Da Alchemist Posted August 11, 2016 Share Posted August 11, 2016 Today i wanted to try some changes an build a new kernel for my H3 PCPlus. When I executed compile.sh i got a Message that the script was outdated. So i copied a newer Version from lib to my root directory. I made thechanges i did before: Set KERNEL_Configure to "yes" and set DEST_LANG="de_DE.UTF-8" (that was the only way to get a clean translated german Desktop before..) Now I get a warning Message: [ warn ] Can't update since you made changes to: compile.sh When I hit Enter the next thing happens: The Toolchan is downloaded every time. Is this really necessary? I have only a volume based Internet connection... Regards Link to comment Share on other sites More sharing options...
wildcat_paris Posted August 11, 2016 Share Posted August 11, 2016 yes I have seen this recently but I have 500/200 FTTH (about toolchain) Link to comment Share on other sites More sharing options...
zador.blood.stained Posted August 11, 2016 Share Posted August 11, 2016 Today i wanted to try some changes an build a new kernel for my H3 PCPlus. When I executed compile.sh i got a Message that the script was outdated. So i copied a newer Version from lib to my root directory. I made thechanges i did before: Set KERNEL_Configure to "yes" and set DEST_LANG="de_DE.UTF-8" (that was the only way to get a clean translated german Desktop before..) Did you edit lib/compile.sh instead of a copy next to lib, sources and toolchains directory? Please delete lib directory and run compilation process again to download a fresh copy of build scripts, and in the future edit only copy of compile.sh The Toolchan is downloaded every time. Is this really necessary? I have only a volume based Internet connection... This process is not perfect, I'll try to add more logging to this process to catch the problem Link to comment Share on other sites More sharing options...
Da Alchemist Posted August 11, 2016 Author Share Posted August 11, 2016 I edited just a copy of compile.sh ( in the first post it should be: "So i copied a newer Version from the lib directory to my root directory", this is what is what the script warning told me to do..) Regards Link to comment Share on other sites More sharing options...
zador.blood.stained Posted August 11, 2016 Share Posted August 11, 2016 When I hit Enter the next thing happens: The Toolchan is downloaded every time. Is this really necessary? I have only a volume based Internet connection... This should be fixed now Link to comment Share on other sites More sharing options...
Da Alchemist Posted August 11, 2016 Author Share Posted August 11, 2016 This should be fixed now I am afraid it is not, i have deleted the lib directory and started from the beginning, i have compiled two kernels, both times the toolchain was downloaded... Link to comment Share on other sites More sharing options...
zador.blood.stained Posted August 11, 2016 Share Posted August 11, 2016 Please run the process again (I pushed an update to improve logging) and post here contents of output/debug/output.log Link to comment Share on other sites More sharing options...
Da Alchemist Posted August 11, 2016 Author Share Posted August 11, 2016 (edited) Here it is: Displaying message: Preparing host info Displaying message: Build host OS release trusty info Displaying message: Downloading toolchain gcc-linaro-arm-linux-gnueabihf-4.8-2014.04_linux info Displaying message: Verifying gpg: WARNUNG: Unsicheres Besitzverhältnis der Konfigurationsdatei `/home/ek/.gnupg/gpg.conf' gpg: error reading key: Öffentlicher Schlüssel nicht gefunden gpg: WARNUNG: Unsicheres Besitzverhältnis der Konfigurationsdatei `/home/ek/.gnupg/gpg.conf' gpg: Ausführen von externen Programmen ist ausgeschaltet, da die Dateirechte nicht sicher sind gpg: Schlüsselserver-Datenübertragunsfehler: Allgemeiner Fehler gpg: Empfangen vom Schlüsselserver fehlgeschlagen: Allgemeiner Fehler gpg: WARNUNG: Unsicheres Besitzverhältnis der Konfigurationsdatei `/home/ek/.gnupg/gpg.conf' gpg: Unterschrift vom Mi 16 Apr 2014 20:29:14 CEST mittels RSA-Schlüssel ID 8F427EAF gpg: Unterschrift kann nicht geprüft werden: Öffentlicher Schlüssel nicht gefunden Displaying message: Verification failed wrn ## BUILD CONFIGURATION Kernel configuration: Repository: https://github.com/igorpecovnik/linux Branch: sun8i Config file: linux-sun8i-default U-boot configuration: Repository: git://git.denx.de/u-boot.git Branch: v2016.07 Offset: 1 Size: 0 CPU configuration: 480000 - 1296000 with interactive 11.08.2016 20:24:50 Armbian 5.17 Orangepipc Debian default Build script version: 5bf1dfdd90068a9c88d3f9608b140267c0ef20a3 Displaying message: Starting Armbian build script @host info Displaying message: Compiling kernel orangepipc info Displaying message: Syncing clock host info Displaying message: source downloading @host info Displaying message: ... you have latest sources u-boot v2016.07 info Displaying message: ... you have latest sources linux-sun8i sun8i info Displaying message: ... you have latest sources sunxi-tools info Displaying message: ... you have latest sources sunxi-display-changer info Displaying message: Compiling sunxi tools @host & target info Displaying message: Cleaning u-boot/v2016.07 info Displaying message: Cleaning linux-sun8i/sun8i info Displaying message: Cleaning output/debs for orangepipc default info Displaying message: Started patching process for u-boot u-boot-default 2016.07 info Displaying message: Looking for user patches in userpatches/u-boot/u-boot-default info Displaying message: ... add-awsom-uboot.patch succeeded info Displaying message: ... add-cubieboard4.patch succeeded info Displaying message: ... add-emmc-orangepi.patch succeeded info Displaying message: ... cubieboard1.patch succeeded info Displaying message: ... h3-enable-power-led.patch succeeded info Displaying message: ... u-boot-02-support-cheap-mmc.patch succeeded info Displaying message: ... u-boot-99-add-missing-boards.patch succeeded info Displaying message: Compiling uboot 2016.07 info Displaying message: Compiler version arm-linux-gnueabihf-gcc 4.8 info Displaying message: Building deb linux-u-boot-orangepipc_5.17_armhf.deb info Displaying message: Started patching process for kernel sun8i-default 3.4.39 info Displaying message: Looking for user patches in userpatches/kernel/sun8i-default info Displaying message: ... 0001-Fix-compilation-problems-with-more-modern-version-of.patch succeeded info Displaying message: ... 0001-Fix-ump-build.patch succeeded info Displaying message: ... 0003-sunxi-mali-Add-Mali400-r3p0-driver-code-from-sunxi-3.patch succeeded info Displaying message: ... 0004-HACK-Make-Mali400-driver-work-on-H3.patch succeeded info Displaying message: ... 0006-sunxi-disp2-FBIO_WAITFORVSYNC-as-a-modifier-for-FBIO.patch succeeded info Displaying message: ... 0010-Import-GMAC_PHY_POWER-support-from-the-loboris-sourc.patch succeeded info Displaying message: ... 0011-gpu-drm-Add-Mali-DX910-SW-99002-r2p4-02rel1.patch succeeded info Displaying message: ... 0012-drm-mali-fix-for-3.4.patch succeeded info Displaying message: ... 0013-gpu-drm-mali_drv-fixed-integration-with-3.x-kernels-.patch succeeded info Displaying message: ... 0015-Fix-paths-to-files-in-src-erroneously-searched-for-i.patch succeeded info Displaying message: ... 0016-gcc5-fixes.patch succeeded info Displaying message: ... 0017-linux-sunxi-add-missing-compiler-gcc5.h-from-master.patch succeeded info Displaying message: ... 0018-orangepi_h3_gc2035_camera.patch succeeded info Displaying message: ... 0023-WIP-remove-vsync_task-from-sunxi-fb-driver.patch succeeded info Displaying message: ... 0024-pwm-sunxi-support-for-H3-as-appears-in-loboris-initi.patch succeeded info Displaying message: ... 0025-h3-hdmi-table-reformatting-for-readability-from-lobo.patch succeeded info Displaying message: ... 0026-h3-hdmi-additional-mode-800x480p-from-lobodis-initia.patch succeeded info Displaying message: ... 0027-h3-hdmi-HDMI_EDID-from-loboris-initial-source-import.patch succeeded info Displaying message: ... 02-0001-patch-3.4.39-40.patch succeeded info Displaying message: ... 02-0001-patch-3.4.40-41.patch succeeded info Displaying message: ... 02-0001-patch-3.4.41-42.patch succeeded info Displaying message: ... 02-0001-patch-3.4.42-43.patch succeeded info Displaying message: ... 02-0001-patch-3.4.43-44.patch succeeded info Displaying message: ... 02-0001-patch-3.4.44-45.patch succeeded info Displaying message: ... 02-0001-patch-3.4.45-46.patch succeeded info Displaying message: ... 02-0001-patch-3.4.46-47.patch succeeded info Displaying message: ... 02-0001-patch-3.4.47-48.patch succeeded info Displaying message: ... 02-0001-patch-3.4.48-49.patch succeeded info Displaying message: ... 02-0001-patch-3.4.49-50.patch succeeded info Displaying message: ... 02-0001-patch-3.4.50-51.patch succeeded info Displaying message: ... 02-0001-patch-3.4.51-52.patch succeeded info Displaying message: ... 02-0001-patch-3.4.52-53.patch succeeded info Displaying message: ... 02-0001-patch-3.4.53-54.patch succeeded info Displaying message: ... 02-0001-patch-3.4.54-55.patch succeeded info Displaying message: ... 02-0001-patch-3.4.55-56.patch succeeded info Displaying message: ... 02-0001-patch-3.4.56-57.patch succeeded info Displaying message: ... 02-0001-patch-3.4.57-58.patch succeeded info Displaying message: ... 02-0001-patch-3.4.58-59.patch succeeded info Displaying message: ... 02-0001-patch-3.4.59-60.patch succeeded info Displaying message: ... 02-0001-patch-3.4.60-61.patch succeeded info Displaying message: ... 02-0001-patch-3.4.61-62.patch succeeded info Displaying message: ... 02-0001-patch-3.4.62-63.patch succeeded info Displaying message: ... 02-0001-patch-3.4.63-64.patch succeeded info Displaying message: ... 02-0001-patch-3.4.64-65.patch succeeded info Displaying message: ... 02-0001-patch-3.4.65-66.patch succeeded info Displaying message: ... 02-0001-patch-3.4.66-67.patch succeeded info Displaying message: ... 02-0001-patch-3.4.67-68.patch succeeded info Displaying message: ... 02-0001-patch-3.4.68-69.patch succeeded info Displaying message: ... 02-0001-patch-3.4.69-70.patch succeeded info Displaying message: ... 02-0001-patch-3.4.70-71.patch succeeded info Displaying message: ... 02-0001-patch-3.4.71-72.patch succeeded info Displaying message: ... 02-0001-patch-3.4.72-73.patch succeeded info Displaying message: ... 02-0001-patch-3.4.73-74.patch succeeded info Displaying message: ... 02-0001-patch-3.4.74-75.patch succeeded info Displaying message: ... 02-0001-patch-3.4.75-76.patch succeeded info Displaying message: ... 02-0001-patch-3.4.76-77.patch succeeded info Displaying message: ... 02-0001-patch-3.4.77-78.patch succeeded info Displaying message: ... 02-0001-patch-3.4.78-79.patch succeeded info Displaying message: ... 02-0001-patch-3.4.79-80.patch succeeded info Displaying message: ... 02-0001-patch-3.4.80-81.patch succeeded info Displaying message: ... 02-0001-patch-3.4.81-82.patch succeeded info Displaying message: ... 02-0001-patch-3.4.82-83.patch succeeded info Displaying message: ... 02-0001-patch-3.4.83-84.patch succeeded info Displaying message: ... 02-0001-patch-3.4.84-85.patch succeeded info Displaying message: ... 02-0001-patch-3.4.85-86.patch succeeded info Displaying message: ... 02-0001-patch-3.4.86-87.patch succeeded info Displaying message: ... 02-0001-patch-3.4.87-88.patch succeeded info Displaying message: ... 02-0001-patch-3.4.88-89.patch succeeded info Displaying message: ... 02-0001-patch-3.4.89-90.patch succeeded info Displaying message: ... 02-0001-patch-3.4.90-91.patch succeeded info Displaying message: ... 02-0001-patch-3.4.91-92.patch succeeded info Displaying message: ... 02-0001-patch-3.4.92-93.patch succeeded info Displaying message: ... 02-0001-patch-3.4.93-94.patch succeeded info Displaying message: ... 02-0001-patch-3.4.94-95.patch succeeded info Displaying message: ... 02-0001-patch-3.4.95-96.patch succeeded info Displaying message: ... 02-0001-patch-3.4.96-97.patch succeeded info Displaying message: ... 02-0001-patch-3.4.97-98.patch succeeded info Displaying message: ... 02-0001-patch-3.4.98-99.patch succeeded info Displaying message: ... 02-0001-patch-3.4.99-100.patch succeeded info Displaying message: ... 02-0002-patch-3.4.100-101.patch succeeded info Displaying message: ... 02-0002-patch-3.4.101-102.patch succeeded info Displaying message: ... 02-0002-patch-3.4.102-103.patch succeeded info Displaying message: ... 02-0002-patch-3.4.103-104.patch succeeded info Displaying message: ... 02-0002-patch-3.4.104-105.patch succeeded info Displaying message: ... 02-0002-patch-3.4.105-106.patch succeeded info Displaying message: ... 02-0002-patch-3.4.106-107.patch succeeded info Displaying message: ... 02-0002-patch-3.4.107-108.patch succeeded info Displaying message: ... 02-0003-linux-sunxi-3.4.108-overlayfs.patch succeeded info Displaying message: ... 02-0004-patch-3.4.108-109.patch succeeded info Displaying message: ... 02-0004-patch-3.4.109-110.patch succeeded info Displaying message: ... 02-0004-patch-3.4.110-111.patch succeeded info Displaying message: ... 02-0004-patch-3.4.111-112.patch succeeded info Displaying message: ... 02-0005-backport-firmware-loader.patch succeeded info Displaying message: ... 02-0007-fbdev-fixes.patch.patch succeeded info Displaying message: ... 02-0008-backport-lirc-sunxi-driver.patch succeeded info Displaying message: ... 02-0009-unify-ethernet-settings.patch succeeded info Displaying message: ... 02-0010-export_read_current_timer.patch succeeded info Displaying message: ... 02-0011-fbtft_for_older.patch succeeded info Displaying message: ... 02-0013-w1_h3.patch succeeded info Displaying message: ... 02-0014-no_dev_console.patch succeeded info Displaying message: ... 02-0015-openelec-audio-and-video-fixes.patch succeeded info Displaying message: ... 02-rtl2832.patch succeeded info Displaying message: ... add_8189es_v4.3.18.1_15373.20151005.patch succeeded info Displaying message: ... add_8189fs_v4.3.24_15589.20151023.patch succeeded info Displaying message: ... bash_to_afterinstall.patch succeeded info Displaying message: ... cedar-remove-insecure-code.patch succeeded info Displaying message: ... cpufreq-add-more-frequencies.patch succeeded info Displaying message: ... enable_g_ether.patch succeeded info Displaying message: ... fix-kswapd.patch succeeded info Displaying message: ... linux-82-fix-build-on-non-amd64-hosts.patch succeeded info Displaying message: ... linux-88-enable-tv.patch succeeded info Displaying message: ... m2-plus-ap6212-wireless.patch succeeded info Displaying message: ... packaging-3.4.x-DEFAULT-with-postinstall-scripts.patch succeeded info Displaying message: ... remove-sunxi-debug.patch succeeded info Displaying message: ... sun8i-led-behaviour-through-fex.patch succeeded info Displaying message: ... sun8i-simple-cpu-corekeeper.patch succeeded info Displaying message: ... tbs5520.patch succeeded info Displaying message: ... wdt_reduce_logging.patch succeeded info Displaying message: ... z-0003-add-additional-video-modes.patch succeeded info Displaying message: Compiling default kernel 3.4.112 info Displaying message: Compiler version arm-linux-gnueabihf-gcc 4.8 info Displaying message: Using kernel config file lib/config/kernel/linux-sun8i-default.config info Displaying message: Kernel building done @host info Displaying message: Target directory /home/ek/output/debs/ info Displaying message: File name linux-image-sun8i_5.17_armhf.deb info Displaying message: Runtime 9 min info This time there was an update when i started compile.sh Edited August 11, 2016 by zador.blood.stained Added spoiler tags Link to comment Share on other sites More sharing options...
zador.blood.stained Posted August 11, 2016 Share Posted August 11, 2016 Displaying message: Build host OS release trusty info I think this is the main "problem". If you are using separate VM for working with Armbian, I would recommend upgrading to Xenial (or installing it from scratch) later, currently build script is tested only on Xenial. Since these toolchains are not needed on Trusty AFAIK, they won't be downloaded on Trusty in the future. 1 Link to comment Share on other sites More sharing options...
Da Alchemist Posted August 11, 2016 Author Share Posted August 11, 2016 I am using trusty on my Desktop and there is no reason for me to change to xenial at the moment. Regards 1 Link to comment Share on other sites More sharing options...
Da Alchemist Posted August 12, 2016 Author Share Posted August 12, 2016 So now it is working, thanks a lot. 2 Link to comment Share on other sites More sharing options...
borsti67 Posted August 15, 2016 Share Posted August 15, 2016 currently build script is tested only on Xenial. oops, I must have missed that - so the recommended build environment is Xenial now? Link to comment Share on other sites More sharing options...
zador.blood.stained Posted August 15, 2016 Share Posted August 15, 2016 oops, I must have missed that - so the recommended build environment is Xenial now? Yes. Building (especially u-boot and kernel packages) should still work in Trusty without issues, but some features (container environment detection and building desktop acceleration and some other packages) will work only in Xenial. 1 Link to comment Share on other sites More sharing options...
