  5795            pre_eol_info: 0x00
  5796                     csd: d00e00320f5903ffffffffef92400000
  5797                  manfid: 0x000011
  5798                     ocr: 0x00200000
  5799    preferred_erase_size: 4194304
  5800    enhanced_area_offset: 18446744073709551594
  5801      raw_rpmb_size_mult: 0x4
  5802                    type: MMC
  5803                   hwrev: 0x0
  5804                    date: 01/2014
  5805                     prv: 0x1
  5806             ffu_capable: 0
  5807                     dsr: 0x404
  5808              erase_size: 4194304
  5809               life_time: 0x00 0x00
  5810      enhanced_area_size: 4294967274
  5811                   oemid: 0x0100
  5812                  serial: 0xd3d1a4db
  5813                 cmdq_en: 0
  5814                     rev: 0x6
  5815                    name: 016G92
  5816
  5817    ### Boot system health:
  5818
  5819    Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU
  5820    13:14:12: 1512MHz  0.55  52%  24%  15%   0%  11%   1% 57.0°C
  5821    13:14:12: 1512MHz  0.55  71%  12%  26%   1%  28%   1% 57.0°C
  5822    13:14:12: 1512MHz  0.55  53%   8%   7%   0%  35%   1% 56.0°C
  5823    13:14:13: 1512MHz  0.55  46%   7%  13%   2%  22%   1% 56.0°C
  5824    13:14:13: 1512MHz  0.55  18%   3%   5%   0%   7%   1% 56.0°C
  5825
  5826    ### lsusb:
  5827
  5828    Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
  5829    Bus 001 Device 003: ID 148f:7601 Ralink Technology, Corp. MT7601U Wireless Adapter
  5830    Bus 001 Device 002: ID 05e3:0608 Genesys Logic, Inc. Hub
  5831    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  5832
  5833    /:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/0p, 5000M
  5834    /:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/2p, 480M
  5835        |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
  5836        |__ Port 2: Dev 3, If 0, Class=Vendor Specific Class, Driver=mt7601u, 480M
  5837
  5838    ### lspci:
  5839
  5840
  5841    ### Installed packages:
  5842
  5843    ii  armbian-buster-desktop                21.02.2                              all          Armbian desktop for Debian buster
  5844    ii  armbian-config                        21.02.3                              all          Armbian configuration utility
  5845    ii  armbian-firmware                      21.02.3                              all          Linux firmware
  5846    ii  hostapd                               3:2.9-102~armbian20.05.2+1           arm64        IEEE 802.11 AP and IEEE 802.1X/WPA/WPA2/EAP Authenticator
  5847    ii  htop                                  3.1.0-0~armbian20.08.2+1             arm64        interactive processes viewer
  5848    ii  linux-base                            4.6                                  all          Linux image base package
  5849    ii  linux-buster-root-current-aml-s9xxx   20.02.0-rc1.037                      arm64        Armbian tweaks for buster on aml-s9xxx (current branch)
  5850    ii  linux-image-current-aml-s9xxx         20.02.0-rc1.037                      arm64        Linux kernel, version 5.5.0-rc6-aml-s9xxx
  5851    ii  linux-libc-dev:arm64                  4.19.171-2                           arm64        Linux support headers for userspace development
  5852    ii  linux-u-boot-aml-s9xxx-current        20.02.0-rc1.037                      arm64        Uboot loader 2019.10
  5853
  5854    ### Loaded modules:
  5855
  5856    Module                  Size  Used by
  5857    ip6t_REJECT            16384  2
  5858    nf_reject_ipv6         20480  1 ip6t_REJECT
  5859    ip6table_filter        16384  1
  5860    xt_state               16384  0
  5861    ipt_REJECT             16384  2
  5862    nf_reject_ipv4         16384  1 ipt_REJECT
  5863    ip6_tables             28672  1 ip6table_filter
  5864    xt_nat                 16384  11
  5865    xt_tcpudp              20480  35
  5866    tun                    53248  2
  5867    iptable_filter         16384  1
  5868    iptable_nat            16384  3
  5869    bpfilter               28672  0
  5870    veth                   28672  0
  5871    xt_conntrack           16384  6
  5872    xt_MASQUERADE          20480  7
  5873    nf_conntrack_netlink    49152  0
  5874    xfrm_user              36864  2
  5875    xfrm_algo              16384  1 xfrm_user
  5876    nft_counter            16384  15
  5877    xt_addrtype            16384  8
  5878    nft_compat             20480  4
  5879    nft_chain_nat          16384  4
  5880    nf_nat                 53248  4 xt_nat,nft_chain_nat,iptable_nat,xt_MASQUERADE
  5881    nf_conntrack          176128  6 xt_conntrack,nf_nat,xt_state,xt_nat,nf_conntrack_netlink,xt_MASQUERADE
  5882    nf_defrag_ipv4         16384  1 nf_conntrack
  5883    nf_tables             163840  45 nft_compat,nft_counter,nft_chain_nat
  5884    nfnetlink              16384  5 nft_compat,nf_conntrack_netlink,nf_tables
  5885    br_netfilter           28672  0
  5886    bridge                208896  1 br_netfilter
  5887    stp                    16384  1 bridge
  5888    llc                    16384  2 bridge,stp
  5889    bnep                   32768  2
  5890    zram                   36864  1
  5891    nls_ascii              16384  1
  5892    mt7601u                77824  0
  5893    brcmfmac              376832  0
  5894    mac80211              569344  1 mt7601u
  5895    hci_uart              143360  0
  5896    brcmutil               24576  1 brcmfmac
  5897    btqca                  20480  1 hci_uart
  5898    btrtl                  24576  1 hci_uart
  5899    btbcm                  16384  1 hci_uart
  5900    cfg80211              417792  3 mt7601u,brcmfmac,mac80211
  5901    btintel                32768  1 hci_uart
  5902    bluetooth             598016  27 btrtl,btqca,btintel,hci_uart,btbcm,bnep
  5903    lima                   45056  0
  5904    crct10dif_ce           16384  1
  5905    gpu_sched              28672  1 lima
  5906    ecdh_generic           16384  2 bluetooth
  5907    ecc                    32768  1 ecdh_generic
  5908    meson_rng              16384  0
  5909    rfkill                 36864  5 bluetooth,cfg80211
  5910    meson_vdec             86016  0
  5911    meson_ir               16384  0
  5912    dw_hdmi_cec            16384  0
  5913    rc_core                61440  2 meson_ir
  5914    v4l2_mem2mem           40960  1 meson_vdec
  5915    videobuf2_dma_contig    24576  1 meson_vdec
  5916    videobuf2_memops       20480  1 videobuf2_dma_contig
  5917    videobuf2_v4l2         36864  2 meson_vdec,v4l2_mem2mem
  5918    videobuf2_common       61440  3 meson_vdec,videobuf2_v4l2,v4l2_mem2mem
  5919    videodev              233472  4 meson_vdec,videobuf2_v4l2,videobuf2_common,v4l2_mem2mem
  5920    ao_cec                 20480  0
  5921    mc                     61440  4 videodev,videobuf2_v4l2,videobuf2_common,v4l2_mem2mem
  5922    ip_tables              28672  2 iptable_filter,iptable_nat
  5923    x_tables               40960  13 ip6table_filter,xt_conntrack,iptable_filter,nft_compat,xt_state,xt_tcpudp,xt_addrtype,xt_nat,ip6_tables,ipt_REJECT,ip_tables,xt_MASQUERADE,ip6t_REJECT
  5924    ipv6                  585728  115 bridge,br_netfilter,nf_reject_ipv6
  5925    nf_defrag_ipv6         24576  2 nf_conntrack,ipv6
  5926
  5927    ### Current system health:
  5928
  5929    Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU
  5930    13:22:27:   ---      0.09  14%   3%   4%   4%   1%   0% 50.0°C
  5931    13:22:27:   ---      0.09   4%   3%   0%   0%   0%   0% 50.0°C
  5932    13:22:28:   ---      0.09   4%   2%   0%   0%   0%   0% 49.0°C
  5933    13:22:28:   ---      0.09   3%   2%   0%   1%   0%   0% 49.0°C
  5934    13:22:28:   ---      0.09   4%   2%   0%   1%   0%   0% 49.0°C
  5935    13:22:29:   ---      0.09  14%   3%   4%   4%   1%   0% 54.0°C
  5936    13:22:30:   ---      0.09  99%   2%  96%   0%   0%   0% 57.0°C
  5937    13:22:32:   ---      0.09  99%   1%  96%   0%   0%   0% 57.0°C
  5938    13:22:32:   ---      0.49  57%   4%  52%   0%   0%   0% 52.0°C
  5939    13:22:32:   ---      0.49  30%  11%  16%   1%   0%   1% 53.0°C
  5940
  5941    ### resolv.conf
  5942
  5943    -rw-r--r-- 1 root root 93 mar 25 13:14 /etc/resolv.conf
  5944    # Generated by NetworkManager
  5945    search lan
  5946    nameserver XXX.XXX.1.1
  5947    nameserver fde6:471f:148a::1
  5948
  5949    ### Current sysinfo:
  5950
  5951    Linux 5.5.0-rc6-aml-s9xxx (mxqpro)     25/03/21     _aarch64_    (4 CPU)
  5952
  5953    avg-cpu:  %user   %nice %system %iowait  %steal   %idle
  5954               5,41    4,17    4,18    1,48    0,00   84,76
  5955
  5956    Device             tps    kB_read/s    kB_wrtn/s    kB_read    kB_wrtn
  5957    ram0              0,00         0,00         0,00          0          0
  5958    ram1              0,00         0,00         0,00          0          0
  5959    ram2              0,00         0,00         0,00          0          0
  5960    ram3              0,00         0,00         0,00          0          0
  5961    ram4              0,00         0,00         0,00          0          0
  5962    ram5              0,00         0,00         0,00          0          0
  5963    ram6              0,00         0,00         0,00          0          0
  5964    ram7              0,00         0,00         0,00          0          0
  5965    ram8              0,00         0,00         0,00          0          0
  5966    ram9              0,00         0,00         0,00          0          0
  5967    ram10             0,00         0,00         0,00          0          0
  5968    ram11             0,00         0,00         0,00          0          0
  5969    ram12             0,00         0,00         0,00          0          0
  5970    ram13             0,00         0,00         0,00          0          0
  5971    ram14             0,00         0,00         0,00          0          0
  5972    ram15             0,00         0,00         0,00          0          0
  5973    mmcblk0          42,30      2606,04        26,23    1256374      12644
  5974    mmcblk0p1         0,36        12,49         0,00       6021          0
  5975    mmcblk0p2        41,63      2587,03        26,23    1247205      12644
  5976    mmcblk1           0,50        10,82         0,00       5216          0
  5977    mmcblk1gp0        0,31         1,23         0,00        592          0
  5978    mmcblk1boot1      0,24         0,95         0,00        456          0
  5979    mmcblk1boot0      0,18         0,72         0,00        348          0
  5980    zram0             0,00         0,00         0,00          0          0
  5981    zram1           368,77       704,04       771,04     339416     371720
  5982    zram2             0,00         0,00         0,00          0          0
  5983
  5984    procs -----------------------memory---------------------- ---swap-- -----io---- -system-- --------cpu--------
  5985     r  b         swpd         free         buff        cache   si   so    bi    bo   in   cs  us  sy  id  wa  st
  5986     0  0        21760       279060        33292      1047936  176  194   658     7  303  453  10   4  85   1   0
  5987
  5988                  total        used        free      shared  buff/cache   available
  5989    Mem:          1,7Gi       412Mi       272Mi        18Mi       1,0Gi       1,3Gi
  5990    Swap:         870Mi        21Mi       849Mi
  5991
  5992    NAME       ALGORITHM DISKSIZE  DATA COMPR TOTAL STREAMS MOUNTPOINT
  5993    /dev/zram1 lzo         870,6M 20,9M  6,8M 10,2M       4 [SWAP]
  5994
  5995     13:22:33 up 8 min,  1 user,  load average: 0,49, 0,45, 0,30
  5996
  5997    [    3.388054] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
  5998    [    3.394158] mmcblk0: mmc0:59b4 SDU1  29.5 GiB
  5999    [    3.408285]  mmcblk0: p1 p2
  6000    [    3.418535] hid: raw HID events driver (C) Jiri Kosina
  6001    [    3.418784] usbcore: registered new interface driver usbhid
  6002    [    3.423655] usbhid: USB HID core driver
  6003    [    3.427748] platform-mhu c883c404.mailbox: Platform MHU Mailbox registered
  6004    [    3.444100] NET: Registered protocol family 17
  6005    [    3.444361] Key type dns_resolver registered
  6006    [    3.447805] registered taskstats version 1
  6007    [    3.451268] Loading compiled-in X.509 certificates
  6008    [    3.456140] zswap: loaded using pool lzo/zbud
  6009    [    3.460468] Key type ._fscrypt registered
  6010    [    3.464236] Key type .fscrypt registered
  6011    [    3.469606] Btrfs loaded, crc32c=crc32c-generic
  6012    [    3.489471] mmc1: new HS200 MMC card at address 0001
  6013    [    3.494493] mmcblk1: mmc1:0001 016G92 14.7 GiB
  6014    [    3.494948] mmcblk1boot0: mmc1:0001 016G92 partition 1 4.00 MiB
  6015    [    3.495962] Key type encrypted registered
  6016    [    3.499744] mmcblk1boot1: mmc1:0001 016G92 partition 2 4.00 MiB
  6017    [    3.509598] mmcblk1gp0: mmc1:0001 016G92 partition 4 8.00 MiB
  6018    [    3.515089] mmcblk1rpmb: mmc1:0001 016G92 partition 3 512 KiB, chardev (243:0)
  6019    [    3.522962] meson-drm d0100000.vpu: Queued 3 outputs on vpu
  6020    [    3.527799] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
  6021    [    3.534071] [drm] No driver support for vblank timestamp query.
  6022    [    3.566497] meson-dw-hdmi c883a000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
  6023    [    3.571144] meson-dw-hdmi c883a000.hdmi-tx: registered DesignWare HDMI I2C bus driver
  6024    [    3.579162] meson-drm d0100000.vpu: bound c883a000.hdmi-tx (ops meson_dw_hdmi_ops)
  6025    [    3.586477] [drm] Initialized meson 1.0.0 20161109 for d0100000.vpu on minor 0
  6026    [    3.632479] Console: switching to colour frame buffer device 90x36
  6027    [    3.652708] meson-drm d0100000.vpu: fb0: mesondrmfb frame buffer device
  6028    [    3.659974] libphy: mdio_mux: probed
  6029    [    3.670593] libphy: mdio_mux: probed
  6030    [    3.671080] phy phy-d0078080.phy.2: unsupported PHY mode 5
  6031    [    3.676176] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  6032    [    3.679517] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
  6033    [    3.687223] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228f664 hci version 0x100 quirks 0x0000000002010010
  6034    [    3.696450] xhci-hcd xhci-hcd.0.auto: irq 39, io mem 0xc9000000
  6035    [    3.702598] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.05
  6036    [    3.710958] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  6037    [    3.718112] usb usb1: Product: xHCI Host Controller
  6038    [    3.722942] usb usb1: Manufacturer: Linux 5.5.0-rc6-aml-s9xxx xhci-hcd
  6039    [    3.729411] usb usb1: SerialNumber: xhci-hcd.0.auto
  6040    [    3.734773] hub 1-0:1.0: USB hub found
  6041    [    3.737971] hub 1-0:1.0: 2 ports detected
  6042    [    3.742210] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  6043    [    3.747369] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
  6044    [    3.754954] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
  6045    [    3.761457] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
  6046    [    3.769721] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.05
  6047    [    3.778101] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  6048    [    3.785258] usb usb2: Product: xHCI Host Controller
  6049    [    3.790086] usb usb2: Manufacturer: Linux 5.5.0-rc6-aml-s9xxx xhci-hcd
  6050    [    3.796556] usb usb2: SerialNumber: xhci-hcd.0.auto
  6051    [    3.801861] hub 2-0:1.0: USB hub found
  6052    [    3.805137] hub 2-0:1.0: config failed, hub doesn't have any ports! (err -19)
  6053    [    3.813943] meson-gx-mmc d0070000.mmc: allocated mmc-pwrseq
  6054    [    3.843440] scpi_protocol scpi: SCP Protocol legacy pre-1.0 firmware
  6055    [    3.860948] gx-sound-card sound: snd-soc-dummy-dai <-> c1105400.bus:audio-controller-0 mapping ok
  6056    [    3.870166] gx-sound-card sound: i2s-hifi <-> c1105400.bus:audio-controller-2 mapping ok
  6057    [    3.877878] gx-sound-card sound: ASoC: no DMI vendor name!
  6058    [    3.884153] printk: console [netcon0] enabled
  6059    [    3.887584] netconsole: network logging started
  6060    [    3.892043] hctosys: unable to open rtc device (rtc0)
  6061    [    3.897359] ALSA device list:
  6062    [    3.899986]   #0: AMLGX
  6063    [    3.903050] Freeing unused kernel memory: 960K
  6064    [    3.906903] Run /init as init process
  6065    [    3.918929] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
  6066    [    3.925087] mmc2: queuing unknown CIS tuple 0x80 (6 bytes)
  6067    [    3.931686] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
  6068    [    3.943271] mmc2: queuing unknown CIS tuple 0x80 (19 bytes)
  6069    [    3.970936] random: fast init done
  6070    [    4.029018] mmc2: new high speed SDIO card at address 0001
  6071    [    4.074524] usb 1-1: new high-speed USB device number 2 using xhci-hcd
  6072    [    4.095866] usb 1-1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.36
  6073    [    4.102548] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
  6074    [    4.109638] usb 1-1: Product: USB2.0 Hub
  6075    [    4.177958] hub 1-1:1.0: USB hub found
  6076    [    4.180503] hub 1-1:1.0: 4 ports detected
  6077    [    4.314536] usb 1-2: new high-speed USB device number 3 using xhci-hcd
  6078    [    4.344949] usb 1-2: New USB device found, idVendor=148f, idProduct=7601, bcdDevice= 0.00
  6079    [    4.351851] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
  6080    [    4.358930] usb 1-2: Product: 802.11 n WLAN
  6081    [    4.362957] usb 1-2: Manufacturer: MediaTek
  6082    [    4.367037] usb 1-2: SerialNumber: 1.0
  6083    [    5.080597] EXT4-fs (mmcblk0p2): mounted filesystem with writeback data mode. Opts: data=writeback
  6084    [    6.016593] systemd[1]: System time before build time, advancing clock.
  6085    [    6.176071] NET: Registered protocol family 10
  6086    [    6.244830] Segment Routing with IPv6
  6087    [    6.296213] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
  6088    [    6.329732] systemd[1]: Detected architecture arm64.
  6089    [    6.381795] systemd[1]: Set hostname to <mxqpro>.
  6090    [    6.411797] systemd[1]: Couldn't move remaining userspace processes, ignoring: Input/output error
  6091    [    7.098310] random: systemd: uninitialized urandom read (16 bytes read)
  6092    [    7.110626] random: systemd: uninitialized urandom read (16 bytes read)
  6093    [    7.116481] systemd[1]: Created slice User and Session Slice.
  6094    [    7.122955] random: systemd: uninitialized urandom read (16 bytes read)
  6095    [    7.126508] systemd[1]: Reached target System Time Synchronized.
  6096    [    7.135754] systemd[1]: Listening on fsck to fsckd communication Socket.
  6097    [    7.142958] systemd[1]: Listening on Journal Audit Socket.
  6098    [    7.148678] systemd[1]: Listening on initctl Compatibility Named Pipe.
  6099    [    7.155046] systemd[1]: Reached target Swap.
  6100    [    7.315648] EXT4-fs (mmcblk0p2): re-mounted. Opts: commit=600,errors=remount-ro
  6101    [    7.514419] systemd-journald[400]: Received request to flush runtime journal from PID 1
  6102    [    8.087822] mc: Linux media interface: v0.10
  6103    [    8.112987] videodev: Linux video capture interface: v2.00
  6104    [    8.173973] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
  6105    [    8.187330] Registered IR keymap rc-empty
  6106    [    8.189629] rc rc0: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0
  6107    [    8.196349] input: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0/input0
  6108    [    8.204475] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
  6109    [    8.213462] meson-ir c8100580.ir: receiver initialized
  6110    [    8.330428] lima d00c0000.gpu: IRQ ppmmu3 not found
  6111    [    8.332928] lima d00c0000.gpu: IRQ ppmmu4 not found
  6112    [    8.337055] lima d00c0000.gpu: IRQ ppmmu5 not found
  6113    [    8.342276] lima d00c0000.gpu: IRQ ppmmu6 not found
  6114    [    8.346674] lima d00c0000.gpu: IRQ ppmmu7 not found
  6115    [    8.351906] lima d00c0000.gpu: gp - mali450 version major 0 minor 0
  6116    [    8.358310] lima d00c0000.gpu: pp0 - mali450 version major 0 minor 0
  6117    [    8.364132] lima d00c0000.gpu: pp1 - mali450 version major 0 minor 0
  6118    [    8.392798] lima d00c0000.gpu: pp2 - mali450 version major 0 minor 0
  6119    [    8.404030] lima d00c0000.gpu: IRQ pp3 not found
  6120    [    8.406071] lima d00c0000.gpu: IRQ pp4 not found
  6121    [    8.411195] Bluetooth: Core ver 2.22
  6122    [    8.414163] NET: Registered protocol family 31
  6123    [    8.418076] Bluetooth: HCI device and connection manager initialized
  6124    [    8.424169] lima d00c0000.gpu: IRQ pp5 not found
  6125    [    8.429610] lima d00c0000.gpu: IRQ pp6 not found
  6126    [    8.433371] Bluetooth: HCI socket layer initialized
  6127    [    8.435704] lima d00c0000.gpu: IRQ pp7 not found
  6128    [    8.437881] Bluetooth: L2CAP socket layer initialized
  6129    [    8.448502] Bluetooth: SCO socket layer initialized
  6130    [    8.449879] lima d00c0000.gpu: l2 cache 8K, 4-way, 64byte cache line, 128bit external bus
  6131    [    8.465305] lima d00c0000.gpu: l2 cache 64K, 4-way, 64byte cache line, 128bit external bus
  6132    [    8.476283] lima d00c0000.gpu: bus rate = 166666667
  6133    [    8.481353] lima d00c0000.gpu: mod rate = 744000000
  6134    [    8.484713] [drm] Initialized lima 1.0.0 20190217 for d00c0000.gpu on minor 1
  6135    [    8.507606] cfg80211: Loading compiled-in X.509 certificates for regulatory database
  6136    [    8.554437] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
  6137    [    8.568272] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
  6138    [    8.574785] cfg80211: failed to load regulatory.db
  6139    [    8.636201] Bluetooth: HCI UART driver ver 2.3
  6140    [    8.638158] Bluetooth: HCI UART protocol H4 registered
  6141    [    8.642130] Bluetooth: HCI UART protocol BCSP registered
  6142    [    8.647604] Bluetooth: HCI UART protocol LL registered
  6143    [    8.652481] Bluetooth: HCI UART protocol ATH3K registered
  6144    [    8.657961] Bluetooth: HCI UART protocol Three-wire (H5) registered
  6145    [    8.666809] Bluetooth: HCI UART protocol Intel registered
  6146    [    8.676166] Bluetooth: HCI UART protocol Broadcom registered
  6147    [    8.676295] hci_uart_bcm serial0-0: serial0-0 supply vbat not found, using dummy regulator
  6148    [    8.678753] Bluetooth: HCI UART protocol QCA registered
  6149    [    8.686964] hci_uart_bcm serial0-0: serial0-0 supply vddio not found, using dummy regulator
  6150    [    8.692817] Bluetooth: HCI UART protocol AG6XX registered
  6151    [    8.706966] Bluetooth: HCI UART protocol Marvell registered
  6152    [    8.771672] brcmfmac: F1 signature read @0x18000000=0x16034334
  6153    [    8.776191] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4334-sdio for chip BCM4334/3
  6154    [    8.784002] usbcore: registered new interface driver brcmfmac
  6155    [    8.832472] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.amlogic,p212.txt failed with error -2
  6156    [    8.842654] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.txt failed with error -2
  6157    [    8.898795] usb 1-2: reset high-speed USB device number 3 using xhci-hcd
  6158    [    8.921533] mt7601u 1-2:1.0: ASIC revision: 76010001 MAC revision: 76010500
  6159    [    8.954204] mt7601u 1-2:1.0: EEPROM ver:0d fae:00
  6160    [    9.087505] Bluetooth: hci0: BCM: chip id 68
  6161    [    9.090826] Bluetooth: hci0: BCM: features 0x0f
  6162    [    9.095328] Bluetooth: hci0: BCM4334B0
  6163    [    9.099208] Bluetooth: hci0: BCM4334B0 (002.001.013) build 0000
  6164    [    9.103571] bluetooth hci0: Direct firmware load for brcm/BCM4334B0.hcd failed with error -2
  6165    [    9.112576] Bluetooth: hci0: BCM: Patch brcm/BCM4334B0.hcd not found
  6166    [    9.161029] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
  6167    [    9.162083] usbcore: registered new interface driver mt7601u
  6168    [    9.858558] brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x50
  6169    [    9.924476] zram: Added device: zram0
  6170    [    9.929425] zram: Added device: zram1
  6171    [    9.932756] zram: Added device: zram2
  6172    [    9.969596] zram1: detected capacity change from 0 to 912879616
  6173    [    9.977617] meson8b-dwmac c9410000.ethernet eth0: PHY [0.e40908ff:08] driver [Meson GXL Internal PHY]
  6174    [    9.998576] meson8b-dwmac c9410000.ethernet eth0: No Safety Features support found
  6175    [   10.003018] meson8b-dwmac c9410000.ethernet eth0: PTP not supported by HW
  6176    [   10.016025] meson8b-dwmac c9410000.ethernet eth0: configuring for phy/rmii link mode
  6177    [   10.577428] random: crng init done
  6178    [   10.580005] random: 7 urandom warning(s) missed due to ratelimiting
  6179    [   10.674782] Adding 891480k swap on /dev/zram1.  Priority:5 extents:1 across:891480k SSFS
  6180    [   12.101100] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
  6181    [   12.103009] Bluetooth: BNEP filters: protocol multicast
  6182    [   12.107950] Bluetooth: BNEP socket layer initialized
  6183    [   16.726741] wlan0: authenticate with 9c:9d:7e:12:20:57
  6184    [   16.744771] wlan0: send auth to 9c:9d:7e:12:20:57 (try 1/3)
  6185    [   16.950368] wlan0: send auth to 9c:9d:7e:12:20:57 (try 2/3)
  6186    [   16.956557] wlan0: authenticated
  6187    [   16.962416] wlan0: associate with 9c:9d:7e:12:20:57 (try 1/3)
  6188    [   16.969152] wlan0: RX AssocResp from 9c:9d:7e:12:20:57 (capab=0x431 status=0 aid=1)
  6189    [   16.997750] wlan0: associated
  6190    [   17.011390] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
  6191    [   26.066498] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
  6192    [   26.082113] Bridge firewalling registered
  6193    [   26.716669] Initializing XFRM netlink socket
  6194    [   32.421609] overlayfs: NFS export requires "index=on", falling back to nfs_export=off.
  6195    [   32.599839] overlayfs: NFS export requires "index=on", falling back to nfs_export=off.
  6196    [   32.720064] overlayfs: NFS export requires "index=on", falling back to nfs_export=off.
  6197    [   32.766938] docker0: port 1(veth499e21b) entered blocking state
  6198    [   32.773794] docker0: port 1(veth499e21b) entered disabled state
  6199    [   32.778067] device veth499e21b entered promiscuous mode
  6200    [   33.409095] rc rc0: two consecutive events of type space
  6201    [   34.083026] eth0: renamed from veth334ddd0
  6202    [   34.114431] IPv6: ADDRCONF(NETDEV_CHANGE): veth499e21b: link becomes ready
  6203    [   34.118936] docker0: port 1(veth499e21b) entered blocking state
  6204    [   34.124623] docker0: port 1(veth499e21b) entered forwarding state
  6205    [   34.131427] IPv6: ADDRCONF(NETDEV_CHANGE): docker0: link becomes ready
  6206    [   39.527319] bpfilter: Loaded bpfilter_umh pid 2466
  6207    [   42.574193] tun: Universal TUN/TAP device driver, 1.6
  6208    [   43.884040] br-d68f2303413d: port 1(vethf97dc83) entered blocking state
  6209    [   43.889416] br-d68f2303413d: port 1(vethf97dc83) entered disabled state
  6210    [   43.895761] device vethf97dc83 entered promiscuous mode
  6211    [   43.905012] br-d68f2303413d: port 1(vethf97dc83) entered blocking state
  6212    [   43.908587] br-d68f2303413d: port 1(vethf97dc83) entered forwarding state
  6213    [   43.916135] br-d68f2303413d: port 1(vethf97dc83) entered disabled state
  6214    [   43.922475] supervisor0: port 1(veth2564adb) entered blocking state
  6215    [   43.929014] supervisor0: port 1(veth2564adb) entered disabled state
  6216    [   43.935069] device veth2564adb entered promiscuous mode
  6217    [   43.940530] supervisor0: port 1(veth2564adb) entered blocking state
  6218    [   43.945736] supervisor0: port 1(veth2564adb) entered forwarding state
  6219    [   43.952335] supervisor0: port 1(veth2564adb) entered disabled state
  6220    [   44.353749] br-d68f2303413d: port 2(veth09a605a) entered blocking state
  6221    [   44.357074] br-d68f2303413d: port 2(veth09a605a) entered disabled state
  6222    [   44.364655] device veth09a605a entered promiscuous mode
  6223    [   44.370981] br-d68f2303413d: port 2(veth09a605a) entered blocking state
  6224    [   44.375380] br-d68f2303413d: port 2(veth09a605a) entered forwarding state
  6225    [   44.383397] br-d68f2303413d: port 2(veth09a605a) entered disabled state
  6226    [   44.970268] eth0: renamed from veth191678d
  6227    [   44.994343] br-d68f2303413d: port 1(vethf97dc83) entered blocking state
  6228    [   44.997524] br-d68f2303413d: port 1(vethf97dc83) entered forwarding state
  6229    [   45.168378] kmem.limit_in_bytes is deprecated and will be removed. Please report your usecase to linux-mm@kvack.org if you depend on this functionality.
  6230    [   45.598382] eth0: renamed from vethb18955d
  6231    [   45.626056] br-d68f2303413d: port 2(veth09a605a) entered blocking state
  6232    [   45.629315] br-d68f2303413d: port 2(veth09a605a) entered forwarding state
  6233    [   45.687185] eth1: renamed from vethee1b5eb
  6234    [   45.714356] supervisor0: port 1(veth2564adb) entered blocking state
  6235    [   45.717349] supervisor0: port 1(veth2564adb) entered forwarding state
  6236    [   58.970589] br-d68f2303413d: port 3(veth16c3d5c) entered blocking state
  6237    [   58.971751] br-d68f2303413d: port 3(veth16c3d5c) entered disabled state
  6238    [   58.988982] device veth16c3d5c entered promiscuous mode
  6239    [   60.061974] eth0: renamed from vetha11efdf
  6240    [   60.078332] br-d68f2303413d: port 3(veth16c3d5c) entered blocking state
  6241    [   60.079433] br-d68f2303413d: port 3(veth16c3d5c) entered forwarding state
  6242    [   60.883548] br-d68f2303413d: port 3(veth16c3d5c) entered disabled state
  6243    [   60.893741] vetha11efdf: renamed from eth0
  6244    [   60.998928] br-d68f2303413d: port 3(veth16c3d5c) entered disabled state
  6245    [   61.003351] device veth16c3d5c left promiscuous mode
  6246    [   61.005131] br-d68f2303413d: port 3(veth16c3d5c) entered disabled state
  6247
  6248
  6249    vm.admin_reserve_kbytes = 8192
  6250    vm.block_dump = 0
  6251    vm.compact_unevictable_allowed = 1
  6252    vm.dirty_background_bytes = 0
  6253    vm.dirty_background_ratio = 10
  6254    vm.dirty_bytes = 0
  6255    vm.dirty_expire_centisecs = 3000
  6256    vm.dirty_ratio = 20
  6257    vm.dirtytime_expire_seconds = 43200
  6258    vm.dirty_writeback_centisecs = 500
  6259    vm.extfrag_threshold = 500
  6260    vm.hugetlb_shm_group = 0
  6261    vm.laptop_mode = 0
  6262    vm.legacy_va_layout = 0
  6263    vm.lowmem_reserve_ratio = 256    256    32    0
  6264    vm.max_map_count = 65530
  6265    vm.min_free_kbytes = 5274
  6266    vm.mmap_min_addr = 4096
  6267    vm.nr_hugepages = 0
  6268    vm.nr_overcommit_hugepages = 0
  6269    vm.oom_dump_tasks = 1
  6270    vm.oom_kill_allocating_task = 0
  6271    vm.overcommit_kbytes = 0
  6272    vm.overcommit_memory = 0
  6273    vm.overcommit_ratio = 50
  6274    vm.page-cluster = 0
  6275    vm.panic_on_oom = 0
  6276    vm.percpu_pagelist_fraction = 0
  6277    vm.stat_interval = 1
  6278    vm.swappiness = 100
  6279    vm.user_reserve_kbytes = 55239
  6280    vm.vfs_cache_pressure = 100
  6281    vm.watermark_boost_factor = 15000
  6282    vm.watermark_scale_factor = 10
  6283
  6284    ### interrupts:
  6285               CPU0       CPU1       CPU2       CPU3
  6286      3:      60418      64391      56536      58357     GICv2  30 Level     arch_timer
  6287      6:          0          0          0          0     GICv2 169 Level     arm-pmu
  6288      7:          0          0          0          0     GICv2 170 Level     arm-pmu
  6289      8:          0          0          0          0     GICv2 185 Level     arm-pmu
  6290      9:          0          0          0          0     GICv2 186 Level     arm-pmu
  6291     10:       1303          0          0          0     GICv2  58 Edge      ttyAML6
  6292     11:          5          0          0          0     GICv2 105 Edge      c1108680.adc
  6293     12:          0          0          0          0     GICv2 231 Edge      c8100100.cec
  6294     13:        123          0          0          0     GICv2 225 Edge      ttyAML0
  6295     14:          4          0          0          0     GICv2 228 Edge      c8100580.ir
  6296     15:          0          0          0          0     GICv2  76 Edge      vdec
  6297     16:          0          0          0          0     GICv2  64 Edge      esparserirq
  6298     18:        146          0          0          0     GICv2 241 Edge      platform_mhu_link
  6299     19:        831          0          0          0     GICv2 242 Edge      platform_mhu_link
  6300     20:          0          0          0          0     GICv2  40 Level     eth0
  6301     21:        723          0          0          0     GICv2 248 Edge      d0070000.mmc
  6302     22:      42523          0          0          0     GICv2 249 Edge      d0072000.mmc
  6303     23:       1570          0          0          0     GICv2 250 Edge      d0074000.mmc
  6304     25:          0          0          0          0     GICv2 192 Level     gp
  6305     26:          0          0          0          0     GICv2 193 Level     gpmmu
  6306     27:          0          0          0          0     GICv2 194 Level     pp_bcast
  6307     29:          0          0          0          0     GICv2 196 Level     pp0
  6308     30:          0          0          0          0     GICv2 197 Level     ppmmu0
  6309     31:          0          0          0          0     GICv2 198 Level     pp1
  6310     32:          0          0          0          0     GICv2 199 Level     ppmmu1
  6311     33:          0          0          0          0     GICv2 200 Level     pp2
  6312     34:          0          0          0          0     GICv2 201 Level     ppmmu2
  6313     35:       1033          0          0          0     GICv2  35 Edge      meson
  6314     36:          0          0          0          0     GICv2  89 Edge      dw_hdmi_top_irq, c883a000.hdmi-tx, dw-hdmi-cec
  6315     37:          0          0          0          0     GICv2 220 Edge      gxl-crypto
  6316     38:          0          0          0          0     GICv2 221 Edge      gxl-crypto
  6317     39:      89231          0          0          0     GICv2  62 Level     xhci-hcd:usb1
  6318     42:          0          0          0          0     GICv2  41 Level     0.e40908ff:08
  6319    IPI0:     30443      57828      58357      55898       Rescheduling interrupts
  6320    IPI1:       513        528        476        494       Function call interrupts
  6321    IPI2:         0          0          0          0       CPU stop interrupts
  6322    IPI3:         0          0          0          0       CPU stop (for crash dump) interrupts
  6323    IPI4:         0          0          0          0       Timer broadcast interrupts
  6324    IPI5:       633        468        377        355       IRQ work interrupts
  6325    IPI6:         0          0          0          0       CPU wake-up interrupts
  6326    Err:          0
Please upload the whole output above to an online pasteboard service
and provide the URL in the forum where you have been asked for this.
Any idea about how I'm doing wrong?
Another try usinf de DTS edit function inside 'armbian-config' same result:
Spoiler
     1
     2    ### Activated 1 lzo zram swap devices with 870 MB each
     3
     4
     5    dom mar 21 00:17:31 CET 2021 | AML-S9xxx | 20.02.0-rc1.037 | arm64 | aarch64 | 5.5.0-rc6-aml-s9xxx
     6
     7    ### dmesg:
     8
     9    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
    10    [    0.000000] Linux version 5.5.0-rc6-aml-s9xxx (root@vbox) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #rc1.037 SMP PREEMPT Wed Feb 5 15:59:04 MSK 2020
    11    [    0.000000] Machine model: Amlogic Meson GXL (S905X) P212 Development Board
    12    [    0.000000] efi: Getting EFI parameters from FDT:
    13    [    0.000000] efi: UEFI not found.
    14    [    0.000000] Reserved memory: created CMA memory pool at 0x0000000063400000, size 256 MiB
    15    [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
    16    [    0.000000] On node 0 totalpages: 477952
    17    [    0.000000]   DMA zone: 4032 pages used for memmap
    18    [    0.000000]   DMA zone: 0 pages reserved
    19    [    0.000000]   DMA zone: 248576 pages, LIFO batch:63
    20    [    0.000000]   DMA32 zone: 3584 pages used for memmap
    21    [    0.000000]   DMA32 zone: 229376 pages, LIFO batch:63
    22    [    0.000000] psci: probing for conduit method from DT.
    23    [    0.000000] psci: PSCIv0.2 detected in firmware.
    24    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    25    [    0.000000] psci: Trusted OS migration not required
    26    [    0.000000] percpu: Embedded 22 pages/cpu s50392 r8192 d31528 u90112
    27    [    0.000000] pcpu-alloc: s50392 r8192 d31528 u90112 alloc=22*4096
    28    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
    29    [    0.000000] Detected VIPT I-cache on CPU0
    30    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 470336
    31    [    0.000000] Kernel command line: root=LABEL=ROOTFS rootflags=data=writeback rw console=ttyAML0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 mac=00:df:06:00:00:0b
    32    [    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    33    [    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
    34    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    35    [    0.000000] software IO TLB: mapped [mem 0x3bfff000-0x3ffff000] (64MB)
    36    [    0.000000] Memory: 1509616K/1911808K available (14460K kernel code, 1434K rwdata, 5884K rodata, 960K init, 927K bss, 140048K reserved, 262144K cma-reserved)
    37    [    0.000000] random: get_random_u64 called from cache_random_seq_create+0x7c/0x150 with crng_init=0
    38    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    39    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    40    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
    41    [    0.000000]     Tasks RCU enabled.
    42    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    43    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
    44    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    45    [    0.000000] GIC: Using split EOI/Deactivate mode
    46    [    0.000000] irq_meson_gpio: 110 to 8 gpio interrupt mux initialized
    47    [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
    48    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
    49    [    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
    50    [    0.000357] Console: colour dummy device 80x25
    51    [    0.000658] printk: console [tty0] enabled
    52    [    0.000698] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
    53    [    0.000719] pid_max: default: 32768 minimum: 301
    54    [    0.000843] LSM: Security Framework initializing
    55    [    0.000893] SELinux:  Initializing.
    56    [    0.000973] *** VALIDATE SELinux ***
    57    [    0.001041] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    58    [    0.001067] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    59    [    0.001130] *** VALIDATE tmpfs ***
    60    [    0.001535] *** VALIDATE proc ***
    61    [    0.001762] *** VALIDATE cgroup1 ***
    62    [    0.001776] *** VALIDATE cgroup2 ***
    63    [    0.024017] ASID allocator initialised with 32768 entries
    64    [    0.031999] rcu: Hierarchical SRCU implementation.
    65    [    0.042087] EFI services will not be available.
    66    [    0.048056] smp: Bringing up secondary CPUs ...
    67    [    0.080283] Detected VIPT I-cache on CPU1
    68    [    0.080336] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    69    [    0.112323] Detected VIPT I-cache on CPU2
    70    [    0.112367] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
    71    [    0.144371] Detected VIPT I-cache on CPU3
    72    [    0.144414] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
    73    [    0.144488] smp: Brought up 1 node, 4 CPUs
    74    [    0.144556] SMP: Total of 4 processors activated.
    75    [    0.144567] CPU features: detected: 32-bit EL0 Support
    76    [    0.144579] CPU features: detected: CRC32 instructions
    77    [    0.144883] CPU: All CPU(s) started at EL2
    78    [    0.144906] alternatives: patching kernel code
    79    [    0.146005] devtmpfs: initialized
    80    [    0.151132] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    81    [    0.151173] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
    82    [    0.158028] xor: measuring software checksum speed
    83    [    0.196372]    8regs     :  2375.000 MB/sec
    84    [    0.236403]    32regs    :  2724.000 MB/sec
    85    [    0.276440]    arm64_neon:  2406.000 MB/sec
    86    [    0.276451] xor: using function: 32regs (2724.000 MB/sec)
    87    [    0.276506] pinctrl core: initialized pinctrl subsystem
    88    [    0.277171] thermal_sys: Registered thermal governor 'step_wise'
    89    [    0.277344] DMI not present or invalid.
    90    [    0.277704] NET: Registered protocol family 16
    91    [    0.281247] DMA: preallocated 256 KiB pool for atomic allocations
    92    [    0.281298] audit: initializing netlink subsys (disabled)
    93    [    0.281510] audit: type=2000 audit(0.280:1): state=initialized audit_enabled=0 res=1
    94    [    0.282595] cpuidle: using governor ladder
    95    [    0.282635] cpuidle: using governor menu
    96    [    0.283005] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    97    [    0.283728] Serial: AMBA PL011 UART driver
    98    [    0.297742] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
    99    [    0.297768] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
   100    [    0.297782] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
   101    [    0.297794] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
   102    [    0.301475] cryptd: max_cpu_qlen set to 1000
   103    [    0.376663] raid6: neonx8   gen()  1620 MB/s
   104    [    0.444705] raid6: neonx8   xor()  1505 MB/s
   105    [    0.512768] raid6: neonx4   gen()  1564 MB/s
   106    [    0.580822] raid6: neonx4   xor()  1471 MB/s
   107    [    0.648903] raid6: neonx2   gen()  1199 MB/s
   108    [    0.716957] raid6: neonx2   xor()  1217 MB/s
   109    [    0.785006] raid6: neonx1   gen()   786 MB/s
   110    [    0.853091] raid6: neonx1   xor()   915 MB/s
   111    [    0.921101] raid6: int64x8  gen()  1194 MB/s
   112    [    0.989168] raid6: int64x8  xor()   769 MB/s
   113    [    1.057245] raid6: int64x4  gen()  1029 MB/s
   114    [    1.125290] raid6: int64x4  xor()   752 MB/s
   115    [    1.193323] raid6: int64x2  gen()   728 MB/s
   116    [    1.261407] raid6: int64x2  xor()   615 MB/s
   117    [    1.329515] raid6: int64x1  gen()   486 MB/s
   118    [    1.397467] raid6: int64x1  xor()   468 MB/s
   119    [    1.397477] raid6: using algorithm neonx8 gen() 1620 MB/s
   120    [    1.397487] raid6: .... xor() 1505 MB/s, rmw enabled
   121    [    1.397498] raid6: using neon recovery algorithm
   122    [    1.397743] ACPI: Interpreter disabled.
   123    [    1.398940] iommu: Default domain type: Translated
   124    [    1.399209] vgaarb: loaded
   125    [    1.399757] SCSI subsystem initialized
   126    [    1.399934] libata version 3.00 loaded.
   127    [    1.400144] usbcore: registered new interface driver usbfs
   128    [    1.400192] usbcore: registered new interface driver hub
   129    [    1.400255] usbcore: registered new device driver usb
   130    [    1.400657] pps_core: LinuxPPS API ver. 1 registered
   131    [    1.400670] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
   132    [    1.400696] PTP clock support registered
   133    [    1.400724] EDAC MC: Ver: 3.0.0
   134    [    1.401299] FPGA manager framework
   135    [    1.401422] Advanced Linux Sound Architecture Driver Initialized.
   136    [    1.401892] NetLabel: Initializing
   137    [    1.401904] NetLabel:  domain hash size = 128
   138    [    1.401913] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
   139    [    1.401967] NetLabel:  unlabeled traffic allowed by default
   140    [    1.402449] clocksource: Switched to clocksource arch_sys_counter
   141    [    1.402471] *** VALIDATE bpf ***
   142    [    1.402725] VFS: Disk quotas dquot_6.6.0
   143    [    1.402785] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
   144    [    1.402914] FS-Cache: Loaded
   145    [    1.402924] *** VALIDATE ramfs ***
   146    [    1.402945] *** VALIDATE hugetlbfs ***
   147    [    1.403322] pnp: PnP ACPI: disabled
   148    [    1.408351] NET: Registered protocol family 2
   149    [    1.408850] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
   150    [    1.408895] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
   151    [    1.409012] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
   152    [    1.409232] TCP: Hash tables configured (established 16384 bind 16384)
   153    [    1.409392] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
   154    [    1.409444] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
   155    [    1.409668] NET: Registered protocol family 1
   156    [    1.410112] RPC: Registered named UNIX socket transport module.
   157    [    1.410133] RPC: Registered udp transport module.
   158    [    1.410143] RPC: Registered tcp transport module.
   159    [    1.410152] RPC: Registered tcp NFSv4.1 backchannel transport module.
   160    [    1.410168] NET: Registered protocol family 44
   161    [    1.410189] PCI: CLS 0 bytes, default 64
   162    [    1.410384] Trying to unpack rootfs image as initramfs...
   163    [    1.871991] Freeing initrd memory: 10248K
   164    [    1.872788] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
   165    [    2.086160] Initialise system trusted keyrings
   166    [    2.086373] workingset: timestamp_bits=46 max_order=19 bucket_order=0
   167    [    2.091523] zbud: loaded
   168    [    2.092745] squashfs: version 4.0 (2009/01/31) Phillip Lougher
   169    [    2.093051] FS-Cache: Netfs 'nfs' registered for caching
   170    [    2.093577] NFS: Registering the id_resolver key type
   171    [    2.093613] Key type id_resolver registered
   172    [    2.093623] Key type id_legacy registered
   173    [    2.093640] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
   174    [    2.093652] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
   175    [    2.094834] FS-Cache: Netfs 'cifs' registered for caching
   176    [    2.095176] Key type cifs.spnego registered
   177    [    2.095199] Key type cifs.idmap registered
   178    [    2.095223] ntfs: driver 2.1.32 [Flags: R/W].
   179    [    2.095810] JFS: nTxBlock = 8192, nTxLock = 65536
   180    [    2.101758] SGI XFS with ACLs, security attributes, realtime, quota, no debug enabled
   181    [    2.103205] *** VALIDATE xfs ***
   182    [    2.103493] ocfs2: Registered cluster interface o2cb
   183    [    2.103717] OCFS2 User DLM kernel interface loaded
   184    [    2.105117] *** VALIDATE gfs2 ***
   185    [    2.105401] gfs2: GFS2 installed
   186    [    2.106305] aufs 5.5-20200203
   187    [    2.127122] Key type asymmetric registered
   188    [    2.127147] Asymmetric key parser 'x509' registered
   189    [    2.127157] Asymmetric key parser 'pkcs8' registered
   190    [    2.127228] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
   191    [    2.127431] io scheduler mq-deadline registered
   192    [    2.127446] io scheduler kyber registered
   193    [    2.127639] io scheduler bfq registered
   194    [    2.140178] soc soc0: Amlogic Meson GXL (S905X) Revision 21:b (82:2) Detected
   195    [    2.143753] Serial: 8250/16550 driver, 5 ports, IRQ sharing enabled
   196    [    2.145442] Serial: AMBA driver
   197    [    2.145810] c11084c0.serial: ttyAML6 at MMIO 0xc11084c0 (irq = 10, base_baud = 1500000) is a meson_uart
   198    [    2.145963] serial serial0: tty port ttyAML6 registered
   199    [    2.146175] c81004c0.serial: ttyAML0 at MMIO 0xc81004c0 (irq = 13, base_baud = 1500000) is a meson_uart
   200    [    3.121643] printk: console [ttyAML0] enabled
   201    [    3.137733] brd: module loaded
   202    [    3.146278] loop: module loaded
   203    [    3.148724] libphy: Fixed MDIO Bus: probed
   204    [    3.149372] meson8b-dwmac c9410000.ethernet: IRQ eth_wake_irq not found
   205    [    3.154490] meson8b-dwmac c9410000.ethernet: IRQ eth_lpi not found
   206    [    3.160659] meson8b-dwmac c9410000.ethernet: PTP uses main clock
   207    [    3.166503] meson8b-dwmac c9410000.ethernet: no reset control found
   208    [    3.173207] meson8b-dwmac c9410000.ethernet: User ID: 0x11, Synopsys ID: 0x37
   209    [    3.179791] meson8b-dwmac c9410000.ethernet:     DWMAC1000
   210    [    3.184956] meson8b-dwmac c9410000.ethernet: DMA HW capability register supported
   211    [    3.192371] meson8b-dwmac c9410000.ethernet: RX Checksum Offload Engine supported
   212    [    3.199788] meson8b-dwmac c9410000.ethernet: COE Type 2
   213    [    3.204962] meson8b-dwmac c9410000.ethernet: TX Checksum insertion supported
   214    [    3.211949] meson8b-dwmac c9410000.ethernet: Wake-Up On Lan supported
   215    [    3.218362] meson8b-dwmac c9410000.ethernet: Normal descriptors
   216    [    3.224197] meson8b-dwmac c9410000.ethernet: Ring mode enabled
   217    [    3.229975] meson8b-dwmac c9410000.ethernet: Enable RX Mitigation via HW Watchdog Timer
   218    [    3.238093] libphy: stmmac: probed
   219    [    3.242604] VFIO - User Level meta-driver version: 0.3
   220    [    3.247889] dwc3 c9000000.dwc3: Failed to get clk 'ref': -2
   221    [    3.252824] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
   222    [    3.258383] ehci-pci: EHCI PCI platform driver
   223    [    3.262821] ehci-platform: EHCI generic platform driver
   224    [    3.268118] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
   225    [    3.274064] ohci-pci: OHCI PCI platform driver
   226    [    3.278498] ohci-platform: OHCI generic platform driver
   227    [    3.284238] usbcore: registered new interface driver usb-storage
   228    [    3.289806] mousedev: PS/2 mouse device common for all mice
   229    [    3.295758] i2c /dev entries driver
   230    [    3.301360] sdhci: Secure Digital Host Controller Interface driver
   231    [    3.304684] sdhci: Copyright(c) Pierre Ossman
   232    [    3.308998] Synopsys Designware Multimedia Card Interface Driver
   233    [    3.316270] meson-gx-mmc d0072000.mmc: Got CD GPIO
   234    [    3.346815] meson-gx-mmc d0074000.mmc: allocated mmc-pwrseq
   235    [    3.374325] sdhci-pltfm: SDHCI platform and OF driver helper
   236    [    3.375509] ledtrig-cpu: registered to indicate activity on CPUs
   237    [    3.380905] meson-sm: secure-monitor enabled
   238    [    3.385180] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
   239    [    3.386535] mmc0: new high speed SDHC card at address 59b4
   240    [    3.392509] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
   241    [    3.398655] mmcblk0: mmc0:59b4 SDU1  29.5 GiB
   242    [    3.416709]  mmcblk0: p1 p2
   243    [    3.422890] hid: raw HID events driver (C) Jiri Kosina
   244    [    3.423124] usbcore: registered new interface driver usbhid
   245    [    3.428032] usbhid: USB HID core driver
   246    [    3.432100] platform-mhu c883c404.mailbox: Platform MHU Mailbox registered
   247    [    3.449062] NET: Registered protocol family 17
   248    [    3.449316] Key type dns_resolver registered
   249    [    3.452656] registered taskstats version 1
   250    [    3.456205] Loading compiled-in X.509 certificates
   251    [    3.461156] zswap: loaded using pool lzo/zbud
   252    [    3.465437] Key type ._fscrypt registered
   253    [    3.469201] Key type .fscrypt registered
   254    [    3.474133] Btrfs loaded, crc32c=crc32c-generic
   255    [    3.496556] mmc1: new HS200 MMC card at address 0001
   256    [    3.497451] mmcblk1: mmc1:0001 016G92 14.7 GiB
   257    [    3.500892] mmcblk1boot0: mmc1:0001 016G92 partition 1 4.00 MiB
   258    [    3.502047] Key type encrypted registered
   259    [    3.506766] mmcblk1boot1: mmc1:0001 016G92 partition 2 4.00 MiB
   260    [    3.516603] mmcblk1gp0: mmc1:0001 016G92 partition 4 8.00 MiB
   261    [    3.522126] mmcblk1rpmb: mmc1:0001 016G92 partition 3 512 KiB, chardev (243:0)
   262    [    3.529870] meson-drm d0100000.vpu: Queued 3 outputs on vpu
   263    [    3.534840] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
   264    [    3.541118] [drm] No driver support for vblank timestamp query.
   265    [    3.574515] meson-dw-hdmi c883a000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
   266    [    3.579233] meson-dw-hdmi c883a000.hdmi-tx: registered DesignWare HDMI I2C bus driver
   267    [    3.587184] meson-drm d0100000.vpu: bound c883a000.hdmi-tx (ops meson_dw_hdmi_ops)
   268    [    3.594541] [drm] Initialized meson 1.0.0 20161109 for d0100000.vpu on minor 0
   269    [    3.631355] Console: switching to colour frame buffer device 90x36
   270    [    3.651576] meson-drm d0100000.vpu: fb0: mesondrmfb frame buffer device
   271    [    3.658841] libphy: mdio_mux: probed
   272    [    3.669389] libphy: mdio_mux: probed
   273    [    3.669879] phy phy-d0078080.phy.2: unsupported PHY mode 5
   274    [    3.674927] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
   275    [    3.678308] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
   276    [    3.686022] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228f664 hci version 0x100 quirks 0x0000000002010010
   277    [    3.695262] xhci-hcd xhci-hcd.0.auto: irq 39, io mem 0xc9000000
   278    [    3.701356] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.05
   279    [    3.709727] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   280    [    3.716869] usb usb1: Product: xHCI Host Controller
   281    [    3.721696] usb usb1: Manufacturer: Linux 5.5.0-rc6-aml-s9xxx xhci-hcd
   282    [    3.728169] usb usb1: SerialNumber: xhci-hcd.0.auto
   283    [    3.733493] hub 1-0:1.0: USB hub found
   284    [    3.736745] hub 1-0:1.0: 2 ports detected
   285    [    3.740969] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
   286    [    3.746124] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
   287    [    3.753728] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
   288    [    3.760237] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
   289    [    3.768522] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.05
   290    [    3.776916] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   291    [    3.784072] usb usb2: Product: xHCI Host Controller
   292    [    3.788908] usb usb2: Manufacturer: Linux 5.5.0-rc6-aml-s9xxx xhci-hcd
   293    [    3.795373] usb usb2: SerialNumber: xhci-hcd.0.auto
   294    [    3.800681] hub 2-0:1.0: USB hub found
   295    [    3.803950] hub 2-0:1.0: config failed, hub doesn't have any ports! (err -19)
   296    [    3.812806] meson-gx-mmc d0070000.mmc: allocated mmc-pwrseq
   297    [    3.843446] scpi_protocol scpi: SCP Protocol legacy pre-1.0 firmware
   298    [    3.860311] gx-sound-card sound: snd-soc-dummy-dai <-> c1105400.bus:audio-controller-0 mapping ok
   299    [    3.872049] gx-sound-card sound: i2s-hifi <-> c1105400.bus:audio-controller-2 mapping ok
   300    [    3.879785] gx-sound-card sound: ASoC: no DMI vendor name!
   301    [    3.885960] printk: console [netcon0] enabled
   302    [    3.889372] netconsole: network logging started
   303    [    3.893930] hctosys: unable to open rtc device (rtc0)
   304    [    3.899408] ALSA device list:
   305    [    3.901959]   #0: AMLGX
   306    [    3.905031] Freeing unused kernel memory: 960K
   307    [    3.908791] Run /init as init process
   308    [    3.920297] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
   309    [    3.926571] mmc2: queuing unknown CIS tuple 0x80 (6 bytes)
   310    [    3.933111] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
   311    [    3.945261] mmc2: queuing unknown CIS tuple 0x80 (19 bytes)
   312    [    3.970942] random: fast init done
   313    [    4.031650] mmc2: new high speed SDIO card at address 0001
   314    [    4.074519] usb 1-1: new high-speed USB device number 2 using xhci-hcd
   315    [    4.095824] usb 1-1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.36
   316    [    4.102658] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
   317    [    4.110273] usb 1-1: Product: USB2.0 Hub
   318    [    4.176691] hub 1-1:1.0: USB hub found
   319    [    4.179315] hub 1-1:1.0: 4 ports detected
   320    [    4.310532] usb 1-2: new high-speed USB device number 3 using xhci-hcd
   321    [    4.341017] usb 1-2: New USB device found, idVendor=148f, idProduct=7601, bcdDevice= 0.00
   322    [    4.347976] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
   323    [    4.355838] usb 1-2: Product: 802.11 n WLAN
   324    [    4.359565] usb 1-2: Manufacturer: MediaTek
   325    [    4.363631] usb 1-2: SerialNumber: 1.0
   326    [    5.110138] EXT4-fs (mmcblk0p2): mounted filesystem with writeback data mode. Opts: data=writeback
   327    [    6.052807] systemd[1]: System time before build time, advancing clock.
   328    [    6.200507] NET: Registered protocol family 10
   329    [    6.274520] Segment Routing with IPv6
   330    [    6.325154] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
   331    [    6.358527] systemd[1]: Detected architecture arm64.
   332    [    6.413903] systemd[1]: Set hostname to <mxqpro>.
   333    [    6.447693] systemd[1]: Couldn't move remaining userspace processes, ignoring: Input/output error
   334    [    7.138797] random: systemd: uninitialized urandom read (16 bytes read)
   335    [    7.153425] random: systemd: uninitialized urandom read (16 bytes read)
   336    [    7.156998] systemd[1]: Reached target Remote File Systems.
   337    [    7.165768] random: systemd: uninitialized urandom read (16 bytes read)
   338    [    7.169563] systemd[1]: Listening on initctl Compatibility Named Pipe.
   339    [    7.179002] systemd[1]: Listening on udev Kernel Socket.
   340    [    7.184570] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
   341    [    7.192779] systemd[1]: Listening on Syslog Socket.
   342    [    7.201447] systemd[1]: Created slice system-serial\x2dgetty.slice.
   343    [    7.429845] EXT4-fs (mmcblk0p2): re-mounted. Opts: commit=600,errors=remount-ro
   344    [    7.628140] systemd-journald[411]: Received request to flush runtime journal from PID 1
   345    [    8.125525] mc: Linux media interface: v0.10
   346    [    8.151775] videodev: Linux video capture interface: v2.00
   347    [    8.166795] Registered IR keymap rc-empty
   348    [    8.169397] rc rc0: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0
   349    [    8.186083] input: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0/input0
   350    [    8.197729] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
   351    [    8.208339] meson-ir c8100580.ir: receiver initialized
   352    [    8.308327] lima d00c0000.gpu: IRQ ppmmu3 not found
   353    [    8.310996] lima d00c0000.gpu: IRQ ppmmu4 not found
   354    [    8.314707] lima d00c0000.gpu: IRQ ppmmu5 not found
   355    [    8.319537] lima d00c0000.gpu: IRQ ppmmu6 not found
   356    [    8.324389] lima d00c0000.gpu: IRQ ppmmu7 not found
   357    [    8.334645] lima d00c0000.gpu: gp - mali450 version major 0 minor 0
   358    [    8.337703] lima d00c0000.gpu: pp0 - mali450 version major 0 minor 0
   359    [    8.346755] lima d00c0000.gpu: pp1 - mali450 version major 0 minor 0
   360    [    8.350021] lima d00c0000.gpu: pp2 - mali450 version major 0 minor 0
   361    [    8.359370] lima d00c0000.gpu: IRQ pp3 not found
   362    [    8.361255] lima d00c0000.gpu: IRQ pp4 not found
   363    [    8.365744] lima d00c0000.gpu: IRQ pp5 not found
   364    [    8.370349] lima d00c0000.gpu: IRQ pp6 not found
   365    [    8.374849] lima d00c0000.gpu: IRQ pp7 not found
   366    [    8.379326] lima d00c0000.gpu: l2 cache 8K, 4-way, 64byte cache line, 128bit external bus
   367    [    8.387575] lima d00c0000.gpu: l2 cache 64K, 4-way, 64byte cache line, 128bit external bus
   368    [    8.395757] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
   369    [    8.414186] lima d00c0000.gpu: bus rate = 166666667
   370    [    8.417450] lima d00c0000.gpu: mod rate = 744000000
   371    [    8.425573] [drm] Initialized lima 1.0.0 20190217 for d00c0000.gpu on minor 1
   372    [    8.432277] Bluetooth: Core ver 2.22
   373    [    8.434596] NET: Registered protocol family 31
   374    [    8.436947] Bluetooth: HCI device and connection manager initialized
   375    [    8.445229] Bluetooth: HCI socket layer initialized
   376    [    8.449221] Bluetooth: L2CAP socket layer initialized
   377    [    8.453394] Bluetooth: SCO socket layer initialized
   378    [    8.575514] cfg80211: Loading compiled-in X.509 certificates for regulatory database
   379    [    8.581098] Bluetooth: HCI UART driver ver 2.3
   380    [    8.592788] Bluetooth: HCI UART protocol H4 registered
   381    [    8.594644] Bluetooth: HCI UART protocol BCSP registered
   382    [    8.599514] Bluetooth: HCI UART protocol LL registered
   383    [    8.604491] Bluetooth: HCI UART protocol ATH3K registered
   384    [    8.610028] Bluetooth: HCI UART protocol Three-wire (H5) registered
   385    [    8.616590] Bluetooth: HCI UART protocol Intel registered
   386    [    8.629866] Bluetooth: HCI UART protocol Broadcom registered
   387    [    8.630006] hci_uart_bcm serial0-0: serial0-0 supply vbat not found, using dummy regulator
   388    [    8.631847] Bluetooth: HCI UART protocol QCA registered
   389    [    8.642148] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
   390    [    8.645138] Bluetooth: HCI UART protocol AG6XX registered
   391    [    8.651762] hci_uart_bcm serial0-0: serial0-0 supply vddio not found, using dummy regulator
   392    [    8.657080] Bluetooth: HCI UART protocol Marvell registered
   393    [    8.683291] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
   394    [    8.690778] cfg80211: failed to load regulatory.db
   395    [    8.794743] brcmfmac: F1 signature read @0x18000000=0x16034334
   396    [    8.798059] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4334-sdio for chip BCM4334/3
   397    [    8.805682] usbcore: registered new interface driver brcmfmac
   398    [    8.855976] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.amlogic,p212.txt failed with error -2
   399    [    8.866189] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.txt failed with error -2
   400    [    8.942799] usb 1-2: reset high-speed USB device number 3 using xhci-hcd
   401    [    8.965572] mt7601u 1-2:1.0: ASIC revision: 76010001 MAC revision: 76010500
   402    [    9.008611] mt7601u 1-2:1.0: EEPROM ver:0d fae:00
   403    [    9.051512] Bluetooth: hci0: BCM: chip id 68
   404    [    9.055464] Bluetooth: hci0: BCM: features 0x0f
   405    [    9.060643] Bluetooth: hci0: BCM4334B0
   406    [    9.063489] Bluetooth: hci0: BCM4334B0 (002.001.013) build 0000
   407    [    9.067647] bluetooth hci0: Direct firmware load for brcm/BCM4334B0.hcd failed with error -2
   408    [    9.075959] Bluetooth: hci0: BCM: Patch brcm/BCM4334B0.hcd not found
   409    [    9.223051] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
   410    [    9.225005] usbcore: registered new interface driver mt7601u
   411    [    9.878553] brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x50
   412    [    9.908340] zram: Added device: zram0
   413    [    9.911823] zram: Added device: zram1
   414    [    9.927131] zram: Added device: zram2
   415    [    9.975264] zram1: detected capacity change from 0 to 912879616
   416    [    9.993267] meson8b-dwmac c9410000.ethernet eth0: PHY [0.e40908ff:08] driver [Meson GXL Internal PHY]
   417    [   10.014535] meson8b-dwmac c9410000.ethernet eth0: No Safety Features support found
   418    [   10.019869] meson8b-dwmac c9410000.ethernet eth0: PTP not supported by HW
   419    [   10.019881] meson8b-dwmac c9410000.ethernet eth0: configuring for phy/rmii link mode
   420    [   10.596915] random: crng init done
   421    [   10.599535] random: 7 urandom warning(s) missed due to ratelimiting
   422    [   10.682808] Adding 891480k swap on /dev/zram1.  Priority:5 extents:1 across:891480k SSFS
   423
   424    ### armbian-release:
   425
   426    # PLEASE DO NOT EDIT THIS FILE
   427    BOARD=aml-s9xxx
   428    BOARD_NAME="AML-S9xxx"
   429    BOARDFAMILY=aml-s9xxx
   430    BUILD_REPOSITORY_URL=https://github.com/150balbes/Build-Armbian.git
   431    BUILD_REPOSITORY_COMMIT=62b8c07-dirty
   432    DISTRIBUTION_CODENAME=buster
   433    DISTRIBUTION_STATUS=supported
   434    VERSION=20.02.0-rc1.037
   435    LINUXFAMILY=aml-s9xxx
   436    BRANCH=current
   437    ARCH=arm64
   438    IMAGE_TYPE=nightly
   439    BOARD_TYPE=conf
   440    INITRD_ARCH=arm64
   441    KERNEL_IMAGE_TYPE=Image
   442
   443    ### boot environment:
   444
   445    ODROIDN2-UBOOT-CONFIG
   446    setenv env_addr 0x10400000
   447    setenv kernel_addr 0x11000000
   448    setenv initrd_addr 0x13000000
   449    setenv dtb_addr 0x1000000
   450    if test "${devtype}" = ""; then setenv devtype "mmc"; fi
   451    load ${devtype} ${devnum} ${env_addr} uEnv.txt && env import -t ${env_addr} ${filesize}
   452    setenv bootargs ${APPEND}
   453    load ${devtype} ${devnum} ${kernel_addr} ${LINUX}
   454    load ${devtype} ${devnum} ${initrd_addr} ${INITRD}
   455    load ${devtype} ${devnum} ${dtb_addr} ${FDT}
   456    fdt addr ${dtb_addr}
   457    booti ${kernel_addr} ${initrd_addr} ${dtb_addr}
   458
   459    ### lsusb:
   460
   461    Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
   462    Bus 001 Device 003: ID 148f:7601 Ralink Technology, Corp. MT7601U Wireless Adapter
   463    Bus 001 Device 002: ID 05e3:0608 Genesys Logic, Inc. Hub
   464    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
   465
   466    ### lscpu:
   467
   468    Architecture:        aarch64
   469    Byte Order:          Little Endian
   470    CPU(s):              4
   471    On-line CPU(s) list: 0-3
   472    Thread(s) per core:  1
   473    Core(s) per socket:  4
   474    Socket(s):           1
   475    Vendor ID:           ARM
   476    Model:               4
   477    Model name:          Cortex-A53
   478    Stepping:            r0p4
   479    CPU max MHz:         1512,0000
   480    CPU min MHz:         100,0000
   481    BogoMIPS:            48.00
   482    L1d cache:           unknown size
   483    L1i cache:           unknown size
   484    L2 cache:            unknown size
   485    Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
   486
   487    ### cpuinfo:
   488
   489    processor    : 0
   490    model name    : ARMv8 Processor rev 4 (v8l)
   491    BogoMIPS    : 48.00
   492    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
   493    CPU implementer    : 0x41
   494    CPU architecture: 8
   495    CPU variant    : 0x0
   496    CPU part    : 0xd03
   497    CPU revision    : 4
   498
   499    processor    : 1
   500    model name    : ARMv8 Processor rev 4 (v8l)
   501    BogoMIPS    : 48.00
   502    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
   503    CPU implementer    : 0x41
   504    CPU architecture: 8
   505    CPU variant    : 0x0
   506    CPU part    : 0xd03
   507    CPU revision    : 4
   508
   509    processor    : 2
   510    model name    : ARMv8 Processor rev 4 (v8l)
   511    BogoMIPS    : 48.00
   512    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
   513    CPU implementer    : 0x41
   514    CPU architecture: 8
   515    CPU variant    : 0x0
   516    CPU part    : 0xd03
   517    CPU revision    : 4
   518
   519    processor    : 3
   520    model name    : ARMv8 Processor rev 4 (v8l)
   521    BogoMIPS    : 48.00
   522    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
   523    CPU implementer    : 0x41
   524    CPU architecture: 8
   525    CPU variant    : 0x0
   526    CPU part    : 0xd03
   527    CPU revision    : 4
   528
   529
   530    ### meminfo:
   531
   532    MemTotal:        1782968 kB
   533    MemFree:         1609176 kB
   534    MemAvailable:    1666708 kB
   535    Buffers:           11832 kB
   536    Cached:            54040 kB
   537    SwapCached:            0 kB
   538    Active:            52492 kB
   539    Inactive:          34792 kB
   540    Active(anon):      21768 kB
   541    Inactive(anon):     2588 kB
   542    Active(file):      30724 kB
   543    Inactive(file):    32204 kB
   544    Unevictable:           0 kB
   545    Mlocked:               0 kB
   546    SwapTotal:        891480 kB
   547    SwapFree:         891480 kB
   548    Dirty:               708 kB
   549    Writeback:             0 kB
   550    AnonPages:         21532 kB
   551    Mapped:            21964 kB
   552    Shmem:              2688 kB
   553    KReclaimable:      17720 kB
   554    Slab:              52844 kB
   555    SReclaimable:      17720 kB
   556    SUnreclaim:        35124 kB
   557    KernelStack:        2752 kB
   558    PageTables:         1452 kB
   559    NFS_Unstable:          0 kB
   560    Bounce:                0 kB
   561    WritebackTmp:          0 kB
   562    CommitLimit:     1782964 kB
   563    Committed_AS:      53988 kB
   564    VmallocTotal:   135290159040 kB
   565    VmallocUsed:       16696 kB
   566    VmallocChunk:          0 kB
   567    Percpu:             1264 kB
   568    CmaTotal:         262144 kB
   569    CmaFree:          258460 kB
   570    HugePages_Total:       0
   571    HugePages_Free:        0
   572    HugePages_Rsvd:        0
   573    HugePages_Surp:        0
   574    Hugepagesize:       2048 kB
   575    Hugetlb:               0 kB
   576
   577    ### virtual memory:
   578
   579    vm.admin_reserve_kbytes = 8192
   580    vm.block_dump = 0
   581    vm.compact_unevictable_allowed = 1
   582    vm.dirty_background_bytes = 0
   583    vm.dirty_background_ratio = 10
   584    vm.dirty_bytes = 0
   585    vm.dirty_expire_centisecs = 3000
   586    vm.dirty_ratio = 20
   587    vm.dirtytime_expire_seconds = 43200
   588    vm.dirty_writeback_centisecs = 500
   589    vm.extfrag_threshold = 500
   590    vm.hugetlb_shm_group = 0
   591    vm.laptop_mode = 0
   592    vm.legacy_va_layout = 0
   593    vm.lowmem_reserve_ratio = 256    256    32    0
   594    vm.max_map_count = 65530
   595    vm.min_free_kbytes = 4914
   596    vm.mmap_min_addr = 4096
   597    vm.mmap_rnd_bits = 18
   598    vm.nr_hugepages = 0
   599    vm.nr_overcommit_hugepages = 0
   600    vm.oom_dump_tasks = 1
   601    vm.oom_kill_allocating_task = 0
   602    vm.overcommit_kbytes = 0
   603    vm.overcommit_memory = 0
   604    vm.overcommit_ratio = 50
   605    vm.page-cluster = 0
   606    vm.panic_on_oom = 0
   607    vm.percpu_pagelist_fraction = 0
   608    vm.stat_interval = 1
   609    vm.swappiness = 100
   610    vm.user_reserve_kbytes = 55239
   611    vm.vfs_cache_pressure = 100
   612    vm.watermark_boost_factor = 15000
   613    vm.watermark_scale_factor = 10
   614
   615    ### ip addr:
   616
   617    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
   618        link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
   619        inet XXX.XXX.0.1/8 scope host lo
   620           valid_lft forever preferred_lft forever
   621        inet6 ::1/128 scope host
   622           valid_lft forever preferred_lft forever
   623    2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
   624        link/ether 00:df:06:00:00:0b brd ff:ff:ff:ff:ff:ff
   625    3: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
   626        link/ether 00:36:76:61:0b:24 brd ff:ff:ff:ff:ff:ff
   627
   628    ### partitions:
   629
   630    major minor  #blocks  name
   631
   632     179        0   30924800 mmcblk0
   633     179        1     262144 mmcblk0p1
   634     179        2   30337024 mmcblk0p2
   635     179       32   15384576 mmcblk1
   636     179      128       8192 mmcblk1gp0
   637     254        1     891484 zram1
   638
   639    ### df:
   640
   641    udev             738M      0  738M   0% /dev
   642    tmpfs            175M   2,7M  172M   2% /run
   643    /dev/mmcblk0p2    29G    10G   19G  36% /
   644    tmpfs            871M      0  871M   0% /dev/shm
   645    tmpfs            5,0M   4,0K  5,0M   1% /run/lock
   646    tmpfs            871M      0  871M   0% /sys/fs/cgroup
   647    tmpfs            871M      0  871M   0% /tmp
   648    /dev/mmcblk0p1   256M    76M  180M  30% /boot
   649
   650    ### lsblk:
   651
   652    NAME         FSTYPE   SIZE MOUNTPOINT UUID
   653    mmcblk0              29,5G
   654    ├─mmcblk0p1  vfat     256M /boot      50FC-6AC8
   655    └─mmcblk0p2  ext4      29G /          3e297ac1-e4e4-4ab1-bc57-47c07d0422ba
   656    mmcblk1              14,7G
   657    mmcblk1boot0            4M
   658    mmcblk1boot1            4M
   659    mmcblk1gp0              8M
   660
   661    ### zramctl:
   662
   663    NAME       ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT
   664    /dev/zram1 lzo         870,6M   4K   81B   12K       4 [SWAP]
   665
   666    ### mtab:
   667
   668    /dev/mmcblk0p1 /boot vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro 0 0
   669    /dev/mmcblk0p2 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
   670
   671    ### mmc0:59b4 info:
   672
   673                   fwrev: 0x0
   674                  uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SDU1  MODALIAS=mmc:block
   675                     cid: 1b534d53445531201014a136d4013800
   676                     rca: 0x59b4
   677                     csd: 400e00325b590000ebef7f800a400000
   678                  manfid: 0x00001b
   679                     ocr: 0x00200000
   680    preferred_erase_size: 4194304
   681                    type: SD
   682                   hwrev: 0x1
   683                    date: 08/2019
   684                     dsr: 0x404
   685              erase_size: 512
   686                   oemid: 0x534d
   687                  serial: 0x14a136d4
   688                     ssr: 0000000005000000040090000811391e00089a342f01000000000000000000000000000000000000000000000000000000000000000000000000000000000000
   689                     scr: 0235844300000000
   690                    name: SDU1
   691
   692    ### mmc1:0001 info:
   693
   694                   fwrev: 0x0
   695                  uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=016G92 MODALIAS=mmc:block
   696                     cid: 11010030313647393201d3d1a4db1100
   697             rel_sectors: 0x10
   698                     rca: 0x0001
   699            pre_eol_info: 0x00
   700                     csd: d00e00320f5903ffffffffef92400000
   701                  manfid: 0x000011
   702                     ocr: 0x00200000
   703    preferred_erase_size: 4194304
   704    enhanced_area_offset: 18446744073709551594
   705      raw_rpmb_size_mult: 0x4
   706                    type: MMC
   707                   hwrev: 0x0
   708                    date: 01/2014
   709                     prv: 0x1
   710             ffu_capable: 0
   711                     dsr: 0x404
   712              erase_size: 4194304
   713               life_time: 0x00 0x00
   714      enhanced_area_size: 4294967274
   715                   oemid: 0x0100
   716                  serial: 0xd3d1a4db
   717                 cmdq_en: 0
   718                     rev: 0x6
   719                    name: 016G92
   720
   721    ### Boot system health:
   722
   723    Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU
   724    00:17:34: 1512MHz  0.39  52%  24%  15%   0%  11%   1% 41.0°C
   725    00:17:34: 1512MHz  0.39  73%  11%  18%   1%  40%   2% 42.0°C
   726    00:17:34: 1512MHz  0.39  68%  13%  20%   1%  31%   2% 41.0°C
   727    00:17:35: 1512MHz  0.39  52%   7%  11%   0%  30%   1% 41.0°C
   728    00:17:35: 1512MHz  0.39  42%   8%   8%   0%  23%   1% 40.0°C
   729
   730    ### Activated 1 lzo zram swap devices with 870 MB each
   731
   732
   733    lun mar 22 07:51:53 CET 2021 | AML-S9xxx | 20.02.0-rc1.037 | arm64 | aarch64 | 5.5.0-rc6-aml-s9xxx
   734
   735    ### dmesg:
   736
   737    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
   738    [    0.000000] Linux version 5.5.0-rc6-aml-s9xxx (root@vbox) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #rc1.037 SMP PREEMPT Wed Feb 5 15:59:04 MSK 2020
   739    [    0.000000] Machine model: Amlogic Meson GXL (S905X) P212 Development Board
   740    [    0.000000] efi: Getting EFI parameters from FDT:
   741    [    0.000000] efi: UEFI not found.
   742    [    0.000000] Reserved memory: created CMA memory pool at 0x0000000063400000, size 256 MiB
   743    [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
   744    [    0.000000] On node 0 totalpages: 477952
   745    [    0.000000]   DMA zone: 4032 pages used for memmap
   746    [    0.000000]   DMA zone: 0 pages reserved
   747    [    0.000000]   DMA zone: 248576 pages, LIFO batch:63
   748    [    0.000000]   DMA32 zone: 3584 pages used for memmap
   749    [    0.000000]   DMA32 zone: 229376 pages, LIFO batch:63
   750    [    0.000000] psci: probing for conduit method from DT.
   751    [    0.000000] psci: PSCIv0.2 detected in firmware.
   752    [    0.000000] psci: Using standard PSCI v0.2 function IDs
   753    [    0.000000] psci: Trusted OS migration not required
   754    [    0.000000] percpu: Embedded 22 pages/cpu s50392 r8192 d31528 u90112
   755    [    0.000000] pcpu-alloc: s50392 r8192 d31528 u90112 alloc=22*4096
   756    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
   757    [    0.000000] Detected VIPT I-cache on CPU0
   758    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 470336
   759    [    0.000000] Kernel command line: root=LABEL=ROOTFS rootflags=data=writeback rw console=ttyAML0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 mac=00:df:06:00:00:0b
   760    [    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
   761    [    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
   762    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
   763    [    0.000000] software IO TLB: mapped [mem 0x3bfff000-0x3ffff000] (64MB)
   764    [    0.000000] Memory: 1509616K/1911808K available (14460K kernel code, 1434K rwdata, 5884K rodata, 960K init, 927K bss, 140048K reserved, 262144K cma-reserved)
   765    [    0.000000] random: get_random_u64 called from cache_random_seq_create+0x7c/0x150 with crng_init=0
   766    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
   767    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
   768    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
   769    [    0.000000]     Tasks RCU enabled.
   770    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
   771    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
   772    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
   773    [    0.000000] GIC: Using split EOI/Deactivate mode
   774    [    0.000000] irq_meson_gpio: 110 to 8 gpio interrupt mux initialized
   775    [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
   776    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
   777    [    0.000003] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
   778    [    0.000352] Console: colour dummy device 80x25
   779    [    0.000652] printk: console [tty0] enabled
   780    [    0.000691] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
   781    [    0.000712] pid_max: default: 32768 minimum: 301
   782    [    0.000839] LSM: Security Framework initializing
   783    [    0.000889] SELinux:  Initializing.
   784    [    0.000967] *** VALIDATE SELinux ***
   785    [    0.001034] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
   786    [    0.001060] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
   787    [    0.001124] *** VALIDATE tmpfs ***
   788    [    0.001535] *** VALIDATE proc ***
   789    [    0.001758] *** VALIDATE cgroup1 ***
   790    [    0.001773] *** VALIDATE cgroup2 ***
   791    [    0.024017] ASID allocator initialised with 32768 entries
   792    [    0.031999] rcu: Hierarchical SRCU implementation.
   793    [    0.042089] EFI services will not be available.
   794    [    0.048056] smp: Bringing up secondary CPUs ...
   795    [    0.080285] Detected VIPT I-cache on CPU1
   796    [    0.080339] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
   797    [    0.112330] Detected VIPT I-cache on CPU2
   798    [    0.112377] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
   799    [    0.144374] Detected VIPT I-cache on CPU3
   800    [    0.144416] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
   801    [    0.144493] smp: Brought up 1 node, 4 CPUs
   802    [    0.144560] SMP: Total of 4 processors activated.
   803    [    0.144572] CPU features: detected: 32-bit EL0 Support
   804    [    0.144584] CPU features: detected: CRC32 instructions
   805    [    0.144887] CPU: All CPU(s) started at EL2
   806    [    0.144910] alternatives: patching kernel code
   807    [    0.146010] devtmpfs: initialized
   808    [    0.151131] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
   809    [    0.151173] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
   810    [    0.157999] xor: measuring software checksum speed
   811    [    0.196369]    8regs     :  2374.000 MB/sec
   812    [    0.236401]    32regs    :  2724.000 MB/sec
   813    [    0.276439]    arm64_neon:  2406.000 MB/sec
   814    [    0.276449] xor: using function: 32regs (2724.000 MB/sec)
   815    [    0.276505] pinctrl core: initialized pinctrl subsystem
   816    [    0.277159] thermal_sys: Registered thermal governor 'step_wise'
   817    [    0.277328] DMI not present or invalid.
   818    [    0.277690] NET: Registered protocol family 16
   819    [    0.281245] DMA: preallocated 256 KiB pool for atomic allocations
   820    [    0.281296] audit: initializing netlink subsys (disabled)
   821    [    0.281507] audit: type=2000 audit(0.280:1): state=initialized audit_enabled=0 res=1
   822    [    0.282585] cpuidle: using governor ladder
   823    [    0.282626] cpuidle: using governor menu
   824    [    0.282996] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
   825    [    0.283719] Serial: AMBA PL011 UART driver
   826    [    0.297732] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
   827    [    0.297758] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
   828    [    0.297771] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
   829    [    0.297784] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
   830    [    0.301432] cryptd: max_cpu_qlen set to 1000
   831    [    0.376690] raid6: neonx8   gen()  1616 MB/s
   832    [    0.444714] raid6: neonx8   xor()  1491 MB/s
   833    [    0.512772] raid6: neonx4   gen()  1564 MB/s
   834    [    0.580828] raid6: neonx4   xor()  1471 MB/s
   835    [    0.648908] raid6: neonx2   gen()  1201 MB/s
   836    [    0.716919] raid6: neonx2   xor()  1216 MB/s
   837    [    0.785015] raid6: neonx1   gen()   788 MB/s
   838    [    0.853082] raid6: neonx1   xor()   915 MB/s
   839    [    0.921130] raid6: int64x8  gen()  1195 MB/s
   840    [    0.989152] raid6: int64x8  xor()   769 MB/s
   841    [    1.057214] raid6: int64x4  gen()  1029 MB/s
   842    [    1.125269] raid6: int64x4  xor()   752 MB/s
   843    [    1.193304] raid6: int64x2  gen()   728 MB/s
   844    [    1.261341] raid6: int64x2  xor()   615 MB/s
   845    [    1.329490] raid6: int64x1  gen()   486 MB/s
   846    [    1.397458] raid6: int64x1  xor()   467 MB/s
   847    [    1.397469] raid6: using algorithm neonx8 gen() 1616 MB/s
   848    [    1.397479] raid6: .... xor() 1491 MB/s, rmw enabled
   849    [    1.397489] raid6: using neon recovery algorithm
   850    [    1.397731] ACPI: Interpreter disabled.
   851    [    1.398932] iommu: Default domain type: Translated
   852    [    1.399201] vgaarb: loaded
   853    [    1.399747] SCSI subsystem initialized
   854    [    1.399919] libata version 3.00 loaded.
   855    [    1.400129] usbcore: registered new interface driver usbfs
   856    [    1.400176] usbcore: registered new interface driver hub
   857    [    1.400238] usbcore: registered new device driver usb
   858    [    1.400648] pps_core: LinuxPPS API ver. 1 registered
   859    [    1.400660] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
   860    [    1.400685] PTP clock support registered
   861    [    1.400712] EDAC MC: Ver: 3.0.0
   862    [    1.401285] FPGA manager framework
   863    [    1.401409] Advanced Linux Sound Architecture Driver Initialized.
   864    [    1.401874] NetLabel: Initializing
   865    [    1.401887] NetLabel:  domain hash size = 128
   866    [    1.401896] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
   867    [    1.401950] NetLabel:  unlabeled traffic allowed by default
   868    [    1.402425] clocksource: Switched to clocksource arch_sys_counter
   869    [    1.402448] *** VALIDATE bpf ***
   870    [    1.402705] VFS: Disk quotas dquot_6.6.0
   871    [    1.402767] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
   872    [    1.402895] FS-Cache: Loaded
   873    [    1.402906] *** VALIDATE ramfs ***
   874    [    1.402927] *** VALIDATE hugetlbfs ***
   875    [    1.403302] pnp: PnP ACPI: disabled
   876    [    1.408331] NET: Registered protocol family 2
   877    [    1.408830] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
   878    [    1.408878] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
   879    [    1.408995] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
   880    [    1.409209] TCP: Hash tables configured (established 16384 bind 16384)
   881    [    1.409363] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
   882    [    1.409419] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
   883    [    1.409636] NET: Registered protocol family 1
   884    [    1.410100] RPC: Registered named UNIX socket transport module.
   885    [    1.410122] RPC: Registered udp transport module.
   886    [    1.410131] RPC: Registered tcp transport module.
   887    [    1.410140] RPC: Registered tcp NFSv4.1 backchannel transport module.
   888    [    1.410157] NET: Registered protocol family 44
   889    [    1.410178] PCI: CLS 0 bytes, default 64
   890    [    1.410379] Trying to unpack rootfs image as initramfs...
   891    [    1.872010] Freeing initrd memory: 10248K
   892    [    1.872812] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
   893    [    2.086312] Initialise system trusted keyrings
   894    [    2.086627] workingset: timestamp_bits=46 max_order=19 bucket_order=0
   895    [    2.091819] zbud: loaded
   896    [    2.093042] squashfs: version 4.0 (2009/01/31) Phillip Lougher
   897    [    2.093345] FS-Cache: Netfs 'nfs' registered for caching
   898    [    2.093872] NFS: Registering the id_resolver key type
   899    [    2.093909] Key type id_resolver registered
   900    [    2.093919] Key type id_legacy registered
   901    [    2.093935] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
   902    [    2.093947] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
   903    [    2.095154] FS-Cache: Netfs 'cifs' registered for caching
   904    [    2.095485] Key type cifs.spnego registered
   905    [    2.095509] Key type cifs.idmap registered
   906    [    2.095533] ntfs: driver 2.1.32 [Flags: R/W].
   907    [    2.096106] JFS: nTxBlock = 8192, nTxLock = 65536
   908    [    2.101997] SGI XFS with ACLs, security attributes, realtime, quota, no debug enabled
   909    [    2.103440] *** VALIDATE xfs ***
   910    [    2.103744] ocfs2: Registered cluster interface o2cb
   911    [    2.103958] OCFS2 User DLM kernel interface loaded
   912    [    2.105359] *** VALIDATE gfs2 ***
   913    [    2.105638] gfs2: GFS2 installed
   914    [    2.106589] aufs 5.5-20200203
   915    [    2.126560] Key type asymmetric registered
   916    [    2.126586] Asymmetric key parser 'x509' registered
   917    [    2.126597] Asymmetric key parser 'pkcs8' registered
   918    [    2.126668] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
   919    [    2.126849] io scheduler mq-deadline registered
   920    [    2.126864] io scheduler kyber registered
   921    [    2.127062] io scheduler bfq registered
   922    [    2.139630] soc soc0: Amlogic Meson GXL (S905X) Revision 21:b (82:2) Detected
   923    [    2.143192] Serial: 8250/16550 driver, 5 ports, IRQ sharing enabled
   924    [    2.144887] Serial: AMBA driver
   925    [    2.145264] c11084c0.serial: ttyAML6 at MMIO 0xc11084c0 (irq = 10, base_baud = 1500000) is a meson_uart
   926    [    2.145418] serial serial0: tty port ttyAML6 registered
   927    [    2.145624] c81004c0.serial: ttyAML0 at MMIO 0xc81004c0 (irq = 13, base_baud = 1500000) is a meson_uart
   928    [    3.121095] printk: console [ttyAML0] enabled
   929    [    3.137297] brd: module loaded
   930    [    3.145834] loop: module loaded
   931    [    3.148342] libphy: Fixed MDIO Bus: probed
   932    [    3.148995] meson8b-dwmac c9410000.ethernet: IRQ eth_wake_irq not found
   933    [    3.154017] meson8b-dwmac c9410000.ethernet: IRQ eth_lpi not found
   934    [    3.160208] meson8b-dwmac c9410000.ethernet: PTP uses main clock
   935    [    3.166067] meson8b-dwmac c9410000.ethernet: no reset control found
   936    [    3.172770] meson8b-dwmac c9410000.ethernet: User ID: 0x11, Synopsys ID: 0x37
   937    [    3.179368] meson8b-dwmac c9410000.ethernet:     DWMAC1000
   938    [    3.184536] meson8b-dwmac c9410000.ethernet: DMA HW capability register supported
   939    [    3.191936] meson8b-dwmac c9410000.ethernet: RX Checksum Offload Engine supported
   940    [    3.199353] meson8b-dwmac c9410000.ethernet: COE Type 2
   941    [    3.204525] meson8b-dwmac c9410000.ethernet: TX Checksum insertion supported
   942    [    3.211512] meson8b-dwmac c9410000.ethernet: Wake-Up On Lan supported
   943    [    3.217926] meson8b-dwmac c9410000.ethernet: Normal descriptors
   944    [    3.223761] meson8b-dwmac c9410000.ethernet: Ring mode enabled
   945    [    3.229538] meson8b-dwmac c9410000.ethernet: Enable RX Mitigation via HW Watchdog Timer
   946    [    3.237657] libphy: stmmac: probed
   947    [    3.242136] VFIO - User Level meta-driver version: 0.3
   948    [    3.247535] dwc3 c9000000.dwc3: Failed to get clk 'ref': -2
   949    [    3.252355] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
   950    [    3.257953] ehci-pci: EHCI PCI platform driver
   951    [    3.262382] ehci-platform: EHCI generic platform driver
   952    [    3.267684] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
   953    [    3.273628] ohci-pci: OHCI PCI platform driver
   954    [    3.278062] ohci-platform: OHCI generic platform driver
   955    [    3.283803] usbcore: registered new interface driver usb-storage
   956    [    3.289403] mousedev: PS/2 mouse device common for all mice
   957    [    3.295322] i2c /dev entries driver
   958    [    3.300958] sdhci: Secure Digital Host Controller Interface driver
   959    [    3.304247] sdhci: Copyright(c) Pierre Ossman
   960    [    3.308564] Synopsys Designware Multimedia Card Interface Driver
   961    [    3.315853] meson-gx-mmc d0072000.mmc: Got CD GPIO
   962    [    3.346332] meson-gx-mmc d0074000.mmc: allocated mmc-pwrseq
   963    [    3.377634] sdhci-pltfm: SDHCI platform and OF driver helper
   964    [    3.378540] ledtrig-cpu: registered to indicate activity on CPUs
   965    [    3.384520] meson-sm: secure-monitor enabled
   966    [    3.388582] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
   967    [    3.395889] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
   968    [    3.403825] mmc0: new high speed SDHC card at address 59b4
   969    [    3.413773] mmcblk0: mmc0:59b4 SDU1  29.5 GiB
   970    [    3.420178]  mmcblk0: p1 p2
   971    [    3.421997] hid: raw HID events driver (C) Jiri Kosina
   972    [    3.422720] usbcore: registered new interface driver usbhid
   973    [    3.428044] usbhid: USB HID core driver
   974    [    3.432131] platform-mhu c883c404.mailbox: Platform MHU Mailbox registered
   975    [    3.448747] NET: Registered protocol family 17
   976    [    3.449007] Key type dns_resolver registered
   977    [    3.452350] registered taskstats version 1
   978    [    3.455966] Loading compiled-in X.509 certificates
   979    [    3.460733] zswap: loaded using pool lzo/zbud
   980    [    3.465113] Key type ._fscrypt registered
   981    [    3.468949] Key type .fscrypt registered
   982    [    3.474301] Btrfs loaded, crc32c=crc32c-generic
   983    [    3.493643] mmc1: new HS200 MMC card at address 0001
   984    [    3.494529] mmcblk1: mmc1:0001 016G92 14.7 GiB
   985    [    3.497803] mmcblk1boot0: mmc1:0001 016G92 partition 1 4.00 MiB
   986    [    3.503797] mmcblk1boot1: mmc1:0001 016G92 partition 2 4.00 MiB
   987    [    3.506370] Key type encrypted registered
   988    [    3.509660] mmcblk1gp0: mmc1:0001 016G92 partition 4 8.00 MiB
   989    [    3.519153] mmcblk1rpmb: mmc1:0001 016G92 partition 3 512 KiB, chardev (243:0)
   990    [    3.532427] meson-drm d0100000.vpu: Queued 3 outputs on vpu
   991    [    3.532743] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
   992    [    3.538984] [drm] No driver support for vblank timestamp query.
   993    [    3.570490] meson-dw-hdmi c883a000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
   994    [    3.575196] meson-dw-hdmi c883a000.hdmi-tx: registered DesignWare HDMI I2C bus driver
   995    [    3.583155] meson-drm d0100000.vpu: bound c883a000.hdmi-tx (ops meson_dw_hdmi_ops)
   996    [    3.590506] [drm] Initialized meson 1.0.0 20161109 for d0100000.vpu on minor 0
   997    [    3.630979] Console: switching to colour frame buffer device 90x36
   998    [    3.651200] meson-drm d0100000.vpu: fb0: mesondrmfb frame buffer device
   999    [    3.658507] libphy: mdio_mux: probed
  1000    [    3.668973] libphy: mdio_mux: probed
  1001    [    3.669458] phy phy-d0078080.phy.2: unsupported PHY mode 5
  1002    [    3.674512] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  1003    [    3.677904] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
  1004    [    3.685612] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228f664 hci version 0x100 quirks 0x0000000002010010
  1005    [    3.694851] xhci-hcd xhci-hcd.0.auto: irq 39, io mem 0xc9000000
  1006    [    3.700956] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.05
  1007    [    3.709197] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1008    [    3.716338] usb usb1: Product: xHCI Host Controller
  1009    [    3.721166] usb usb1: Manufacturer: Linux 5.5.0-rc6-aml-s9xxx xhci-hcd
  1010    [    3.727638] usb usb1: SerialNumber: xhci-hcd.0.auto
  1011    [    3.732971] hub 1-0:1.0: USB hub found
  1012    [    3.736213] hub 1-0:1.0: 2 ports detected
  1013    [    3.740438] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  1014    [    3.745593] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
  1015    [    3.753190] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
  1016    [    3.759700] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
  1017    [    3.767965] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.05
  1018    [    3.776351] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1019    [    3.783507] usb usb2: Product: xHCI Host Controller
  1020    [    3.788342] usb usb2: Manufacturer: Linux 5.5.0-rc6-aml-s9xxx xhci-hcd
  1021    [    3.794807] usb usb2: SerialNumber: xhci-hcd.0.auto
  1022    [    3.800115] hub 2-0:1.0: USB hub found
  1023    [    3.803403] hub 2-0:1.0: config failed, hub doesn't have any ports! (err -19)
  1024    [    3.812210] meson-gx-mmc d0070000.mmc: allocated mmc-pwrseq
  1025    [    3.843436] scpi_protocol scpi: SCP Protocol legacy pre-1.0 firmware
  1026    [    3.860258] gx-sound-card sound: snd-soc-dummy-dai <-> c1105400.bus:audio-controller-0 mapping ok
  1027    [    3.871992] gx-sound-card sound: i2s-hifi <-> c1105400.bus:audio-controller-2 mapping ok
  1028    [    3.879733] gx-sound-card sound: ASoC: no DMI vendor name!
  1029    [    3.885968] printk: console [netcon0] enabled
  1030    [    3.889354] netconsole: network logging started
  1031    [    3.893810] hctosys: unable to open rtc device (rtc0)
  1032    [    3.896612] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
  1033    [    3.899028] ALSA device list:
  1034    [    3.907276]   #0: AMLGX
  1035    [    3.907521] mmc2: queuing unknown CIS tuple 0x80 (6 bytes)
  1036    [    3.915566] Freeing unused kernel memory: 960K
  1037    [    3.919452] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
  1038    [    3.919780] Run /init as init process
  1039    [    3.934273] mmc2: queuing unknown CIS tuple 0x80 (19 bytes)
  1040    [    3.961260] random: fast init done
  1041    [    4.017177] mmc2: new high speed SDIO card at address 0001
  1042    [    4.074520] usb 1-1: new high-speed USB device number 2 using xhci-hcd
  1043    [    4.095825] usb 1-1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.36
  1044    [    4.103271] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
  1045    [    4.110059] usb 1-1: Product: USB2.0 Hub
  1046    [    4.176186] hub 1-1:1.0: USB hub found
  1047    [    4.178935] hub 1-1:1.0: 4 ports detected
  1048    [    4.310488] usb 1-2: new high-speed USB device number 3 using xhci-hcd
  1049    [    4.340923] usb 1-2: New USB device found, idVendor=148f, idProduct=7601, bcdDevice= 0.00
  1050    [    4.348279] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
  1051    [    4.357563] usb 1-2: Product: 802.11 n WLAN
  1052    [    4.361305] usb 1-2: Manufacturer: MediaTek
  1053    [    4.364631] usb 1-2: SerialNumber: 1.0
  1054    [    5.096209] EXT4-fs (mmcblk0p2): mounted filesystem with writeback data mode. Opts: data=writeback
  1055    [    6.061107] systemd[1]: System time before build time, advancing clock.
  1056    [    6.207418] NET: Registered protocol family 10
  1057    [    6.281144] Segment Routing with IPv6
  1058    [    6.332035] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
  1059    [    6.365245] systemd[1]: Detected architecture arm64.
  1060    [    6.423428] systemd[1]: Set hostname to <mxqpro>.
  1061    [    6.457238] systemd[1]: Couldn't move remaining userspace processes, ignoring: Input/output error
  1062    [    7.168006] random: systemd: uninitialized urandom read (16 bytes read)
  1063    [    7.181362] random: systemd: uninitialized urandom read (16 bytes read)
  1064    [    7.185655] systemd[1]: Listening on udev Control Socket.
  1065    [    7.193341] random: systemd: uninitialized urandom read (16 bytes read)
  1066    [    7.200119] systemd[1]: Created slice system-systemd\x2dfsck.slice.
  1067    [    7.206197] systemd[1]: Reached target System Time Synchronized.
  1068    [    7.212326] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
  1069    [    7.220700] systemd[1]: Listening on Syslog Socket.
  1070    [    7.226206] systemd[1]: Condition check resulted in Arbitrary Executable File Formats File System Automount Point being skipped.
  1071    [    7.400684] EXT4-fs (mmcblk0p2): re-mounted. Opts: commit=600,errors=remount-ro
  1072    [    7.653696] systemd-journald[414]: Received request to flush runtime journal from PID 1
  1073    [    8.127667] mc: Linux media interface: v0.10
  1074    [    8.150658] videodev: Linux video capture interface: v2.00
  1075    [    8.190007] Registered IR keymap rc-empty
  1076    [    8.193464] rc rc0: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0
  1077    [    8.193567] input: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0/input0
  1078    [    8.196518] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
  1079    [    8.217739] meson-ir c8100580.ir: receiver initialized
  1080    [    8.256211] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
  1081    [    8.362349] Bluetooth: Core ver 2.22
  1082    [    8.364934] NET: Registered protocol family 31
  1083    [    8.368059] Bluetooth: HCI device and connection manager initialized
  1084    [    8.373468] Bluetooth: HCI socket layer initialized
  1085    [    8.378267] Bluetooth: L2CAP socket layer initialized
  1086    [    8.383632] lima d00c0000.gpu: IRQ ppmmu3 not found
  1087    [    8.388076] lima d00c0000.gpu: IRQ ppmmu4 not found
  1088    [    8.396142] lima d00c0000.gpu: IRQ ppmmu5 not found
  1089    [    8.398402] lima d00c0000.gpu: IRQ ppmmu6 not found
  1090    [    8.402910] Bluetooth: SCO socket layer initialized
  1091    [    8.406027] lima d00c0000.gpu: IRQ ppmmu7 not found
  1092    [    8.414208] lima d00c0000.gpu: gp - mali450 version major 0 minor 0
  1093    [    8.421823] lima d00c0000.gpu: pp0 - mali450 version major 0 minor 0
  1094    [    8.427037] lima d00c0000.gpu: pp1 - mali450 version major 0 minor 0
  1095    [    8.435164] lima d00c0000.gpu: pp2 - mali450 version major 0 minor 0
  1096    [    8.438062] lima d00c0000.gpu: IRQ pp3 not found
  1097    [    8.442570] lima d00c0000.gpu: IRQ pp4 not found
  1098    [    8.447234] lima d00c0000.gpu: IRQ pp5 not found
  1099    [    8.458533] lima d00c0000.gpu: IRQ pp6 not found
  1100    [    8.460376] lima d00c0000.gpu: IRQ pp7 not found
  1101    [    8.464141] lima d00c0000.gpu: l2 cache 8K, 4-way, 64byte cache line, 128bit external bus
  1102    [    8.472238] lima d00c0000.gpu: l2 cache 64K, 4-way, 64byte cache line, 128bit external bus
  1103    [    8.481502] lima d00c0000.gpu: bus rate = 166666667
  1104    [    8.485293] lima d00c0000.gpu: mod rate = 744000000
  1105    [    8.490607] [drm] Initialized lima 1.0.0 20190217 for d00c0000.gpu on minor 1
  1106    [    8.605049] Bluetooth: HCI UART driver ver 2.3
  1107    [    8.611953] Bluetooth: HCI UART protocol H4 registered
  1108    [    8.613635] Bluetooth: HCI UART protocol BCSP registered
  1109    [    8.626129] Bluetooth: HCI UART protocol LL registered
  1110    [    8.628225] Bluetooth: HCI UART protocol ATH3K registered
  1111    [    8.638573] Bluetooth: HCI UART protocol Three-wire (H5) registered
  1112    [    8.641023] Bluetooth: HCI UART protocol Intel registered
  1113    [    8.647141] Bluetooth: HCI UART protocol Broadcom registered
  1114    [    8.647275] hci_uart_bcm serial0-0: serial0-0 supply vbat not found, using dummy regulator
  1115    [    8.649068] cfg80211: Loading compiled-in X.509 certificates for regulatory database
  1116    [    8.658160] Bluetooth: HCI UART protocol QCA registered
  1117    [    8.666731] hci_uart_bcm serial0-0: serial0-0 supply vddio not found, using dummy regulator
  1118    [    8.672767] Bluetooth: HCI UART protocol AG6XX registered
  1119    [    8.672863] Bluetooth: HCI UART protocol Marvell registered
  1120    [    8.711963] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
  1121    [    8.715916] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
  1122    [    8.724809] cfg80211: failed to load regulatory.db
  1123    [    8.855376] brcmfmac: F1 signature read @0x18000000=0x16034334
  1124    [    8.862780] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4334-sdio for chip BCM4334/3
  1125    [    8.870669] usbcore: registered new interface driver brcmfmac
  1126    [    8.907337] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.amlogic,p212.txt failed with error -2
  1127    [    8.917543] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.txt failed with error -2
  1128    [    8.966861] usb 1-2: reset high-speed USB device number 3 using xhci-hcd
  1129    [    8.990168] mt7601u 1-2:1.0: ASIC revision: 76010001 MAC revision: 76010500
  1130    [    9.020609] mt7601u 1-2:1.0: EEPROM ver:0d fae:00
  1131    [    9.087757] Bluetooth: hci0: BCM: chip id 68
  1132    [    9.091308] Bluetooth: hci0: BCM: features 0x0f
  1133    [    9.093032] Bluetooth: hci0: BCM4334B0
  1134    [    9.097456] Bluetooth: hci0: BCM4334B0 (002.001.013) build 0000
  1135    [    9.097567] bluetooth hci0: Direct firmware load for brcm/BCM4334B0.hcd failed with error -2
  1136    [    9.111747] Bluetooth: hci0: BCM: Patch brcm/BCM4334B0.hcd not found
  1137    [    9.225190] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
  1138    [    9.226144] usbcore: registered new interface driver mt7601u
  1139    [    9.934519] brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x50
  1140    [   10.054188] zram: Added device: zram0
  1141    [   10.057679] zram: Added device: zram1
  1142    [   10.064074] zram: Added device: zram2
  1143    [   10.097602] meson8b-dwmac c9410000.ethernet eth0: PHY [0.e40908ff:08] driver [Meson GXL Internal PHY]
  1144    [   10.117679] zram1: detected capacity change from 0 to 912879616
  1145    [   10.122547] meson8b-dwmac c9410000.ethernet eth0: No Safety Features support found
  1146    [   10.128700] meson8b-dwmac c9410000.ethernet eth0: PTP not supported by HW
  1147    [   10.134755] meson8b-dwmac c9410000.ethernet eth0: configuring for phy/rmii link mode
  1148    [   10.792532] random: crng init done
  1149    [   10.795025] random: 7 urandom warning(s) missed due to ratelimiting
  1150    [   10.962942] Adding 891480k swap on /dev/zram1.  Priority:5 extents:1 across:891480k SSFS
  1151
  1152    ### armbian-release:
  1153
  1154    # PLEASE DO NOT EDIT THIS FILE
  1155    BOARD=aml-s9xxx
  1156    BOARD_NAME="AML-S9xxx"
  1157    BOARDFAMILY=aml-s9xxx
  1158    BUILD_REPOSITORY_URL=https://github.com/150balbes/Build-Armbian.git
  1159    BUILD_REPOSITORY_COMMIT=62b8c07-dirty
  1160    DISTRIBUTION_CODENAME=buster
  1161    DISTRIBUTION_STATUS=supported
  1162    VERSION=20.02.0-rc1.037
  1163    LINUXFAMILY=aml-s9xxx
  1164    BRANCH=current
  1165    ARCH=arm64
  1166    IMAGE_TYPE=nightly
  1167    BOARD_TYPE=conf
  1168    INITRD_ARCH=arm64
  1169    KERNEL_IMAGE_TYPE=Image
  1170
  1171    ### boot environment:
  1172
  1173    ODROIDN2-UBOOT-CONFIG
  1174    setenv env_addr 0x10400000
  1175    setenv kernel_addr 0x11000000
  1176    setenv initrd_addr 0x13000000
  1177    setenv dtb_addr 0x1000000
  1178    if test "${devtype}" = ""; then setenv devtype "mmc"; fi
  1179    load ${devtype} ${devnum} ${env_addr} uEnv.txt && env import -t ${env_addr} ${filesize}
  1180    setenv bootargs ${APPEND}
  1181    load ${devtype} ${devnum} ${kernel_addr} ${LINUX}
  1182    load ${devtype} ${devnum} ${initrd_addr} ${INITRD}
  1183    load ${devtype} ${devnum} ${dtb_addr} ${FDT}
  1184    fdt addr ${dtb_addr}
  1185    booti ${kernel_addr} ${initrd_addr} ${dtb_addr}
  1186
  1187    ### lsusb:
  1188
  1189    Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
  1190    Bus 001 Device 003: ID 148f:7601 Ralink Technology, Corp. MT7601U Wireless Adapter
  1191    Bus 001 Device 002: ID 05e3:0608 Genesys Logic, Inc. Hub
  1192    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  1193
  1194    ### lscpu:
  1195
  1196    Architecture:        aarch64
  1197    Byte Order:          Little Endian
  1198    CPU(s):              4
  1199    On-line CPU(s) list: 0-3
  1200    Thread(s) per core:  1
  1201    Core(s) per socket:  4
  1202    Socket(s):           1
  1203    Vendor ID:           ARM
  1204    Model:               4
  1205    Model name:          Cortex-A53
  1206    Stepping:            r0p4
  1207    CPU max MHz:         1512,0000
  1208    CPU min MHz:         100,0000
  1209    BogoMIPS:            48.00
  1210    L1d cache:           unknown size
  1211    L1i cache:           unknown size
  1212    L2 cache:            unknown size
  1213    Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1214
  1215    ### cpuinfo:
  1216
  1217    processor    : 0
  1218    model name    : ARMv8 Processor rev 4 (v8l)
  1219    BogoMIPS    : 48.00
  1220    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1221    CPU implementer    : 0x41
  1222    CPU architecture: 8
  1223    CPU variant    : 0x0
  1224    CPU part    : 0xd03
  1225    CPU revision    : 4
  1226
  1227    processor    : 1
  1228    model name    : ARMv8 Processor rev 4 (v8l)
  1229    BogoMIPS    : 48.00
  1230    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1231    CPU implementer    : 0x41
  1232    CPU architecture: 8
  1233    CPU variant    : 0x0
  1234    CPU part    : 0xd03
  1235    CPU revision    : 4
  1236
  1237    processor    : 2
  1238    model name    : ARMv8 Processor rev 4 (v8l)
  1239    BogoMIPS    : 48.00
  1240    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1241    CPU implementer    : 0x41
  1242    CPU architecture: 8
  1243    CPU variant    : 0x0
  1244    CPU part    : 0xd03
  1245    CPU revision    : 4
  1246
  1247    processor    : 3
  1248    model name    : ARMv8 Processor rev 4 (v8l)
  1249    BogoMIPS    : 48.00
  1250    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1251    CPU implementer    : 0x41
  1252    CPU architecture: 8
  1253    CPU variant    : 0x0
  1254    CPU part    : 0xd03
  1255    CPU revision    : 4
  1256
  1257
  1258    ### meminfo:
  1259
  1260    MemTotal:        1782968 kB
  1261    MemFree:         1610664 kB
  1262    MemAvailable:    1665824 kB
  1263    Buffers:           11472 kB
  1264    Cached:            52268 kB
  1265    SwapCached:            0 kB
  1266    Active:            50352 kB
  1267    Inactive:          33304 kB
  1268    Active(anon):      20552 kB
  1269    Inactive(anon):     2580 kB
  1270    Active(file):      29800 kB
  1271    Inactive(file):    30724 kB
  1272    Unevictable:           0 kB
  1273    Mlocked:               0 kB
  1274    SwapTotal:        891480 kB
  1275    SwapFree:         891480 kB
  1276    Dirty:               520 kB
  1277    Writeback:             0 kB
  1278    AnonPages:         20500 kB
  1279    Mapped:            21228 kB
  1280    Shmem:              2684 kB
  1281    KReclaimable:      17752 kB
  1282    Slab:              54268 kB
  1283    SReclaimable:      17752 kB
  1284    SUnreclaim:        36516 kB
  1285    KernelStack:        2780 kB
  1286    PageTables:         1568 kB
  1287    NFS_Unstable:          0 kB
  1288    Bounce:                0 kB
  1289    WritebackTmp:          0 kB
  1290    CommitLimit:     1782964 kB
  1291    Committed_AS:      77144 kB
  1292    VmallocTotal:   135290159040 kB
  1293    VmallocUsed:       16724 kB
  1294    VmallocChunk:          0 kB
  1295    Percpu:             1312 kB
  1296    CmaTotal:         262144 kB
  1297    CmaFree:          258460 kB
  1298    HugePages_Total:       0
  1299    HugePages_Free:        0
  1300    HugePages_Rsvd:        0
  1301    HugePages_Surp:        0
  1302    Hugepagesize:       2048 kB
  1303    Hugetlb:               0 kB
  1304
  1305    ### virtual memory:
  1306
  1307    vm.admin_reserve_kbytes = 8192
  1308    vm.block_dump = 0
  1309    vm.compact_unevictable_allowed = 1
  1310    vm.dirty_background_bytes = 0
  1311    vm.dirty_background_ratio = 10
  1312    vm.dirty_bytes = 0
  1313    vm.dirty_expire_centisecs = 3000
  1314    vm.dirty_ratio = 20
  1315    vm.dirtytime_expire_seconds = 43200
  1316    vm.dirty_writeback_centisecs = 500
  1317    vm.extfrag_threshold = 500
  1318    vm.hugetlb_shm_group = 0
  1319    vm.laptop_mode = 0
  1320    vm.legacy_va_layout = 0
  1321    vm.lowmem_reserve_ratio = 256    256    32    0
  1322    vm.max_map_count = 65530
  1323    vm.min_free_kbytes = 4914
  1324    vm.mmap_min_addr = 4096
  1325    vm.mmap_rnd_bits = 18
  1326    vm.nr_hugepages = 0
  1327    vm.nr_overcommit_hugepages = 0
  1328    vm.oom_dump_tasks = 1
  1329    vm.oom_kill_allocating_task = 0
  1330    vm.overcommit_kbytes = 0
  1331    vm.overcommit_memory = 0
  1332    vm.overcommit_ratio = 50
  1333    vm.page-cluster = 0
  1334    vm.panic_on_oom = 0
  1335    vm.percpu_pagelist_fraction = 0
  1336    vm.stat_interval = 1
  1337    vm.swappiness = 100
  1338    vm.user_reserve_kbytes = 55239
  1339    vm.vfs_cache_pressure = 100
  1340    vm.watermark_boost_factor = 15000
  1341    vm.watermark_scale_factor = 10
  1342
  1343    ### ip addr:
  1344
  1345    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
  1346        link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  1347        inet XXX.XXX.0.1/8 scope host lo
  1348           valid_lft forever preferred_lft forever
  1349        inet6 ::1/128 scope host
  1350           valid_lft forever preferred_lft forever
  1351    2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
  1352        link/ether 00:df:06:00:00:0b brd ff:ff:ff:ff:ff:ff
  1353    3: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  1354        link/ether 00:36:76:61:0b:24 brd ff:ff:ff:ff:ff:ff
  1355
  1356    ### partitions:
  1357
  1358    major minor  #blocks  name
  1359
  1360     179        0   30924800 mmcblk0
  1361     179        1     262144 mmcblk0p1
  1362     179        2   30337024 mmcblk0p2
  1363     179       32   15384576 mmcblk1
  1364     179      128       8192 mmcblk1gp0
  1365     254        1     891484 zram1
  1366
  1367    ### df:
  1368
  1369    udev             738M      0  738M   0% /dev
  1370    tmpfs            175M   2,7M  172M   2% /run
  1371    /dev/mmcblk0p2    29G    10G   19G  36% /
  1372    tmpfs            871M      0  871M   0% /dev/shm
  1373    tmpfs            5,0M   4,0K  5,0M   1% /run/lock
  1374    tmpfs            871M      0  871M   0% /sys/fs/cgroup
  1375    tmpfs            871M      0  871M   0% /tmp
  1376    /dev/mmcblk0p1   256M    76M  180M  30% /boot
  1377
  1378    ### lsblk:
  1379
  1380    NAME         FSTYPE   SIZE MOUNTPOINT UUID
  1381    mmcblk0              29,5G
  1382    ├─mmcblk0p1  vfat     256M /boot      50FC-6AC8
  1383    └─mmcblk0p2  ext4      29G /          3e297ac1-e4e4-4ab1-bc57-47c07d0422ba
  1384    mmcblk1              14,7G
  1385    mmcblk1boot0            4M
  1386    mmcblk1boot1            4M
  1387    mmcblk1gp0              8M
  1388
  1389    ### zramctl:
  1390
  1391    NAME       ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT
  1392    /dev/zram1 lzo         870,6M   4K   81B   12K       4 [SWAP]
  1393
  1394    ### mtab:
  1395
  1396    /dev/mmcblk0p1 /boot vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro 0 0
  1397    /dev/mmcblk0p2 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  1398
  1399    ### mmc0:59b4 info:
  1400
  1401                   fwrev: 0x0
  1402                  uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SDU1  MODALIAS=mmc:block
  1403                     cid: 1b534d53445531201014a136d4013800
  1404                     rca: 0x59b4
  1405                     csd: 400e00325b590000ebef7f800a400000
  1406                  manfid: 0x00001b
  1407                     ocr: 0x00200000
  1408    preferred_erase_size: 4194304
  1409                    type: SD
  1410                   hwrev: 0x1
  1411                    date: 08/2019
  1412                     dsr: 0x404
  1413              erase_size: 512
  1414                   oemid: 0x534d
  1415                  serial: 0x14a136d4
  1416                     ssr: 0000000005000000040090000811391e00089a342f01000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  1417                     scr: 0235844300000000
  1418                    name: SDU1
  1419
  1420    ### mmc1:0001 info:
  1421
  1422                   fwrev: 0x0
  1423                  uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=016G92 MODALIAS=mmc:block
  1424                     cid: 11010030313647393201d3d1a4db1100
  1425             rel_sectors: 0x10
  1426                     rca: 0x0001
  1427            pre_eol_info: 0x00
  1428                     csd: d00e00320f5903ffffffffef92400000
  1429                  manfid: 0x000011
  1430                     ocr: 0x00200000
  1431    preferred_erase_size: 4194304
  1432    enhanced_area_offset: 18446744073709551594
  1433      raw_rpmb_size_mult: 0x4
  1434                    type: MMC
  1435                   hwrev: 0x0
  1436                    date: 01/2014
  1437                     prv: 0x1
  1438             ffu_capable: 0
  1439                     dsr: 0x404
  1440              erase_size: 4194304
  1441               life_time: 0x00 0x00
  1442      enhanced_area_size: 4294967274
  1443                   oemid: 0x0100
  1444                  serial: 0xd3d1a4db
  1445                 cmdq_en: 0
  1446                     rev: 0x6
  1447                    name: 016G92
  1448
  1449    ### Boot system health:
  1450
  1451    Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU
  1452    07:51:56: 1512MHz  0.47  51%  24%  15%   0%  10%   1% 41.0°C
  1453    07:51:56: 1512MHz  0.47  60%   7%  11%   0%  40%   0% 40.0°C
  1454    07:51:57: 1512MHz  0.47  74%  12%  24%   0%  34%   2% 41.0°C
  1455    07:51:57: 1512MHz  0.47  52%   6%  12%   1%  30%   0% 41.0°C
  1456    07:51:57: 1512MHz  0.60  43%   5%  11%   0%  24%   1% 40.0°C
  1457
  1458    ### Activated 1 lzo zram swap devices with 870 MB each
  1459
  1460
  1461    lun mar 22 11:17:04 CET 2021 | AML-S9xxx | 20.02.0-rc1.037 | arm64 | aarch64 | 5.5.0-rc6-aml-s9xxx
  1462
  1463    ### dmesg:
  1464
  1465    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
  1466    [    0.000000] Linux version 5.5.0-rc6-aml-s9xxx (root@vbox) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #rc1.037 SMP PREEMPT Wed Feb 5 15:59:04 MSK 2020
  1467    [    0.000000] Machine model: Amlogic Meson GXL (S905X) P212 Development Board
  1468    [    0.000000] efi: Getting EFI parameters from FDT:
  1469    [    0.000000] efi: UEFI not found.
  1470    [    0.000000] Reserved memory: created CMA memory pool at 0x0000000063400000, size 256 MiB
  1471    [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
  1472    [    0.000000] On node 0 totalpages: 477952
  1473    [    0.000000]   DMA zone: 4032 pages used for memmap
  1474    [    0.000000]   DMA zone: 0 pages reserved
  1475    [    0.000000]   DMA zone: 248576 pages, LIFO batch:63
  1476    [    0.000000]   DMA32 zone: 3584 pages used for memmap
  1477    [    0.000000]   DMA32 zone: 229376 pages, LIFO batch:63
  1478    [    0.000000] psci: probing for conduit method from DT.
  1479    [    0.000000] psci: PSCIv0.2 detected in firmware.
  1480    [    0.000000] psci: Using standard PSCI v0.2 function IDs
  1481    [    0.000000] psci: Trusted OS migration not required
  1482    [    0.000000] percpu: Embedded 22 pages/cpu s50392 r8192 d31528 u90112
  1483    [    0.000000] pcpu-alloc: s50392 r8192 d31528 u90112 alloc=22*4096
  1484    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
  1485    [    0.000000] Detected VIPT I-cache on CPU0
  1486    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 470336
  1487    [    0.000000] Kernel command line: root=LABEL=ROOTFS rootflags=data=writeback rw console=ttyAML0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 mac=00:df:06:00:00:0b
  1488    [    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
  1489    [    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
  1490    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
  1491    [    0.000000] software IO TLB: mapped [mem 0x3bfff000-0x3ffff000] (64MB)
  1492    [    0.000000] Memory: 1509616K/1911808K available (14460K kernel code, 1434K rwdata, 5884K rodata, 960K init, 927K bss, 140048K reserved, 262144K cma-reserved)
  1493    [    0.000000] random: get_random_u64 called from cache_random_seq_create+0x7c/0x150 with crng_init=0
  1494    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
  1495    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
  1496    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
  1497    [    0.000000]     Tasks RCU enabled.
  1498    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
  1499    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
  1500    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
  1501    [    0.000000] GIC: Using split EOI/Deactivate mode
  1502    [    0.000000] irq_meson_gpio: 110 to 8 gpio interrupt mux initialized
  1503    [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
  1504    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
  1505    [    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
  1506    [    0.000353] Console: colour dummy device 80x25
  1507    [    0.000653] printk: console [tty0] enabled
  1508    [    0.000695] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
  1509    [    0.000715] pid_max: default: 32768 minimum: 301
  1510    [    0.000841] LSM: Security Framework initializing
  1511    [    0.000891] SELinux:  Initializing.
  1512    [    0.000968] *** VALIDATE SELinux ***
  1513    [    0.001032] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
  1514    [    0.001060] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
  1515    [    0.001125] *** VALIDATE tmpfs ***
  1516    [    0.001529] *** VALIDATE proc ***
  1517    [    0.001751] *** VALIDATE cgroup1 ***
  1518    [    0.001766] *** VALIDATE cgroup2 ***
  1519    [    0.024016] ASID allocator initialised with 32768 entries
  1520    [    0.032000] rcu: Hierarchical SRCU implementation.
  1521    [    0.042081] EFI services will not be available.
  1522    [    0.048055] smp: Bringing up secondary CPUs ...
  1523    [    0.080284] Detected VIPT I-cache on CPU1
  1524    [    0.080336] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
  1525    [    0.112321] Detected VIPT I-cache on CPU2
  1526    [    0.112364] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
  1527    [    0.144370] Detected VIPT I-cache on CPU3
  1528    [    0.144414] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
  1529    [    0.144492] smp: Brought up 1 node, 4 CPUs
  1530    [    0.144556] SMP: Total of 4 processors activated.
  1531    [    0.144568] CPU features: detected: 32-bit EL0 Support
  1532    [    0.144580] CPU features: detected: CRC32 instructions
  1533    [    0.144886] CPU: All CPU(s) started at EL2
  1534    [    0.144908] alternatives: patching kernel code
  1535    [    0.146008] devtmpfs: initialized
  1536    [    0.151153] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
  1537    [    0.151196] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
  1538    [    0.158017] xor: measuring software checksum speed
  1539    [    0.196363]    8regs     :  2375.000 MB/sec
  1540    [    0.236393]    32regs    :  2724.000 MB/sec
  1541    [    0.276431]    arm64_neon:  2406.000 MB/sec
  1542    [    0.276441] xor: using function: 32regs (2724.000 MB/sec)
  1543    [    0.276496] pinctrl core: initialized pinctrl subsystem
  1544    [    0.277148] thermal_sys: Registered thermal governor 'step_wise'
  1545    [    0.277317] DMI not present or invalid.
  1546    [    0.277677] NET: Registered protocol family 16
  1547    [    0.281248] DMA: preallocated 256 KiB pool for atomic allocations
  1548    [    0.281296] audit: initializing netlink subsys (disabled)
  1549    [    0.281515] audit: type=2000 audit(0.280:1): state=initialized audit_enabled=0 res=1
  1550    [    0.282597] cpuidle: using governor ladder
  1551    [    0.282638] cpuidle: using governor menu
  1552    [    0.283009] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
  1553    [    0.283728] Serial: AMBA PL011 UART driver
  1554    [    0.297704] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
  1555    [    0.297731] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
  1556    [    0.297744] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
  1557    [    0.297756] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
  1558    [    0.301423] cryptd: max_cpu_qlen set to 1000
  1559    [    0.376690] raid6: neonx8   gen()  1616 MB/s
  1560    [    0.444751] raid6: neonx8   xor()  1504 MB/s
  1561    [    0.512789] raid6: neonx4   gen()  1562 MB/s
  1562    [    0.580844] raid6: neonx4   xor()  1471 MB/s
  1563    [    0.648886] raid6: neonx2   gen()  1200 MB/s
  1564    [    0.716949] raid6: neonx2   xor()  1216 MB/s
  1565    [    0.784989] raid6: neonx1   gen()   787 MB/s
  1566    [    0.853076] raid6: neonx1   xor()   914 MB/s
  1567    [    0.921136] raid6: int64x8  gen()  1195 MB/s
  1568    [    0.989153] raid6: int64x8  xor()   769 MB/s
  1569    [    1.057220] raid6: int64x4  gen()  1029 MB/s
  1570    [    1.125263] raid6: int64x4  xor()   752 MB/s
  1571    [    1.193316] raid6: int64x2  gen()   728 MB/s
  1572    [    1.261380] raid6: int64x2  xor()   615 MB/s
  1573    [    1.329449] raid6: int64x1  gen()   485 MB/s
  1574    [    1.397480] raid6: int64x1  xor()   468 MB/s
  1575    [    1.397490] raid6: using algorithm neonx8 gen() 1616 MB/s
  1576    [    1.397501] raid6: .... xor() 1504 MB/s, rmw enabled
  1577    [    1.397511] raid6: using neon recovery algorithm
  1578    [    1.397791] ACPI: Interpreter disabled.
  1579    [    1.398966] iommu: Default domain type: Translated
  1580    [    1.399259] vgaarb: loaded
  1581    [    1.399805] SCSI subsystem initialized
  1582    [    1.400017] libata version 3.00 loaded.
  1583    [    1.400230] usbcore: registered new interface driver usbfs
  1584    [    1.400274] usbcore: registered new interface driver hub
  1585    [    1.400338] usbcore: registered new device driver usb
  1586    [    1.400735] pps_core: LinuxPPS API ver. 1 registered
  1587    [    1.400747] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
  1588    [    1.400771] PTP clock support registered
  1589    [    1.400804] EDAC MC: Ver: 3.0.0
  1590    [    1.401402] FPGA manager framework
  1591    [    1.401506] Advanced Linux Sound Architecture Driver Initialized.
  1592    [    1.401972] NetLabel: Initializing
  1593    [    1.401986] NetLabel:  domain hash size = 128
  1594    [    1.401995] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
  1595    [    1.402048] NetLabel:  unlabeled traffic allowed by default
  1596    [    1.402565] clocksource: Switched to clocksource arch_sys_counter
  1597    [    1.402591] *** VALIDATE bpf ***
  1598    [    1.402832] VFS: Disk quotas dquot_6.6.0
  1599    [    1.402892] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
  1600    [    1.403008] FS-Cache: Loaded
  1601    [    1.403019] *** VALIDATE ramfs ***
  1602    [    1.403040] *** VALIDATE hugetlbfs ***
  1603    [    1.403408] pnp: PnP ACPI: disabled
  1604    [    1.408468] NET: Registered protocol family 2
  1605    [    1.408965] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
  1606    [    1.409013] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
  1607    [    1.409131] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
  1608    [    1.409344] TCP: Hash tables configured (established 16384 bind 16384)
  1609    [    1.409501] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
  1610    [    1.409555] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
  1611    [    1.409773] NET: Registered protocol family 1
  1612    [    1.410262] RPC: Registered named UNIX socket transport module.
  1613    [    1.410284] RPC: Registered udp transport module.
  1614    [    1.410294] RPC: Registered tcp transport module.
  1615    [    1.410303] RPC: Registered tcp NFSv4.1 backchannel transport module.
  1616    [    1.410318] NET: Registered protocol family 44
  1617    [    1.410339] PCI: CLS 0 bytes, default 64
  1618    [    1.410535] Trying to unpack rootfs image as initramfs...
  1619    [    1.872260] Freeing initrd memory: 10248K
  1620    [    1.873053] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
  1621    [    2.086883] Initialise system trusted keyrings
  1622    [    2.087111] workingset: timestamp_bits=46 max_order=19 bucket_order=0
  1623    [    2.092264] zbud: loaded
  1624    [    2.093497] squashfs: version 4.0 (2009/01/31) Phillip Lougher
  1625    [    2.093774] FS-Cache: Netfs 'nfs' registered for caching
  1626    [    2.094296] NFS: Registering the id_resolver key type
  1627    [    2.094334] Key type id_resolver registered
  1628    [    2.094343] Key type id_legacy registered
  1629    [    2.094359] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
  1630    [    2.094372] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
  1631    [    2.095575] FS-Cache: Netfs 'cifs' registered for caching
  1632    [    2.095898] Key type cifs.spnego registered
  1633    [    2.095920] Key type cifs.idmap registered
  1634    [    2.095942] ntfs: driver 2.1.32 [Flags: R/W].
  1635    [    2.096545] JFS: nTxBlock = 8192, nTxLock = 65536
  1636    [    2.102466] SGI XFS with ACLs, security attributes, realtime, quota, no debug enabled
  1637    [    2.103899] *** VALIDATE xfs ***
  1638    [    2.104193] ocfs2: Registered cluster interface o2cb
  1639    [    2.104407] OCFS2 User DLM kernel interface loaded
  1640    [    2.105834] *** VALIDATE gfs2 ***
  1641    [    2.106104] gfs2: GFS2 installed
  1642    [    2.107087] aufs 5.5-20200203
  1643    [    2.127652] Key type asymmetric registered
  1644    [    2.127677] Asymmetric key parser 'x509' registered
  1645    [    2.127688] Asymmetric key parser 'pkcs8' registered
  1646    [    2.127758] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
  1647    [    2.127963] io scheduler mq-deadline registered
  1648    [    2.127978] io scheduler kyber registered
  1649    [    2.128172] io scheduler bfq registered
  1650    [    2.140736] soc soc0: Amlogic Meson GXL (S905X) Revision 21:b (82:2) Detected
  1651    [    2.144299] Serial: 8250/16550 driver, 5 ports, IRQ sharing enabled
  1652    [    2.145988] Serial: AMBA driver
  1653    [    2.146346] c11084c0.serial: ttyAML6 at MMIO 0xc11084c0 (irq = 10, base_baud = 1500000) is a meson_uart
  1654    [    2.146497] serial serial0: tty port ttyAML6 registered
  1655    [    2.146774] c81004c0.serial: ttyAML0 at MMIO 0xc81004c0 (irq = 13, base_baud = 1500000) is a meson_uart
  1656    [    3.122238] printk: console [ttyAML0] enabled
  1657    [    3.138300] brd: module loaded
  1658    [    3.146945] loop: module loaded
  1659    [    3.149310] libphy: Fixed MDIO Bus: probed
  1660    [    3.149970] meson8b-dwmac c9410000.ethernet: IRQ eth_wake_irq not found
  1661    [    3.155116] meson8b-dwmac c9410000.ethernet: IRQ eth_lpi not found
  1662    [    3.161324] meson8b-dwmac c9410000.ethernet: PTP uses main clock
  1663    [    3.167175] meson8b-dwmac c9410000.ethernet: no reset control found
  1664    [    3.173867] meson8b-dwmac c9410000.ethernet: User ID: 0x11, Synopsys ID: 0x37
  1665    [    3.180465] meson8b-dwmac c9410000.ethernet:     DWMAC1000
  1666    [    3.185628] meson8b-dwmac c9410000.ethernet: DMA HW capability register supported
  1667    [    3.193045] meson8b-dwmac c9410000.ethernet: RX Checksum Offload Engine supported
  1668    [    3.200463] meson8b-dwmac c9410000.ethernet: COE Type 2
  1669    [    3.205635] meson8b-dwmac c9410000.ethernet: TX Checksum insertion supported
  1670    [    3.212622] meson8b-dwmac c9410000.ethernet: Wake-Up On Lan supported
  1671    [    3.219035] meson8b-dwmac c9410000.ethernet: Normal descriptors
  1672    [    3.224871] meson8b-dwmac c9410000.ethernet: Ring mode enabled
  1673    [    3.230650] meson8b-dwmac c9410000.ethernet: Enable RX Mitigation via HW Watchdog Timer
  1674    [    3.238770] libphy: stmmac: probed
  1675    [    3.243317] VFIO - User Level meta-driver version: 0.3
  1676    [    3.248583] dwc3 c9000000.dwc3: Failed to get clk 'ref': -2
  1677    [    3.253459] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
  1678    [    3.259061] ehci-pci: EHCI PCI platform driver
  1679    [    3.263499] ehci-platform: EHCI generic platform driver
  1680    [    3.268798] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
  1681    [    3.274737] ohci-pci: OHCI PCI platform driver
  1682    [    3.279174] ohci-platform: OHCI generic platform driver
  1683    [    3.284915] usbcore: registered new interface driver usb-storage
  1684    [    3.290479] mousedev: PS/2 mouse device common for all mice
  1685    [    3.296429] i2c /dev entries driver
  1686    [    3.302079] sdhci: Secure Digital Host Controller Interface driver
  1687    [    3.305363] sdhci: Copyright(c) Pierre Ossman
  1688    [    3.309674] Synopsys Designware Multimedia Card Interface Driver
  1689    [    3.316973] meson-gx-mmc d0072000.mmc: Got CD GPIO
  1690    [    3.347434] meson-gx-mmc d0074000.mmc: allocated mmc-pwrseq
  1691    [    3.375068] sdhci-pltfm: SDHCI platform and OF driver helper
  1692    [    3.376044] ledtrig-cpu: registered to indicate activity on CPUs
  1693    [    3.381997] meson-sm: secure-monitor enabled
  1694    [    3.386196] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
  1695    [    3.393305] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
  1696    [    3.409504] mmc0: new high speed SDHC card at address 59b4
  1697    [    3.410552] mmcblk0: mmc0:59b4 SDU1  29.5 GiB
  1698    [    3.415991]  mmcblk0: p1 p2
  1699    [    3.418801] hid: raw HID events driver (C) Jiri Kosina
  1700    [    3.421870] usbcore: registered new interface driver usbhid
  1701    [    3.427236] usbhid: USB HID core driver
  1702    [    3.431362] platform-mhu c883c404.mailbox: Platform MHU Mailbox registered
  1703    [    3.447844] NET: Registered protocol family 17
  1704    [    3.448108] Key type dns_resolver registered
  1705    [    3.451482] registered taskstats version 1
  1706    [    3.454976] Loading compiled-in X.509 certificates
  1707    [    3.459843] zswap: loaded using pool lzo/zbud
  1708    [    3.464174] Key type ._fscrypt registered
  1709    [    3.467976] Key type .fscrypt registered
  1710    [    3.472893] Btrfs loaded, crc32c=crc32c-generic
  1711    [    3.493551] mmc1: new HS200 MMC card at address 0001
  1712    [    3.498597] mmcblk1: mmc1:0001 016G92 14.7 GiB
  1713    [    3.499083] mmcblk1boot0: mmc1:0001 016G92 partition 1 4.00 MiB
  1714    [    3.499576] Key type encrypted registered
  1715    [    3.503823] mmcblk1boot1: mmc1:0001 016G92 partition 2 4.00 MiB
  1716    [    3.513683] mmcblk1gp0: mmc1:0001 016G92 partition 4 8.00 MiB
  1717    [    3.519208] mmcblk1rpmb: mmc1:0001 016G92 partition 3 512 KiB, chardev (243:0)
  1718    [    3.527032] meson-drm d0100000.vpu: Queued 3 outputs on vpu
  1719    [    3.532002] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
  1720    [    3.538154] [drm] No driver support for vblank timestamp query.
  1721    [    3.570617] meson-dw-hdmi c883a000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
  1722    [    3.575269] meson-dw-hdmi c883a000.hdmi-tx: registered DesignWare HDMI I2C bus driver
  1723    [    3.583292] meson-drm d0100000.vpu: bound c883a000.hdmi-tx (ops meson_dw_hdmi_ops)
  1724    [    3.590598] [drm] Initialized meson 1.0.0 20161109 for d0100000.vpu on minor 0
  1725    [    3.632196] Console: switching to colour frame buffer device 90x36
  1726    [    3.652422] meson-drm d0100000.vpu: fb0: mesondrmfb frame buffer device
  1727    [    3.659677] libphy: mdio_mux: probed
  1728    [    3.670179] libphy: mdio_mux: probed
  1729    [    3.670701] phy phy-d0078080.phy.2: unsupported PHY mode 5
  1730    [    3.675722] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  1731    [    3.679109] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
  1732    [    3.686820] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228f664 hci version 0x100 quirks 0x0000000002010010
  1733    [    3.696039] xhci-hcd xhci-hcd.0.auto: irq 39, io mem 0xc9000000
  1734    [    3.702161] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.05
  1735    [    3.710506] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1736    [    3.717655] usb usb1: Product: xHCI Host Controller
  1737    [    3.722483] usb usb1: Manufacturer: Linux 5.5.0-rc6-aml-s9xxx xhci-hcd
  1738    [    3.728951] usb usb1: SerialNumber: xhci-hcd.0.auto
  1739    [    3.734300] hub 1-0:1.0: USB hub found
  1740    [    3.737543] hub 1-0:1.0: 2 ports detected
  1741    [    3.741744] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  1742    [    3.746908] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
  1743    [    3.754496] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
  1744    [    3.760997] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
  1745    [    3.769244] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.05
  1746    [    3.777616] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1747    [    3.784773] usb usb2: Product: xHCI Host Controller
  1748    [    3.789602] usb usb2: Manufacturer: Linux 5.5.0-rc6-aml-s9xxx xhci-hcd
  1749    [    3.796072] usb usb2: SerialNumber: xhci-hcd.0.auto
  1750    [    3.801371] hub 2-0:1.0: USB hub found
  1751    [    3.804657] hub 2-0:1.0: config failed, hub doesn't have any ports! (err -19)
  1752    [    3.813480] meson-gx-mmc d0070000.mmc: allocated mmc-pwrseq
  1753    [    3.843571] scpi_protocol scpi: SCP Protocol legacy pre-1.0 firmware
  1754    [    3.860329] gx-sound-card sound: snd-soc-dummy-dai <-> c1105400.bus:audio-controller-0 mapping ok
  1755    [    3.871876] gx-sound-card sound: i2s-hifi <-> c1105400.bus:audio-controller-2 mapping ok
  1756    [    3.879564] gx-sound-card sound: ASoC: no DMI vendor name!
  1757    [    3.885756] printk: console [netcon0] enabled
  1758    [    3.889196] netconsole: network logging started
  1759    [    3.893768] hctosys: unable to open rtc device (rtc0)
  1760    [    3.899074] ALSA device list:
  1761    [    3.901684]   #0: AMLGX
  1762    [    3.904696] Freeing unused kernel memory: 960K
  1763    [    3.908544] Run /init as init process
  1764    [    3.917231] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
  1765    [    3.924029] mmc2: queuing unknown CIS tuple 0x80 (6 bytes)
  1766    [    3.931091] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
  1767    [    3.942576] mmc2: queuing unknown CIS tuple 0x80 (19 bytes)
  1768    [    3.965156] random: fast init done
  1769    [    4.028824] mmc2: new high speed SDIO card at address 0001
  1770    [    4.078643] usb 1-1: new high-speed USB device number 2 using xhci-hcd
  1771    [    4.100299] usb 1-1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.36
  1772    [    4.107220] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
  1773    [    4.114599] usb 1-1: Product: USB2.0 Hub
  1774    [    4.177498] hub 1-1:1.0: USB hub found
  1775    [    4.180084] hub 1-1:1.0: 4 ports detected
  1776    [    4.310653] usb 1-2: new high-speed USB device number 3 using xhci-hcd
  1777    [    4.341205] usb 1-2: New USB device found, idVendor=148f, idProduct=7601, bcdDevice= 0.00
  1778    [    4.348256] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
  1779    [    4.355203] usb 1-2: Product: 802.11 n WLAN
  1780    [    4.359906] usb 1-2: Manufacturer: MediaTek
  1781    [    4.366181] usb 1-2: SerialNumber: 1.0
  1782    [    5.929977] EXT4-fs (mmcblk0p2): mounted filesystem with writeback data mode. Opts: data=writeback
  1783    [    6.863884] systemd[1]: System time before build time, advancing clock.
  1784    [    7.010117] NET: Registered protocol family 10
  1785    [    7.084053] Segment Routing with IPv6
  1786    [    7.133798] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
  1787    [    7.166249] systemd[1]: Detected architecture arm64.
  1788    [    7.220331] systemd[1]: Set hostname to <mxqpro>.
  1789    [    7.252129] systemd[1]: Couldn't move remaining userspace processes, ignoring: Input/output error
  1790    [    7.956616] random: systemd: uninitialized urandom read (16 bytes read)
  1791    [    7.969840] random: systemd: uninitialized urandom read (16 bytes read)
  1792    [    7.973996] systemd[1]: Listening on udev Control Socket.
  1793    [    7.981535] random: systemd: uninitialized urandom read (16 bytes read)
  1794    [    7.985645] systemd[1]: Listening on Syslog Socket.
  1795    [    7.993273] systemd[1]: Listening on Journal Socket (/dev/log).
  1796    [    8.002123] systemd[1]: Created slice system-getty.slice.
  1797    [    8.007503] systemd[1]: Condition check resulted in Arbitrary Executable File Formats File System Automount Point being skipped.
  1798    [    8.020080] systemd[1]: Created slice system-systemd\x2dfsck.slice.
  1799    [    8.238538] EXT4-fs (mmcblk0p2): re-mounted. Opts: commit=600,errors=remount-ro
  1800    [    8.363785] systemd-journald[401]: Received request to flush runtime journal from PID 1
  1801    [    8.923111] Registered IR keymap rc-empty
  1802    [    8.925284] rc rc0: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0
  1803    [    8.932461] input: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0/input0
  1804    [    8.932902] mc: Linux media interface: v0.10
  1805    [    8.943825] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
  1806    [    8.944046] meson-ir c8100580.ir: receiver initialized
  1807    [    8.989219] videodev: Linux video capture interface: v2.00
  1808    [    9.071859] lima d00c0000.gpu: IRQ ppmmu3 not found
  1809    [    9.074122] lima d00c0000.gpu: IRQ ppmmu4 not found
  1810    [    9.088435] lima d00c0000.gpu: IRQ ppmmu5 not found
  1811    [    9.092159] lima d00c0000.gpu: IRQ ppmmu6 not found
  1812    [    9.099697] lima d00c0000.gpu: IRQ ppmmu7 not found
  1813    [    9.111856] lima d00c0000.gpu: gp - mali450 version major 0 minor 0
  1814    [    9.114960] lima d00c0000.gpu: pp0 - mali450 version major 0 minor 0
  1815    [    9.121193] lima d00c0000.gpu: pp1 - mali450 version major 0 minor 0
  1816    [    9.137298] lima d00c0000.gpu: pp2 - mali450 version major 0 minor 0
  1817    [    9.143713] lima d00c0000.gpu: IRQ pp3 not found
  1818    [    9.145623] lima d00c0000.gpu: IRQ pp4 not found
  1819    [    9.151337] lima d00c0000.gpu: IRQ pp5 not found
  1820    [    9.154252] lima d00c0000.gpu: IRQ pp6 not found
  1821    [    9.160786] lima d00c0000.gpu: IRQ pp7 not found
  1822    [    9.164026] lima d00c0000.gpu: l2 cache 8K, 4-way, 64byte cache line, 128bit external bus
  1823    [    9.172789] lima d00c0000.gpu: l2 cache 64K, 4-way, 64byte cache line, 128bit external bus
  1824    [    9.181946] lima d00c0000.gpu: bus rate = 166666667
  1825    [    9.185335] lima d00c0000.gpu: mod rate = 744000000
  1826    [    9.189438] [drm] Initialized lima 1.0.0 20190217 for d00c0000.gpu on minor 1
  1827    [    9.249835] Bluetooth: Core ver 2.22
  1828    [    9.251794] NET: Registered protocol family 31
  1829    [    9.253961] Bluetooth: HCI device and connection manager initialized
  1830    [    9.260332] Bluetooth: HCI socket layer initialized
  1831    [    9.265170] Bluetooth: L2CAP socket layer initialized
  1832    [    9.270191] Bluetooth: SCO socket layer initialized
  1833    [    9.276369] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
  1834    [    9.359942] cfg80211: Loading compiled-in X.509 certificates for regulatory database
  1835    [    9.405540] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
  1836    [    9.419935] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
  1837    [    9.426671] cfg80211: failed to load regulatory.db
  1838    [    9.456704] Bluetooth: HCI UART driver ver 2.3
  1839    [    9.459129] Bluetooth: HCI UART protocol H4 registered
  1840    [    9.469525] Bluetooth: HCI UART protocol BCSP registered
  1841    [    9.472981] Bluetooth: HCI UART protocol LL registered
  1842    [    9.482704] Bluetooth: HCI UART protocol ATH3K registered
  1843    [    9.486032] Bluetooth: HCI UART protocol Three-wire (H5) registered
  1844    [    9.526538] Bluetooth: HCI UART protocol Intel registered
  1845    [    9.531615] hci_uart_bcm serial0-0: serial0-0 supply vbat not found, using dummy regulator
  1846    [    9.538846] hci_uart_bcm serial0-0: serial0-0 supply vddio not found, using dummy regulator
  1847    [    9.551114] Bluetooth: HCI UART protocol Broadcom registered
  1848    [    9.573794] Bluetooth: HCI UART protocol QCA registered
  1849    [    9.576715] Bluetooth: HCI UART protocol AG6XX registered
  1850    [    9.581285] brcmfmac: F1 signature read @0x18000000=0x16034334
  1851    [    9.582638] Bluetooth: HCI UART protocol Marvell registered
  1852    [    9.589720] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4334-sdio for chip BCM4334/3
  1853    [    9.599275] usbcore: registered new interface driver brcmfmac
  1854    [    9.652250] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.amlogic,p212.txt failed with error -2
  1855    [    9.662348] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.txt failed with error -2
  1856    [    9.730971] usb 1-2: reset high-speed USB device number 3 using xhci-hcd
  1857    [    9.753871] mt7601u 1-2:1.0: ASIC revision: 76010001 MAC revision: 76010500
  1858    [    9.798465] mt7601u 1-2:1.0: EEPROM ver:0d fae:00
  1859    [    9.956858] Bluetooth: hci0: BCM: chip id 68
  1860    [    9.965676] Bluetooth: hci0: BCM: features 0x0f
  1861    [    9.973632] Bluetooth: hci0: BCM4334B0
  1862    [    9.976380] Bluetooth: hci0: BCM4334B0 (002.001.013) build 0000
  1863    [    9.980456] bluetooth hci0: Direct firmware load for brcm/BCM4334B0.hcd failed with error -2
  1864    [    9.988712] Bluetooth: hci0: BCM: Patch brcm/BCM4334B0.hcd not found
  1865    [   10.027270] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
  1866    [   10.028288] usbcore: registered new interface driver mt7601u
  1867    [   10.666716] brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x50
  1868    [   10.717095] zram: Added device: zram0
  1869    [   10.723846] zram: Added device: zram1
  1870    [   10.730716] zram: Added device: zram2
  1871    [   10.766088] meson8b-dwmac c9410000.ethernet eth0: PHY [0.e40908ff:08] driver [Meson GXL Internal PHY]
  1872    [   10.783471] zram1: detected capacity change from 0 to 912879616
  1873    [   10.787344] meson8b-dwmac c9410000.ethernet eth0: No Safety Features support found
  1874    [   10.793812] meson8b-dwmac c9410000.ethernet eth0: PTP not supported by HW
  1875    [   10.800726] meson8b-dwmac c9410000.ethernet eth0: configuring for phy/rmii link mode
  1876    [   11.441161] random: crng init done
  1877    [   11.443690] random: 7 urandom warning(s) missed due to ratelimiting
  1878    [   11.494636] Adding 891480k swap on /dev/zram1.  Priority:5 extents:1 across:891480k SSFS
  1879
  1880    ### armbian-release:
  1881
  1882    # PLEASE DO NOT EDIT THIS FILE
  1883    BOARD=aml-s9xxx
  1884    BOARD_NAME="AML-S9xxx"
  1885    BOARDFAMILY=aml-s9xxx
  1886    BUILD_REPOSITORY_URL=https://github.com/150balbes/Build-Armbian.git
  1887    BUILD_REPOSITORY_COMMIT=62b8c07-dirty
  1888    DISTRIBUTION_CODENAME=buster
  1889    DISTRIBUTION_STATUS=supported
  1890    VERSION=20.02.0-rc1.037
  1891    LINUXFAMILY=aml-s9xxx
  1892    BRANCH=current
  1893    ARCH=arm64
  1894    IMAGE_TYPE=nightly
  1895    BOARD_TYPE=conf
  1896    INITRD_ARCH=arm64
  1897    KERNEL_IMAGE_TYPE=Image
  1898
  1899    ### boot environment:
  1900
  1901    ODROIDN2-UBOOT-CONFIG
  1902    setenv env_addr 0x10400000
  1903    setenv kernel_addr 0x11000000
  1904    setenv initrd_addr 0x13000000
  1905    setenv dtb_addr 0x1000000
  1906    if test "${devtype}" = ""; then setenv devtype "mmc"; fi
  1907    load ${devtype} ${devnum} ${env_addr} uEnv.txt && env import -t ${env_addr} ${filesize}
  1908    setenv bootargs ${APPEND}
  1909    load ${devtype} ${devnum} ${kernel_addr} ${LINUX}
  1910    load ${devtype} ${devnum} ${initrd_addr} ${INITRD}
  1911    load ${devtype} ${devnum} ${dtb_addr} ${FDT}
  1912    fdt addr ${dtb_addr}
  1913    booti ${kernel_addr} ${initrd_addr} ${dtb_addr}
  1914
  1915    ### lsusb:
  1916
  1917    Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
  1918    Bus 001 Device 003: ID 148f:7601 Ralink Technology, Corp. MT7601U Wireless Adapter
  1919    Bus 001 Device 002: ID 05e3:0608 Genesys Logic, Inc. Hub
  1920    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  1921
  1922    ### lscpu:
  1923
  1924    Architecture:        aarch64
  1925    Byte Order:          Little Endian
  1926    CPU(s):              4
  1927    On-line CPU(s) list: 0-3
  1928    Thread(s) per core:  1
  1929    Core(s) per socket:  4
  1930    Socket(s):           1
  1931    Vendor ID:           ARM
  1932    Model:               4
  1933    Model name:          Cortex-A53
  1934    Stepping:            r0p4
  1935    CPU max MHz:         1512,0000
  1936    CPU min MHz:         100,0000
  1937    BogoMIPS:            48.00
  1938    L1d cache:           unknown size
  1939    L1i cache:           unknown size
  1940    L2 cache:            unknown size
  1941    Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1942
  1943    ### cpuinfo:
  1944
  1945    processor    : 0
  1946    model name    : ARMv8 Processor rev 4 (v8l)
  1947    BogoMIPS    : 48.00
  1948    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1949    CPU implementer    : 0x41
  1950    CPU architecture: 8
  1951    CPU variant    : 0x0
  1952    CPU part    : 0xd03
  1953    CPU revision    : 4
  1954
  1955    processor    : 1
  1956    model name    : ARMv8 Processor rev 4 (v8l)
  1957    BogoMIPS    : 48.00
  1958    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1959    CPU implementer    : 0x41
  1960    CPU architecture: 8
  1961    CPU variant    : 0x0
  1962    CPU part    : 0xd03
  1963    CPU revision    : 4
  1964
  1965    processor    : 2
  1966    model name    : ARMv8 Processor rev 4 (v8l)
  1967    BogoMIPS    : 48.00
  1968    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1969    CPU implementer    : 0x41
  1970    CPU architecture: 8
  1971    CPU variant    : 0x0
  1972    CPU part    : 0xd03
  1973    CPU revision    : 4
  1974
  1975    processor    : 3
  1976    model name    : ARMv8 Processor rev 4 (v8l)
  1977    BogoMIPS    : 48.00
  1978    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1979    CPU implementer    : 0x41
  1980    CPU architecture: 8
  1981    CPU variant    : 0x0
  1982    CPU part    : 0xd03
  1983    CPU revision    : 4
  1984
  1985
  1986    ### meminfo:
  1987
  1988    MemTotal:        1782968 kB
  1989    MemFree:         1612468 kB
  1990    MemAvailable:    1666120 kB
  1991    Buffers:           11828 kB
  1992    Cached:            51068 kB
  1993    SwapCached:            0 kB
  1994    Active:            49940 kB
  1995    Inactive:          33288 kB
  1996    Active(anon):      20848 kB
  1997    Inactive(anon):     2620 kB
  1998    Active(file):      29092 kB
  1999    Inactive(file):    30668 kB
  2000    Unevictable:           0 kB
  2001    Mlocked:               0 kB
  2002    SwapTotal:        891480 kB
  2003    SwapFree:         891480 kB
  2004    Dirty:               704 kB
  2005    Writeback:             0 kB
  2006    AnonPages:         20748 kB
  2007    Mapped:            21148 kB
  2008    Shmem:              2720 kB
  2009    KReclaimable:      17008 kB
  2010    Slab:              52992 kB
  2011    SReclaimable:      17008 kB
  2012    SUnreclaim:        35984 kB
  2013    KernelStack:        2672 kB
  2014    PageTables:         1668 kB
  2015    NFS_Unstable:          0 kB
  2016    Bounce:                0 kB
  2017    WritebackTmp:          0 kB
  2018    CommitLimit:     1782964 kB
  2019    Committed_AS:      54464 kB
  2020    VmallocTotal:   135290159040 kB
  2021    VmallocUsed:       16600 kB
  2022    VmallocChunk:          0 kB
  2023    Percpu:             1312 kB
  2024    CmaTotal:         262144 kB
  2025    CmaFree:          258460 kB
  2026    HugePages_Total:       0
  2027    HugePages_Free:        0
  2028    HugePages_Rsvd:        0
  2029    HugePages_Surp:        0
  2030    Hugepagesize:       2048 kB
  2031    Hugetlb:               0 kB
  2032
  2033    ### virtual memory:
  2034
  2035    vm.admin_reserve_kbytes = 8192
  2036    vm.block_dump = 0
  2037    vm.compact_unevictable_allowed = 1
  2038    vm.dirty_background_bytes = 0
  2039    vm.dirty_background_ratio = 10
  2040    vm.dirty_bytes = 0
  2041    vm.dirty_expire_centisecs = 3000
  2042    vm.dirty_ratio = 20
  2043    vm.dirtytime_expire_seconds = 43200
  2044    vm.dirty_writeback_centisecs = 500
  2045    vm.extfrag_threshold = 500
  2046    vm.hugetlb_shm_group = 0
  2047    vm.laptop_mode = 0
  2048    vm.legacy_va_layout = 0
  2049    vm.lowmem_reserve_ratio = 256    256    32    0
  2050    vm.max_map_count = 65530
  2051    vm.min_free_kbytes = 4914
  2052    vm.mmap_min_addr = 4096
  2053    vm.mmap_rnd_bits = 18
  2054    vm.nr_hugepages = 0
  2055    vm.nr_overcommit_hugepages = 0
  2056    vm.oom_dump_tasks = 1
  2057    vm.oom_kill_allocating_task = 0
  2058    vm.overcommit_kbytes = 0
  2059    vm.overcommit_memory = 0
  2060    vm.overcommit_ratio = 50
  2061    vm.page-cluster = 0
  2062    vm.panic_on_oom = 0
  2063    vm.percpu_pagelist_fraction = 0
  2064    vm.stat_interval = 1
  2065    vm.swappiness = 100
  2066    vm.user_reserve_kbytes = 55239
  2067    vm.vfs_cache_pressure = 100
  2068    vm.watermark_boost_factor = 15000
  2069    vm.watermark_scale_factor = 10
  2070
  2071    ### ip addr:
  2072
  2073    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
  2074        link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  2075        inet XXX.XXX.0.1/8 scope host lo
  2076           valid_lft forever preferred_lft forever
  2077        inet6 ::1/128 scope host
  2078           valid_lft forever preferred_lft forever
  2079    2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
  2080        link/ether 00:df:06:00:00:0b brd ff:ff:ff:ff:ff:ff
  2081    3: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  2082        link/ether 00:36:76:61:0b:24 brd ff:ff:ff:ff:ff:ff
  2083
  2084    ### partitions:
  2085
  2086    major minor  #blocks  name
  2087
  2088     179        0   30924800 mmcblk0
  2089     179        1     262144 mmcblk0p1
  2090     179        2   30337024 mmcblk0p2
  2091     179       32   15384576 mmcblk1
  2092     179      128       8192 mmcblk1gp0
  2093     254        1     891484 zram1
  2094
  2095    ### df:
  2096
  2097    udev             738M      0  738M   0% /dev
  2098    tmpfs            175M   2,7M  172M   2% /run
  2099    /dev/mmcblk0p2    29G    10G   19G  36% /
  2100    tmpfs            871M      0  871M   0% /dev/shm
  2101    tmpfs            5,0M   4,0K  5,0M   1% /run/lock
  2102    tmpfs            871M      0  871M   0% /sys/fs/cgroup
  2103    tmpfs            871M      0  871M   0% /tmp
  2104    /dev/mmcblk0p1   256M    76M  180M  30% /boot
  2105
  2106    ### lsblk:
  2107
  2108    NAME         FSTYPE   SIZE MOUNTPOINT UUID
  2109    mmcblk0              29,5G
  2110    ├─mmcblk0p1  vfat     256M /boot      50FC-6AC8
  2111    └─mmcblk0p2  ext4      29G /          3e297ac1-e4e4-4ab1-bc57-47c07d0422ba
  2112    mmcblk1              14,7G
  2113    mmcblk1boot0            4M
  2114    mmcblk1boot1            4M
  2115    mmcblk1gp0              8M
  2116
  2117    ### zramctl:
  2118
  2119    NAME       ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT
  2120    /dev/zram1 lzo         870,6M   4K   81B   12K       4 [SWAP]
  2121
  2122    ### mtab:
  2123
  2124    /dev/mmcblk0p1 /boot vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro 0 0
  2125    /dev/mmcblk0p2 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  2126
  2127    ### mmc0:59b4 info:
  2128
  2129                   fwrev: 0x0
  2130                  uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SDU1  MODALIAS=mmc:block
  2131                     cid: 1b534d53445531201014a136d4013800
  2132                     rca: 0x59b4
  2133                     csd: 400e00325b590000ebef7f800a400000
  2134                  manfid: 0x00001b
  2135                     ocr: 0x00200000
  2136    preferred_erase_size: 4194304
  2137                    type: SD
  2138                   hwrev: 0x1
  2139                    date: 08/2019
  2140                     dsr: 0x404
  2141              erase_size: 512
  2142                   oemid: 0x534d
  2143                  serial: 0x14a136d4
  2144                     ssr: 0000000005000000040090000811391e00089a342f01000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  2145                     scr: 0235844300000000
  2146                    name: SDU1
  2147
  2148    ### mmc1:0001 info:
  2149
  2150                   fwrev: 0x0
  2151                  uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=016G92 MODALIAS=mmc:block
  2152                     cid: 11010030313647393201d3d1a4db1100
  2153             rel_sectors: 0x10
  2154                     rca: 0x0001
  2155            pre_eol_info: 0x00
  2156                     csd: d00e00320f5903ffffffffef92400000
  2157                  manfid: 0x000011
  2158                     ocr: 0x00200000
  2159    preferred_erase_size: 4194304
  2160    enhanced_area_offset: 18446744073709551594
  2161      raw_rpmb_size_mult: 0x4
  2162                    type: MMC
  2163                   hwrev: 0x0
  2164                    date: 01/2014
  2165                     prv: 0x1
  2166             ffu_capable: 0
  2167                     dsr: 0x404
  2168              erase_size: 4194304
  2169               life_time: 0x00 0x00
  2170      enhanced_area_size: 4294967274
  2171                   oemid: 0x0100
  2172                  serial: 0xd3d1a4db
  2173                 cmdq_en: 0
  2174                     rev: 0x6
  2175                    name: 016G92
  2176
  2177    ### Boot system health:
  2178
  2179    Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU
  2180    11:17:07: 1512MHz  0.79  50%  23%  14%   0%  10%   1% 54.0°C
  2181    11:17:07: 1512MHz  0.79  66%   5%  11%   1%  46%   1% 54.0°C
  2182    11:17:07: 1512MHz  0.79  77%  13%  27%   1%  33%   2% 54.0°C
  2183    11:17:08: 1512MHz  1.21  52%   6%   7%   1%  35%   1% 54.0°C
  2184    11:17:08: 1512MHz  1.21  50%   8%  13%   1%  25%   1% 53.0°C
  2185
  2186    ### Activated 1 lzo zram swap devices with 870 MB each
  2187
  2188
  2189    mar mar 23 09:17:04 CET 2021 | AML-S9xxx | 20.02.0-rc1.037 | arm64 | aarch64 | 5.5.0-rc6-aml-s9xxx
  2190
  2191    ### dmesg:
  2192
  2193    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
  2194    [    0.000000] Linux version 5.5.0-rc6-aml-s9xxx (root@vbox) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #rc1.037 SMP PREEMPT Wed Feb 5 15:59:04 MSK 2020
  2195    [    0.000000] Machine model: Amlogic Meson GXL (S905X) P212 Development Board
  2196    [    0.000000] efi: Getting EFI parameters from FDT:
  2197    [    0.000000] efi: UEFI not found.
  2198    [    0.000000] Reserved memory: created CMA memory pool at 0x0000000063400000, size 256 MiB
  2199    [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
  2200    [    0.000000] On node 0 totalpages: 477952
  2201    [    0.000000]   DMA zone: 4032 pages used for memmap
  2202    [    0.000000]   DMA zone: 0 pages reserved
  2203    [    0.000000]   DMA zone: 248576 pages, LIFO batch:63
  2204    [    0.000000]   DMA32 zone: 3584 pages used for memmap
  2205    [    0.000000]   DMA32 zone: 229376 pages, LIFO batch:63
  2206    [    0.000000] psci: probing for conduit method from DT.
  2207    [    0.000000] psci: PSCIv0.2 detected in firmware.
  2208    [    0.000000] psci: Using standard PSCI v0.2 function IDs
  2209    [    0.000000] psci: Trusted OS migration not required
  2210    [    0.000000] percpu: Embedded 22 pages/cpu s50392 r8192 d31528 u90112
  2211    [    0.000000] pcpu-alloc: s50392 r8192 d31528 u90112 alloc=22*4096
  2212    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
  2213    [    0.000000] Detected VIPT I-cache on CPU0
  2214    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 470336
  2215    [    0.000000] Kernel command line: root=LABEL=ROOTFS rootflags=data=writeback rw console=ttyAML0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 mac=00:df:06:00:00:0b
  2216    [    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
  2217    [    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
  2218    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
  2219    [    0.000000] software IO TLB: mapped [mem 0x3bfff000-0x3ffff000] (64MB)
  2220    [    0.000000] Memory: 1509616K/1911808K available (14460K kernel code, 1434K rwdata, 5884K rodata, 960K init, 927K bss, 140048K reserved, 262144K cma-reserved)
  2221    [    0.000000] random: get_random_u64 called from cache_random_seq_create+0x7c/0x150 with crng_init=0
  2222    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
  2223    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
  2224    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
  2225    [    0.000000]     Tasks RCU enabled.
  2226    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
  2227    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
  2228    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
  2229    [    0.000000] GIC: Using split EOI/Deactivate mode
  2230    [    0.000000] irq_meson_gpio: 110 to 8 gpio interrupt mux initialized
  2231    [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
  2232    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
  2233    [    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
  2234    [    0.000354] Console: colour dummy device 80x25
  2235    [    0.000655] printk: console [tty0] enabled
  2236    [    0.000696] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
  2237    [    0.000717] pid_max: default: 32768 minimum: 301
  2238    [    0.000841] LSM: Security Framework initializing
  2239    [    0.000893] SELinux:  Initializing.
  2240    [    0.000970] *** VALIDATE SELinux ***
  2241    [    0.001034] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
  2242    [    0.001060] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
  2243    [    0.001123] *** VALIDATE tmpfs ***
  2244    [    0.001529] *** VALIDATE proc ***
  2245    [    0.001749] *** VALIDATE cgroup1 ***
  2246    [    0.001763] *** VALIDATE cgroup2 ***
  2247    [    0.024016] ASID allocator initialised with 32768 entries
  2248    [    0.031997] rcu: Hierarchical SRCU implementation.
  2249    [    0.042088] EFI services will not be available.
  2250    [    0.048056] smp: Bringing up secondary CPUs ...
  2251    [    0.080281] Detected VIPT I-cache on CPU1
  2252    [    0.080336] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
  2253    [    0.112321] Detected VIPT I-cache on CPU2
  2254    [    0.112366] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
  2255    [    0.144373] Detected VIPT I-cache on CPU3
  2256    [    0.144414] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
  2257    [    0.144490] smp: Brought up 1 node, 4 CPUs
  2258    [    0.144561] SMP: Total of 4 processors activated.
  2259    [    0.144572] CPU features: detected: 32-bit EL0 Support
  2260    [    0.144584] CPU features: detected: CRC32 instructions
  2261    [    0.144889] CPU: All CPU(s) started at EL2
  2262    [    0.144910] alternatives: patching kernel code
  2263    [    0.146007] devtmpfs: initialized
  2264    [    0.151117] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
  2265    [    0.151158] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
  2266    [    0.158029] xor: measuring software checksum speed
  2267    [    0.196370]    8regs     :  2375.000 MB/sec
  2268    [    0.236402]    32regs    :  2724.000 MB/sec
  2269    [    0.276440]    arm64_neon:  2406.000 MB/sec
  2270    [    0.276450] xor: using function: 32regs (2724.000 MB/sec)
  2271    [    0.276505] pinctrl core: initialized pinctrl subsystem
  2272    [    0.277152] thermal_sys: Registered thermal governor 'step_wise'
  2273    [    0.277312] DMI not present or invalid.
  2274    [    0.277674] NET: Registered protocol family 16
  2275    [    0.281246] DMA: preallocated 256 KiB pool for atomic allocations
  2276    [    0.281295] audit: initializing netlink subsys (disabled)
  2277    [    0.281514] audit: type=2000 audit(0.280:1): state=initialized audit_enabled=0 res=1
  2278    [    0.282597] cpuidle: using governor ladder
  2279    [    0.282638] cpuidle: using governor menu
  2280    [    0.283008] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
  2281    [    0.283723] Serial: AMBA PL011 UART driver
  2282    [    0.297708] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
  2283    [    0.297736] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
  2284    [    0.297750] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
  2285    [    0.297762] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
  2286    [    0.301305] cryptd: max_cpu_qlen set to 1000
  2287    [    0.376675] raid6: neonx8   gen()  1617 MB/s
  2288    [    0.444712] raid6: neonx8   xor()  1505 MB/s
  2289    [    0.512788] raid6: neonx4   gen()  1564 MB/s
  2290    [    0.580814] raid6: neonx4   xor()  1471 MB/s
  2291    [    0.648899] raid6: neonx2   gen()  1199 MB/s
  2292    [    0.716941] raid6: neonx2   xor()  1216 MB/s
  2293    [    0.785050] raid6: neonx1   gen()   787 MB/s
  2294    [    0.853062] raid6: neonx1   xor()   916 MB/s
  2295    [    0.921116] raid6: int64x8  gen()  1194 MB/s
  2296    [    0.989169] raid6: int64x8  xor()   769 MB/s
  2297    [    1.057240] raid6: int64x4  gen()  1029 MB/s
  2298    [    1.125289] raid6: int64x4  xor()   752 MB/s
  2299    [    1.193337] raid6: int64x2  gen()   728 MB/s
  2300    [    1.261360] raid6: int64x2  xor()   618 MB/s
  2301    [    1.329530] raid6: int64x1  gen()   487 MB/s
  2302    [    1.397482] raid6: int64x1  xor()   468 MB/s
  2303    [    1.397492] raid6: using algorithm neonx8 gen() 1617 MB/s
  2304    [    1.397503] raid6: .... xor() 1505 MB/s, rmw enabled
  2305    [    1.397513] raid6: using neon recovery algorithm
  2306    [    1.397789] ACPI: Interpreter disabled.
  2307    [    1.398974] iommu: Default domain type: Translated
  2308    [    1.399253] vgaarb: loaded
  2309    [    1.399784] SCSI subsystem initialized
  2310    [    1.399986] libata version 3.00 loaded.
  2311    [    1.400200] usbcore: registered new interface driver usbfs
  2312    [    1.400244] usbcore: registered new interface driver hub
  2313    [    1.400308] usbcore: registered new device driver usb
  2314    [    1.400708] pps_core: LinuxPPS API ver. 1 registered
  2315    [    1.400720] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
  2316    [    1.400744] PTP clock support registered
  2317    [    1.400779] EDAC MC: Ver: 3.0.0
  2318    [    1.401353] FPGA manager framework
  2319    [    1.401474] Advanced Linux Sound Architecture Driver Initialized.
  2320    [    1.401942] NetLabel: Initializing
  2321    [    1.401955] NetLabel:  domain hash size = 128
  2322    [    1.401964] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
  2323    [    1.402020] NetLabel:  unlabeled traffic allowed by default
  2324    [    1.402522] clocksource: Switched to clocksource arch_sys_counter
  2325    [    1.402548] *** VALIDATE bpf ***
  2326    [    1.402790] VFS: Disk quotas dquot_6.6.0
  2327    [    1.402851] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
  2328    [    1.402967] FS-Cache: Loaded
  2329    [    1.402977] *** VALIDATE ramfs ***
  2330    [    1.402999] *** VALIDATE hugetlbfs ***
  2331    [    1.403369] pnp: PnP ACPI: disabled
  2332    [    1.408382] NET: Registered protocol family 2
  2333    [    1.408878] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
  2334    [    1.408927] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
  2335    [    1.409047] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
  2336    [    1.409262] TCP: Hash tables configured (established 16384 bind 16384)
  2337    [    1.409418] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
  2338    [    1.409470] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
  2339    [    1.409685] NET: Registered protocol family 1
  2340    [    1.410162] RPC: Registered named UNIX socket transport module.
  2341    [    1.410182] RPC: Registered udp transport module.
  2342    [    1.410192] RPC: Registered tcp transport module.
  2343    [    1.410201] RPC: Registered tcp NFSv4.1 backchannel transport module.
  2344    [    1.410217] NET: Registered protocol family 44
  2345    [    1.410238] PCI: CLS 0 bytes, default 64
  2346    [    1.410428] Trying to unpack rootfs image as initramfs...
  2347    [    1.871868] Freeing initrd memory: 10248K
  2348    [    1.872648] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
  2349    [    2.086163] Initialise system trusted keyrings
  2350    [    2.086390] workingset: timestamp_bits=46 max_order=19 bucket_order=0
  2351    [    2.091505] zbud: loaded
  2352    [    2.092750] squashfs: version 4.0 (2009/01/31) Phillip Lougher
  2353    [    2.093050] FS-Cache: Netfs 'nfs' registered for caching
  2354    [    2.093595] NFS: Registering the id_resolver key type
  2355    [    2.093634] Key type id_resolver registered
  2356    [    2.093644] Key type id_legacy registered
  2357    [    2.093660] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
  2358    [    2.093672] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
  2359    [    2.094843] FS-Cache: Netfs 'cifs' registered for caching
  2360    [    2.095181] Key type cifs.spnego registered
  2361    [    2.095201] Key type cifs.idmap registered
  2362    [    2.095226] ntfs: driver 2.1.32 [Flags: R/W].
  2363    [    2.095800] JFS: nTxBlock = 8192, nTxLock = 65536
  2364    [    2.101705] SGI XFS with ACLs, security attributes, realtime, quota, no debug enabled
  2365    [    2.103218] *** VALIDATE xfs ***
  2366    [    2.103502] ocfs2: Registered cluster interface o2cb
  2367    [    2.103713] OCFS2 User DLM kernel interface loaded
  2368    [    2.105087] *** VALIDATE gfs2 ***
  2369    [    2.105361] gfs2: GFS2 installed
  2370    [    2.106285] aufs 5.5-20200203
  2371    [    2.126790] Key type asymmetric registered
  2372    [    2.126817] Asymmetric key parser 'x509' registered
  2373    [    2.126827] Asymmetric key parser 'pkcs8' registered
  2374    [    2.126897] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
  2375    [    2.127091] io scheduler mq-deadline registered
  2376    [    2.127105] io scheduler kyber registered
  2377    [    2.127304] io scheduler bfq registered
  2378    [    2.139846] soc soc0: Amlogic Meson GXL (S905X) Revision 21:b (82:2) Detected
  2379    [    2.143423] Serial: 8250/16550 driver, 5 ports, IRQ sharing enabled
  2380    [    2.145118] Serial: AMBA driver
  2381    [    2.145479] c11084c0.serial: ttyAML6 at MMIO 0xc11084c0 (irq = 10, base_baud = 1500000) is a meson_uart
  2382    [    2.145632] serial serial0: tty port ttyAML6 registered
  2383    [    2.145845] c81004c0.serial: ttyAML0 at MMIO 0xc81004c0 (irq = 13, base_baud = 1500000) is a meson_uart
  2384    [    3.121312] printk: console [ttyAML0] enabled
  2385    [    3.137613] brd: module loaded
  2386    [    3.146122] loop: module loaded
  2387    [    3.148619] libphy: Fixed MDIO Bus: probed
  2388    [    3.149270] meson8b-dwmac c9410000.ethernet: IRQ eth_wake_irq not found
  2389    [    3.154294] meson8b-dwmac c9410000.ethernet: IRQ eth_lpi not found
  2390    [    3.160507] meson8b-dwmac c9410000.ethernet: PTP uses main clock
  2391    [    3.166354] meson8b-dwmac c9410000.ethernet: no reset control found
  2392    [    3.173033] meson8b-dwmac c9410000.ethernet: User ID: 0x11, Synopsys ID: 0x37
  2393    [    3.179663] meson8b-dwmac c9410000.ethernet:     DWMAC1000
  2394    [    3.184822] meson8b-dwmac c9410000.ethernet: DMA HW capability register supported
  2395    [    3.192223] meson8b-dwmac c9410000.ethernet: RX Checksum Offload Engine supported
  2396    [    3.199640] meson8b-dwmac c9410000.ethernet: COE Type 2
  2397    [    3.204812] meson8b-dwmac c9410000.ethernet: TX Checksum insertion supported
  2398    [    3.211799] meson8b-dwmac c9410000.ethernet: Wake-Up On Lan supported
  2399    [    3.218216] meson8b-dwmac c9410000.ethernet: Normal descriptors
  2400    [    3.224048] meson8b-dwmac c9410000.ethernet: Ring mode enabled
  2401    [    3.229825] meson8b-dwmac c9410000.ethernet: Enable RX Mitigation via HW Watchdog Timer
  2402    [    3.237948] libphy: stmmac: probed
  2403    [    3.242413] VFIO - User Level meta-driver version: 0.3
  2404    [    3.247770] dwc3 c9000000.dwc3: Failed to get clk 'ref': -2
  2405    [    3.252618] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
  2406    [    3.258263] ehci-pci: EHCI PCI platform driver
  2407    [    3.262672] ehci-platform: EHCI generic platform driver
  2408    [    3.267971] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
  2409    [    3.273918] ohci-pci: OHCI PCI platform driver
  2410    [    3.278351] ohci-platform: OHCI generic platform driver
  2411    [    3.284100] usbcore: registered new interface driver usb-storage
  2412    [    3.289677] mousedev: PS/2 mouse device common for all mice
  2413    [    3.295614] i2c /dev entries driver
  2414    [    3.301246] sdhci: Secure Digital Host Controller Interface driver
  2415    [    3.304535] sdhci: Copyright(c) Pierre Ossman
  2416    [    3.308851] Synopsys Designware Multimedia Card Interface Driver
  2417    [    3.316105] meson-gx-mmc d0072000.mmc: Got CD GPIO
  2418    [    3.346807] meson-gx-mmc d0074000.mmc: allocated mmc-pwrseq
  2419    [    3.374378] sdhci-pltfm: SDHCI platform and OF driver helper
  2420    [    3.375595] ledtrig-cpu: registered to indicate activity on CPUs
  2421    [    3.380953] meson-sm: secure-monitor enabled
  2422    [    3.385242] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
  2423    [    3.386495] mmc0: new high speed SDHC card at address 59b4
  2424    [    3.392598] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
  2425    [    3.398722] mmcblk0: mmc0:59b4 SDU1  29.5 GiB
  2426    [    3.416767]  mmcblk0: p1 p2
  2427    [    3.422958] hid: raw HID events driver (C) Jiri Kosina
  2428    [    3.423198] usbcore: registered new interface driver usbhid
  2429    [    3.428109] usbhid: USB HID core driver
  2430    [    3.432169] platform-mhu c883c404.mailbox: Platform MHU Mailbox registered
  2431    [    3.449257] NET: Registered protocol family 17
  2432    [    3.449514] Key type dns_resolver registered
  2433    [    3.452841] registered taskstats version 1
  2434    [    3.456379] Loading compiled-in X.509 certificates
  2435    [    3.461360] zswap: loaded using pool lzo/zbud
  2436    [    3.465615] Key type ._fscrypt registered
  2437    [    3.469396] Key type .fscrypt registered
  2438    [    3.474317] Btrfs loaded, crc32c=crc32c-generic
  2439    [    3.496751] mmc1: new HS200 MMC card at address 0001
  2440    [    3.497658] mmcblk1: mmc1:0001 016G92 14.7 GiB
  2441    [    3.501075] mmcblk1boot0: mmc1:0001 016G92 partition 1 4.00 MiB
  2442    [    3.502154] Key type encrypted registered
  2443    [    3.506938] mmcblk1boot1: mmc1:0001 016G92 partition 2 4.00 MiB
  2444    [    3.516793] mmcblk1gp0: mmc1:0001 016G92 partition 4 8.00 MiB
  2445    [    3.522333] mmcblk1rpmb: mmc1:0001 016G92 partition 3 512 KiB, chardev (243:0)
  2446    [    3.530034] meson-drm d0100000.vpu: Queued 3 outputs on vpu
  2447    [    3.535035] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
  2448    [    3.541307] [drm] No driver support for vblank timestamp query.
  2449    [    3.574588] meson-dw-hdmi c883a000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
  2450    [    3.579301] meson-dw-hdmi c883a000.hdmi-tx: registered DesignWare HDMI I2C bus driver
  2451    [    3.587263] meson-drm d0100000.vpu: bound c883a000.hdmi-tx (ops meson_dw_hdmi_ops)
  2452    [    3.594604] [drm] Initialized meson 1.0.0 20161109 for d0100000.vpu on minor 0
  2453    [    3.631915] Console: switching to colour frame buffer device 90x36
  2454    [    3.652134] meson-drm d0100000.vpu: fb0: mesondrmfb frame buffer device
  2455    [    3.659390] libphy: mdio_mux: probed
  2456    [    3.669964] libphy: mdio_mux: probed
  2457    [    3.670454] phy phy-d0078080.phy.2: unsupported PHY mode 5
  2458    [    3.675581] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  2459    [    3.678893] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
  2460    [    3.686599] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228f664 hci version 0x100 quirks 0x0000000002010010
  2461    [    3.695838] xhci-hcd xhci-hcd.0.auto: irq 39, io mem 0xc9000000
  2462    [    3.701934] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.05
  2463    [    3.710305] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  2464    [    3.717444] usb usb1: Product: xHCI Host Controller
  2465    [    3.722271] usb usb1: Manufacturer: Linux 5.5.0-rc6-aml-s9xxx xhci-hcd
  2466    [    3.728744] usb usb1: SerialNumber: xhci-hcd.0.auto
  2467    [    3.734073] hub 1-0:1.0: USB hub found
  2468    [    3.737319] hub 1-0:1.0: 2 ports detected
  2469    [    3.741542] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  2470    [    3.746704] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
  2471    [    3.754302] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
  2472    [    3.760808] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
  2473    [    3.769076] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.05
  2474    [    3.777458] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  2475    [    3.784613] usb usb2: Product: xHCI Host Controller
  2476    [    3.789449] usb usb2: Manufacturer: Linux 5.5.0-rc6-aml-s9xxx xhci-hcd
  2477    [    3.795913] usb usb2: SerialNumber: xhci-hcd.0.auto
  2478    [    3.801213] hub 2-0:1.0: USB hub found
  2479    [    3.804489] hub 2-0:1.0: config failed, hub doesn't have any ports! (err -19)
  2480    [    3.813355] meson-gx-mmc d0070000.mmc: allocated mmc-pwrseq
  2481    [    3.843529] scpi_protocol scpi: SCP Protocol legacy pre-1.0 firmware
  2482    [    3.860387] gx-sound-card sound: snd-soc-dummy-dai <-> c1105400.bus:audio-controller-0 mapping ok
  2483    [    3.872096] gx-sound-card sound: i2s-hifi <-> c1105400.bus:audio-controller-2 mapping ok
  2484    [    3.879822] gx-sound-card sound: ASoC: no DMI vendor name!
  2485    [    3.886001] printk: console [netcon0] enabled
  2486    [    3.889412] netconsole: network logging started
  2487    [    3.893971] hctosys: unable to open rtc device (rtc0)
  2488    [    3.899446] ALSA device list:
  2489    [    3.901990]   #0: AMLGX
  2490    [    3.905060] Freeing unused kernel memory: 960K
  2491    [    3.908830] Run /init as init process
  2492    [    3.920322] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
  2493    [    3.926636] mmc2: queuing unknown CIS tuple 0x80 (6 bytes)
  2494    [    3.933204] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
  2495    [    3.945335] mmc2: queuing unknown CIS tuple 0x80 (19 bytes)
  2496    [    3.972003] random: fast init done
  2497    [    4.036841] mmc2: new high speed SDIO card at address 0001
  2498    [    4.074598] usb 1-1: new high-speed USB device number 2 using xhci-hcd
  2499    [    4.095827] usb 1-1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.36
  2500    [    4.102693] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
  2501    [    4.110264] usb 1-1: Product: USB2.0 Hub
  2502    [    4.177263] hub 1-1:1.0: USB hub found
  2503    [    4.179875] hub 1-1:1.0: 4 ports detected
  2504    [    4.310595] usb 1-2: new high-speed USB device number 3 using xhci-hcd
  2505    [    4.341103] usb 1-2: New USB device found, idVendor=148f, idProduct=7601, bcdDevice= 0.00
  2506    [    4.348045] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
  2507    [    4.358711] usb 1-2: Product: 802.11 n WLAN
  2508    [    4.362184] usb 1-2: Manufacturer: MediaTek
  2509    [    4.365243] usb 1-2: SerialNumber: 1.0
  2510    [    5.767106] EXT4-fs (mmcblk0p2): mounted filesystem with writeback data mode. Opts: data=writeback
  2511    [    6.716386] systemd[1]: System time before build time, advancing clock.
  2512    [    6.862930] NET: Registered protocol family 10
  2513    [    6.937655] Segment Routing with IPv6
  2514    [    6.989321] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
  2515    [    7.024610] systemd[1]: Detected architecture arm64.
  2516    [    7.078067] systemd[1]: Set hostname to <mxqpro>.
  2517    [    7.108068] systemd[1]: Couldn't move remaining userspace processes, ignoring: Input/output error
  2518    [    7.822405] random: systemd: uninitialized urandom read (16 bytes read)
  2519    [    7.835139] random: systemd: uninitialized urandom read (16 bytes read)
  2520    [    7.839481] systemd[1]: Listening on udev Kernel Socket.
  2521    [    7.846966] random: systemd: uninitialized urandom read (16 bytes read)
  2522    [    7.850893] systemd[1]: Listening on initctl Compatibility Named Pipe.
  2523    [    7.859927] systemd[1]: Reached target System Time Synchronized.
  2524    [    7.866451] systemd[1]: Listening on Journal Socket.
  2525    [    7.891079] systemd[1]: Starting Set the console keyboard layout...
  2526    [    7.901680] systemd[1]: Mounting Huge Pages File System...
  2527    [    8.066045] EXT4-fs (mmcblk0p2): re-mounted. Opts: commit=600,errors=remount-ro
  2528    [    8.369388] systemd-journald[416]: Received request to flush runtime journal from PID 1
  2529    [    8.796070] mc: Linux media interface: v0.10
  2530    [    8.830991] videodev: Linux video capture interface: v2.00
  2531    [    8.883011] Registered IR keymap rc-empty
  2532    [    8.883125] rc rc0: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0
  2533    [    8.883217] input: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0/input0
  2534    [    8.883527] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
  2535    [    8.883735] meson-ir c8100580.ir: receiver initialized
  2536    [    9.043577] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
  2537    [    9.060891] Bluetooth: Core ver 2.22
  2538    [    9.067627] NET: Registered protocol family 31
  2539    [    9.069981] Bluetooth: HCI device and connection manager initialized
  2540    [    9.075308] Bluetooth: HCI socket layer initialized
  2541    [    9.080002] Bluetooth: L2CAP socket layer initialized
  2542    [    9.081040] lima d00c0000.gpu: IRQ ppmmu3 not found
  2543    [    9.086296] Bluetooth: SCO socket layer initialized
  2544    [    9.091519] lima d00c0000.gpu: IRQ ppmmu4 not found
  2545    [    9.099899] lima d00c0000.gpu: IRQ ppmmu5 not found
  2546    [    9.114758] lima d00c0000.gpu: IRQ ppmmu6 not found
  2547    [    9.123908] lima d00c0000.gpu: IRQ ppmmu7 not found
  2548    [    9.126204] lima d00c0000.gpu: gp - mali450 version major 0 minor 0
  2549    [    9.134190] lima d00c0000.gpu: pp0 - mali450 version major 0 minor 0
  2550    [    9.138418] lima d00c0000.gpu: pp1 - mali450 version major 0 minor 0
  2551    [    9.145016] lima d00c0000.gpu: pp2 - mali450 version major 0 minor 0
  2552    [    9.154102] lima d00c0000.gpu: IRQ pp3 not found
  2553    [    9.157559] lima d00c0000.gpu: IRQ pp4 not found
  2554    [    9.160780] lima d00c0000.gpu: IRQ pp5 not found
  2555    [    9.165780] lima d00c0000.gpu: IRQ pp6 not found
  2556    [    9.170690] lima d00c0000.gpu: IRQ pp7 not found
  2557    [    9.174623] lima d00c0000.gpu: l2 cache 8K, 4-way, 64byte cache line, 128bit external bus
  2558    [    9.182694] lima d00c0000.gpu: l2 cache 64K, 4-way, 64byte cache line, 128bit external bus
  2559    [    9.191551] lima d00c0000.gpu: bus rate = 166666667
  2560    [    9.194479] lima d00c0000.gpu: mod rate = 744000000
  2561    [    9.202058] [drm] Initialized lima 1.0.0 20190217 for d00c0000.gpu on minor 1
  2562    [    9.262421] cfg80211: Loading compiled-in X.509 certificates for regulatory database
  2563    [    9.298592] Bluetooth: HCI UART driver ver 2.3
  2564    [    9.301253] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
  2565    [    9.308220] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
  2566    [    9.309086] Bluetooth: HCI UART protocol H4 registered
  2567    [    9.314715] cfg80211: failed to load regulatory.db
  2568    [    9.323096] Bluetooth: HCI UART protocol BCSP registered
  2569    [    9.366727] Bluetooth: HCI UART protocol LL registered
  2570    [    9.368546] Bluetooth: HCI UART protocol ATH3K registered
  2571    [    9.394317] Bluetooth: HCI UART protocol Three-wire (H5) registered
  2572    [    9.408539] Bluetooth: HCI UART protocol Intel registered
  2573    [    9.413646] hci_uart_bcm serial0-0: serial0-0 supply vbat not found, using dummy regulator
  2574    [    9.420243] hci_uart_bcm serial0-0: serial0-0 supply vddio not found, using dummy regulator
  2575    [    9.431376] Bluetooth: HCI UART protocol Broadcom registered
  2576    [    9.442681] Bluetooth: HCI UART protocol QCA registered
  2577    [    9.444862] Bluetooth: HCI UART protocol AG6XX registered
  2578    [    9.452767] Bluetooth: HCI UART protocol Marvell registered
  2579    [    9.468106] brcmfmac: F1 signature read @0x18000000=0x16034334
  2580    [    9.478721] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4334-sdio for chip BCM4334/3
  2581    [    9.486437] usbcore: registered new interface driver brcmfmac
  2582    [    9.533602] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.amlogic,p212.txt failed with error -2
  2583    [    9.545525] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.txt failed with error -2
  2584    [    9.566965] usb 1-2: reset high-speed USB device number 3 using xhci-hcd
  2585    [    9.604605] mt7601u 1-2:1.0: ASIC revision: 76010001 MAC revision: 76010500
  2586    [    9.639613] mt7601u 1-2:1.0: EEPROM ver:0d fae:00
  2587    [    9.819587] Bluetooth: hci0: BCM: chip id 68
  2588    [    9.824102] Bluetooth: hci0: BCM: features 0x0f
  2589    [    9.829909] Bluetooth: hci0: BCM4334B0
  2590    [    9.833466] Bluetooth: hci0: BCM4334B0 (002.001.013) build 0000
  2591    [    9.837535] bluetooth hci0: Direct firmware load for brcm/BCM4334B0.hcd failed with error -2
  2592    [    9.846552] Bluetooth: hci0: BCM: Patch brcm/BCM4334B0.hcd not found
  2593    [    9.850943] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
  2594    [    9.853803] usbcore: registered new interface driver mt7601u
  2595    [   10.566663] brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x50
  2596    [   10.672746] zram: Added device: zram0
  2597    [   10.676197] zram: Added device: zram1
  2598    [   10.679381] zram: Added device: zram2
  2599    [   10.701076] meson8b-dwmac c9410000.ethernet eth0: PHY [0.e40908ff:08] driver [Meson GXL Internal PHY]
  2600    [   10.718825] meson8b-dwmac c9410000.ethernet eth0: No Safety Features support found
  2601    [   10.723273] meson8b-dwmac c9410000.ethernet eth0: PTP not supported by HW
  2602    [   10.730069] meson8b-dwmac c9410000.ethernet eth0: configuring for phy/rmii link mode
  2603    [   10.738434] zram1: detected capacity change from 0 to 912879616
  2604    [   11.380719] random: crng init done
  2605    [   11.383194] random: 7 urandom warning(s) missed due to ratelimiting
  2606    [   11.438589] Adding 891480k swap on /dev/zram1.  Priority:5 extents:1 across:891480k SSFS
  2607
  2608    ### armbian-release:
  2609
  2610    # PLEASE DO NOT EDIT THIS FILE
  2611    BOARD=aml-s9xxx
  2612    BOARD_NAME="AML-S9xxx"
  2613    BOARDFAMILY=aml-s9xxx
  2614    BUILD_REPOSITORY_URL=https://github.com/150balbes/Build-Armbian.git
  2615    BUILD_REPOSITORY_COMMIT=62b8c07-dirty
  2616    DISTRIBUTION_CODENAME=buster
  2617    DISTRIBUTION_STATUS=supported
  2618    VERSION=20.02.0-rc1.037
  2619    LINUXFAMILY=aml-s9xxx
  2620    BRANCH=current
  2621    ARCH=arm64
  2622    IMAGE_TYPE=nightly
  2623    BOARD_TYPE=conf
  2624    INITRD_ARCH=arm64
  2625    KERNEL_IMAGE_TYPE=Image
  2626
  2627    ### boot environment:
  2628
  2629    ODROIDN2-UBOOT-CONFIG
  2630    setenv env_addr 0x10400000
  2631    setenv kernel_addr 0x11000000
  2632    setenv initrd_addr 0x13000000
  2633    setenv dtb_addr 0x1000000
  2634    if test "${devtype}" = ""; then setenv devtype "mmc"; fi
  2635    load ${devtype} ${devnum} ${env_addr} uEnv.txt && env import -t ${env_addr} ${filesize}
  2636    setenv bootargs ${APPEND}
  2637    load ${devtype} ${devnum} ${kernel_addr} ${LINUX}
  2638    load ${devtype} ${devnum} ${initrd_addr} ${INITRD}
  2639    load ${devtype} ${devnum} ${dtb_addr} ${FDT}
  2640    fdt addr ${dtb_addr}
  2641    booti ${kernel_addr} ${initrd_addr} ${dtb_addr}
  2642
  2643    ### lsusb:
  2644
  2645    Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
  2646    Bus 001 Device 003: ID 148f:7601 Ralink Technology, Corp. MT7601U Wireless Adapter
  2647    Bus 001 Device 002: ID 05e3:0608 Genesys Logic, Inc. Hub
  2648    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  2649
  2650    ### lscpu:
  2651
  2652    Architecture:        aarch64
  2653    Byte Order:          Little Endian
  2654    CPU(s):              4
  2655    On-line CPU(s) list: 0-3
  2656    Thread(s) per core:  1
  2657    Core(s) per socket:  4
  2658    Socket(s):           1
  2659    Vendor ID:           ARM
  2660    Model:               4
  2661    Model name:          Cortex-A53
  2662    Stepping:            r0p4
  2663    CPU max MHz:         1512,0000
  2664    CPU min MHz:         100,0000
  2665    BogoMIPS:            48.00
  2666    L1d cache:           unknown size
  2667    L1i cache:           unknown size
  2668    L2 cache:            unknown size
  2669    Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  2670
  2671    ### cpuinfo:
  2672
  2673    processor    : 0
  2674    model name    : ARMv8 Processor rev 4 (v8l)
  2675    BogoMIPS    : 48.00
  2676    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  2677    CPU implementer    : 0x41
  2678    CPU architecture: 8
  2679    CPU variant    : 0x0
  2680    CPU part    : 0xd03
  2681    CPU revision    : 4
  2682
  2683    processor    : 1
  2684    model name    : ARMv8 Processor rev 4 (v8l)
  2685    BogoMIPS    : 48.00
  2686    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  2687    CPU implementer    : 0x41
  2688    CPU architecture: 8
  2689    CPU variant    : 0x0
  2690    CPU part    : 0xd03
  2691    CPU revision    : 4
  2692
  2693    processor    : 2
  2694    model name    : ARMv8 Processor rev 4 (v8l)
  2695    BogoMIPS    : 48.00
  2696    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  2697    CPU implementer    : 0x41
  2698    CPU architecture: 8
  2699    CPU variant    : 0x0
  2700    CPU part    : 0xd03
  2701    CPU revision    : 4
  2702
  2703    processor    : 3
  2704    model name    : ARMv8 Processor rev 4 (v8l)
  2705    BogoMIPS    : 48.00
  2706    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  2707    CPU implementer    : 0x41
  2708    CPU architecture: 8
  2709    CPU variant    : 0x0
  2710    CPU part    : 0xd03
  2711    CPU revision    : 4
  2712
  2713
  2714    ### meminfo:
  2715
  2716    MemTotal:        1782968 kB
  2717    MemFree:         1610676 kB
  2718    MemAvailable:    1666844 kB
  2719    Buffers:           11640 kB
  2720    Cached:            52980 kB
  2721    SwapCached:            0 kB
  2722    Active:            51084 kB
  2723    Inactive:          34584 kB
  2724    Active(anon):      21292 kB
  2725    Inactive(anon):     2636 kB
  2726    Active(file):      29792 kB
  2727    Inactive(file):    31948 kB
  2728    Unevictable:          16 kB
  2729    Mlocked:              16 kB
  2730    SwapTotal:        891480 kB
  2731    SwapFree:         891480 kB
  2732    Dirty:               616 kB
  2733    Writeback:             0 kB
  2734    AnonPages:         21268 kB
  2735    Mapped:            22136 kB
  2736    Shmem:              2752 kB
  2737    KReclaimable:      17544 kB
  2738    Slab:              52484 kB
  2739    SReclaimable:      17544 kB
  2740    SUnreclaim:        34940 kB
  2741    KernelStack:        2760 kB
  2742    PageTables:         1640 kB
  2743    NFS_Unstable:          0 kB
  2744    Bounce:                0 kB
  2745    WritebackTmp:          0 kB
  2746    CommitLimit:     1782964 kB
  2747    Committed_AS:      74504 kB
  2748    VmallocTotal:   135290159040 kB
  2749    VmallocUsed:       16712 kB
  2750    VmallocChunk:          0 kB
  2751    Percpu:             1264 kB
  2752    CmaTotal:         262144 kB
  2753    CmaFree:          258460 kB
  2754    HugePages_Total:       0
  2755    HugePages_Free:        0
  2756    HugePages_Rsvd:        0
  2757    HugePages_Surp:        0
  2758    Hugepagesize:       2048 kB
  2759    Hugetlb:               0 kB
  2760
  2761    ### virtual memory:
  2762
  2763    vm.admin_reserve_kbytes = 8192
  2764    vm.block_dump = 0
  2765    vm.compact_unevictable_allowed = 1
  2766    vm.dirty_background_bytes = 0
  2767    vm.dirty_background_ratio = 10
  2768    vm.dirty_bytes = 0
  2769    vm.dirty_expire_centisecs = 3000
  2770    vm.dirty_ratio = 20
  2771    vm.dirtytime_expire_seconds = 43200
  2772    vm.dirty_writeback_centisecs = 500
  2773    vm.extfrag_threshold = 500
  2774    vm.hugetlb_shm_group = 0
  2775    vm.laptop_mode = 0
  2776    vm.legacy_va_layout = 0
  2777    vm.lowmem_reserve_ratio = 256    256    32    0
  2778    vm.max_map_count = 65530
  2779    vm.min_free_kbytes = 4914
  2780    vm.mmap_min_addr = 4096
  2781    vm.mmap_rnd_bits = 18
  2782    vm.nr_hugepages = 0
  2783    vm.nr_overcommit_hugepages = 0
  2784    vm.oom_dump_tasks = 1
  2785    vm.oom_kill_allocating_task = 0
  2786    vm.overcommit_kbytes = 0
  2787    vm.overcommit_memory = 0
  2788    vm.overcommit_ratio = 50
  2789    vm.page-cluster = 0
  2790    vm.panic_on_oom = 0
  2791    vm.percpu_pagelist_fraction = 0
  2792    vm.stat_interval = 1
  2793    vm.swappiness = 100
  2794    vm.user_reserve_kbytes = 55239
  2795    vm.vfs_cache_pressure = 100
  2796    vm.watermark_boost_factor = 15000
  2797    vm.watermark_scale_factor = 10
  2798
  2799    ### ip addr:
  2800
  2801    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
  2802        link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  2803        inet XXX.XXX.0.1/8 scope host lo
  2804           valid_lft forever preferred_lft forever
  2805        inet6 ::1/128 scope host
  2806           valid_lft forever preferred_lft forever
  2807    2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
  2808        link/ether 00:df:06:00:00:0b brd ff:ff:ff:ff:ff:ff
  2809    3: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  2810        link/ether 00:36:76:61:0b:24 brd ff:ff:ff:ff:ff:ff
  2811
  2812    ### partitions:
  2813
  2814    major minor  #blocks  name
  2815
  2816     179        0   30924800 mmcblk0
  2817     179        1     262144 mmcblk0p1
  2818     179        2   30337024 mmcblk0p2
  2819     179       32   15384576 mmcblk1
  2820     179      128       8192 mmcblk1gp0
  2821     254        1     891484 zram1
  2822
  2823    ### df:
  2824
  2825    udev             738M      0  738M   0% /dev
  2826    tmpfs            175M   2,7M  172M   2% /run
  2827    /dev/mmcblk0p2    29G    10G   19G  36% /
  2828    tmpfs            871M      0  871M   0% /dev/shm
  2829    tmpfs            5,0M   4,0K  5,0M   1% /run/lock
  2830    tmpfs            871M      0  871M   0% /sys/fs/cgroup
  2831    tmpfs            871M      0  871M   0% /tmp
  2832    /dev/mmcblk0p1   256M    76M  180M  30% /boot
  2833
  2834    ### lsblk:
  2835
  2836    NAME         FSTYPE   SIZE MOUNTPOINT UUID
  2837    mmcblk0              29,5G
  2838    ├─mmcblk0p1  vfat     256M /boot      50FC-6AC8
  2839    └─mmcblk0p2  ext4      29G /          3e297ac1-e4e4-4ab1-bc57-47c07d0422ba
  2840    mmcblk1              14,7G
  2841    mmcblk1boot0            4M
  2842    mmcblk1boot1            4M
  2843    mmcblk1gp0              8M
  2844
  2845    ### zramctl:
  2846
  2847    NAME       ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT
  2848    /dev/zram1 lzo         870,6M   4K   81B   12K       4 [SWAP]
  2849
  2850    ### mtab:
  2851
  2852    /dev/mmcblk0p1 /boot vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro 0 0
  2853    /dev/mmcblk0p2 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  2854
  2855    ### mmc0:59b4 info:
  2856
  2857                   fwrev: 0x0
  2858                  uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SDU1  MODALIAS=mmc:block
  2859                     cid: 1b534d53445531201014a136d4013800
  2860                     rca: 0x59b4
  2861                     csd: 400e00325b590000ebef7f800a400000
  2862                  manfid: 0x00001b
  2863                     ocr: 0x00200000
  2864    preferred_erase_size: 4194304
  2865                    type: SD
  2866                   hwrev: 0x1
  2867                    date: 08/2019
  2868                     dsr: 0x404
  2869              erase_size: 512
  2870                   oemid: 0x534d
  2871                  serial: 0x14a136d4
  2872                     ssr: 0000000005000000040090000811391e00089a342f01000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  2873                     scr: 0235844300000000
  2874                    name: SDU1
  2875
  2876    ### mmc1:0001 info:
  2877
  2878                   fwrev: 0x0
  2879                  uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=016G92 MODALIAS=mmc:block
  2880                     cid: 11010030313647393201d3d1a4db1100
  2881             rel_sectors: 0x10
  2882                     rca: 0x0001
  2883            pre_eol_info: 0x00
  2884                     csd: d00e00320f5903ffffffffef92400000
  2885                  manfid: 0x000011
  2886                     ocr: 0x00200000
  2887    preferred_erase_size: 4194304
  2888    enhanced_area_offset: 18446744073709551594
  2889      raw_rpmb_size_mult: 0x4
  2890                    type: MMC
  2891                   hwrev: 0x0
  2892                    date: 01/2014
  2893                     prv: 0x1
  2894             ffu_capable: 0
  2895                     dsr: 0x404
  2896              erase_size: 4194304
  2897               life_time: 0x00 0x00
  2898      enhanced_area_size: 4294967274
  2899                   oemid: 0x0100
  2900                  serial: 0xd3d1a4db
  2901                 cmdq_en: 0
  2902                     rev: 0x6
  2903                    name: 016G92
  2904
  2905    ### Boot system health:
  2906
  2907    Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU
  2908    09:17:07: 1512MHz  0.62  50%  24%  14%   0%  10%   1% 57.0°C
  2909    09:17:07: 1512MHz  0.62  64%   6%  10%   0%  44%   1% 57.0°C
  2910    09:17:07: 1512MHz  0.62  70%  10%  22%   2%  34%   2% 57.0°C
  2911    09:17:08: 1512MHz  0.89  56%   9%  13%   0%  30%   1% 57.0°C
  2912    09:17:08: 1512MHz  0.89  33%   5%   4%   1%  20%   1% 56.0°C
  2913
  2914    ### Activated 1 lzo zram swap devices with 870 MB each
  2915
  2916
  2917    mar mar 23 21:19:42 CET 2021 | AML-S9xxx | 20.02.0-rc1.037 | arm64 | aarch64 | 5.5.0-rc6-aml-s9xxx
  2918
  2919    ### dmesg:
  2920
  2921    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
  2922    [    0.000000] Linux version 5.5.0-rc6-aml-s9xxx (root@vbox) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #rc1.037 SMP PREEMPT Wed Feb 5 15:59:04 MSK 2020
  2923    [    0.000000] Machine model: Amlogic Meson GXL (S905X) P212 Development Board
  2924    [    0.000000] efi: Getting EFI parameters from FDT:
  2925    [    0.000000] efi: UEFI not found.
  2926    [    0.000000] Reserved memory: created CMA memory pool at 0x0000000063400000, size 256 MiB
  2927    [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
  2928    [    0.000000] On node 0 totalpages: 477952
  2929    [    0.000000]   DMA zone: 4032 pages used for memmap
  2930    [    0.000000]   DMA zone: 0 pages reserved
  2931    [    0.000000]   DMA zone: 248576 pages, LIFO batch:63
  2932    [    0.000000]   DMA32 zone: 3584 pages used for memmap
  2933    [    0.000000]   DMA32 zone: 229376 pages, LIFO batch:63
  2934    [    0.000000] psci: probing for conduit method from DT.
  2935    [    0.000000] psci: PSCIv0.2 detected in firmware.
  2936    [    0.000000] psci: Using standard PSCI v0.2 function IDs
  2937    [    0.000000] psci: Trusted OS migration not required
  2938    [    0.000000] percpu: Embedded 22 pages/cpu s50392 r8192 d31528 u90112
  2939    [    0.000000] pcpu-alloc: s50392 r8192 d31528 u90112 alloc=22*4096
  2940    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
  2941    [    0.000000] Detected VIPT I-cache on CPU0
  2942    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 470336
  2943    [    0.000000] Kernel command line: root=LABEL=ROOTFS rootflags=data=writeback rw console=ttyAML0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 mac=00:df:06:00:00:0b
  2944    [    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
  2945    [    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
  2946    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
  2947    [    0.000000] software IO TLB: mapped [mem 0x3bfff000-0x3ffff000] (64MB)
  2948    [    0.000000] Memory: 1509616K/1911808K available (14460K kernel code, 1434K rwdata, 5884K rodata, 960K init, 927K bss, 140048K reserved, 262144K cma-reserved)
  2949    [    0.000000] random: get_random_u64 called from cache_random_seq_create+0x7c/0x150 with crng_init=0
  2950    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
  2951    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
  2952    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
  2953    [    0.000000]     Tasks RCU enabled.
  2954    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
  2955    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
  2956    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
  2957    [    0.000000] GIC: Using split EOI/Deactivate mode
  2958    [    0.000000] irq_meson_gpio: 110 to 8 gpio interrupt mux initialized
  2959    [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
  2960    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
  2961    [    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
  2962    [    0.000355] Console: colour dummy device 80x25
  2963    [    0.000657] printk: console [tty0] enabled
  2964    [    0.000697] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
  2965    [    0.000718] pid_max: default: 32768 minimum: 301
  2966    [    0.000841] LSM: Security Framework initializing
  2967    [    0.000892] SELinux:  Initializing.
  2968    [    0.000969] *** VALIDATE SELinux ***
  2969    [    0.001035] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
  2970    [    0.001061] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
  2971    [    0.001123] *** VALIDATE tmpfs ***
  2972    [    0.001531] *** VALIDATE proc ***
  2973    [    0.001753] *** VALIDATE cgroup1 ***
  2974    [    0.001768] *** VALIDATE cgroup2 ***
  2975    [    0.024018] ASID allocator initialised with 32768 entries
  2976    [    0.032003] rcu: Hierarchical SRCU implementation.
  2977    [    0.042089] EFI services will not be available.
  2978    [    0.048059] smp: Bringing up secondary CPUs ...
  2979    [    0.080286] Detected VIPT I-cache on CPU1
  2980    [    0.080340] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
  2981    [    0.112325] Detected VIPT I-cache on CPU2
  2982    [    0.112371] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
  2983    [    0.144375] Detected VIPT I-cache on CPU3
  2984    [    0.144415] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
  2985    [    0.144492] smp: Brought up 1 node, 4 CPUs
  2986    [    0.144559] SMP: Total of 4 processors activated.
  2987    [    0.144570] CPU features: detected: 32-bit EL0 Support
  2988    [    0.144582] CPU features: detected: CRC32 instructions
  2989    [    0.144885] CPU: All CPU(s) started at EL2
  2990    [    0.144908] alternatives: patching kernel code
  2991    [    0.146007] devtmpfs: initialized
  2992    [    0.151117] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
  2993    [    0.151158] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
  2994    [    0.158013] xor: measuring software checksum speed
  2995    [    0.196376]    8regs     :  2375.000 MB/sec
  2996    [    0.236407]    32regs    :  2724.000 MB/sec
  2997    [    0.276446]    arm64_neon:  2406.000 MB/sec
  2998    [    0.276456] xor: using function: 32regs (2724.000 MB/sec)
  2999    [    0.276513] pinctrl core: initialized pinctrl subsystem
  3000    [    0.277174] thermal_sys: Registered thermal governor 'step_wise'
  3001    [    0.277340] DMI not present or invalid.
  3002    [    0.277701] NET: Registered protocol family 16
  3003    [    0.281251] DMA: preallocated 256 KiB pool for atomic allocations
  3004    [    0.281299] audit: initializing netlink subsys (disabled)
  3005    [    0.281513] audit: type=2000 audit(0.280:1): state=initialized audit_enabled=0 res=1
  3006    [    0.282591] cpuidle: using governor ladder
  3007    [    0.282633] cpuidle: using governor menu
  3008    [    0.283004] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
  3009    [    0.283717] Serial: AMBA PL011 UART driver
  3010    [    0.297724] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
  3011    [    0.297751] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
  3012    [    0.297764] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
  3013    [    0.297777] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
  3014    [    0.301295] cryptd: max_cpu_qlen set to 1000
  3015    [    0.376682] raid6: neonx8   gen()  1621 MB/s
  3016    [    0.444706] raid6: neonx8   xor()  1493 MB/s
  3017    [    0.512771] raid6: neonx4   gen()  1563 MB/s
  3018    [    0.580813] raid6: neonx4   xor()  1469 MB/s
  3019    [    0.648868] raid6: neonx2   gen()  1200 MB/s
  3020    [    0.716918] raid6: neonx2   xor()  1217 MB/s
  3021    [    0.784985] raid6: neonx1   gen()   788 MB/s
  3022    [    0.853045] raid6: neonx1   xor()   914 MB/s
  3023    [    0.921081] raid6: int64x8  gen()  1194 MB/s
  3024    [    0.989136] raid6: int64x8  xor()   769 MB/s
  3025    [    1.057201] raid6: int64x4  gen()  1029 MB/s
  3026    [    1.125252] raid6: int64x4  xor()   752 MB/s
  3027    [    1.193278] raid6: int64x2  gen()   728 MB/s
  3028    [    1.261329] raid6: int64x2  xor()   618 MB/s
  3029    [    1.329460] raid6: int64x1  gen()   486 MB/s
  3030    [    1.397431] raid6: int64x1  xor()   468 MB/s
  3031    [    1.397441] raid6: using algorithm neonx8 gen() 1621 MB/s
  3032    [    1.397451] raid6: .... xor() 1493 MB/s, rmw enabled
  3033    [    1.397467] raid6: using neon recovery algorithm
  3034    [    1.397715] ACPI: Interpreter disabled.
  3035    [    1.398887] iommu: Default domain type: Translated
  3036    [    1.399164] vgaarb: loaded
  3037    [    1.399744] SCSI subsystem initialized
  3038    [    1.399927] libata version 3.00 loaded.
  3039    [    1.400133] usbcore: registered new interface driver usbfs
  3040    [    1.400178] usbcore: registered new interface driver hub
  3041    [    1.400241] usbcore: registered new device driver usb
  3042    [    1.400645] pps_core: LinuxPPS API ver. 1 registered
  3043    [    1.400658] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
  3044    [    1.400680] PTP clock support registered
  3045    [    1.400707] EDAC MC: Ver: 3.0.0
  3046    [    1.401303] FPGA manager framework
  3047    [    1.401392] Advanced Linux Sound Architecture Driver Initialized.
  3048    [    1.401881] NetLabel: Initializing
  3049    [    1.401895] NetLabel:  domain hash size = 128
  3050    [    1.401904] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
  3051    [    1.401957] NetLabel:  unlabeled traffic allowed by default
  3052    [    1.402438] clocksource: Switched to clocksource arch_sys_counter
  3053    [    1.402460] *** VALIDATE bpf ***
  3054    [    1.402710] VFS: Disk quotas dquot_6.6.0
  3055    [    1.402769] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
  3056    [    1.402892] FS-Cache: Loaded
  3057    [    1.402903] *** VALIDATE ramfs ***
  3058    [    1.402925] *** VALIDATE hugetlbfs ***
  3059    [    1.403296] pnp: PnP ACPI: disabled
  3060    [    1.408322] NET: Registered protocol family 2
  3061    [    1.408821] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
  3062    [    1.408871] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
  3063    [    1.408988] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
  3064    [    1.409233] TCP: Hash tables configured (established 16384 bind 16384)
  3065    [    1.409395] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
  3066    [    1.409450] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
  3067    [    1.409667] NET: Registered protocol family 1
  3068    [    1.410120] RPC: Registered named UNIX socket transport module.
  3069    [    1.410140] RPC: Registered udp transport module.
  3070    [    1.410149] RPC: Registered tcp transport module.
  3071    [    1.410159] RPC: Registered tcp NFSv4.1 backchannel transport module.
  3072    [    1.410175] NET: Registered protocol family 44
  3073    [    1.410196] PCI: CLS 0 bytes, default 64
  3074    [    1.410388] Trying to unpack rootfs image as initramfs...
  3075    [    1.871864] Freeing initrd memory: 10248K
  3076    [    1.872664] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
  3077    [    2.086306] Initialise system trusted keyrings
  3078    [    2.086595] workingset: timestamp_bits=46 max_order=19 bucket_order=0
  3079    [    2.091765] zbud: loaded
  3080    [    2.093008] squashfs: version 4.0 (2009/01/31) Phillip Lougher
  3081    [    2.093291] FS-Cache: Netfs 'nfs' registered for caching
  3082    [    2.093830] NFS: Registering the id_resolver key type
  3083    [    2.093870] Key type id_resolver registered
  3084    [    2.093880] Key type id_legacy registered
  3085    [    2.093896] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
  3086    [    2.093908] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
  3087    [    2.095063] FS-Cache: Netfs 'cifs' registered for caching
  3088    [    2.095384] Key type cifs.spnego registered
  3089    [    2.095403] Key type cifs.idmap registered
  3090    [    2.095425] ntfs: driver 2.1.32 [Flags: R/W].
  3091    [    2.095992] JFS: nTxBlock = 8192, nTxLock = 65536
  3092    [    2.101852] SGI XFS with ACLs, security attributes, realtime, quota, no debug enabled
  3093    [    2.103292] *** VALIDATE xfs ***
  3094    [    2.103576] ocfs2: Registered cluster interface o2cb
  3095    [    2.103788] OCFS2 User DLM kernel interface loaded
  3096    [    2.105194] *** VALIDATE gfs2 ***
  3097    [    2.105475] gfs2: GFS2 installed
  3098    [    2.106400] aufs 5.5-20200203
  3099    [    2.126670] Key type asymmetric registered
  3100    [    2.126695] Asymmetric key parser 'x509' registered
  3101    [    2.126706] Asymmetric key parser 'pkcs8' registered
  3102    [    2.126775] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
  3103    [    2.126970] io scheduler mq-deadline registered
  3104    [    2.126984] io scheduler kyber registered
  3105    [    2.127183] io scheduler bfq registered
  3106    [    2.139800] soc soc0: Amlogic Meson GXL (S905X) Revision 21:b (82:2) Detected
  3107    [    2.143368] Serial: 8250/16550 driver, 5 ports, IRQ sharing enabled
  3108    [    2.145047] Serial: AMBA driver
  3109    [    2.145418] c11084c0.serial: ttyAML6 at MMIO 0xc11084c0 (irq = 10, base_baud = 1500000) is a meson_uart
  3110    [    2.145573] serial serial0: tty port ttyAML6 registered
  3111    [    2.145782] c81004c0.serial: ttyAML0 at MMIO 0xc81004c0 (irq = 13, base_baud = 1500000) is a meson_uart
  3112    [    3.121269] printk: console [ttyAML0] enabled
  3113    [    3.137363] brd: module loaded
  3114    [    3.145840] loop: module loaded
  3115    [    3.148319] libphy: Fixed MDIO Bus: probed
  3116    [    3.148969] meson8b-dwmac c9410000.ethernet: IRQ eth_wake_irq not found
  3117    [    3.154019] meson8b-dwmac c9410000.ethernet: IRQ eth_lpi not found
  3118    [    3.160213] meson8b-dwmac c9410000.ethernet: PTP uses main clock
  3119    [    3.166069] meson8b-dwmac c9410000.ethernet: no reset control found
  3120    [    3.172767] meson8b-dwmac c9410000.ethernet: User ID: 0x11, Synopsys ID: 0x37
  3121    [    3.179371] meson8b-dwmac c9410000.ethernet:     DWMAC1000
  3122    [    3.184538] meson8b-dwmac c9410000.ethernet: DMA HW capability register supported
  3123    [    3.191939] meson8b-dwmac c9410000.ethernet: RX Checksum Offload Engine supported
  3124    [    3.199356] meson8b-dwmac c9410000.ethernet: COE Type 2
  3125    [    3.204529] meson8b-dwmac c9410000.ethernet: TX Checksum insertion supported
  3126    [    3.211515] meson8b-dwmac c9410000.ethernet: Wake-Up On Lan supported
  3127    [    3.217929] meson8b-dwmac c9410000.ethernet: Normal descriptors
  3128    [    3.223764] meson8b-dwmac c9410000.ethernet: Ring mode enabled
  3129    [    3.229541] meson8b-dwmac c9410000.ethernet: Enable RX Mitigation via HW Watchdog Timer
  3130    [    3.237658] libphy: stmmac: probed
  3131    [    3.242151] VFIO - User Level meta-driver version: 0.3
  3132    [    3.247500] dwc3 c9000000.dwc3: Failed to get clk 'ref': -2
  3133    [    3.252360] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
  3134    [    3.257950] ehci-pci: EHCI PCI platform driver
  3135    [    3.262384] ehci-platform: EHCI generic platform driver
  3136    [    3.267686] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
  3137    [    3.273632] ohci-pci: OHCI PCI platform driver
  3138    [    3.278060] ohci-platform: OHCI generic platform driver
  3139    [    3.283798] usbcore: registered new interface driver usb-storage
  3140    [    3.289396] mousedev: PS/2 mouse device common for all mice
  3141    [    3.295328] i2c /dev entries driver
  3142    [    3.300944] sdhci: Secure Digital Host Controller Interface driver
  3143    [    3.304251] sdhci: Copyright(c) Pierre Ossman
  3144    [    3.308566] Synopsys Designware Multimedia Card Interface Driver
  3145    [    3.315828] meson-gx-mmc d0072000.mmc: Got CD GPIO
  3146    [    3.346475] meson-gx-mmc d0074000.mmc: allocated mmc-pwrseq
  3147    [    3.377729] sdhci-pltfm: SDHCI platform and OF driver helper
  3148    [    3.378609] ledtrig-cpu: registered to indicate activity on CPUs
  3149    [    3.384289] meson-sm: secure-monitor enabled
  3150    [    3.386108] mmc0: new high speed SDHC card at address 59b4
  3151    [    3.388806] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
  3152    [    3.398316] mmcblk0: mmc0:59b4 SDU1  29.5 GiB
  3153    [    3.401395] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
  3154    [    3.416240]  mmcblk0: p1 p2
  3155    [    3.428925] hid: raw HID events driver (C) Jiri Kosina
  3156    [    3.429163] usbcore: registered new interface driver usbhid
  3157    [    3.433982] usbhid: USB HID core driver
  3158    [    3.438122] platform-mhu c883c404.mailbox: Platform MHU Mailbox registered
  3159    [    3.454817] NET: Registered protocol family 17
  3160    [    3.455072] Key type dns_resolver registered
  3161    [    3.458374] registered taskstats version 1
  3162    [    3.461943] Loading compiled-in X.509 certificates
  3163    [    3.466872] zswap: loaded using pool lzo/zbud
  3164    [    3.471179] Key type ._fscrypt registered
  3165    [    3.474951] Key type .fscrypt registered
  3166    [    3.480317] Btrfs loaded, crc32c=crc32c-generic
  3167    [    3.500162] mmc1: new HS200 MMC card at address 0001
  3168    [    3.501003] mmcblk1: mmc1:0001 016G92 14.7 GiB
  3169    [    3.504604] mmcblk1boot0: mmc1:0001 016G92 partition 1 4.00 MiB
  3170    [    3.510331] mmcblk1boot1: mmc1:0001 016G92 partition 2 4.00 MiB
  3171    [    3.510548] Key type encrypted registered
  3172    [    3.516162] mmcblk1gp0: mmc1:0001 016G92 partition 4 8.00 MiB
  3173    [    3.525704] mmcblk1rpmb: mmc1:0001 016G92 partition 3 512 KiB, chardev (243:0)
  3174    [    3.539703] meson-drm d0100000.vpu: Queued 3 outputs on vpu
  3175    [    3.540066] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
  3176    [    3.546244] [drm] No driver support for vblank timestamp query.
  3177    [    3.582486] meson-dw-hdmi c883a000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
  3178    [    3.587175] meson-dw-hdmi c883a000.hdmi-tx: registered DesignWare HDMI I2C bus driver
  3179    [    3.595134] meson-drm d0100000.vpu: bound c883a000.hdmi-tx (ops meson_dw_hdmi_ops)
  3180    [    3.602524] [drm] Initialized meson 1.0.0 20161109 for d0100000.vpu on minor 0
  3181    [    3.654111] Console: switching to colour frame buffer device 90x36
  3182    [    3.674471] meson-drm d0100000.vpu: fb0: mesondrmfb frame buffer device
  3183    [    3.681729] libphy: mdio_mux: probed
  3184    [    3.692306] libphy: mdio_mux: probed
  3185    [    3.692784] phy phy-d0078080.phy.2: unsupported PHY mode 5
  3186    [    3.697838] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  3187    [    3.701238] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
  3188    [    3.708956] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228f664 hci version 0x100 quirks 0x0000000002010010
  3189    [    3.718176] xhci-hcd xhci-hcd.0.auto: irq 39, io mem 0xc9000000
  3190    [    3.724300] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.05
  3191    [    3.732533] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  3192    [    3.739680] usb usb1: Product: xHCI Host Controller
  3193    [    3.744508] usb usb1: Manufacturer: Linux 5.5.0-rc6-aml-s9xxx xhci-hcd
  3194    [    3.750977] usb usb1: SerialNumber: xhci-hcd.0.auto
  3195    [    3.756314] hub 1-0:1.0: USB hub found
  3196    [    3.759557] hub 1-0:1.0: 2 ports detected
  3197    [    3.763784] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  3198    [    3.768936] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
  3199    [    3.776520] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
  3200    [    3.783023] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
  3201    [    3.791282] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.05
  3202    [    3.799659] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  3203    [    3.806815] usb usb2: Product: xHCI Host Controller
  3204    [    3.811644] usb usb2: Manufacturer: Linux 5.5.0-rc6-aml-s9xxx xhci-hcd
  3205    [    3.818118] usb usb2: SerialNumber: xhci-hcd.0.auto
  3206    [    3.823409] hub 2-0:1.0: USB hub found
  3207    [    3.826691] hub 2-0:1.0: config failed, hub doesn't have any ports! (err -19)
  3208    [    3.835635] meson-gx-mmc d0070000.mmc: allocated mmc-pwrseq
  3209    [    3.866756] scpi_protocol scpi: SCP Protocol legacy pre-1.0 firmware
  3210    [    3.881694] gx-sound-card sound: snd-soc-dummy-dai <-> c1105400.bus:audio-controller-0 mapping ok
  3211    [    3.893501] gx-sound-card sound: i2s-hifi <-> c1105400.bus:audio-controller-2 mapping ok
  3212    [    3.906981] gx-sound-card sound: ASoC: no DMI vendor name!
  3213    [    3.914094] printk: console [netcon0] enabled
  3214    [    3.916762] netconsole: network logging started
  3215    [    3.921257] hctosys: unable to open rtc device (rtc0)
  3216    [    3.926646] ALSA device list:
  3217    [    3.929147]   #0: AMLGX
  3218    [    3.932152] Freeing unused kernel memory: 960K
  3219    [    3.936019] Run /init as init process
  3220    [    3.952150] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
  3221    [    3.958983] mmc2: queuing unknown CIS tuple 0x80 (6 bytes)
  3222    [    3.966057] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
  3223    [    3.978108] mmc2: queuing unknown CIS tuple 0x80 (19 bytes)
  3224    [    4.004629] random: fast init done
  3225    [    4.063607] mmc2: new high speed SDIO card at address 0001
  3226    [    4.106519] usb 1-1: new high-speed USB device number 2 using xhci-hcd
  3227    [    4.127848] usb 1-1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.36
  3228    [    4.135524] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
  3229    [    4.141775] usb 1-1: Product: USB2.0 Hub
  3230    [    4.199533] hub 1-1:1.0: USB hub found
  3231    [    4.202102] hub 1-1:1.0: 4 ports detected
  3232    [    4.338530] usb 1-2: new high-speed USB device number 3 using xhci-hcd
  3233    [    4.368971] usb 1-2: New USB device found, idVendor=148f, idProduct=7601, bcdDevice= 0.00
  3234    [    4.376432] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
  3235    [    4.390570] usb 1-2: Product: 802.11 n WLAN
  3236    [    4.392787] usb 1-2: Manufacturer: MediaTek
  3237    [    4.395474] usb 1-2: SerialNumber: 1.0
  3238    [    5.099822] EXT4-fs (mmcblk0p2): mounted filesystem with writeback data mode. Opts: data=writeback
  3239    [    6.048820] systemd[1]: System time before build time, advancing clock.
  3240    [    6.196333] NET: Registered protocol family 10
  3241    [    6.270105] Segment Routing with IPv6
  3242    [    6.320855] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
  3243    [    6.354372] systemd[1]: Detected architecture arm64.
  3244    [    6.407432] systemd[1]: Set hostname to <mxqpro>.
  3245    [    6.440906] systemd[1]: Couldn't move remaining userspace processes, ignoring: Input/output error
  3246    [    7.139111] random: systemd: uninitialized urandom read (16 bytes read)
  3247    [    7.151443] random: systemd: uninitialized urandom read (16 bytes read)
  3248    [    7.155058] systemd[1]: Reached target Swap.
  3249    [    7.162373] random: systemd: uninitialized urandom read (16 bytes read)
  3250    [    7.166618] systemd[1]: Listening on Journal Socket.
  3251    [    7.179338] systemd[1]: Mounting Huge Pages File System...
  3252    [    7.185005] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
  3253    [    7.193947] systemd[1]: Created slice User and Session Slice.
  3254    [    7.204144] systemd[1]: Starting Restore / save the current clock...
  3255    [    7.347072] EXT4-fs (mmcblk0p2): re-mounted. Opts: commit=600,errors=remount-ro
  3256    [    7.629413] systemd-journald[414]: Received request to flush runtime journal from PID 1
  3257    [    8.162338] Registered IR keymap rc-empty
  3258    [    8.167562] rc rc0: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0
  3259    [    8.167715] input: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0/input0
  3260    [    8.168779] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
  3261    [    8.168977] meson-ir c8100580.ir: receiver initialized
  3262    [    8.197964] mc: Linux media interface: v0.10
  3263    [    8.225407] videodev: Linux video capture interface: v2.00
  3264    [    8.337571] Bluetooth: Core ver 2.22
  3265    [    8.341132] NET: Registered protocol family 31
  3266    [    8.344095] Bluetooth: HCI device and connection manager initialized
  3267    [    8.348947] Bluetooth: HCI socket layer initialized
  3268    [    8.353709] Bluetooth: L2CAP socket layer initialized
  3269    [    8.359498] Bluetooth: SCO socket layer initialized
  3270    [    8.360538] lima d00c0000.gpu: IRQ ppmmu3 not found
  3271    [    8.368178] lima d00c0000.gpu: IRQ ppmmu4 not found
  3272    [    8.372908] lima d00c0000.gpu: IRQ ppmmu5 not found
  3273    [    8.377853] lima d00c0000.gpu: IRQ ppmmu6 not found
  3274    [    8.382529] lima d00c0000.gpu: IRQ ppmmu7 not found
  3275    [    8.387445] lima d00c0000.gpu: gp - mali450 version major 0 minor 0
  3276    [    8.395703] lima d00c0000.gpu: pp0 - mali450 version major 0 minor 0
  3277    [    8.401955] lima d00c0000.gpu: pp1 - mali450 version major 0 minor 0
  3278    [    8.408416] lima d00c0000.gpu: pp2 - mali450 version major 0 minor 0
  3279    [    8.414739] lima d00c0000.gpu: IRQ pp3 not found
  3280    [    8.417351] lima d00c0000.gpu: IRQ pp4 not found
  3281    [    8.424486] lima d00c0000.gpu: IRQ pp5 not found
  3282    [    8.427863] lima d00c0000.gpu: IRQ pp6 not found
  3283    [    8.432895] lima d00c0000.gpu: IRQ pp7 not found
  3284    [    8.436839] lima d00c0000.gpu: l2 cache 8K, 4-way, 64byte cache line, 128bit external bus
  3285    [    8.444957] lima d00c0000.gpu: l2 cache 64K, 4-way, 64byte cache line, 128bit external bus
  3286    [    8.453791] lima d00c0000.gpu: bus rate = 166666667
  3287    [    8.456591] lima d00c0000.gpu: mod rate = 744000000
  3288    [    8.466237] [drm] Initialized lima 1.0.0 20190217 for d00c0000.gpu on minor 1
  3289    [    8.578496] Bluetooth: HCI UART driver ver 2.3
  3290    [    8.580103] Bluetooth: HCI UART protocol H4 registered
  3291    [    8.590577] Bluetooth: HCI UART protocol BCSP registered
  3292    [    8.592215] Bluetooth: HCI UART protocol LL registered
  3293    [    8.604950] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
  3294    [    8.607957] Bluetooth: HCI UART protocol ATH3K registered
  3295    [    8.625058] Bluetooth: HCI UART protocol Three-wire (H5) registered
  3296    [    8.641264] cfg80211: Loading compiled-in X.509 certificates for regulatory database
  3297    [    8.671320] Bluetooth: HCI UART protocol Intel registered
  3298    [    8.673562] hci_uart_bcm serial0-0: serial0-0 supply vbat not found, using dummy regulator
  3299    [    8.681406] hci_uart_bcm serial0-0: serial0-0 supply vddio not found, using dummy regulator
  3300    [    8.694377] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
  3301    [    8.697434] Bluetooth: HCI UART protocol Broadcom registered
  3302    [    8.710645] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
  3303    [    8.718241] cfg80211: failed to load regulatory.db
  3304    [    8.729581] Bluetooth: HCI UART protocol QCA registered
  3305    [    8.745239] Bluetooth: HCI UART protocol AG6XX registered
  3306    [    8.757175] Bluetooth: HCI UART protocol Marvell registered
  3307    [    8.874079] brcmfmac: F1 signature read @0x18000000=0x16034334
  3308    [    8.877379] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4334-sdio for chip BCM4334/3
  3309    [    8.885521] usbcore: registered new interface driver brcmfmac
  3310    [    8.934980] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.amlogic,p212.txt failed with error -2
  3311    [    8.945342] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.txt failed with error -2
  3312    [    8.982983] usb 1-2: reset high-speed USB device number 3 using xhci-hcd
  3313    [    9.006286] mt7601u 1-2:1.0: ASIC revision: 76010001 MAC revision: 76010500
  3314    [    9.075576] mt7601u 1-2:1.0: EEPROM ver:0d fae:00
  3315    [    9.083475] Bluetooth: hci0: BCM: chip id 68
  3316    [    9.087249] Bluetooth: hci0: BCM: features 0x0f
  3317    [    9.091998] Bluetooth: hci0: BCM4334B0
  3318    [    9.095099] Bluetooth: hci0: BCM4334B0 (002.001.013) build 0000
  3319    [    9.099318] bluetooth hci0: Direct firmware load for brcm/BCM4334B0.hcd failed with error -2
  3320    [    9.108322] Bluetooth: hci0: BCM: Patch brcm/BCM4334B0.hcd not found
  3321    [    9.286109] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
  3322    [    9.287337] usbcore: registered new interface driver mt7601u
  3323    [    9.921115] zram: Added device: zram0
  3324    [    9.924739] zram: Added device: zram1
  3325    [    9.928700] zram: Added device: zram2
  3326    [    9.970535] brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x50
  3327    [    9.981194] zram1: detected capacity change from 0 to 912879616
  3328    [   10.037232] meson8b-dwmac c9410000.ethernet eth0: PHY [0.e40908ff:08] driver [Meson GXL Internal PHY]
  3329    [   10.058536] meson8b-dwmac c9410000.ethernet eth0: No Safety Features support found
  3330    [   10.063028] meson8b-dwmac c9410000.ethernet eth0: PTP not supported by HW
  3331    [   10.069766] meson8b-dwmac c9410000.ethernet eth0: configuring for phy/rmii link mode
  3332    [   10.701039] random: crng init done
  3333    [   10.703560] random: 7 urandom warning(s) missed due to ratelimiting
  3334    [   10.810732] Adding 891480k swap on /dev/zram1.  Priority:5 extents:1 across:891480k SSFS
  3335
  3336    ### armbian-release:
  3337
  3338    # PLEASE DO NOT EDIT THIS FILE
  3339    BOARD=aml-s9xxx
  3340    BOARD_NAME="AML-S9xxx"
  3341    BOARDFAMILY=aml-s9xxx
  3342    BUILD_REPOSITORY_URL=https://github.com/150balbes/Build-Armbian.git
  3343    BUILD_REPOSITORY_COMMIT=62b8c07-dirty
  3344    DISTRIBUTION_CODENAME=buster
  3345    DISTRIBUTION_STATUS=supported
  3346    VERSION=20.02.0-rc1.037
  3347    LINUXFAMILY=aml-s9xxx
  3348    BRANCH=current
  3349    ARCH=arm64
  3350    IMAGE_TYPE=nightly
  3351    BOARD_TYPE=conf
  3352    INITRD_ARCH=arm64
  3353    KERNEL_IMAGE_TYPE=Image
  3354
  3355    ### boot environment:
  3356
  3357    ODROIDN2-UBOOT-CONFIG
  3358    setenv env_addr 0x10400000
  3359    setenv kernel_addr 0x11000000
  3360    setenv initrd_addr 0x13000000
  3361    setenv dtb_addr 0x1000000
  3362    if test "${devtype}" = ""; then setenv devtype "mmc"; fi
  3363    load ${devtype} ${devnum} ${env_addr} uEnv.txt && env import -t ${env_addr} ${filesize}
  3364    setenv bootargs ${APPEND}
  3365    load ${devtype} ${devnum} ${kernel_addr} ${LINUX}
  3366    load ${devtype} ${devnum} ${initrd_addr} ${INITRD}
  3367    load ${devtype} ${devnum} ${dtb_addr} ${FDT}
  3368    fdt addr ${dtb_addr}
  3369    booti ${kernel_addr} ${initrd_addr} ${dtb_addr}
  3370
  3371    ### lsusb:
  3372
  3373    Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
  3374    Bus 001 Device 003: ID 148f:7601 Ralink Technology, Corp. MT7601U Wireless Adapter
  3375    Bus 001 Device 002: ID 05e3:0608 Genesys Logic, Inc. Hub
  3376    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  3377
  3378    ### lscpu:
  3379
  3380    Architecture:        aarch64
  3381    Byte Order:          Little Endian
  3382    CPU(s):              4
  3383    On-line CPU(s) list: 0-3
  3384    Thread(s) per core:  1
  3385    Core(s) per socket:  4
  3386    Socket(s):           1
  3387    Vendor ID:           ARM
  3388    Model:               4
  3389    Model name:          Cortex-A53
  3390    Stepping:            r0p4
  3391    CPU max MHz:         1512,0000
  3392    CPU min MHz:         100,0000
  3393    BogoMIPS:            48.00
  3394    L1d cache:           unknown size
  3395    L1i cache:           unknown size
  3396    L2 cache:            unknown size
  3397    Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  3398
  3399    ### cpuinfo:
  3400
  3401    processor    : 0
  3402    model name    : ARMv8 Processor rev 4 (v8l)
  3403    BogoMIPS    : 48.00
  3404    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  3405    CPU implementer    : 0x41
  3406    CPU architecture: 8
  3407    CPU variant    : 0x0
  3408    CPU part    : 0xd03
  3409    CPU revision    : 4
  3410
  3411    processor    : 1
  3412    model name    : ARMv8 Processor rev 4 (v8l)
  3413    BogoMIPS    : 48.00
  3414    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  3415    CPU implementer    : 0x41
  3416    CPU architecture: 8
  3417    CPU variant    : 0x0
  3418    CPU part    : 0xd03
  3419    CPU revision    : 4
  3420
  3421    processor    : 2
  3422    model name    : ARMv8 Processor rev 4 (v8l)
  3423    BogoMIPS    : 48.00
  3424    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  3425    CPU implementer    : 0x41
  3426    CPU architecture: 8
  3427    CPU variant    : 0x0
  3428    CPU part    : 0xd03
  3429    CPU revision    : 4
  3430
  3431    processor    : 3
  3432    model name    : ARMv8 Processor rev 4 (v8l)
  3433    BogoMIPS    : 48.00
  3434    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  3435    CPU implementer    : 0x41
  3436    CPU architecture: 8
  3437    CPU variant    : 0x0
  3438    CPU part    : 0xd03
  3439    CPU revision    : 4
  3440
  3441
  3442    ### meminfo:
  3443
  3444    MemTotal:        1782968 kB
  3445    MemFree:         1606100 kB
  3446    MemAvailable:    1663936 kB
  3447    Buffers:           11616 kB
  3448    Cached:            54224 kB
  3449    SwapCached:            0 kB
  3450    Active:            52488 kB
  3451    Inactive:          35056 kB
  3452    Active(anon):      22012 kB
  3453    Inactive(anon):     2616 kB
  3454    Active(file):      30476 kB
  3455    Inactive(file):    32440 kB
  3456    Unevictable:          16 kB
  3457    Mlocked:              16 kB
  3458    SwapTotal:        891480 kB
  3459    SwapFree:         891480 kB
  3460    Dirty:               672 kB
  3461    Writeback:             0 kB
  3462    AnonPages:         21924 kB
  3463    Mapped:            23660 kB
  3464    Shmem:              2728 kB
  3465    KReclaimable:      18036 kB
  3466    Slab:              53316 kB
  3467    SReclaimable:      18036 kB
  3468    SUnreclaim:        35280 kB
  3469    KernelStack:        2784 kB
  3470    PageTables:         1628 kB
  3471    NFS_Unstable:          0 kB
  3472    Bounce:                0 kB
  3473    WritebackTmp:          0 kB
  3474    CommitLimit:     1782964 kB
  3475    Committed_AS:      79772 kB
  3476    VmallocTotal:   135290159040 kB
  3477    VmallocUsed:       16776 kB
  3478    VmallocChunk:          0 kB
  3479    Percpu:             1264 kB
  3480    CmaTotal:         262144 kB
  3481    CmaFree:          258460 kB
  3482    HugePages_Total:       0
  3483    HugePages_Free:        0
  3484    HugePages_Rsvd:        0
  3485    HugePages_Surp:        0
  3486    Hugepagesize:       2048 kB
  3487    Hugetlb:               0 kB
  3488
  3489    ### virtual memory:
  3490
  3491    vm.admin_reserve_kbytes = 8192
  3492    vm.block_dump = 0
  3493    vm.compact_unevictable_allowed = 1
  3494    vm.dirty_background_bytes = 0
  3495    vm.dirty_background_ratio = 10
  3496    vm.dirty_bytes = 0
  3497    vm.dirty_expire_centisecs = 3000
  3498    vm.dirty_ratio = 20
  3499    vm.dirtytime_expire_seconds = 43200
  3500    vm.dirty_writeback_centisecs = 500
  3501    vm.extfrag_threshold = 500
  3502    vm.hugetlb_shm_group = 0
  3503    vm.laptop_mode = 0
  3504    vm.legacy_va_layout = 0
  3505    vm.lowmem_reserve_ratio = 256    256    32    0
  3506    vm.max_map_count = 65530
  3507    vm.min_free_kbytes = 4914
  3508    vm.mmap_min_addr = 4096
  3509    vm.mmap_rnd_bits = 18
  3510    vm.nr_hugepages = 0
  3511    vm.nr_overcommit_hugepages = 0
  3512    vm.oom_dump_tasks = 1
  3513    vm.oom_kill_allocating_task = 0
  3514    vm.overcommit_kbytes = 0
  3515    vm.overcommit_memory = 0
  3516    vm.overcommit_ratio = 50
  3517    vm.page-cluster = 0
  3518    vm.panic_on_oom = 0
  3519    vm.percpu_pagelist_fraction = 0
  3520    vm.stat_interval = 1
  3521    vm.swappiness = 100
  3522    vm.user_reserve_kbytes = 55239
  3523    vm.vfs_cache_pressure = 100
  3524    vm.watermark_boost_factor = 15000
  3525    vm.watermark_scale_factor = 10
  3526
  3527    ### ip addr:
  3528
  3529    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
  3530        link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  3531        inet XXX.XXX.0.1/8 scope host lo
  3532           valid_lft forever preferred_lft forever
  3533        inet6 ::1/128 scope host
  3534           valid_lft forever preferred_lft forever
  3535    2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
  3536        link/ether 00:df:06:00:00:0b brd ff:ff:ff:ff:ff:ff
  3537    3: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  3538        link/ether 00:36:76:61:0b:24 brd ff:ff:ff:ff:ff:ff
  3539
  3540    ### partitions:
  3541
  3542    major minor  #blocks  name
  3543
  3544     179        0   30924800 mmcblk0
  3545     179        1     262144 mmcblk0p1
  3546     179        2   30337024 mmcblk0p2
  3547     179       32   15384576 mmcblk1
  3548     179      128       8192 mmcblk1gp0
  3549     254        1     891484 zram1
  3550
  3551    ### df:
  3552
  3553    udev             738M      0  738M   0% /dev
  3554    tmpfs            175M   2,7M  172M   2% /run
  3555    /dev/mmcblk0p2    29G    10G   19G  36% /
  3556    tmpfs            871M      0  871M   0% /dev/shm
  3557    tmpfs            5,0M   4,0K  5,0M   1% /run/lock
  3558    tmpfs            871M      0  871M   0% /sys/fs/cgroup
  3559    tmpfs            871M      0  871M   0% /tmp
  3560    /dev/mmcblk0p1   256M    76M  180M  30% /boot
  3561
  3562    ### lsblk:
  3563
  3564    NAME         FSTYPE   SIZE MOUNTPOINT UUID
  3565    mmcblk0              29,5G
  3566    ├─mmcblk0p1  vfat     256M /boot      50FC-6AC8
  3567    └─mmcblk0p2  ext4      29G /          3e297ac1-e4e4-4ab1-bc57-47c07d0422ba
  3568    mmcblk1              14,7G
  3569    mmcblk1boot0            4M
  3570    mmcblk1boot1            4M
  3571    mmcblk1gp0              8M
  3572
  3573    ### zramctl:
  3574
  3575    NAME       ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT
  3576    /dev/zram1 lzo         870,6M   4K   81B   12K       4 [SWAP]
  3577
  3578    ### mtab:
  3579
  3580    /dev/mmcblk0p1 /boot vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro 0 0
  3581    /dev/mmcblk0p2 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  3582
  3583    ### mmc0:59b4 info:
  3584
  3585                   fwrev: 0x0
  3586                  uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SDU1  MODALIAS=mmc:block
  3587                     cid: 1b534d53445531201014a136d4013800
  3588                     rca: 0x59b4
  3589                     csd: 400e00325b590000ebef7f800a400000
  3590                  manfid: 0x00001b
  3591                     ocr: 0x00200000
  3592    preferred_erase_size: 4194304
  3593                    type: SD
  3594                   hwrev: 0x1
  3595                    date: 08/2019
  3596                     dsr: 0x404
  3597              erase_size: 512
  3598                   oemid: 0x534d
  3599                  serial: 0x14a136d4
  3600                     ssr: 0000000005000000040090000811391e00089a342f01000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  3601                     scr: 0235844300000000
  3602                    name: SDU1
  3603
  3604    ### mmc1:0001 info:
  3605
  3606                   fwrev: 0x0
  3607                  uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=016G92 MODALIAS=mmc:block
  3608                     cid: 11010030313647393201d3d1a4db1100
  3609             rel_sectors: 0x10
  3610                     rca: 0x0001
  3611            pre_eol_info: 0x00
  3612                     csd: d00e00320f5903ffffffffef92400000
  3613                  manfid: 0x000011
  3614                     ocr: 0x00200000
  3615    preferred_erase_size: 4194304
  3616    enhanced_area_offset: 18446744073709551594
  3617      raw_rpmb_size_mult: 0x4
  3618                    type: MMC
  3619                   hwrev: 0x0
  3620                    date: 01/2014
  3621                     prv: 0x1
  3622             ffu_capable: 0
  3623                     dsr: 0x404
  3624              erase_size: 4194304
  3625               life_time: 0x00 0x00
  3626      enhanced_area_size: 4294967274
  3627                   oemid: 0x0100
  3628                  serial: 0xd3d1a4db
  3629                 cmdq_en: 0
  3630                     rev: 0x6
  3631                    name: 016G92
  3632
  3633    ### Boot system health:
  3634
  3635    Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU
  3636    21:19:45: 1512MHz  0.55  51%  24%  15%   0%  10%   1% 53.0°C
  3637    21:19:45: 1512MHz  0.55  61%   8%  15%   0%  34%   1% 54.0°C
  3638    21:19:46: 1512MHz  0.55  76%  13%  16%   0%  43%   1% 53.0°C
  3639    21:19:46: 1512MHz  0.55  52%   9%  14%   1%  26%   0% 53.0°C
  3640    21:19:46:  500MHz  0.67  31%   6%   8%   1%  12%   1% 52.0°C
  3641
  3642    ### Activated 1 lzo zram swap devices with 870 MB each
  3643
  3644
  3645    mié mar 24 08:01:46 CET 2021 | AML-S9xxx | 20.02.0-rc1.037 | arm64 | aarch64 | 5.5.0-rc6-aml-s9xxx
  3646
  3647    ### dmesg:
  3648
  3649    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
  3650    [    0.000000] Linux version 5.5.0-rc6-aml-s9xxx (root@vbox) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #rc1.037 SMP PREEMPT Wed Feb 5 15:59:04 MSK 2020
  3651    [    0.000000] Machine model: Amlogic Meson GXL (S905X) P212 Development Board
  3652    [    0.000000] efi: Getting EFI parameters from FDT:
  3653    [    0.000000] efi: UEFI not found.
  3654    [    0.000000] Reserved memory: created CMA memory pool at 0x0000000063400000, size 256 MiB
  3655    [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
  3656    [    0.000000] On node 0 totalpages: 477952
  3657    [    0.000000]   DMA zone: 4032 pages used for memmap
  3658    [    0.000000]   DMA zone: 0 pages reserved
  3659    [    0.000000]   DMA zone: 248576 pages, LIFO batch:63
  3660    [    0.000000]   DMA32 zone: 3584 pages used for memmap
  3661    [    0.000000]   DMA32 zone: 229376 pages, LIFO batch:63
  3662    [    0.000000] psci: probing for conduit method from DT.
  3663    [    0.000000] psci: PSCIv0.2 detected in firmware.
  3664    [    0.000000] psci: Using standard PSCI v0.2 function IDs
  3665    [    0.000000] psci: Trusted OS migration not required
  3666    [    0.000000] percpu: Embedded 22 pages/cpu s50392 r8192 d31528 u90112
  3667    [    0.000000] pcpu-alloc: s50392 r8192 d31528 u90112 alloc=22*4096
  3668    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
  3669    [    0.000000] Detected VIPT I-cache on CPU0
  3670    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 470336
  3671    [    0.000000] Kernel command line: root=LABEL=ROOTFS rootflags=data=writeback rw console=ttyAML0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 mac=00:df:06:00:00:0b
  3672    [    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
  3673    [    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
  3674    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
  3675    [    0.000000] software IO TLB: mapped [mem 0x3bfff000-0x3ffff000] (64MB)
  3676    [    0.000000] Memory: 1509616K/1911808K available (14460K kernel code, 1434K rwdata, 5884K rodata, 960K init, 927K bss, 140048K reserved, 262144K cma-reserved)
  3677    [    0.000000] random: get_random_u64 called from cache_random_seq_create+0x7c/0x150 with crng_init=0
  3678    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
  3679    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
  3680    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
  3681    [    0.000000]     Tasks RCU enabled.
  3682    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
  3683    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
  3684    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
  3685    [    0.000000] GIC: Using split EOI/Deactivate mode
  3686    [    0.000000] irq_meson_gpio: 110 to 8 gpio interrupt mux initialized
  3687    [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
  3688    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
  3689    [    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
  3690    [    0.000355] Console: colour dummy device 80x25
  3691    [    0.000655] printk: console [tty0] enabled
  3692    [    0.000697] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
  3693    [    0.000718] pid_max: default: 32768 minimum: 301
  3694    [    0.000841] LSM: Security Framework initializing
  3695    [    0.000891] SELinux:  Initializing.
  3696    [    0.000970] *** VALIDATE SELinux ***
  3697    [    0.001034] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
  3698    [    0.001064] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
  3699    [    0.001128] *** VALIDATE tmpfs ***
  3700    [    0.001531] *** VALIDATE proc ***
  3701    [    0.001754] *** VALIDATE cgroup1 ***
  3702    [    0.001770] *** VALIDATE cgroup2 ***
  3703    [    0.024017] ASID allocator initialised with 32768 entries
  3704    [    0.032002] rcu: Hierarchical SRCU implementation.
  3705    [    0.042102] EFI services will not be available.
  3706    [    0.048058] smp: Bringing up secondary CPUs ...
  3707    [    0.080287] Detected VIPT I-cache on CPU1
  3708    [    0.080340] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
  3709    [    0.112326] Detected VIPT I-cache on CPU2
  3710    [    0.112373] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
  3711    [    0.144370] Detected VIPT I-cache on CPU3
  3712    [    0.144411] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
  3713    [    0.144485] smp: Brought up 1 node, 4 CPUs
  3714    [    0.144552] SMP: Total of 4 processors activated.
  3715    [    0.144564] CPU features: detected: 32-bit EL0 Support
  3716    [    0.144576] CPU features: detected: CRC32 instructions
  3717    [    0.144879] CPU: All CPU(s) started at EL2
  3718    [    0.144901] alternatives: patching kernel code
  3719    [    0.146000] devtmpfs: initialized
  3720    [    0.151134] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
  3721    [    0.151175] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
  3722    [    0.157994] xor: measuring software checksum speed
  3723    [    0.196365]    8regs     :  2375.000 MB/sec
  3724    [    0.236396]    32regs    :  2724.000 MB/sec
  3725    [    0.276434]    arm64_neon:  2406.000 MB/sec
  3726    [    0.276444] xor: using function: 32regs (2724.000 MB/sec)
  3727    [    0.276499] pinctrl core: initialized pinctrl subsystem
  3728    [    0.277168] thermal_sys: Registered thermal governor 'step_wise'
  3729    [    0.277339] DMI not present or invalid.
  3730    [    0.277699] NET: Registered protocol family 16
  3731    [    0.281233] DMA: preallocated 256 KiB pool for atomic allocations
  3732    [    0.281281] audit: initializing netlink subsys (disabled)
  3733    [    0.281468] audit: type=2000 audit(0.280:1): state=initialized audit_enabled=0 res=1
  3734    [    0.282515] cpuidle: using governor ladder
  3735    [    0.282555] cpuidle: using governor menu
  3736    [    0.282888] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
  3737    [    0.283581] Serial: AMBA PL011 UART driver
  3738    [    0.297615] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
  3739    [    0.297644] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
  3740    [    0.297657] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
  3741    [    0.297669] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
  3742    [    0.301361] cryptd: max_cpu_qlen set to 1000
  3743    [    0.376709] raid6: neonx8   gen()  1623 MB/s
  3744    [    0.444778] raid6: neonx8   xor()  1490 MB/s
  3745    [    0.512860] raid6: neonx4   gen()  1564 MB/s
  3746    [    0.580921] raid6: neonx4   xor()  1470 MB/s
  3747    [    0.648998] raid6: neonx2   gen()  1199 MB/s
  3748    [    0.717076] raid6: neonx2   xor()  1216 MB/s
  3749    [    0.785202] raid6: neonx1   gen()   787 MB/s
  3750    [    0.853268] raid6: neonx1   xor()   915 MB/s
  3751    [    0.921327] raid6: int64x8  gen()  1195 MB/s
  3752    [    0.989332] raid6: int64x8  xor()   769 MB/s
  3753    [    1.057385] raid6: int64x4  gen()  1029 MB/s
  3754    [    1.125444] raid6: int64x4  xor()   752 MB/s
  3755    [    1.193556] raid6: int64x2  gen()   729 MB/s
  3756    [    1.261544] raid6: int64x2  xor()   615 MB/s
  3757    [    1.329690] raid6: int64x1  gen()   486 MB/s
  3758    [    1.397647] raid6: int64x1  xor()   468 MB/s
  3759    [    1.397658] raid6: using algorithm neonx8 gen() 1623 MB/s
  3760    [    1.397668] raid6: .... xor() 1490 MB/s, rmw enabled
  3761    [    1.397678] raid6: using neon recovery algorithm
  3762    [    1.397963] ACPI: Interpreter disabled.
  3763    [    1.399153] iommu: Default domain type: Translated
  3764    [    1.399435] vgaarb: loaded
  3765    [    1.400028] SCSI subsystem initialized
  3766    [    1.400214] libata version 3.00 loaded.
  3767    [    1.400425] usbcore: registered new interface driver usbfs
  3768    [    1.400473] usbcore: registered new interface driver hub
  3769    [    1.400539] usbcore: registered new device driver usb
  3770    [    1.400937] pps_core: LinuxPPS API ver. 1 registered
  3771    [    1.400949] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
  3772    [    1.400973] PTP clock support registered
  3773    [    1.401003] EDAC MC: Ver: 3.0.0
  3774    [    1.401599] FPGA manager framework
  3775    [    1.401710] Advanced Linux Sound Architecture Driver Initialized.
  3776    [    1.402173] NetLabel: Initializing
  3777    [    1.402185] NetLabel:  domain hash size = 128
  3778    [    1.402194] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
  3779    [    1.402254] NetLabel:  unlabeled traffic allowed by default
  3780    [    1.402764] clocksource: Switched to clocksource arch_sys_counter
  3781    [    1.402791] *** VALIDATE bpf ***
  3782    [    1.403040] VFS: Disk quotas dquot_6.6.0
  3783    [    1.403103] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
  3784    [    1.403225] FS-Cache: Loaded
  3785    [    1.403235] *** VALIDATE ramfs ***
  3786    [    1.403256] *** VALIDATE hugetlbfs ***
  3787    [    1.403646] pnp: PnP ACPI: disabled
  3788    [    1.408761] NET: Registered protocol family 2
  3789    [    1.409264] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
  3790    [    1.409312] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
  3791    [    1.409431] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
  3792    [    1.409647] TCP: Hash tables configured (established 16384 bind 16384)
  3793    [    1.409800] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
  3794    [    1.409852] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
  3795    [    1.410064] NET: Registered protocol family 1
  3796    [    1.410539] RPC: Registered named UNIX socket transport module.
  3797    [    1.410559] RPC: Registered udp transport module.
  3798    [    1.410569] RPC: Registered tcp transport module.
  3799    [    1.410578] RPC: Registered tcp NFSv4.1 backchannel transport module.
  3800    [    1.410594] NET: Registered protocol family 44
  3801    [    1.410613] PCI: CLS 0 bytes, default 64
  3802    [    1.410872] Trying to unpack rootfs image as initramfs...
  3803    [    1.872487] Freeing initrd memory: 10248K
  3804    [    1.873283] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
  3805    [    2.087101] Initialise system trusted keyrings
  3806    [    2.087337] workingset: timestamp_bits=46 max_order=19 bucket_order=0
  3807    [    2.092516] zbud: loaded
  3808    [    2.093742] squashfs: version 4.0 (2009/01/31) Phillip Lougher
  3809    [    2.094022] FS-Cache: Netfs 'nfs' registered for caching
  3810    [    2.094544] NFS: Registering the id_resolver key type
  3811    [    2.094581] Key type id_resolver registered
  3812    [    2.094591] Key type id_legacy registered
  3813    [    2.094607] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
  3814    [    2.094619] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
  3815    [    2.095805] FS-Cache: Netfs 'cifs' registered for caching
  3816    [    2.096136] Key type cifs.spnego registered
  3817    [    2.096156] Key type cifs.idmap registered
  3818    [    2.096178] ntfs: driver 2.1.32 [Flags: R/W].
  3819    [    2.096791] JFS: nTxBlock = 8192, nTxLock = 65536
  3820    [    2.102738] SGI XFS with ACLs, security attributes, realtime, quota, no debug enabled
  3821    [    2.104167] *** VALIDATE xfs ***
  3822    [    2.104480] ocfs2: Registered cluster interface o2cb
  3823    [    2.104696] OCFS2 User DLM kernel interface loaded
  3824    [    2.106116] *** VALIDATE gfs2 ***
  3825    [    2.106391] gfs2: GFS2 installed
  3826    [    2.107424] aufs 5.5-20200203
  3827    [    2.128183] Key type asymmetric registered
  3828    [    2.128210] Asymmetric key parser 'x509' registered
  3829    [    2.128220] Asymmetric key parser 'pkcs8' registered
  3830    [    2.128289] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
  3831    [    2.128467] io scheduler mq-deadline registered
  3832    [    2.128483] io scheduler kyber registered
  3833    [    2.128682] io scheduler bfq registered
  3834    [    2.141268] soc soc0: Amlogic Meson GXL (S905X) Revision 21:b (82:2) Detected
  3835    [    2.144819] Serial: 8250/16550 driver, 5 ports, IRQ sharing enabled
  3836    [    2.146498] Serial: AMBA driver
  3837    [    2.146931] c11084c0.serial: ttyAML6 at MMIO 0xc11084c0 (irq = 10, base_baud = 1500000) is a meson_uart
  3838    [    2.147103] serial serial0: tty port ttyAML6 registered
  3839    [    2.147339] c81004c0.serial: ttyAML0 at MMIO 0xc81004c0 (irq = 13, base_baud = 1500000) is a meson_uart
  3840    [    3.122811] printk: console [ttyAML0] enabled
  3841    [    3.138835] brd: module loaded
  3842    [    3.147354] loop: module loaded
  3843    [    3.149722] libphy: Fixed MDIO Bus: probed
  3844    [    3.150378] meson8b-dwmac c9410000.ethernet: IRQ eth_wake_irq not found
  3845    [    3.155554] meson8b-dwmac c9410000.ethernet: IRQ eth_lpi not found
  3846    [    3.161739] meson8b-dwmac c9410000.ethernet: PTP uses main clock
  3847    [    3.167586] meson8b-dwmac c9410000.ethernet: no reset control found
  3848    [    3.174260] meson8b-dwmac c9410000.ethernet: User ID: 0x11, Synopsys ID: 0x37
  3849    [    3.180872] meson8b-dwmac c9410000.ethernet:     DWMAC1000
  3850    [    3.186038] meson8b-dwmac c9410000.ethernet: DMA HW capability register supported
  3851    [    3.193453] meson8b-dwmac c9410000.ethernet: RX Checksum Offload Engine supported
  3852    [    3.200870] meson8b-dwmac c9410000.ethernet: COE Type 2
  3853    [    3.206045] meson8b-dwmac c9410000.ethernet: TX Checksum insertion supported
  3854    [    3.213031] meson8b-dwmac c9410000.ethernet: Wake-Up On Lan supported
  3855    [    3.219446] meson8b-dwmac c9410000.ethernet: Normal descriptors
  3856    [    3.225280] meson8b-dwmac c9410000.ethernet: Ring mode enabled
  3857    [    3.231058] meson8b-dwmac c9410000.ethernet: Enable RX Mitigation via HW Watchdog Timer
  3858    [    3.239174] libphy: stmmac: probed
  3859    [    3.243681] VFIO - User Level meta-driver version: 0.3
  3860    [    3.248997] dwc3 c9000000.dwc3: Failed to get clk 'ref': -2
  3861    [    3.253832] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
  3862    [    3.259463] ehci-pci: EHCI PCI platform driver
  3863    [    3.263921] ehci-platform: EHCI generic platform driver
  3864    [    3.269208] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
  3865    [    3.275147] ohci-pci: OHCI PCI platform driver
  3866    [    3.279575] ohci-platform: OHCI generic platform driver
  3867    [    3.285324] usbcore: registered new interface driver usb-storage
  3868    [    3.290908] mousedev: PS/2 mouse device common for all mice
  3869    [    3.296837] i2c /dev entries driver
  3870    [    3.302494] sdhci: Secure Digital Host Controller Interface driver
  3871    [    3.305766] sdhci: Copyright(c) Pierre Ossman
  3872    [    3.310080] Synopsys Designware Multimedia Card Interface Driver
  3873    [    3.317365] meson-gx-mmc d0072000.mmc: Got CD GPIO
  3874    [    3.347902] meson-gx-mmc d0074000.mmc: allocated mmc-pwrseq
  3875    [    3.379258] sdhci-pltfm: SDHCI platform and OF driver helper
  3876    [    3.380195] ledtrig-cpu: registered to indicate activity on CPUs
  3877    [    3.386163] meson-sm: secure-monitor enabled
  3878    [    3.390227] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
  3879    [    3.397534] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
  3880    [    3.405380] mmc0: new high speed SDHC card at address 59b4
  3881    [    3.415490] mmcblk0: mmc0:59b4 SDU1  29.5 GiB
  3882    [    3.418164]  mmcblk0: p1 p2
  3883    [    3.424070] hid: raw HID events driver (C) Jiri Kosina
  3884    [    3.424303] usbcore: registered new interface driver usbhid
  3885    [    3.429122] usbhid: USB HID core driver
  3886    [    3.433276] platform-mhu c883c404.mailbox: Platform MHU Mailbox registered
  3887    [    3.449845] NET: Registered protocol family 17
  3888    [    3.450134] Key type dns_resolver registered
  3889    [    3.453440] registered taskstats version 1
  3890    [    3.456979] Loading compiled-in X.509 certificates
  3891    [    3.461845] zswap: loaded using pool lzo/zbud
  3892    [    3.466219] Key type ._fscrypt registered
  3893    [    3.469989] Key type .fscrypt registered
  3894    [    3.474963] Btrfs loaded, crc32c=crc32c-generic
  3895    [    3.489771] mmc1: new HS200 MMC card at address 0001
  3896    [    3.490699] mmcblk1: mmc1:0001 016G92 14.7 GiB
  3897    [    3.494114] mmcblk1boot0: mmc1:0001 016G92 partition 1 4.00 MiB
  3898    [    3.499947] mmcblk1boot1: mmc1:0001 016G92 partition 2 4.00 MiB
  3899    [    3.504253] Key type encrypted registered
  3900    [    3.505814] mmcblk1gp0: mmc1:0001 016G92 partition 4 8.00 MiB
  3901    [    3.515269] mmcblk1rpmb: mmc1:0001 016G92 partition 3 512 KiB, chardev (243:0)
  3902    [    3.529028] meson-drm d0100000.vpu: Queued 3 outputs on vpu
  3903    [    3.529479] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
  3904    [    3.535570] [drm] No driver support for vblank timestamp query.
  3905    [    3.566821] meson-dw-hdmi c883a000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
  3906    [    3.571474] meson-dw-hdmi c883a000.hdmi-tx: registered DesignWare HDMI I2C bus driver
  3907    [    3.579490] meson-drm d0100000.vpu: bound c883a000.hdmi-tx (ops meson_dw_hdmi_ops)
  3908    [    3.586839] [drm] Initialized meson 1.0.0 20161109 for d0100000.vpu on minor 0
  3909    [    3.632176] Console: switching to colour frame buffer device 90x36
  3910    [    3.652390] meson-drm d0100000.vpu: fb0: mesondrmfb frame buffer device
  3911    [    3.659669] libphy: mdio_mux: probed
  3912    [    3.670160] libphy: mdio_mux: probed
  3913    [    3.670655] phy phy-d0078080.phy.2: unsupported PHY mode 5
  3914    [    3.675737] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  3915    [    3.679104] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
  3916    [    3.686808] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228f664 hci version 0x100 quirks 0x0000000002010010
  3917    [    3.696018] xhci-hcd xhci-hcd.0.auto: irq 39, io mem 0xc9000000
  3918    [    3.702129] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.05
  3919    [    3.710361] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  3920    [    3.717511] usb usb1: Product: xHCI Host Controller
  3921    [    3.722338] usb usb1: Manufacturer: Linux 5.5.0-rc6-aml-s9xxx xhci-hcd
  3922    [    3.728807] usb usb1: SerialNumber: xhci-hcd.0.auto
  3923    [    3.734135] hub 1-0:1.0: USB hub found
  3924    [    3.737394] hub 1-0:1.0: 2 ports detected
  3925    [    3.741605] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  3926    [    3.746771] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
  3927    [    3.754351] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
  3928    [    3.760866] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
  3929    [    3.769115] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.05
  3930    [    3.777492] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  3931    [    3.784648] usb usb2: Product: xHCI Host Controller
  3932    [    3.789475] usb usb2: Manufacturer: Linux 5.5.0-rc6-aml-s9xxx xhci-hcd
  3933    [    3.795945] usb usb2: SerialNumber: xhci-hcd.0.auto
  3934    [    3.801257] hub 2-0:1.0: USB hub found
  3935    [    3.804513] hub 2-0:1.0: config failed, hub doesn't have any ports! (err -19)
  3936    [    3.813379] meson-gx-mmc d0070000.mmc: allocated mmc-pwrseq
  3937    [    3.843766] scpi_protocol scpi: SCP Protocol legacy pre-1.0 firmware
  3938    [    3.860346] gx-sound-card sound: snd-soc-dummy-dai <-> c1105400.bus:audio-controller-0 mapping ok
  3939    [    3.871872] gx-sound-card sound: i2s-hifi <-> c1105400.bus:audio-controller-2 mapping ok
  3940    [    3.879545] gx-sound-card sound: ASoC: no DMI vendor name!
  3941    [    3.885716] printk: console [netcon0] enabled
  3942    [    3.889181] netconsole: network logging started
  3943    [    3.893749] hctosys: unable to open rtc device (rtc0)
  3944    [    3.899168] ALSA device list:
  3945    [    3.901666]   #0: AMLGX
  3946    [    3.904671] Freeing unused kernel memory: 960K
  3947    [    3.908544] Run /init as init process
  3948    [    3.920532] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
  3949    [    3.928985] mmc2: queuing unknown CIS tuple 0x80 (6 bytes)
  3950    [    3.935916] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
  3951    [    3.947155] mmc2: queuing unknown CIS tuple 0x80 (19 bytes)
  3952    [    3.973021] random: fast init done
  3953    [    4.036133] mmc2: new high speed SDIO card at address 0001
  3954    [    4.078829] usb 1-1: new high-speed USB device number 2 using xhci-hcd
  3955    [    4.100075] usb 1-1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.36
  3956    [    4.106975] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
  3957    [    4.114457] usb 1-1: Product: USB2.0 Hub
  3958    [    4.177348] hub 1-1:1.0: USB hub found
  3959    [    4.179988] hub 1-1:1.0: 4 ports detected
  3960    [    4.310853] usb 1-2: new high-speed USB device number 3 using xhci-hcd
  3961    [    4.341408] usb 1-2: New USB device found, idVendor=148f, idProduct=7601, bcdDevice= 0.00
  3962    [    4.348554] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
  3963    [    4.357117] usb 1-2: Product: 802.11 n WLAN
  3964    [    4.360635] usb 1-2: Manufacturer: MediaTek
  3965    [    4.363813] usb 1-2: SerialNumber: 1.0
  3966    [    5.060678] EXT4-fs (mmcblk0p2): mounted filesystem with writeback data mode. Opts: data=writeback
  3967    [    6.009519] systemd[1]: System time before build time, advancing clock.
  3968    [    6.155845] NET: Registered protocol family 10
  3969    [    6.237468] Segment Routing with IPv6
  3970    [    6.287593] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
  3971    [    6.317767] systemd[1]: Detected architecture arm64.
  3972    [    6.369656] systemd[1]: Set hostname to <mxqpro>.
  3973    [    6.402019] systemd[1]: Couldn't move remaining userspace processes, ignoring: Input/output error
  3974    [    7.079227] random: systemd: uninitialized urandom read (16 bytes read)
  3975    [    7.091773] random: systemd: uninitialized urandom read (16 bytes read)
  3976    [    7.098133] systemd[1]: Created slice User and Session Slice.
  3977    [    7.104512] random: systemd: uninitialized urandom read (16 bytes read)
  3978    [    7.108123] systemd[1]: Reached target System Time Synchronized.
  3979    [    7.119630] systemd[1]: Created slice system-serial\x2dgetty.slice.
  3980    [    7.125760] systemd[1]: Condition check resulted in Arbitrary Executable File Formats File System Automount Point being skipped.
  3981    [    7.137238] systemd[1]: Listening on udev Kernel Socket.
  3982    [    7.145531] systemd[1]: Listening on Journal Socket.
  3983    [    7.312959] EXT4-fs (mmcblk0p2): re-mounted. Opts: commit=600,errors=remount-ro
  3984    [    7.588585] systemd-journald[419]: Received request to flush runtime journal from PID 1
  3985    [    8.119491] mc: Linux media interface: v0.10
  3986    [    8.146808] Registered IR keymap rc-empty
  3987    [    8.150257] rc rc0: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0
  3988    [    8.159027] input: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0/input0
  3989    [    8.159385] videodev: Linux video capture interface: v2.00
  3990    [    8.166155] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
  3991    [    8.180718] meson-ir c8100580.ir: receiver initialized
  3992    [    8.281207] lima d00c0000.gpu: IRQ ppmmu3 not found
  3993    [    8.295039] lima d00c0000.gpu: IRQ ppmmu4 not found
  3994    [    8.297230] lima d00c0000.gpu: IRQ ppmmu5 not found
  3995    [    8.305523] lima d00c0000.gpu: IRQ ppmmu6 not found
  3996    [    8.309379] lima d00c0000.gpu: IRQ ppmmu7 not found
  3997    [    8.311785] lima d00c0000.gpu: gp - mali450 version major 0 minor 0
  3998    [    8.318274] lima d00c0000.gpu: pp0 - mali450 version major 0 minor 0
  3999    [    8.324514] lima d00c0000.gpu: pp1 - mali450 version major 0 minor 0
  4000    [    8.330821] lima d00c0000.gpu: pp2 - mali450 version major 0 minor 0
  4001    [    8.337079] lima d00c0000.gpu: IRQ pp3 not found
  4002    [    8.341548] lima d00c0000.gpu: IRQ pp4 not found
  4003    [    8.346159] lima d00c0000.gpu: IRQ pp5 not found
  4004    [    8.350732] lima d00c0000.gpu: IRQ pp6 not found
  4005    [    8.355163] lima d00c0000.gpu: IRQ pp7 not found
  4006    [    8.359745] lima d00c0000.gpu: l2 cache 8K, 4-way, 64byte cache line, 128bit external bus
  4007    [    8.367982] lima d00c0000.gpu: l2 cache 64K, 4-way, 64byte cache line, 128bit external bus
  4008    [    8.376648] lima d00c0000.gpu: bus rate = 166666667
  4009    [    8.381060] lima d00c0000.gpu: mod rate = 744000000
  4010    [    8.386261] [drm] Initialized lima 1.0.0 20190217 for d00c0000.gpu on minor 1
  4011    [    8.429850] Bluetooth: Core ver 2.22
  4012    [    8.431929] NET: Registered protocol family 31
  4013    [    8.434004] Bluetooth: HCI device and connection manager initialized
  4014    [    8.440509] Bluetooth: HCI socket layer initialized
  4015    [    8.445254] Bluetooth: L2CAP socket layer initialized
  4016    [    8.450381] Bluetooth: SCO socket layer initialized
  4017    [    8.539528] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
  4018    [    8.580125] cfg80211: Loading compiled-in X.509 certificates for regulatory database
  4019    [    8.620889] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
  4020    [    8.629699] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
  4021    [    8.636595] cfg80211: failed to load regulatory.db
  4022    [    8.668217] Bluetooth: HCI UART driver ver 2.3
  4023    [    8.672254] Bluetooth: HCI UART protocol H4 registered
  4024    [    8.674344] Bluetooth: HCI UART protocol BCSP registered
  4025    [    8.687230] Bluetooth: HCI UART protocol LL registered
  4026    [    8.689350] Bluetooth: HCI UART protocol ATH3K registered
  4027    [    8.716365] Bluetooth: HCI UART protocol Three-wire (H5) registered
  4028    [    8.729446] Bluetooth: HCI UART protocol Intel registered
  4029    [    8.732136] Bluetooth: HCI UART protocol Broadcom registered
  4030    [    8.732261] hci_uart_bcm serial0-0: serial0-0 supply vbat not found, using dummy regulator
  4031    [    8.745690] Bluetooth: HCI UART protocol QCA registered
  4032    [    8.748247] hci_uart_bcm serial0-0: serial0-0 supply vddio not found, using dummy regulator
  4033    [    8.761994] Bluetooth: HCI UART protocol AG6XX registered
  4034    [    8.765651] brcmfmac: F1 signature read @0x18000000=0x16034334
  4035    [    8.772888] Bluetooth: HCI UART protocol Marvell registered
  4036    [    8.773290] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4334-sdio for chip BCM4334/3
  4037    [    8.783828] usbcore: registered new interface driver brcmfmac
  4038    [    8.826705] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.amlogic,p212.txt failed with error -2
  4039    [    8.839833] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.txt failed with error -2
  4040    [    8.887159] usb 1-2: reset high-speed USB device number 3 using xhci-hcd
  4041    [    8.910409] mt7601u 1-2:1.0: ASIC revision: 76010001 MAC revision: 76010500
  4042    [    8.944847] mt7601u 1-2:1.0: EEPROM ver:0d fae:00
  4043    [    9.148163] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
  4044    [    9.149051] usbcore: registered new interface driver mt7601u
  4045    [    9.151922] Bluetooth: hci0: BCM: chip id 68
  4046    [    9.156726] Bluetooth: hci0: BCM: features 0x0f
  4047    [    9.162455] Bluetooth: hci0: BCM4334B0
  4048    [    9.166033] Bluetooth: hci0: BCM4334B0 (002.001.013) build 0000
  4049    [    9.170302] bluetooth hci0: Direct firmware load for brcm/BCM4334B0.hcd failed with error -2
  4050    [    9.178556] Bluetooth: hci0: BCM: Patch brcm/BCM4334B0.hcd not found
  4051    [    9.858954] brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x50
  4052    [    9.971908] zram: Added device: zram0
  4053    [    9.977684] zram: Added device: zram1
  4054    [    9.981120] zram: Added device: zram2
  4055    [   10.006027] meson8b-dwmac c9410000.ethernet eth0: PHY [0.e40908ff:08] driver [Meson GXL Internal PHY]
  4056    [   10.036616] zram1: detected capacity change from 0 to 912879616
  4057    [   10.050917] meson8b-dwmac c9410000.ethernet eth0: No Safety Features support found
  4058    [   10.055400] meson8b-dwmac c9410000.ethernet eth0: PTP not supported by HW
  4059    [   10.062116] meson8b-dwmac c9410000.ethernet eth0: configuring for phy/rmii link mode
  4060    [   10.672031] random: crng init done
  4061    [   10.674521] random: 7 urandom warning(s) missed due to ratelimiting
  4062    [   10.723040] Adding 891480k swap on /dev/zram1.  Priority:5 extents:1 across:891480k SSFS
  4063
  4064    ### armbian-release:
  4065
  4066    # PLEASE DO NOT EDIT THIS FILE
  4067    BOARD=aml-s9xxx
  4068    BOARD_NAME="AML-S9xxx"
  4069    BOARDFAMILY=aml-s9xxx
  4070    BUILD_REPOSITORY_URL=https://github.com/150balbes/Build-Armbian.git
  4071    BUILD_REPOSITORY_COMMIT=62b8c07-dirty
  4072    DISTRIBUTION_CODENAME=buster
  4073    DISTRIBUTION_STATUS=supported
  4074    VERSION=20.02.0-rc1.037
  4075    LINUXFAMILY=aml-s9xxx
  4076    BRANCH=current
  4077    ARCH=arm64
  4078    IMAGE_TYPE=nightly
  4079    BOARD_TYPE=conf
  4080    INITRD_ARCH=arm64
  4081    KERNEL_IMAGE_TYPE=Image
  4082
  4083    ### boot environment:
  4084
  4085    ODROIDN2-UBOOT-CONFIG
  4086    setenv env_addr 0x10400000
  4087    setenv kernel_addr 0x11000000
  4088    setenv initrd_addr 0x13000000
  4089    setenv dtb_addr 0x1000000
  4090    if test "${devtype}" = ""; then setenv devtype "mmc"; fi
  4091    load ${devtype} ${devnum} ${env_addr} uEnv.txt && env import -t ${env_addr} ${filesize}
  4092    setenv bootargs ${APPEND}
  4093    load ${devtype} ${devnum} ${kernel_addr} ${LINUX}
  4094    load ${devtype} ${devnum} ${initrd_addr} ${INITRD}
  4095    load ${devtype} ${devnum} ${dtb_addr} ${FDT}
  4096    fdt addr ${dtb_addr}
  4097    booti ${kernel_addr} ${initrd_addr} ${dtb_addr}
  4098
  4099    ### lsusb:
  4100
  4101    Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
  4102    Bus 001 Device 003: ID 148f:7601 Ralink Technology, Corp. MT7601U Wireless Adapter
  4103    Bus 001 Device 002: ID 05e3:0608 Genesys Logic, Inc. Hub
  4104    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  4105
  4106    ### lscpu:
  4107
  4108    Architecture:        aarch64
  4109    Byte Order:          Little Endian
  4110    CPU(s):              4
  4111    On-line CPU(s) list: 0-3
  4112    Thread(s) per core:  1
  4113    Core(s) per socket:  4
  4114    Socket(s):           1
  4115    Vendor ID:           ARM
  4116    Model:               4
  4117    Model name:          Cortex-A53
  4118    Stepping:            r0p4
  4119    CPU max MHz:         1512,0000
  4120    CPU min MHz:         100,0000
  4121    BogoMIPS:            48.00
  4122    L1d cache:           unknown size
  4123    L1i cache:           unknown size
  4124    L2 cache:            unknown size
  4125    Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  4126
  4127    ### cpuinfo:
  4128
  4129    processor    : 0
  4130    model name    : ARMv8 Processor rev 4 (v8l)
  4131    BogoMIPS    : 48.00
  4132    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  4133    CPU implementer    : 0x41
  4134    CPU architecture: 8
  4135    CPU variant    : 0x0
  4136    CPU part    : 0xd03
  4137    CPU revision    : 4
  4138
  4139    processor    : 1
  4140    model name    : ARMv8 Processor rev 4 (v8l)
  4141    BogoMIPS    : 48.00
  4142    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  4143    CPU implementer    : 0x41
  4144    CPU architecture: 8
  4145    CPU variant    : 0x0
  4146    CPU part    : 0xd03
  4147    CPU revision    : 4
  4148
  4149    processor    : 2
  4150    model name    : ARMv8 Processor rev 4 (v8l)
  4151    BogoMIPS    : 48.00
  4152    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  4153    CPU implementer    : 0x41
  4154    CPU architecture: 8
  4155    CPU variant    : 0x0
  4156    CPU part    : 0xd03
  4157    CPU revision    : 4
  4158
  4159    processor    : 3
  4160    model name    : ARMv8 Processor rev 4 (v8l)
  4161    BogoMIPS    : 48.00
  4162    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  4163    CPU implementer    : 0x41
  4164    CPU architecture: 8
  4165    CPU variant    : 0x0
  4166    CPU part    : 0xd03
  4167    CPU revision    : 4
  4168
  4169
  4170    ### meminfo:
  4171
  4172    MemTotal:        1782968 kB
  4173    MemFree:         1609204 kB
  4174    MemAvailable:    1666596 kB
  4175    Buffers:           11472 kB
  4176    Cached:            54512 kB
  4177    SwapCached:            0 kB
  4178    Active:            51108 kB
  4179    Inactive:          35432 kB
  4180    Active(anon):      21068 kB
  4181    Inactive(anon):     2592 kB
  4182    Active(file):      30040 kB
  4183    Inactive(file):    32840 kB
  4184    Unevictable:           0 kB
  4185    Mlocked:               0 kB
  4186    SwapTotal:        891480 kB
  4187    SwapFree:         891480 kB
  4188    Dirty:               500 kB
  4189    Writeback:             4 kB
  4190    AnonPages:         20960 kB
  4191    Mapped:            22916 kB
  4192    Shmem:              2696 kB
  4193    KReclaimable:      17628 kB
  4194    Slab:              52720 kB
  4195    SReclaimable:      17628 kB
  4196    SUnreclaim:        35092 kB
  4197    KernelStack:        2748 kB
  4198    PageTables:         1632 kB
  4199    NFS_Unstable:          0 kB
  4200    Bounce:                0 kB
  4201    WritebackTmp:          0 kB
  4202    CommitLimit:     1782964 kB
  4203    Committed_AS:      77316 kB
  4204    VmallocTotal:   135290159040 kB
  4205    VmallocUsed:       16708 kB
  4206    VmallocChunk:          0 kB
  4207    Percpu:             1264 kB
  4208    CmaTotal:         262144 kB
  4209    CmaFree:          258460 kB
  4210    HugePages_Total:       0
  4211    HugePages_Free:        0
  4212    HugePages_Rsvd:        0
  4213    HugePages_Surp:        0
  4214    Hugepagesize:       2048 kB
  4215    Hugetlb:               0 kB
  4216
  4217    ### virtual memory:
  4218
  4219    vm.admin_reserve_kbytes = 8192
  4220    vm.block_dump = 0
  4221    vm.compact_unevictable_allowed = 1
  4222    vm.dirty_background_bytes = 0
  4223    vm.dirty_background_ratio = 10
  4224    vm.dirty_bytes = 0
  4225    vm.dirty_expire_centisecs = 3000
  4226    vm.dirty_ratio = 20
  4227    vm.dirtytime_expire_seconds = 43200
  4228    vm.dirty_writeback_centisecs = 500
  4229    vm.extfrag_threshold = 500
  4230    vm.hugetlb_shm_group = 0
  4231    vm.laptop_mode = 0
  4232    vm.legacy_va_layout = 0
  4233    vm.lowmem_reserve_ratio = 256    256    32    0
  4234    vm.max_map_count = 65530
  4235    vm.min_free_kbytes = 4914
  4236    vm.mmap_min_addr = 4096
  4237    vm.mmap_rnd_bits = 18
  4238    vm.nr_hugepages = 0
  4239    vm.nr_overcommit_hugepages = 0
  4240    vm.oom_dump_tasks = 1
  4241    vm.oom_kill_allocating_task = 0
  4242    vm.overcommit_kbytes = 0
  4243    vm.overcommit_memory = 0
  4244    vm.overcommit_ratio = 50
  4245    vm.page-cluster = 0
  4246    vm.panic_on_oom = 0
  4247    vm.percpu_pagelist_fraction = 0
  4248    vm.stat_interval = 1
  4249    vm.swappiness = 100
  4250    vm.user_reserve_kbytes = 55254
  4251    vm.vfs_cache_pressure = 100
  4252    vm.watermark_boost_factor = 15000
  4253    vm.watermark_scale_factor = 10
  4254
  4255    ### ip addr:
  4256
  4257    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
  4258        link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  4259        inet XXX.XXX.0.1/8 scope host lo
  4260           valid_lft forever preferred_lft forever
  4261        inet6 ::1/128 scope host
  4262           valid_lft forever preferred_lft forever
  4263    2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
  4264        link/ether 00:df:06:00:00:0b brd ff:ff:ff:ff:ff:ff
  4265    3: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  4266        link/ether 00:36:76:61:0b:24 brd ff:ff:ff:ff:ff:ff
  4267
  4268    ### partitions:
  4269
  4270    major minor  #blocks  name
  4271
  4272     179        0   30924800 mmcblk0
  4273     179        1     262144 mmcblk0p1
  4274     179        2   30337024 mmcblk0p2
  4275     179       32   15384576 mmcblk1
  4276     179      128       8192 mmcblk1gp0
  4277     254        1     891484 zram1
  4278
  4279    ### df:
  4280
  4281    udev             738M      0  738M   0% /dev
  4282    tmpfs            175M   2,7M  172M   2% /run
  4283    /dev/mmcblk0p2    29G    10G   19G  36% /
  4284    tmpfs            871M      0  871M   0% /dev/shm
  4285    tmpfs            5,0M   4,0K  5,0M   1% /run/lock
  4286    tmpfs            871M      0  871M   0% /sys/fs/cgroup
  4287    tmpfs            871M      0  871M   0% /tmp
  4288    /dev/mmcblk0p1   256M    76M  180M  30% /boot
  4289
  4290    ### lsblk:
  4291
  4292    NAME         FSTYPE   SIZE MOUNTPOINT UUID
  4293    mmcblk0              29,5G
  4294    ├─mmcblk0p1  vfat     256M /boot      50FC-6AC8
  4295    └─mmcblk0p2  ext4      29G /          3e297ac1-e4e4-4ab1-bc57-47c07d0422ba
  4296    mmcblk1              14,7G
  4297    mmcblk1boot0            4M
  4298    mmcblk1boot1            4M
  4299    mmcblk1gp0              8M
  4300
  4301    ### zramctl:
  4302
  4303    NAME       ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT
  4304    /dev/zram1 lzo         870,6M   4K   81B   12K       4 [SWAP]
  4305
  4306    ### mtab:
  4307
  4308    /dev/mmcblk0p1 /boot vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro 0 0
  4309    /dev/mmcblk0p2 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  4310
  4311    ### mmc0:59b4 info:
  4312
  4313                   fwrev: 0x0
  4314                  uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SDU1  MODALIAS=mmc:block
  4315                     cid: 1b534d53445531201014a136d4013800
  4316                     rca: 0x59b4
  4317                     csd: 400e00325b590000ebef7f800a400000
  4318                  manfid: 0x00001b
  4319                     ocr: 0x00200000
  4320    preferred_erase_size: 4194304
  4321                    type: SD
  4322                   hwrev: 0x1
  4323                    date: 08/2019
  4324                     dsr: 0x404
  4325              erase_size: 512
  4326                   oemid: 0x534d
  4327                  serial: 0x14a136d4
  4328                     ssr: 0000000005000000040090000811391e00089a342f01000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  4329                     scr: 0235844300000000
  4330                    name: SDU1
  4331
  4332    ### mmc1:0001 info:
  4333
  4334                   fwrev: 0x0
  4335                  uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=016G92 MODALIAS=mmc:block
  4336                     cid: 11010030313647393201d3d1a4db1100
  4337             rel_sectors: 0x10
  4338                     rca: 0x0001
  4339            pre_eol_info: 0x00
  4340                     csd: d00e00320f5903ffffffffef92400000
  4341                  manfid: 0x000011
  4342                     ocr: 0x00200000
  4343    preferred_erase_size: 4194304
  4344    enhanced_area_offset: 18446744073709551594
  4345      raw_rpmb_size_mult: 0x4
  4346                    type: MMC
  4347                   hwrev: 0x0
  4348                    date: 01/2014
  4349                     prv: 0x1
  4350             ffu_capable: 0
  4351                     dsr: 0x404
  4352              erase_size: 4194304
  4353               life_time: 0x00 0x00
  4354      enhanced_area_size: 4294967274
  4355                   oemid: 0x0100
  4356                  serial: 0xd3d1a4db
  4357                 cmdq_en: 0
  4358                     rev: 0x6
  4359                    name: 016G92
  4360
  4361    ### Boot system health:
  4362
  4363    Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU
  4364    08:01:49: 1512MHz  0.55  51%  24%  15%   0%  10%   1% 45.0°C
  4365    08:01:49: 1512MHz  0.55  64%  12%  21%   1%  28%   1% 45.0°C
  4366    08:01:50: 1512MHz  0.55  63%  10%   7%   0%  43%   1% 44.0°C
  4367    08:01:50: 1512MHz  0.55  53%   8%  15%   1%  26%   2% 44.0°C
  4368    08:01:50: 1512MHz  0.55  25%   6%   6%   0%  11%   0% 44.0°C
  4369
  4370    ### Activated 1 lzo zram swap devices with 870 MB each
  4371
  4372
  4373    jue mar 25 08:29:09 CET 2021 | AML-S9xxx | 20.02.0-rc1.037 | arm64 | aarch64 | 5.5.0-rc6-aml-s9xxx
  4374
  4375    ### dmesg:
  4376
  4377    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
  4378    [    0.000000] Linux version 5.5.0-rc6-aml-s9xxx (root@vbox) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #rc1.037 SMP PREEMPT Wed Feb 5 15:59:04 MSK 2020
  4379    [    0.000000] Machine model: Amlogic Meson GXL (S905X) P212 Development Board
  4380    [    0.000000] efi: Getting EFI parameters from FDT:
  4381    [    0.000000] efi: UEFI not found.
  4382    [    0.000000] Reserved memory: created CMA memory pool at 0x0000000063400000, size 256 MiB
  4383    [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
  4384    [    0.000000] On node 0 totalpages: 477952
  4385    [    0.000000]   DMA zone: 4032 pages used for memmap
  4386    [    0.000000]   DMA zone: 0 pages reserved
  4387    [    0.000000]   DMA zone: 248576 pages, LIFO batch:63
  4388    [    0.000000]   DMA32 zone: 3584 pages used for memmap
  4389    [    0.000000]   DMA32 zone: 229376 pages, LIFO batch:63
  4390    [    0.000000] psci: probing for conduit method from DT.
  4391    [    0.000000] psci: PSCIv0.2 detected in firmware.
  4392    [    0.000000] psci: Using standard PSCI v0.2 function IDs
  4393    [    0.000000] psci: Trusted OS migration not required
  4394    [    0.000000] percpu: Embedded 22 pages/cpu s50392 r8192 d31528 u90112
  4395    [    0.000000] pcpu-alloc: s50392 r8192 d31528 u90112 alloc=22*4096
  4396    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
  4397    [    0.000000] Detected VIPT I-cache on CPU0
  4398    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 470336
  4399    [    0.000000] Kernel command line: root=LABEL=ROOTFS rootflags=data=writeback rw console=ttyAML0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 mac=00:df:06:00:00:0b
  4400    [    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
  4401    [    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
  4402    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
  4403    [    0.000000] software IO TLB: mapped [mem 0x3bfff000-0x3ffff000] (64MB)
  4404    [    0.000000] Memory: 1509616K/1911808K available (14460K kernel code, 1434K rwdata, 5884K rodata, 960K init, 927K bss, 140048K reserved, 262144K cma-reserved)
  4405    [    0.000000] random: get_random_u64 called from cache_random_seq_create+0x7c/0x150 with crng_init=0
  4406    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
  4407    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
  4408    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
  4409    [    0.000000]     Tasks RCU enabled.
  4410    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
  4411    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
  4412    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
  4413    [    0.000000] GIC: Using split EOI/Deactivate mode
  4414    [    0.000000] irq_meson_gpio: 110 to 8 gpio interrupt mux initialized
  4415    [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
  4416    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
  4417    [    0.000003] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
  4418    [    0.000353] Console: colour dummy device 80x25
  4419    [    0.000654] printk: console [tty0] enabled
  4420    [    0.000694] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
  4421    [    0.000715] pid_max: default: 32768 minimum: 301
  4422    [    0.000842] LSM: Security Framework initializing
  4423    [    0.000892] SELinux:  Initializing.
  4424    [    0.000969] *** VALIDATE SELinux ***
  4425    [    0.001032] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
  4426    [    0.001058] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
  4427    [    0.001120] *** VALIDATE tmpfs ***
  4428    [    0.001529] *** VALIDATE proc ***
  4429    [    0.001749] *** VALIDATE cgroup1 ***
  4430    [    0.001764] *** VALIDATE cgroup2 ***
  4431    [    0.024017] ASID allocator initialised with 32768 entries
  4432    [    0.032000] rcu: Hierarchical SRCU implementation.
  4433    [    0.042069] EFI services will not be available.
  4434    [    0.048055] smp: Bringing up secondary CPUs ...
  4435    [    0.080281] Detected VIPT I-cache on CPU1
  4436    [    0.080335] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
  4437    [    0.112323] Detected VIPT I-cache on CPU2
  4438    [    0.112370] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
  4439    [    0.144370] Detected VIPT I-cache on CPU3
  4440    [    0.144414] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
  4441    [    0.144491] smp: Brought up 1 node, 4 CPUs
  4442    [    0.144556] SMP: Total of 4 processors activated.
  4443    [    0.144567] CPU features: detected: 32-bit EL0 Support
  4444    [    0.144579] CPU features: detected: CRC32 instructions
  4445    [    0.144884] CPU: All CPU(s) started at EL2
  4446    [    0.144909] alternatives: patching kernel code
  4447    [    0.145995] devtmpfs: initialized
  4448    [    0.151117] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
  4449    [    0.151157] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
  4450    [    0.158019] xor: measuring software checksum speed
  4451    [    0.196360]    8regs     :  2374.000 MB/sec
  4452    [    0.236390]    32regs    :  2724.000 MB/sec
  4453    [    0.276430]    arm64_neon:  2406.000 MB/sec
  4454    [    0.276441] xor: using function: 32regs (2724.000 MB/sec)
  4455    [    0.276496] pinctrl core: initialized pinctrl subsystem
  4456    [    0.277166] thermal_sys: Registered thermal governor 'step_wise'
  4457    [    0.277333] DMI not present or invalid.
  4458    [    0.277696] NET: Registered protocol family 16
  4459    [    0.281243] DMA: preallocated 256 KiB pool for atomic allocations
  4460    [    0.281293] audit: initializing netlink subsys (disabled)
  4461    [    0.281508] audit: type=2000 audit(0.280:1): state=initialized audit_enabled=0 res=1
  4462    [    0.282589] cpuidle: using governor ladder
  4463    [    0.282628] cpuidle: using governor menu
  4464    [    0.282998] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
  4465    [    0.283714] Serial: AMBA PL011 UART driver
  4466    [    0.297728] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
  4467    [    0.297756] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
  4468    [    0.297769] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
  4469    [    0.297781] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
  4470    [    0.301495] cryptd: max_cpu_qlen set to 1000
  4471    [    0.376682] raid6: neonx8   gen()  1621 MB/s
  4472    [    0.444703] raid6: neonx8   xor()  1491 MB/s
  4473    [    0.512752] raid6: neonx4   gen()  1565 MB/s
  4474    [    0.580824] raid6: neonx4   xor()  1471 MB/s
  4475    [    0.648889] raid6: neonx2   gen()  1200 MB/s
  4476    [    0.716938] raid6: neonx2   xor()  1217 MB/s
  4477    [    0.785034] raid6: neonx1   gen()   787 MB/s
  4478    [    0.853075] raid6: neonx1   xor()   915 MB/s
  4479    [    0.921126] raid6: int64x8  gen()  1194 MB/s
  4480    [    0.989166] raid6: int64x8  xor()   769 MB/s
  4481    [    1.057211] raid6: int64x4  gen()  1029 MB/s
  4482    [    1.125279] raid6: int64x4  xor()   752 MB/s
  4483    [    1.193381] raid6: int64x2  gen()   729 MB/s
  4484    [    1.261389] raid6: int64x2  xor()   618 MB/s
  4485    [    1.329481] raid6: int64x1  gen()   486 MB/s
  4486    [    1.397499] raid6: int64x1  xor()   468 MB/s
  4487    [    1.397510] raid6: using algorithm neonx8 gen() 1621 MB/s
  4488    [    1.397520] raid6: .... xor() 1491 MB/s, rmw enabled
  4489    [    1.397530] raid6: using neon recovery algorithm
  4490    [    1.397818] ACPI: Interpreter disabled.
  4491    [    1.399000] iommu: Default domain type: Translated
  4492    [    1.399268] vgaarb: loaded
  4493    [    1.399829] SCSI subsystem initialized
  4494    [    1.399993] libata version 3.00 loaded.
  4495    [    1.400201] usbcore: registered new interface driver usbfs
  4496    [    1.400248] usbcore: registered new interface driver hub
  4497    [    1.400314] usbcore: registered new device driver usb
  4498    [    1.400712] pps_core: LinuxPPS API ver. 1 registered
  4499    [    1.400725] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
  4500    [    1.400748] PTP clock support registered
  4501    [    1.400778] EDAC MC: Ver: 3.0.0
  4502    [    1.401386] FPGA manager framework
  4503    [    1.401500] Advanced Linux Sound Architecture Driver Initialized.
  4504    [    1.401953] NetLabel: Initializing
  4505    [    1.401966] NetLabel:  domain hash size = 128
  4506    [    1.401975] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
  4507    [    1.402039] NetLabel:  unlabeled traffic allowed by default
  4508    [    1.402529] clocksource: Switched to clocksource arch_sys_counter
  4509    [    1.402552] *** VALIDATE bpf ***
  4510    [    1.402804] VFS: Disk quotas dquot_6.6.0
  4511    [    1.402866] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
  4512    [    1.402985] FS-Cache: Loaded
  4513    [    1.402996] *** VALIDATE ramfs ***
  4514    [    1.403016] *** VALIDATE hugetlbfs ***
  4515    [    1.403391] pnp: PnP ACPI: disabled
  4516    [    1.408430] NET: Registered protocol family 2
  4517    [    1.408913] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
  4518    [    1.408959] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
  4519    [    1.409076] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
  4520    [    1.409292] TCP: Hash tables configured (established 16384 bind 16384)
  4521    [    1.409446] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
  4522    [    1.409499] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
  4523    [    1.409708] NET: Registered protocol family 1
  4524    [    1.410157] RPC: Registered named UNIX socket transport module.
  4525    [    1.410178] RPC: Registered udp transport module.
  4526    [    1.410188] RPC: Registered tcp transport module.
  4527    [    1.410197] RPC: Registered tcp NFSv4.1 backchannel transport module.
  4528    [    1.410213] NET: Registered protocol family 44
  4529    [    1.410233] PCI: CLS 0 bytes, default 64
  4530    [    1.410425] Trying to unpack rootfs image as initramfs...
  4531    [    1.871277] Freeing initrd memory: 10248K
  4532    [    1.872066] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
  4533    [    2.086060] Initialise system trusted keyrings
  4534    [    2.086296] workingset: timestamp_bits=46 max_order=19 bucket_order=0
  4535    [    2.091541] zbud: loaded
  4536    [    2.092796] squashfs: version 4.0 (2009/01/31) Phillip Lougher
  4537    [    2.093082] FS-Cache: Netfs 'nfs' registered for caching
  4538    [    2.093600] NFS: Registering the id_resolver key type
  4539    [    2.093640] Key type id_resolver registered
  4540    [    2.093650] Key type id_legacy registered
  4541    [    2.093666] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
  4542    [    2.093679] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
  4543    [    2.094913] FS-Cache: Netfs 'cifs' registered for caching
  4544    [    2.095244] Key type cifs.spnego registered
  4545    [    2.095265] Key type cifs.idmap registered
  4546    [    2.095288] ntfs: driver 2.1.32 [Flags: R/W].
  4547    [    2.095851] JFS: nTxBlock = 8192, nTxLock = 65536
  4548    [    2.101816] SGI XFS with ACLs, security attributes, realtime, quota, no debug enabled
  4549    [    2.103213] *** VALIDATE xfs ***
  4550    [    2.103499] ocfs2: Registered cluster interface o2cb
  4551    [    2.103716] OCFS2 User DLM kernel interface loaded
  4552    [    2.105103] *** VALIDATE gfs2 ***
  4553    [    2.105373] gfs2: GFS2 installed
  4554    [    2.106270] aufs 5.5-20200203
  4555    [    2.127038] Key type asymmetric registered
  4556    [    2.127065] Asymmetric key parser 'x509' registered
  4557    [    2.127075] Asymmetric key parser 'pkcs8' registered
  4558    [    2.127146] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
  4559    [    2.127335] io scheduler mq-deadline registered
  4560    [    2.127350] io scheduler kyber registered
  4561    [    2.127555] io scheduler bfq registered
  4562    [    2.140235] soc soc0: Amlogic Meson GXL (S905X) Revision 21:b (82:2) Detected
  4563    [    2.143898] Serial: 8250/16550 driver, 5 ports, IRQ sharing enabled
  4564    [    2.145597] Serial: AMBA driver
  4565    [    2.145969] c11084c0.serial: ttyAML6 at MMIO 0xc11084c0 (irq = 10, base_baud = 1500000) is a meson_uart
  4566    [    2.146132] serial serial0: tty port ttyAML6 registered
  4567    [    2.146346] c81004c0.serial: ttyAML0 at MMIO 0xc81004c0 (irq = 13, base_baud = 1500000) is a meson_uart
  4568    [    3.121815] printk: console [ttyAML0] enabled
  4569    [    3.137867] brd: module loaded
  4570    [    3.146325] loop: module loaded
  4571    [    3.148799] libphy: Fixed MDIO Bus: probed
  4572    [    3.149454] meson8b-dwmac c9410000.ethernet: IRQ eth_wake_irq not found
  4573    [    3.154596] meson8b-dwmac c9410000.ethernet: IRQ eth_lpi not found
  4574    [    3.160701] meson8b-dwmac c9410000.ethernet: PTP uses main clock
  4575    [    3.166553] meson8b-dwmac c9410000.ethernet: no reset control found
  4576    [    3.173233] meson8b-dwmac c9410000.ethernet: User ID: 0x11, Synopsys ID: 0x37
  4577    [    3.179850] meson8b-dwmac c9410000.ethernet:     DWMAC1000
  4578    [    3.185006] meson8b-dwmac c9410000.ethernet: DMA HW capability register supported
  4579    [    3.192423] meson8b-dwmac c9410000.ethernet: RX Checksum Offload Engine supported
  4580    [    3.199839] meson8b-dwmac c9410000.ethernet: COE Type 2
  4581    [    3.205013] meson8b-dwmac c9410000.ethernet: TX Checksum insertion supported
  4582    [    3.211999] meson8b-dwmac c9410000.ethernet: Wake-Up On Lan supported
  4583    [    3.218412] meson8b-dwmac c9410000.ethernet: Normal descriptors
  4584    [    3.224247] meson8b-dwmac c9410000.ethernet: Ring mode enabled
  4585    [    3.230027] meson8b-dwmac c9410000.ethernet: Enable RX Mitigation via HW Watchdog Timer
  4586    [    3.238142] libphy: stmmac: probed
  4587    [    3.242704] VFIO - User Level meta-driver version: 0.3
  4588    [    3.247954] dwc3 c9000000.dwc3: Failed to get clk 'ref': -2
  4589    [    3.252807] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
  4590    [    3.258433] ehci-pci: EHCI PCI platform driver
  4591    [    3.262869] ehci-platform: EHCI generic platform driver
  4592    [    3.268172] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
  4593    [    3.274113] ohci-pci: OHCI PCI platform driver
  4594    [    3.278547] ohci-platform: OHCI generic platform driver
  4595    [    3.284299] usbcore: registered new interface driver usb-storage
  4596    [    3.289855] mousedev: PS/2 mouse device common for all mice
  4597    [    3.295807] i2c /dev entries driver
  4598    [    3.301483] sdhci: Secure Digital Host Controller Interface driver
  4599    [    3.304736] sdhci: Copyright(c) Pierre Ossman
  4600    [    3.309049] Synopsys Designware Multimedia Card Interface Driver
  4601    [    3.316343] meson-gx-mmc d0072000.mmc: Got CD GPIO
  4602    [    3.346863] meson-gx-mmc d0074000.mmc: allocated mmc-pwrseq
  4603    [    3.374376] sdhci-pltfm: SDHCI platform and OF driver helper
  4604    [    3.375320] ledtrig-cpu: registered to indicate activity on CPUs
  4605    [    3.380976] meson-sm: secure-monitor enabled
  4606    [    3.385250] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
  4607    [    3.386581] mmc0: new high speed SDHC card at address 59b4
  4608    [    3.392576] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
  4609    [    3.398708] mmcblk0: mmc0:59b4 SDU1  29.5 GiB
  4610    [    3.420838]  mmcblk0: p1 p2
  4611    [    3.422850] hid: raw HID events driver (C) Jiri Kosina
  4612    [    3.423311] usbcore: registered new interface driver usbhid
  4613    [    3.428747] usbhid: USB HID core driver
  4614    [    3.432818] platform-mhu c883c404.mailbox: Platform MHU Mailbox registered
  4615    [    3.449810] NET: Registered protocol family 17
  4616    [    3.450093] Key type dns_resolver registered
  4617    [    3.453483] registered taskstats version 1
  4618    [    3.456943] Loading compiled-in X.509 certificates
  4619    [    3.461866] zswap: loaded using pool lzo/zbud
  4620    [    3.466146] Key type ._fscrypt registered
  4621    [    3.469948] Key type .fscrypt registered
  4622    [    3.475100] Btrfs loaded, crc32c=crc32c-generic
  4623    [    3.496281] mmc1: new HS200 MMC card at address 0001
  4624    [    3.501282] mmcblk1: mmc1:0001 016G92 14.7 GiB
  4625    [    3.501719] mmcblk1boot0: mmc1:0001 016G92 partition 1 4.00 MiB
  4626    [    3.501972] Key type encrypted registered
  4627    [    3.506485] mmcblk1boot1: mmc1:0001 016G92 partition 2 4.00 MiB
  4628    [    3.516412] mmcblk1gp0: mmc1:0001 016G92 partition 4 8.00 MiB
  4629    [    3.521893] mmcblk1rpmb: mmc1:0001 016G92 partition 3 512 KiB, chardev (243:0)
  4630    [    3.529751] meson-drm d0100000.vpu: Queued 3 outputs on vpu
  4631    [    3.534814] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
  4632    [    3.540845] [drm] No driver support for vblank timestamp query.
  4633    [    3.574586] meson-dw-hdmi c883a000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
  4634    [    3.579242] meson-dw-hdmi c883a000.hdmi-tx: registered DesignWare HDMI I2C bus driver
  4635    [    3.587261] meson-drm d0100000.vpu: bound c883a000.hdmi-tx (ops meson_dw_hdmi_ops)
  4636    [    3.594608] [drm] Initialized meson 1.0.0 20161109 for d0100000.vpu on minor 0
  4637    [    3.630094] Console: switching to colour frame buffer device 90x36
  4638    [    3.650314] meson-drm d0100000.vpu: fb0: mesondrmfb frame buffer device
  4639    [    3.657576] libphy: mdio_mux: probed
  4640    [    3.668137] libphy: mdio_mux: probed
  4641    [    3.668622] phy phy-d0078080.phy.2: unsupported PHY mode 5
  4642    [    3.673649] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  4643    [    3.677062] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
  4644    [    3.684768] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228f664 hci version 0x100 quirks 0x0000000002010010
  4645    [    3.693998] xhci-hcd xhci-hcd.0.auto: irq 39, io mem 0xc9000000
  4646    [    3.700098] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.05
  4647    [    3.708441] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  4648    [    3.715591] usb usb1: Product: xHCI Host Controller
  4649    [    3.720419] usb usb1: Manufacturer: Linux 5.5.0-rc6-aml-s9xxx xhci-hcd
  4650    [    3.726887] usb usb1: SerialNumber: xhci-hcd.0.auto
  4651    [    3.732245] hub 1-0:1.0: USB hub found
  4652    [    3.735462] hub 1-0:1.0: 2 ports detected
  4653    [    3.739681] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  4654    [    3.744847] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
  4655    [    3.752437] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
  4656    [    3.758938] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
  4657    [    3.767192] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.05
  4658    [    3.775570] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  4659    [    3.782726] usb usb2: Product: xHCI Host Controller
  4660    [    3.787555] usb usb2: Manufacturer: Linux 5.5.0-rc6-aml-s9xxx xhci-hcd
  4661    [    3.794024] usb usb2: SerialNumber: xhci-hcd.0.auto
  4662    [    3.799320] hub 2-0:1.0: USB hub found
  4663    [    3.802602] hub 2-0:1.0: config failed, hub doesn't have any ports! (err -19)
  4664    [    3.811539] meson-gx-mmc d0070000.mmc: allocated mmc-pwrseq
  4665    [    3.842657] scpi_protocol scpi: SCP Protocol legacy pre-1.0 firmware
  4666    [    3.860111] gx-sound-card sound: snd-soc-dummy-dai <-> c1105400.bus:audio-controller-0 mapping ok
  4667    [    3.869332] gx-sound-card sound: i2s-hifi <-> c1105400.bus:audio-controller-2 mapping ok
  4668    [    3.877017] gx-sound-card sound: ASoC: no DMI vendor name!
  4669    [    3.883196] printk: console [netcon0] enabled
  4670    [    3.886653] netconsole: network logging started
  4671    [    3.891215] hctosys: unable to open rtc device (rtc0)
  4672    [    3.896449] ALSA device list:
  4673    [    3.899588]   #0: AMLGX
  4674    [    3.903113] Freeing unused kernel memory: 960K
  4675    [    3.906194] Run /init as init process
  4676    [    3.906862] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
  4677    [    3.918736] mmc2: queuing unknown CIS tuple 0x80 (6 bytes)
  4678    [    3.925288] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
  4679    [    3.937311] mmc2: queuing unknown CIS tuple 0x80 (19 bytes)
  4680    [    3.964376] random: fast init done
  4681    [    4.022156] mmc2: new high speed SDIO card at address 0001
  4682    [    4.078608] usb 1-1: new high-speed USB device number 2 using xhci-hcd
  4683    [    4.100400] usb 1-1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.36
  4684    [    4.107205] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
  4685    [    4.114252] usb 1-1: Product: USB2.0 Hub
  4686    [    4.175438] hub 1-1:1.0: USB hub found
  4687    [    4.177914] hub 1-1:1.0: 4 ports detected
  4688    [    4.310606] usb 1-2: new high-speed USB device number 3 using xhci-hcd
  4689    [    4.341180] usb 1-2: New USB device found, idVendor=148f, idProduct=7601, bcdDevice= 0.00
  4690    [    4.348015] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
  4691    [    4.355977] usb 1-2: Product: 802.11 n WLAN
  4692    [    4.359219] usb 1-2: Manufacturer: MediaTek
  4693    [    4.363298] usb 1-2: SerialNumber: 1.0
  4694    [    5.040612] EXT4-fs (mmcblk0p2): mounted filesystem with writeback data mode. Opts: data=writeback
  4695    [    5.995866] systemd[1]: System time before build time, advancing clock.
  4696    [    6.149780] NET: Registered protocol family 10
  4697    [    6.221058] Segment Routing with IPv6
  4698    [    6.272439] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
  4699    [    6.308765] systemd[1]: Detected architecture arm64.
  4700    [    6.360408] systemd[1]: Set hostname to <mxqpro>.
  4701    [    6.392837] systemd[1]: Couldn't move remaining userspace processes, ignoring: Input/output error
  4702    [    7.078770] random: systemd: uninitialized urandom read (16 bytes read)
  4703    [    7.091350] random: systemd: uninitialized urandom read (16 bytes read)
  4704    [    7.099361] systemd[1]: Created slice system-systemd\x2dfsck.slice.
  4705    [    7.105688] random: systemd: uninitialized urandom read (16 bytes read)
  4706    [    7.109844] systemd[1]: Listening on Journal Socket.
  4707    [    7.121041] systemd[1]: Mounting Kernel Debug File System...
  4708    [    7.128262] systemd[1]: Created slice system-serial\x2dgetty.slice.
  4709    [    7.138153] systemd[1]: Starting Nameserver information manager...
  4710    [    7.144520] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
  4711    [    7.325631] EXT4-fs (mmcblk0p2): re-mounted. Opts: commit=600,errors=remount-ro
  4712    [    7.596933] systemd-journald[414]: Received request to flush runtime journal from PID 1
  4713    [    8.082747] mc: Linux media interface: v0.10
  4714    [    8.109912] videodev: Linux video capture interface: v2.00
  4715    [    8.134829] Registered IR keymap rc-empty
  4716    [    8.136908] rc rc0: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0
  4717    [    8.143380] input: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0/input0
  4718    [    8.150768] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
  4719    [    8.166190] meson-ir c8100580.ir: receiver initialized
  4720    [    8.231729] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
  4721    [    8.246786] lima d00c0000.gpu: IRQ ppmmu3 not found
  4722    [    8.249267] lima d00c0000.gpu: IRQ ppmmu4 not found
  4723    [    8.262760] lima d00c0000.gpu: IRQ ppmmu5 not found
  4724    [    8.265124] lima d00c0000.gpu: IRQ ppmmu6 not found
  4725    [    8.276242] lima d00c0000.gpu: IRQ ppmmu7 not found
  4726    [    8.281140] lima d00c0000.gpu: gp - mali450 version major 0 minor 0
  4727    [    8.289232] lima d00c0000.gpu: pp0 - mali450 version major 0 minor 0
  4728    [    8.292584] lima d00c0000.gpu: pp1 - mali450 version major 0 minor 0
  4729    [    8.301737] lima d00c0000.gpu: pp2 - mali450 version major 0 minor 0
  4730    [    8.306700] lima d00c0000.gpu: IRQ pp3 not found
  4731    [    8.309479] lima d00c0000.gpu: IRQ pp4 not found
  4732    [    8.317008] lima d00c0000.gpu: IRQ pp5 not found
  4733    [    8.320573] lima d00c0000.gpu: IRQ pp6 not found
  4734    [    8.324550] lima d00c0000.gpu: IRQ pp7 not found
  4735    [    8.329196] lima d00c0000.gpu: l2 cache 8K, 4-way, 64byte cache line, 128bit external bus
  4736    [    8.337366] lima d00c0000.gpu: l2 cache 64K, 4-way, 64byte cache line, 128bit external bus
  4737    [    8.347139] lima d00c0000.gpu: bus rate = 166666667
  4738    [    8.349365] lima d00c0000.gpu: mod rate = 744000000
  4739    [    8.356470] [drm] Initialized lima 1.0.0 20190217 for d00c0000.gpu on minor 1
  4740    [    8.447229] Bluetooth: Core ver 2.22
  4741    [    8.449868] NET: Registered protocol family 31
  4742    [    8.451911] Bluetooth: HCI device and connection manager initialized
  4743    [    8.458128] Bluetooth: HCI socket layer initialized
  4744    [    8.462854] Bluetooth: L2CAP socket layer initialized
  4745    [    8.467896] Bluetooth: SCO socket layer initialized
  4746    [    8.520770] cfg80211: Loading compiled-in X.509 certificates for regulatory database
  4747    [    8.556595] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
  4748    [    8.561226] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
  4749    [    8.568938] cfg80211: failed to load regulatory.db
  4750    [    8.694760] Bluetooth: HCI UART driver ver 2.3
  4751    [    8.697128] Bluetooth: HCI UART protocol H4 registered
  4752    [    8.700667] brcmfmac: F1 signature read @0x18000000=0x16034334
  4753    [    8.706070] Bluetooth: HCI UART protocol BCSP registered
  4754    [    8.708106] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4334-sdio for chip BCM4334/3
  4755    [    8.708403] Bluetooth: HCI UART protocol LL registered
  4756    [    8.716487] usbcore: registered new interface driver brcmfmac
  4757    [    8.721404] Bluetooth: HCI UART protocol ATH3K registered
  4758    [    8.736563] Bluetooth: HCI UART protocol Three-wire (H5) registered
  4759    [    8.739900] Bluetooth: HCI UART protocol Intel registered
  4760    [    8.745480] hci_uart_bcm serial0-0: serial0-0 supply vbat not found, using dummy regulator
  4761    [    8.753237] hci_uart_bcm serial0-0: serial0-0 supply vddio not found, using dummy regulator
  4762    [    8.761540] Bluetooth: HCI UART protocol Broadcom registered
  4763    [    8.767107] Bluetooth: HCI UART protocol QCA registered
  4764    [    8.772212] Bluetooth: HCI UART protocol AG6XX registered
  4765    [    8.777638] Bluetooth: HCI UART protocol Marvell registered
  4766    [    8.827167] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.amlogic,p212.txt failed with error -2
  4767    [    8.827232] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.txt failed with error -2
  4768    [    8.862911] usb 1-2: reset high-speed USB device number 3 using xhci-hcd
  4769    [    8.893347] mt7601u 1-2:1.0: ASIC revision: 76010001 MAC revision: 76010500
  4770    [    8.919367] mt7601u 1-2:1.0: EEPROM ver:0d fae:00
  4771    [    9.130069] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
  4772    [    9.132833] usbcore: registered new interface driver mt7601u
  4773    [    9.147542] Bluetooth: hci0: BCM: chip id 68
  4774    [    9.150833] Bluetooth: hci0: BCM: features 0x0f
  4775    [    9.158784] Bluetooth: hci0: BCM4334B0
  4776    [    9.163806] Bluetooth: hci0: BCM4334B0 (002.001.013) build 0000
  4777    [    9.167835] bluetooth hci0: Direct firmware load for brcm/BCM4334B0.hcd failed with error -2
  4778    [    9.177450] Bluetooth: hci0: BCM: Patch brcm/BCM4334B0.hcd not found
  4779    [    9.830624] brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x50
  4780    [    9.886451] zram: Added device: zram0
  4781    [    9.891176] zram: Added device: zram1
  4782    [    9.894404] zram: Added device: zram2
  4783    [    9.925547] meson8b-dwmac c9410000.ethernet eth0: PHY [0.e40908ff:08] driver [Meson GXL Internal PHY]
  4784    [    9.945386] zram1: detected capacity change from 0 to 912879616
  4785    [    9.950673] meson8b-dwmac c9410000.ethernet eth0: No Safety Features support found
  4786    [    9.957268] meson8b-dwmac c9410000.ethernet eth0: PTP not supported by HW
  4787    [    9.962462] meson8b-dwmac c9410000.ethernet eth0: configuring for phy/rmii link mode
  4788    [   10.586495] random: crng init done
  4789    [   10.588901] random: 7 urandom warning(s) missed due to ratelimiting
  4790    [   10.790775] Adding 891480k swap on /dev/zram1.  Priority:5 extents:1 across:891480k SSFS
  4791
  4792    ### armbian-release:
  4793
  4794    # PLEASE DO NOT EDIT THIS FILE
  4795    BOARD=aml-s9xxx
  4796    BOARD_NAME="AML-S9xxx"
  4797    BOARDFAMILY=aml-s9xxx
  4798    BUILD_REPOSITORY_URL=https://github.com/150balbes/Build-Armbian.git
  4799    BUILD_REPOSITORY_COMMIT=62b8c07-dirty
  4800    DISTRIBUTION_CODENAME=buster
  4801    DISTRIBUTION_STATUS=supported
  4802    VERSION=20.02.0-rc1.037
  4803    LINUXFAMILY=aml-s9xxx
  4804    BRANCH=current
  4805    ARCH=arm64
  4806    IMAGE_TYPE=nightly
  4807    BOARD_TYPE=conf
  4808    INITRD_ARCH=arm64
  4809    KERNEL_IMAGE_TYPE=Image
  4810
  4811    ### boot environment:
  4812
  4813    ODROIDN2-UBOOT-CONFIG
  4814    setenv env_addr 0x10400000
  4815    setenv kernel_addr 0x11000000
  4816    setenv initrd_addr 0x13000000
  4817    setenv dtb_addr 0x1000000
  4818    if test "${devtype}" = ""; then setenv devtype "mmc"; fi
  4819    load ${devtype} ${devnum} ${env_addr} uEnv.txt && env import -t ${env_addr} ${filesize}
  4820    setenv bootargs ${APPEND}
  4821    load ${devtype} ${devnum} ${kernel_addr} ${LINUX}
  4822    load ${devtype} ${devnum} ${initrd_addr} ${INITRD}
  4823    load ${devtype} ${devnum} ${dtb_addr} ${FDT}
  4824    fdt addr ${dtb_addr}
  4825    booti ${kernel_addr} ${initrd_addr} ${dtb_addr}
  4826
  4827    ### lsusb:
  4828
  4829    Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
  4830    Bus 001 Device 003: ID 148f:7601 Ralink Technology, Corp. MT7601U Wireless Adapter
  4831    Bus 001 Device 002: ID 05e3:0608 Genesys Logic, Inc. Hub
  4832    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  4833
  4834    ### lscpu:
  4835
  4836    Architecture:        aarch64
  4837    Byte Order:          Little Endian
  4838    CPU(s):              4
  4839    On-line CPU(s) list: 0-3
  4840    Thread(s) per core:  1
  4841    Core(s) per socket:  4
  4842    Socket(s):           1
  4843    Vendor ID:           ARM
  4844    Model:               4
  4845    Model name:          Cortex-A53
  4846    Stepping:            r0p4
  4847    CPU max MHz:         1512,0000
  4848    CPU min MHz:         100,0000
  4849    BogoMIPS:            48.00
  4850    L1d cache:           unknown size
  4851    L1i cache:           unknown size
  4852    L2 cache:            unknown size
  4853    Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  4854
  4855    ### cpuinfo:
  4856
  4857    processor    : 0
  4858    model name    : ARMv8 Processor rev 4 (v8l)
  4859    BogoMIPS    : 48.00
  4860    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  4861    CPU implementer    : 0x41
  4862    CPU architecture: 8
  4863    CPU variant    : 0x0
  4864    CPU part    : 0xd03
  4865    CPU revision    : 4
  4866
  4867    processor    : 1
  4868    model name    : ARMv8 Processor rev 4 (v8l)
  4869    BogoMIPS    : 48.00
  4870    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  4871    CPU implementer    : 0x41
  4872    CPU architecture: 8
  4873    CPU variant    : 0x0
  4874    CPU part    : 0xd03
  4875    CPU revision    : 4
  4876
  4877    processor    : 2
  4878    model name    : ARMv8 Processor rev 4 (v8l)
  4879    BogoMIPS    : 48.00
  4880    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  4881    CPU implementer    : 0x41
  4882    CPU architecture: 8
  4883    CPU variant    : 0x0
  4884    CPU part    : 0xd03
  4885    CPU revision    : 4
  4886
  4887    processor    : 3
  4888    model name    : ARMv8 Processor rev 4 (v8l)
  4889    BogoMIPS    : 48.00
  4890    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  4891    CPU implementer    : 0x41
  4892    CPU architecture: 8
  4893    CPU variant    : 0x0
  4894    CPU part    : 0xd03
  4895    CPU revision    : 4
  4896
  4897
  4898    ### meminfo:
  4899
  4900    MemTotal:        1782968 kB
  4901    MemFree:         1606640 kB
  4902    MemAvailable:    1665088 kB
  4903    Buffers:           11628 kB
  4904    Cached:            54492 kB
  4905    SwapCached:            0 kB
  4906    Active:            52744 kB
  4907    Inactive:          35564 kB
  4908    Active(anon):      22256 kB
  4909    Inactive(anon):     2596 kB
  4910    Active(file):      30488 kB
  4911    Inactive(file):    32968 kB
  4912    Unevictable:           0 kB
  4913    Mlocked:               0 kB
  4914    SwapTotal:        891480 kB
  4915    SwapFree:         891480 kB
  4916    Dirty:               428 kB
  4917    Writeback:             0 kB
  4918    AnonPages:         21932 kB
  4919    Mapped:            22784 kB
  4920    Shmem:              2696 kB
  4921    KReclaimable:      18108 kB
  4922    Slab:              53388 kB
  4923    SReclaimable:      18108 kB
  4924    SUnreclaim:        35280 kB
  4925    KernelStack:        2752 kB
  4926    PageTables:         1432 kB
  4927    NFS_Unstable:          0 kB
  4928    Bounce:                0 kB
  4929    WritebackTmp:          0 kB
  4930    CommitLimit:     1782964 kB
  4931    Committed_AS:      77968 kB
  4932    VmallocTotal:   135290159040 kB
  4933    VmallocUsed:       16740 kB
  4934    VmallocChunk:          0 kB
  4935    Percpu:             1264 kB
  4936    CmaTotal:         262144 kB
  4937    CmaFree:          258460 kB
  4938    HugePages_Total:       0
  4939    HugePages_Free:        0
  4940    HugePages_Rsvd:        0
  4941    HugePages_Surp:        0
  4942    Hugepagesize:       2048 kB
  4943    Hugetlb:               0 kB
  4944
  4945    ### virtual memory:
  4946
  4947    vm.admin_reserve_kbytes = 8192
  4948    vm.block_dump = 0
  4949    vm.compact_unevictable_allowed = 1
  4950    vm.dirty_background_bytes = 0
  4951    vm.dirty_background_ratio = 10
  4952    vm.dirty_bytes = 0
  4953    vm.dirty_expire_centisecs = 3000
  4954    vm.dirty_ratio = 20
  4955    vm.dirtytime_expire_seconds = 43200
  4956    vm.dirty_writeback_centisecs = 500
  4957    vm.extfrag_threshold = 500
  4958    vm.hugetlb_shm_group = 0
  4959    vm.laptop_mode = 0
  4960    vm.legacy_va_layout = 0
  4961    vm.lowmem_reserve_ratio = 256    256    32    0
  4962    vm.max_map_count = 65530
  4963    vm.min_free_kbytes = 4914
  4964    vm.mmap_min_addr = 4096
  4965    vm.mmap_rnd_bits = 18
  4966    vm.nr_hugepages = 0
  4967    vm.nr_overcommit_hugepages = 0
  4968    vm.oom_dump_tasks = 1
  4969    vm.oom_kill_allocating_task = 0
  4970    vm.overcommit_kbytes = 0
  4971    vm.overcommit_memory = 0
  4972    vm.overcommit_ratio = 50
  4973    vm.page-cluster = 0
  4974    vm.panic_on_oom = 0
  4975    vm.percpu_pagelist_fraction = 0
  4976    vm.stat_interval = 1
  4977    vm.swappiness = 100
  4978    vm.user_reserve_kbytes = 55239
  4979    vm.vfs_cache_pressure = 100
  4980    vm.watermark_boost_factor = 15000
  4981    vm.watermark_scale_factor = 10
  4982
  4983    ### ip addr:
  4984
  4985    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
  4986        link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  4987        inet XXX.XXX.0.1/8 scope host lo
  4988           valid_lft forever preferred_lft forever
  4989        inet6 ::1/128 scope host
  4990           valid_lft forever preferred_lft forever
  4991    2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
  4992        link/ether 00:df:06:00:00:0b brd ff:ff:ff:ff:ff:ff
  4993    3: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  4994        link/ether 00:36:76:61:0b:24 brd ff:ff:ff:ff:ff:ff
  4995
  4996    ### partitions:
  4997
  4998    major minor  #blocks  name
  4999
  5000     179        0   30924800 mmcblk0
  5001     179        1     262144 mmcblk0p1
  5002     179        2   30337024 mmcblk0p2
  5003     179       32   15384576 mmcblk1
  5004     179      128       8192 mmcblk1gp0
  5005     254        1     891484 zram1
  5006
  5007    ### df:
  5008
  5009    udev             738M      0  738M   0% /dev
  5010    tmpfs            175M   2,7M  172M   2% /run
  5011    /dev/mmcblk0p2    29G    10G   19G  36% /
  5012    tmpfs            871M      0  871M   0% /dev/shm
  5013    tmpfs            5,0M   4,0K  5,0M   1% /run/lock
  5014    tmpfs            871M      0  871M   0% /sys/fs/cgroup
  5015    tmpfs            871M      0  871M   0% /tmp
  5016    /dev/mmcblk0p1   256M    76M  180M  30% /boot
  5017
  5018    ### lsblk:
  5019
  5020    NAME         FSTYPE   SIZE MOUNTPOINT UUID
  5021    mmcblk0              29,5G
  5022    ├─mmcblk0p1  vfat     256M /boot      50FC-6AC8
  5023    └─mmcblk0p2  ext4      29G /          3e297ac1-e4e4-4ab1-bc57-47c07d0422ba
  5024    mmcblk1              14,7G
  5025    mmcblk1boot0            4M
  5026    mmcblk1boot1            4M
  5027    mmcblk1gp0              8M
  5028
  5029    ### zramctl:
  5030
  5031    NAME       ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT
  5032    /dev/zram1 lzo         870,6M   4K   81B   12K       4 [SWAP]
  5033
  5034    ### mtab:
  5035
  5036    /dev/mmcblk0p1 /boot vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro 0 0
  5037    /dev/mmcblk0p2 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  5038
  5039    ### mmc0:59b4 info:
  5040
  5041                   fwrev: 0x0
  5042                  uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SDU1  MODALIAS=mmc:block
  5043                     cid: 1b534d53445531201014a136d4013800
  5044                     rca: 0x59b4
  5045                     csd: 400e00325b590000ebef7f800a400000
  5046                  manfid: 0x00001b
  5047                     ocr: 0x00200000
  5048    preferred_erase_size: 4194304
  5049                    type: SD
  5050                   hwrev: 0x1
  5051                    date: 08/2019
  5052                     dsr: 0x404
  5053              erase_size: 512
  5054                   oemid: 0x534d
  5055                  serial: 0x14a136d4
  5056                     ssr: 0000000005000000040090000811391e00089a342f01000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  5057                     scr: 0235844300000000
  5058                    name: SDU1
  5059
  5060    ### mmc1:0001 info:
  5061
  5062                   fwrev: 0x0
  5063                  uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=016G92 MODALIAS=mmc:block
  5064                     cid: 11010030313647393201d3d1a4db1100
  5065             rel_sectors: 0x10
  5066                     rca: 0x0001
  5067            pre_eol_info: 0x00
  5068                     csd: d00e00320f5903ffffffffef92400000
  5069                  manfid: 0x000011
  5070                     ocr: 0x00200000
  5071    preferred_erase_size: 4194304
  5072    enhanced_area_offset: 18446744073709551594
  5073      raw_rpmb_size_mult: 0x4
  5074                    type: MMC
  5075                   hwrev: 0x0
  5076                    date: 01/2014
  5077                     prv: 0x1
  5078             ffu_capable: 0
  5079                     dsr: 0x404
  5080              erase_size: 4194304
  5081               life_time: 0x00 0x00
  5082      enhanced_area_size: 4294967274
  5083                   oemid: 0x0100
  5084                  serial: 0xd3d1a4db
  5085                 cmdq_en: 0
  5086                     rev: 0x6
  5087                    name: 016G92
  5088
  5089    ### Boot system health:
  5090
  5091    Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU
  5092    08:29:12: 1512MHz  0.15  51%  24%  14%   0%  10%   1% 60.0°C
  5093    08:29:12: 1512MHz  0.15  71%   8%  18%   1%  40%   1% 60.0°C
  5094    08:29:12: 1512MHz  0.15  68%   9%  12%   0%  44%   1% 59.0°C
  5095    08:29:13: 1512MHz  0.15  52%  10%  15%   1%  23%   2% 59.0°C
  5096    08:29:13: 1512MHz  0.15  25%   3%   4%   1%  14%   0% 58.0°C
  5097
  5098    ### Activated 1 lzo zram swap devices with 870 MB each
  5099
  5100
  5101    jue mar 25 13:14:09 CET 2021 | AML-S9xxx | 20.02.0-rc1.037 | arm64 | aarch64 | 5.5.0-rc6-aml-s9xxx
  5102
  5103    ### dmesg:
  5104
  5105    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
  5106    [    0.000000] Linux version 5.5.0-rc6-aml-s9xxx (root@vbox) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #rc1.037 SMP PREEMPT Wed Feb 5 15:59:04 MSK 2020
  5107    [    0.000000] Machine model: Amlogic Meson GXL (S905X) P212 Development Board
  5108    [    0.000000] efi: Getting EFI parameters from FDT:
  5109    [    0.000000] efi: UEFI not found.
  5110    [    0.000000] Reserved memory: created CMA memory pool at 0x0000000076000000, size 32 MiB
  5111    [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
  5112    [    0.000000] On node 0 totalpages: 477952
  5113    [    0.000000]   DMA zone: 4032 pages used for memmap
  5114    [    0.000000]   DMA zone: 0 pages reserved
  5115    [    0.000000]   DMA zone: 248576 pages, LIFO batch:63
  5116    [    0.000000]   DMA32 zone: 3584 pages used for memmap
  5117    [    0.000000]   DMA32 zone: 229376 pages, LIFO batch:63
  5118    [    0.000000] psci: probing for conduit method from DT.
  5119    [    0.000000] psci: PSCIv0.2 detected in firmware.
  5120    [    0.000000] psci: Using standard PSCI v0.2 function IDs
  5121    [    0.000000] psci: Trusted OS migration not required
  5122    [    0.000000] percpu: Embedded 22 pages/cpu s50392 r8192 d31528 u90112
  5123    [    0.000000] pcpu-alloc: s50392 r8192 d31528 u90112 alloc=22*4096
  5124    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
  5125    [    0.000000] Detected VIPT I-cache on CPU0
  5126    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 470336
  5127    [    0.000000] Kernel command line: root=LABEL=ROOTFS rootflags=data=writeback rw console=ttyAML0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 mac=00:df:06:00:00:0b
  5128    [    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
  5129    [    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
  5130    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
  5131    [    0.000000] software IO TLB: mapped [mem 0x3bfff000-0x3ffff000] (64MB)
  5132    [    0.000000] Memory: 1738992K/1911808K available (14460K kernel code, 1434K rwdata, 5884K rodata, 960K init, 927K bss, 140048K reserved, 32768K cma-reserved)
  5133    [    0.000000] random: get_random_u64 called from cache_random_seq_create+0x7c/0x150 with crng_init=0
  5134    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
  5135    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
  5136    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
  5137    [    0.000000]     Tasks RCU enabled.
  5138    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
  5139    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
  5140    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
  5141    [    0.000000] GIC: Using split EOI/Deactivate mode
  5142    [    0.000000] irq_meson_gpio: 110 to 8 gpio interrupt mux initialized
  5143    [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
  5144    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
  5145    [    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
  5146    [    0.000355] Console: colour dummy device 80x25
  5147    [    0.000656] printk: console [tty0] enabled
  5148    [    0.000698] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
  5149    [    0.000718] pid_max: default: 32768 minimum: 301
  5150    [    0.000847] LSM: Security Framework initializing
  5151    [    0.000898] SELinux:  Initializing.
  5152    [    0.000975] *** VALIDATE SELinux ***
  5153    [    0.001039] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
  5154    [    0.001066] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
  5155    [    0.001129] *** VALIDATE tmpfs ***
  5156    [    0.001540] *** VALIDATE proc ***
  5157    [    0.001761] *** VALIDATE cgroup1 ***
  5158    [    0.001776] *** VALIDATE cgroup2 ***
  5159    [    0.024016] ASID allocator initialised with 32768 entries
  5160    [    0.032000] rcu: Hierarchical SRCU implementation.
  5161    [    0.042094] EFI services will not be available.
  5162    [    0.048058] smp: Bringing up secondary CPUs ...
  5163    [    0.080286] Detected VIPT I-cache on CPU1
  5164    [    0.080340] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
  5165    [    0.112322] Detected VIPT I-cache on CPU2
  5166    [    0.112368] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
  5167    [    0.144373] Detected VIPT I-cache on CPU3
  5168    [    0.144418] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
  5169    [    0.144496] smp: Brought up 1 node, 4 CPUs
  5170    [    0.144561] SMP: Total of 4 processors activated.
  5171    [    0.144572] CPU features: detected: 32-bit EL0 Support
  5172    [    0.144584] CPU features: detected: CRC32 instructions
  5173    [    0.144888] CPU: All CPU(s) started at EL2
  5174    [    0.144910] alternatives: patching kernel code
  5175    [    0.146013] devtmpfs: initialized
  5176    [    0.151162] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
  5177    [    0.151203] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
  5178    [    0.152372] xor: measuring software checksum speed
  5179    [    0.192317]    8regs     :  2375.000 MB/sec
  5180    [    0.232347]    32regs    :  2724.000 MB/sec
  5181    [    0.272388]    arm64_neon:  2406.000 MB/sec
  5182    [    0.272399] xor: using function: 32regs (2724.000 MB/sec)
  5183    [    0.272453] pinctrl core: initialized pinctrl subsystem
  5184    [    0.273089] thermal_sys: Registered thermal governor 'step_wise'
  5185    [    0.273251] DMI not present or invalid.
  5186    [    0.273606] NET: Registered protocol family 16
  5187    [    0.277268] DMA: preallocated 256 KiB pool for atomic allocations
  5188    [    0.277317] audit: initializing netlink subsys (disabled)
  5189    [    0.277544] audit: type=2000 audit(0.276:1): state=initialized audit_enabled=0 res=1
  5190    [    0.278623] cpuidle: using governor ladder
  5191    [    0.278655] cpuidle: using governor menu
  5192    [    0.278982] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
  5193    [    0.279706] Serial: AMBA PL011 UART driver
  5194    [    0.293714] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
  5195    [    0.293741] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
  5196    [    0.293754] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
  5197    [    0.293767] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
  5198    [    0.297435] cryptd: max_cpu_qlen set to 1000
  5199    [    0.372652] raid6: neonx8   gen()  1621 MB/s
  5200    [    0.440686] raid6: neonx8   xor()  1491 MB/s
  5201    [    0.508757] raid6: neonx4   gen()  1564 MB/s
  5202    [    0.576773] raid6: neonx4   xor()  1470 MB/s
  5203    [    0.644832] raid6: neonx2   gen()  1199 MB/s
  5204    [    0.712890] raid6: neonx2   xor()  1216 MB/s
  5205    [    0.780931] raid6: neonx1   gen()   786 MB/s
  5206    [    0.849035] raid6: neonx1   xor()   915 MB/s
  5207    [    0.917050] raid6: int64x8  gen()  1194 MB/s
  5208    [    0.985108] raid6: int64x8  xor()   769 MB/s
  5209    [    1.053172] raid6: int64x4  gen()  1029 MB/s
  5210    [    1.121227] raid6: int64x4  xor()   752 MB/s
  5211    [    1.189254] raid6: int64x2  gen()   728 MB/s
  5212    [    1.257302] raid6: int64x2  xor()   613 MB/s
  5213    [    1.325388] raid6: int64x1  gen()   486 MB/s
  5214    [    1.393431] raid6: int64x1  xor()   467 MB/s
  5215    [    1.393442] raid6: using algorithm neonx8 gen() 1621 MB/s
  5216    [    1.393452] raid6: .... xor() 1491 MB/s, rmw enabled
  5217    [    1.393462] raid6: using neon recovery algorithm
  5218    [    1.393745] ACPI: Interpreter disabled.
  5219    [    1.394922] iommu: Default domain type: Translated
  5220    [    1.395191] vgaarb: loaded
  5221    [    1.395771] SCSI subsystem initialized
  5222    [    1.395952] libata version 3.00 loaded.
  5223    [    1.396163] usbcore: registered new interface driver usbfs
  5224    [    1.396210] usbcore: registered new interface driver hub
  5225    [    1.396271] usbcore: registered new device driver usb
  5226    [    1.396665] pps_core: LinuxPPS API ver. 1 registered
  5227    [    1.396678] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
  5228    [    1.396701] PTP clock support registered
  5229    [    1.396729] EDAC MC: Ver: 3.0.0
  5230    [    1.397269] FPGA manager framework
  5231    [    1.397397] Advanced Linux Sound Architecture Driver Initialized.
  5232    [    1.397857] NetLabel: Initializing
  5233    [    1.397870] NetLabel:  domain hash size = 128
  5234    [    1.397880] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
  5235    [    1.397940] NetLabel:  unlabeled traffic allowed by default
  5236    [    1.398444] clocksource: Switched to clocksource arch_sys_counter
  5237    [    1.398470] *** VALIDATE bpf ***
  5238    [    1.398726] VFS: Disk quotas dquot_6.6.0
  5239    [    1.398788] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
  5240    [    1.398909] FS-Cache: Loaded
  5241    [    1.398919] *** VALIDATE ramfs ***
  5242    [    1.398940] *** VALIDATE hugetlbfs ***
  5243    [    1.399309] pnp: PnP ACPI: disabled
  5244    [    1.404399] NET: Registered protocol family 2
  5245    [    1.404891] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
  5246    [    1.404941] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
  5247    [    1.405060] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
  5248    [    1.405273] TCP: Hash tables configured (established 16384 bind 16384)
  5249    [    1.405429] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
  5250    [    1.405481] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
  5251    [    1.405693] NET: Registered protocol family 1
  5252    [    1.406167] RPC: Registered named UNIX socket transport module.
  5253    [    1.406191] RPC: Registered udp transport module.
  5254    [    1.406201] RPC: Registered tcp transport module.
  5255    [    1.406210] RPC: Registered tcp NFSv4.1 backchannel transport module.
  5256    [    1.406226] NET: Registered protocol family 44
  5257    [    1.406247] PCI: CLS 0 bytes, default 64
  5258    [    1.406512] Trying to unpack rootfs image as initramfs...
  5259    [    1.867660] Freeing initrd memory: 10248K
  5260    [    1.868457] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
  5261    [    2.081826] Initialise system trusted keyrings
  5262    [    2.082041] workingset: timestamp_bits=46 max_order=19 bucket_order=0
  5263    [    2.087265] zbud: loaded
  5264    [    2.088499] squashfs: version 4.0 (2009/01/31) Phillip Lougher
  5265    [    2.088776] FS-Cache: Netfs 'nfs' registered for caching
  5266    [    2.089309] NFS: Registering the id_resolver key type
  5267    [    2.089348] Key type id_resolver registered
  5268    [    2.089358] Key type id_legacy registered
  5269    [    2.089375] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
  5270    [    2.089388] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
  5271    [    2.090632] FS-Cache: Netfs 'cifs' registered for caching
  5272    [    2.090984] Key type cifs.spnego registered
  5273    [    2.091006] Key type cifs.idmap registered
  5274    [    2.091031] ntfs: driver 2.1.32 [Flags: R/W].
  5275    [    2.091626] JFS: nTxBlock = 8192, nTxLock = 65536
  5276    [    2.097468] SGI XFS with ACLs, security attributes, realtime, quota, no debug enabled
  5277    [    2.098907] *** VALIDATE xfs ***
  5278    [    2.099219] ocfs2: Registered cluster interface o2cb
  5279    [    2.099432] OCFS2 User DLM kernel interface loaded
  5280    [    2.100780] *** VALIDATE gfs2 ***
  5281    [    2.101044] gfs2: GFS2 installed
  5282    [    2.101952] aufs 5.5-20200203
  5283    [    2.122493] Key type asymmetric registered
  5284    [    2.122519] Asymmetric key parser 'x509' registered
  5285    [    2.122530] Asymmetric key parser 'pkcs8' registered
  5286    [    2.122600] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
  5287    [    2.122789] io scheduler mq-deadline registered
  5288    [    2.122803] io scheduler kyber registered
  5289    [    2.123002] io scheduler bfq registered
  5290    [    2.135623] soc soc0: Amlogic Meson GXL (S905X) Revision 21:b (82:2) Detected
  5291    [    2.139232] Serial: 8250/16550 driver, 5 ports, IRQ sharing enabled
  5292    [    2.140940] Serial: AMBA driver
  5293    [    2.141302] c11084c0.serial: ttyAML6 at MMIO 0xc11084c0 (irq = 10, base_baud = 1500000) is a meson_uart
  5294    [    2.141459] serial serial0: tty port ttyAML6 registered
  5295    [    2.141665] c81004c0.serial: ttyAML0 at MMIO 0xc81004c0 (irq = 13, base_baud = 1500000) is a meson_uart
  5296    [    3.116963] printk: console [ttyAML0] enabled
  5297    [    3.133135] brd: module loaded
  5298    [    3.141592] loop: module loaded
  5299    [    3.144065] libphy: Fixed MDIO Bus: probed
  5300    [    3.144711] meson8b-dwmac c9410000.ethernet: IRQ eth_wake_irq not found
  5301    [    3.149763] meson8b-dwmac c9410000.ethernet: IRQ eth_lpi not found
  5302    [    3.155968] meson8b-dwmac c9410000.ethernet: PTP uses main clock
  5303    [    3.161823] meson8b-dwmac c9410000.ethernet: no reset control found
  5304    [    3.168506] meson8b-dwmac c9410000.ethernet: User ID: 0x11, Synopsys ID: 0x37
  5305    [    3.175126] meson8b-dwmac c9410000.ethernet:     DWMAC1000
  5306    [    3.180291] meson8b-dwmac c9410000.ethernet: DMA HW capability register supported
  5307    [    3.187691] meson8b-dwmac c9410000.ethernet: RX Checksum Offload Engine supported
  5308    [    3.195109] meson8b-dwmac c9410000.ethernet: COE Type 2
  5309    [    3.200281] meson8b-dwmac c9410000.ethernet: TX Checksum insertion supported
  5310    [    3.207268] meson8b-dwmac c9410000.ethernet: Wake-Up On Lan supported
  5311    [    3.213690] meson8b-dwmac c9410000.ethernet: Normal descriptors
  5312    [    3.219518] meson8b-dwmac c9410000.ethernet: Ring mode enabled
  5313    [    3.225294] meson8b-dwmac c9410000.ethernet: Enable RX Mitigation via HW Watchdog Timer
  5314    [    3.233411] libphy: stmmac: probed
  5315    [    3.237901] VFIO - User Level meta-driver version: 0.3
  5316    [    3.243237] dwc3 c9000000.dwc3: Failed to get clk 'ref': -2
  5317    [    3.248117] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
  5318    [    3.253700] ehci-pci: EHCI PCI platform driver
  5319    [    3.258139] ehci-platform: EHCI generic platform driver
  5320    [    3.263428] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
  5321    [    3.269385] ohci-pci: OHCI PCI platform driver
  5322    [    3.273812] ohci-platform: OHCI generic platform driver
  5323    [    3.279572] usbcore: registered new interface driver usb-storage
  5324    [    3.285150] mousedev: PS/2 mouse device common for all mice
  5325    [    3.291102] i2c /dev entries driver
  5326    [    3.296705] sdhci: Secure Digital Host Controller Interface driver
  5327    [    3.300011] sdhci: Copyright(c) Pierre Ossman
  5328    [    3.304321] Synopsys Designware Multimedia Card Interface Driver
  5329    [    3.311644] meson-gx-mmc d0072000.mmc: Got CD GPIO
  5330    [    3.342280] meson-gx-mmc d0074000.mmc: allocated mmc-pwrseq
  5331    [    3.369861] sdhci-pltfm: SDHCI platform and OF driver helper
  5332    [    3.370759] ledtrig-cpu: registered to indicate activity on CPUs
  5333    [    3.376438] meson-sm: secure-monitor enabled
  5334    [    3.380756] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
  5335    [    3.381969] mmc0: new high speed SDHC card at address 59b4
  5336    [    3.388054] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
  5337    [    3.394158] mmcblk0: mmc0:59b4 SDU1  29.5 GiB
  5338    [    3.408285]  mmcblk0: p1 p2
  5339    [    3.418535] hid: raw HID events driver (C) Jiri Kosina
  5340    [    3.418784] usbcore: registered new interface driver usbhid
  5341    [    3.423655] usbhid: USB HID core driver
  5342    [    3.427748] platform-mhu c883c404.mailbox: Platform MHU Mailbox registered
  5343    [    3.444100] NET: Registered protocol family 17
  5344    [    3.444361] Key type dns_resolver registered
  5345    [    3.447805] registered taskstats version 1
  5346    [    3.451268] Loading compiled-in X.509 certificates
  5347    [    3.456140] zswap: loaded using pool lzo/zbud
  5348    [    3.460468] Key type ._fscrypt registered
  5349    [    3.464236] Key type .fscrypt registered
  5350    [    3.469606] Btrfs loaded, crc32c=crc32c-generic
  5351    [    3.489471] mmc1: new HS200 MMC card at address 0001
  5352    [    3.494493] mmcblk1: mmc1:0001 016G92 14.7 GiB
  5353    [    3.494948] mmcblk1boot0: mmc1:0001 016G92 partition 1 4.00 MiB
  5354    [    3.495962] Key type encrypted registered
  5355    [    3.499744] mmcblk1boot1: mmc1:0001 016G92 partition 2 4.00 MiB
  5356    [    3.509598] mmcblk1gp0: mmc1:0001 016G92 partition 4 8.00 MiB
  5357    [    3.515089] mmcblk1rpmb: mmc1:0001 016G92 partition 3 512 KiB, chardev (243:0)
  5358    [    3.522962] meson-drm d0100000.vpu: Queued 3 outputs on vpu
  5359    [    3.527799] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
  5360    [    3.534071] [drm] No driver support for vblank timestamp query.
  5361    [    3.566497] meson-dw-hdmi c883a000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
  5362    [    3.571144] meson-dw-hdmi c883a000.hdmi-tx: registered DesignWare HDMI I2C bus driver
  5363    [    3.579162] meson-drm d0100000.vpu: bound c883a000.hdmi-tx (ops meson_dw_hdmi_ops)
  5364    [    3.586477] [drm] Initialized meson 1.0.0 20161109 for d0100000.vpu on minor 0
  5365    [    3.632479] Console: switching to colour frame buffer device 90x36
  5366    [    3.652708] meson-drm d0100000.vpu: fb0: mesondrmfb frame buffer device
  5367    [    3.659974] libphy: mdio_mux: probed
  5368    [    3.670593] libphy: mdio_mux: probed
  5369    [    3.671080] phy phy-d0078080.phy.2: unsupported PHY mode 5
  5370    [    3.676176] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  5371    [    3.679517] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
  5372    [    3.687223] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228f664 hci version 0x100 quirks 0x0000000002010010
  5373    [    3.696450] xhci-hcd xhci-hcd.0.auto: irq 39, io mem 0xc9000000
  5374    [    3.702598] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.05
  5375    [    3.710958] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  5376    [    3.718112] usb usb1: Product: xHCI Host Controller
  5377    [    3.722942] usb usb1: Manufacturer: Linux 5.5.0-rc6-aml-s9xxx xhci-hcd
  5378    [    3.729411] usb usb1: SerialNumber: xhci-hcd.0.auto
  5379    [    3.734773] hub 1-0:1.0: USB hub found
  5380    [    3.737971] hub 1-0:1.0: 2 ports detected
  5381    [    3.742210] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  5382    [    3.747369] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
  5383    [    3.754954] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
  5384    [    3.761457] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
  5385    [    3.769721] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.05
  5386    [    3.778101] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  5387    [    3.785258] usb usb2: Product: xHCI Host Controller
  5388    [    3.790086] usb usb2: Manufacturer: Linux 5.5.0-rc6-aml-s9xxx xhci-hcd
  5389    [    3.796556] usb usb2: SerialNumber: xhci-hcd.0.auto
  5390    [    3.801861] hub 2-0:1.0: USB hub found
  5391    [    3.805137] hub 2-0:1.0: config failed, hub doesn't have any ports! (err -19)
  5392    [    3.813943] meson-gx-mmc d0070000.mmc: allocated mmc-pwrseq
  5393    [    3.843440] scpi_protocol scpi: SCP Protocol legacy pre-1.0 firmware
  5394    [    3.860948] gx-sound-card sound: snd-soc-dummy-dai <-> c1105400.bus:audio-controller-0 mapping ok
  5395    [    3.870166] gx-sound-card sound: i2s-hifi <-> c1105400.bus:audio-controller-2 mapping ok
  5396    [    3.877878] gx-sound-card sound: ASoC: no DMI vendor name!
  5397    [    3.884153] printk: console [netcon0] enabled
  5398    [    3.887584] netconsole: network logging started
  5399    [    3.892043] hctosys: unable to open rtc device (rtc0)
  5400    [    3.897359] ALSA device list:
  5401    [    3.899986]   #0: AMLGX
  5402    [    3.903050] Freeing unused kernel memory: 960K
  5403    [    3.906903] Run /init as init process
  5404    [    3.918929] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
  5405    [    3.925087] mmc2: queuing unknown CIS tuple 0x80 (6 bytes)
  5406    [    3.931686] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
  5407    [    3.943271] mmc2: queuing unknown CIS tuple 0x80 (19 bytes)
  5408    [    3.970936] random: fast init done
  5409    [    4.029018] mmc2: new high speed SDIO card at address 0001
  5410    [    4.074524] usb 1-1: new high-speed USB device number 2 using xhci-hcd
  5411    [    4.095866] usb 1-1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.36
  5412    [    4.102548] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
  5413    [    4.109638] usb 1-1: Product: USB2.0 Hub
  5414    [    4.177958] hub 1-1:1.0: USB hub found
  5415    [    4.180503] hub 1-1:1.0: 4 ports detected
  5416    [    4.314536] usb 1-2: new high-speed USB device number 3 using xhci-hcd
  5417    [    4.344949] usb 1-2: New USB device found, idVendor=148f, idProduct=7601, bcdDevice= 0.00
  5418    [    4.351851] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
  5419    [    4.358930] usb 1-2: Product: 802.11 n WLAN
  5420    [    4.362957] usb 1-2: Manufacturer: MediaTek
  5421    [    4.367037] usb 1-2: SerialNumber: 1.0
  5422    [    5.080597] EXT4-fs (mmcblk0p2): mounted filesystem with writeback data mode. Opts: data=writeback
  5423    [    6.016593] systemd[1]: System time before build time, advancing clock.
  5424    [    6.176071] NET: Registered protocol family 10
  5425    [    6.244830] Segment Routing with IPv6
  5426    [    6.296213] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
  5427    [    6.329732] systemd[1]: Detected architecture arm64.
  5428    [    6.381795] systemd[1]: Set hostname to <mxqpro>.
  5429    [    6.411797] systemd[1]: Couldn't move remaining userspace processes, ignoring: Input/output error
  5430    [    7.098310] random: systemd: uninitialized urandom read (16 bytes read)
  5431    [    7.110626] random: systemd: uninitialized urandom read (16 bytes read)
  5432    [    7.116481] systemd[1]: Created slice User and Session Slice.
  5433    [    7.122955] random: systemd: uninitialized urandom read (16 bytes read)
  5434    [    7.126508] systemd[1]: Reached target System Time Synchronized.
  5435    [    7.135754] systemd[1]: Listening on fsck to fsckd communication Socket.
  5436    [    7.142958] systemd[1]: Listening on Journal Audit Socket.
  5437    [    7.148678] systemd[1]: Listening on initctl Compatibility Named Pipe.
  5438    [    7.155046] systemd[1]: Reached target Swap.
  5439    [    7.315648] EXT4-fs (mmcblk0p2): re-mounted. Opts: commit=600,errors=remount-ro
  5440    [    7.514419] systemd-journald[400]: Received request to flush runtime journal from PID 1
  5441    [    8.087822] mc: Linux media interface: v0.10
  5442    [    8.112987] videodev: Linux video capture interface: v2.00
  5443    [    8.173973] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
  5444    [    8.187330] Registered IR keymap rc-empty
  5445    [    8.189629] rc rc0: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0
  5446    [    8.196349] input: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0/input0
  5447    [    8.204475] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
  5448    [    8.213462] meson-ir c8100580.ir: receiver initialized
  5449    [    8.330428] lima d00c0000.gpu: IRQ ppmmu3 not found
  5450    [    8.332928] lima d00c0000.gpu: IRQ ppmmu4 not found
  5451    [    8.337055] lima d00c0000.gpu: IRQ ppmmu5 not found
  5452    [    8.342276] lima d00c0000.gpu: IRQ ppmmu6 not found
  5453    [    8.346674] lima d00c0000.gpu: IRQ ppmmu7 not found
  5454    [    8.351906] lima d00c0000.gpu: gp - mali450 version major 0 minor 0
  5455    [    8.358310] lima d00c0000.gpu: pp0 - mali450 version major 0 minor 0
  5456    [    8.364132] lima d00c0000.gpu: pp1 - mali450 version major 0 minor 0
  5457    [    8.392798] lima d00c0000.gpu: pp2 - mali450 version major 0 minor 0
  5458    [    8.404030] lima d00c0000.gpu: IRQ pp3 not found
  5459    [    8.406071] lima d00c0000.gpu: IRQ pp4 not found
  5460    [    8.411195] Bluetooth: Core ver 2.22
  5461    [    8.414163] NET: Registered protocol family 31
  5462    [    8.418076] Bluetooth: HCI device and connection manager initialized
  5463    [    8.424169] lima d00c0000.gpu: IRQ pp5 not found
  5464    [    8.429610] lima d00c0000.gpu: IRQ pp6 not found
  5465    [    8.433371] Bluetooth: HCI socket layer initialized
  5466    [    8.435704] lima d00c0000.gpu: IRQ pp7 not found
  5467    [    8.437881] Bluetooth: L2CAP socket layer initialized
  5468    [    8.448502] Bluetooth: SCO socket layer initialized
  5469    [    8.449879] lima d00c0000.gpu: l2 cache 8K, 4-way, 64byte cache line, 128bit external bus
  5470    [    8.465305] lima d00c0000.gpu: l2 cache 64K, 4-way, 64byte cache line, 128bit external bus
  5471    [    8.476283] lima d00c0000.gpu: bus rate = 166666667
  5472    [    8.481353] lima d00c0000.gpu: mod rate = 744000000
  5473    [    8.484713] [drm] Initialized lima 1.0.0 20190217 for d00c0000.gpu on minor 1
  5474    [    8.507606] cfg80211: Loading compiled-in X.509 certificates for regulatory database
  5475    [    8.554437] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
  5476    [    8.568272] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
  5477    [    8.574785] cfg80211: failed to load regulatory.db
  5478    [    8.636201] Bluetooth: HCI UART driver ver 2.3
  5479    [    8.638158] Bluetooth: HCI UART protocol H4 registered
  5480    [    8.642130] Bluetooth: HCI UART protocol BCSP registered
  5481    [    8.647604] Bluetooth: HCI UART protocol LL registered
  5482    [    8.652481] Bluetooth: HCI UART protocol ATH3K registered
  5483    [    8.657961] Bluetooth: HCI UART protocol Three-wire (H5) registered
  5484    [    8.666809] Bluetooth: HCI UART protocol Intel registered
  5485    [    8.676166] Bluetooth: HCI UART protocol Broadcom registered
  5486    [    8.676295] hci_uart_bcm serial0-0: serial0-0 supply vbat not found, using dummy regulator
  5487    [    8.678753] Bluetooth: HCI UART protocol QCA registered
  5488    [    8.686964] hci_uart_bcm serial0-0: serial0-0 supply vddio not found, using dummy regulator
  5489    [    8.692817] Bluetooth: HCI UART protocol AG6XX registered
  5490    [    8.706966] Bluetooth: HCI UART protocol Marvell registered
  5491    [    8.771672] brcmfmac: F1 signature read @0x18000000=0x16034334
  5492    [    8.776191] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4334-sdio for chip BCM4334/3
  5493    [    8.784002] usbcore: registered new interface driver brcmfmac
  5494    [    8.832472] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.amlogic,p212.txt failed with error -2
  5495    [    8.842654] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.txt failed with error -2
  5496    [    8.898795] usb 1-2: reset high-speed USB device number 3 using xhci-hcd
  5497    [    8.921533] mt7601u 1-2:1.0: ASIC revision: 76010001 MAC revision: 76010500
  5498    [    8.954204] mt7601u 1-2:1.0: EEPROM ver:0d fae:00
  5499    [    9.087505] Bluetooth: hci0: BCM: chip id 68
  5500    [    9.090826] Bluetooth: hci0: BCM: features 0x0f
  5501    [    9.095328] Bluetooth: hci0: BCM4334B0
  5502    [    9.099208] Bluetooth: hci0: BCM4334B0 (002.001.013) build 0000
  5503    [    9.103571] bluetooth hci0: Direct firmware load for brcm/BCM4334B0.hcd failed with error -2
  5504    [    9.112576] Bluetooth: hci0: BCM: Patch brcm/BCM4334B0.hcd not found
  5505    [    9.161029] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
  5506    [    9.162083] usbcore: registered new interface driver mt7601u
  5507    [    9.858558] brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x50
  5508    [    9.924476] zram: Added device: zram0
  5509    [    9.929425] zram: Added device: zram1
  5510    [    9.932756] zram: Added device: zram2
  5511    [    9.969596] zram1: detected capacity change from 0 to 912879616
  5512    [    9.977617] meson8b-dwmac c9410000.ethernet eth0: PHY [0.e40908ff:08] driver [Meson GXL Internal PHY]
  5513    [    9.998576] meson8b-dwmac c9410000.ethernet eth0: No Safety Features support found
  5514    [   10.003018] meson8b-dwmac c9410000.ethernet eth0: PTP not supported by HW
  5515    [   10.016025] meson8b-dwmac c9410000.ethernet eth0: configuring for phy/rmii link mode
  5516    [   10.577428] random: crng init done
  5517    [   10.580005] random: 7 urandom warning(s) missed due to ratelimiting
  5518    [   10.674782] Adding 891480k swap on /dev/zram1.  Priority:5 extents:1 across:891480k SSFS
  5519
  5520    ### armbian-release:
  5521
  5522    # PLEASE DO NOT EDIT THIS FILE
  5523    BOARD=aml-s9xxx
  5524    BOARD_NAME="AML-S9xxx"
  5525    BOARDFAMILY=aml-s9xxx
  5526    BUILD_REPOSITORY_URL=https://github.com/150balbes/Build-Armbian.git
  5527    BUILD_REPOSITORY_COMMIT=62b8c07-dirty
  5528    DISTRIBUTION_CODENAME=buster
  5529    DISTRIBUTION_STATUS=supported
  5530    VERSION=20.02.0-rc1.037
  5531    LINUXFAMILY=aml-s9xxx
  5532    BRANCH=current
  5533    ARCH=arm64
  5534    IMAGE_TYPE=nightly
  5535    BOARD_TYPE=conf
  5536    INITRD_ARCH=arm64
  5537    KERNEL_IMAGE_TYPE=Image
  5538
  5539    ### boot environment:
  5540
  5541    ODROIDN2-UBOOT-CONFIG
  5542    setenv env_addr 0x10400000
  5543    setenv kernel_addr 0x11000000
  5544    setenv initrd_addr 0x13000000
  5545    setenv dtb_addr 0x1000000
  5546    if test "${devtype}" = ""; then setenv devtype "mmc"; fi
  5547    load ${devtype} ${devnum} ${env_addr} uEnv.txt && env import -t ${env_addr} ${filesize}
  5548    setenv bootargs ${APPEND}
  5549    load ${devtype} ${devnum} ${kernel_addr} ${LINUX}
  5550    load ${devtype} ${devnum} ${initrd_addr} ${INITRD}
  5551    load ${devtype} ${devnum} ${dtb_addr} ${FDT}
  5552    fdt addr ${dtb_addr}
  5553    booti ${kernel_addr} ${initrd_addr} ${dtb_addr}
  5554
  5555    ### lsusb:
  5556
  5557    Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
  5558    Bus 001 Device 003: ID 148f:7601 Ralink Technology, Corp. MT7601U Wireless Adapter
  5559    Bus 001 Device 002: ID 05e3:0608 Genesys Logic, Inc. Hub
  5560    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  5561
  5562    ### lscpu:
  5563
  5564    Architecture:        aarch64
  5565    Byte Order:          Little Endian
  5566    CPU(s):              4
  5567    On-line CPU(s) list: 0-3
  5568    Thread(s) per core:  1
  5569    Core(s) per socket:  4
  5570    Socket(s):           1
  5571    Vendor ID:           ARM
  5572    Model:               4
  5573    Model name:          Cortex-A53
  5574    Stepping:            r0p4
  5575    CPU max MHz:         1512,0000
  5576    CPU min MHz:         100,0000
  5577    BogoMIPS:            48.00
  5578    L1d cache:           unknown size
  5579    L1i cache:           unknown size
  5580    L2 cache:            unknown size
  5581    Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  5582
  5583    ### cpuinfo:
  5584
  5585    processor    : 0
  5586    model name    : ARMv8 Processor rev 4 (v8l)
  5587    BogoMIPS    : 48.00
  5588    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  5589    CPU implementer    : 0x41
  5590    CPU architecture: 8
  5591    CPU variant    : 0x0
  5592    CPU part    : 0xd03
  5593    CPU revision    : 4
  5594
  5595    processor    : 1
  5596    model name    : ARMv8 Processor rev 4 (v8l)
  5597    BogoMIPS    : 48.00
  5598    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  5599    CPU implementer    : 0x41
  5600    CPU architecture: 8
  5601    CPU variant    : 0x0
  5602    CPU part    : 0xd03
  5603    CPU revision    : 4
  5604
  5605    processor    : 2
  5606    model name    : ARMv8 Processor rev 4 (v8l)
  5607    BogoMIPS    : 48.00
  5608    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  5609    CPU implementer    : 0x41
  5610    CPU architecture: 8
  5611    CPU variant    : 0x0
  5612    CPU part    : 0xd03
  5613    CPU revision    : 4
  5614
  5615    processor    : 3
  5616    model name    : ARMv8 Processor rev 4 (v8l)
  5617    BogoMIPS    : 48.00
  5618    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  5619    CPU implementer    : 0x41
  5620    CPU architecture: 8
  5621    CPU variant    : 0x0
  5622    CPU part    : 0xd03
  5623    CPU revision    : 4
  5624
  5625
  5626    ### meminfo:
  5627
  5628    MemTotal:        1782968 kB
  5629    MemFree:         1602384 kB
  5630    MemAvailable:    1658892 kB
  5631    Buffers:           11628 kB
  5632    Cached:            58260 kB
  5633    SwapCached:            0 kB
  5634    Active:            53124 kB
  5635    Inactive:          39252 kB
  5636    Active(anon):      22828 kB
  5637    Inactive(anon):     4816 kB
  5638    Active(file):      30296 kB
  5639    Inactive(file):    34436 kB
  5640    Unevictable:           0 kB
  5641    Mlocked:               0 kB
  5642    SwapTotal:        891480 kB
  5643    SwapFree:         891480 kB
  5644    Dirty:               376 kB
  5645    Writeback:             0 kB
  5646    AnonPages:         22532 kB
  5647    Mapped:            24720 kB
  5648    Shmem:              4916 kB
  5649    KReclaimable:      17780 kB
  5650    Slab:              53304 kB
  5651    SReclaimable:      17780 kB
  5652    SUnreclaim:        35524 kB
  5653    KernelStack:        2836 kB
  5654    PageTables:         1724 kB
  5655    NFS_Unstable:          0 kB
  5656    Bounce:                0 kB
  5657    WritebackTmp:          0 kB
  5658    CommitLimit:     1782964 kB
  5659    Committed_AS:      92168 kB
  5660    VmallocTotal:   135290159040 kB
  5661    VmallocUsed:       16820 kB
  5662    VmallocChunk:          0 kB
  5663    Percpu:             1264 kB
  5664    CmaTotal:          32768 kB
  5665    CmaFree:           29084 kB
  5666    HugePages_Total:       0
  5667    HugePages_Free:        0
  5668    HugePages_Rsvd:        0
  5669    HugePages_Surp:        0
  5670    Hugepagesize:       2048 kB
  5671    Hugetlb:               0 kB
  5672
  5673    ### virtual memory:
  5674
  5675    vm.admin_reserve_kbytes = 8192
  5676    vm.block_dump = 0
  5677    vm.compact_unevictable_allowed = 1
  5678    vm.dirty_background_bytes = 0
  5679    vm.dirty_background_ratio = 10
  5680    vm.dirty_bytes = 0
  5681    vm.dirty_expire_centisecs = 3000
  5682    vm.dirty_ratio = 20
  5683    vm.dirtytime_expire_seconds = 43200
  5684    vm.dirty_writeback_centisecs = 500
  5685    vm.extfrag_threshold = 500
  5686    vm.hugetlb_shm_group = 0
  5687    vm.laptop_mode = 0
  5688    vm.legacy_va_layout = 0
  5689    vm.lowmem_reserve_ratio = 256    256    32    0
  5690    vm.max_map_count = 65530
  5691    vm.min_free_kbytes = 5274
  5692    vm.mmap_min_addr = 4096
  5693    vm.mmap_rnd_bits = 18
  5694    vm.nr_hugepages = 0
  5695    vm.nr_overcommit_hugepages = 0
  5696    vm.oom_dump_tasks = 1
  5697    vm.oom_kill_allocating_task = 0
  5698    vm.overcommit_kbytes = 0
  5699    vm.overcommit_memory = 0
  5700    vm.overcommit_ratio = 50
  5701    vm.page-cluster = 0
  5702    vm.panic_on_oom = 0
  5703    vm.percpu_pagelist_fraction = 0
  5704    vm.stat_interval = 1
  5705    vm.swappiness = 100
  5706    vm.user_reserve_kbytes = 55239
  5707    vm.vfs_cache_pressure = 100
  5708    vm.watermark_boost_factor = 15000
  5709    vm.watermark_scale_factor = 10
  5710
  5711    ### ip addr:
  5712
  5713    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
  5714        link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  5715        inet XXX.XXX.0.1/8 scope host lo
  5716           valid_lft forever preferred_lft forever
  5717        inet6 ::1/128 scope host
  5718           valid_lft forever preferred_lft forever
  5719    2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
  5720        link/ether 00:df:06:00:00:0b brd ff:ff:ff:ff:ff:ff
  5721    3: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  5722        link/ether 00:36:76:61:0b:24 brd ff:ff:ff:ff:ff:ff
  5723
  5724    ### partitions:
  5725
  5726    major minor  #blocks  name
  5727
  5728     179        0   30924800 mmcblk0
  5729     179        1     262144 mmcblk0p1
  5730     179        2   30337024 mmcblk0p2
  5731     179       32   15384576 mmcblk1
  5732     179      128       8192 mmcblk1gp0
  5733     254        1     891484 zram1
  5734
  5735    ### df:
  5736
  5737    udev             850M      0  850M   0% /dev
  5738    tmpfs            175M   4,9M  170M   3% /run
  5739    /dev/mmcblk0p2    29G    10G   19G  36% /
  5740    tmpfs            871M      0  871M   0% /dev/shm
  5741    tmpfs            5,0M   4,0K  5,0M   1% /run/lock
  5742    tmpfs            871M      0  871M   0% /sys/fs/cgroup
  5743    tmpfs            871M      0  871M   0% /tmp
  5744    /dev/mmcblk0p1   256M    76M  180M  30% /boot
  5745
  5746    ### lsblk:
  5747
  5748    NAME         FSTYPE   SIZE MOUNTPOINT UUID
  5749    mmcblk0              29,5G
  5750    ├─mmcblk0p1  vfat     256M /boot      50FC-6AC8
  5751    └─mmcblk0p2  ext4      29G /          3e297ac1-e4e4-4ab1-bc57-47c07d0422ba
  5752    mmcblk1              14,7G
  5753    mmcblk1boot0            4M
  5754    mmcblk1boot1            4M
  5755    mmcblk1gp0              8M
  5756
  5757    ### zramctl:
  5758
  5759    NAME       ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT
  5760    /dev/zram1 lzo         870,6M   4K   81B   12K       4 [SWAP]
  5761
  5762    ### mtab:
  5763
  5764    /dev/mmcblk0p1 /boot vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro 0 0
  5765    /dev/mmcblk0p2 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  5766
  5767    ### mmc0:59b4 info:
  5768
  5769                   fwrev: 0x0
  5770                  uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SDU1  MODALIAS=mmc:block
  5771                     cid: 1b534d53445531201014a136d4013800
  5772                     rca: 0x59b4
  5773                     csd: 400e00325b590000ebef7f800a400000
  5774                  manfid: 0x00001b
  5775                     ocr: 0x00200000
  5776    preferred_erase_size: 4194304
  5777                    type: SD
  5778                   hwrev: 0x1
  5779                    date: 08/2019
  5780                     dsr: 0x404
  5781              erase_size: 512
  5782                   oemid: 0x534d
  5783                  serial: 0x14a136d4
  5784                     ssr: 0000000005000000040090000811391e00089a342f01000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  5785                     scr: 0235844300000000
  5786                    name: SDU1
  5787
  5788    ### mmc1:0001 info:
  5789
  5790                   fwrev: 0x0
  5791                  uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=016G92 MODALIAS=mmc:block
  5792                     cid: 11010030313647393201d3d1a4db1100
  5793             rel_sectors: 0x10
  5794                     rca: 0x0001
  5795            pre_eol_info: 0x00
  5796                     csd: d00e00320f5903ffffffffef92400000
  5797                  manfid: 0x000011
  5798                     ocr: 0x00200000
  5799    preferred_erase_size: 4194304
  5800    enhanced_area_offset: 18446744073709551594
  5801      raw_rpmb_size_mult: 0x4
  5802                    type: MMC
  5803                   hwrev: 0x0
  5804                    date: 01/2014
  5805                     prv: 0x1
  5806             ffu_capable: 0
  5807                     dsr: 0x404
  5808              erase_size: 4194304
  5809               life_time: 0x00 0x00
  5810      enhanced_area_size: 4294967274
  5811                   oemid: 0x0100
  5812                  serial: 0xd3d1a4db
  5813                 cmdq_en: 0
  5814                     rev: 0x6
  5815                    name: 016G92
  5816
  5817    ### Boot system health:
  5818
  5819    Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU
  5820    13:14:12: 1512MHz  0.55  52%  24%  15%   0%  11%   1% 57.0°C
  5821    13:14:12: 1512MHz  0.55  71%  12%  26%   1%  28%   1% 57.0°C
  5822    13:14:12: 1512MHz  0.55  53%   8%   7%   0%  35%   1% 56.0°C
  5823    13:14:13: 1512MHz  0.55  46%   7%  13%   2%  22%   1% 56.0°C
  5824    13:14:13: 1512MHz  0.55  18%   3%   5%   0%   7%   1% 56.0°C
  5825
  5826    ### Activated 1 lzo zram swap devices with 870 MB each
  5827
  5828
  5829    jue mar 25 13:17:04 CET 2021 | AML-S9xxx | 20.02.0-rc1.037 | arm64 | aarch64 | 5.5.0-rc6-aml-s9xxx
  5830
  5831    ### dmesg:
  5832
  5833    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
  5834    [    0.000000] Linux version 5.5.0-rc6-aml-s9xxx (root@vbox) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #rc1.037 SMP PREEMPT Wed Feb 5 15:59:04 MSK 2020
  5835    [    0.000000] Machine model: Amlogic Meson GXL (S905X) P212 Development Board
  5836    [    0.000000] efi: Getting EFI parameters from FDT:
  5837    [    0.000000] efi: UEFI not found.
  5838    [    0.000000] Reserved memory: created CMA memory pool at 0x0000000076000000, size 32 MiB
  5839    [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
  5840    [    0.000000] On node 0 totalpages: 477952
  5841    [    0.000000]   DMA zone: 4032 pages used for memmap
  5842    [    0.000000]   DMA zone: 0 pages reserved
  5843    [    0.000000]   DMA zone: 248576 pages, LIFO batch:63
  5844    [    0.000000]   DMA32 zone: 3584 pages used for memmap
  5845    [    0.000000]   DMA32 zone: 229376 pages, LIFO batch:63
  5846    [    0.000000] psci: probing for conduit method from DT.
  5847    [    0.000000] psci: PSCIv0.2 detected in firmware.
  5848    [    0.000000] psci: Using standard PSCI v0.2 function IDs
  5849    [    0.000000] psci: Trusted OS migration not required
  5850    [    0.000000] percpu: Embedded 22 pages/cpu s50392 r8192 d31528 u90112
  5851    [    0.000000] pcpu-alloc: s50392 r8192 d31528 u90112 alloc=22*4096
  5852    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
  5853    [    0.000000] Detected VIPT I-cache on CPU0
  5854    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 470336
  5855    [    0.000000] Kernel command line: root=LABEL=ROOTFS rootflags=data=writeback rw console=ttyAML0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 mac=00:df:06:00:00:0b
  5856    [    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
  5857    [    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
  5858    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
  5859    [    0.000000] software IO TLB: mapped [mem 0x3bfff000-0x3ffff000] (64MB)
  5860    [    0.000000] Memory: 1738992K/1911808K available (14460K kernel code, 1434K rwdata, 5884K rodata, 960K init, 927K bss, 140048K reserved, 32768K cma-reserved)
  5861    [    0.000000] random: get_random_u64 called from cache_random_seq_create+0x7c/0x150 with crng_init=0
  5862    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
  5863    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
  5864    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
  5865    [    0.000000]     Tasks RCU enabled.
  5866    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
  5867    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
  5868    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
  5869    [    0.000000] GIC: Using split EOI/Deactivate mode
  5870    [    0.000000] irq_meson_gpio: 110 to 8 gpio interrupt mux initialized
  5871    [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
  5872    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
  5873    [    0.000003] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
  5874    [    0.000352] Console: colour dummy device 80x25
  5875    [    0.000655] printk: console [tty0] enabled
  5876    [    0.000697] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
  5877    [    0.000717] pid_max: default: 32768 minimum: 301
  5878    [    0.000848] LSM: Security Framework initializing
  5879    [    0.000901] SELinux:  Initializing.
  5880    [    0.000979] *** VALIDATE SELinux ***
  5881    [    0.001042] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
  5882    [    0.001071] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
  5883    [    0.001134] *** VALIDATE tmpfs ***
  5884    [    0.001545] *** VALIDATE proc ***
  5885    [    0.001768] *** VALIDATE cgroup1 ***
  5886    [    0.001782] *** VALIDATE cgroup2 ***
  5887    [    0.024015] ASID allocator initialised with 32768 entries
  5888    [    0.032000] rcu: Hierarchical SRCU implementation.
  5889    [    0.042102] EFI services will not be available.
  5890    [    0.048055] smp: Bringing up secondary CPUs ...
  5891    [    0.080282] Detected VIPT I-cache on CPU1
  5892    [    0.080336] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
  5893    [    0.112318] Detected VIPT I-cache on CPU2
  5894    [    0.112362] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
  5895    [    0.144366] Detected VIPT I-cache on CPU3
  5896    [    0.144409] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
  5897    [    0.144483] smp: Brought up 1 node, 4 CPUs
  5898    [    0.144549] SMP: Total of 4 processors activated.
  5899    [    0.144560] CPU features: detected: 32-bit EL0 Support
  5900    [    0.144572] CPU features: detected: CRC32 instructions
  5901    [    0.144875] CPU: All CPU(s) started at EL2
  5902    [    0.144896] alternatives: patching kernel code
  5903    [    0.145998] devtmpfs: initialized
  5904    [    0.151116] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
  5905    [    0.151158] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
  5906    [    0.152334] xor: measuring software checksum speed
  5907    [    0.192307]    8regs     :  2375.000 MB/sec
  5908    [    0.232337]    32regs    :  2724.000 MB/sec
  5909    [    0.272379]    arm64_neon:  2406.000 MB/sec
  5910    [    0.272389] xor: using function: 32regs (2724.000 MB/sec)
  5911    [    0.272444] pinctrl core: initialized pinctrl subsystem
  5912    [    0.273090] thermal_sys: Registered thermal governor 'step_wise'
  5913    [    0.273258] DMI not present or invalid.
  5914    [    0.273609] NET: Registered protocol family 16
  5915    [    0.277261] DMA: preallocated 256 KiB pool for atomic allocations
  5916    [    0.277311] audit: initializing netlink subsys (disabled)
  5917    [    0.277535] audit: type=2000 audit(0.276:1): state=initialized audit_enabled=0 res=1
  5918    [    0.278627] cpuidle: using governor ladder
  5919    [    0.278658] cpuidle: using governor menu
  5920    [    0.278978] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
  5921    [    0.279700] Serial: AMBA PL011 UART driver
  5922    [    0.293696] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
  5923    [    0.293723] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
  5924    [    0.293736] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
  5925    [    0.293749] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
  5926    [    0.297432] cryptd: max_cpu_qlen set to 1000
  5927    [    0.372637] raid6: neonx8   gen()  1618 MB/s
  5928    [    0.440672] raid6: neonx8   xor()  1491 MB/s
  5929    [    0.508754] raid6: neonx4   gen()  1564 MB/s
  5930    [    0.576787] raid6: neonx4   xor()  1470 MB/s
  5931    [    0.644850] raid6: neonx2   gen()  1199 MB/s
  5932    [    0.712889] raid6: neonx2   xor()  1217 MB/s
  5933    [    0.780955] raid6: neonx1   gen()   787 MB/s
  5934    [    0.849025] raid6: neonx1   xor()   915 MB/s
  5935    [    0.917073] raid6: int64x8  gen()  1195 MB/s
  5936    [    0.985091] raid6: int64x8  xor()   769 MB/s
  5937    [    1.053162] raid6: int64x4  gen()  1029 MB/s
  5938    [    1.121218] raid6: int64x4  xor()   752 MB/s
  5939    [    1.189248] raid6: int64x2  gen()   728 MB/s
  5940    [    1.257297] raid6: int64x2  xor()   615 MB/s
  5941    [    1.325388] raid6: int64x1  gen()   486 MB/s
  5942    [    1.393412] raid6: int64x1  xor()   468 MB/s
  5943    [    1.393423] raid6: using algorithm neonx8 gen() 1618 MB/s
  5944    [    1.393433] raid6: .... xor() 1491 MB/s, rmw enabled
  5945    [    1.393443] raid6: using neon recovery algorithm
  5946    [    1.393684] ACPI: Interpreter disabled.
  5947    [    1.394859] iommu: Default domain type: Translated
  5948    [    1.395136] vgaarb: loaded
  5949    [    1.395734] SCSI subsystem initialized
  5950    [    1.395911] libata version 3.00 loaded.
  5951    [    1.396138] usbcore: registered new interface driver usbfs
  5952    [    1.396183] usbcore: registered new interface driver hub
  5953    [    1.396250] usbcore: registered new device driver usb
  5954    [    1.396646] pps_core: LinuxPPS API ver. 1 registered
  5955    [    1.396659] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
  5956    [    1.396683] PTP clock support registered
  5957    [    1.396709] EDAC MC: Ver: 3.0.0
  5958    [    1.397305] FPGA manager framework
  5959    [    1.397419] Advanced Linux Sound Architecture Driver Initialized.
  5960    [    1.397887] NetLabel: Initializing
  5961    [    1.397899] NetLabel:  domain hash size = 128
  5962    [    1.397908] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
  5963    [    1.397963] NetLabel:  unlabeled traffic allowed by default
  5964    [    1.398442] clocksource: Switched to clocksource arch_sys_counter
  5965    [    1.398463] *** VALIDATE bpf ***
  5966    [    1.398712] VFS: Disk quotas dquot_6.6.0
  5967    [    1.398773] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
  5968    [    1.398890] FS-Cache: Loaded
  5969    [    1.398901] *** VALIDATE ramfs ***
  5970    [    1.398922] *** VALIDATE hugetlbfs ***
  5971    [    1.399296] pnp: PnP ACPI: disabled
  5972    [    1.404352] NET: Registered protocol family 2
  5973    [    1.404856] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
  5974    [    1.404903] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
  5975    [    1.405021] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
  5976    [    1.405248] TCP: Hash tables configured (established 16384 bind 16384)
  5977    [    1.405404] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
  5978    [    1.405459] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
  5979    [    1.405680] NET: Registered protocol family 1
  5980    [    1.406138] RPC: Registered named UNIX socket transport module.
  5981    [    1.406158] RPC: Registered udp transport module.
  5982    [    1.406168] RPC: Registered tcp transport module.
  5983    [    1.406177] RPC: Registered tcp NFSv4.1 backchannel transport module.
  5984    [    1.406193] NET: Registered protocol family 44
  5985    [    1.406213] PCI: CLS 0 bytes, default 64
  5986    [    1.406408] Trying to unpack rootfs image as initramfs...
  5987    [    1.867520] Freeing initrd memory: 10248K
  5988    [    1.868310] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
  5989    [    2.082027] Initialise system trusted keyrings
  5990    [    2.082236] workingset: timestamp_bits=46 max_order=19 bucket_order=0
  5991    [    2.087454] zbud: loaded
  5992    [    2.088703] squashfs: version 4.0 (2009/01/31) Phillip Lougher
  5993    [    2.088980] FS-Cache: Netfs 'nfs' registered for caching
  5994    [    2.089500] NFS: Registering the id_resolver key type
  5995    [    2.089538] Key type id_resolver registered
  5996    [    2.089548] Key type id_legacy registered
  5997    [    2.089564] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
  5998    [    2.089576] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
  5999    [    2.090787] FS-Cache: Netfs 'cifs' registered for caching
  6000    [    2.091122] Key type cifs.spnego registered
  6001    [    2.091148] Key type cifs.idmap registered
  6002    [    2.091172] ntfs: driver 2.1.32 [Flags: R/W].
  6003    [    2.091759] JFS: nTxBlock = 8192, nTxLock = 65536
  6004    [    2.097605] SGI XFS with ACLs, security attributes, realtime, quota, no debug enabled
  6005    [    2.099130] *** VALIDATE xfs ***
  6006    [    2.099414] ocfs2: Registered cluster interface o2cb
  6007    [    2.099629] OCFS2 User DLM kernel interface loaded
  6008    [    2.101029] *** VALIDATE gfs2 ***
  6009    [    2.101296] gfs2: GFS2 installed
  6010    [    2.102215] aufs 5.5-20200203
  6011    [    2.123307] Key type asymmetric registered
  6012    [    2.123332] Asymmetric key parser 'x509' registered
  6013    [    2.123343] Asymmetric key parser 'pkcs8' registered
  6014    [    2.123412] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
  6015    [    2.123614] io scheduler mq-deadline registered
  6016    [    2.123631] io scheduler kyber registered
  6017    [    2.123831] io scheduler bfq registered
  6018    [    2.136345] soc soc0: Amlogic Meson GXL (S905X) Revision 21:b (82:2) Detected
  6019    [    2.139865] Serial: 8250/16550 driver, 5 ports, IRQ sharing enabled
  6020    [    2.141536] Serial: AMBA driver
  6021    [    2.141901] c11084c0.serial: ttyAML6 at MMIO 0xc11084c0 (irq = 10, base_baud = 1500000) is a meson_uart
  6022    [    2.142061] serial serial0: tty port ttyAML6 registered
  6023    [    2.142282] c81004c0.serial: ttyAML0 at MMIO 0xc81004c0 (irq = 13, base_baud = 1500000) is a meson_uart
  6024    [    3.117578] printk: console [ttyAML0] enabled
  6025    [    3.133628] brd: module loaded
  6026    [    3.142133] loop: module loaded
  6027    [    3.144581] libphy: Fixed MDIO Bus: probed
  6028    [    3.145219] meson8b-dwmac c9410000.ethernet: IRQ eth_wake_irq not found
  6029    [    3.150349] meson8b-dwmac c9410000.ethernet: IRQ eth_lpi not found
  6030    [    3.156501] meson8b-dwmac c9410000.ethernet: PTP uses main clock
  6031    [    3.162358] meson8b-dwmac c9410000.ethernet: no reset control found
  6032    [    3.169051] meson8b-dwmac c9410000.ethernet: User ID: 0x11, Synopsys ID: 0x37
  6033    [    3.175645] meson8b-dwmac c9410000.ethernet:     DWMAC1000
  6034    [    3.180813] meson8b-dwmac c9410000.ethernet: DMA HW capability register supported
  6035    [    3.188228] meson8b-dwmac c9410000.ethernet: RX Checksum Offload Engine supported
  6036    [    3.195645] meson8b-dwmac c9410000.ethernet: COE Type 2
  6037    [    3.200819] meson8b-dwmac c9410000.ethernet: TX Checksum insertion supported
  6038    [    3.207806] meson8b-dwmac c9410000.ethernet: Wake-Up On Lan supported
  6039    [    3.214227] meson8b-dwmac c9410000.ethernet: Normal descriptors
  6040    [    3.220054] meson8b-dwmac c9410000.ethernet: Ring mode enabled
  6041    [    3.225833] meson8b-dwmac c9410000.ethernet: Enable RX Mitigation via HW Watchdog Timer
  6042    [    3.233945] libphy: stmmac: probed
  6043    [    3.238467] VFIO - User Level meta-driver version: 0.3
  6044    [    3.243760] dwc3 c9000000.dwc3: Failed to get clk 'ref': -2
  6045    [    3.248672] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
  6046    [    3.254237] ehci-pci: EHCI PCI platform driver
  6047    [    3.258676] ehci-platform: EHCI generic platform driver
  6048    [    3.263963] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
  6049    [    3.269919] ohci-pci: OHCI PCI platform driver
  6050    [    3.274360] ohci-platform: OHCI generic platform driver
  6051    [    3.280095] usbcore: registered new interface driver usb-storage
  6052    [    3.285674] mousedev: PS/2 mouse device common for all mice
  6053    [    3.291609] i2c /dev entries driver
  6054    [    3.297219] sdhci: Secure Digital Host Controller Interface driver
  6055    [    3.300548] sdhci: Copyright(c) Pierre Ossman
  6056    [    3.304855] Synopsys Designware Multimedia Card Interface Driver
  6057    [    3.312130] meson-gx-mmc d0072000.mmc: Got CD GPIO
  6058    [    3.342836] meson-gx-mmc d0074000.mmc: allocated mmc-pwrseq
  6059    [    3.370402] sdhci-pltfm: SDHCI platform and OF driver helper
  6060    [    3.371600] ledtrig-cpu: registered to indicate activity on CPUs
  6061    [    3.376973] meson-sm: secure-monitor enabled
  6062    [    3.381258] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
  6063    [    3.382552] mmc0: new high speed SDHC card at address 59b4
  6064    [    3.388583] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
  6065    [    3.394757] mmcblk0: mmc0:59b4 SDU1  29.5 GiB
  6066    [    3.412936]  mmcblk0: p1 p2
  6067    [    3.420132] hid: raw HID events driver (C) Jiri Kosina
  6068    [    3.420364] usbcore: registered new interface driver usbhid
  6069    [    3.425276] usbhid: USB HID core driver
  6070    [    3.429342] platform-mhu c883c404.mailbox: Platform MHU Mailbox registered
  6071    [    3.446314] NET: Registered protocol family 17
  6072    [    3.446636] Key type dns_resolver registered
  6073    [    3.449890] registered taskstats version 1
  6074    [    3.453429] Loading compiled-in X.509 certificates
  6075    [    3.458307] zswap: loaded using pool lzo/zbud
  6076    [    3.462728] Key type ._fscrypt registered
  6077    [    3.466528] Key type .fscrypt registered
  6078    [    3.471849] Btrfs loaded, crc32c=crc32c-generic
  6079    [    3.488149] mmc1: new HS200 MMC card at address 0001
  6080    [    3.489105] mmcblk1: mmc1:0001 016G92 14.7 GiB
  6081    [    3.492477] mmcblk1boot0: mmc1:0001 016G92 partition 1 4.00 MiB
  6082    [    3.498334] mmcblk1boot1: mmc1:0001 016G92 partition 2 4.00 MiB
  6083    [    3.499451] Key type encrypted registered
  6084    [    3.504171] mmcblk1gp0: mmc1:0001 016G92 partition 4 8.00 MiB
  6085    [    3.513679] mmcblk1rpmb: mmc1:0001 016G92 partition 3 512 KiB, chardev (243:0)
  6086    [    3.527893] meson-drm d0100000.vpu: Queued 3 outputs on vpu
  6087    [    3.528240] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
  6088    [    3.534444] [drm] No driver support for vblank timestamp query.
  6089    [    3.566492] meson-dw-hdmi c883a000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
  6090    [    3.571154] meson-dw-hdmi c883a000.hdmi-tx: registered DesignWare HDMI I2C bus driver
  6091    [    3.579171] meson-drm d0100000.vpu: bound c883a000.hdmi-tx (ops meson_dw_hdmi_ops)
  6092    [    3.586513] [drm] Initialized meson 1.0.0 20161109 for d0100000.vpu on minor 0
  6093    [    3.632468] Console: switching to colour frame buffer device 90x36
  6094    [    3.652693] meson-drm d0100000.vpu: fb0: mesondrmfb frame buffer device
  6095    [    3.659955] libphy: mdio_mux: probed
  6096    [    3.670574] libphy: mdio_mux: probed
  6097    [    3.671064] phy phy-d0078080.phy.2: unsupported PHY mode 5
  6098    [    3.676066] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  6099    [    3.679504] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
  6100    [    3.687211] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228f664 hci version 0x100 quirks 0x0000000002010010
  6101    [    3.696451] xhci-hcd xhci-hcd.0.auto: irq 39, io mem 0xc9000000
  6102    [    3.702565] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.05
  6103    [    3.710798] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  6104    [    3.717942] usb usb1: Product: xHCI Host Controller
  6105    [    3.722772] usb usb1: Manufacturer: Linux 5.5.0-rc6-aml-s9xxx xhci-hcd
  6106    [    3.729243] usb usb1: SerialNumber: xhci-hcd.0.auto
  6107    [    3.734591] hub 1-0:1.0: USB hub found
  6108    [    3.737795] hub 1-0:1.0: 2 ports detected
  6109    [    3.742048] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  6110    [    3.747198] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
  6111    [    3.754801] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
  6112    [    3.761307] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
  6113    [    3.769571] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.05
  6114    [    3.777950] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  6115    [    3.785107] usb usb2: Product: xHCI Host Controller
  6116    [    3.789939] usb usb2: Manufacturer: Linux 5.5.0-rc6-aml-s9xxx xhci-hcd
  6117    [    3.796403] usb usb2: SerialNumber: xhci-hcd.0.auto
  6118    [    3.801715] hub 2-0:1.0: USB hub found
  6119    [    3.804973] hub 2-0:1.0: config failed, hub doesn't have any ports! (err -19)
  6120    [    3.813812] meson-gx-mmc d0070000.mmc: allocated mmc-pwrseq
  6121    [    3.843449] scpi_protocol scpi: SCP Protocol legacy pre-1.0 firmware
  6122    [    3.860286] gx-sound-card sound: snd-soc-dummy-dai <-> c1105400.bus:audio-controller-0 mapping ok
  6123    [    3.872030] gx-sound-card sound: i2s-hifi <-> c1105400.bus:audio-controller-2 mapping ok
  6124    [    3.879777] gx-sound-card sound: ASoC: no DMI vendor name!
  6125    [    3.886040] printk: console [netcon0] enabled
  6126    [    3.889357] netconsole: network logging started
  6127    [    3.894115] hctosys: unable to open rtc device (rtc0)
  6128    [    3.897446] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
  6129    [    3.899084] ALSA device list:
  6130    [    3.907937] mmc2: queuing unknown CIS tuple 0x80 (6 bytes)
  6131    [    3.908288]   #0: AMLGX
  6132    [    3.916184] Freeing unused kernel memory: 960K
  6133    [    3.916325] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
  6134    [    3.919464] Run /init as init process
  6135    [    3.933672] mmc2: queuing unknown CIS tuple 0x80 (19 bytes)
  6136    [    3.960099] random: fast init done
  6137    [    4.016631] mmc2: new high speed SDIO card at address 0001
  6138    [    4.074525] usb 1-1: new high-speed USB device number 2 using xhci-hcd
  6139    [    4.095874] usb 1-1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.36
  6140    [    4.103676] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
  6141    [    4.110128] usb 1-1: Product: USB2.0 Hub
  6142    [    4.177756] hub 1-1:1.0: USB hub found
  6143    [    4.180482] hub 1-1:1.0: 4 ports detected
  6144    [    4.314522] usb 1-2: new high-speed USB device number 3 using xhci-hcd
  6145    [    4.345012] usb 1-2: New USB device found, idVendor=148f, idProduct=7601, bcdDevice= 0.00
  6146    [    4.352328] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
  6147    [    4.360279] usb 1-2: Product: 802.11 n WLAN
  6148    [    4.364255] usb 1-2: Manufacturer: MediaTek
  6149    [    4.371586] usb 1-2: SerialNumber: 1.0
  6150    [    6.227816] EXT4-fs (mmcblk0p2): mounted filesystem with writeback data mode. Opts: data=writeback
  6151    [    7.143959] systemd[1]: System time before build time, advancing clock.
  6152    [    7.301786] NET: Registered protocol family 10
  6153    [    7.375737] Segment Routing with IPv6
  6154    [    7.426043] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
  6155    [    7.456625] systemd[1]: Detected architecture arm64.
  6156    [    7.498817] systemd[1]: Set hostname to <mxqpro>.
  6157    [    7.531722] systemd[1]: Couldn't move remaining userspace processes, ignoring: Input/output error
  6158    [    8.214312] random: systemd: uninitialized urandom read (16 bytes read)
  6159    [    8.226409] random: systemd: uninitialized urandom read (16 bytes read)
  6160    [    8.233329] systemd[1]: Created slice system-getty.slice.
  6161    [    8.238678] random: systemd: uninitialized urandom read (16 bytes read)
  6162    [    8.243613] systemd[1]: Created slice User and Session Slice.
  6163    [    8.251141] systemd[1]: Listening on fsck to fsckd communication Socket.
  6164    [    8.258257] systemd[1]: Listening on Journal Audit Socket.
  6165    [    8.264100] systemd[1]: Listening on udev Kernel Socket.
  6166    [    8.269509] systemd[1]: Reached target System Time Synchronized.
  6167    [    8.444413] EXT4-fs (mmcblk0p2): re-mounted. Opts: commit=600,errors=remount-ro
  6168    [    8.628485] systemd-journald[395]: Received request to flush runtime journal from PID 1
  6169    [    9.199568] mc: Linux media interface: v0.10
  6170    [    9.243329] Registered IR keymap rc-empty
  6171    [    9.245463] rc rc0: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0
  6172    [    9.254567] input: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0/input0
  6173    [    9.254851] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
  6174    [    9.263721] meson-ir c8100580.ir: receiver initialized
  6175    [    9.273839] videodev: Linux video capture interface: v2.00
  6176    [    9.378320] Bluetooth: Core ver 2.22
  6177    [    9.380745] NET: Registered protocol family 31
  6178    [    9.384040] Bluetooth: HCI device and connection manager initialized
  6179    [    9.389680] Bluetooth: HCI socket layer initialized
  6180    [    9.394774] Bluetooth: L2CAP socket layer initialized
  6181    [    9.399160] Bluetooth: SCO socket layer initialized
  6182    [    9.456514] lima d00c0000.gpu: IRQ ppmmu3 not found
  6183    [    9.458951] lima d00c0000.gpu: IRQ ppmmu4 not found
  6184    [    9.463107] lima d00c0000.gpu: IRQ ppmmu5 not found
  6185    [    9.467810] lima d00c0000.gpu: IRQ ppmmu6 not found
  6186    [    9.473231] lima d00c0000.gpu: IRQ ppmmu7 not found
  6187    [    9.477603] lima d00c0000.gpu: gp - mali450 version major 0 minor 0
  6188    [    9.486823] lima d00c0000.gpu: pp0 - mali450 version major 0 minor 0
  6189    [    9.494837] lima d00c0000.gpu: pp1 - mali450 version major 0 minor 0
  6190    [    9.497574] lima d00c0000.gpu: pp2 - mali450 version major 0 minor 0
  6191    [    9.509050] lima d00c0000.gpu: IRQ pp3 not found
  6192    [    9.512719] lima d00c0000.gpu: IRQ pp4 not found
  6193    [    9.515714] lima d00c0000.gpu: IRQ pp5 not found
  6194    [    9.519964] lima d00c0000.gpu: IRQ pp6 not found
  6195    [    9.524079] lima d00c0000.gpu: IRQ pp7 not found
  6196    [    9.528824] lima d00c0000.gpu: l2 cache 8K, 4-way, 64byte cache line, 128bit external bus
  6197    [    9.536730] lima d00c0000.gpu: l2 cache 64K, 4-way, 64byte cache line, 128bit external bus
  6198    [    9.546255] lima d00c0000.gpu: bus rate = 166666667
  6199    [    9.549472] lima d00c0000.gpu: mod rate = 744000000
  6200    [    9.554837] [drm] Initialized lima 1.0.0 20190217 for d00c0000.gpu on minor 1
  6201    [    9.569274] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
  6202    [    9.604955] Bluetooth: HCI UART driver ver 2.3
  6203    [    9.607208] Bluetooth: HCI UART protocol H4 registered
  6204    [    9.610519] Bluetooth: HCI UART protocol BCSP registered
  6205    [    9.616030] Bluetooth: HCI UART protocol LL registered
  6206    [    9.620899] Bluetooth: HCI UART protocol ATH3K registered
  6207    [    9.626329] Bluetooth: HCI UART protocol Three-wire (H5) registered
  6208    [    9.632744] Bluetooth: HCI UART protocol Intel registered
  6209    [    9.638140] Bluetooth: HCI UART protocol Broadcom registered
  6210    [    9.638272] hci_uart_bcm serial0-0: serial0-0 supply vbat not found, using dummy regulator
  6211    [    9.643474] Bluetooth: HCI UART protocol QCA registered
  6212    [    9.655770] hci_uart_bcm serial0-0: serial0-0 supply vddio not found, using dummy regulator
  6213    [    9.656755] Bluetooth: HCI UART protocol AG6XX registered
  6214    [    9.670497] Bluetooth: HCI UART protocol Marvell registered
  6215    [    9.703383] cfg80211: Loading compiled-in X.509 certificates for regulatory database
  6216    [    9.766577] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
  6217    [    9.794320] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
  6218    [    9.801591] cfg80211: failed to load regulatory.db
  6219    [    9.926533] brcmfmac: F1 signature read @0x18000000=0x16034334
  6220    [    9.929593] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4334-sdio for chip BCM4334/3
  6221    [    9.937726] usbcore: registered new interface driver brcmfmac
  6222    [    9.982511] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.amlogic,p212.txt failed with error -2
  6223    [    9.982592] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.txt failed with error -2
  6224    [   10.042901] usb 1-2: reset high-speed USB device number 3 using xhci-hcd
  6225    [   10.059655] Bluetooth: hci0: BCM: chip id 68
  6226    [   10.063186] Bluetooth: hci0: BCM: features 0x0f
  6227    [   10.065540] mt7601u 1-2:1.0: ASIC revision: 76010001 MAC revision: 76010500
  6228    [   10.073290] Bluetooth: hci0: BCM4334B0
  6229    [   10.073305] Bluetooth: hci0: BCM4334B0 (002.001.013) build 0000
  6230    [   10.073404] bluetooth hci0: Direct firmware load for brcm/BCM4334B0.hcd failed with error -2
  6231    [   10.073411] Bluetooth: hci0: BCM: Patch brcm/BCM4334B0.hcd not found
  6232    [   10.108663] mt7601u 1-2:1.0: EEPROM ver:0d fae:00
  6233    [   10.321833] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
  6234    [   10.322825] usbcore: registered new interface driver mt7601u
  6235    [   10.986557] brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x50
  6236    [   11.099756] zram: Added device: zram0
  6237    [   11.104869] zram: Added device: zram1
  6238    [   11.108318] zram: Added device: zram2
  6239    [   11.137630] meson8b-dwmac c9410000.ethernet eth0: PHY [0.e40908ff:08] driver [Meson GXL Internal PHY]
  6240    [   11.158721] meson8b-dwmac c9410000.ethernet eth0: No Safety Features support found
  6241    [   11.158744] meson8b-dwmac c9410000.ethernet eth0: PTP not supported by HW
  6242    [   11.158757] meson8b-dwmac c9410000.ethernet eth0: configuring for phy/rmii link mode
  6243    [   11.160791] zram1: detected capacity change from 0 to 912879616
  6244    [   11.841787] random: crng init done
  6245    [   11.844215] random: 7 urandom warning(s) missed due to ratelimiting
  6246    [   12.006941] Adding 891480k swap on /dev/zram1.  Priority:5 extents:1 across:891480k SSFS
  6247
  6248    ### armbian-release:
  6249
  6250    # PLEASE DO NOT EDIT THIS FILE
  6251    BOARD=aml-s9xxx
  6252    BOARD_NAME="AML-S9xxx"
  6253    BOARDFAMILY=aml-s9xxx
  6254    BUILD_REPOSITORY_URL=https://github.com/150balbes/Build-Armbian.git
  6255    BUILD_REPOSITORY_COMMIT=62b8c07-dirty
  6256    DISTRIBUTION_CODENAME=buster
  6257    DISTRIBUTION_STATUS=supported
  6258    VERSION=20.02.0-rc1.037
  6259    LINUXFAMILY=aml-s9xxx
  6260    BRANCH=current
  6261    ARCH=arm64
  6262    IMAGE_TYPE=nightly
  6263    BOARD_TYPE=conf
  6264    INITRD_ARCH=arm64
  6265    KERNEL_IMAGE_TYPE=Image
  6266
  6267    ### boot environment:
  6268
  6269    ODROIDN2-UBOOT-CONFIG
  6270    setenv env_addr 0x10400000
  6271    setenv kernel_addr 0x11000000
  6272    setenv initrd_addr 0x13000000
  6273    setenv dtb_addr 0x1000000
  6274    if test "${devtype}" = ""; then setenv devtype "mmc"; fi
  6275    load ${devtype} ${devnum} ${env_addr} uEnv.txt && env import -t ${env_addr} ${filesize}
  6276    setenv bootargs ${APPEND}
  6277    load ${devtype} ${devnum} ${kernel_addr} ${LINUX}
  6278    load ${devtype} ${devnum} ${initrd_addr} ${INITRD}
  6279    load ${devtype} ${devnum} ${dtb_addr} ${FDT}
  6280    fdt addr ${dtb_addr}
  6281    booti ${kernel_addr} ${initrd_addr} ${dtb_addr}
  6282
  6283    ### lsusb:
  6284
  6285    Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
  6286    Bus 001 Device 003: ID 148f:7601 Ralink Technology, Corp. MT7601U Wireless Adapter
  6287    Bus 001 Device 002: ID 05e3:0608 Genesys Logic, Inc. Hub
  6288    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  6289
  6290    ### lscpu:
  6291
  6292    Architecture:        aarch64
  6293    Byte Order:          Little Endian
  6294    CPU(s):              4
  6295    On-line CPU(s) list: 0-3
  6296    Thread(s) per core:  1
  6297    Core(s) per socket:  4
  6298    Socket(s):           1
  6299    Vendor ID:           ARM
  6300    Model:               4
  6301    Model name:          Cortex-A53
  6302    Stepping:            r0p4
  6303    CPU max MHz:         1512,0000
  6304    CPU min MHz:         100,0000
  6305    BogoMIPS:            48.00
  6306    L1d cache:           unknown size
  6307    L1i cache:           unknown size
  6308    L2 cache:            unknown size
  6309    Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  6310
  6311    ### cpuinfo:
  6312
  6313    processor    : 0
  6314    model name    : ARMv8 Processor rev 4 (v8l)
  6315    BogoMIPS    : 48.00
  6316    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  6317    CPU implementer    : 0x41
  6318    CPU architecture: 8
  6319    CPU variant    : 0x0
  6320    CPU part    : 0xd03
  6321    CPU revision    : 4
  6322
  6323    processor    : 1
  6324    model name    : ARMv8 Processor rev 4 (v8l)
  6325    BogoMIPS    : 48.00
  6326    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  6327    CPU implementer    : 0x41
  6328    CPU architecture: 8
  6329    CPU variant    : 0x0
  6330    CPU part    : 0xd03
  6331    CPU revision    : 4
  6332
  6333    processor    : 2
  6334    model name    : ARMv8 Processor rev 4 (v8l)
  6335    BogoMIPS    : 48.00
  6336    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  6337    CPU implementer    : 0x41
  6338    CPU architecture: 8
  6339    CPU variant    : 0x0
  6340    CPU part    : 0xd03
  6341    CPU revision    : 4
  6342
  6343    processor    : 3
  6344    model name    : ARMv8 Processor rev 4 (v8l)
  6345    BogoMIPS    : 48.00
  6346    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  6347    CPU implementer    : 0x41
  6348    CPU architecture: 8
  6349    CPU variant    : 0x0
  6350    CPU part    : 0xd03
  6351    CPU revision    : 4
  6352
  6353
  6354    ### meminfo:
  6355
  6356    MemTotal:        1782968 kB
  6357    MemFree:         1602932 kB
  6358    MemAvailable:    1659324 kB
  6359    Buffers:           11632 kB
  6360    Cached:            57836 kB
  6361    SwapCached:            0 kB
  6362    Active:            51472 kB
  6363    Inactive:          40244 kB
  6364    Active(anon):      22560 kB
  6365    Inactive(anon):     4804 kB
  6366    Active(file):      28912 kB
  6367    Inactive(file):    35440 kB
  6368    Unevictable:           0 kB
  6369    Mlocked:               0 kB
  6370    SwapTotal:        891480 kB
  6371    SwapFree:         891480 kB
  6372    Dirty:               520 kB
  6373    Writeback:            24 kB
  6374    AnonPages:         22456 kB
  6375    Mapped:            24436 kB
  6376    Shmem:              4928 kB
  6377    KReclaimable:      18044 kB
  6378    Slab:              53148 kB
  6379    SReclaimable:      18044 kB
  6380    SUnreclaim:        35104 kB
  6381    KernelStack:        2732 kB
  6382    PageTables:         1752 kB
  6383    NFS_Unstable:          0 kB
  6384    Bounce:                0 kB
  6385    WritebackTmp:          0 kB
  6386    CommitLimit:     1782964 kB
  6387    Committed_AS:      91376 kB
  6388    VmallocTotal:   135290159040 kB
  6389    VmallocUsed:       16708 kB
  6390    VmallocChunk:          0 kB
  6391    Percpu:             1264 kB
  6392    CmaTotal:          32768 kB
  6393    CmaFree:           29084 kB
  6394    HugePages_Total:       0
  6395    HugePages_Free:        0
  6396    HugePages_Rsvd:        0
  6397    HugePages_Surp:        0
  6398    Hugepagesize:       2048 kB
  6399    Hugetlb:               0 kB
  6400
  6401    ### virtual memory:
  6402
  6403    vm.admin_reserve_kbytes = 8192
  6404    vm.block_dump = 0
  6405    vm.compact_unevictable_allowed = 1
  6406    vm.dirty_background_bytes = 0
  6407    vm.dirty_background_ratio = 10
  6408    vm.dirty_bytes = 0
  6409    vm.dirty_expire_centisecs = 3000
  6410    vm.dirty_ratio = 20
  6411    vm.dirtytime_expire_seconds = 43200
  6412    vm.dirty_writeback_centisecs = 500
  6413    vm.extfrag_threshold = 500
  6414    vm.hugetlb_shm_group = 0
  6415    vm.laptop_mode = 0
  6416    vm.legacy_va_layout = 0
  6417    vm.lowmem_reserve_ratio = 256    256    32    0
  6418    vm.max_map_count = 65530
  6419    vm.min_free_kbytes = 5274
  6420    vm.mmap_min_addr = 4096
  6421    vm.mmap_rnd_bits = 18
  6422    vm.nr_hugepages = 0
  6423    vm.nr_overcommit_hugepages = 0
  6424    vm.oom_dump_tasks = 1
  6425    vm.oom_kill_allocating_task = 0
  6426    vm.overcommit_kbytes = 0
  6427    vm.overcommit_memory = 0
  6428    vm.overcommit_ratio = 50
  6429    vm.page-cluster = 0
  6430    vm.panic_on_oom = 0
  6431    vm.percpu_pagelist_fraction = 0
  6432    vm.stat_interval = 1
  6433    vm.swappiness = 100
  6434    vm.user_reserve_kbytes = 55232
  6435    vm.vfs_cache_pressure = 100
  6436    vm.watermark_boost_factor = 15000
  6437    vm.watermark_scale_factor = 10
  6438
  6439    ### ip addr:
  6440
  6441    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
  6442        link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  6443        inet XXX.XXX.0.1/8 scope host lo
  6444           valid_lft forever preferred_lft forever
  6445        inet6 ::1/128 scope host
  6446           valid_lft forever preferred_lft forever
  6447    2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
  6448        link/ether 00:df:06:00:00:0b brd ff:ff:ff:ff:ff:ff
  6449    3: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  6450        link/ether 00:36:76:61:0b:24 brd ff:ff:ff:ff:ff:ff
  6451
  6452    ### partitions:
  6453
  6454    major minor  #blocks  name
  6455
  6456     179        0   30924800 mmcblk0
  6457     179        1     262144 mmcblk0p1
  6458     179        2   30337024 mmcblk0p2
  6459     179       32   15384576 mmcblk1
  6460     179      128       8192 mmcblk1gp0
  6461     254        1     891484 zram1
  6462
  6463    ### df:
  6464
  6465    udev             850M      0  850M   0% /dev
  6466    tmpfs            175M   4,9M  170M   3% /run
  6467    /dev/mmcblk0p2    29G    10G   19G  36% /
  6468    tmpfs            871M      0  871M   0% /dev/shm
  6469    tmpfs            5,0M   4,0K  5,0M   1% /run/lock
  6470    tmpfs            871M      0  871M   0% /sys/fs/cgroup
  6471    tmpfs            871M      0  871M   0% /tmp
  6472    /dev/mmcblk0p1   256M    76M  180M  30% /boot
  6473
  6474    ### lsblk:
  6475
  6476    NAME         FSTYPE   SIZE MOUNTPOINT UUID
  6477    mmcblk0              29,5G
  6478    ├─mmcblk0p1  vfat     256M /boot      50FC-6AC8
  6479    └─mmcblk0p2  ext4      29G /          3e297ac1-e4e4-4ab1-bc57-47c07d0422ba
  6480    mmcblk1              14,7G
  6481    mmcblk1boot0            4M
  6482    mmcblk1boot1            4M
  6483    mmcblk1gp0              8M
  6484
  6485    ### zramctl:
  6486
  6487    NAME       ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT
  6488    /dev/zram1 lzo         870,6M   4K   81B   12K       4 [SWAP]
  6489
  6490    ### mtab:
  6491
  6492    /dev/mmcblk0p1 /boot vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro 0 0
  6493    /dev/mmcblk0p2 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  6494
  6495    ### mmc0:59b4 info:
  6496
  6497                   fwrev: 0x0
  6498                  uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SDU1  MODALIAS=mmc:block
  6499                     cid: 1b534d53445531201014a136d4013800
  6500                     rca: 0x59b4
  6501                     csd: 400e00325b590000ebef7f800a400000
  6502                  manfid: 0x00001b
  6503                     ocr: 0x00200000
  6504    preferred_erase_size: 4194304
  6505                    type: SD
  6506                   hwrev: 0x1
  6507                    date: 08/2019
  6508                     dsr: 0x404
  6509              erase_size: 512
  6510                   oemid: 0x534d
  6511                  serial: 0x14a136d4
  6512                     ssr: 0000000005000000040090000811391e00089a342f01000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  6513                     scr: 0235844300000000
  6514                    name: SDU1
  6515
  6516    ### mmc1:0001 info:
  6517
  6518                   fwrev: 0x0
  6519                  uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=016G92 MODALIAS=mmc:block
  6520                     cid: 11010030313647393201d3d1a4db1100
  6521             rel_sectors: 0x10
  6522                     rca: 0x0001
  6523            pre_eol_info: 0x00
  6524                     csd: d00e00320f5903ffffffffef92400000
  6525                  manfid: 0x000011
  6526                     ocr: 0x00200000
  6527    preferred_erase_size: 4194304
  6528    enhanced_area_offset: 18446744073709551594
  6529      raw_rpmb_size_mult: 0x4
  6530                    type: MMC
  6531                   hwrev: 0x0
  6532                    date: 01/2014
  6533                     prv: 0x1
  6534             ffu_capable: 0
  6535                     dsr: 0x404
  6536              erase_size: 4194304
  6537               life_time: 0x00 0x00
  6538      enhanced_area_size: 4294967274
  6539                   oemid: 0x0100
  6540                  serial: 0xd3d1a4db
  6541                 cmdq_en: 0
  6542                     rev: 0x6
  6543                    name: 016G92
  6544
  6545    ### Boot system health:
  6546
  6547    Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU
  6548    13:17:07: 1512MHz  0.95  49%  22%  14%   0%  10%   1% 49.0°C
  6549    13:17:07: 1512MHz  1.36  69%  11%  22%   1%  32%   2% 49.0°C
  6550    13:17:08: 1512MHz  1.36  59%   9%   9%   1%  37%   2% 50.0°C
  6551    13:17:08: 1512MHz  1.36  43%   7%  10%   2%  22%   1% 49.0°C
  6552    13:17:08: 1512MHz  1.36  16%   4%   2%   1%   6%   0% 48.0°C
  6553
  6554    ### Activated 1 lzo zram swap devices with 870 MB each
  6555
  6556
  6557    jue mar 25 14:12:45 CET 2021 | AML-S9xxx | 20.02.0-rc1.037 | arm64 | aarch64 | 5.5.0-rc6-aml-s9xxx
  6558
  6559    ### dmesg:
  6560
  6561    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
  6562    [    0.000000] Linux version 5.5.0-rc6-aml-s9xxx (root@vbox) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #rc1.037 SMP PREEMPT Wed Feb 5 15:59:04 MSK 2020
  6563    [    0.000000] Machine model: Amlogic Meson GXL (S905X) P212 Development Board
  6564    [    0.000000] efi: Getting EFI parameters from FDT:
  6565    [    0.000000] efi: UEFI not found.
  6566    [    0.000000] Reserved memory: created CMA memory pool at 0x0000000076000000, size 32 MiB
  6567    [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
  6568    [    0.000000] On node 0 totalpages: 477952
  6569    [    0.000000]   DMA zone: 4032 pages used for memmap
  6570    [    0.000000]   DMA zone: 0 pages reserved
  6571    [    0.000000]   DMA zone: 248576 pages, LIFO batch:63
  6572    [    0.000000]   DMA32 zone: 3584 pages used for memmap
  6573    [    0.000000]   DMA32 zone: 229376 pages, LIFO batch:63
  6574    [    0.000000] psci: probing for conduit method from DT.
  6575    [    0.000000] psci: PSCIv0.2 detected in firmware.
  6576    [    0.000000] psci: Using standard PSCI v0.2 function IDs
  6577    [    0.000000] psci: Trusted OS migration not required
  6578    [    0.000000] percpu: Embedded 22 pages/cpu s50392 r8192 d31528 u90112
  6579    [    0.000000] pcpu-alloc: s50392 r8192 d31528 u90112 alloc=22*4096
  6580    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
  6581    [    0.000000] Detected VIPT I-cache on CPU0
  6582    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 470336
  6583    [    0.000000] Kernel command line: root=LABEL=ROOTFS rootflags=data=writeback rw console=ttyAML0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 mac=00:df:06:00:00:0b
  6584    [    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
  6585    [    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
  6586    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
  6587    [    0.000000] software IO TLB: mapped [mem 0x3bfff000-0x3ffff000] (64MB)
  6588    [    0.000000] Memory: 1738992K/1911808K available (14460K kernel code, 1434K rwdata, 5884K rodata, 960K init, 927K bss, 140048K reserved, 32768K cma-reserved)
  6589    [    0.000000] random: get_random_u64 called from cache_random_seq_create+0x7c/0x150 with crng_init=0
  6590    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
  6591    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
  6592    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
  6593    [    0.000000]     Tasks RCU enabled.
  6594    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
  6595    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
  6596    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
  6597    [    0.000000] GIC: Using split EOI/Deactivate mode
  6598    [    0.000000] irq_meson_gpio: 110 to 8 gpio interrupt mux initialized
  6599    [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
  6600    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
  6601    [    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
  6602    [    0.000354] Console: colour dummy device 80x25
  6603    [    0.000654] printk: console [tty0] enabled
  6604    [    0.000696] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
  6605    [    0.000716] pid_max: default: 32768 minimum: 301
  6606    [    0.000849] LSM: Security Framework initializing
  6607    [    0.000901] SELinux:  Initializing.
  6608    [    0.000979] *** VALIDATE SELinux ***
  6609    [    0.001043] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
  6610    [    0.001071] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
  6611    [    0.001136] *** VALIDATE tmpfs ***
  6612    [    0.001554] *** VALIDATE proc ***
  6613    [    0.001776] *** VALIDATE cgroup1 ***
  6614    [    0.001791] *** VALIDATE cgroup2 ***
  6615    [    0.024014] ASID allocator initialised with 32768 entries
  6616    [    0.031998] rcu: Hierarchical SRCU implementation.
  6617    [    0.042086] EFI services will not be available.
  6618    [    0.048053] smp: Bringing up secondary CPUs ...
  6619    [    0.080279] Detected VIPT I-cache on CPU1
  6620    [    0.080333] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
  6621    [    0.112316] Detected VIPT I-cache on CPU2
  6622    [    0.112362] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
  6623    [    0.144365] Detected VIPT I-cache on CPU3
  6624    [    0.144407] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
  6625    [    0.144482] smp: Brought up 1 node, 4 CPUs
  6626    [    0.144548] SMP: Total of 4 processors activated.
  6627    [    0.144559] CPU features: detected: 32-bit EL0 Support
  6628    [    0.144571] CPU features: detected: CRC32 instructions
  6629    [    0.144874] CPU: All CPU(s) started at EL2
  6630    [    0.144898] alternatives: patching kernel code
  6631    [    0.146014] devtmpfs: initialized
  6632    [    0.151179] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
  6633    [    0.151223] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
  6634    [    0.152397] xor: measuring software checksum speed
  6635    [    0.192309]    8regs     :  2375.000 MB/sec
  6636    [    0.232339]    32regs    :  2724.000 MB/sec
  6637    [    0.272379]    arm64_neon:  2406.000 MB/sec
  6638    [    0.272390] xor: using function: 32regs (2724.000 MB/sec)
  6639    [    0.272444] pinctrl core: initialized pinctrl subsystem
  6640    [    0.273091] thermal_sys: Registered thermal governor 'step_wise'
  6641    [    0.273252] DMI not present or invalid.
  6642    [    0.273606] NET: Registered protocol family 16
  6643    [    0.277246] DMA: preallocated 256 KiB pool for atomic allocations
  6644    [    0.277297] audit: initializing netlink subsys (disabled)
  6645    [    0.277499] audit: type=2000 audit(0.276:1): state=initialized audit_enabled=0 res=1
  6646    [    0.278553] cpuidle: using governor ladder
  6647    [    0.278592] cpuidle: using governor menu
  6648    [    0.278928] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
  6649    [    0.279628] Serial: AMBA PL011 UART driver
  6650    [    0.293599] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
  6651    [    0.293626] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
  6652    [    0.293639] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
  6653    [    0.293651] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
  6654    [    0.297317] cryptd: max_cpu_qlen set to 1000
  6655    [    0.372695] raid6: neonx8   gen()  1620 MB/s
  6656    [    0.440736] raid6: neonx8   xor()  1490 MB/s
  6657    [    0.508809] raid6: neonx4   gen()  1564 MB/s
  6658    [    0.576887] raid6: neonx4   xor()  1471 MB/s
  6659    [    0.644990] raid6: neonx2   gen()  1199 MB/s
  6660    [    0.713023] raid6: neonx2   xor()  1216 MB/s
  6661    [    0.781159] raid6: neonx1   gen()   787 MB/s
  6662    [    0.849232] raid6: neonx1   xor()   914 MB/s
  6663    [    0.917281] raid6: int64x8  gen()  1195 MB/s
  6664    [    0.985326] raid6: int64x8  xor()   769 MB/s
  6665    [    1.053415] raid6: int64x4  gen()  1029 MB/s
  6666    [    1.121501] raid6: int64x4  xor()   752 MB/s
  6667    [    1.189543] raid6: int64x2  gen()   728 MB/s
  6668    [    1.257630] raid6: int64x2  xor()   615 MB/s
  6669    [    1.325714] raid6: int64x1  gen()   486 MB/s
  6670    [    1.393797] raid6: int64x1  xor()   468 MB/s
  6671    [    1.393808] raid6: using algorithm neonx8 gen() 1620 MB/s
  6672    [    1.393818] raid6: .... xor() 1490 MB/s, rmw enabled
  6673    [    1.393828] raid6: using neon recovery algorithm
  6674    [    1.394066] ACPI: Interpreter disabled.
  6675    [    1.395312] iommu: Default domain type: Translated
  6676    [    1.395587] vgaarb: loaded
  6677    [    1.396137] SCSI subsystem initialized
  6678    [    1.396331] libata version 3.00 loaded.
  6679    [    1.396548] usbcore: registered new interface driver usbfs
  6680    [    1.396592] usbcore: registered new interface driver hub
  6681    [    1.396661] usbcore: registered new device driver usb
  6682    [    1.397050] pps_core: LinuxPPS API ver. 1 registered
  6683    [    1.397062] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
  6684    [    1.397085] PTP clock support registered
  6685    [    1.397118] EDAC MC: Ver: 3.0.0
  6686    [    1.397722] FPGA manager framework
  6687    [    1.397857] Advanced Linux Sound Architecture Driver Initialized.
  6688    [    1.398336] NetLabel: Initializing
  6689    [    1.398349] NetLabel:  domain hash size = 128
  6690    [    1.398358] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
  6691    [    1.398413] NetLabel:  unlabeled traffic allowed by default
  6692    [    1.398884] clocksource: Switched to clocksource arch_sys_counter
  6693    [    1.398906] *** VALIDATE bpf ***
  6694    [    1.399161] VFS: Disk quotas dquot_6.6.0
  6695    [    1.399224] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
  6696    [    1.399340] FS-Cache: Loaded
  6697    [    1.399350] *** VALIDATE ramfs ***
  6698    [    1.399372] *** VALIDATE hugetlbfs ***
  6699    [    1.399768] pnp: PnP ACPI: disabled
  6700    [    1.404845] NET: Registered protocol family 2
  6701    [    1.405356] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
  6702    [    1.405402] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
  6703    [    1.405520] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
  6704    [    1.405757] TCP: Hash tables configured (established 16384 bind 16384)
  6705    [    1.405930] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
  6706    [    1.405985] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
  6707    [    1.406207] NET: Registered protocol family 1
  6708    [    1.406679] RPC: Registered named UNIX socket transport module.
  6709    [    1.406701] RPC: Registered udp transport module.
  6710    [    1.406711] RPC: Registered tcp transport module.
  6711    [    1.406720] RPC: Registered tcp NFSv4.1 backchannel transport module.
  6712    [    1.406736] NET: Registered protocol family 44
  6713    [    1.406760] PCI: CLS 0 bytes, default 64
  6714    [    1.407021] Trying to unpack rootfs image as initramfs...
  6715    [    1.868086] Freeing initrd memory: 10248K
  6716    [    1.868928] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
  6717    [    2.082277] Initialise system trusted keyrings
  6718    [    2.082493] workingset: timestamp_bits=46 max_order=19 bucket_order=0
  6719    [    2.087690] zbud: loaded
  6720    [    2.088932] squashfs: version 4.0 (2009/01/31) Phillip Lougher
  6721    [    2.089223] FS-Cache: Netfs 'nfs' registered for caching
  6722    [    2.089757] NFS: Registering the id_resolver key type
  6723    [    2.089797] Key type id_resolver registered
  6724    [    2.089807] Key type id_legacy registered
  6725    [    2.089824] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
  6726    [    2.089836] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
  6727    [    2.091033] FS-Cache: Netfs 'cifs' registered for caching
  6728    [    2.091386] Key type cifs.spnego registered
  6729    [    2.091409] Key type cifs.idmap registered
  6730    [    2.091435] ntfs: driver 2.1.32 [Flags: R/W].
  6731    [    2.092053] JFS: nTxBlock = 8192, nTxLock = 65536
  6732    [    2.097960] SGI XFS with ACLs, security attributes, realtime, quota, no debug enabled
  6733    [    2.099433] *** VALIDATE xfs ***
  6734    [    2.099748] ocfs2: Registered cluster interface o2cb
  6735    [    2.099980] OCFS2 User DLM kernel interface loaded
  6736    [    2.101375] *** VALIDATE gfs2 ***
  6737    [    2.101628] gfs2: GFS2 installed
  6738    [    2.102544] aufs 5.5-20200203
  6739    [    2.123751] Key type asymmetric registered
  6740    [    2.123780] Asymmetric key parser 'x509' registered
  6741    [    2.123790] Asymmetric key parser 'pkcs8' registered
  6742    [    2.123862] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
  6743    [    2.124057] io scheduler mq-deadline registered
  6744    [    2.124071] io scheduler kyber registered
  6745    [    2.124271] io scheduler bfq registered
  6746    [    2.136809] soc soc0: Amlogic Meson GXL (S905X) Revision 21:b (82:2) Detected
  6747    [    2.140393] Serial: 8250/16550 driver, 5 ports, IRQ sharing enabled
  6748    [    2.142089] Serial: AMBA driver
  6749    [    2.142458] c11084c0.serial: ttyAML6 at MMIO 0xc11084c0 (irq = 10, base_baud = 1500000) is a meson_uart
  6750    [    2.142616] serial serial0: tty port ttyAML6 registered
  6751    [    2.142824] c81004c0.serial: ttyAML0 at MMIO 0xc81004c0 (irq = 13, base_baud = 1500000) is a meson_uart
  6752    [    3.118115] printk: console [ttyAML0] enabled
  6753    [    3.134163] brd: module loaded
  6754    [    3.142654] loop: module loaded
  6755    [    3.145092] libphy: Fixed MDIO Bus: probed
  6756    [    3.145730] meson8b-dwmac c9410000.ethernet: IRQ eth_wake_irq not found
  6757    [    3.150924] meson8b-dwmac c9410000.ethernet: IRQ eth_lpi not found
  6758    [    3.157025] meson8b-dwmac c9410000.ethernet: PTP uses main clock
  6759    [    3.162881] meson8b-dwmac c9410000.ethernet: no reset control found
  6760    [    3.169589] meson8b-dwmac c9410000.ethernet: User ID: 0x11, Synopsys ID: 0x37
  6761    [    3.176181] meson8b-dwmac c9410000.ethernet:     DWMAC1000
  6762    [    3.181333] meson8b-dwmac c9410000.ethernet: DMA HW capability register supported
  6763    [    3.188750] meson8b-dwmac c9410000.ethernet: RX Checksum Offload Engine supported
  6764    [    3.196166] meson8b-dwmac c9410000.ethernet: COE Type 2
  6765    [    3.201340] meson8b-dwmac c9410000.ethernet: TX Checksum insertion supported
  6766    [    3.208326] meson8b-dwmac c9410000.ethernet: Wake-Up On Lan supported
  6767    [    3.214738] meson8b-dwmac c9410000.ethernet: Normal descriptors
  6768    [    3.220574] meson8b-dwmac c9410000.ethernet: Ring mode enabled
  6769    [    3.226354] meson8b-dwmac c9410000.ethernet: Enable RX Mitigation via HW Watchdog Timer
  6770    [    3.234475] libphy: stmmac: probed
  6771    [    3.239019] VFIO - User Level meta-driver version: 0.3
  6772    [    3.244293] dwc3 c9000000.dwc3: Failed to get clk 'ref': -2
  6773    [    3.249178] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
  6774    [    3.254764] ehci-pci: EHCI PCI platform driver
  6775    [    3.259198] ehci-platform: EHCI generic platform driver
  6776    [    3.264485] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
  6777    [    3.270440] ohci-pci: OHCI PCI platform driver
  6778    [    3.274884] ohci-platform: OHCI generic platform driver
  6779    [    3.280625] usbcore: registered new interface driver usb-storage
  6780    [    3.286179] mousedev: PS/2 mouse device common for all mice
  6781    [    3.292133] i2c /dev entries driver
  6782    [    3.297754] sdhci: Secure Digital Host Controller Interface driver
  6783    [    3.301067] sdhci: Copyright(c) Pierre Ossman
  6784    [    3.305384] Synopsys Designware Multimedia Card Interface Driver
  6785    [    3.312634] meson-gx-mmc d0072000.mmc: Got CD GPIO
  6786    [    3.343438] meson-gx-mmc d0074000.mmc: allocated mmc-pwrseq
  6787    [    3.371085] sdhci-pltfm: SDHCI platform and OF driver helper
  6788    [    3.372202] ledtrig-cpu: registered to indicate activity on CPUs
  6789    [    3.378022] meson-sm: secure-monitor enabled
  6790    [    3.382208] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
  6791    [    3.389330] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
  6792    [    3.405434] mmc0: new high speed SDHC card at address 59b4
  6793    [    3.406427] mmcblk0: mmc0:59b4 SDU1  29.5 GiB
  6794    [    3.411918]  mmcblk0: p1 p2
  6795    [    3.415362] hid: raw HID events driver (C) Jiri Kosina
  6796    [    3.417772] usbcore: registered new interface driver usbhid
  6797    [    3.423089] usbhid: USB HID core driver
  6798    [    3.427269] platform-mhu c883c404.mailbox: Platform MHU Mailbox registered
  6799    [    3.443607] NET: Registered protocol family 17
  6800    [    3.443891] Key type dns_resolver registered
  6801    [    3.447229] registered taskstats version 1
  6802    [    3.450710] Loading compiled-in X.509 certificates
  6803    [    3.455608] zswap: loaded using pool lzo/zbud
  6804    [    3.459995] Key type ._fscrypt registered
  6805    [    3.463745] Key type .fscrypt registered
  6806    [    3.468678] Btrfs loaded, crc32c=crc32c-generic
  6807    [    3.478837] mmc1: new HS200 MMC card at address 0001
  6808    [    3.479777] mmcblk1: mmc1:0001 016G92 14.7 GiB
  6809    [    3.483260] mmcblk1boot0: mmc1:0001 016G92 partition 1 4.00 MiB
  6810    [    3.489023] mmcblk1boot1: mmc1:0001 016G92 partition 2 4.00 MiB
  6811    [    3.494909] mmcblk1gp0: mmc1:0001 016G92 partition 4 8.00 MiB
  6812    [    3.497911] Key type encrypted registered
  6813    [    3.500430] mmcblk1rpmb: mmc1:0001 016G92 partition 3 512 KiB, chardev (243:0)
  6814    [    3.522981] meson-drm d0100000.vpu: Queued 3 outputs on vpu
  6815    [    3.523334] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
  6816    [    3.529495] [drm] No driver support for vblank timestamp query.
  6817    [    3.562940] meson-dw-hdmi c883a000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
  6818    [    3.567593] meson-dw-hdmi c883a000.hdmi-tx: registered DesignWare HDMI I2C bus driver
  6819    [    3.575606] meson-drm d0100000.vpu: bound c883a000.hdmi-tx (ops meson_dw_hdmi_ops)
  6820    [    3.582964] [drm] Initialized meson 1.0.0 20161109 for d0100000.vpu on minor 0
  6821    [    3.633658] Console: switching to colour frame buffer device 90x36
  6822    [    3.653878] meson-drm d0100000.vpu: fb0: mesondrmfb frame buffer device
  6823    [    3.661158] libphy: mdio_mux: probed
  6824    [    3.671793] libphy: mdio_mux: probed
  6825    [    3.672275] phy phy-d0078080.phy.2: unsupported PHY mode 5
  6826    [    3.677307] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  6827    [    3.680721] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
  6828    [    3.688429] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228f664 hci version 0x100 quirks 0x0000000002010010
  6829    [    3.697656] xhci-hcd xhci-hcd.0.auto: irq 39, io mem 0xc9000000
  6830    [    3.703781] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.05
  6831    [    3.712023] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  6832    [    3.719171] usb usb1: Product: xHCI Host Controller
  6833    [    3.724000] usb usb1: Manufacturer: Linux 5.5.0-rc6-aml-s9xxx xhci-hcd
  6834    [    3.730467] usb usb1: SerialNumber: xhci-hcd.0.auto
  6835    [    3.735831] hub 1-0:1.0: USB hub found
  6836    [    3.739041] hub 1-0:1.0: 2 ports detected
  6837    [    3.743265] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  6838    [    3.748424] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
  6839    [    3.756010] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
  6840    [    3.762519] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
  6841    [    3.770773] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.05
  6842    [    3.779150] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  6843    [    3.786307] usb usb2: Product: xHCI Host Controller
  6844    [    3.791137] usb usb2: Manufacturer: Linux 5.5.0-rc6-aml-s9xxx xhci-hcd
  6845    [    3.797609] usb usb2: SerialNumber: xhci-hcd.0.auto
  6846    [    3.802934] hub 2-0:1.0: USB hub found
  6847    [    3.806163] hub 2-0:1.0: config failed, hub doesn't have any ports! (err -19)
  6848    [    3.815060] meson-gx-mmc d0070000.mmc: allocated mmc-pwrseq
  6849    [    3.846258] scpi_protocol scpi: SCP Protocol legacy pre-1.0 firmware
  6850    [    3.863953] gx-sound-card sound: snd-soc-dummy-dai <-> c1105400.bus:audio-controller-0 mapping ok
  6851    [    3.873182] gx-sound-card sound: i2s-hifi <-> c1105400.bus:audio-controller-2 mapping ok
  6852    [    3.880879] gx-sound-card sound: ASoC: no DMI vendor name!
  6853    [    3.887098] printk: console [netcon0] enabled
  6854    [    3.890479] netconsole: network logging started
  6855    [    3.895089] hctosys: unable to open rtc device (rtc0)
  6856    [    3.900386] ALSA device list:
  6857    [    3.902970]   #0: AMLGX
  6858    [    3.906528] Freeing unused kernel memory: 960K
  6859    [    3.910902] Run /init as init process
  6860    [    3.912430] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
  6861    [    3.922187] mmc2: queuing unknown CIS tuple 0x80 (6 bytes)
  6862    [    3.928350] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
  6863    [    3.940100] mmc2: queuing unknown CIS tuple 0x80 (19 bytes)
  6864    [    3.966045] random: fast init done
  6865    [    4.028898] mmc2: new high speed SDIO card at address 0001
  6866    [    4.078946] usb 1-1: new high-speed USB device number 2 using xhci-hcd
  6867    [    4.100590] usb 1-1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.36
  6868    [    4.107354] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
  6869    [    4.114808] usb 1-1: Product: USB2.0 Hub
  6870    [    4.179038] hub 1-1:1.0: USB hub found
  6871    [    4.181528] hub 1-1:1.0: 4 ports detected
  6872    [    4.310947] usb 1-2: new high-speed USB device number 3 using xhci-hcd
  6873    [    4.341440] usb 1-2: New USB device found, idVendor=148f, idProduct=7601, bcdDevice= 0.00
  6874    [    4.348256] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
  6875    [    4.355282] usb 1-2: Product: 802.11 n WLAN
  6876    [    4.362539] usb 1-2: Manufacturer: MediaTek
  6877    [    4.364626] usb 1-2: SerialNumber: 1.0
  6878    [    5.062707] EXT4-fs (mmcblk0p2): mounted filesystem with writeback data mode. Opts: data=writeback
  6879    [    5.994737] systemd[1]: System time before build time, advancing clock.
  6880    [    6.141100] NET: Registered protocol family 10
  6881    [    6.209997] Segment Routing with IPv6
  6882    [    6.259732] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
  6883    [    6.288199] systemd[1]: Detected architecture arm64.
  6884    [    6.338704] systemd[1]: Set hostname to <mxqpro>.
  6885    [    6.372074] systemd[1]: Couldn't move remaining userspace processes, ignoring: Input/output error
  6886    [    7.054861] random: systemd: uninitialized urandom read (16 bytes read)
  6887    [    7.067075] random: systemd: uninitialized urandom read (16 bytes read)
  6888    [    7.071149] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
  6889    [    7.081240] random: systemd: uninitialized urandom read (16 bytes read)
  6890    [    7.084823] systemd[1]: Reached target Swap.
  6891    [    7.092295] systemd[1]: Listening on Syslog Socket.
  6892    [    7.098246] systemd[1]: Listening on Journal Socket.
  6893    [    7.122859] systemd[1]: Starting Set the console keyboard layout...
  6894    [    7.129515] systemd[1]: Listening on Journal Socket (/dev/log).
  6895    [    7.315203] EXT4-fs (mmcblk0p2): re-mounted. Opts: commit=600,errors=remount-ro
  6896    [    7.493901] systemd-journald[407]: Received request to flush runtime journal from PID 1
  6897    [    8.071019] mc: Linux media interface: v0.10
  6898    [    8.079945] Registered IR keymap rc-empty
  6899    [    8.087170] rc rc0: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0
  6900    [    8.100657] input: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0/input0
  6901    [    8.100893] videodev: Linux video capture interface: v2.00
  6902    [    8.132854] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
  6903    [    8.148810] meson-ir c8100580.ir: receiver initialized
  6904    [    8.178782] lima d00c0000.gpu: IRQ ppmmu3 not found
  6905    [    8.181518] lima d00c0000.gpu: IRQ ppmmu4 not found
  6906    [    8.201614] lima d00c0000.gpu: IRQ ppmmu5 not found
  6907    [    8.203913] lima d00c0000.gpu: IRQ ppmmu6 not found
  6908    [    8.207939] lima d00c0000.gpu: IRQ ppmmu7 not found
  6909    [    8.215838] lima d00c0000.gpu: gp - mali450 version major 0 minor 0
  6910    [    8.219188] lima d00c0000.gpu: pp0 - mali450 version major 0 minor 0
  6911    [    8.225647] lima d00c0000.gpu: pp1 - mali450 version major 0 minor 0
  6912    [    8.231623] lima d00c0000.gpu: pp2 - mali450 version major 0 minor 0
  6913    [    8.238119] lima d00c0000.gpu: IRQ pp3 not found
  6914    [    8.242419] lima d00c0000.gpu: IRQ pp4 not found
  6915    [    8.247000] lima d00c0000.gpu: IRQ pp5 not found
  6916    [    8.251561] lima d00c0000.gpu: IRQ pp6 not found
  6917    [    8.256107] lima d00c0000.gpu: IRQ pp7 not found
  6918    [    8.261785] lima d00c0000.gpu: l2 cache 8K, 4-way, 64byte cache line, 128bit external bus
  6919    [    8.268845] lima d00c0000.gpu: l2 cache 64K, 4-way, 64byte cache line, 128bit external bus
  6920    [    8.277844] lima d00c0000.gpu: bus rate = 166666667
  6921    [    8.281874] lima d00c0000.gpu: mod rate = 744000000
  6922    [    8.287181] [drm] Initialized lima 1.0.0 20190217 for d00c0000.gpu on minor 1
  6923    [    8.357862] Bluetooth: Core ver 2.22
  6924    [    8.359871] NET: Registered protocol family 31
  6925    [    8.362008] Bluetooth: HCI device and connection manager initialized
  6926    [    8.368798] Bluetooth: HCI socket layer initialized
  6927    [    8.373423] Bluetooth: L2CAP socket layer initialized
  6928    [    8.379021] Bluetooth: SCO socket layer initialized
  6929    [    8.422423] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
  6930    [    8.493274] cfg80211: Loading compiled-in X.509 certificates for regulatory database
  6931    [    8.561575] Bluetooth: HCI UART driver ver 2.3
  6932    [    8.564147] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
  6933    [    8.565986] Bluetooth: HCI UART protocol H4 registered
  6934    [    8.569887] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
  6935    [    8.573959] Bluetooth: HCI UART protocol BCSP registered
  6936    [    8.582321] cfg80211: failed to load regulatory.db
  6937    [    8.595293] Bluetooth: HCI UART protocol LL registered
  6938    [    8.600786] Bluetooth: HCI UART protocol ATH3K registered
  6939    [    8.605964] Bluetooth: HCI UART protocol Three-wire (H5) registered
  6940    [    8.613913] Bluetooth: HCI UART protocol Intel registered
  6941    [    8.633245] hci_uart_bcm serial0-0: serial0-0 supply vbat not found, using dummy regulator
  6942    [    8.640769] hci_uart_bcm serial0-0: serial0-0 supply vddio not found, using dummy regulator
  6943    [    8.658992] Bluetooth: HCI UART protocol Broadcom registered
  6944    [    8.661584] Bluetooth: HCI UART protocol QCA registered
  6945    [    8.667927] Bluetooth: HCI UART protocol AG6XX registered
  6946    [    8.668026] Bluetooth: HCI UART protocol Marvell registered
  6947    [    8.706773] brcmfmac: F1 signature read @0x18000000=0x16034334
  6948    [    8.712346] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4334-sdio for chip BCM4334/3
  6949    [    8.720376] usbcore: registered new interface driver brcmfmac
  6950    [    8.755825] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.amlogic,p212.txt failed with error -2
  6951    [    8.767171] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.txt failed with error -2
  6952    [    8.859229] usb 1-2: reset high-speed USB device number 3 using xhci-hcd
  6953    [    8.881999] mt7601u 1-2:1.0: ASIC revision: 76010001 MAC revision: 76010500
  6954    [    8.940600] mt7601u 1-2:1.0: EEPROM ver:0d fae:00
  6955    [    9.052103] Bluetooth: hci0: BCM: chip id 68
  6956    [    9.057452] Bluetooth: hci0: BCM: features 0x0f
  6957    [    9.062136] Bluetooth: hci0: BCM4334B0
  6958    [    9.065093] Bluetooth: hci0: BCM4334B0 (002.001.013) build 0000
  6959    [    9.069602] bluetooth hci0: Direct firmware load for brcm/BCM4334B0.hcd failed with error -2
  6960    [    9.078068] Bluetooth: hci0: BCM: Patch brcm/BCM4334B0.hcd not found
  6961    [    9.143693] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
  6962    [    9.144849] usbcore: registered new interface driver mt7601u
  6963    [    9.782968] brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x50
  6964    [    9.824533] zram: Added device: zram0
  6965    [    9.828286] zram: Added device: zram1
  6966    [    9.832429] zram: Added device: zram2
  6967    [    9.889835] zram1: detected capacity change from 0 to 912879616
  6968    [    9.953468] meson8b-dwmac c9410000.ethernet eth0: PHY [0.e40908ff:08] driver [Meson GXL Internal PHY]
  6969    [    9.978974] meson8b-dwmac c9410000.ethernet eth0: No Safety Features support found
  6970    [    9.983456] meson8b-dwmac c9410000.ethernet eth0: PTP not supported by HW
  6971    [    9.990268] meson8b-dwmac c9410000.ethernet eth0: configuring for phy/rmii link mode
  6972    [   10.525892] random: crng init done
  6973    [   10.528417] random: 7 urandom warning(s) missed due to ratelimiting
  6974    [   10.579111] Adding 891480k swap on /dev/zram1.  Priority:5 extents:1 across:891480k SSFS
  6975
  6976    ### armbian-release:
  6977
  6978    # PLEASE DO NOT EDIT THIS FILE
  6979    BOARD=aml-s9xxx
  6980    BOARD_NAME="AML-S9xxx"
  6981    BOARDFAMILY=aml-s9xxx
  6982    BUILD_REPOSITORY_URL=https://github.com/150balbes/Build-Armbian.git
  6983    BUILD_REPOSITORY_COMMIT=62b8c07-dirty
  6984    DISTRIBUTION_CODENAME=buster
  6985    DISTRIBUTION_STATUS=supported
  6986    VERSION=20.02.0-rc1.037
  6987    LINUXFAMILY=aml-s9xxx
  6988    BRANCH=current
  6989    ARCH=arm64
  6990    IMAGE_TYPE=nightly
  6991    BOARD_TYPE=conf
  6992    INITRD_ARCH=arm64
  6993    KERNEL_IMAGE_TYPE=Image
  6994
  6995    ### boot environment:
  6996
  6997    ODROIDN2-UBOOT-CONFIG
  6998    setenv env_addr 0x10400000
  6999    setenv kernel_addr 0x11000000
  7000    setenv initrd_addr 0x13000000
  7001    setenv dtb_addr 0x1000000
  7002    if test "${devtype}" = ""; then setenv devtype "mmc"; fi
  7003    load ${devtype} ${devnum} ${env_addr} uEnv.txt && env import -t ${env_addr} ${filesize}
  7004    setenv bootargs ${APPEND}
  7005    load ${devtype} ${devnum} ${kernel_addr} ${LINUX}
  7006    load ${devtype} ${devnum} ${initrd_addr} ${INITRD}
  7007    load ${devtype} ${devnum} ${dtb_addr} ${FDT}
  7008    fdt addr ${dtb_addr}
  7009    booti ${kernel_addr} ${initrd_addr} ${dtb_addr}
  7010
  7011    ### lsusb:
  7012
  7013    Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
  7014    Bus 001 Device 003: ID 148f:7601 Ralink Technology, Corp. MT7601U Wireless Adapter
  7015    Bus 001 Device 002: ID 05e3:0608 Genesys Logic, Inc. Hub
  7016    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  7017
  7018    ### lscpu:
  7019
  7020    Architecture:        aarch64
  7021    Byte Order:          Little Endian
  7022    CPU(s):              4
  7023    On-line CPU(s) list: 0-3
  7024    Thread(s) per core:  1
  7025    Core(s) per socket:  4
  7026    Socket(s):           1
  7027    Vendor ID:           ARM
  7028    Model:               4
  7029    Model name:          Cortex-A53
  7030    Stepping:            r0p4
  7031    CPU max MHz:         1512,0000
  7032    CPU min MHz:         100,0000
  7033    BogoMIPS:            48.00
  7034    L1d cache:           unknown size
  7035    L1i cache:           unknown size
  7036    L2 cache:            unknown size
  7037    Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  7038
  7039    ### cpuinfo:
  7040
  7041    processor    : 0
  7042    model name    : ARMv8 Processor rev 4 (v8l)
  7043    BogoMIPS    : 48.00
  7044    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  7045    CPU implementer    : 0x41
  7046    CPU architecture: 8
  7047    CPU variant    : 0x0
  7048    CPU part    : 0xd03
  7049    CPU revision    : 4
  7050
  7051    processor    : 1
  7052    model name    : ARMv8 Processor rev 4 (v8l)
  7053    BogoMIPS    : 48.00
  7054    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  7055    CPU implementer    : 0x41
  7056    CPU architecture: 8
  7057    CPU variant    : 0x0
  7058    CPU part    : 0xd03
  7059    CPU revision    : 4
  7060
  7061    processor    : 2
  7062    model name    : ARMv8 Processor rev 4 (v8l)
  7063    BogoMIPS    : 48.00
  7064    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  7065    CPU implementer    : 0x41
  7066    CPU architecture: 8
  7067    CPU variant    : 0x0
  7068    CPU part    : 0xd03
  7069    CPU revision    : 4
  7070
  7071    processor    : 3
  7072    model name    : ARMv8 Processor rev 4 (v8l)
  7073    BogoMIPS    : 48.00
  7074    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  7075    CPU implementer    : 0x41
  7076    CPU architecture: 8
  7077    CPU variant    : 0x0
  7078    CPU part    : 0xd03
  7079    CPU revision    : 4
  7080
  7081
  7082    ### meminfo:
  7083
  7084    MemTotal:        1782968 kB
  7085    MemFree:         1603708 kB
  7086    MemAvailable:    1660488 kB
  7087    Buffers:           11628 kB
  7088    Cached:            56000 kB
  7089    SwapCached:            0 kB
  7090    Active:            53564 kB
  7091    Inactive:          36916 kB
  7092    Active(anon):      22932 kB
  7093    Inactive(anon):     2628 kB
  7094    Active(file):      30632 kB
  7095    Inactive(file):    34288 kB
  7096    Unevictable:          16 kB
  7097    Mlocked:              16 kB
  7098    SwapTotal:        891480 kB
  7099    SwapFree:         891480 kB
  7100    Dirty:               720 kB
  7101    Writeback:             0 kB
  7102    AnonPages:         22756 kB
  7103    Mapped:            24900 kB
  7104    Shmem:              2756 kB
  7105    KReclaimable:      17864 kB
  7106    Slab:              53516 kB
  7107    SReclaimable:      17864 kB
  7108    SUnreclaim:        35652 kB
  7109    KernelStack:        2784 kB
  7110    PageTables:         1712 kB
  7111    NFS_Unstable:          0 kB
  7112    Bounce:                0 kB
  7113    WritebackTmp:          0 kB
  7114    CommitLimit:     1782964 kB
  7115    Committed_AS:      78780 kB
  7116    VmallocTotal:   135290159040 kB
  7117    VmallocUsed:       16756 kB
  7118    VmallocChunk:          0 kB
  7119    Percpu:             1264 kB
  7120    CmaTotal:          32768 kB
  7121    CmaFree:           29084 kB
  7122    HugePages_Total:       0
  7123    HugePages_Free:        0
  7124    HugePages_Rsvd:        0
  7125    HugePages_Surp:        0
  7126    Hugepagesize:       2048 kB
  7127    Hugetlb:               0 kB
  7128
  7129    ### virtual memory:
  7130
  7131    vm.admin_reserve_kbytes = 8192
  7132    vm.block_dump = 0
  7133    vm.compact_unevictable_allowed = 1
  7134    vm.dirty_background_bytes = 0
  7135    vm.dirty_background_ratio = 10
  7136    vm.dirty_bytes = 0
  7137    vm.dirty_expire_centisecs = 3000
  7138    vm.dirty_ratio = 20
  7139    vm.dirtytime_expire_seconds = 43200
  7140    vm.dirty_writeback_centisecs = 500
  7141    vm.extfrag_threshold = 500
  7142    vm.hugetlb_shm_group = 0
  7143    vm.laptop_mode = 0
  7144    vm.legacy_va_layout = 0
  7145    vm.lowmem_reserve_ratio = 256    256    32    0
  7146    vm.max_map_count = 65530
  7147    vm.min_free_kbytes = 5274
  7148    vm.mmap_min_addr = 4096
  7149    vm.mmap_rnd_bits = 18
  7150    vm.nr_hugepages = 0
  7151    vm.nr_overcommit_hugepages = 0
  7152    vm.oom_dump_tasks = 1
  7153    vm.oom_kill_allocating_task = 0
  7154    vm.overcommit_kbytes = 0
  7155    vm.overcommit_memory = 0
  7156    vm.overcommit_ratio = 50
  7157    vm.page-cluster = 0
  7158    vm.panic_on_oom = 0
  7159    vm.percpu_pagelist_fraction = 0
  7160    vm.stat_interval = 1
  7161    vm.swappiness = 100
  7162    vm.user_reserve_kbytes = 55250
  7163    vm.vfs_cache_pressure = 100
  7164    vm.watermark_boost_factor = 15000
  7165    vm.watermark_scale_factor = 10
  7166
  7167    ### ip addr:
  7168
  7169    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
  7170        link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  7171        inet XXX.XXX.0.1/8 scope host lo
  7172           valid_lft forever preferred_lft forever
  7173        inet6 ::1/128 scope host
  7174           valid_lft forever preferred_lft forever
  7175    2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
  7176        link/ether 00:df:06:00:00:0b brd ff:ff:ff:ff:ff:ff
  7177    3: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  7178        link/ether 00:36:76:61:0b:24 brd ff:ff:ff:ff:ff:ff
  7179
  7180    ### partitions:
  7181
  7182    major minor  #blocks  name
  7183
  7184     179        0   30924800 mmcblk0
  7185     179        1     262144 mmcblk0p1
  7186     179        2   30337024 mmcblk0p2
  7187     179       32   15384576 mmcblk1
  7188     179      128       8192 mmcblk1gp0
  7189     254        1     891484 zram1
  7190
  7191    ### df:
  7192
  7193    udev             850M      0  850M   0% /dev
  7194    tmpfs            175M   2,7M  172M   2% /run
  7195    /dev/mmcblk0p2    29G    10G   19G  36% /
  7196    tmpfs            871M      0  871M   0% /dev/shm
  7197    tmpfs            5,0M   4,0K  5,0M   1% /run/lock
  7198    tmpfs            871M      0  871M   0% /sys/fs/cgroup
  7199    tmpfs            871M      0  871M   0% /tmp
  7200    /dev/mmcblk0p1   256M    76M  180M  30% /boot
  7201
  7202    ### lsblk:
  7203
  7204    NAME         FSTYPE   SIZE MOUNTPOINT UUID
  7205    mmcblk0              29,5G
  7206    ├─mmcblk0p1  vfat     256M /boot      50FC-6AC8
  7207    └─mmcblk0p2  ext4      29G /          3e297ac1-e4e4-4ab1-bc57-47c07d0422ba
  7208    mmcblk1              14,7G
  7209    mmcblk1boot0            4M
  7210    mmcblk1boot1            4M
  7211    mmcblk1gp0              8M
  7212
  7213    ### zramctl:
  7214
  7215    NAME       ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT
  7216    /dev/zram1 lzo         870,6M   4K   81B   12K       4 [SWAP]
  7217
  7218    ### mtab:
  7219
  7220    /dev/mmcblk0p1 /boot vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro 0 0
  7221    /dev/mmcblk0p2 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  7222
  7223    ### mmc0:59b4 info:
  7224
  7225                   fwrev: 0x0
  7226                  uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SDU1  MODALIAS=mmc:block
  7227                     cid: 1b534d53445531201014a136d4013800
  7228                     rca: 0x59b4
  7229                     csd: 400e00325b590000ebef7f800a400000
  7230                  manfid: 0x00001b
  7231                     ocr: 0x00200000
  7232    preferred_erase_size: 4194304
  7233                    type: SD
  7234                   hwrev: 0x1
  7235                    date: 08/2019
  7236                     dsr: 0x404
  7237              erase_size: 512
  7238                   oemid: 0x534d
  7239                  serial: 0x14a136d4
  7240                     ssr: 0000000005000000040090000811391e00089a342f01000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  7241                     scr: 0235844300000000
  7242                    name: SDU1
  7243
  7244    ### mmc1:0001 info:
  7245
  7246                   fwrev: 0x0
  7247                  uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=016G92 MODALIAS=mmc:block
  7248                     cid: 11010030313647393201d3d1a4db1100
  7249             rel_sectors: 0x10
  7250                     rca: 0x0001
  7251            pre_eol_info: 0x00
  7252                     csd: d00e00320f5903ffffffffef92400000
  7253                  manfid: 0x000011
  7254                     ocr: 0x00200000
  7255    preferred_erase_size: 4194304
  7256    enhanced_area_offset: 18446744073709551594
  7257      raw_rpmb_size_mult: 0x4
  7258                    type: MMC
  7259                   hwrev: 0x0
  7260                    date: 01/2014
  7261                     prv: 0x1
  7262             ffu_capable: 0
  7263                     dsr: 0x404
  7264              erase_size: 4194304
  7265               life_time: 0x00 0x00
  7266      enhanced_area_size: 4294967274
  7267                   oemid: 0x0100
  7268                  serial: 0xd3d1a4db
  7269                 cmdq_en: 0
  7270                     rev: 0x6
  7271                    name: 016G92
  7272
  7273    ### Boot system health:
  7274
  7275    Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU
  7276    14:12:48: 1512MHz  0.23  51%  24%  15%   0%   9%   1% 50.0°C
  7277    14:12:48: 1512MHz  0.23  75%  11%  20%   1%  40%   2% 50.0°C
  7278    14:12:49: 1512MHz  0.23  58%   6%   5%   1%  44%   0% 49.0°C
  7279    14:12:49: 1512MHz  0.23  49%   9%  12%   0%  24%   2% 49.0°C
  7280    14:12:49: 1512MHz  0.23  21%   6%   2%   1%  11%   0% 49.0°C
  7281
  7282    ### lsusb:
  7283
  7284    Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
  7285    Bus 001 Device 003: ID 148f:7601 Ralink Technology, Corp. MT7601U Wireless Adapter
  7286    Bus 001 Device 002: ID 05e3:0608 Genesys Logic, Inc. Hub
  7287    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  7288
  7289    /:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/0p, 5000M
  7290    /:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/2p, 480M
  7291        |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
  7292        |__ Port 2: Dev 3, If 0, Class=Vendor Specific Class, Driver=mt7601u, 480M
  7293
  7294    ### lspci:
  7295
  7296
  7297    ### Installed packages:
  7298
  7299    ii  armbian-buster-desktop                21.02.2                              all          Armbian desktop for Debian buster
  7300    ii  armbian-config                        21.02.3                              all          Armbian configuration utility
  7301    ii  armbian-firmware                      21.02.3                              all          Linux firmware
  7302    ii  hostapd                               3:2.9-102~armbian20.05.2+1           arm64        IEEE 802.11 AP and IEEE 802.1X/WPA/WPA2/EAP Authenticator
  7303    ii  htop                                  3.1.0-0~armbian20.08.2+1             arm64        interactive processes viewer
  7304    ii  linux-base                            4.6                                  all          Linux image base package
  7305    ii  linux-buster-root-current-aml-s9xxx   20.02.0-rc1.037                      arm64        Armbian tweaks for buster on aml-s9xxx (current branch)
  7306    ii  linux-image-current-aml-s9xxx         20.02.0-rc1.037                      arm64        Linux kernel, version 5.5.0-rc6-aml-s9xxx
  7307    ii  linux-libc-dev:arm64                  4.19.171-2                           arm64        Linux support headers for userspace development
  7308    ii  linux-u-boot-aml-s9xxx-current        20.02.0-rc1.037                      arm64        Uboot loader 2019.10
  7309
  7310    ### Loaded modules:
  7311
  7312    Module                  Size  Used by
  7313    ip6t_REJECT            16384  2
  7314    nf_reject_ipv6         20480  1 ip6t_REJECT
  7315    ip6table_filter        16384  1
  7316    xt_state               16384  0
  7317    ipt_REJECT             16384  2
  7318    nf_reject_ipv4         16384  1 ipt_REJECT
  7319    ip6_tables             28672  1 ip6table_filter
  7320    xt_nat                 16384  11
  7321    xt_tcpudp              20480  35
  7322    tun                    53248  2
  7323    iptable_filter         16384  1
  7324    iptable_nat            16384  3
  7325    bpfilter               28672  0
  7326    veth                   28672  0
  7327    xt_conntrack           16384  6
  7328    xt_MASQUERADE          20480  7
  7329    nf_conntrack_netlink    49152  0
  7330    xfrm_user              36864  2
  7331    xfrm_algo              16384  1 xfrm_user
  7332    nft_counter            16384  15
  7333    xt_addrtype            16384  8
  7334    nft_compat             20480  4
  7335    nft_chain_nat          16384  4
  7336    nf_nat                 53248  4 xt_nat,nft_chain_nat,iptable_nat,xt_MASQUERADE
  7337    nf_conntrack          176128  6 xt_conntrack,nf_nat,xt_state,xt_nat,nf_conntrack_netlink,xt_MASQUERADE
  7338    nf_defrag_ipv4         16384  1 nf_conntrack
  7339    nf_tables             163840  45 nft_compat,nft_counter,nft_chain_nat
  7340    nfnetlink              16384  5 nft_compat,nf_conntrack_netlink,nf_tables
  7341    br_netfilter           28672  0
  7342    bridge                208896  1 br_netfilter
  7343    stp                    16384  1 bridge
  7344    llc                    16384  2 bridge,stp
  7345    bnep                   32768  2
  7346    zram                   36864  1
  7347    nls_ascii              16384  1
  7348    mt7601u                77824  0
  7349    brcmfmac              376832  0
  7350    mac80211              569344  1 mt7601u
  7351    brcmutil               24576  1 brcmfmac
  7352    hci_uart              143360  0
  7353    btqca                  20480  1 hci_uart
  7354    btrtl                  24576  1 hci_uart
  7355    cfg80211              417792  3 mt7601u,brcmfmac,mac80211
  7356    btbcm                  16384  1 hci_uart
  7357    meson_vdec             86016  0
  7358    btintel                32768  1 hci_uart
  7359    bluetooth             598016  27 btrtl,btqca,btintel,hci_uart,btbcm,bnep
  7360    crct10dif_ce           16384  1
  7361    v4l2_mem2mem           40960  1 meson_vdec
  7362    lima                   45056  0
  7363    ecdh_generic           16384  2 bluetooth
  7364    ecc                    32768  1 ecdh_generic
  7365    videobuf2_dma_contig    24576  1 meson_vdec
  7366    gpu_sched              28672  1 lima
  7367    rfkill                 36864  5 bluetooth,cfg80211
  7368    videobuf2_memops       20480  1 videobuf2_dma_contig
  7369    videobuf2_v4l2         36864  2 meson_vdec,v4l2_mem2mem
  7370    videobuf2_common       61440  3 meson_vdec,videobuf2_v4l2,v4l2_mem2mem
  7371    meson_rng              16384  0
  7372    videodev              233472  4 meson_vdec,videobuf2_v4l2,videobuf2_common,v4l2_mem2mem
  7373    dw_hdmi_cec            16384  0
  7374    meson_ir               16384  0
  7375    mc                     61440  4 videodev,videobuf2_v4l2,videobuf2_common,v4l2_mem2mem
  7376    rc_core                61440  2 meson_ir
  7377    ao_cec                 20480  0
  7378    ip_tables              28672  2 iptable_filter,iptable_nat
  7379    x_tables               40960  13 ip6table_filter,xt_conntrack,iptable_filter,nft_compat,xt_state,xt_tcpudp,xt_addrtype,xt_nat,ip6_tables,ipt_REJECT,ip_tables,xt_MASQUERADE,ip6t_REJECT
  7380    ipv6                  585728  111 bridge,br_netfilter,nf_reject_ipv6
  7381    nf_defrag_ipv6         24576  2 nf_conntrack,ipv6
  7382
  7383    ### Current system health:
  7384
  7385    Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU
  7386    14:15:15:   ---      1.08  22%   8%   9%   0%   4%   0% 49.0°C
  7387    14:15:15:   ---      1.08   4%   2%   0%   1%   0%   0% 48.0°C
  7388    14:15:15:   ---      1.08   4%   4%   0%   0%   0%   0% 48.0°C
  7389    14:15:16:   ---      1.08   4%   2%   0%   0%   0%   0% 48.0°C
  7390    14:15:16:   ---      1.08   4%   2%   0%   0%   0%   0% 48.0°C
  7391    14:15:19:   ---      1.40  23%   7%  10%   0%   3%   0% 57.0°C
  7392    14:15:20:   ---      1.40  76%   0%  75%   0%   0%   0% 51.0°C
  7393    14:15:20:   ---      1.40   4%   2%   0%   0%   0%   1% 50.0°C
  7394    14:15:20:   ---      1.40   3%   2%   0%   0%   0%   0% 50.0°C
  7395    14:15:21:   ---      1.40   2%   1%   0%   1%   0%   0% 50.0°C
  7396
  7397    ### resolv.conf
  7398
  7399    -rw-r--r-- 1 root root 93 mar 25 14:12 /etc/resolv.conf
  7400    # Generated by NetworkManager
  7401    search lan
  7402    nameserver XXX.XXX.1.1
  7403    nameserver fde6:471f:148a::1
  7404
  7405    ### Current sysinfo:
  7406
  7407    Linux 5.5.0-rc6-aml-s9xxx (mxqpro)     25/03/21     _aarch64_    (4 CPU)
  7408
  7409    avg-cpu:  %user   %nice %system %iowait  %steal   %idle
  7410              11,17    0,04    8,63    3,82    0,00   76,34
  7411
  7412    Device             tps    kB_read/s    kB_wrtn/s    kB_read    kB_wrtn
  7413    ram0              0,00         0,00         0,00          0          0
  7414    ram1              0,00         0,00         0,00          0          0
  7415    ram2              0,00         0,00         0,00          0          0
  7416    ram3              0,00         0,00         0,00          0          0
  7417    ram4              0,00         0,00         0,00          0          0
  7418    ram5              0,00         0,00         0,00          0          0
  7419    ram6              0,00         0,00         0,00          0          0
  7420    ram7              0,00         0,00         0,00          0          0
  7421    ram8              0,00         0,00         0,00          0          0
  7422    ram9              0,00         0,00         0,00          0          0
  7423    ram10             0,00         0,00         0,00          0          0
  7424    ram11             0,00         0,00         0,00          0          0
  7425    ram12             0,00         0,00         0,00          0          0
  7426    ram13             0,00         0,00         0,00          0          0
  7427    ram14             0,00         0,00         0,00          0          0
  7428    ram15             0,00         0,00         0,00          0          0
  7429    mmcblk0         103,15      4149,96        81,25     555306      10872
  7430    mmcblk0p1         1,32        45,00         0,00       6021          0
  7431    mmcblk0p2       100,70      4081,44        81,25     546137      10872
  7432    mmcblk1           1,79        38,98         0,00       5216          0
  7433    mmcblk1gp0        1,11         4,42         0,00        592          0
  7434    mmcblk1boot1      0,85         3,41         0,00        456          0
  7435    mmcblk1boot0      0,85         3,41         0,00        456          0
  7436    zram0             0,00         0,00         0,00          0          0
  7437    zram1           541,54       921,07      1245,11     123248     166608
  7438    zram2             0,00         0,00         0,00          0          0
  7439
  7440    procs -----------------------memory---------------------- ---swap-- -----io---- -system-- --------cpu--------
  7441     r  b         swpd         free         buff        cache   si   so    bi    bo   in   cs  us  sy  id  wa  st
  7442     0  0        39424       821352        33000       546440  230  314  1058    20  504  812  11   9  76   4   0
  7443
  7444                  total        used        free      shared  buff/cache   available
  7445    Mem:          1,7Gi       373Mi       802Mi        18Mi       565Mi       1,3Gi
  7446    Swap:         870Mi        38Mi       832Mi
  7447
  7448    NAME       ALGORITHM DISKSIZE  DATA COMPR TOTAL STREAMS MOUNTPOINT
  7449    /dev/zram1 lzo         870,6M 37,9M 12,8M 14,2M       4 [SWAP]
  7450
  7451     14:15:21 up 2 min,  1 user,  load average: 1,40, 0,68, 0,26
  7452
  7453    [    3.389330] gxl-crypto c883e000.crypto: will run requests pump with realtime priority
  7454    [    3.405434] mmc0: new high speed SDHC card at address 59b4
  7455    [    3.406427] mmcblk0: mmc0:59b4 SDU1  29.5 GiB
  7456    [    3.411918]  mmcblk0: p1 p2
  7457    [    3.415362] hid: raw HID events driver (C) Jiri Kosina
  7458    [    3.417772] usbcore: registered new interface driver usbhid
  7459    [    3.423089] usbhid: USB HID core driver
  7460    [    3.427269] platform-mhu c883c404.mailbox: Platform MHU Mailbox registered
  7461    [    3.443607] NET: Registered protocol family 17
  7462    [    3.443891] Key type dns_resolver registered
  7463    [    3.447229] registered taskstats version 1
  7464    [    3.450710] Loading compiled-in X.509 certificates
  7465    [    3.455608] zswap: loaded using pool lzo/zbud
  7466    [    3.459995] Key type ._fscrypt registered
  7467    [    3.463745] Key type .fscrypt registered
  7468    [    3.468678] Btrfs loaded, crc32c=crc32c-generic
  7469    [    3.478837] mmc1: new HS200 MMC card at address 0001
  7470    [    3.479777] mmcblk1: mmc1:0001 016G92 14.7 GiB
  7471    [    3.483260] mmcblk1boot0: mmc1:0001 016G92 partition 1 4.00 MiB
  7472    [    3.489023] mmcblk1boot1: mmc1:0001 016G92 partition 2 4.00 MiB
  7473    [    3.494909] mmcblk1gp0: mmc1:0001 016G92 partition 4 8.00 MiB
  7474    [    3.497911] Key type encrypted registered
  7475    [    3.500430] mmcblk1rpmb: mmc1:0001 016G92 partition 3 512 KiB, chardev (243:0)
  7476    [    3.522981] meson-drm d0100000.vpu: Queued 3 outputs on vpu
  7477    [    3.523334] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
  7478    [    3.529495] [drm] No driver support for vblank timestamp query.
  7479    [    3.562940] meson-dw-hdmi c883a000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy)
  7480    [    3.567593] meson-dw-hdmi c883a000.hdmi-tx: registered DesignWare HDMI I2C bus driver
  7481    [    3.575606] meson-drm d0100000.vpu: bound c883a000.hdmi-tx (ops meson_dw_hdmi_ops)
  7482    [    3.582964] [drm] Initialized meson 1.0.0 20161109 for d0100000.vpu on minor 0
  7483    [    3.633658] Console: switching to colour frame buffer device 90x36
  7484    [    3.653878] meson-drm d0100000.vpu: fb0: mesondrmfb frame buffer device
  7485    [    3.661158] libphy: mdio_mux: probed
  7486    [    3.671793] libphy: mdio_mux: probed
  7487    [    3.672275] phy phy-d0078080.phy.2: unsupported PHY mode 5
  7488    [    3.677307] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  7489    [    3.680721] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
  7490    [    3.688429] xhci-hcd xhci-hcd.0.auto: hcc params 0x0228f664 hci version 0x100 quirks 0x0000000002010010
  7491    [    3.697656] xhci-hcd xhci-hcd.0.auto: irq 39, io mem 0xc9000000
  7492    [    3.703781] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.05
  7493    [    3.712023] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  7494    [    3.719171] usb usb1: Product: xHCI Host Controller
  7495    [    3.724000] usb usb1: Manufacturer: Linux 5.5.0-rc6-aml-s9xxx xhci-hcd
  7496    [    3.730467] usb usb1: SerialNumber: xhci-hcd.0.auto
  7497    [    3.735831] hub 1-0:1.0: USB hub found
  7498    [    3.739041] hub 1-0:1.0: 2 ports detected
  7499    [    3.743265] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
  7500    [    3.748424] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
  7501    [    3.756010] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
  7502    [    3.762519] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
  7503    [    3.770773] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.05
  7504    [    3.779150] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  7505    [    3.786307] usb usb2: Product: xHCI Host Controller
  7506    [    3.791137] usb usb2: Manufacturer: Linux 5.5.0-rc6-aml-s9xxx xhci-hcd
  7507    [    3.797609] usb usb2: SerialNumber: xhci-hcd.0.auto
  7508    [    3.802934] hub 2-0:1.0: USB hub found
  7509    [    3.806163] hub 2-0:1.0: config failed, hub doesn't have any ports! (err -19)
  7510    [    3.815060] meson-gx-mmc d0070000.mmc: allocated mmc-pwrseq
  7511    [    3.846258] scpi_protocol scpi: SCP Protocol legacy pre-1.0 firmware
  7512    [    3.863953] gx-sound-card sound: snd-soc-dummy-dai <-> c1105400.bus:audio-controller-0 mapping ok
  7513    [    3.873182] gx-sound-card sound: i2s-hifi <-> c1105400.bus:audio-controller-2 mapping ok
  7514    [    3.880879] gx-sound-card sound: ASoC: no DMI vendor name!
  7515    [    3.887098] printk: console [netcon0] enabled
  7516    [    3.890479] netconsole: network logging started
  7517    [    3.895089] hctosys: unable to open rtc device (rtc0)
  7518    [    3.900386] ALSA device list:
  7519    [    3.902970]   #0: AMLGX
  7520    [    3.906528] Freeing unused kernel memory: 960K
  7521    [    3.910902] Run /init as init process
  7522    [    3.912430] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
  7523    [    3.922187] mmc2: queuing unknown CIS tuple 0x80 (6 bytes)
  7524    [    3.928350] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
  7525    [    3.940100] mmc2: queuing unknown CIS tuple 0x80 (19 bytes)
  7526    [    3.966045] random: fast init done
  7527    [    4.028898] mmc2: new high speed SDIO card at address 0001
  7528    [    4.078946] usb 1-1: new high-speed USB device number 2 using xhci-hcd
  7529    [    4.100590] usb 1-1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.36
  7530    [    4.107354] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
  7531    [    4.114808] usb 1-1: Product: USB2.0 Hub
  7532    [    4.179038] hub 1-1:1.0: USB hub found
  7533    [    4.181528] hub 1-1:1.0: 4 ports detected
  7534    [    4.310947] usb 1-2: new high-speed USB device number 3 using xhci-hcd
  7535    [    4.341440] usb 1-2: New USB device found, idVendor=148f, idProduct=7601, bcdDevice= 0.00
  7536    [    4.348256] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
  7537    [    4.355282] usb 1-2: Product: 802.11 n WLAN
  7538    [    4.362539] usb 1-2: Manufacturer: MediaTek
  7539    [    4.364626] usb 1-2: SerialNumber: 1.0
  7540    [    5.062707] EXT4-fs (mmcblk0p2): mounted filesystem with writeback data mode. Opts: data=writeback
  7541    [    5.994737] systemd[1]: System time before build time, advancing clock.
  7542    [    6.141100] NET: Registered protocol family 10
  7543    [    6.209997] Segment Routing with IPv6
  7544    [    6.259732] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
  7545    [    6.288199] systemd[1]: Detected architecture arm64.
  7546    [    6.338704] systemd[1]: Set hostname to <mxqpro>.
  7547    [    6.372074] systemd[1]: Couldn't move remaining userspace processes, ignoring: Input/output error
  7548    [    7.054861] random: systemd: uninitialized urandom read (16 bytes read)
  7549    [    7.067075] random: systemd: uninitialized urandom read (16 bytes read)
  7550    [    7.071149] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
  7551    [    7.081240] random: systemd: uninitialized urandom read (16 bytes read)
  7552    [    7.084823] systemd[1]: Reached target Swap.
  7553    [    7.092295] systemd[1]: Listening on Syslog Socket.
  7554    [    7.098246] systemd[1]: Listening on Journal Socket.
  7555    [    7.122859] systemd[1]: Starting Set the console keyboard layout...
  7556    [    7.129515] systemd[1]: Listening on Journal Socket (/dev/log).
  7557    [    7.315203] EXT4-fs (mmcblk0p2): re-mounted. Opts: commit=600,errors=remount-ro
  7558    [    7.493901] systemd-journald[407]: Received request to flush runtime journal from PID 1
  7559    [    8.071019] mc: Linux media interface: v0.10
  7560    [    8.079945] Registered IR keymap rc-empty
  7561    [    8.087170] rc rc0: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0
  7562    [    8.100657] input: meson-ir as /devices/platform/soc/c8100000.bus/c8100580.ir/rc/rc0/input0
  7563    [    8.100893] videodev: Linux video capture interface: v2.00
  7564    [    8.132854] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter
  7565    [    8.148810] meson-ir c8100580.ir: receiver initialized
  7566    [    8.178782] lima d00c0000.gpu: IRQ ppmmu3 not found
  7567    [    8.181518] lima d00c0000.gpu: IRQ ppmmu4 not found
  7568    [    8.201614] lima d00c0000.gpu: IRQ ppmmu5 not found
  7569    [    8.203913] lima d00c0000.gpu: IRQ ppmmu6 not found
  7570    [    8.207939] lima d00c0000.gpu: IRQ ppmmu7 not found
  7571    [    8.215838] lima d00c0000.gpu: gp - mali450 version major 0 minor 0
  7572    [    8.219188] lima d00c0000.gpu: pp0 - mali450 version major 0 minor 0
  7573    [    8.225647] lima d00c0000.gpu: pp1 - mali450 version major 0 minor 0
  7574    [    8.231623] lima d00c0000.gpu: pp2 - mali450 version major 0 minor 0
  7575    [    8.238119] lima d00c0000.gpu: IRQ pp3 not found
  7576    [    8.242419] lima d00c0000.gpu: IRQ pp4 not found
  7577    [    8.247000] lima d00c0000.gpu: IRQ pp5 not found
  7578    [    8.251561] lima d00c0000.gpu: IRQ pp6 not found
  7579    [    8.256107] lima d00c0000.gpu: IRQ pp7 not found
  7580    [    8.261785] lima d00c0000.gpu: l2 cache 8K, 4-way, 64byte cache line, 128bit external bus
  7581    [    8.268845] lima d00c0000.gpu: l2 cache 64K, 4-way, 64byte cache line, 128bit external bus
  7582    [    8.277844] lima d00c0000.gpu: bus rate = 166666667
  7583    [    8.281874] lima d00c0000.gpu: mod rate = 744000000
  7584    [    8.287181] [drm] Initialized lima 1.0.0 20190217 for d00c0000.gpu on minor 1
  7585    [    8.357862] Bluetooth: Core ver 2.22
  7586    [    8.359871] NET: Registered protocol family 31
  7587    [    8.362008] Bluetooth: HCI device and connection manager initialized
  7588    [    8.368798] Bluetooth: HCI socket layer initialized
  7589    [    8.373423] Bluetooth: L2CAP socket layer initialized
  7590    [    8.379021] Bluetooth: SCO socket layer initialized
  7591    [    8.422423] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
  7592    [    8.493274] cfg80211: Loading compiled-in X.509 certificates for regulatory database
  7593    [    8.561575] Bluetooth: HCI UART driver ver 2.3
  7594    [    8.564147] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
  7595    [    8.565986] Bluetooth: HCI UART protocol H4 registered
  7596    [    8.569887] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
  7597    [    8.573959] Bluetooth: HCI UART protocol BCSP registered
  7598    [    8.582321] cfg80211: failed to load regulatory.db
  7599    [    8.595293] Bluetooth: HCI UART protocol LL registered
  7600    [    8.600786] Bluetooth: HCI UART protocol ATH3K registered
  7601    [    8.605964] Bluetooth: HCI UART protocol Three-wire (H5) registered
  7602    [    8.613913] Bluetooth: HCI UART protocol Intel registered
  7603    [    8.633245] hci_uart_bcm serial0-0: serial0-0 supply vbat not found, using dummy regulator
  7604    [    8.640769] hci_uart_bcm serial0-0: serial0-0 supply vddio not found, using dummy regulator
  7605    [    8.658992] Bluetooth: HCI UART protocol Broadcom registered
  7606    [    8.661584] Bluetooth: HCI UART protocol QCA registered
  7607    [    8.667927] Bluetooth: HCI UART protocol AG6XX registered
  7608    [    8.668026] Bluetooth: HCI UART protocol Marvell registered
  7609    [    8.706773] brcmfmac: F1 signature read @0x18000000=0x16034334
  7610    [    8.712346] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4334-sdio for chip BCM4334/3
  7611    [    8.720376] usbcore: registered new interface driver brcmfmac
  7612    [    8.755825] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.amlogic,p212.txt failed with error -2
  7613    [    8.767171] brcmfmac mmc2:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.txt failed with error -2
  7614    [    8.859229] usb 1-2: reset high-speed USB device number 3 using xhci-hcd
  7615    [    8.881999] mt7601u 1-2:1.0: ASIC revision: 76010001 MAC revision: 76010500
  7616    [    8.940600] mt7601u 1-2:1.0: EEPROM ver:0d fae:00
  7617    [    9.052103] Bluetooth: hci0: BCM: chip id 68
  7618    [    9.057452] Bluetooth: hci0: BCM: features 0x0f
  7619    [    9.062136] Bluetooth: hci0: BCM4334B0
  7620    [    9.065093] Bluetooth: hci0: BCM4334B0 (002.001.013) build 0000
  7621    [    9.069602] bluetooth hci0: Direct firmware load for brcm/BCM4334B0.hcd failed with error -2
  7622    [    9.078068] Bluetooth: hci0: BCM: Patch brcm/BCM4334B0.hcd not found
  7623    [    9.143693] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
  7624    [    9.144849] usbcore: registered new interface driver mt7601u
  7625    [    9.782968] brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x50
  7626    [    9.824533] zram: Added device: zram0
  7627    [    9.828286] zram: Added device: zram1
  7628    [    9.832429] zram: Added device: zram2
  7629    [    9.889835] zram1: detected capacity change from 0 to 912879616
  7630    [    9.953468] meson8b-dwmac c9410000.ethernet eth0: PHY [0.e40908ff:08] driver [Meson GXL Internal PHY]
  7631    [    9.978974] meson8b-dwmac c9410000.ethernet eth0: No Safety Features support found
  7632    [    9.983456] meson8b-dwmac c9410000.ethernet eth0: PTP not supported by HW
  7633    [    9.990268] meson8b-dwmac c9410000.ethernet eth0: configuring for phy/rmii link mode
  7634    [   10.525892] random: crng init done
  7635    [   10.528417] random: 7 urandom warning(s) missed due to ratelimiting
  7636    [   10.579111] Adding 891480k swap on /dev/zram1.  Priority:5 extents:1 across:891480k SSFS
  7637    [   12.010988] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
  7638    [   12.012929] Bluetooth: BNEP filters: protocol multicast
  7639    [   12.017913] Bluetooth: BNEP socket layer initialized
  7640    [   16.618148] wlan0: authenticate with 9c:9d:7e:12:20:57
  7641    [   16.641251] wlan0: send auth to 9c:9d:7e:12:20:57 (try 1/3)
  7642    [   16.645658] wlan0: authenticated
  7643    [   16.654900] wlan0: associate with 9c:9d:7e:12:20:57 (try 1/3)
  7644    [   16.660616] wlan0: RX AssocResp from 9c:9d:7e:12:20:57 (capab=0x431 status=0 aid=1)
  7645    [   16.691209] wlan0: associated
  7646    [   16.704876] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
  7647    [   25.824117] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
  7648    [   25.839727] Bridge firewalling registered
  7649    [   26.474524] Initializing XFRM netlink socket
  7650    [   31.925205] overlayfs: NFS export requires "index=on", falling back to nfs_export=off.
  7651    [   32.019283] overlayfs: NFS export requires "index=on", falling back to nfs_export=off.
  7652    [   32.114228] overlayfs: NFS export requires "index=on", falling back to nfs_export=off.
  7653    [   32.134956] docker0: port 1(veth1894119) entered blocking state
  7654    [   32.138249] docker0: port 1(veth1894119) entered disabled state
  7655    [   32.144653] device veth1894119 entered promiscuous mode
  7656    [   33.308448] eth0: renamed from vethe34d203
  7657    [   33.336113] IPv6: ADDRCONF(NETDEV_CHANGE): veth1894119: link becomes ready
  7658    [   33.340546] docker0: port 1(veth1894119) entered blocking state
  7659    [   33.346251] docker0: port 1(veth1894119) entered forwarding state
  7660    [   33.352618] IPv6: ADDRCONF(NETDEV_CHANGE): docker0: link becomes ready
  7661    [   38.394805] bpfilter: Loaded bpfilter_umh pid 2063
  7662    [   41.434092] tun: Universal TUN/TAP device driver, 1.6
  7663    [   42.514812] br-d68f2303413d: port 1(veth3debcfa) entered blocking state
  7664    [   42.518635] br-d68f2303413d: port 1(veth3debcfa) entered disabled state
  7665    [   42.526137] device veth3debcfa entered promiscuous mode
  7666    [   42.531619] br-d68f2303413d: port 1(veth3debcfa) entered blocking state
  7667    [   42.536951] br-d68f2303413d: port 1(veth3debcfa) entered forwarding state
  7668    [   42.544599] br-d68f2303413d: port 1(veth3debcfa) entered disabled state
  7669    [   42.574853] br-d68f2303413d: port 2(veth3566733) entered blocking state
  7670    [   42.578662] br-d68f2303413d: port 2(veth3566733) entered disabled state
  7671    [   42.587317] device veth3566733 entered promiscuous mode
  7672    [   42.599452] br-d68f2303413d: port 2(veth3566733) entered blocking state
  7673    [   42.602815] br-d68f2303413d: port 2(veth3566733) entered forwarding state
  7674    [   42.615682] br-d68f2303413d: port 2(veth3566733) entered disabled state
  7675    [   43.018085] supervisor0: port 1(veth3403f1d) entered blocking state
  7676    [   43.022805] supervisor0: port 1(veth3403f1d) entered disabled state
  7677    [   43.028285] device veth3403f1d entered promiscuous mode
  7678    [   43.033663] supervisor0: port 1(veth3403f1d) entered blocking state
  7679    [   43.038607] supervisor0: port 1(veth3403f1d) entered forwarding state
  7680    [   43.054968] supervisor0: port 1(veth3403f1d) entered disabled state
  7681    [   43.433693] kmem.limit_in_bytes is deprecated and will be removed. Please report your usecase to linux-mm@kvack.org if you depend on this functionality.
  7682    [   43.600375] eth0: renamed from vetha94a182
  7683    [   43.636031] br-d68f2303413d: port 1(veth3debcfa) entered blocking state
  7684    [   43.639202] br-d68f2303413d: port 1(veth3debcfa) entered forwarding state
  7685    [   43.868148] eth0: renamed from vethdf4e256
  7686    [   43.883792] br-d68f2303413d: port 2(veth3566733) entered blocking state
  7687    [   43.887005] br-d68f2303413d: port 2(veth3566733) entered forwarding state
  7688    [   43.948156] eth1: renamed from veth29cc8f6
  7689    [   43.975819] supervisor0: port 1(veth3403f1d) entered blocking state
  7690    [   43.978774] supervisor0: port 1(veth3403f1d) entered forwarding state
  7691    [   54.647169] br-d68f2303413d: port 3(veth636e024) entered blocking state
  7692    [   54.648322] br-d68f2303413d: port 3(veth636e024) entered disabled state
  7693    [   54.661000] device veth636e024 entered promiscuous mode
  7694    [   55.150516] rc rc0: two consecutive events of type space
  7695    [   55.307955] eth0: renamed from veth6a3199e
  7696    [   55.331578] br-d68f2303413d: port 3(veth636e024) entered blocking state
  7697    [   55.332695] br-d68f2303413d: port 3(veth636e024) entered forwarding state
  7698    [   55.846507] br-d68f2303413d: port 3(veth636e024) entered disabled state
  7699    [   55.848423] veth6a3199e: renamed from eth0
  7700    [   55.925856] br-d68f2303413d: port 3(veth636e024) entered disabled state
  7701    [   55.930603] device veth636e024 left promiscuous mode
  7702    [   55.931912] br-d68f2303413d: port 3(veth636e024) entered disabled state
  7703
  7704
  7705    vm.admin_reserve_kbytes = 8192
  7706    vm.block_dump = 0
  7707    vm.compact_unevictable_allowed = 1
  7708    vm.dirty_background_bytes = 0
  7709    vm.dirty_background_ratio = 10
  7710    vm.dirty_bytes = 0
  7711    vm.dirty_expire_centisecs = 3000
  7712    vm.dirty_ratio = 20
  7713    vm.dirtytime_expire_seconds = 43200
  7714    vm.dirty_writeback_centisecs = 500
  7715    vm.extfrag_threshold = 500
  7716    vm.hugetlb_shm_group = 0
  7717    vm.laptop_mode = 0
  7718    vm.legacy_va_layout = 0
  7719    vm.lowmem_reserve_ratio = 256    256    32    0
  7720    vm.max_map_count = 65530
  7721    vm.min_free_kbytes = 5274
  7722    vm.mmap_min_addr = 4096
  7723    vm.nr_hugepages = 0
  7724    vm.nr_overcommit_hugepages = 0
  7725    vm.oom_dump_tasks = 1
  7726    vm.oom_kill_allocating_task = 0
  7727    vm.overcommit_kbytes = 0
  7728    vm.overcommit_memory = 0
  7729    vm.overcommit_ratio = 50
  7730    vm.page-cluster = 0
  7731    vm.panic_on_oom = 0
  7732    vm.percpu_pagelist_fraction = 0
  7733    vm.stat_interval = 1
  7734    vm.swappiness = 100
  7735    vm.user_reserve_kbytes = 55250
  7736    vm.vfs_cache_pressure = 100
  7737    vm.watermark_boost_factor = 15000
  7738    vm.watermark_scale_factor = 10
  7739
  7740    ### interrupts:
  7741               CPU0       CPU1       CPU2       CPU3
  7742      3:      27903      29385      25279      27196     GICv2  30 Level     arch_timer
  7743      6:          0          0          0          0     GICv2 169 Level     arm-pmu
  7744      7:          0          0          0          0     GICv2 170 Level     arm-pmu
  7745      8:          0          0          0          0     GICv2 185 Level     arm-pmu
  7746      9:          0          0          0          0     GICv2 186 Level     arm-pmu
  7747     10:       1071          0          0          0     GICv2  58 Edge      ttyAML6
  7748     11:          5          0          0          0     GICv2 105 Edge      c1108680.adc
  7749     12:          0          0          0          0     GICv2 231 Edge      c8100100.cec
  7750     13:        115          0          0          0     GICv2 225 Edge      ttyAML0
  7751     14:          2          0          0          0     GICv2 228 Edge      c8100580.ir
  7752     15:          0          0          0          0     GICv2  76 Edge      vdec
  7753     16:          0          0          0          0     GICv2  64 Edge      esparserirq
  7754     18:         52          0          0          0     GICv2 241 Edge      platform_mhu_link
  7755     19:        649          0          0          0     GICv2 242 Edge      platform_mhu_link
  7756     20:          0          0          0          0     GICv2  40 Level     eth0
  7757     21:        721          0          0          0     GICv2 248 Edge      d0070000.mmc
  7758     22:      28879          0          0          0     GICv2 249 Edge      d0072000.mmc
  7759     23:       1592          0          0          0     GICv2 250 Edge      d0074000.mmc
  7760     25:          0          0          0          0     GICv2 192 Level     gp
  7761     26:          0          0          0          0     GICv2 193 Level     gpmmu
  7762     27:          0          0          0          0     GICv2 194 Level     pp_bcast
  7763     29:          0          0          0          0     GICv2 196 Level     pp0
  7764     30:          0          0          0          0     GICv2 197 Level     ppmmu0
  7765     31:          0          0          0          0     GICv2 198 Level     pp1
  7766     32:          0          0          0          0     GICv2 199 Level     ppmmu1
  7767     33:          0          0          0          0     GICv2 200 Level     pp2
  7768     34:          0          0          0          0     GICv2 201 Level     ppmmu2
  7769     35:       1032          0          0          0     GICv2  35 Edge      meson
  7770     36:          0          0          0          0     GICv2  89 Edge      dw_hdmi_top_irq, c883a000.hdmi-tx, dw-hdmi-cec
  7771     37:          0          0          0          0     GICv2 220 Edge      gxl-crypto
  7772     38:          0          0          0          0     GICv2 221 Edge      gxl-crypto
  7773     39:      24308          0          0          0     GICv2  62 Level     xhci-hcd:usb1
  7774     42:          0          0          0          0     GICv2  41 Level     0.e40908ff:08
  7775    IPI0:     17009      28626      28137      24270       Rescheduling interrupts
  7776    IPI1:       496        542        438        524       Function call interrupts
  7777    IPI2:         0          0          0          0       CPU stop interrupts
  7778    IPI3:         0          0          0          0       CPU stop (for crash dump) interrupts
  7779    IPI4:         0          0          0          0       Timer broadcast interrupts
  7780    IPI5:       403        205        148        138       IRQ work interrupts
  7781    IPI6:         0          0          0          0       CPU wake-up interrupts
  7782    Err:          0
Please upload the whole output above to an online pasteboard service
and provide the URL in the forum where you have been asked for this.
Ideas?
On 3/25/2021 at 4:54 PM, manuti said:
Another try usinf de DTS edit function inside 'armbian-config' same result:
.RAM is meant to be used. If you have a lot of free ram then you over built your system and wasted money. On windows 10 a fresh boot should consume around 30% of RAM. If you experience more ram usage in task manager this guide can help you to clear up some ram.
