Anyone has any idea why the Orange Pi Zero +2 H3 keep overheating?
Josephjo
### Current system health:
Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU  C.St.
05:45:33:  816MHz  6.10  95%  23%  71%   0%   0%   0% 95.9°C  6/8
05:45:41:  816MHz  6.16  99%  23%  76%   0%   0%   0% 95.7°C  6/8
05:45:48:  816MHz  6.23  99%  24%  75%   0%   0%   0% 95.9°C  6/8
05:45:54:  816MHz  6.35  99%  23%  76%   0%   0%   0% 95.8°C  6/8
05:46:02:  816MHz  6.40  99%  23%  75%   0%   0%   0% 96.4°C  6/8
05:46:14:  816MHz  6.41  96%  23%  72%   0%   0%   0% 96.3°C  6/8
05:46:22:  816MHz  6.50  99%  22%  76%   0%   0%   0% 96.9°C  6/8
05:46:27:  816MHz  6.50  99%  23%  76%   0%   0%   0% 97.0°C  6/8
05:46:32:  816MHz  6.50 100%  25%  73%   0%   0%   0% 97.1°C  6/8
05:46:41:  816MHz  6.50  99%  23%  76%   0%   0%   0% 97.5°C  6/8
Some process put heavy load onto it. Without at least passive cooling it surely dies.
Does this happen too if you start over with a clean image fromhttps://www.armbian.com/download/  ?
Wonder what it is, I was using nmcli and some codes. I will check my codes. Anyway i tried a heat sink doesn't exactly helps alot,
NowI put a heat sink and a small fan on it. It cools it down.
