Problem: TvHeadEnd DVB-C scanning (Unitymedia/Vodafone) stays at 89%
Lelo
Hello.
After my provider (Unitymedia/Vodafone  NRW/Germany) asked to run a complete new station search my installation stopped
working for me:Stations were missing, EPG-infos not displayed anymore. So I decided to make a hole new installation.
The DVB-USB stick was detected fine again (see picture), the configuration wizard is executed step by step, the scan process starts -
but stays at 89%, even after 3 hours (see picture). If I stop ithe process, several stations are missing, the EPG-info is missing in wide
parts of the stations and the EPG-search is not working at all..
Hardware:
- BananapiPro (1GB, LAN 1GBit, SATA with 128GB SDD)
- ASTROMETA DVB-T2 (RTL2832)
Software:
Armbian_20.02.1_Bananapipro_bionic_current_5.4.20 (oldest listed in Archive)
 ---> sudo apt-add-repository ppa:mamarley/tvheadend-git
 ---> sudo apt update && sudo apt install tvheadend
 ---> Successfully installed "HTS Tvheadend 4.3.0~pre+202105051438-0~built202105060457~git637844055~ubuntu18.04.1"
A hardware defect seems to me excluded, since the stick works fine under Windows 10 (with AltDVB v2.4_B5488 and
DVBViewer Pro 7.1.0.0 each 472 channels, station search took ~15 Minutes).
I look forward to the decisive hint from you to solve my problem.
Cheers, Lelo.
PS:Unfortunately, I can not successfully register in the forum of TvHeadend:
- I got an Activation-mail, clicked on it, entered User & PW ---> Allegedly wrong.
- Request PW reset, followed the link, entered a new PQ twice successfully ---> User or PW allegedly wrong.
---> Does anyone know who and how to contact for such problems?
yeah the admin of that forum ;)
and you got 423 channels
and tvheadend is fun there is a wiki a manual and a lot of info how it works
the wizard is just to get it working , and then you have to tune it to your desires
map the services to channels
has the option check mux changes to be enabled or not etc,etc
and epg is not that fast and works when you have it setup .
just check what the mux is to start to scan to get a mux list  , is the provider id right ,is there a encryption involved , etc etc
