Myron Posted September 16, 2021 Share Posted September 16, 2021 (edited) Armbianmonitor: http://ix.io/3z46 I'm not sure if this is a bug that needs to be reported and I don't know what issues it may be causing, if any. ----< CUT >---- Sep 16 08:55:56 loki kernel: [35972.411737] ieee80211 phy2: brcmf_fweh_event_worker: event handler failed (72) Sep 16 08:55:56 loki kernel: [35972.465736] ieee80211 phy2: brcmf_fweh_call_event_handler: no interface object Sep 16 08:55:56 loki kernel: [35972.465781] ieee80211 phy2: brcmf_fweh_event_worker: event handler failed (72) Sep 16 08:55:56 loki kernel: [35972.471791] ieee80211 phy2: brcmf_fweh_call_event_handler: no interface object Sep 16 08:55:56 loki kernel: [35972.471838] ieee80211 phy2: brcmf_fweh_event_worker: event handler failed (72) Sep 16 09:00:54 loki kernel: [36270.546084] ieee80211 phy2: brcmf_fweh_call_event_handler: no interface object Sep 16 09:00:54 loki kernel: [36270.546174] ieee80211 phy2: brcmf_fweh_event_worker: event handler failed (72) Sep 16 09:00:54 loki kernel: [36270.673121] ieee80211 phy2: brcmf_fweh_call_event_handler: no interface object Sep 16 09:00:54 loki kernel: [36270.673211] ieee80211 phy2: brcmf_fweh_event_worker: event handler failed (72) Sep 16 09:03:24 loki kernel: [36420.901890] sun7i-dwmac 1c50000.ethernet eth0: Link is Down Sep 16 09:03:25 loki kernel: [36421.344529] device wlan0 entered promiscuous mode Sep 16 09:03:26 loki kernel: [36422.743514] PM: suspend entry (s2idle) Sep 16 09:03:26 loki kernel: [36422.858919] Filesystems sync: 0.115 seconds Sep 16 15:54:45 loki kernel: [36422.893328] Freezing user space processes ... (elapsed 0.007 seconds) done. Sep 16 15:54:45 loki kernel: [36422.901044] OOM killer disabled. Sep 16 15:54:45 loki kernel: [36422.901053] Freezing remaining freezable tasks ... (elapsed 0.002 seconds) done. Sep 16 15:54:45 loki kernel: [36422.903250] printk: Suspending console(s) (use no_console_suspend to debug) Sep 16 15:54:45 loki kernel: [61102.651236] usb usb1: root hub lost power or was reset Sep 16 15:54:45 loki kernel: [61102.651348] usb usb2: root hub lost power or was reset Sep 16 15:54:45 loki kernel: [61102.823144] usb usb3: root hub lost power or was reset Sep 16 15:54:45 loki kernel: [61102.887103] usb usb4: root hub lost power or was reset Sep 16 15:54:45 loki kernel: [61102.928819] mmc1: queuing unknown CIS tuple 0x80 (2 bytes) Sep 16 15:54:45 loki kernel: [61102.930362] mmc1: queuing unknown CIS tuple 0x80 (3 bytes) Sep 16 15:54:45 loki kernel: [61102.931907] mmc1: queuing unknown CIS tuple 0x80 (3 bytes) Sep 16 15:54:45 loki kernel: [61102.934666] mmc1: queuing unknown CIS tuple 0x80 (7 bytes) Sep 16 15:54:45 loki kernel: [61102.953149] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43362-sdio for chip BCM43362/1 Sep 16 15:54:45 loki kernel: [61102.953422] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43362-sdio.lemaker,bananapro.txt failed with error -2 Sep 16 15:54:45 loki kernel: [61102.953436] brcmfmac mmc1:0001:1: Falling back to sysfs fallback for: brcm/brcmfmac43362-sdio.lemaker,bananapro.txt Sep 16 15:54:45 loki kernel: [61102.953448] ------------[ cut here ]------------ Sep 16 15:54:45 loki kernel: [61102.953480] WARNING: CPU: 1 PID: 11708 at drivers/base/firmware_loader/fallback.c:569 firmware_fallback_sysfs+0x201/0x348 Sep 16 15:54:45 loki kernel: [61102.953486] Modules linked in: l2tp_ppp l2tp_netlink l2tp_core ip6_udp_tunnel udp_tunnel pppox ppp_gene ric slhc nls_utf8 cifs libarc4 fscache evdev lima axp20x_adc gpu_sched sun4i_gpadc_iio industrialio sunxi_cir sun4i_ts brcmfmac brcmutil cfg80211 rfkill sunxi_cedrus(C) v4l2_mem2mem videobuf2_dma_contig videobuf2_memops videobuf2_v4l2 videobuf2_common nf_log_ipv6 uio_pdrv_genirq uio display_connector ip6t_REJECT nf_reject_ipv6 cpufreq_dt zram xt_hl ip6t_rt nf_log_ipv4 nf_log_common ipt_REJECT nf_reject_ipv4 xt_LOG xt_recent xt_limit xt_addrtype xt_tcpudp xt_conntrack nf_conntrack nf_defrag_ipv6 sch_fq_codel nf_defrag_ipv4 ip6table_filter ip6_tables iptable_filter ip_tables x_tables autofs4 pwrseq_simple sun4i_gpadc realtek Sep 16 15:54:45 loki kernel: [61102.953851] CPU: 1 PID: 11708 Comm: kworker/1:0 Tainted: G WC 5.10.60-sunxi#21.08.2 Sep 16 15:54:45 loki kernel: [61102.953858] Hardware name: Allwinner sun7i (A20) Family Sep 16 15:54:45 loki kernel: [61102.953878] Workqueue: events request_firmware_work_func Sep 16 15:54:45 loki kernel: [61102.953922] [<c010ca1d>] (unwind_backtrace) from [<c010952d>] (show_stack+0x11/0x14) Sep 16 15:54:45 loki kernel: [61102.953949] [<c010952d>] (show_stack) from [<c0978293>] (dump_stack+0x77/0x84) Sep 16 15:54:45 loki kernel: [61102.953976] [<c0978293>] (dump_stack) from [<c011ae71>] (__warn+0xad/0xc0) Sep 16 15:54:45 loki kernel: [61102.953999] [<c011ae71>] (__warn) from [<c09721a3>] (warn_slowpath_fmt+0x43/0x7c) Sep 16 15:54:45 loki kernel: [61102.954021] [<c09721a3>] (warn_slowpath_fmt) from [<c0667dcd (firmware_fallback_sysfs+0x201/0x348) Sep 16 15:54:45 loki kernel: [61102.954043] [<c0667dcd>] (firmware_fallback_sysfs) from [<c06671e1>] (_request_firmware+0x3a5/0x570) Sep 16 15:54:45 loki kernel: [61102.954061] [<c06671e1>] (_request_firmware) from [<c06673d9>] (request_firmware+0x2d/0x3c) Sep 16 15:54:45 loki kernel: [61102.954208] [<c06673d9>] (request_firmware) from [<bf9a7957>] (brcmf_fw_request_firmware+0xaf/0xe4 [brcmfmac]) Sep 16 15:54:45 loki kernel: [61102.954388] [<bf9a7957>] (brcmf_fw_request_firmware [brcmfmac]) from [<bf9a8063>] (brcmf_fw_request_done+0x23/0xa0 [brcmfmac]) Sep 16 15:54:45 loki kernel: [61102.954486] [<bf9a8063>] (brcmf_fw_request_done [brcmfmac]) from [<c066766b>] (request_firmware_work_func+0x37/0x60) Sep 16 15:54:45 loki kernel: [61102.954512] [<c066766b>] (request_firmware_work_func) from [<c012f701>] (process_one_work+0x179/0x3e0) Sep 16 15:54:45 loki kernel: [61102.954537] [<c012f701>] (process_one_work) from [<c012fa6b>] (worker_thread+0x103/0x408) Sep 16 15:54:45 loki kernel: [61102.954561] [<c012fa6b>] (worker_thread) from [<c01345bd>] (kthread+0x109/0x10c) Sep 16 15:54:45 loki kernel: [61102.954583] [<c01345bd>] (kthread) from [<c0100159>] (ret_from_fork+0x11/0x38) Sep 16 15:54:45 loki kernel: [61102.954592] Exception stack(0xde4f5fb0 to 0xde4f5ff8) Sep 16 15:54:45 loki kernel: [61102.954606] 5fa0: 00000000 00000000 00000000 00000000 Sep 16 15:54:45 loki kernel: [61102.954622] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 Sep 16 15:54:45 loki kernel: [61102.954636] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000 Sep 16 15:54:45 loki kernel: [61102.954648] ---[ end trace 0e7e15c499c4d644 ]--- ----< CUT >---- Might be related. Always happens on poweroff. reboot: Power down [ 351.051654] ------------[ cut here ]------------ [ 351.056307] WARNING: CPU: 0 PID: 1 at drivers/i2c/i2c-core.h:41 i2c_transfer+0x93/0xbc [ 351.064226] No atomic I2C transfer handler for 'i2c-1' [ 351.069364] Modules linked in: overlay l2tp_ppp l2tp_netlink l2tp_core ip6_udp_tunnel udp_tunnel pppox ppp_generic slhc nls_utf8 cifs libarc4 fscache evdev axp20x_adc lima sun4i_gpadc_iio gpu_sched industrialio sun4i_ts sunxi_cir brcmfmac brcmutil cfg80211 rfkill sunxi_cedrus(C) v4l2_mem2mem videobuf2_dma_contig videobuf2_memops videobuf2_v4l2 videobuf2_common display_connector uio_pdrv_genirq uio cpufreq_dt nf_log_ipv6 ip6t_REJECT nf_reject_ipv6 zram xt_hl ip6t_rt nf_log_ipv4 nf_log_common ipt_REJECT nf_reject_ipv4 xt_LOG xt_recent xt_limit xt_addrtype xt_tcpudp xt_conntrack nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 sch_fq_codel ip6table_filter ip6_tables iptable_filter ip_tables x_tables autofs4 pwrseq_simple sun4i_gpadc realtek [ 351.134401] CPU: 0 PID: 1 Comm: systemd-shutdow Tainted: G WC 5.10.60-sunxi #21.08.2 [ 351.143363] Hardware name: Allwinner sun7i (A20) Family [ 351.148615] [<c010ca1d>] (unwind_backtrace) from [<c010952d>] (show_stack+0x11/0x14) [ 351.156374] [<c010952d>] (show_stack) from [<c0978293>] (dump_stack+0x77/0x84) [ 351.163611] [<c0978293>] (dump_stack) from [<c011ae71>] (__warn+0xad/0xc0) [ 351.170496] [<c011ae71>] (__warn) from [<c09721bf>] (warn_slowpath_fmt+0x5f/0x7c) [ 351.177989] [<c09721bf>] (warn_slowpath_fmt) from [<c07616a7>] (i2c_transfer+0x93/0xbc) [ 351.186005] [<c07616a7>] (i2c_transfer) from [<c076170b>] (i2c_transfer_buffer_flags+0x3b/0x50) [ 351.194713] [<c076170b>] (i2c_transfer_buffer_flags) from [<c066e8ef>] (regmap_i2c_write+0x13/0x24) [ 351.203769] [<c066e8ef>] (regmap_i2c_write) from [<c066b257>] (_regmap_raw_write_impl+0x4af/0x580) [ 351.212736] [<c066b257>] (_regmap_raw_write_impl) from [<c066b369>] (_regmap_bus_raw_write+0x41/0x5c) [ 351.221963] [<c066b369>] (_regmap_bus_raw_write) from [<c066bb31>] (regmap_write+0x29/0x3c) [ 351.230325] [<c066bb31>] (regmap_write) from [<c0674f63>] (axp20x_power_off+0x23/0x30) [ 351.238254] [<c0674f63>] (axp20x_power_off) from [<c0136a39>] (__do_sys_reboot+0xf5/0x168) [ 351.246528] [<c0136a39>] (__do_sys_reboot) from [<c0100061>] (ret_fast_syscall+0x1/0x62) [ 351.254620] Exception stack(0xc1529fa8 to 0xc1529ff0) [ 351.259677] 9fa0: 4321fedc bebe1aa8 fee1dead 28121969 4321fedc 00000000 [ 351.267861] 9fc0: 4321fedc bebe1aa8 bebe1aa4 00000058 bebe1aa8 bebe1aa4 fffff000 bebe1aac [ 351.276042] 9fe0: 00000058 bebe1a1c b6e9e545 b6e1cbe6 [ 351.281096] ---[ end trace bd6c600f4ffe1d83 ]--- Edited September 16, 2021 by Myron Additional details added Link to comment Share on other sites More sharing options...
Myron Posted February 19, 2022 Author Share Posted February 19, 2022 For anyone visiting this thread, the issue was fixed when I moved to Kernel version 5.15.y. Link to comment Share on other sites More sharing options...
