Myron Posted September 14, 2021 Share Posted September 14, 2021 Hello kind folk. Hoping someone can help. What's listed below is what gone wrong. Armbian monitor diagnostics dump: http://ix.io/3yOY All I've done is install Armbian, did the 'apt update && apt upgrade' and enabled options to see how will it will work. I'm not sure if I have done something wrong for several DT overlays not to load. I can see it states that (what is an ftd?) base ftds are missing a node and need recompiling. How do I do that? (The analog codec does load. It's the only one that does.) U-Boot SPL 2020.10-armbian (Aug 08 2021 - 14:48:33 +0200) DRAM: 1024 MiB CPU: 912000000Hz, AXI/AHB/APB: 3/2/2 Trying to boot from MMC1 U-Boot 2020.10-armbian (Aug 08 2021 - 14:48:33 +0200) Allwinner Technology CPU: Allwinner A20 (SUN7I) Model: LeMaker Banana Pro I2C: ready DRAM: 1 GiB MMC: mmc@1c0f000: 0, mmc@1c12000: 1 Loading Environment from FAT... Unable to use mmc 0:1... Setting up a 720x576i composite-pal console (overscan 32x20) In: serial Out: vga Err: vga Net: eth0: ethernet@1c50000 230454 bytes read in 17 ms (12.9 MiB/s) starting USB... Bus usb@1c14000: USB EHCI 1.00 Bus usb@1c14400: USB OHCI 1.0 Bus usb@1c1c000: USB EHCI 1.00 Bus usb@1c1c400: USB OHCI 1.0 scanning bus usb@1c14000 for devices... 1 USB Device(s) found scanning bus usb@1c14400 for devices... 1 USB Device(s) found scanning bus usb@1c1c000 for devices... 1 USB Device(s) found scanning bus usb@1c1c400 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Autoboot in 1 seconds switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3964 bytes read in 4 ms (967.8 KiB/s) ## Executing script at 43100000 U-boot loaded from SD Boot script loaded from mmc 281 bytes read in 4 ms (68.4 KiB/s) 11582960 bytes read in 639 ms (17.3 MiB/s) 7995296 bytes read in 441 ms (17.3 MiB/s) Found mainline kernel configuration 40795 bytes read in 8 ms (4.9 MiB/s) 267 bytes read in 10 ms (25.4 KiB/s) Applying kernel provided DT overlay sun7i-a20-analog-codec.dtbo 386 bytes read in 10 ms (37.1 KiB/s) Applying kernel provided DT overlay sun7i-a20-can.dtbo failed on fdt_overlay_apply(): FDT_ERR_NOTFOUND 500 bytes read in 9 ms (53.7 KiB/s) Applying kernel provided DT overlay sun7i-a20-i2c1.dtbo failed on fdt_overlay_apply(): FDT_ERR_BADMAGIC base fdt does did not have a /__symbols__ node make sure you've compiled with -@ 500 bytes read in 10 ms (48.8 KiB/s) Applying kernel provided DT overlay sun7i-a20-i2c2.dtbo failed on fdt_overlay_apply(): FDT_ERR_BADMAGIC base fdt does did not have a /__symbols__ node make sure you've compiled with -@ 500 bytes read in 9 ms (53.7 KiB/s) Applying kernel provided DT overlay sun7i-a20-i2c3.dtbo failed on fdt_overlay_apply(): FDT_ERR_BADMAGIC base fdt does did not have a /__symbols__ node make sure you've compiled with -@ 766 bytes read in 10 ms (74.2 KiB/s) Applying kernel provided DT overlay sun7i-a20-i2c4.dtbo failed on fdt_overlay_apply(): FDT_ERR_BADMAGIC base fdt does did not have a /__symbols__ node make sure you've compiled with -@ 778 bytes read in 10 ms (75.2 KiB/s) Applying kernel provided DT overlay sun7i-a20-pps-gpio.dtbo failed on fdt_overlay_apply(): FDT_ERR_BADMAGIC base fdt does did not have a /__symbols__ node make sure you've compiled with -@ 443 bytes read in 10 ms (43 KiB/s) Applying kernel provided DT overlay sun7i-a20-pwm.dtbo failed on fdt_overlay_apply(): FDT_ERR_BADMAGIC base fdt does did not have a /__symbols__ node make sure you've compiled with -@ 1069 bytes read in 11 ms (94.7 KiB/s) Applying kernel provided DT overlay sun7i-a20-spi-spidev.dtbo failed on fdt_overlay_apply(): FDT_ERR_BADMAGIC base fdt does did not have a /__symbols__ node make sure you've compiled with -@ 777 bytes read in 11 ms (68.4 KiB/s) Applying kernel provided DT overlay sun7i-a20-w1-gpio.dtbo failed on fdt_overlay_apply(): FDT_ERR_BADMAGIC base fdt does did not have a /__symbols__ node make sure you've compiled with -@ Error applying DT overlays, restoring original DT 40795 bytes read in 8 ms (4.9 MiB/s) ## Loading init Ramdisk from Legacy Image at 43300000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 11582896 Bytes = 11 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 43000000 Booting using the fdt blob at 0x43000000 EHCI failed to shut down host controller. Loading Ramdisk to 494f4000, end 49fffdb0 ... OK Loading Device Tree to 494e7000, end 494f3f5a ... OK Starting kernel ... Armbian 21.08.2 Focal ttyS0 medusa login: 0 Quote Link to comment Share on other sites More sharing options...
phelum Posted September 19, 2021 Share Posted September 19, 2021 Hi, An "fdt" is a flattened device tree (e.g. sun7i-a20-bananapi.dtb) which will be in your /boot/dtb directory. The "-@" option is used when running dtc (the devicetree compiler) to create the fdt. It tells the compiler to include symbols details in the .dtb. These are needed so overlays can be applied. But you'll need the source files and compiler to create the .dtb and this shouldn't be necessary. I'm wondering if the first overlay (analogue-codec) is causing the problem. Can you try deleting it from your "overlays=" line in armbianEnv.txt to see what happens ? The fact that the "can.dtbo" overlay is not found might cause a problem. Does it exist ? Can you try deleting it from the "overlays=" line and see what happens ? Hopefully someone with more knowledge will chip in here and help. Cheers, Steven 0 Quote Link to comment Share on other sites More sharing options...
Myron Posted September 20, 2021 Author Share Posted September 20, 2021 Thanks. will look at that when I can. My legacy Rasberry v1 Rasberry Pi has died which I was using for a specific set of tasks and I've had to put the BananaPro in it's place as the replacement. At the moment this is the content of armbianEnv.txt: verbosity=1 bootlogo=false console=both disp_mode=1920x1080p60 overlay_prefix=sun7i-a20 rootdev=UUID=dffd2ee5-5480-480b-9853-7884f8ba5e47 rootfstype=ext4 overlays=analog-codec usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u I removed the overlays that where not loading. Not using that at the moment, but I would have expected the drivers to at least load. I'm assuming that the analog-codec is to do with the microphone that's build in to the BananaPro and I may be actively [nor for spying! :-) ] using that some time in the future. 0 Quote Link to comment Share on other sites More sharing options...
phelum Posted September 20, 2021 Share Posted September 20, 2021 When I saw your original log listing all the failed overlay loads I assumed your "overlay=" line would be a long list containing all of them. But it's not and your single entry there looks fine to me. Can you try booting with no overlays and if it works then add entries to your "ovelays=" line one by one ? 0 Quote Link to comment Share on other sites More sharing options...
Myron Posted September 20, 2021 Author Share Posted September 20, 2021 (edited) It does seem that there are specific DTs that do not load, but I did notice one particular thing and this can only be seen observing output from the serial debug port, if ANY dt overlays fail then I get . . . Error applying DT overlays, restoring original DT If all the device tree overlays succeed then I get . . . Applying kernel provided DT fixup script (sun7i-a20-fixup.scr) Is this an all or nothing scenario, where if one overlay does not initialise correctly then no overlays get applied? When it comes to device trees I am an absolute noob. armbian-monitor details of my BananaPro as it is when I post this reply: http://ix.io/3zxW (As well as all the others that are still in there) Reboots while I had the USB to TTL RS232 bridge connected: ▒ U-Boot SPL 2021.07-armbian (Sep 13 2021 - 23:19:26 +0200) DRAM: 1024 MiB CPU: 912000000Hz, AXI/AHB/APB: 3/2/2 Trying to boot from MMC1 U-Boot 2021.07-armbian (Sep 13 2021 - 23:19:26 +0200) Allwinner Technology CPU: Allwinner A20 (SUN7I) Model: LeMaker Banana Pro I2C: ready DRAM: 1 GiB MMC: mmc@1c0f000: 0, mmc@1c12000: 2 Loading Environment from FAT... Unable to use mmc 0:1... Setting up a 720x576i composite-pal console (overscan 32x20) In: serial Out: vidconsole Err: vidconsole Net: eth0: ethernet@1c50000 230454 bytes read in 17 ms (12.9 MiB/s) starting USB... Bus usb@1c14000: USB EHCI 1.00 Bus usb@1c14400: USB OHCI 1.0 Bus usb@1c1c000: USB EHCI 1.00 Bus usb@1c1c400: USB OHCI 1.0 scanning bus usb@1c14000 for devices... 1 USB Device(s) found scanning bus usb@1c14400 for devices... 1 USB Device(s) found scanning bus usb@1c1c000 for devices... 1 USB Device(s) found scanning bus usb@1c1c400 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Autoboot in 1 seconds, press <Space> to stop switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3964 bytes read in 4 ms (967.8 KiB/s) ## Executing script at 43100000 U-boot loaded from SD Boot script loaded from mmc 230 bytes read in 4 ms (55.7 KiB/s) 11588626 bytes read in 639 ms (17.3 MiB/s) 7995288 bytes read in 442 ms (17.3 MiB/s) Found mainline kernel configuration 41126 bytes read in 10 ms (3.9 MiB/s) 267 bytes read in 11 ms (23.4 KiB/s) Applying kernel provided DT overlay sun7i-a20-analog-codec.dtbo 500 bytes read in 10 ms (48.8 KiB/s) Applying kernel provided DT overlay sun7i-a20-i2c1.dtbo 5532 bytes read in 11 ms (490.2 KiB/s) Applying kernel provided DT fixup script (sun7i-a20-fixup.scr) ## Executing script at 45000000 Kernel image @ 0x42000000 [ 0x000000 - 0x79ff98 ] ## Loading init Ramdisk from Legacy Image at 43400000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 11588562 Bytes = 11.1 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 43000000 Booting using the fdt blob at 0x43000000 EHCI failed to shut down host controller. Loading Ramdisk to 494f2000, end 49fff3d2 ... OK Loading Device Tree to 4947f000, end 494f1fff ... OK Starting kernel ... Armbian 21.08.2 Focal ttyS0 loki login: [ 177.621676] reboot: Restarting system U-Boot SPL 2021.07-armbian (Sep 13 2021 - 23:19:26 +0200) DRAM: 1024 MiB CPU: 912000000Hz, AXI/AHB/APB: 3/2/2 Trying to boot from MMC1 U-Boot 2021.07-armbian (Sep 13 2021 - 23:19:26 +0200) Allwinner Technology CPU: Allwinner A20 (SUN7I) Model: LeMaker Banana Pro I2C: ready DRAM: 1 GiB MMC: mmc@1c0f000: 0, mmc@1c12000: 2 Loading Environment from FAT... Unable to use mmc 0:1... Setting up a 720x576i composite-pal console (overscan 32x20) In: serial Out: vidconsole Err: vidconsole Net: eth0: ethernet@1c50000 230454 bytes read in 17 ms (12.9 MiB/s) starting USB... Bus usb@1c14000: USB EHCI 1.00 Bus usb@1c14400: USB OHCI 1.0 Bus usb@1c1c000: USB EHCI 1.00 Bus usb@1c1c400: USB OHCI 1.0 scanning bus usb@1c14000 for devices... 1 USB Device(s) found scanning bus usb@1c14400 for devices... 1 USB Device(s) found scanning bus usb@1c1c000 for devices... 1 USB Device(s) found scanning bus usb@1c1c400 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Autoboot in 1 seconds, press <Space> to stop switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3964 bytes read in 4 ms (967.8 KiB/s) ## Executing script at 43100000 U-boot loaded from SD Boot script loaded from mmc 216 bytes read in 4 ms (52.7 KiB/s) 11588626 bytes read in 638 ms (17.3 MiB/s) 7995288 bytes read in 441 ms (17.3 MiB/s) Found mainline kernel configuration 41126 bytes read in 10 ms (3.9 MiB/s) 386 bytes read in 11 ms (34.2 KiB/s) Applying kernel provided DT overlay sun7i-a20-can.dtbo failed on fdt_overlay_apply(): FDT_ERR_NOTFOUND Error applying DT overlays, restoring original DT 41126 bytes read in 9 ms (4.4 MiB/s) Kernel image @ 0x42000000 [ 0x000000 - 0x79ff98 ] ## Loading init Ramdisk from Legacy Image at 43400000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 11588562 Bytes = 11.1 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 43000000 Booting using the fdt blob at 0x43000000 EHCI failed to shut down host controller. Loading Ramdisk to 494f2000, end 49fff3d2 ... OK Loading Device Tree to 494e4000, end 494f10a5 ... OK Starting kernel ... Armbian 21.08.2 Focal ttyS0 loki login: [ 173.714013] reboot: Restarting system U-Boot SPL 2021.07-armbian (Sep 13 2021 - 23:19:26 +0200) DRAM: 1024 MiB CPU: 912000000Hz, AXI/AHB/APB: 3/2/2 Trying to boot from MMC1 U-Boot 2021.07-armbian (Sep 13 2021 - 23:19:26 +0200) Allwinner Technology CPU: Allwinner A20 (SUN7I) Model: LeMaker Banana Pro I2C: ready DRAM: 1 GiB MMC: mmc@1c0f000: 0, mmc@1c12000: 2 Loading Environment from FAT... Unable to use mmc 0:1... Setting up a 720x576i composite-pal console (overscan 32x20) In: serial Out: vidconsole Err: vidconsole Net: eth0: ethernet@1c50000 230454 bytes read in 17 ms (12.9 MiB/s) starting USB... Bus usb@1c14000: USB EHCI 1.00 Bus usb@1c14400: USB OHCI 1.0 Bus usb@1c1c000: USB EHCI 1.00 Bus usb@1c1c400: USB OHCI 1.0 scanning bus usb@1c14000 for devices... 1 USB Device(s) found scanning bus usb@1c14400 for devices... 1 USB Device(s) found scanning bus usb@1c1c000 for devices... 1 USB Device(s) found scanning bus usb@1c1c400 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Autoboot in 1 seconds, press <Space> to stop switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3964 bytes read in 4 ms (967.8 KiB/s) ## Executing script at 43100000 U-boot loaded from SD Boot script loaded from mmc 245 bytes read in 3 ms (79.1 KiB/s) 11588626 bytes read in 639 ms (17.3 MiB/s) 7995288 bytes read in 441 ms (17.3 MiB/s) Found mainline kernel configuration 41126 bytes read in 9 ms (4.4 MiB/s) 267 bytes read in 11 ms (23.4 KiB/s) Applying kernel provided DT overlay sun7i-a20-analog-codec.dtbo 500 bytes read in 10 ms (48.8 KiB/s) Applying kernel provided DT overlay sun7i-a20-i2c1.dtbo 500 bytes read in 10 ms (48.8 KiB/s) Applying kernel provided DT overlay sun7i-a20-i2c2.dtbo 500 bytes read in 10 ms (48.8 KiB/s) Applying kernel provided DT overlay sun7i-a20-i2c3.dtbo 766 bytes read in 11 ms (67.4 KiB/s) Applying kernel provided DT overlay sun7i-a20-i2c4.dtbo failed on fdt_overlay_apply(): FDT_ERR_NOTFOUND Error applying DT overlays, restoring original DT 41126 bytes read in 9 ms (4.4 MiB/s) Kernel image @ 0x42000000 [ 0x000000 - 0x79ff98 ] ## Loading init Ramdisk from Legacy Image at 43400000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 11588562 Bytes = 11.1 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 43000000 Booting using the fdt blob at 0x43000000 EHCI failed to shut down host controller. Loading Ramdisk to 494f2000, end 49fff3d2 ... OK Loading Device Tree to 494e4000, end 494f10a5 ... OK Starting kernel ... Armbian 21.08.2 Focal ttyS0 loki login: [ 178.697923] reboot: Restarting system U-Boot SPL 2021.07-armbian (Sep 13 2021 - 23:19:26 +0200) DRAM: 1024 MiB CPU: 912000000Hz, AXI/AHB/APB: 3/2/2 Trying to boot from MMC1 U-Boot 2021.07-armbian (Sep 13 2021 - 23:19:26 +0200) Allwinner Technology CPU: Allwinner A20 (SUN7I) Model: LeMaker Banana Pro I2C: ready DRAM: 1 GiB MMC: mmc@1c0f000: 0, mmc@1c12000: 2 Loading Environment from FAT... Unable to use mmc 0:1... Setting up a 720x576i composite-pal console (overscan 32x20) In: serial Out: vidconsole Err: vidconsole Net: eth0: ethernet@1c50000 230454 bytes read in 17 ms (12.9 MiB/s) starting USB... Bus usb@1c14000: USB EHCI 1.00 Bus usb@1c14400: USB OHCI 1.0 Bus usb@1c1c000: USB EHCI 1.00 Bus usb@1c1c400: USB OHCI 1.0 scanning bus usb@1c14000 for devices... 1 USB Device(s) found scanning bus usb@1c14400 for devices... 1 USB Device(s) found scanning bus usb@1c1c000 for devices... 1 USB Device(s) found scanning bus usb@1c1c400 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Autoboot in 1 seconds, press <Space> to stop switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3964 bytes read in 4 ms (967.8 KiB/s) ## Executing script at 43100000 U-boot loaded from SD Boot script loaded from mmc 240 bytes read in 4 ms (58.6 KiB/s) 11588626 bytes read in 639 ms (17.3 MiB/s) 7995288 bytes read in 442 ms (17.3 MiB/s) Found mainline kernel configuration 41126 bytes read in 9 ms (4.4 MiB/s) 267 bytes read in 11 ms (23.4 KiB/s) Applying kernel provided DT overlay sun7i-a20-analog-codec.dtbo 500 bytes read in 11 ms (43.9 KiB/s) Applying kernel provided DT overlay sun7i-a20-i2c1.dtbo 500 bytes read in 11 ms (43.9 KiB/s) Applying kernel provided DT overlay sun7i-a20-i2c2.dtbo 500 bytes read in 11 ms (43.9 KiB/s) Applying kernel provided DT overlay sun7i-a20-i2c3.dtbo 5532 bytes read in 11 ms (490.2 KiB/s) Applying kernel provided DT fixup script (sun7i-a20-fixup.scr) ## Executing script at 45000000 Kernel image @ 0x42000000 [ 0x000000 - 0x79ff98 ] ## Loading init Ramdisk from Legacy Image at 43400000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 11588562 Bytes = 11.1 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 43000000 Booting using the fdt blob at 0x43000000 EHCI failed to shut down host controller. Loading Ramdisk to 494f2000, end 49fff3d2 ... OK Loading Device Tree to 4947f000, end 494f1fff ... OK Starting kernel ... Armbian 21.08.2 Focal ttyS0 loki login: [ 109.894018] reboot: Power down [ 109.897239] ------------[ cut here ]------------ [ 109.901889] WARNING: CPU: 0 PID: 1 at drivers/i2c/i2c-core.h:41 i2c_transfer+0x93/0xbc [ 109.909808] No atomic I2C transfer handler for 'i2c-1' [ 109.914946] Modules linked in: overlay l2tp_ppp l2tp_netlink l2tp_core ip6_udp_tunnel udp_tunnel pppox ppp_generic slhc nls_utf8 cifs libarc4 fscache evdev axp20x_adc lima gpu_sched sunxi_cir sun4i_gpadc_iio industrialio brcmfmac sun4i_ts brcmutil cfg80211 rfkill sunxi_cedrus(C) v4l2_mem2mem videobuf2_dma_contig videobuf2_memops videobuf2_v4l2 videobuf2_common nf_log_ipv6 ip6t_REJECT display_connector nf_reject_ipv6 uio_pdrv_genirq uio zram cpufreq_dt xt_hl ip6t_rt nf_log_ipv4 nf_log_common ipt_REJECT nf_reject_ipv4 xt_LOG xt_recent xt_limit xt_addrtype xt_tcpudp xt_conntrack nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 sch_fq_codel ip6table_filter ip6_tables iptable_filter ip_tables x_tables autofs4 pwrseq_simple sun4i_gpadc realtek [ 109.979974] CPU: 0 PID: 1 Comm: systemd-shutdow Tainted: G WC 5.10.60-sunxi #21.08.2 [ 109.988932] Hardware name: Allwinner sun7i (A20) Family [ 109.994185] [<c010ca1d>] (unwind_backtrace) from [<c010952d>] (show_stack+0x11/0x14) [ 110.001944] [<c010952d>] (show_stack) from [<c0978293>] (dump_stack+0x77/0x84) [ 110.009182] [<c0978293>] (dump_stack) from [<c011ae71>] (__warn+0xad/0xc0) [ 110.016067] [<c011ae71>] (__warn) from [<c09721bf>] (warn_slowpath_fmt+0x5f/0x7c) [ 110.023560] [<c09721bf>] (warn_slowpath_fmt) from [<c07616a7>] (i2c_transfer+0x93/0xbc) [ 110.031576] [<c07616a7>] (i2c_transfer) from [<c076170b>] (i2c_transfer_buffer_flags+0x3b/0x50) [ 110.040284] [<c076170b>] (i2c_transfer_buffer_flags) from [<c066e8ef>] (regmap_i2c_write+0x13/0x24) [ 110.049340] [<c066e8ef>] (regmap_i2c_write) from [<c066b257>] (_regmap_raw_write_impl+0x4af/0x580) [ 110.058308] [<c066b257>] (_regmap_raw_write_impl) from [<c066b369>] (_regmap_bus_raw_write+0x41/0x5c) [ 110.067535] [<c066b369>] (_regmap_bus_raw_write) from [<c066bb31>] (regmap_write+0x29/0x3c) [ 110.075896] [<c066bb31>] (regmap_write) from [<c0674f63>] (axp20x_power_off+0x23/0x30) [ 110.083826] [<c0674f63>] (axp20x_power_off) from [<c0136a39>] (__do_sys_reboot+0xf5/0x168) [ 110.092099] [<c0136a39>] (__do_sys_reboot) from [<c0100061>] (ret_fast_syscall+0x1/0x62) [ 110.100192] Exception stack(0xc1529fa8 to 0xc1529ff0) [ 110.105250] 9fa0: 4321fedc befd1aa8 fee1dead 28121969 4321fedc 00000000 [ 110.113433] 9fc0: 4321fedc befd1aa8 befd1aa4 00000058 befd1aa8 befd1aa4 fffff000 befd1aac [ 110.121613] 9fe0: 00000058 befd1a1c b6f2c545 b6eaabe6 [ 110.126668] ---[ end trace 9aac65adb4b3b0e1 ]--- Edited September 21, 2021 by Myron Results of test 0 Quote Link to comment Share on other sites More sharing options...
Javier Vela Posted March 23, 2022 Share Posted March 23, 2022 Hi, I have a similar problem with Bananapi M2 Zero. Did you find a solution? 0 Quote Link to comment Share on other sites More sharing options...
Myron Posted March 28, 2022 Author Share Posted March 28, 2022 Nope. I didn't. My knowledge of the Linux Kernel is not that deep. I've got, at least, the analog-codec up-and-running. 🙂 The rest is on indefinite hold. 0 Quote Link to comment Share on other sites More sharing options...
tepo Posted April 22, 2023 Share Posted April 22, 2023 the support and documentation for BPI M2 0 is very sad and worrysome 0 Quote Link to comment Share on other sites More sharing options...
SteeMan Posted April 22, 2023 Share Posted April 22, 2023 @tepo The Banana PI M2 Zero is not supported by Armbian maintainers. It is "Community Support" status, which means that it is available for the public at large to support. There is currently no one in the community that has stepped up to say they will be a maintainer for that board. So the board is languishing for lack of support by anyone interested enough to contribute. Armbian is first and foremost a platform for building images for the many different Arm based boards that are out there. But with limited resources (both people and money) only a handful of boards get officially supported by the project. The majority end up supported (or not supported) by the community of volunteers interested in the particular boards. 1 Quote Link to comment Share on other sites More sharing options...
tepo Posted April 22, 2023 Share Posted April 22, 2023 i see 0 Quote Link to comment Share on other sites More sharing options...
