Jerry Jyrer Posted May 11, 2021 Share Posted May 11, 2021 Armbianmonitor: http://ix.io/3mw6 I originally installed Armbian witk Kernel 4.4 on my Nanopi.m4 and later upgraded it to 5.10 via armbian-config. Things work fine but whenever I got a new update via apt update, things get messed up a bit the /boot/Image got linked to vmlinux-4.4.213-rk3399 instead of vmlinuz-5.10.35-rockchip64 while others uInitrd -> uInitrd-5.10.35-rockchip64 dtb -> dtb-5.10.35-rockchip64 The result's the board couldn't boot-up, when I restarted it. And, I need to correct the Image -> vmlinuz-5.10.35-rockchip64 and doing mkimage -C none -A arm -T script -d boot.cmd boot.scr from another linux machine to the SDCard. It works fine afterward but I wondered if there is the right way to fix this issue for good. Thank you, 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted May 12, 2021 Share Posted May 12, 2021 7 hours ago, Jerry Jyrer said: upgraded it to 5.10 via armbian-config. So you used the switch kernel feature, correct? 0 Quote Link to comment Share on other sites More sharing options...
Jerry Jyrer Posted May 12, 2021 Author Share Posted May 12, 2021 6 minutes ago, Werner said: So you used the switch kernel feature, correct? Yes, that is correct. 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted May 12, 2021 Share Posted May 12, 2021 Maybe there is an issue with switching to a different board family which is usually not the case 35 ii linux-dtb-current-rockchip64 21.05.1 arm64 Linux DTB, version 5.10.35-rockchip64 36 ii linux-dtb-legacy-rk3399 21.05.1 arm64 Linux DTB, version 4.4.213-rk3399 0 Quote Link to comment Share on other sites More sharing options...
Jerry Jyrer Posted May 12, 2021 Author Share Posted May 12, 2021 3 hours ago, Werner said: Maybe there is an issue with switching to a different board family which is usually not the case 35 ii linux-dtb-current-rockchip64 21.05.1 arm64 Linux DTB, version 5.10.35-rockchip64 36 ii linux-dtb-legacy-rk3399 21.05.1 arm64 Linux DTB, version 4.4.213-rk3399 From armbian-config -> System -> Other, here are the options I'm seeing linux-image-current-rockchip64=21.02. 5.10.21-rockchip64 … linux-image-dev-rockchip64=21.02.2 … 5.10.16-rockchip64 … linux-image-legacy-rk3399=21.05.1 … 4.4.213-rk3399 I don't see an option of rk3399 with 5.x kernel. Do you know which dtb it's for those with 5.x kernel from the Download page: https://www.armbian.com/nanopi-m4/#kernels-archive-all 0 Quote Link to comment Share on other sites More sharing options...
