hartraft Posted April 11, 2021 Share Posted April 11, 2021 I'm in the process of upgrading my network and with the Helios64 capable of 2.5 GbE, what are some people's switch recommendations? My needs aren't really too high so I think 5 ports should be enough until the rest of the infrastructure catches up in my home network. My short-list are: * QNAP QSW-1105-5T * TP Link TL-SG105-M2 * TRENDnet TEG-S350 Article from servethehome 0 Quote Link to comment Share on other sites More sharing options...
gprovost Posted April 12, 2021 Share Posted April 12, 2021 There are few more brands offering 5 ports 2.5GbE network switch. Most likely they are all based on the same exact network chip. 2.5GbE doesn't require any special high quality component, so my guess it's the build quality is more or less the same of all those models. So end of the day you are just buying the name among all those 5x port 2.5Gbe models. You could also consider maybe a switch with more ports even though some of them might only be 1Gbps. But if you don't have the need for more ports, then any model you listed will do the job. 0 Quote Link to comment Share on other sites More sharing options...
clostro Posted April 12, 2021 Share Posted April 12, 2021 I'm using Zyxel XGS1010-12. Has 8x1gbe, 2x2.5gbe, and 2x10gb sfp+ ports. Works ok, does what I need. 0 Quote Link to comment Share on other sites More sharing options...
retrack Posted April 12, 2021 Share Posted April 12, 2021 I have the Netgear MS510TXPP which has POE, 4 x 1Gbe, 2 x 2.5Gbe, 2 x 2.5/5Gbe, 1 x 2.5/5/10Gbe, 1 x 10 Gbe SFP Works well but is noisy for home environment, louder than the Helios64 or rather because of a small fan with a noise that is higher pitched so not great. It did negotiate 2.5Gbe with the Helios though. 0 Quote Link to comment Share on other sites More sharing options...
hartraft Posted April 12, 2021 Author Share Posted April 12, 2021 7 hours ago, retrack said: I have the Netgear MS510TXPP which has POE, 4 x 1Gbe, 2 x 2.5Gbe, 2 x 2.5/5Gbe, 1 x 2.5/5/10Gbe, 1 x 10 Gbe SFP Works well but is noisy for home environment, louder than the Helios64 or rather because of a small fan with a noise that is higher pitched so not great Thanks for that feedback, noise is something I would want to indeed avoid and I'm not ready to upgrade to 10Gbe (not enough devices). That's reassuring that between vendors there isn't anything to watch out for in particular, since these are mainly unmanaged switches there isn't really an interface to compare between them. I did see this on reddit though for the QNAP so just monitoring if there's other potential faults. But whatever I can easy source seems in the EU seems fine for my case. Thanks all! 0 Quote Link to comment Share on other sites More sharing options...
