Problem with orange pi pc not started after reboot
newsy
device: orange pi pc
soft: Armbian_5.14_Orangepipc_Debian_jessie_3.4.112.7z
my log via serial:
U-Boot SPL 2016.05-armbian (Jun 05 2016 - 09:45:23)
DRAM: 1024 MiB
Trying to boot from MMC1
U-Boot 2016.05-armbian (Jun 05 2016 - 09:45:23 +0200) Allwinner Technology
CPU:   Allwinner H3 (SUN8I 1680)
Model: Xunlong Orange Pi PC
I2C:   ready
DRAM:  1 GiB
MMC:   SUNXI SD/MMC: 0 (SD), SUNXI SD/MMC: 1
*** Warning - bad CRC, using default environment
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
starting USB...
USB0:   USB EHCI 1.00
USB1:   USB OHCI 1.0
USB2:   USB EHCI 1.00
USB3:   USB OHCI 1.0
USB4:   USB EHCI 1.00
USB5:   USB OHCI 1.0
scanning bus 0 for devices... 1 USB Device(s) found
scanning bus 2 for devices... 1 USB Device(s) found
scanning bus 4 for devices... 1 USB Device(s) found
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
2444 bytes read in 182 ms (12.7 KiB/s)
## Executing script at 43100000
gpio: pin PL10 (gpio 298) value is 1
gpio: pin PG11 (gpio 203) value is 1
0 bytes read in 131 ms (0 Bytes/s)
** File not found /boot/.next **
** Unrecognized filesystem type **
** File not found .next **
36192 bytes read in 516 ms (68.4 KiB/s)
3113891 bytes read in 3143 ms (966.8 KiB/s)
5064616 bytes read in 5070 ms (974.6 KiB/s)
Kernel image @ 0x48000000 [ 0x000000 - 0x4d47a8 ]
## Loading init Ramdisk from Legacy Image at 42000000 ...
   Image Name:   uInitrd
   Image Type:   ARM Linux RAMDisk Image (gzip compressed)
   Data Size:    3113827 Bytes = 3 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
Using machid 0x1029 from environment
Starting kernel ...
[sun8i_fixup]: From boot, get meminfo:
        Start:  0x40000000
ion_carveout reserve: 160m@0 256m@0 130m@1 200m@1
ion_reserve_select: ion chipid  [0x2004620!
ion_reserve_common: ion reserve: [0x50000000, 0x60000000]!
Debian GNU/Linux 8 orangepipc ttyS0
orangepipc login:
DRAM: 1024 MiB
mmc_load_image_raw_sector: mmc block read error
SPL: failed to boot from all boot devices
### ERROR ### Please RESET the board ###
but after switch off/on power this work....
problem only with command reboot or shutdown -r now device after this command not started :(
please help
Just a shot in the dark: Does rebooting work without serial console connected?
I do not understand how serial console may interfere with read flash, but I checked out without serial console connected does not work.
Please read the last 2 paragraphs in the UART chapter: http://linux-sunxi.org/Pine64#Serial_port_.2F_UART
We also had various clock/calibration issues that might be related to stuff like that. Anyway: I would upgrade Armbian (apt-get upgrade), then try again and if that doesn't help try another SD card (recommendations and procedure to choose AND TEST prior to using a card exist)
This is a bit different but similar. How to boot after shutdown on OPI PC Plus? It seems I need to unplug the device before the start button works (or maybe it doesn't work at all and resetting power reboots?).
The power button is only there to wake from suspend, you would need to add a reset switch (or a physical switch disconnecting DC-IN completely)
I now test other two 8G sdcard, nothing has changed the problem persists, I can not understand what exactly I need to disconnect, as I have is connected only serial and eth (photo https://yadi.sk/i/GMJEPJ_QuVyFh)
Another shot in the dark (since you seem to be the only one with this phenomenon and struggle with just one Orange Pi PC -- always the same SD card slot used -- and only Armbian). You could try to use a thin peace of paper to get more pressure in the SD card slot (yeah, no idea what's different on cold vs. warm boot -- still 'shot in the dark' mode) or loboris' Ubuntu Mate image for OPi PC.
The one approach tries to improve hardware (contacts in SD card slot), the other tries to get a clue whether different u-boot versions make the difference (Armbian uses mainline u-boot, nearly all other Orange Pi OS images an outdated u-boot version from 2009 which boots differently).
And another shot in the dark: DRAM problems, please read through http://forum.armbian.com/index.php/topic/1322-testers-wanted-testing-dram-reliability-on-bpi-m2-and-nanopi-m1/?view=getlastpost (would then be the combination of a cold vs. warm boot issue with unreliable DRAM calibration that leads to u-boot failing to read from SD card). Since this is very unlikely please give a loboris image a try before (different DRAM calibration in this old u-boot version there)
