wifi not working on banana m1+ & latest debian
phier
Hi,
after login the error>
RX today:      Error: Unable to read database "/var/lib/vnstat/wlan0": No such file or directory Merge "eth0+wlan0" failed.
When i try to connect to WIFI network via armbain-configure -> WIFI ; network selected + password provided I got error>
Passwords or encryption keys are required to access the      │
         │ wireless network 'OpenWrt'.
second / third try>
Could not activate connection:  │       │
                │ │   │ Activation failed: Secrets were │       │
                │ │   │ required, but not provided
root@bananapi:~# cat /var/lib/vnstat
cat: /var/lib/vnstat: Is a directory
root@bananapi:~# iwconfig
wlan0     IEEE 802.11  ESSID:off/any
          Mode:Managed  Access Point: Not-Associated   Tx-Power=31 dBm
          Retry short limit:7   RTS thr:off   Fragment thr:off
          Encryption key:off
          Power Management:off
I can connect to router1 (generic box from provider) wpa-psk but I cant connect to router2 running openwrt 2.4ghz  channel 9... wpa2-psk
Somone had same issue - no one cared....
journalctl -xe
Jun 17 15:56:17 bananapi NetworkManager[1259]: <info>  [1623945377.8507] device
(wlan0): supplicant interface state: scanning -> associating
Jun 17 15:56:18 bananapi wpa_supplicant[1246]: wlan0: CTRL-EVENT-ASSOC-REJECT bs
sid=00:00:00:00:00:00 status_code=16
Jun 17 15:56:18 bananapi wpa_supplicant[1246]: wlan0: CTRL-EVENT-SSID-TEMP-DISAB
LED id=0 ssid="OpenWrt" auth_failures=2 duration=20 reason=CONN_FAILED
Jun 17 15:56:18 bananapi NetworkManager[1259]: <info>  [1623945378.5012] device
(wlan0): supplicant interface state: associating -> disconnected
Jun 17 15:56:28 bananapi NetworkManager[1259]: <info>  [1623945388.6097] device
(wlan0): supplicant interface state: disconnected -> scanning
Jun 17 15:56:30 bananapi NetworkManager[1259]: <warn>  [1623945390.4327] device
(wlan0): Activation: (wifi) association took too long
Jun 17 15:56:30 bananapi NetworkManager[1259]: <info>  [1623945390.4367] device
(wlan0): state change: config -> failed (reason 'no-secrets', sys-iface-state: '
managed')
Jun 17 15:56:30 bananapi NetworkManager[1259]: <warn>  [1623945390.4442] device
(wlan0): Activation: failed for connection 'OpenWrt'
Jun 17 15:56:30 bananapi NetworkManager[1259]: <info>  [1623945390.4482] device
(wlan0): state change: failed -> disconnected (reason 'none', sys-iface-state: '
managed')
Jun 17 15:56:31 bananapi NetworkManager[1259]: <info>  [1623945391.2775] device
(wlan0): supplicant interface state: scanning -> disconnected
 systemctl status  wpa_supplicant
Jun 17 16:21:45 bananapi systemd[1]: Starting WPA supplicant...
Jun 17 16:21:45 bananapi wpa_supplicant[3821]: Successfully initialized wpa_supplicant
Jun 17 16:21:45 bananapi systemd[1]: Started WPA supplicant.
Jun 17 16:21:47 bananapi wpa_supplicant[3821]: Failed to create interface p2p-dev-wlan0: -5 (Input/output error)
Jun 17 16:21:47 bananapi wpa_supplicant[3821]: nl80211: Failed to create a P2P Device interface p2p-dev-wlan0
Jun 17 16:21:47 bananapi wpa_supplicant[3821]: P2P: Failed to enable P2P Device interface
journalctl -xe
-- The job identifier is 1102.
Jun 17 16:21:45 bananapi nm-dispatcher[3823]: req:1 'down' [wlan0]: new request (3 scripts)
Jun 17 16:21:45 bananapi nm-dispatcher[3823]: req:1 'down' [wlan0]: start running ordered scripts...
Jun 17 16:21:47 bananapi kernel: ieee80211 phy0: brcmf_p2p_create_p2pdev: timeout occurred
Jun 17 16:21:47 bananapi kernel: ieee80211 phy0: brcmf_cfg80211_add_iface: add iface p2p-dev-wlan0 type 10 failed: err=-5
Jun 17 16:21:47 bananapi NetworkManager[1259]: <info>  [1623946907.2591] sup-iface[0xa32608,wlan0]: supports 5 scan SSIDs
Jun 17 16:21:47 bananapi NetworkManager[1259]: <info>  [1623946907.2686] device (wlan0): supplicant interface state: starting -> ready
Jun 17 16:21:47 bananapi NetworkManager[1259]: <info>  [1623946907.2690] device (wlan0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface
Jun 17 16:21:48 bananapi nm-dispatcher[3823]: Eth0 Eth0stat 2 2
IN-USE  SSID          MODE   CHAN  RATE        SIGNAL  BARS  SECURITY
        router2         Infra  9     260 Mbit/s  97      ****  WPA2
        router1         Infra  2     130 Mbit/s  80      ***   WPA1 WPA2
Have you done apt update and upgrade? Bug was already fixed and pushed out, but ofc this can't be fixed on already published binaries. Which are usually changed only at major releases.
yes apt update && upgrade
but apparently  Error: Unable to read database "/var/lib/vnstat/wlan0": No such file or directory Merge "eth0+wlan0" failed.  is another bug as the one i reported ie its not connecting to the AP using WPA2
That is probably related to the ampak firmware / chip revision mess. Which we will not even try to fix.
I dont think so, when i was running OS Bananian it worked fine and i was able connect to the same AP via WPA2
on latest ubuntu it does >
               │ │   st│ Activation failed: The Wi-Fi   │         │
               │ │   RE│ network could not be found
15 minutes ago, phier said:
I dont think so
Referencing to Bananian has zero value and we are totally fine if it works there, but not here. It's the same as referencing to some random years old Armbian build, where this, I am 100% sure, worked well - up to some point. Why it doesn't work anymore? Without spending few hours, which is not possible to happen, not possible to know.
Also something tells me you might not be using latest kernel (you have to provide logs each time you want to discuss something like that - not logs you think are enough) - due to other issues - which means you could run into random error, related to wireless subsystem, which was fixed upstream weeks after. Linux kernel is a messy thing and nobody will waste time to fix problems in some older versions / builds. Not even for (good) money.
1769]: Failed to create interface p2p-dev-wlan0: -5 (Input/output error)
1769]: nl80211: Failed to create a P2P Device interface p2p-dev-wlan0
1769]: P2P: Failed to enable P2P Device interface
1769]: dbus: fill_dict_with_properties dbus_interface=fi.w1.wpa_supplicant1.Int>
1769]: wlan0: Trying to associate with SSID 'OpenWrt'
1769]: wlan0: WPA: Failed to select authenticated key management type
1769]: wlan0: WPA: Failed to set WPA key management and encryption suites
root@bananapi:~# armbianmonitor -u
System diagnosis information will now be uploaded to unterminated quoted string at or near "'\x0a232323204163746976617465642031206c7a6f2d726c65207a72616d20737761702064657669636573207769746820343938204d4220656163680a0a232323204163746976617465642041726d6269616e2072616d6c6f6720706172746974696f6e2077697468207a73746420636f6d7072657373696f6e0a0a53756e203133204a756e20323032312030363a31373a333220504d20555443207c2042616e616e61205069207c'
073797374656d645b315d3a204c697374656e696e6"
LINE 7:                 '\x0a232323204163746976617465642031206c7a6f2...
Please post the URL in the forum where you've been asked for.
:) broken also hah
Second try >
System diagnosis information will now be uploaded to http://ix.io/3qg3
And i am going to try it with kernel 5.10.
  • Igor locked this topic
