command time : missing --help and other options
Marcation
Go to solution Solved by arox,
  • Solution
"time" is "built in" into the shell.
In order to use the full version described by "man", you should first install the full version in /usr/bin/time :
# apt-get install time.
And call it with the full path.
Also, when man fail to give doc because a package is missing, just google "man cmd".
Thanks to arox and my bad : I was trying to use some full version's option in the built in version of time.
No need to install time, it's done in armbian, just give the full path\command :
root@Bpi2+:~# time -f
-f: command not found
real 0m0,484s
user 0m0,396s
sys 0m0,089s
root@Bpi2+:~# which time
/usr/bin/time
root@Bpi2+:~# /usr/bin/time -f
/usr/bin/time: option requires an argument -- 'f'
Usage: /usr/bin/time [-apvV] [-f format] [-o file] [--append] [--verbose]
       [--portability] [--format=format] [--output=file] [--version]
       [--quiet] [--help] command [arg...]
root@Bpi2+:~# /usr/bin/time -f "%E" curl www.orange.fr
0:00.27
In such case type "type time" and the shell will inform you (is a shell keyword").
Thank You again I wanted to script some test and collect the results and this format is useful for this.
My next step is to remove the ':' in the output (is not trivial to combine 'time' and pipe without writing the output in a file, may be I have to try something else).
Be patient I can only write one post/day....
It's nice to have so small SBC and so large facilities and community.  Thank You Armbian !
@Werner & @Igor Thank You for replying (maybe too fast ?) but You are wrong when You think that I did'nt red the man pages ... it was more complex.
In shell, pipes and awk are your bests friends : perhaps something like this :
$ mkfifo /tmp/timefifo
$ awk -W interactive -F: '{printf("cmd=%s s=%f\n", $1, $2*60+$3)}' <>/tmp/timefifo > /tmp/stats &
$ /usr/bin/time -o /tmp/timefifo -f "%C:%E" ls -l
$ /usr/bin/time -o /tmp/timefifo -f "%C:%E" who
$ cat /tmp/stats
cmd=ls -l s=0.700000
cmd=ls s=0.070000
cmd=who s=0.000000
$ killall awk
N.B.  : <> open the pipe in read/wite mode to prevent it to be closed when "time" send EOF.
I have tested the mamed pipe thru three small scripts :
=> the first one is called by snmpcd (snmp formating)
echo .1.3.6.1.2.1.25.1.8.0
echo Gauge32
bash /usr/bin/local/secondscript
=> the secondscript with awk and named pipe :
FIFO="/tmp/timefifo"
[[ -e $FIFO ]] &&  rm $FIFO    # if present then suppress it
mkfifo $FIFO
awk -W interactive '{printf("%-6d \n", $1*1000)}' <> $FIFO > /tmp/stats &
/usr/bin/time -o $FIFO -f "%e" /usr/bin/thirdscript
cat /tmp/stats
killall awk
=> the third script :define the operation You want to know the during :
URL="example.html"
for i in `seq 1 20`;
do
         curl $URL > /dev/null 2>&1
done
********   It works, but there is a more simple solution
echo Gauge32
before=$(date +%s%N)
curl http://example.html > /dev/null 2>/dev/null
after=$(date +%s%N)
echo $((((after-before))/1000))
********** result in microsecond
On 6/22/2021 at 5:33 AM, Werner said:
Often the best solutions are the simplest ;)
"called by snmpcd (snmp formating)"
As you and Werner say : the best solutions are often the simplest. The problem is to find what is really the simplest and to make the difference between simple and basic in a use case.
(This is just a bit of general thinking (and nostalgy), as I have no idea about what you are working on).
The **simple** network management protocol is surely basic but I never found it was simple and it has been a long time since I saw someone care about it.
One more time, this is just general thinking, but I feel we use today a lot of complicated but no so powerful technologies in IT. Linux is a unix derivative, UNix  has been designed by people who wanted a simple but powerful system after having worked on MULTix.
I try to keep that in mind. But it is not always easy and cannot be achieve if we want our computers to also toast bread and do the laundry.
