NFS protocol not supported?
tony013
Hi,
I just updated my armbian current to 5.10.35 and I'm quite excited, as pwm and gpio works as with LE :)
Then I tried to mount some nfs-shares from nas. Usually I only have to install nfs-common.
I did that on armbian, but when I try to mount a share, I get the error message, that nfs protocol (version) is not supported.
The used command work on every other system I have (desktop and rockpi).
I just use 'nfs' as filesystem type - no version specified/requested.
Is there something special on armbian, to have nfs support enabled?
that is weird..
can you do the following
zgrep -i nfs /proc/config.gz
and also armbianmontor -u
what's your mount target.... for grins try added -o vers=3
For what it's worth, I've hit this error when trying to mount a NFS share from a Windows system (no idea how it was set up), and had to use NFS v2 for it to work.
Thank you all for your support!
vor 7 Stunden schrieb lanefu:
Oh, didn't know, that config is available that way (on my desktop debian it is not)
Here's the result:
CONFIG_USB_FUNCTIONFS=m
CONFIG_USB_FUNCTIONFS_ETH=y
CONFIG_USB_FUNCTIONFS_RNDIS=y
CONFIG_USB_FUNCTIONFS_GENERIC=y
CONFIG_XENFS=y
CONFIG_XEN_COMPAT_XENFS=y
CONFIG_KERNFS=y
CONFIG_NFS_FS=m
CONFIG_NFS_V2=m
CONFIG_NFS_V3=m
CONFIG_NFS_V3_ACL=y
CONFIG_NFS_V4=m
CONFIG_NFS_SWAP=y
CONFIG_NFS_V4_1=y
CONFIG_NFS_V4_2=y
CONFIG_PNFS_FILE_LAYOUT=m
CONFIG_PNFS_BLOCK=m
CONFIG_PNFS_FLEXFILE_LAYOUT=m
CONFIG_NFS_V4_1_IMPLEMENTATION_ID_DOMAIN="kernel.org"
CONFIG_NFS_V4_1_MIGRATION=y
CONFIG_NFS_V4_SECURITY_LABEL=y
CONFIG_NFS_FSCACHE=y
# CONFIG_NFS_USE_LEGACY_DNS is not set
CONFIG_NFS_USE_KERNEL_DNS=y
CONFIG_NFS_DEBUG=y
CONFIG_NFS_DISABLE_UDP_SUPPORT=y
CONFIG_NFS_V4_2_READ_PLUS=y
CONFIG_NFSD=m
CONFIG_NFSD_V2_ACL=y
CONFIG_NFSD_V3=y
CONFIG_NFSD_V3_ACL=y
CONFIG_NFSD_V4=y
CONFIG_NFSD_PNFS=y
CONFIG_NFSD_BLOCKLAYOUT=y
CONFIG_NFSD_SCSILAYOUT=y
CONFIG_NFSD_FLEXFILELAYOUT=y
# CONFIG_NFSD_V4_2_INTER_SSC is not set
CONFIG_NFSD_V4_SECURITY_LABEL=y
CONFIG_NFS_ACL_SUPPORT=m
CONFIG_NFS_COMMON=y
And this is "grep -i nfs /boot/config-5.10.0-0.bpo.3-amd64" from my desktop debian
CONFIG_XENFS=m
CONFIG_KERNFS=y
CONFIG_NFS_FS=m
CONFIG_NFS_V2=m
CONFIG_NFS_V3=m
CONFIG_NFS_V3_ACL=y
CONFIG_NFS_V4=m
CONFIG_NFS_SWAP=y
CONFIG_NFS_V4_1=y
CONFIG_NFS_V4_2=y
CONFIG_PNFS_BLOCK=m
# CONFIG_NFS_V4_1_MIGRATION is not set
CONFIG_NFS_DEBUG=y
# CONFIG_NFS_V4_2_READ_PLUS is not set
CONFIG_NFSD=m
CONFIG_NFSD_V3=y
CONFIG_NFSD_V4=y
CONFIG_NFSD_PNFS=y
# CONFIG_NFSD_SCSILAYOUT is not set
# CONFIG_NFSD_FLEXFILELAYOUT is not set
CONFIG_NFS_COMMON=y
I beg your pardon, but I'm too stupid for that tool.
I read a lot about it (in other threads), skimmed the docs for it, but I don't know, what to enter, when it asks for a target.
So if you tell me what output you want, I could deliver any on my own.
I know my debian well - as a user. Not as a developer.
vor einer Stunde schrieb tparys:
I don't have/use any windows systems. My PCs run all debian stable without any experiments.
Only with rockpi I started to use others and find a usable base ...
vor 3 Stunden schrieb lanefu:
I don't understand your question.
I have two rockpi sata towers, one runs armbian multimedia legacy with emmc and boot from usb-drive, the other (not assembled yet) is my testbox, where I can switch sdcards.
In this case, armbian multimedia legacy is the nfs server and armbian current was the client (target?)
Target?
armbianmontor -u will provide you with a link to a website where the debug logs have been pushed to. If your board is not connected to the internet or there are other issues it should tell you to use -U instead of -u to output everything to stdout so you can paste it somewhere else.
There are a number of issues with the numerous versions of nfs, locking, architecture and export path on server with nfsV4 ... and I wouldn't trust error messages.
For example "protocol not supported" can be emitted because of the share path semantic :
From : https://wiki.archlinux.org/title/NFS/Troubleshooting#mount.nfs:_Protocol_not_supported
mount.nfs: Protocol not supported
This error occurs when you include the export root in the path of the NFS source. For example:
# mount SERVER:/srv/nfs4/media /mnt mount.nfs4: Protocol not supported
Use the relative path instead:
# mount SERVER:/media /mnt
I have had some troubles in the past with export path and nfsV4 and it works at present although my configuration is not supposed to be correct ?!?
vor 10 Stunden schrieb Werner:
Thank you, Werner, for the explanation!
Patience is not my strong point. So I killed the program before it could tell me any link.
I thought, I have to enter some address or path ...
Being more patient, it works ;)
vor 14 Stunden schrieb lanefu:
does not change anything.
vor einer Stunde schrieb arox:
Hm, I do not want to use version 4, nor do i have an export root stored anywhere. Thus it is difficult for me to assign the error to this category.
anyway ...
... since the error only occurs when both server and client are running armbian, I had a suspicion.
So I started the client (armbian recent) with ssh connection to my main machine. When I then turned on the NAS, the ssh connection was interrupted with the following error message:
"Connection to ... port 22: Broken pipe"
When I then looked at the list of active machines, only the NAS was listed. The client (with armbian) was gone.
Could it be, that the MAC address is generated by the operating system and thus two different machines get the same MAC address?
That would explain a lot.
After some further research - it looks like armbian generates mac-address from cpuid - but rockpi has no cpuid ...
excerpt from ifconfig:
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
    link/ether 6e:e4:fe:d4:82:6d brd ff:ff:ff:ff:ff:ff
Is there a way to fake/set/overwrite static part from cpuid or cpuid ?
Hum  !
Is address 6e:e4:fe:d4:82:6d a valid mac-address ?
It seems to me that the first bit of first octet shouln't be 1 because it is reserved to multicast addresses.
https://communities.vmware.com/t5/VMware-Fusion-Discussions/The-first-byte-of-the-MAC-address-cannot-bit-odd/td-p/1218107
7 minutes ago, arox said:
Hum  !
Sorry, my mistake, 6e is odd !!!
Sorry, it is even so first bit 0. I go to bed ...
vor 2 Minuten schrieb arox:
6e is odd !!!
I don't think, that my dhcp-server does validate the mac-address. I guess, it takes the number as is and uses it as token ...
anyway: looks like I found the problem.
I guess, any linux has some individual hardcoded portion ...
this is output from twisteros:
 eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
	    link/ether ea:69:c3:92:45:fc brd ff:ff:ff:ff:ff:ff
its different to armbian native - but also constant - so two boxes with twister would fail too
Hi,
having identified the evil, I found lots of postings about this issue.
Unfortunately the given workarounds don't work.
  • setting ethaddr in /boot/armbianEnv.txt does not change anything
  • same with modifying /etc/network/interfaces - no effect.
What worked with armbian current (kernel 5.10.35) is changing configuration of Network-Manager.
That configuration can be found at /etc/Networkmanager/system-connections
I have a file-entry like this: 'Wired connection 1.nmconnection'. Format is common ini-file format of linux.
There's a group called [ethernet], which contains an entry "cloned-mac-address", which gets used on every  reboot.
Changing that number, changes mac-address and for so the address received from dhcp server.
@developers
As there are so many postings regarding this issue, what about adding a "network" section to "Troubleshooting" of armbian documentation?
This sets a u-boot environment variable. It is up to the boot script used for your board whether or not anything is done with it. What boot script you're using is a mystery as you've not provided any information about your board (armbianmonitor -u).
Per "man 5 interfaces", the option is "hwaddress". Whether or not this takes effect is determined by what network software is running (NetworkManager or ifupdown). Given that poking NetworkManager files created a change, it's probably the former.
> Just for sake of documentation: setting mac address in /etc/network/interfaces works on TwisterOS
And it's probably using ifupdown. You can switch if you'd like. I bet it works on Armbian too, but you need to be running it first.
$ sudo systemctl stop NetworkManager
$ sudo systemctl disable NetworkManager
$ sudo systemctl start networking
$ sudo systemctl enable networking
vor 5 Stunden schrieb tparys:
Just wanted to upload that information for you, but ...
root@rockpi-4a:~# armbianmonitor -u
System diagnosis information will now be uploaded to Please post the URL in the forum where you've been asked for.
root@rockpi-4a:~# ping armbian.com
PING armbian.com(stuff.armbian.com (2605:7900:20::5)) 56 data bytes
64 bytes from stuff.armbian.com (2605:7900:20::5): icmp_seq=1 ttl=51 time=166 ms
64 bytes from stuff.armbian.com (2605:7900:20::5): icmp_seq=2 ttl=51 time=164 ms
64 bytes from stuff.armbian.com (2605:7900:20::5): icmp_seq=3 ttl=51 time=164 ms
^C
--- armbian.com ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 5ms
rtt min/avg/max/mdev = 164.301/164.886/166.041/0.816 ms
So - its not only for being impatient, the tool seems not to work as it should - or I'm stil to dumb to use it. The ping is just to proove, that I have internet access enabled.
I attached the output to this post
That's not the question.
As a common user, you won't care which tool provides network support as long as the network works. So I guess, its not common to know about these options.
Having a problem - you search around and most (at least what I did) was trial and error.
Therefore I would have been happy to find a network section in armbian documentation which lists the issues or links to related forum discussions.
by the way: mac-address of Network-manager is established very late in boot process, so wrong ip-address with all that conflicts will stil happen. So mac-address by Network-manager is just a poor workaround, no final solution!
Don't know, where the information is collected from, armbianmonitor does not show the final mac address ...
rockpi-4a.armbianmonitor1.7z
We used to mitigate random MAC problem (many drivers in the past were unable to read it from some unique hw id) with this script, which runs only once. Our primate network tool is Network manager with functional backing via ifupdown while it is difficult to have one system that is good for all. Then there is also a networkd type of networking which was recently added, but I agree we lack proper documentation for all this. I general this network mess should be cleaned, make a clear choice of which to use (build and run time) and make a proper documentation. Perhaps we have already open a Jira for that, if not, someone has to add it. Then someone, who we lack the most, has to find the time to do something about ...
But also I have to mention that generall policy about networking is / was: once board boots up with a working networking - which can be sometimes challenging due to the changing upstream kernel 1 2 3 4 5 ...  - our job is done. Optionally we try to secure its MAC doesn't go random. Nothing more than that. How you will set IP, VLAN, VPN, whatever ... its in users domain. We are not doing to cover in documentation since Armbian is Debian based and it all Debian/Ubuntu how-to should work. Yes, this policy can be improved with additional resources.
Isn't it only important that MAC is set before talking to the DHCP server.
The tool relies on 3rd party paste infrastructure. We had even more problems in the past, so we were thinking to move into our infrastructure - I think we even have it, but don't use. This would give us more control and I could answer you to this questions. Now I have no idea why its not working for you. I tried on my random armbian machine and it works for me. For example, you can check this testing report, which runs various of tests on the hardware and adds armbianmonitor for each board - check "report" column.
A choice for Network manager lies in simpler usage for its users. UX is far superior then ifupdown and its one tool that covers CLI and desktop at the same time. Surely its technically not the most bullet proof system, but we have been with almost since the start. Its pro points wins over its con. Ifupdown (which is mainly deprecated) should take over if IP settings are added. If not, then its a bug. If MAC is not taken, its bug again and could be tied to the network driver itself. (speaking generally - i don't know for this specific case)
16 hours ago, tony013 said:
@developers
<rant>
FYI. IMHO there are about 1/1000 of needed resources which listen to this forum and follow up on ideas that pops up :( Some ideas are important, some not, some simple, some difficult - projects for months if not years. And most of that kind of projects are close to impossible to start with the resources we have, without funding / serious full timers. All people that contribute are already busy (over the top), there are tasks - we have select as something that is realistic to finish - that waits for months to be addressed. Also it is hard to motivate newcomers to join and do this (sometimes very hard) work and mainly in exchange for eternal fame. They are not much interested even in selection of easy tasks. People just want to have professional support and professional software without giving anything for.
</rant>
vor 13 Minuten schrieb Igor:
Well, I would be willing to write some docs, but ...
1. - I guess, I need some permission to do so
2. - I'm absolutely not qualified to talk about network or system internals
... but if that's ok, I could write about my experience
vor 15 Minuten schrieb Igor:
That's the point - I suspect (can't proove it, its only like a feeling), that DHCP server responds to armbians mac address before using "my" mac-address. When I try to access internet right after connecting with ssh to rockpi, I have no permission to do so.
Waiting a few seconds, the ssh-connection breaks.
At reconnect, ssh rants about suspicious address entry. I accept that warning by writing "yes" and ssh-connections is established second time. This time internet access works fine.
When I'm to lazy in starting ssh-connection, the above will not happen.
vor 22 Minuten schrieb Igor:
Everything you know is easy - the rest is hard stuff
vor 23 Minuten schrieb Igor:
<rant>
I appreciate your rants, as they show the other side of the game ...
vor 24 Minuten schrieb Igor:
Well, that's not true for everybody.
I'm willing to learn and do the job on my own, but I've almost no glue about it. So I need a helping hand, some pushes into the right direction, whatever helps.
I don't expect others to solve my problem.
I don't know, what's a resonable way of living together. I'm just a user and I wasn't able to compile armbian on my own (following your documentation). I know, my questions are steeling your time - but what can I give back?
You can count my experience with rockpi in hours - not in years.
If you know around Github:
https://github.com/armbian/documentation
https://github.com/armbian/documentation/tree/master/docs
also via direct links on https://docs.armbian.com/
If this is not a technical manual style that would fit into general docs, then this subforum is a proper place: https://forum.armbian.com/forum/40-reviews-tutorials-hardware-hacks/
Can't say anything without research ... but currently I barely found time to read a few forum topics this week ... it could be something new that we don't know about. I'll try to recreate what you are saying during next week if possible. Perhaps someone else will.
Good one :thumbup:
Ofc not.
Anything that helps - fixing trouble / growing the project. We have many open tickets, we would like to solve, but we can't follow. Not everyone are technical difficult. But also other non technical skills are helpful - running projects, coordinating / editing internal content production, help moderatring forum, ...
And ofc any area from Jira / "Help wanted" section. Some tasks are trivial - just to break the ice. Improving - how to join UX - is again something important to be done.
Even I would like to help, I am also busy like hell those days. Whenever someone shows interest to help on our common troubles, we help how we can. Sometimes the problem people find aligns with our priorities, sometimes it doesn't and we can't do much right spot on. Best effort.
You have, seems like a lots of general Linux userland experiences and that is what can help us. If trouble is hw related, we have some know-how, "just" time is needed ...
vor 14 Stunden schrieb Igor:
Ok, I created my first pull-request with a network section in troubleshooting guide.
With Jira - I don't know, seems not to work. I read, that communication about a topic should happen in Jira, so I created an account. But probably you have to grant me some permissions to enable participating ...
So how should I start with Jira topics? For example, AR-735 is a topic, that sounds interesting. I use that pwm overlay on armbian as well as patches at LE ...
What needs to be done?
by the way: we're quite off topic already. Where's the right place for this kind of questions?
