NormanT Posted July 9, 2021 Share Posted July 9, 2021 Is anyone having issues with the Cinnamon desktop version restarting the desktop when using the menu app launcher? Can be repeated by launching with super key and typing anything for search or just launching any application. Happens with all 3 major menu app launchers. menu, cinnamenu and cinnstark Pinebook pro 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted July 10, 2021 Share Posted July 10, 2021 Your issue report is not a valid bug report per the Armbian bug reporting instructions (https://www.armbian.com/bugs). With limited resources the Armbian project is only able to spend time on issues where all the requested information has been provided and for only the boards/images/software that are supported. Your report is invalid for one or more of the following reasons (non-exhaustive list): it is for an unsupported board or image (CSC/EOS/WIP/edge) it is for software that is not supported (such as userspace modules installed on top of the core operating system) it has been logged in the wrong forum (for example requests for help that are not actual bug reports) it lacks requested data (armbianmonitor output) it could have been easily solved by a quick search and/or reading documentation Please review what you have submitted and the bug logging instructions (https://www.armbian.com/bugs) and either add the required information or open a new topic in the correct forum (such as Common issues / peer to peer technical support or General chit chat) 0 Quote Link to comment Share on other sites More sharing options...
NormanT Posted July 10, 2021 Author Share Posted July 10, 2021 10 hours ago, Werner said: Your issue report is not a valid bug report per the Armbian bug reporting instructions (https://www.armbian.com/bugs). With limited resources the Armbian project is only able to spend time on issues where all the requested information has been provided and for only the boards/images/software that are supported. Your report is invalid for one or more of the following reasons (non-exhaustive list): it is for an unsupported board or image (CSC/EOS/WIP/edge) it is for software that is not supported (such as userspace modules installed on top of the core operating system) it has been logged in the wrong forum (for example requests for help that are not actual bug reports) it lacks requested data (armbianmonitor output) it could have been easily solved by a quick search and/or reading documentation Please review what you have submitted and the bug logging instructions (https://www.armbian.com/bugs) and either add the required information or open a new topic in the correct forum (such as Common issues / peer to peer technical support or General chit chat) I wasn't submitting a bug. I was just asking a question of the community if they were experiencing something similar to determine if it was just my config or a bigger issue. Clearly it's a bigger issue based on the replies in this thread. 0 Quote Link to comment Share on other sites More sharing options...
NormanT Posted July 10, 2021 Author Share Posted July 10, 2021 12 hours ago, Rich Neese said: the version you are running is mosy likly the 4.4 and we have updated to 4.9 . I hope to have a new nightly build for you to test. as in 4.8 this but is fixed Yes. The current version installed after updates is Cinnamon 4.4.8. 0 Quote Link to comment Share on other sites More sharing options...
