odroidhc4 with 5.13.9-meson64, missing ZFS modules
ChrisO
Hi
I have Odroidhc4 with the following kernel:
root@odroidhc4:/opt# uname -a
Linux odroidhc4 5.13.9-meson64 #trunk.114 SMP PREEMPT Mon Aug 9 01:19:39 UTC 2021 aarch64 aarch64 aarch64 GNU/Linux
Installed from:
Armbian_21.08.0-trunk.116_Odroidhc4_hirsute_edge_5.13.9.img
And I'm missing ZFS modules.
root@odroidhc4:/opt# dpkg -L linux-modules-5.11.0-25-generic | grep zfs
/lib/modules/5.11.0-25-generic/kernel/zfs
/lib/modules/5.11.0-25-generic/kernel/zfs/icp.ko
/lib/modules/5.11.0-25-generic/kernel/zfs/spl.ko
/lib/modules/5.11.0-25-generic/kernel/zfs/zavl.ko
/lib/modules/5.11.0-25-generic/kernel/zfs/zcommon.ko
/lib/modules/5.11.0-25-generic/kernel/zfs/zfs.ko
/lib/modules/5.11.0-25-generic/kernel/zfs/zlua.ko
/lib/modules/5.11.0-25-generic/kernel/zfs/znvpair.ko
/lib/modules/5.11.0-25-generic/kernel/zfs/zunicode.ko
/lib/modules/5.11.0-25-generic/kernel/zfs/zzstd.ko
root@odroidhc4:/opt# apt-cache search linux-modules-5.13
root@odroidhc4:/opt# dpkg -l | grep linux-modules
ii  linux-modules-5.11.0-25-generic    5.11.0-25.27                                                         arm64        Linux kernel extra modules for version 5.11.0 on ARMv8 SMP
I feel lost and would be gratefull for any assistance.
Regards
Chris
I had them already installed. Reinstalled with armbian-config, no change. I'm missing the zfs modules which, if I understand correctly, are provided by linux-modules*
and I cannot find linux-modules.
root@odroidhc4:~# ls /lib/modules/5.13.9-meson64/kernel/
arch  crypto  drivers  fs  kernel  lib  net  sound
Nope. Armbian is not Canonical.
You should do some forum search - there are many happy ZFS users around here. Me included.
sudo apt install zfsutils-linux zfs-dkms
... but unfortunately there is a bug in headers which needs some time. That is on you to fix or wait ... but it can take months since bug is with us also months.
Workaround is using stable kernels (current). You can switch to them within armbian-config, install headers there and install dkms package again.
OK, trying from scratch:
1. Installed current image: Armbian_21.05.4_Odroidhc4_buster_current_5.10.43.img.xz
2. apt update
 got some of those recently quite famous "Hash Sum mismatch" *) errors:
Err:19 http://mirrors.netix.net/armbian/apt buster/main arm64 linux-image-current-meson64 arm64 21.05.8
  Hash Sum mismatch
  Hashes of expected file:
   - SHA512:992fe660df2fafcd5487bd613c87bc8d0e5d01d95c9ca26e3385c964934b3e8517ef71b83e7a0830636172ebbac1831a8c1ed872b513730b4ed9068589aa0a9c
   - SHA256:bf1396f7dba17c053a7ba42958bd65751e06a3921958669fe63f057e522f3a99
   - SHA1:f2a4bad1df0353b8fcc1d111d5bdcc520be98ae7 [weak]
   - MD5Sum:a2a292c3a27617e6aa0e4877637c5a14 [weak]
   - Filesize:43238688 [weak]
  Hashes of received file:
   - SHA512:595cb6dc4c711e3c86c220dc9342a843232903b2529317a5333ac359f9f92205b1fc36023eaeaa322140a7eabce3670425a096718cc71a8881893bc80be4c79f
   - SHA256:57519afde133640572833f5e4845a75a0ba840e4f529ab6e73815b2004942e62
   - SHA1:050d4f43d1f58755af9e702d5a769cef5ea70639 [weak]
   - MD5Sum:5830178161646bc59ffafa454931425f [weak]
  Last modification reported: Mon, 09 Aug 2021 13:25:41 +0000
Fetched 73.2 MB in 1min 20s (911 kB/s)
E: Failed to fetch http://mirrors.netix.net/armbian/apt/pool/main/l/linux-5.10.57-meson64/linux-image-current-meson64_21.05.8_arm64.deb  Hash Sum mismatch
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Tried again and it worked, go figure why.
3. apt upgrade
 This upgraded the kernel to 5.10.57-meson64
4. apt install linux-headers-current-meson64
5. apt install zfsutils-linux zfs-dkms
ZFS is there.
*) Recently, few weeks ago, most of my Debian based systems started to fail on "apt update"  with this "Hash Sum mismatch" error.
Cannot figure out what the problem is. The "solution nr. 1" fro google, rm -rf /var/cache/apt/* /var/lib/apt/lists/* doesn't help.
https://forum.armbian.com/search/?q=Hash Sum mismatch&quick=1
We need to extend repository index synchronisation timeout from 1 day to several days since mirrors doesn't get in sync in this time frame. The problem is that current main rsync server is slow (only 50Mbps upload in total), but is cheap and has no traffic limits.
We know how to solve this, but we lack time: https://armbian.atlassian.net/browse/AR-789
