How do I turn on networking using bash commands if I've accidentally disabled networking within the GUI shell?
Myron
Yes, I managed to do this. Luckily I managed to re-enable the GDM3 graphical console on-start-up by using the debug serial port and then using the GUI through the TV to put the tick back to enable networking.  Yep, very much a noob mistake.
So, the question is when networking is disabled so eth0 and wlan0 disappear, leaving only lo, how do I get eth0 and wlan0 back just using the command line?  I can't easily find how to do this. I've looked, I've searched and now ....   help!  :-)
(I do also have the ability to put the MicroSD card into my laptop, so maybe it would be simpler to do that and change some configuration files to re-enable networking?)
This would be very useful information for anyone else who gets stuck in the same situation.
Unfortunately, it depends on what you did to disable networking?
By default, I think that networking services are managed by NetworkManager. You can check to see if the service is disabled with:
$ systemctl status NetworkManager
If it's disabled, you can re-enable with:
$ sudo systemctl enable NetworkManager
$ sudo systemctl start NetworkManager
If you touched one of the network configurations, You can manually poke at the configs like this:
$ sudo -i
# cd /etc/NetworkManager/system-connections
# ls
my_connection
# nano -w my_connection
<Hit Control-O, Enter, then Control-X when done>
