Armbian running on Pine64 (and other A64/H5 devices)
tkaiser
And now he kicked me out of chat, I never even said anything in the chat. LOL. Man those forum rep points must be like water for him.
Well, let's stop speculating about motives and focus on the real problem again (him being a huge part of though). He closed the thread, censored the advise to measure voltages away and even discourages users to do so ('I have proven that the VDD33 voltage is not the problem').
So all we have now are Zador's measurements on his board where no problem occurs, we have @androsch's board where I can not measure since I sent it back to @androsch yesterday before new schematic release and Zador came up with the PHY_VDD33 suggestion and we now have to rely on others taking notice (quite unlikely given the weird situation in pine64 forum). So let's see what happens when @-L0thar-'s gear arrives and he's able to compare his two boards.
@tkaiser
As far as I tried measured in iperf it seems out speed.
However, perhaps because of Packet loss, it takes a very time situation to apt-get update.
kometch@pine64:~$ iperf3 -c 192.168.122.223
Connecting to host 192.168.122.223, port 5201
[  4] local 192.168.122.171 port 42206 connected to 192.168.122.223 port 5201
[ ID] Interval           Transfer     Bandwidth       Retr  Cwnd
[  4]   0.00-1.01   sec  46.6 MBytes   386 Mbits/sec  130    215 KBytes
[  4]   1.01-2.00   sec  34.7 MBytes   295 Mbits/sec   70   90.5 KBytes
[  4]   2.00-3.00   sec  45.6 MBytes   382 Mbits/sec   10    173 KBytes
[  4]   3.00-4.00   sec  55.9 MBytes   468 Mbits/sec   94    164 KBytes
[  4]   4.00-5.00   sec  56.0 MBytes   470 Mbits/sec  120    191 KBytes
[  4]   5.00-6.01   sec  57.7 MBytes   480 Mbits/sec   55    245 KBytes
[  4]   6.01-7.00   sec  45.0 MBytes   381 Mbits/sec   59    141 KBytes
[  4]   7.00-8.01   sec  45.4 MBytes   377 Mbits/sec   17    178 KBytes
[  4]   8.01-9.02   sec  53.9 MBytes   447 Mbits/sec  120    133 KBytes
[  4]   9.02-10.00  sec  56.5 MBytes   484 Mbits/sec   38    198 KBytes
[  4]   0.00-10.00  sec   497 MBytes   417 Mbits/sec  713             sender
[  4]   0.00-10.00  sec   496 MBytes   416 Mbits/sec                  receiver
iperf Done.
Well, there are retransmissions and speed is relatively low. Is this legacy kernel or mainline? How do you power your board (microUSB or GPIO pins, power supply characteristics)?
apt-get update
This is the other direction. Please have a look at posts #33 and #34. With @androsch's board by powering through the Euler pins I was able to immediately increase the throughput in the direction you tested now but not in the other. Please test again, this time from 192.168.122.171 to 192.168.122.223. I would assume numbers will be terribly low then.
Do you have a Multimeter and are able to measure PHY_VDD33 as Zador outlined yesterday?
First we need to check if we can reproduce both very low and normal results on the same board, otherwise we will get "numbers without meaning"
Hmm... just to document what I did (still noobie needing your help to understand electronics basics):
  • In post #33 I started with the USB PSU on the right using an 'average' (crappy) USB cable and powered through Micro USB. Tested in the same direction as @kometchtech and got pretty bad results.
  • Then I replaced immediately USB PSU cable with the dual voltage PSU next to it and powered through Euler pins 4 and 6. In TX direction I got close to 900 Mbits/sec but in RX direction (apt-get update|upgrade ;) ) everything remained bad.
  • After I found my '5.5/2.1 to Micro USB' adapter (in the lower middle of the picture) I could use the next 2 PSUs. The larger one is rated 5V/3A (came IIRC as part of the 'UP Board' package) and the small one is cheap chinese crap rated 5V/2A and also the PSU showing 'best GbE performance' (since it provides 5.25V?). When I did tests with mainline kernel then using the larger dual voltage PSU with screw terminal (jumper wires connecting to Euler pins) I ended up with 'no PHY found' (PSU only providing 4.97V) and when using the small chinese crap connected to Micro USB connector GbE worked but showed still heavy symptoms in RX direction (TX being fine, I got the 470 Mbits/sec that can be expected with mainline kernel running at 408 MHz)
  • On friday I bought the large PSU on the left and re-tested with different voltages but got only results I don't understand and that were not that reproducable (at least it seems obvious to me that we're not only talking about voltage but instead about other PSU characteristics I have no idea of :)
I don't really trust in the large PSU since when I did tests with the Wandboard Quad on weekend testing through SATA and USB performance with i.MX6 using this PSU led reproducable to no Ethernet (not even PHY leds blinking). I wasted two hours testing through all different Wandboard OS images (could've ported Armbian to Wandboard in the same amount of time  :wacko: ) just to realize that I had to use a different PSU. But that's a different story and needs more time/investigation.
So I still find it hard to give any advice how to reproduce 'getting better numbers'. I only know that heavy undervolting (using a crappy USB cable) resulted in pretty bad TX numbers while providing almost 5V cured that. And I also know that I got strange voltage drops measured on the USB ports depending on how I powered @androsch's board. So it seems to be PSU related and I would already be happy if we're able to collect voltage numbers (measuring DC-IN, pins 4/6 on RPi and Euler headers and on the USB ports and of course also PHY_VDD33).
I hope I didn't forget anything relevant.
Currently I don't see any significant differences in PHY power part, but I think I found a point where the voltage can be measured, at least on my board, and running iperf3 test shows that voltage drops by 0.02V
Edit: I mean PHY 3.3V voltage (PHY_VDD33)
I have a 'bad' PINE64+ board, running armbian with legacy kernel, powered via micro-USB AC adapter. NIC and UART0 serial are the only active peripherals. 100Mbps is perfectly fine, but there's a major packet loss at 1Gbps, no need for iperf to tell there's an issue.
VDD33 voltage is between 3.26V and 3.27V, regardless of
- 1Gbps or 100Mbps or 10Mbps link speed
- CPU idle (/sys/class/thermal/thermal_zone0/temp @ 42 degrees) or busy (/sys/class/thermal/thermal_zone0/temp @ 65 degrees)
- 3 different microUSB AC 5V adapters and cables
That voltage is within tolerance range of 2.97V to 3.63V for PHY VDD33 (per PHY DS). PMIC AC input tolerance range is 3.5V to 7V (per PMIC DS), so PHY should be getting conditioned ~3.3V consistently, even when microUSB AC source is used. Unfortunately I don't have a scope to monitor continuously, but if AC-IN voltage drops were affecting 1Gbps communications, I'd expect them to equally affect 100Mbps communications and that is not the case. So the issue with my board doesn't seem to be caused by PHY input voltage fluctuations.
However, there is a noticeable difference in the amount of packet loss with different power sources:
1. laptop USB, so <500mA, 2 feet USB cable
PC -> SBC: 30% loss
SBC -> PC: 36% loss
2. AC 5V/2A adapter, 6 feet USB cable
PC -> SBC: 5% loss
SBC -> PC: 11% loss
3. AC 5V/3A adapter, 3 feet USB cable
PC -> SBC: 15% loss
SBC -> PC: 31% loss
I'd speculate that there's possibly another element sensitive to AC input inconsistencies that might not be conditioned by the PMIC or that may have a narrow tolerance range. Alternatively, PINE64+ PCB layout might not be strictly following guidelines for RTL8211E IC as set forth in PHY DS, resulting in EMI affecting its operation or VDD10 conditioned input being outside of a narrow 0.95V to 1.06V tolerance range.
References:
PHY DS - http://files.pine64.org/doc/datasheet/pine64/rtl8211e(g)-vb(vl)-cg_datasheet_1.6.pdf
PMIC DS - http://files.pine64.org/doc/datasheet/pine64/AXP803_Datasheet_V1.0.pdf
So I've fiddled around with EMAC IC and its RGMII interface to PHY IC.
Some findings:
1. MII RXERC = 0 in mii-tool reg dump, supposedly that indicates PHY is not receiving erroneous frames
#mii-tool -vvv
  registers for MII PHY 0:
    1140 796d 001c c915 01e1 cde1 000d 2001
    6801 0300 7800 0000 0000 0000 0000 3000
    016e acc2 9f01 0000 8040 1006 4100 2100
    0000 8c00 0040 0106 21fc 8038 0123 0000
2. EMAC reports RGMII speed/duplex and clock is consistent with PHY link type
1Gbps/full:
EMAC BASIC_CTL_0:
#devmem2 0x1c30000 w
0x1 = 1Gbps/full
EMAC RGMII_STA:
#devmem2 0x1c300d0 w
0xD = 0b1101 - 1Gbps, 125MHz clock
MII PHY:
#mii-tool -vvv
    1140 796d 001c c915 0001 cde1 000f 2001
    6801 0200 7800 0000 0000 0000 0000 3000
    016e acc2 9f01 6c52 8040 1006 4100 2100
100Mbps/full:
EMAC BASIC_CTL_0:
0xD = 100Mbps/full
EMAC RGMII_STA:
0xB = 0b1011 - 100Mbps, 25MHz clock
MII PHY:
#mii-tool -vvv
3. EMAC is using internal clock for 1Gbps/125MHz
A64 EMAC_CLK_REG:
#devmem2 0x1c00030 w
clock 0b01 = GMII/RGMII external
clock 0b10 = GMII/RGMII internal (default)
This said, there could be a problem with 125MHz clock sync, required for proper RGMII communication between EMAC and PHY at 1Gbps rate. Judging by latest PCB diagrams, PHY CLK125 is attached to EMAC, presumably to supply 125MHz clock to EMAC, however EMAC's internal clock is enabled (by the EMAC driver?), so EMAC and PHY clocks are not synchronized. However, switching to external clock (supplied by PHY?) results in even higher packet loss, upwards of 80%
I was trying to dump EMAC DMA TX/RX descriptors and buffers to get an idea of whether frames received by PHY make it to EMAC over RGMII and vice versa, but so far didn't manage to access them from userland. I guess it would take to debug EMAC driver to monitor them and accumulate TX/RX frames and errors statistics.
in the mainline kernel, and I get the data in power from the GPIO.
The output of the power supply adapter is 5V/3A is written.
[  4] local 192.168.122.176 port 38366 connected to 192.168.122.223 port 5201
[  4]   0.00-1.00   sec  57.6 MBytes   483 Mbits/sec   17    253 KBytes
[  4]   1.00-2.00   sec  56.2 MBytes   471 Mbits/sec  127    253 KBytes
[  4]   2.00-3.00   sec  55.9 MBytes   469 Mbits/sec  129    247 KBytes
[  4]   3.00-4.00   sec  55.8 MBytes   468 Mbits/sec  194    180 KBytes
[  4]   4.00-5.00   sec  56.2 MBytes   471 Mbits/sec  183    167 KBytes
[  4]   5.00-6.00   sec  56.4 MBytes   473 Mbits/sec    0    256 KBytes
[  4]   6.00-7.00   sec  56.4 MBytes   473 Mbits/sec  165    236 KBytes
[  4]   7.00-8.00   sec  55.7 MBytes   468 Mbits/sec  208    180 KBytes
[  4]   8.00-9.00   sec  55.7 MBytes   467 Mbits/sec   80    181 KBytes
[  4]   9.00-10.00  sec  56.8 MBytes   476 Mbits/sec    0    256 KBytes
[  4]   0.00-10.00  sec   563 MBytes   472 Mbits/sec  1103             sender
[  4]   0.00-10.00  sec   561 MBytes   471 Mbits/sec                  receiver
iperf Done.
So, I know it isn't comparing apples with apples, but I just have to post this as it shows the GbE on the pine64 can indeed move when it wants too...
I finally reformatted my USB flash drive as btrfs, and made a zeroed 1G file as you suggested earlier (with compression on). I'd started armbian up again a youtube upload for tonight, so thought I'd make that file first,and then see what the transfer speed was like. I'm copying to the same desktop computer as before, but it's booted in to windows (I know, you won't like it) this time (dual-boot), and it was... fast... damn near missed getting the screenshot!
Well, it has been already known that Pine64+ is capable of exceeding 80 MB/s based on 'raw' iperf3 numbers (only one person needed to be convinced, thanks for doing the job). It would be great if you could grab 'Helios LanTest' (available at http://webshare.helios.de user 'tools', pwd 'tools') and run each 3 times with the settings for 'Very fast' and 'Enterprise' networks.
And while this sort of test using btrfs compression is somewhat useless since it only demonstrates what's possible if storage isn't the bottleneck (but most of the time disk IO will be the bottleneck since we're limited by USB 2.0) it gives also a nice preview of what will be possible later when mainline kernel is ready (and EMAC driver further improves) or when Pine64+ runs completely from fast network storage (since GbE is the fastest interface available on A64 this makes perfectly sense)
This what you wanted?
Exactly, I was especially interested in those little orange arrows (in case you ever test again with LanTest please mouse over a bar with huge variations and see what happens). Thanks!
BTW: Reasons why Explorer is capable of sucking more out of Pine64's Ethernet port here: http://www.helios.de/web/EN/support/TI/157.html
lol... sound about right... another file management tool I use does exactly the same thing... uses multiple I/O threads, and also uses larger buffers for certain transfers (i.e. drive to drive, or via network IIRC). I'll throw that in just for fun... and also the reverse direction file copy... the 1gb of zeros TO the pine64 this time... looks like the brtfs is pretty happy to compress that puppy down as it goes... so happy in fact that I don't see the USB lighting up much during the transfer :-) So it will be interesting to see what happens once the dual USB opens up. I will say that after transferring of the the more typical data types (for me anyway - some 270MB of uni assessments and notes, and about 250MB worth of PDF datasheets)... it processed very quickly...  It it understandably fell over the zillions of small files that were in a 2.1GB datasheet... (there were a heck of a lot of small c files in it) and was dropping to 10MB/s speeds... but picking up again when hitting some big files (bottom sceenshot).
And on a repeat run of LanTest on GbE, the measurement with the biggest swing was the 'write 300MB to file' test again, with a AVG as 52.7 MB/s, and the min and max in the tooltip were 51.2MB/s and 67.4MB/s. The read 300MB/s test only had about a 2MB/s swing... (65.0 - 67.4), and all the others really didn't have too much separation ether.
Small note: Since TL Lim said he will send an LCD to me, I just had a look what seems to be necessary to support the LCD in Linux (ayufan's commits from Sep 11, 2016 here). Looks like the usual adjustments we know from Allwinner BSP since ages (this time in DT and not in fex any more):
            screen0_output_type = <0x00000001>;
            screen0_output_mode = <0x00000004>;
            screen1_output_type = <0x00000003>;
            screen1_output_mode = <0x00000004>;
            lcd_used = <0x00000001>;
Of course in boot_disp section also switching from HDMI to LCD necessary:
And for the touch:
        ctp {
            device_type = "ctp";
            compatible = "allwinner,sun50i-ctp-para";
            status = "okay";
            ctp_used = <0x00000001>;
            ctp_name = "gt911_DB2";
            ctp_twi_id = <0x00000000>;
            ctp_twi_addr = <0x00000040>;
            ctp_screen_max_x = <0x00000400>;
            ctp_screen_max_y = <0x00000258>;
            ctp_revert_x_flag = <0x00000001>;
            ctp_revert_y_flag = <0x00000001>;
When I played around with NanoPI M3 I realized that FriendlyARM uses code in u-boot to detect a connected LCD and then configures the kernel correctly (via cmdline there). Wonder whether this is also possible with Pine64...
Nice, just discovered the Azpen Hybrx A64 laptop starting at $69: http://hybrxpc.com/about-hybrx/(combining an A64 board with cheap and most probably ultra glossy 1366x768 LCD and starting with 1 GB DRAM and 16 GB flash). In case it's eMMC it should be possible to flash Armbian to it through USB/FEL...
LOL, the same person (Charbax) showcases Allwinner's reference design and 5 months later the very same device in pink (known as Azpen Hybrx now).
Update: TL Lim from Pine64 sent out a couple of hardware: 3 Pine64+ 2GB, WiFi/BT modules, one 7" LCD and a camera module.
I only had time to check for the GbE issue (only one Pine64+ affected so two are working!) and LCD. Works flawlessly with Android 7.0 (checked only whether Android on Pine64 now behaves like Armbian and resizes the image on first boot -- check!) but not with Linux in my few tests with Armbian legacy build, the board simply freezes or even powers down with LCD connected. It seems we have an AXP803 PMIC problem with legacy u-boot/kernel here since this occurs even without DT modifications.
Edit: Below first our legacy image freezing (with DT modification to activate LCD) and then most recent Android 7.0 image booting:
Armbian legacy:
boot0 version : 4.0.0
set pll start
set pll end
rtc[0] value = 0x00000000
rtc[1] value = 0x000000001c10000.sdmmc: smc 1 p1 err, cmd 5
rtc[2] value = 0x000000001c10000.sdmmc: smc 1 p1 err, cmd 5
rtc[3] value = 0x000000001c10000.sdmmc: smc 1 p1 err, cmd 5
rtc[4] value = 0x000000001c10000.sdmmc: smc 1 p1 err, cmd 5
rtc[5] value = 0x000000001c10000.sdmmc: sdc set ios: clk 40
DRAM driver version: V1.1
rsb_send_initseq: rsb clk 400Khz -> 3Mhz
PMU: AXP81X
ddr voltage = 1500 mv
DRAM Type = 3 (2:DDR2,3:DDR3,6:LPDDR2,7:LPDDR3)
DRAM clk = 672 MHz
DRAM zq value: 003b3bbb
DRAM single rank full DQ OK
DRAM size = 2048 MB
DRAM init ok
dram size =2048
card boot number = 0, boot0 copy = 0
card no is 0
sdcard 0 line count 4
[mmc]: mmc driver ver 2015-05-08 20:06
[mmc]: sdc0 spd mode error, 2
[mmc]: Wrong media type 0x00000000
[mmc]: ***Try SD card 0***
[mmc]: HSSDR52/SDR25 4 bit
[mmc]: 50000000 Hz
[mmc]: 7580 MB
[mmc]: ***SD/MMC 0 init OK!!!***
sdcard 0 init ok
The size of uboot is 000e4000.
sum=5ea832be
src_sum=5ea832be
Succeed in loading uboot from sdmmc flash.
boot0: start load other image
boot0: Loading BL3-1
Loading file 0 at address 0x40000000,size 0x0000a200 success
boot0: Loading scp
Loading file 2 at address 0x00040000,size 0x00019a00 success
set arisc reset to de-assert state
Ready to disable icache.
?  Configuring SPC Controller
NOTICE:  BL3-1: v1.0(debug):e9fc343
NOTICE:  BL3-1: Built : 18:48:04, Aug 31 2016
INFO:    BL3-1: Initializing runtime services
INFO:    BL3-1: Preparing for EL3 exit to normal world
INFO:    BL3-1: Next image address = 0x4a000000
INFO:    BL3-1: Next image spsr = 0x1d3
U-Boot 2014.07-4-pine64-g55c9c8c-dirty (Aug 31 2016 - 18:48:04) Allwinner Technology
uboot commit : 55c9c8c8ac005b1c00ac948386c60c4a741ebaa9
rsb: secure monitor exist
[      0.380]pmbus:   ready
[      0.382][ARISC] :arisc initialize
[      0.710][ARISC] :arisc_dvfs_cfg_vf_table: support only one vf_table
[SCP] :sunxi-arisc driver begin startup 2
[SCP] :arisc_para size:1a8
[SCP] :arisc version: [v0.1.76]
[SCP] :sunxi-arisc driver v1.10 is starting
[      0.837][ARISC] :sunxi-arisc driver startup succeeded
[      0.870]PMU: AXP81X
[      0.872]PMU: AXP81X found
bat_vol=304, ratio=100
[      0.879]PMU: dcdc2 1100
[      0.882]PMU: cpux 1008 Mhz,AXI=336 Mhz
PLL6=600 Mhz,AHB1=200 Mhz, APB1=100Mhz AHB2=300Mhz MBus=400Mhz
device_type = 3253, onoff=1
dcdc1_vol = 3300, onoff=1
dcdc2_vol = 1100, onoff=1
dcdc6_vol = 1100, onoff=1
aldo1_vol = 2800, onoff=0
aldo2_vol = 1800, onoff=1
aldo3_vol = 3000, onoff=1
dldo1_vol = 3300, onoff=0
dldo2_vol = 3300, onoff=0
dldo3_vol = 2800, onoff=0
dldo4_vol = 3300, onoff=1
eldo1_vol = 1800, onoff=1
eldo2_vol = 1800, onoff=0
eldo3_vol = 1800, onoff=0
fldo1_vol = 1200, onoff=0
fldo2_vol = 1100, onoff=1
gpio0_vol = 3100, onoff=0
vbus not exist
no battery, limit to dc
run key detect
no key found
no uart input
DRAM:  2 GiB
fdt addr: 0xb6ebf0c0
Relocation Offset is: 75f11000
In:    serial
Out:   serial
Err:   serial
gic: sec monitor mode
[      1.691]start
drv_disp_init
init_clocks: finish init_clocks.
enable power vcc-hdmi-33, ret=0
drv_disp_init finish
boot_disp.output_disp=0
boot_disp.output_type=3
boot_disp.output_mode=10
fetch script data boot_disp.auto_hpd fail
disp0 device type(4) enable
attched ok, mgr0<-->device1, type=4, mode=10
[      2.066]end
workmode = 0,storage type = 1
[      2.070]MMC:        0
[mmc]: mmc driver ver 2015-06-03 13:50:00
WARNING: Unimplemented Standard Service Call: 0x8000ff05
WARNING: Unimplemented Standard Service Call: 0x8000ff06
SUNXI SD/MMC: 0
[mmc]: start mmc_calibrate_delay_unit, don't access device...
[mmc]: delay chain cal done, sample: 185(ps)
[mmc]: media type 0x0
[mmc]: ************Try SD card 0************
[mmc]: host caps: 0x27
[mmc]: MID 03 PSN 437635a9
[mmc]: PNM SL08G -- 0x53-4c-30-38-47
[mmc]: PRV 8.0
[mmc]: MDT m-7 y-2015
[mmc]: speed mode     : HSSDR52/SDR25
[mmc]: clock          : 50000000 Hz
[mmc]: bus_width      : 4 bit
[mmc]: user capacity  : 7580 MB
[mmc]: ************SD/MMC 0 init OK!!!************
[mmc]: erase_grp_size      : 0x1WrBlk*0x200=0x200 Byte
[mmc]: secure_feature      : 0x0
[mmc]: secure_removal_type : 0x0
[      2.311]sunxi flash init ok
[mmc]: Has init
[      2.345]---drivers/mmc/mmc.c 2733 mmc_init
** Unable to use mmc 0:1 for loading the env **
Using default environment
--------fastboot partitions--------
mbr not exist
base bootcmd=run mmcbootcmd
bootcmd set setargs_mmc
key 0
recovery key high 12, low 10
fastboot key high 6, low 4
no misc partition is found
to be run cmd=run mmcbootcmd
update dtb dram start
update dtb dram  end
serial is: ffffffffffffffffffff
get Pine64 model from DRAM size
DRAM >512M
Pine64 model: pine64-plus
no battery exist
sunxi_bmp_logo_display
[mmc]: Has init
[      2.568]---drivers/mmc/mmc.c 2733 mmc_init
** Unrecognized filesystem type **
sunxi bmp info error : unable to open logo file bootlogo.bmp
[      2.582]inter uboot shell
[mmc]: Has init
[      5.697]---drivers/mmc/mmc.c 2733 mmc_init
26 bytes read in 27 ms (0 Bytes/s)
Loading boot environment ...
[mmc]: Has init
[      5.740]---drivers/mmc/mmc.c 2733 mmc_init
1601 bytes read in 13 ms (120.1 KiB/s)
Booting with script ...
## Executing script at 41000000
[mmc]: Has init
[      5.778]---drivers/mmc/mmc.c 2733 mmc_init
** File not found /boot/.next **
[mmc]: Has init
[      5.804]---drivers/mmc/mmc.c 2733 mmc_init
[mmc]: Has init
[      5.813]---drivers/mmc/mmc.c 2733 mmc_init
** File not found .next **
[mmc]: Has init
[      5.840]---drivers/mmc/mmc.c 2733 mmc_init
69084 bytes read in 18 ms (3.7 MiB/s)
[mmc]: Has init
[      5.868]---drivers/mmc/mmc.c 2733 mmc_init
3789808 bytes read in 210 ms (17.2 MiB/s)
[mmc]: Has init
[      6.090]---drivers/mmc/mmc.c 2733 mmc_init
11730096 bytes read in 618 ms (18.1 MiB/s)
Image lacks image_size field, assuming 16MiB
## Loading init Ramdisk from Legacy Image at 45300000 ...
   Image Name:   uInitrd
   Image Type:   ARM Linux RAMDisk Image (gzip compressed)
   Data Size:    3789744 Bytes = 3.6 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 45000000
   Booting using the fdt blob at 0x45000000
   reserving fdt memory region: addr=45000000 size=200000
   reserving fdt memory region: addr=41010000 size=10000
   reserving fdt memory region: addr=41020000 size=800
   reserving fdt memory region: addr=40100000 size=4000
   reserving fdt memory region: addr=40104000 size=1000
   reserving fdt memory region: addr=40105000 size=1000
   Loading Ramdisk to b6b1d000, end b6eba3b0 ... OK
   Loading Device Tree to 44fec000, end 44fffddb ... OK
Starting kernel ...
[mmc]: MMC Device 2 not found
[mmc]: mmc 2 not find, so not exit
INFO:    BL3-1: Next image address = 0x41080000
INFO:    BL3-1: Next image spsr = 0x3c9
Loading, please wait...
Begin: Loading essential drivers ... done.
Begin: Running /scripts/init-premount ... done.
Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done.
Begin: Running /scripts/local-premount ...
Android 7.0:
set pll start
set pll end
PMU: AXP81X
DRAM clk = 672 MHz
DRAM size = 2048 MB
DRAM init ok
dram size =2048
card no is 0
[mmc]: 50000000 Hz
[mmc]: 7580 MB
sdcard 0 init ok
The size of uboot is 000e8000.
sum=832e0b41
src_sum=832e0b41
Loading file 0 at address 0x40000000,size 0x00008400 success
boot0: Loading scp
Loading file 2 at address 0x00040000,size 0x00019c00 success
Jump to secend Boot.
U-Boot 2014.07-6-pine64-longsleep (Jun 18 2016 - 16:15:13) Allwinner Technology
[      0.363]pmbus:   ready
[      0.365][ARISC] :arisc initialize
[      0.693][ARISC] :arisc_dvfs_cfg_vf_table: support only one vf_table
[      0.807][ARISC] :sunxi-arisc driver startup succeeded
[      0.840]PMU: AXP81X
[      0.842]PMU: AXP81X found
bat_vol=330, ratio=100
[      0.849]PMU: dcdc2 1100
[      0.852]PMU: cpux 1008 Mhz,AXI=336 Mhz
vbus not exist
run key detect
no key found
no uart input
DRAM:  2 GiB
fdt addr: 0xb6ebf0a0
In:    serial
Out:   serial
Err:   serial
[      1.662]start
drv_disp_init
[      2.033]end
[      2.037]MMC:        0
SUNXI SD/MMC: 0
[mmc]: MID 03 PSN 49e841fe
[mmc]: PRV 8.0
[mmc]: MDT m-6 y-2016
[      2.243]sunxi flash init ok
[mmc]: Has init
[      2.276]---drivers/mmc/mmc.c 2733 mmc_init
reading uboot.env
** Unable to read "uboot.env" from mmc0:1 **
mbr not exist
key 0
update dtb dram  end
serial is: 0410519008081422060e
DRAM >512M
no battery exist
[mmc]: Has init
[      2.477]---drivers/mmc/mmc.c 2733 mmc_init
** Unable to read file bootlogo.bmp **
[      2.493]inter uboot shell
[mmc]: Has init
[      5.605]---drivers/mmc/mmc.c 2733 mmc_init
reading uEnv.txt
[mmc]: blkcnt should not be 0
238 bytes read in 9 ms (25.4 KiB/s)
[mmc]: Has init
[      5.628]---drivers/mmc/mmc.c 2733 mmc_init
reading boot.scr
305 bytes read in 6 ms (48.8 KiB/s)
[mmc]: Has init
[      5.657]---drivers/mmc/mmc.c 2733 mmc_init
reading pine64/sun50i-a64-lcd-pine64-plus.dtb
69427 bytes read in 11 ms (6 MiB/s)
[mmc]: Has init
[      5.714]---drivers/mmc/mmc.c 2733 mmc_init
reading kernel
11165776 bytes read in 545 ms (19.5 MiB/s)
[mmc]: Has init
[      6.270]---drivers/mmc/mmc.c 2733 mmc_init
reading ramdisk.img
5862981 bytes read in 289 ms (19.3 MiB/s)
   reserving fdt memory region: addr=45000000 size=11000
   Loading Ramdisk to b6920000, end b6eb7645 ... OK
   Loading Device Tree to 44feb000, end 44ffefff ... OK
Starting kernel ...
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 3.10.65+ (root@android-7.0-pine64-squashfs-4gb-ams6
[    0.000000] CPU: AArch64 Processor [410fd034] revision 4
[    0.000000] Machine: sun50iw1p1
[    0.000000] bootconsole [earlycon0] enabled
[    0.000000] cma: CMA: reserved 384 MiB at 9e800000
[    0.000000] On node 0 totalpages: 520192
[    0.000000]   DMA zone: 7112 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 520192 pages, LIFO batch:31
[    0.000000] script_init enter!
[    0.000000] script_init exit!
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv0.2 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] PERCPU: Embedded 12 pages/cpu @ffffffc07ef92000 s20288 r8192 d202
[    0.000000] pcpu-alloc: s20288 r8192 d20672 u49152 alloc=12*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pa0
[    0.000000] Kernel command line: console=ttyS0,115200n8 enforcing=0 cma=384M2
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.000000] Memory: 2032MB = 2032MB total
[    0.000000] Memory: 1637328k/1637328k available, 443440k reserved
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vmalloc : 0xffffff8000000000 - 0xffffffbbffff0000   (245759 )
[    0.000000]     vmemmap : 0xffffffbc00e38000 - 0xffffffbc02a00000   (    27 )
[    0.000000]     modules : 0xffffffbffc000000 - 0xffffffc000000000   (    64 )
[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc07f000000   (  2032 )
[    0.000000]       .init : 0xffffffc0009f5000 - 0xffffffc000a77f40   (   524 )
[    0.000000]       .text : 0xffffffc000080000 - 0xffffffc0009f45d4   (  9682 )
[    0.000000]       .data : 0xffffffc000a78000 - 0xffffffc000b26050   (   697 )
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] Console: colour dummy device 80x25
[    8.589275] Calibrating delay loop (skipped), value calculated using timer f)
[    8.599414] pid_max: default: 32768 minimum: 301
[    8.604398] Security Framework initialized
[    8.607962] SELinux:  Initializing.
[    8.611425] SELinux:  Starting in permissive mode
[    8.616241] Mount-cache hash table entries: 256
[    8.622396] Initializing cgroup subsys debug
[    8.624574] Initializing cgroup subsys freezer
[    8.629193] ftrace: allocating 24867 entries in 98 pages
[    8.665547] CPU0: update cpu_power 1968128
[    8.665579] hw perfevents: enabled with arm/armv8-pmuv3 PMU driver, 7 countee
[    8.673692] virtual base = 0xffffff800000a000.
[    8.676438] gicd_base = 0xffffff800000c000.
[    8.680577] gicc_base = 0xffffff800000e000.
[    8.686852] CPU1: Booted secondary processor
[    8.686875] CPU1: update cpu_power 1968128
[    8.689477] CPU2: Booted secondary processor
[    8.689491] CPU2: update cpu_power 1968128
[    8.693595] CPU3: Booted secondary processor
[    8.693608] CPU3: update cpu_power 1968128
[    8.693689] Brought up 4 CPUs
[    8.715640] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[    8.723055] devtmpfs: initialized
[    8.755517] atomic64 test passed
[    8.755541] pinctrl core: initialized pinctrl subsystem
[    8.771192] NET: Registered protocol family 16
[    8.771776] script_sysfs_init success
[    8.776261] dump_class_init,806, success
[    8.778877] vdso: 2 pages (1 code, 1 data) at base ffffffc000a7d000
[    8.783597] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    8.791501] software IO TLB [mem 0xbd000000-0xbd400000] (4MB) mapped at [fff]
[    8.800993] DMA: preallocated 256 KiB pool for atomic allocations
[    8.806638] axp81x_board_init: axp regl_devs num = 23
[    8.811059] pll_audio-set_default_rate=24576000 success!
[    8.815928] pll_video0-set_default_rate=297000000 success!
[    8.821388] pll_video1-set_default_rate=297000000 success!
[    8.826741] pll_de-set_default_rate=297000000 success!
[    8.832807] de-set_default_source=pll_de success!
[    8.836283] de-set_default_rate=297000000 success!
[    8.841036] tcon0-set_default_source=pll_mipi success!
[    8.846052] tcon1-set_default_source=pll_video0 success!
[    8.851512] hdmi-set_default_source=pll_video0 success!
[    8.860156] sun50i-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
[    8.863454] [sun50iw1p1_pinctrl_probe][838]
[    8.870000] sun50i-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    8.876532] sunxi hwspinlock vbase:0xffffff800005c000
[    8.899255] sunxi_chipid_probe,150: soc bin:0
[    8.956323] bio: create slab <bio-0> at 0
[    8.957425] pwm module init!
[    8.962675] SCSI subsystem initialized
[    8.965888] usbcore: registered new interface driver usbfs
[    8.966804] usbcore: registered new interface driver hub
[    8.972083] usbcore: registered new device driver usb
[    8.979157] Linux video capture interface: v2.00
[    8.983423] [ARISC] :sunxi-arisc driver v1.10
[    9.006441] [ARISC] :sunxi-arisc driver v1.10 startup succeeded
[    9.007423] Advanced Linux Sound Architecture Driver Initialized.
[    9.014144] Bluetooth: Core ver 2.16
[    9.016397] NET: Registered protocol family 31
[    9.020534] Bluetooth: HCI device and connection manager initialized
[    9.026801] Bluetooth: HCI socket layer initialized
[    9.031558] Bluetooth: L2CAP socket layer initialized
[    9.036533] Bluetooth: SCO socket layer initialized
[    9.043959] cfg80211: Calling CRDA to update world regulatory domain
[    9.048320] [pm]aw_pm_init!
[    9.050283] rtc physical base = 0x0000000001f00000 .
[    9.055216] np name = /soc@01c00000/rtc@01f00000.
[    9.059849] base = ffffff8000070100, len = 4.
[    9.064112] pmu name: pmu0 .
[    9.066975] pmu0_enable = 0x1.
[    9.069998] pmux_id = 0x6.
[    9.072727] pmux_twi_id = 0x1.
[    9.075796] pmux_twi_addr = 0x34.
[    9.079130] pmu name: pmu1 .
[    9.081989] Warning: can not find np for pmu1.
[    9.086609] add_sys_pwr_dm: get ldo name  for id: vcc-lpddr failed
[    9.092585] after inited: sys_mask config = 0x4a55.
[    9.097307] Warning: can not find np for dynamic_standby_para.
[    9.103214] [pm]valid
[    9.105301] [pm]valid
[    9.107519] Notice: sun9i&sun8iw5&sun50i not need support normal standby,   .
[    9.116952] Switching to clocksource arch_sys_counter
[    9.164628] FS-Cache: Loaded
[    9.165176] CacheFiles: Loaded
[    9.189481] get det_vbus is fail, 84
[    9.192931] NET: Registered protocol family 2
[    9.194452] TCP established hash table entries: 16384 (order: 6, 262144 byte)
[    9.199081] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[    9.205589] TCP: Hash tables configured (established 16384 bind 16384)
[    9.212867] TCP: reno registered
[    9.214837] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[    9.220781] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[    9.227863] NET: Registered protocol family 1
[    9.232289] Unpacking initramfs...
[    9.533089] Freeing initrd memory: 5724K (ffffffc075920000 - ffffffc075eb700)
[    9.536578] lock super standby defaultly!
[    9.538576] lookup_scene_lock_name: new scene lock super_standby
[    9.544453] scene_lock_init name=super_standby
[    9.548822] scene_lock: super_standby, type 5, count 1
[    9.555152] audit: initializing netlink socket (disabled)
[    9.559203] type=2000 audit(0.890:1): initialized
[    9.568739] NTFS driver 2.1.30 [Flags: R/W].
[    9.569022] fuse init (API version 7.22)
[    9.572861] msgmni has been set to 3977
[    9.575638] SELinux:  Registering netfilter hooks
[    9.582167] NET: Registered protocol family 38
[    9.584529] io scheduler noop registered
[    9.588287] io scheduler deadline registered
[    9.592572] io scheduler cfq registered (default)
[    9.599195] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI
[    9.602969] sw_console_setup()1173 - console setup baud 115200 parity n bitsn
[    9.610808] console [ttyS0] enabled, bootconsole disabled
[    9.623008] uart1: ttyS1 at MMIO 0x1c28400 (irq = 33) is a SUNXI
[    9.634680] uart2: ttyS2 at MMIO 0x1c28800 (irq = 34) is a SUNXI
[    9.641904] uart3: ttyS3 at MMIO 0x1c28c00 (irq = 35) is a SUNXI
[    9.649129] uart4: ttyS4 at MMIO 0x1c29000 (irq = 36) is a SUNXI
[    9.656540] misc dump reg init
[    9.667845] loop: module loaded
[    9.671612] sunxi-bt bt.29: Missing bt_power.
[    9.676389] sunxi-bt bt.29: bt_power_name ((null))
[    9.681624] sunxi-bt bt.29: io_regulator_name (vcc-wifi-io)
[    9.687749] sunxi-bt bt.29: bt_rst gpio=356  mul-sel=1  pull=-1  drv_level=-0
[    9.696350] sunxi-bt bt.29: clk not config
[    9.701128] sunxi-bt bt.29: block state already is 1
[    9.707012] sunxi-wlan wlan.28: wlan_busnum (1)
[    9.711959] sunxi-wlan wlan.28: Missing wlan_power.
[    9.717298] sunxi-wlan wlan.28: wlan_power_name ((null))
[    9.723112] sunxi-wlan wlan.28: io_regulator_name (vcc-wifi-io)
[    9.729604] sunxi-wlan wlan.28: wlan_regon gpio=354  mul-sel=1  pull=-1  drv0
[    9.738956] sunxi-wlan wlan.28: wlan_hostwake gpio=355  mul-sel=6  pull=-1  0
[    9.748587] sunxi-wlan wlan.28: clk not config
[    9.756686] tun: Universal TUN/TAP device driver, 1.6
[    9.762223] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    9.770087] WARNING: Get ephy clock is failed
[    9.775879] geth_check_addr
[    9.778926] geth_check_addr: try to use mac str, 00:00:00:00:00:00
[    9.785686] chipid 0x4,0x10,0x51,0x90,0x8,0x8,0x14,0x22,0x6,0xe,
[    9.792331] result 0xfc,0xa,0xe3,0x97,0x75,0x19,0x0,0x4e,0xe,0x78,
[    9.799117] addr 0x0,0x6,0xdc,0x97,0x75,0x19,
[    9.803909] try to use hwaddr 0x0,0x6,0xdc,0x97,0x75,0x19,
[    9.810200] PPP generic driver version 2.4.2
[    9.815584] PPP BSD Compression module registered
[    9.820739] PPP Deflate Compression module registered
[    9.826265] PPP MPPE Compression module registered
[    9.831504] NET: Registered protocol family 24
[    9.836401] PPTP driver version 0.8.5
[    9.840666] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    9.848016] get ehci0-controller drv_vbus_gpio is fail
[    9.853638] get ehci0-controller, regulator_io is no nocare
[    9.859785] [sunxi-ehci0]: probe, pdev->name: 1c1a000.ehci0-controller, sunx8
[    9.873062] sunxi-ehci 1c1a000.ehci0-controller: SW USB2.0 'Enhanced' Host Cr
[    9.882974] sunxi-ehci 1c1a000.ehci0-controller: new USB bus registered, ass1
[    9.892907] sunxi-ehci 1c1a000.ehci0-controller: irq 104, io mem 0xffffffc00c
[    9.918684] sunxi-ehci 1c1a000.ehci0-controller: USB 0.0 started, EHCI 1.00
[    9.926414] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    9.933842] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber1
[    9.941741] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Dr
[    9.949924] usb usb1: Manufacturer: Linux 3.10.65+ ehci_hcd
[    9.956010] usb usb1: SerialNumber: sunxi-ehci
[    9.962019] hub 1-0:1.0: USB hub found
[    9.966142] hub 1-0:1.0: 1 port detected
[    9.970725] scene_lock_init name=ehci_standby
[    9.975591] get ehci1-controller drv_vbus_gpio is fail
[    9.981213] get ehci1-controller, regulator_io is no nocare
[    9.987350] [sunxi-ehci1]: probe, pdev->name: 1c1b000.ehci1-controller, sunxa
[   10.000632] sunxi-ehci 1c1b000.ehci1-controller: SW USB2.0 'Enhanced' Host Cr
[   10.010544] sunxi-ehci 1c1b000.ehci1-controller: new USB bus registered, ass2
[   10.020354] sunxi-ehci 1c1b000.ehci1-controller: irq 106, io mem 0xffffffc00c
[   10.046603] sunxi-ehci 1c1b000.ehci1-controller: USB 0.0 started, EHCI 1.00
[   10.054329] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[   10.061757] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber1
[   10.069695] usb usb2: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Dr
[   10.077881] usb usb2: Manufacturer: Linux 3.10.65+ ehci_hcd
[   10.083966] usb usb2: SerialNumber: sunxi-ehci
[   10.089729] hub 2-0:1.0: USB hub found
[   10.093844] hub 2-0:1.0: 1 port detected
[   10.098427] scene_lock_init name=ehci_standby
[   10.103565] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[   10.110525] get ohci0-controller drv_vbus_gpio is fail
[   10.116145] get ohci0-controller, regulator_io is no nocare
[   10.122282] [sunxi-ohci0]: probe, pdev->name: 1c1a000.ohci0-controller, sunx0
[   10.132521] sunxi-ohci 1c1a000.ohci0-controller: SW USB2.0 'Open' Host Contrr
[   10.142063] sunxi-ohci 1c1a000.ohci0-controller: new USB bus registered, ass3
[   10.151546] sunxi-ohci 1c1a000.ohci0-controller: irq 105, io mem 0xffffffc008
[   10.217929] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[   10.225356] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber1
[   10.233246] usb usb3: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.241050] usb usb3: Manufacturer: Linux 3.10.65+ ohci_hcd
[   10.247145] usb usb3: SerialNumber: sunxi-ohci
[   10.252883] hub 3-0:1.0: USB hub found
[   10.257021] hub 3-0:1.0: 1 port detected
[   10.261586] scene_lock_init name=ohci_standby
[   10.266461] get ohci1-controller drv_vbus_gpio is fail
[   10.272071] get ohci1-controller, regulator_io is no nocare
[   10.278212] [sunxi-ohci1]: probe, pdev->name: 1c1b000.ohci1-controller, sunx0
[   10.288447] sunxi-ohci 1c1b000.ohci1-controller: SW USB2.0 'Open' Host Contrr
[   10.297978] sunxi-ohci 1c1b000.ohci1-controller: new USB bus registered, ass4
[   10.307457] sunxi-ohci 1c1b000.ohci1-controller: irq 107, io mem 0xffffffc008
[   10.375371] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[   10.382799] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber1
[   10.390688] usb usb4: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   10.398493] usb usb4: Manufacturer: Linux 3.10.65+ ohci_hcd
[   10.404587] usb usb4: SerialNumber: sunxi-ohci
[   10.410312] hub 4-0:1.0: USB hub found
[   10.414440] hub 4-0:1.0: 1 port detected
[   10.418997] scene_lock_init name=ohci_standby
[   10.424466] usbcore: registered new interface driver cdc_acm
[   10.430657] cdc_acm: USB Abstract Control Model driver for USB modems and ISs
[   10.439690] usbcore: registered new interface driver usb-storage
[   10.446465] usbcore: registered new interface driver ums-alauda
[   10.453140] usbcore: registered new interface driver ums-cypress
[   10.459960] usbcore: registered new interface driver ums-datafab
[   10.466714] usbcore: registered new interface driver ums_eneub6250
[   10.473668] usbcore: registered new interface driver ums-freecom
[   10.480451] usbcore: registered new interface driver ums-isd200
[   10.487114] usbcore: registered new interface driver ums-jumpshot
[   10.493976] usbcore: registered new interface driver ums-karma
[   10.500545] usbcore: registered new interface driver ums-onetouch
[   10.507423] usbcore: registered new interface driver ums-realtek
[   10.514233] usbcore: registered new interface driver ums-sddr09
[   10.520905] usbcore: registered new interface driver ums-sddr55
[   10.527567] usbcore: registered new interface driver ums-usbat
[   10.534725] usbcore: registered new interface driver usbserial
[   10.541305] usbcore: registered new interface driver option
[   10.547584] usbserial: USB Serial support registered for GSM modem (1-port)
[   10.556606] mousedev: PS/2 mouse device common for all mice
[   10.563203] usbcore: registered new interface driver xpad
[   10.569316] usbcore: registered new interface driver usb_acecad
[   10.575986] usbcore: registered new interface driver aiptek
[   10.582294] usbcore: registered new interface driver gtco
[   10.588400] usbcore: registered new interface driver hanwang
[   10.594789] usbcore: registered new interface driver kbtab
[   10.601010] usbcore: registered new interface driver wacom
[   10.609216] sunxi-rtc 1f00000.rtc: rtc core: registered rtc-sunxi as rtc0
[   10.616675] sunxi-rtc 1f00000.rtc: RTC enabled
[   10.622194] IR NEC protocol handler initialized
[   10.627150] IR RC5(x) protocol handler initialized
[   10.632379] IR RC6 protocol handler initialized
[   10.637332] IR JVC protocol handler initialized
[   10.642275] IR Sony protocol handler initialized
[   10.647326] IR RC5 (streamzap) protocol handler initialized
[   10.653409] IR SANYO protocol handler initialized
[   10.658550] IR MCE Keyboard/mouse protocol handler initialized
[   10.665388] Registered IR keymap rc_map_sunxi
[   10.671161] input: sunxi_ir_recv as /devices/soc.0/1f02000.s_cir/rc/rc0/inpu0
[   10.679611] rc0: sunxi_ir_recv as /devices/soc.0/1f02000.s_cir/rc/rc0
[   10.687213] input: MCE IR Keyboard/Mouse (sunxi-rc-recv) as /devices/virtual1
[   10.697335] sunxi cedar version 0.1
[   10.701350] [cedar]: install start!!!
[   10.705423] ycy the get irq is 90
[   10.709845] ycy clk_bass_vir 0x18  is ffffff8000150018, the value:3006207
[   10.717272] ycy clk_bass_vir 0x13c  is ffffff800015013c, the value:0
[   10.724210] ycy clk_bass_vir 0x64  is ffffff8000150064, the value:601810
[   10.731536] ycy clk_bass_vir 0x2c4  is ffffff80001502c4, the value:601c10
[   10.738957] ycy clk_bass_vir 0x100  is ffffff8000150100, the value:0
[   10.745902] [cedar]: install end!!!
[   10.785917] input: axp81x-supplyer as /devices/platform/axp81x_board/axp81x-2
[   10.810146] sunxi budget cooling probe start !
[   10.815049] CPU freq cooling register Success
[   10.819823] CPU hotplug cooling register Success
[   10.825250] CPU budget cooling register Success
[   10.830902] sunxi gpu cooling probe start !
[   10.835488] CPU gpu cooling register Success
[   10.840560] device-mapper: uevent: version 1.0.3
[   10.846139] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-m
[   10.855564] Bluetooth: HCI UART driver ver 2.2
[   10.860416] Bluetooth: HCI H4 protocol initialized
[   10.865656] Bluetooth: HCI Three-wire UART (H5) protocol initialized
[   10.875545] cpuidle: using governor ladder
[   10.880016] cpuidle: using governor menu
[   10.885387] sunxi-mmc 1c0f000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.22
[   10.898282] sunxi-mmc 1c0f000.sdmmc: regulator prop vmmc,str none
[   10.904949] sunxi-mmc 1c0f000.sdmmc: regulator prop vqmmc,str none
[   10.911701] sunxi-mmc 1c0f000.sdmmc: regulator prop vdmmc,str vcc-sdc
[   10.918849] sunxi-mmc 1c0f000.sdmmc: No vmmc regulator found
[   10.925039] sunxi-mmc 1c0f000.sdmmc: No vqmmc regulator found
[   10.931845] sunxi-mmc 1c0f000.sdmmc: Got CD GPIO #166.
[   10.937834] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21B
[   10.948788] sunxi-mmc 1c0f000.sdmmc: no vqmmc,Check if there is regulator
[   10.971559] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vB
[   11.001109] sunxi-mmc 1c0f000.sdmmc: base:0xffffff8000152000 irq:92
[   11.008389] sunxi-mmc 1c10000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.22
[   11.021272] sunxi-mmc 1c10000.sdmmc: Can't get vmmc regulator string
[   11.028211] sunxi-mmc 1c10000.sdmmc: Can't get vqmmc regulator string
[   11.035257] sunxi-mmc 1c10000.sdmmc: Can't get vdmmc regulator string
[   11.042306] get() with no identifier
[   11.046205] get() with no identifier
[   11.050102] get() with no identifier
[   11.054011] sunxi-mmc 1c10000.sdmmc: No vmmc regulator found
[   11.060207] sunxi-mmc 1c10000.sdmmc: No vqmmc regulator found
[   11.066481] sunxi-mmc 1c10000.sdmmc: No vdmmc regulator found
[   11.073497] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21B
[   11.084459] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[   11.100284] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[   11.107750] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[   11.109315] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vB
[   11.125812] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vB
[   11.129037] sunxi-mmc 1c10000.sdmmc: base:0xffffff800015a000 irq:93
[   11.146578] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vB
[   11.147026] hidraw: raw HID events driver (C) Jiri Kosina
[   11.159127] usbcore: registered new interface driver usbhid
[   11.159131] usbhid: USB HID core driver
[   11.160020] zram: Created 1 device(s) ...
[   11.179751] ashmem: initialized
[   11.180808] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   11.181620] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   11.182432] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   11.183243] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   11.183873] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vB
[   11.183930] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vB
[   11.186302] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vB
[   11.243923] logger: created 256K log 'log_main'
[   11.249188] logger: created 256K log 'log_events'
[   11.254633] logger: created 256K log 'log_radio'
[   11.256322] mmc0: host does not support reading read-only switch. assuming w.
[   11.259632] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vB
[   11.259707] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ONB
[   11.259824] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ONB
[   11.259849] mmc0: new high speed SDHC card at address aaaa
[   11.309413] logger: created 256K log 'log_system'
[   11.314586] mmcblk0: mmc0:aaaa SL08G 7.40 GiB
[   11.320973]  mmcblk0: p1 p2 p3 p4
[   11.327235] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   11.334718] sunxi-codec-machine sound.6:  codec-aif1 <-> 1c22c00.i2s0-controk
[   11.334725] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   11.334744] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vB
[   11.337149] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vB
[   11.338969] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[   11.339776] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   11.340580] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   11.341385] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   11.342189] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   11.342996] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   11.343800] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   11.344605] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   11.345409] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   11.345425] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vB
[   11.346262] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 1, RTO !!
[   11.346277] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0B
[   11.462102] sunxi-codec-machine sound.6:  codec-aif2 <-> bb-dai mapping ok
[   11.470275] sunxi-codec-machine sound.6:  codec-aif2 <-> bb-dai mapping ok
[   11.478334] sunxi-codec-machine sound.6:  codec-aif3 <-> bb-dai mapping ok
[   11.489138] input: audiocodec sunxi Audio Jack as /devices/soc.0/sound.6/sou3
[   11.499443] SUNXI_HMIC_STS:8,225
[   11.503377] sndhdmi sound.7:  sndhdmi <-> 1c22800.daudio mapping ok
[   11.512058] u32 classifier
[   11.515080] plugout_end:switch:0
[   11.518711]     Actions configured
[   11.522424] Netfilter messages via NETLINK v0.30.
[   11.527684] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[   11.534851] ctnetlink v0.93: registering with nfnetlink.
[   11.542705] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[   11.550307] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[   11.557896] xt_time: kernel timezone is -0000
[   11.562788] ipip: IPv4 over IPv4 tunneling driver
[   11.568926] gre: GRE over IPv4 demultiplexor driver
[   11.574263] ip_gre: GRE over IPv4 tunneling driver
[   11.581756] ip_tables: (C) 2000-2006 Netfilter Core Team
[   11.587983] arp_tables: (C) 2002 David S. Miller
[   11.593150] TCP: bic registered
[   11.596575] TCP: cubic registered
[   11.600181] TCP: westwood registered
[   11.604088] TCP: htcp registered
[   11.607607] Initializing XFRM netlink socket
[   11.612608] NET: Registered protocol family 10
[   11.619936] mip6: Mobile IPv6
[   11.623266] ip6_tables: (C) 2000-2006 Netfilter Core Team
[   11.629555] sit: IPv6 over IPv4 tunneling driver
[   11.636078] NET: Registered protocol family 17
[   11.641011] NET: Registered protocol family 15
[   11.646368] Bluetooth: RFCOMM TTY layer initialized
[   11.651757] Bluetooth: RFCOMM socket layer initialized
[   11.657365] Bluetooth: RFCOMM ver 1.11
[   11.661465] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   11.667262] Bluetooth: BNEP filters: protocol multicast
[   11.672995] Bluetooth: BNEP socket layer initialized
[   11.678413] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[   11.684905] Bluetooth: HIDP socket layer initialized
[   11.690944] Registering SWP/SWPB emulation handler
[   11.697178] registered taskstats version 1
[   11.702593] get usb_serial_number success from boot command line[sw_udc]: al)
[   11.717334] [sw_udc]: sunxi_udc_set_selfpowered_2320: usb device is not actie
[   11.725234] [sw_udc]: sunxi_udc_pullup, is_on = 0
[   11.730377] [sw_udc]: sunxi_udc_set_pullup_2337: usb device is not active
[   11.738018] file system registered
[   11.745508] android_usb gadget: Mass Storage Function, version: 2009/09/11
[   11.753035] android_usb gadget: Number of LUNs=3
[   11.758109]  lun0: LUN: removable file: (no medium)
[   11.763443]  lun1: LUN: removable file: (no medium)
[   11.768774]  lun2: LUN: removable file: (no medium)
[   11.774884] [sw_udc]: sunxi_udc_set_selfpowered_2320: usb device is not actie
[   11.782787] android_usb gadget: android_usb ready
[   11.787920] [sw_udc]: [sunxi_usb_udc]: binding gadget driver 'android_usb'
[   11.795631] sunxi-rtc 1f00000.rtc: setting system clock to 2010-01-01 00:00:)
[   11.806347] input: sunxi-ths as /devices/virtual/input/input4
[   11.812984] thermal thermal_zone0: failed to read out thermal zone 0
[   11.828448] ALSA device list:
[   11.831696]   #0: audiocodec
[   11.834835]   #1: sndhdmi
[   11.838298] Freeing unused kernel memory: 520K (ffffffc0009f5000 - ffffffc00)
[   11.849338] init: init first stage started!
[   11.863643] SELinux: 2048 avtab hash slots, 6593 rules.
[   11.876305] SELinux: 2048 avtab hash slots, 6593 rules.
[   11.882131] SELinux:  1 users, 2 roles, 653 types, 0 bools, 1 sens, 1024 cats
[   11.890058] SELinux:  63 classes, 6593 rules
[   11.898725] SELinux:  Completing initialization.
[   11.903762] SELinux:  Setting up existing superblocks.
[   11.909456] SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts
[   11.917315] SELinux: initialized (dev rootfs, type rootfs), uses genfs_contes
[   11.925380] SELinux: initialized (dev bdev, type bdev), not configured for lg
[   11.933760] SELinux: initialized (dev proc, type proc), uses genfs_contexts
[   11.941402] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIs
[   11.949324] SELinux: initialized (dev devtmpfs, type devtmpfs), uses transits
[   11.958260] SELinux: initialized (dev debugfs, type debugfs), uses genfs_cons
[   11.971307] SELinux: initialized (dev sockfs, type sockfs), uses task SIDs
[   11.978856] SELinux: initialized (dev pipefs, type pipefs), uses task SIDs
[   11.986382] SELinux: initialized (dev anon_inodefs, type anon_inodefs), not g
[   11.996279] SELinux: initialized (dev devpts, type devpts), uses transition s
[   12.004394] SELinux: initialized (dev selinuxfs, type selinuxfs), uses genfss
[   12.013031] SELinux: initialized (dev configfs, type configfs), uses genfs_cs
[   12.021405] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIs
[   12.029321] SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts
[   12.255729] type=1403 audit(1262304008.960:2): policy loaded auid=42949672955
[   12.265722] init: (Initializing SELinux non-enforcing took 0.42s.)
[   12.276343] init: init second stage started!
[   12.288426] init: Running restorecon...
[   12.365786] init: waitpid failed: No child processes
[   12.371629] init: (Loading properties from /default.prop took 0.00s.)
[   12.381603] init: (Parsing /init.environ.rc took 0.00s.)
[   12.387962] init: (Parsing /init.usb.rc took 0.00s.)
[   12.394033] init: /init.sun50iw1p1.rc: 185: invalid keyword 'ifeq'
[   12.400832] init: /init.sun50iw1p1.rc: 190: invalid keyword 'endif'
[   12.408334] init: (Parsing init.sensors.rc took 0.00s.)
[   12.414050] init: (Parsing init.common.rc took 0.01s.)
[   12.420051] init: (Parsing init.sun50iw1p1.usb.rc took 0.00s.)
[   12.426604] init: (Parsing init.zygote64_32.rc took 0.00s.)
[   12.432731] init: (Parsing /init.sun50iw1p1.rc took 0.04s.)
[   12.439671] init: (Parsing /init.usb.configfs.rc took 0.00s.)
[   12.446090] init: ignored duplicate definition of service 'zygote'init: igno)
[   12.463571] init: (Parsing /init.rc took 0.09s.)
[   12.694333] init: Starting service 'ueventd'...
[   12.700213] init: Waiting for /dev/.coldboot_done...
[   12.702418] ueventd: ueventd started!
[   13.136380]
[   13.136380]
[   13.136380] rmmod_host_driver
[   13.136380]
[   13.144475] [ehci0-controller]: sunxi_usb_disable_ehci
[   13.150114] [sunxi-ehci0]: remove, pdev->name: 1c1a000.ehci0-controller, sun0
[   13.160423] scene_lock_destroy name=ehci_standby
[   13.165478] sunxi-ehci 1c1a000.ehci0-controller: remove, state 4
[   13.172072] usb usb1: USB disconnect, device number 1
[   13.179064] sunxi-ehci 1c1a000.ehci0-controller: USB bus 1 deregistered
[   13.186369] [ohci0-controller]: sunxi_usb_disable_ohci
[   13.191992] [sunxi-ohci0]: remove, pdev->name: 1c1a000.ohci0-controller, sun0
[   13.200695] ueventd: Coldboot took 0.50s.
[   13.206653] scene_lock_destroy name=ohci_standby
[   13.207418] init: Waiting for /dev/.coldboot_done took 0.52s.
[   13.207518] init: /dev/hw_random not found
[   13.207739] init: Unable to set adequate mmap entropy value!
[   13.228635] sunxi-ohci 1c1a000.ohci0-controller: remove, state 4
[   13.235242] usb usb3: USB disconnect, device number 1
[   13.242591] sunxi-ohci 1c1a000.ohci0-controller: USB bus 3 deregistered
[   13.242691] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contes
[   13.245175] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIs
[   13.252927] init: write_file: Unable to open '/proc/cpu/alignment': No such y
[   13.253242] init: write_file: Unable to open '/proc/sys/kernel/sched_compat_y
[   13.255529] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contes
[   13.255846] init: write_file: Unable to write to '/dev/cpuctl/cpu.shares': It
[   13.258036] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contes
[   13.265778] SELinux: initialized (dev pstore, type pstore), uses genfs_contes
[   13.266098] init: write_file: Unable to open '/proc/sys/abi/swp': No such fiy
[   13.267953] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIs
[   13.268659] init: /dev/hw_random not found
[   13.282380] [NAND]Failed to insmod nand!!!
[   13.282535] init: Starting service 'exec 1 (/sbin/busybox)'...
[   13.283772] type=1400 audit(1262304010.000:3): avc:  denied  { transition } 1
[   13.284269] type=1400 audit(1262304010.010:4): avc:  denied  { rlimitinh } f1
[   13.284309] type=1400 audit(1262304010.010:5): avc:  denied  { siginh } for 1
[   13.284371] type=1400 audit(1262304010.010:6): avc:  denied  { noatsecure } 1
[   13.306274]
[   13.306274] The number of cylinders for this disk is set to 242560.
[   13.306274] There is nothing wrong with that, but this is larger than 1024,
[   13.306274] and could in certain setups cause problems with:
[   13.306274] 1) software that runs at boot time (e.g., old versions of LILO)
[   13.306274] 2) booting and partitioning software from other OSs
[   13.306274]    (e.g., DOS FDISK, OS/2 FDISK)
[   13.306274]
[   13.306274] Command (m for help): Partition number (1-4):
[   13.306274] Command (m for help): Command action
[   13.306274]    e   extended
[   13.306274]    p   primary partition (1-4)
[   13.483101]
[   13.483101]
[   13.483101] insmod_host_driver
[   13.483101]
[   13.491336] [ehci0-controller]: sunxi_usb_enable_ehci
[   13.496853] [sunxi-ehci0]: probe, pdev->name: 1c1a000.ehci0-controller, sunx8
[   13.510122] sunxi-ehci 1c1a000.ehci0-controller: SW USB2.0 'Enhanced' Host Cr
[   13.520048] sunxi-ehci 1c1a000.ehci0-controller: new USB bus registered, ass1
[   13.530357] sunxi-ehci 1c1a000.ehci0-controller: irq 104, io mem 0xffffff800c
[   13.549641] sunxi-ehci 1c1a000.ehci0-controller: USB 0.0 started, EHCI 1.00
[   13.557367] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[   13.564792] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber1
[   13.572688] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Dr
[   13.580868] usb usb1: Manufacturer: Linux 3.10.65+ ehci_hcd
[   13.586952] usb usb1: SerialNumber: sunxi-ehci
[   13.595282] hub 1-0:1.0: USB hub found
[   13.599594] hub 1-0:1.0: 1 port detected
[   13.604156] scene_lock_init name=ehci_standby
[   13.608923] [ohci0-controller]: sunxi_usb_enable_ohci
[   13.614438] [sunxi-ohci0]: probe, pdev->name: 1c1a000.ohci0-controller, sunx0
[   13.624666] sunxi-ohci 1c1a000.ohci0-controller: SW USB2.0 'Open' Host Contrr
[   13.634266] sunxi-ohci 1c1a000.ohci0-controller: new USB bus registered, ass3
[   13.643748] sunxi-ohci 1c1a000.ohci0-controller: irq 105, io mem 0xffffffc000
[   13.711110] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[   13.718535] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber1
[   13.726423] usb usb3: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   13.734223] usb usb3: Manufacturer: Linux 3.10.65+ ohci_hcd
[   13.740317] usb usb3: SerialNumber: sunxi-ohci
[   13.747045] hub 3-0:1.0: USB hub found
[   13.751186] hub 3-0:1.0: 1 port detected
[   13.755773] scene_lock_init name=ohci_standby
[   13.760550] host_chose finished 86!
[   14.295371] Selected partition 4
[   14.295371] First cylinder (1-242560, default 1): Last cylinder or +size or
[   14.295371] Command (m for help):
[   14.295372]  mmcblk0: p1 p2 p3 p4
[   14.324448] The partition table has been altered.
[   14.324448] Calling ioctl() to re-read partition table
[   14.350020] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. 1
[   14.359188] SELinux: initialized (dev mmcblk0p2, type ext4), uses xattr
[   14.893454] /dev/block/mmcblk0p4: 11/303104 files (0.0% non-contiguous), 277s
[   14.922309] resize2fs 1.42.9 (28-Dec-2013)
[   14.928947] The filesystem is already 1201664 blocks long.  Nothing to do!
[   14.928947]
[   14.941081] Disk is resized
[   14.949408] init: Service 'exec 1 (/sbin/busybox)' (pid 1446) exited with st0
[   14.970175] SELinux: initialized (dev mmcblk0p1, type vfat), uses genfs_conts
[   14.978366] fs_mgr: __mount(source=/dev/block/mmcblk0p1,target=/bootloader,t0
[   14.997409] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. 1
[   15.006570] SELinux: initialized (dev mmcblk0p2, type ext4), uses xattr
[   15.013883] fs_mgr: __mount(source=/dev/block/mmcblk0p2,target=/system,type=0
[   15.023323] EXT4-fs (mmcblk0p3): Ignoring removed nomblk_io_submit option
[   15.035355] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. t
[   15.046884] SELinux: initialized (dev mmcblk0p3, type ext4), uses xattr
[   15.054180] fs_mgr: check_fs(): mount(/dev/block/mmcblk0p3,/cache,ext4)=0: Ss
[   15.069195] fs_mgr: check_fs(): unmount(/cache) succeeded
[   15.076712] fs_mgr: Running /system/bin/e2fsck on /dev/block/mmcblk0p3
[   15.269445] type=1400 audit(1262304012.020:7): avc:  denied  { getattr } for1
[   15.292619] type=1400 audit(1262304012.050:8): avc:  denied  { read } for  p1
[   15.314210] type=1400 audit(1262304012.070:9): avc:  denied  { open } for  p1
[   15.336898] type=1400 audit(1262304012.090:10): avc:  denied  { write } for 1
[   15.358710] type=1400 audit(1262304012.120:11): avc:  denied  { ioctl } for 1
[   15.423173] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[   15.423173]
[   15.429790] e2fsck: Pass 1: Checking inodes, blocks, and sizes
[   15.429790]
[   15.437780] e2fsck: Pass 2: Checking directory structure
[   15.437780]
[   15.445213] e2fsck: Pass 3: Checking directory connectivity
[   15.445213]
[   15.452927] e2fsck: Pass 4: Checking reference counts
[   15.452927]
[   15.460071] e2fsck: Pass 5: Checking group summary information
[   15.460071]
[   15.468063] e2fsck: /dev/block/mmcblk0p3: 11/49152 files (0.0% non-contiguous
[   15.468063]
[   15.480627] EXT4-fs (mmcblk0p3): Ignoring removed nomblk_io_submit option
[   15.496573] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. c
[   15.511327] SELinux: initialized (dev mmcblk0p3, type ext4), uses xattr
[   15.518616] fs_mgr: __mount(source=/dev/block/mmcblk0p3,target=/cache,type=e0
[   15.527624] EXT4-fs (mmcblk0p4): Ignoring removed nomblk_io_submit option
[   15.539465] EXT4-fs (mmcblk0p4): mounted filesystem with ordered data mode. t
[   15.550989] SELinux: initialized (dev mmcblk0p4, type ext4), uses xattr
[   15.558288] fs_mgr: check_fs(): mount(/dev/block/mmcblk0p4,/data,ext4)=0: Sus
[   15.568718] fs_mgr: check_fs(): unmount(/data) succeeded
[   15.574578] fs_mgr: Running /system/bin/e2fsck on /dev/block/mmcblk0p4
[   15.670625] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[   15.670625]
[   15.677234] e2fsck: Pass 1: Checking inodes, blocks, and sizes
[   15.677234]
[   15.685234] e2fsck: Pass 2: Checking directory structure
[   15.685234]
[   15.692654] e2fsck: Pass 3: Checking directory connectivity
[   15.692654]
[   15.700367] e2fsck: Pass 4: Checking reference counts
[   15.700367]
[   15.707511] e2fsck: Pass 5: Checking group summary information
[   15.707511]
[   15.715562] e2fsck: /dev/block/mmcblk0p4: 11/303104 files (0.0% non-contiguos
[   15.715562]
[   15.728348] EXT4-fs (mmcblk0p4): Ignoring removed nomblk_io_submit option
[   15.740286] EXT4-fs (mmcblk0p4): mounted filesystem with ordered data mode. c
[   15.755085] SELinux: initialized (dev mmcblk0p4, type ext4), uses xattr
[   15.762361] fs_mgr: __mount(source=/dev/block/mmcblk0p4,target=/data,type=ex0
[   15.773436] init: (Parsing /system/etc/init/atrace.rc took 0.00s.)
[   15.780925] init: (Parsing /system/etc/init/audioserver.rc took 0.00s.)
[   15.788892] init: (Parsing /system/etc/init/bootanim.rc took 0.00s.)
[   15.796542] init: (Parsing /system/etc/init/bootstat.rc took 0.00s.)
[   15.804159] init: (Parsing /system/etc/init/cameraserver.rc took 0.00s.)
[   15.812098] init: (Parsing /system/etc/init/debuggerd.rc took 0.00s.)
[   15.819773] init: (Parsing /system/etc/init/debuggerd64.rc took 0.00s.)
[   15.827628] init: (Parsing /system/etc/init/drmserver.rc took 0.00s.)
[   15.835390] init: (Parsing /system/etc/init/dumpstate.rc took 0.00s.)
[   15.843071] init: (Parsing /system/etc/init/gatekeeperd.rc took 0.00s.)
[   15.850957] init: (Parsing /system/etc/init/init-debug.rc took 0.00s.)
[   15.858721] init: (Parsing /system/etc/init/installd.rc took 0.00s.)
[   15.866312] init: (Parsing /system/etc/init/keystore.rc took 0.00s.)
[   15.873971] init: (Parsing /system/etc/init/lmkd.rc took 0.00s.)
[   15.881179] init: (Parsing /system/etc/init/logcatd.rc took 0.00s.)
[   15.888689] init: (Parsing /system/etc/init/logd.rc took 0.00s.)
[   15.895987] init: (Parsing /system/etc/init/mdnsd.rc took 0.00s.)
[   15.903285] init: (Parsing /system/etc/init/mediacodec.rc took 0.00s.)
[   15.911028] init: (Parsing /system/etc/init/mediadrmserver.rc took 0.00s.)
[   15.919244] init: (Parsing /system/etc/init/mediaextractor.rc took 0.00s.)
[   15.927394] init: (Parsing /system/etc/init/mediaserver.rc took 0.00s.)
[   15.935362] init: (Parsing /system/etc/init/mtpd.rc took 0.00s.)
[   15.942568] init: (Parsing /system/etc/init/netd.rc took 0.00s.)
[   15.949752] init: (Parsing /system/etc/init/perfprofd.rc took 0.00s.)
[   15.957514] init: (Parsing /system/etc/init/racoon.rc took 0.00s.)
[   15.964912] init: (Parsing /system/etc/init/rild.rc took 0.00s.)
[   15.972146] init: (Parsing /system/etc/init/servicemanager.rc took 0.00s.)
[   15.980372] init: (Parsing /system/etc/init/surfaceflinger.rc took 0.00s.)
[   15.988527] init: (Parsing /system/etc/init/uncrypt.rc took 0.00s.)
[   15.996129] init: (Parsing /system/etc/init/vdc.rc took 0.00s.)
[   16.003237] init: (Parsing /system/etc/init/vold.rc took 0.00s.)
[   16.105407] Adding 262140k swap on /dev/block/zram0.  Priority:-1 extents:1 S
[   16.488733] [DISP]disp_module_init
[   16.495005] [DISP] disp_boot_para_parse,line:302:of_property_read disp.boot_l
[   16.503591] [DISP] boot_disp:0x0
[   16.507866] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_nodel
[   16.518179] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_nodel
[   16.528488] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_nodel
[   16.556130] [DISP] disp_boot_para_parse,line:302:of_property_read disp.fb_bal
[   16.564505] [DISP] fb_base:0x0
[   16.583238] [DISP] lcd_clk_config,line:808:disp 0, clk: pll(330000000),clk(3)
     clk real:pll(330000000),clk(330000000),dclk(82500000) dsi_rate(148500000)
[   16.603325] [DISP]disp_module_init finish
[   16.608495] mb709_mipi: LCD_power_on[   16.626789] enter tr_probe
[   16.629940] exit tr_probe
mb709_mipi: LCD_panel_init
[   16.642141] [DISP] disp_sys_pin_set_state,line:420:pinctrl_lookup_state for l
[   16.668515] [DISP] disp_boot_para_parse,line:302:of_property_read disp.boot_l
[   16.677111] [DISP] boot_disp:0x0
[   16.680683] HDMI base address: ffffff8001a80000
[   16.687123] [HDMI] power vcc-hdmi-33
[   16.691606] [HDMI] cec support = 0
[   16.924757] [mb709_mipi] send cmd=0x80
[   16.928849] [mb709_mipi] send cmd=0x81
[   16.932938] [mb709_mipi] send cmd=0x82
[   16.937037] [mb709_mipi] send cmd=0x83
[   16.941126] [mb709_mipi] send cmd=0x84
[   16.945223] [mb709_mipi] send cmd=0x85
[   16.949312] [mb709_mipi] send cmd=0x86
[   17.052672] mb709_mipi: LCD_bl_open[   17.070974] HDMI CEC base address: fff0
[   17.076851] HDMI CEC device_create
[   17.082012] HDMI CEC initialized: Oct  5 2016 12:14:36
[   17.087790] init: insmod: open("/system/vendor/modules/te_sec_storage.ko") fz
[   17.383650] Mali: Init Mali gpu clocks successfully
[   17.389983] gpu cooling callback register Success
[   17.399421] Mali: Mali device driver loaded
[   17.440632] input: sunxi-keyboard as /devices/virtual/input/input5
[   17.466418] get ctp_power_io is invalid.
[   17.471751] get_detect_list name = sc7a30
[   17.476733] get_detect_list name = lsm303d
[   17.481204] get_detect_list name = fxos8700
[   17.485805] get_detect_list name = mxc622x
[   17.490644] get_detect_list name = dmard06
[   17.495493] get_detect_list name = dmard10
[   17.499969] get_detect_list name = kxtik
[   17.504249] get_detect_list name = lis3dh_acc
[   17.509474] get_detect_list name = lis3de_acc
[   17.514235] get_detect_list name = afa750
[   17.518642] get_detect_list name = mc32x0
[   17.523025] get_detect_list: script_get_item err.support_number = 6.
[   17.530091] get_detect_list name = mma865x
[   17.534564] get_detect_list name = mma7660
[   17.539042] get_detect_list name = mma8452
[   17.543515] get_detect_list name = stk831x
[   17.547995] get_detect_list: script_get_item err.support_number = 2.
[   17.555036] get_detect_list name = bma250
[   17.559414] get_detect_list name = lsm9ds0_acc_mag
[   17.564826] type=1400 audit(1262304014.360:12): avc:  denied  { write } for 1
[   17.579451] [VFE]cci probe end cci_sel = 0!
[   17.580308] [VFE]cci_init end
[   17.593140] type=1400 audit(1262304014.380:13): avc:  denied  { add_name } f1
[   17.612955] type=1400 audit(1262304014.400:14): avc:  denied  { create } for1
[   17.632747] type=1400 audit(1262304014.420:15): avc:  denied  { write open }1
[   17.656168] sw_get_write_info:read erro or read null !
[   17.661920] get write info erro!
[   17.665622] twi_start()370 - [i2c1] START can't sendout!
[   17.671663] twi_start()370 - [i2c1] START can't sendout!
[   17.677712] twi_start()370 - [i2c1] START can't sendout!
[   17.702266] twi_start()370 - [i2c1] START can't sendout!
[   17.708311] twi_start()370 - [i2c1] START can't sendout!
[   17.714371] twi_start()370 - [i2c1] START can't sendout!
[   17.721835] gpu cooling callback set freq limit 0
[   17.731785] twi_start()370 - [i2c1] START can't sendout!
[   17.737824] twi_start()370 - [i2c1] START can't sendout!
[   17.743875] twi_start()370 - [i2c1] START can't sendout!
[   17.761347] twi_start()370 - [i2c1] START can't sendout!
[   17.767434] twi_start()370 - [i2c1] START can't sendout!
[   17.767888] [VFE]Welcome to Video Front End driver
[   17.768159] [VFE]csi probe end csi_sel = 0!
[   17.769032] [VFE]csi_init end
[   17.769899] [VFE]isp probe start isp_sel = 0!
[   17.791296] twi_start()370 - [i2c1] START can't sendout!
[   17.797193] [ISP] isp platform_id = 3!
[   17.801304] [VFE]isp probe end isp_sel = 0!
[   17.806626] [VFE]sunxi_isp_platform_register end
[   17.810508] twi_start()370 - [i2c1] START can't sendout!
[   17.810756] twi_start()370 - [i2c1] START can't sendout!
[   17.811005] twi_start()370 - [i2c1] START can't sendout!
[   17.830089] [VFE]mipi probe start mipi_sel = 0!
[   17.830187] twi_start()370 - [i2c1] START can't sendout!
[   17.830435] twi_start()370 - [i2c1] START can't sendout!
[   17.830683] twi_start()370 - [i2c1] START can't sendout!
[   17.849861] twi_start()370 - [i2c1] START can't sendout!
[   17.850109] twi_start()370 - [i2c1] START can't sendout!
[   17.850358] twi_start()370 - [i2c1] START can't sendout!
[   17.869541] twi_start()370 - [i2c1] START can't sendout!
[   17.869789] twi_start()370 - [i2c1] START can't sendout!
[   17.870037] twi_start()370 - [i2c1] START can't sendout!
[   17.887234] [VFE]mipi probe end mipi_sel = 0!
[   17.889220] twi_start()370 - [i2c1] START can't sendout!
[   17.889468] twi_start()370 - [i2c1] START can't sendout!
[   17.889717] twi_start()370 - [i2c1] START can't sendout!
[   17.908901] twi_start()370 - [i2c1] START can't sendout!
[   17.909149] twi_start()370 - [i2c1] START can't sendout!
[   17.909397] twi_start()370 - [i2c1] START can't sendout!
[   17.927422] [VFE]mipi_init end
[   17.930770] [VFE]flash_init end
[   17.936097] [VFE]pdev->id = 0
[   17.938433] twi_start()370 - [i2c1] START can't sendout!
[   17.938682] twi_start()370 - [i2c1] START can't sendout!
[   17.938930] twi_start()370 - [i2c1] START can't sendout!
[   17.956739] [VFE]dev->vip_sel = 0
[   17.958096] twi_start()370 - [i2c1] START can't sendout!
[   17.958344] twi_start()370 - [i2c1] START can't sendout!
[   17.958593] twi_start()370 - [i2c1] START can't sendout!
[   17.977770] [VFE_WARN]fetch csi0_dev0_twi_id from device_tree failed
[   17.977776] twi_start()370 - [i2c1] START can't sendout!
[   17.978024] twi_start()370 - [i2c1] START can't sendout!
[   17.978273] twi_start()370 - [i2c1] START can't sendout!
[   18.002135] [VFE_WARN]fetch csi0_dev0_afvdd from device_tree failed
[   18.007306] twi_start()370 - [i2c1] START can't sendout!
[   18.007555] twi_start()370 - [i2c1] START can't sendout!
[   18.007803] twi_start()370 - [i2c1] START can't sendout!
[   18.026378] [VFE_WARN]fetch csi0_dev0_afvdd_vol from device_tree failed
[   18.026976] twi_start()370 - [i2c1] START can't sendout!
[   18.027225] twi_start()370 - [i2c1] START can't sendout!
[   18.027473] twi_start()370 - [i2c1] START can't sendout!
[   18.051001] [VFE_WARN]fetch csi0_dev0_power_en from device_tree failed
[   18.056502] twi_start()370 - [i2c1] START can't sendout!
[   18.056750] twi_start()370 - [i2c1] START can't sendout!
[   18.056999] twi_start()370 - [i2c1] START can't sendout!
[   18.075554] [VFE_WARN]fetch csi0_dev0_flash_en from device_tree failed
[   18.076177] twi_start()370 - [i2c1] START can't sendout!
[   18.076425] twi_start()370 - [i2c1] START can't sendout!
[   18.076673] twi_start()370 - [i2c1] START can't sendout!
[   18.086020] twi_start()370 - [i2c1] START can't sendout!
[   18.086268] twi_start()370 - [i2c1] START can't sendout!
[   18.086516] twi_start()370 - [i2c1] START can't sendout!
[   18.105700] twi_start()370 - [i2c1] START can't sendout!
[   18.105948] twi_start()370 - [i2c1] START can't sendout!
[   18.106197] twi_start()370 - [i2c1] START can't sendout!
[   18.125379] twi_start()370 - [i2c1] START can't sendout!
[   18.125628] twi_start()370 - [i2c1] START can't sendout!
[   18.125876] twi_start()370 - [i2c1] START can't sendout!
[   18.145059] twi_start()370 - [i2c1] START can't sendout!
[   18.145308] twi_start()370 - [i2c1] START can't sendout!
[   18.145556] twi_start()370 - [i2c1] START can't sendout!
[   18.164739] twi_start()370 - [i2c1] START can't sendout!
[   18.164988] twi_start()370 - [i2c1] START can't sendout!
[   18.165236] twi_start()370 - [i2c1] START can't sendout!
[   18.184419] twi_start()370 - [i2c1] START can't sendout!
[   18.184668] twi_start()370 - [i2c1] START can't sendout!
[   18.184916] twi_start()370 - [i2c1] START can't sendout!
[   18.204101] twi_start()370 - [i2c1] START can't sendout!
[   18.204349] twi_start()370 - [i2c1] START can't sendout!
[   18.204598] twi_start()370 - [i2c1] START can't sendout!
[   18.221768] [VFE_WARN]fetch csi0_dev0_flash_mode from device_tree failed
[   18.223779] twi_start()370 - [i2c1] START can't sendout!
[   18.224027] twi_start()370 - [i2c1] START can't sendout!
[   18.224275] twi_start()370 - [i2c1] START can't sendout!
[   18.243463] twi_start()370 - [i2c1] START can't sendout!
[   18.243711] twi_start()370 - [i2c1] START can't sendout!
[   18.243960] twi_start()370 - [i2c1] START can't sendout!
[   18.263143] twi_start()370 - [i2c1] START can't sendout!
[   18.263391] twi_start()370 - [i2c1] START can't sendout!
[   18.263639] twi_start()370 - [i2c1] START can't sendout!
[   18.281258] [VFE_WARN]fetch csi0_dev0_af_pwdn from device_tree failed
[   18.282822] twi_start()370 - [i2c1] START can't sendout!
[   18.283070] twi_start()370 - [i2c1] START can't sendout!
[   18.283319] twi_start()370 - [i2c1] START can't sendout!
[   18.302502] twi_start()370 - [i2c1] START can't sendout!
[   18.302751] twi_start()370 - [i2c1] START can't sendout!
[   18.302999] twi_start()370 - [i2c1] START can't sendout!
[   18.322182] twi_start()370 - [i2c1] START can't sendout!
[   18.322431] twi_start()370 - [i2c1] START can't sendout!
[   18.322679] twi_start()370 - [i2c1] START can't sendout!
[   18.340470] [VFE_WARN]fetch csi0_dev1_twi_id from device_tree failed
[   18.341863] twi_start()370 - [i2c1] START can't sendout!
[   18.342111] twi_start()370 - [i2c1] START can't sendout!
[   18.342360] twi_start()370 - [i2c1] START can't sendout!
[   18.361543] twi_start()370 - [i2c1] START can't sendout!
[   18.361791] twi_start()370 - [i2c1] START can't sendout!
[   18.362039] twi_start()370 - [i2c1] START can't sendout!
[   18.381222] twi_start()370 - [i2c1] START can't sendout!
[   18.381471] twi_start()370 - [i2c1] START can't sendout!
[   18.381719] twi_start()370 - [i2c1] START can't sendout!
[   18.399592] [VFE_WARN]fetch csi0_dev1_afvdd from device_tree failed
[   18.400901] twi_start()370 - [i2c1] START can't sendout!
[   18.401150] twi_start()370 - [i2c1] START can't sendout!
[   18.401398] twi_start()370 - [i2c1] START can't sendout!
[   18.420582] twi_start()370 - [i2c1] START can't sendout!
[   18.420831] twi_start()370 - [i2c1] START can't sendout!
[   18.421080] twi_start()370 - [i2c1] START can't sendout!
[   18.440263] twi_start()370 - [i2c1] START can't sendout!
[   18.440512] twi_start()370 - [i2c1] START can't sendout!
[   18.440760] twi_start()370 - [i2c1] START can't sendout!
[   18.458645] [VFE_WARN]fetch csi0_dev1_afvdd_vol from device_tree failed
[   18.459958] twi_start()370 - [i2c1] START can't sendout!
[   18.460206] twi_start()370 - [i2c1] START can't sendout!
[   18.460455] twi_start()370 - [i2c1] START can't sendout!
[   18.479623] twi_start()370 - [i2c1] START can't sendout!
[   18.479872] twi_start()370 - [i2c1] START can't sendout!
[   18.480120] twi_start()370 - [i2c1] START can't sendout!
[   18.499302] twi_start()370 - [i2c1] START can't sendout!
[   18.499551] twi_start()370 - [i2c1] START can't sendout!
[   18.499799] twi_start()370 - [i2c1] START can't sendout!
[   18.518037] [VFE_WARN]fetch csi0_dev1_power_en from device_tree failed
[   18.518982] twi_start()370 - [i2c1] START can't sendout!
[   18.519231] twi_start()370 - [i2c1] START can't sendout!
[   18.519479] twi_start()370 - [i2c1] START can't sendout!
[   18.538664] twi_start()370 - [i2c1] START can't sendout!
[   18.538912] twi_start()370 - [i2c1] START can't sendout!
[   18.539161] twi_start()370 - [i2c1] START can't sendout!
[   18.558342] twi_start()370 - [i2c1] START can't sendout!
[   18.558591] twi_start()370 - [i2c1] START can't sendout!
[   18.558840] twi_start()370 - [i2c1] START can't sendout!
[   18.577914] [VFE_WARN]fetch csi0_dev1_flash_en from device_tree failed
[   18.578024] twi_start()370 - [i2c1] START can't sendout!
[   18.578272] twi_start()370 - [i2c1] START can't sendout!
[   18.578521] twi_start()370 - [i2c1] START can't sendout!
[   18.597703] twi_start()370 - [i2c1] START can't sendout!
[   18.597951] twi_start()370 - [i2c1] START can't sendout!
[   18.598199] twi_start()370 - [i2c1] START can't sendout!
[   18.617382] twi_start()370 - [i2c1] START can't sendout!
[   18.617630] twi_start()370 - [i2c1] START can't sendout!
[   18.617879] twi_start()370 - [i2c1] START can't sendout!
[   18.637063] twi_start()370 - [i2c1] START can't sendout!
[   18.637312] twi_start()370 - [i2c1] START can't sendout!
[   18.637561] twi_start()370 - [i2c1] START can't sendout!
[   18.654590] [VFE_WARN]fetch csi0_dev1_flash_mode from device_tree failed
[   18.656743] twi_start()370 - [i2c1] START can't sendout!
[   18.656991] twi_start()370 - [i2c1] START can't sendout!
[   18.657240] twi_start()370 - [i2c1] START can't sendout!
[   18.676423] twi_start()370 - [i2c1] START can't sendout!
[   18.676671] twi_start()370 - [i2c1] START can't sendout!
[   18.676919] twi_start()370 - [i2c1] START can't sendout!
[   18.696102] twi_start()370 - [i2c1] START can't sendout!
[   18.696351] twi_start()370 - [i2c1] START can't sendout!
[   18.696599] twi_start()370 - [i2c1] START can't sendout!
[   18.714467] [VFE_WARN]fetch csi0_dev1_af_pwdn from device_tree failed
[   18.715782] twi_start()370 - [i2c1] START can't sendout!
[   18.716031] twi_start()370 - [i2c1] START can't sendout!
[   18.716279] twi_start()370 - [i2c1] START can't sendout!
[   18.735462] twi_start()370 - [i2c1] START can't sendout!
[   18.735711] twi_start()370 - [i2c1] START can't sendout!
[   18.735959] twi_start()370 - [i2c1] START can't sendout!
[   18.755142] twi_start()370 - [i2c1] START can't sendout!
[   18.755391] twi_start()370 - [i2c1] START can't sendout!
[   18.755639] twi_start()370 - [i2c1] START can't sendout!
[   18.773700] [VFE]fetch rear sensor list info start!
[   18.774822] twi_start()370 - [i2c1] START can't sendout!
[   18.775071] twi_start()370 - [i2c1] START can't sendout!
[   18.775319] twi_start()370 - [i2c1] START can't sendout!
[   18.794502] twi_start()370 - [i2c1] START can't sendout!
[   18.794751] twi_start()370 - [i2c1] START can't sendout!
[   18.794999] twi_start()370 - [i2c1] START can't sendout!
[   18.813823] [VFE]Fetch sensor list form"/system/etc/hawkview/sensor_list_cfg"
[   18.814182] twi_start()370 - [i2c1] START can't sendout!
[   18.814430] twi_start()370 - [i2c1] START can't sendout!
[   18.814679] twi_start()370 - [i2c1] START can't sendout!
[   18.833864] twi_start()370 - [i2c1] START can't sendout!
[   18.834112] twi_start()370 - [i2c1] START can't sendout!
[   18.834360] twi_start()370 - [i2c1] START can't sendout!
[   18.853543] twi_start()370 - [i2c1] START can't sendout!
[   18.853791] twi_start()370 - [i2c1] START can't sendout!
[   18.854040] twi_start()370 - [i2c1] START can't sendout!
[   18.873222] twi_start()370 - [i2c1] START can't sendout!
[   18.873470] twi_start()370 - [i2c1] START can't sendout!
[   18.873719] twi_start()370 - [i2c1] START can't sendout!
[   18.892897] twi_start()370 - [i2c1] START can't sendout!
[   18.898946] twi_start()370 - [i2c1] START can't sendout!
[   18.905031] twi_start()370 - [i2c1] START can't sendout!
[   18.922490] twi_start()370 - [i2c1] START can't sendout!
[   18.928548] twi_start()370 - [i2c1] START can't sendout!
[   18.934622] twi_start()370 - [i2c1] START can't sendout!
[   18.951995] twi_start()370 - [i2c1] START can't sendout!
[   18.958053] twi_start()370 - [i2c1] START can't sendout!
[   18.964134] twi_start()370 - [i2c1] START can't sendout!
[   18.981534] twi_start()370 - [i2c1] START can't sendout!
[   18.987587] twi_start()370 - [i2c1] START can't sendout!
[   18.993660] twi_start()370 - [i2c1] START can't sendout!
[   19.011054] twi_start()370 - [i2c1] START can't sendout!
[   19.017106] twi_start()370 - [i2c1] START can't sendout!
[   19.023181] twi_start()370 - [i2c1] START can't sendout!
[   19.040552] twi_start()370 - [i2c1] START can't sendout!
[   19.046611] twi_start()370 - [i2c1] START can't sendout!
[   19.052690] twi_start()370 - [i2c1] START can't sendout!
[   19.070090] twi_start()370 - [i2c1] START can't sendout!
[   19.076144] twi_start()370 - [i2c1] START can't sendout!
[   19.082222] twi_start()370 - [i2c1] START can't sendout!
[   19.099619] twi_start()370 - [i2c1] START can't sendout!
[   19.105681] twi_start()370 - [i2c1] START can't sendout!
[   19.111758] twi_start()370 - [i2c1] START can't sendout!
[   19.125211] [vfe_warn]open file failed!
[   19.129104] twi_start()370 - [i2c1] START can't sendout!
[   19.129353] twi_start()370 - [i2c1] START can't sendout!
[   19.129601] twi_start()370 - [i2c1] START can't sendout!
[   19.148788] twi_start()370 - [i2c1] START can't sendout!
[   19.154846] twi_start()370 - [i2c1] START can't sendout!
[   19.160935] twi_start()370 - [i2c1] START can't sendout!
[   19.178292] twi_start()370 - [i2c1] START can't sendout!
[   19.184349] twi_start()370 - [i2c1] START can't sendout!
[   19.190427] twi_start()370 - [i2c1] START can't sendout!
[   19.207851] twi_start()370 - [i2c1] START can't sendout!
[   19.213912] twi_start()370 - [i2c1] START can't sendout!
[   19.219988] twi_start()370 - [i2c1] START can't sendout!
[   19.237298] get node lightsensor failed
[   19.241501] get sysconfig para erro!
[   19.245482] get node gyroscopesensor failed
[   19.250077] get sysconfig para erro!
[   19.254064] get node compasssensor failed
[   19.258459] get sysconfig para erro!
[   19.262415] ctp_wakeup: !!!!gpio data 1
[   19.365214] get_detect_list name = icn83xx_ts
[   19.369993] get_detect_list: script_get_item err.support_number = 11.
[   19.377160] get_detect_list name = aw5306_ts
[   19.381836] get_detect_list name = zet622x
[   19.386326] get_detect_list name = gt818_ts
[   19.390904] get_detect_list: script_get_item err.support_number = 8.
[   19.397966] get_detect_list name = tu_ts
[   19.402254] get_detect_list: script_get_item err.support_number = 7.
[   19.409322] get_detect_list name = gt9xxf_ts
[   19.413998] get_detect_list name = gt9xxnew_ts
[   19.418879] get_detect_list name = gt9xx_ts
[   19.423454] get_detect_list name = gslX680new
[   19.428231] get_detect_list name = gslX680
[   19.432713] get_detect_list: script_get_item err.support_number = 2.
[   19.439769] get_detect_list name = gt82x
[   19.444380] get_detect_list name = ft5x_ts
[   19.448865] get_detect_list: script_get_item err.support_number = 0.
[   19.450105] [VFE]fetch rear sensor list info end!
[   19.450154] [VFE]fetch front sensor list info start!
[   19.450157] [VFE]Fetch sensor list form"/system/etc/hawkview/sensor_list_cfg"
[   19.474967] sunxi_i2c_do_xfer()902 - [i2c0] incomplete xfer (status: 0x20, d)
[   19.503062] sunxi_i2c_do_xfer()902 - [i2c0] incomplete xfer (status: 0x20, d)
[   19.522728] sunxi_i2c_do_xfer()902 - [i2c0] incomplete xfer (status: 0x20, d)
[   19.542463] sunxi_i2c_do_xfer()902 - [i2c0] incomplete xfer (status: 0x20, d)
[   19.562057] sunxi_i2c_do_xfer()902 - [i2c0] incomplete xfer (status: 0x20, d)
[   19.581747] sunxi_i2c_do_xfer()902 - [i2c0] incomplete xfer (status: 0x20, d)
[   19.601443] sunxi_i2c_do_xfer()902 - [i2c0] incomplete xfer (status: 0x20, d)
[   19.621134] sunxi_i2c_do_xfer()902 - [i2c0] incomplete xfer (status: 0x20, d)
[   19.640820] sunxi_i2c_do_xfer()902 - [i2c0] incomplete xfer (status: 0x20, d)
[   19.660511] sunxi_i2c_do_xfer()902 - [i2c0] incomplete xfer (status: 0x20, d)
[   19.680175] sunxi_i2c_do_xfer()902 - [i2c0] incomplete xfer (status: 0x20, d)
[   19.683299] [vfe_warn]open file failed!
[   19.709677] sunxi_i2c_do_xfer()902 - [i2c0] incomplete xfer (status: 0x20, d)
[   19.729379] sunxi_i2c_do_xfer()902 - [i2c0] incomplete xfer (status: 0x20, d)
[   19.749075] sunxi_i2c_do_xfer()902 - [i2c0] incomplete xfer (status: 0x20, d)
[   19.768745] sunxi_i2c_do_xfer()902 - [i2c0] incomplete xfer (status: 0x20, d)
[   19.788966] sunxi_i2c_do_xfer()902 - [i2c0] incomplete xfer (status: 0x20, d)
[   19.808055] sunxi_i2c_do_xfer()902 - [i2c0] incomplete xfer (status: 0x20, d)
[   19.837605] sunxi_i2c_do_xfer()902 - [i2c0] incomplete xfer (status: 0x20, d)
[   19.857317] sunxi_i2c_do_xfer()902 - [i2c0] incomplete xfer (status: 0x20, d)
[   19.886810] sunxi_i2c_do_xfer()902 - [i2c0] incomplete xfer (status: 0x20, d)
[   19.906501] sunxi_i2c_do_xfer()902 - [i2c0] incomplete xfer (status: 0x20, d)
[   19.926169] sunxi_i2c_do_xfer()902 - [i2c0] incomplete xfer (status: 0x20, d)
[   19.945924] sunxi_i2c_do_xfer()902 - [i2c0] incomplete xfer (status: 0x20, d)
[   19.965497] sunxi_i2c_do_xfer()902 - [i2c0] incomplete xfer (status: 0x20, d)
[   19.986174] [VFE]fetch front sensor list info end!
[   19.991645] [VFE_WARN]os_gpio_request failed, gpio=145, ret=0xfffffff0, -16
[   19.994994] sunxi_i2c_do_xfer()902 - [i2c0] incomplete xfer (status: 0x20, d)
[   20.008288] [VFE_WARN]os_gpio_request failed, gpio=144, ret=0xfffffff0, -16
[   20.015903] [VFE_WARN]os_gpio_request failed, gpio=129, ret=0xfffffff0, -16
[   20.024382] [VFE]probe_work_handle start!
[   20.024721] [VFE]vfe_init end
[   20.032229] [VFE]vfe_runtime_resume
[   20.048053] [VFE]..........................vfe clk open!.....................
[   20.056045] [VFE_WARN]vfe dphy clock is null
[   20.060718] [VFE]v4l2 subdev register input_num = 0
[   20.066336] [VFE]vfe sensor detect start! input_num = 0
[   20.072063] [VFE]Find sensor name is "s5k4ec", i2c address is 5a, type is "Y!
[   20.080245] [VFE]Sub device register "s5k4ec" i2c_addr = 0x5a start!
[   20.087218] [VFE]v4l2_device_register_subdev return 0
[   20.092755] [VFE]registered sensor subdev is OK!
[   20.097811] [VFE]Check sensor!
[   20.113665] [s5k4ec]CSI_SUBDEV_PWR_ON 16:51
[   20.118239] CSI_SUBDEV_PWR_ON 12-21,11:10----------
[   20.128764] usbcore: registered new interface driver asix
[   20.136878] [VFE]mclk on
[   20.150944] usbcore: registered new interface driver qf9700
[   20.172969] usbcore: registered new interface driver MOSCHIP usb-ethernet drr
[   20.173950] [s5k4ec]sensor_init
[   20.184687] [VFE CCI_0 ERR] Status error at addr_8bit = 5a, wr_flag = 0, val0
[   20.193483] [VFE CCI_0 ERR] Status error at addr_8bit = 5a, wr_flag = 0, val0
[   20.201694] usbcore: registered new interface driver rtl8150
[   20.208486] [VFE CCI_0 ERR] Status error at addr_8bit = 5a, wr_flag = 0, val0
[   20.216787] usbcore: registered new interface driver cdc_ether
[   20.223449] [s5k4ec]sensor write retry=2
[   20.227962] [VFE CCI_0 ERR] Status error at addr_8bit = 5a, wr_flag = 0, val0
[   20.232551] init: insmod: open("/system/vendor/modules/smsc75xx.ko") failed:y
[   20.232552] [BT_LPM] bluesleep_init: BlueSleep Mode Driver Ver 1.1
[   20.232900] [BT_LPM] bluesleep_probe: bt_hostwake gpio=357  mul-sel=6  pull=0
[   20.232900]
[   20.232924] [BT_LPM] bluesleep_probe: uart_index (1)
[   20.232924]
[   20.235117] [BT_LPM] bluesleep_get_uart_port: bluesleep_get_uart_port get ua3
[   20.235120] [BT_LPM] bluesleep_start: bluesleep_acquire irq
[   20.235120]
[   20.239109] init: Starting service 'logd'...
[   20.249402] init: SELinux: Could not set context for /logger:  Read-only film
[   20.253931] init: (Loading properties from /system/build.prop took 0.00s.)
[   20.254040] init: (Loading properties from /vendor/build.prop took 0.00s.)
[   20.254104] init: (Loading properties from /factory/factory.prop took 0.00s.)
[   20.254308] init: /recovery not specified in fstab
[   20.257678] init: Starting service 'debuggerd'...
[   20.259444] init: Starting service 'debuggerd64'...
[   20.261202] init: Starting service 'vold'...
[   20.263755] init: Not bootcharting.
[   20.362435] [VFE CCI_0 ERR] Status error at addr_8bit = 5a, wr_flag = 0, val0
[   20.362457] logd.auditd: start
[   20.362515] logd.klogd: 11873655004
[   20.378614] [VFE CCI_0 ERR] Status error at addr_8bit = 5a, wr_flag = 0, val0
[   20.387362] [s5k4ec]sensor write retry=2
[   20.391659] [s5k4ec]sensor_write err at sensor_detect!
[   20.397269] [s5k4ec]chip found is not an target chip.
[   20.402801] [s5k4ec]CSI_SUBDEV_PWR_OFF
[   20.407021] [VFE]mclk off
[   20.434060] [VFE]vfe sensor subdev unregister!
[   20.438966] [VFE]Sub device register "s5k4ec" failed!
[   20.444492] [VFE_ERR]vfe sensor register check error at input_num = 0
[   20.451546] [VFE]v4l2 subdev register input_num = 1
[   20.456920] axp81x_aldo1: Failed to create debugfs directory
[   20.463152] axp81x_dldo3: Failed to create debugfs directory
[   20.469366] axp81x_eldo3: Failed to create debugfs directory
[   20.475605] axp81x_aldo1: Failed to create debugfs directory
[   20.481806] [VFE]vfe sensor detect start! input_num = 1
[   20.487527] [VFE_WARN]NOT found this item:  gc2145, you can add this sensor !
[   20.497278] [VFE]Sub device register "gc2145" i2c_addr = 0x78 start!
[   20.504235] [VFE_ERR]Error registering v4l2 subdevice No such device!
[   20.511294] [VFE_ERR]vfe sensor register check error at input_num = 1
[   20.518387] [VFE]V4L2 device registered as (null)
[   20.523589] [VFE]vfe_runtime_suspend
[   20.527526] [VFE]..........................vfe clk close!....................
[   20.541807] [VFE]probe_work_handle end!
[   20.918467] init: Starting service 'exec 2 (/system/bin/tzdatacheck)'...
[   20.942054] init: Service 'exec 2 (/system/bin/tzdatacheck)' (pid 1609) exit0
[   20.954591] init: property_set("ro.bt.bdaddr_path", "/data/misc/bluetooth/bdd
[   25.893308] init: do_start: Service bootclone not found
[   25.899329] init: Starting service 'precopy'...
[   25.906103] init: (Loading properties from /data/local.prop took 0.00s.)
[   25.909338] type=1400 audit(1262304022.840:16): avc: denied { read } for pid1
[   25.911318] type=1400 audit(1262304022.840:17): avc: denied { execute } for 1
[   25.912120] type=1400 audit(1262304022.840:18): avc: denied { open } for pid1
[   25.912239] type=1400 audit(1262304022.840:19): avc: denied { execute_no_tra1
[   25.913149] type=1400 audit(1262304022.840:20): avc: denied { getattr } for 1
[   25.913668] type=1400 audit(1262304022.840:21): avc: denied { read } for pid1
[   25.913808] type=1400 audit(1262304022.840:22): avc: denied { open } for pid1
[   25.914283] type=1400 audit(1262304022.840:23): avc: denied { getattr } for 1
[   25.914830] type=1400 audit(1262304022.840:24): avc: denied { execute } for 1
[   25.915647] type=1400 audit(1262304022.840:25): avc: denied { read open } fo1
[   25.915846] type=1400 audit(1262304022.840:26): avc: denied { execute_no_tra1
[   25.935027] type=1400 audit(1262304022.840:27): avc: denied { write } for pi1
[   25.936471] type=1400 audit(1262304022.840:28): avc: denied { add_name } for1
[   25.936612] type=1400 audit(1262304022.840:29): avc: denied { create } for p1
[   25.936756] type=1400 audit(1262304022.840:30): avc: denied { read write ope1
[   26.250396] init: Service 'precopy' (pid 1610) exited with status 0
[   26.257818] init: Starting service 'logd-reinit'...
[   26.269414] init: Starting service 'healthd'...
[   26.275195] init: cannot find '/system/bin/tee_supplicant' (No such file or '
[   26.278106] binder: 1615:1615 transaction failed 29189, size 0-0
[   26.280114] logd.daemon: reinit
[   26.295860] init: Starting service 'watchdogd'...
[   26.302394] init: Starting service 'lmkd'...
[   26.304261] watchdogd: started (interval 60, margin 20)!
[   26.304335] watchdogd: Failed to open /dev/watchdog: No such file or directoy
[   26.322113] init: Starting service 'servicemanager'...
[   26.329065] init: Starting service 'surfaceflinger'...
[   26.335557] init: couldn't write 1619 to /sys/fs/cgroup/stune/foreground/tasy
[   26.335767] init: Service 'logd-reinit' (pid 1614) exited with status 0
[   26.335903] init: Service 'watchdogd' (pid 1616) exited with status 1
[   26.339344] init: Starting service 'zygote'...
[   26.340527] init: Starting service 'zygote_secondary'...
[   26.341610] init: couldn't write 1620 to /sys/fs/cgroup/stune/foreground/tasy
[   26.345519] type=1400 audit(1262304023.280:31): avc: denied { write } for pi1
[   26.346261] init: Starting service 'console'...
[   26.347388] init: cannot find '/system/bin/update_verifier' (No such file or'
[   26.347467] init: cannot find '/system/bin/install-recovery.sh' (No such fil'
[   26.348119] init: Starting service 'audioserver'...
[   26.349610] init: Starting service 'cameraserver'...
[   26.350940] init: Starting service 'drm'...
[   26.354526] init: Starting service 'installd'...
[   26.357339] init: Starting service 'keystore'...
[   26.358704] init: Starting service 'mediacodec'...
[   26.361170] init: Starting service 'mediadrm'...
[   26.362736] init: Starting service 'mediaextractor'...
[   26.364287] init: Starting service 'media'...
[   26.365687] init: Starting service 'netd'...
[   26.366955] init: Starting service 'ril-daemon'...
[   26.368246] init: Starting service 'gatekeeperd'...
[   27.157115] type=1400 audit(1262304024.100:32): avc: denied { write } for pi1
[   27.181587] type=1400 audit(1262304024.100:33): avc: denied { open } for pid1
[   27.264991] healthd: BatteryFullChargePath not found
[   27.270640] healthd: BatteryCycleCountPath not found
[   27.406220] init: Starting service 'perfprofd'...
[   27.426174] android_usb: already disabled
[   27.431164] init: Starting service 'adbd'...
[   27.444850] adb_open
[   27.447257] mtp_bind_config
[   27.450318] gadget_is_softwinner_otg is not -int
[   27.455432] gadget_is_softwinner_otg is not -int
[   27.460493] [sw_udc]: alloc request: ep(0xffffffc000ac98b8, ep1in-bulk, 512))
[   27.470684] [sw_udc]: alloc request: ep(0xffffffc000ac98b8, ep1in-bulk, 512))
[   27.480862] [sw_udc]: alloc request: ep(0xffffffc000ac98b8, ep1in-bulk, 512))
[   27.494015] [sw_udc]: alloc request: ep(0xffffffc000ac98b8, ep1in-bulk, 512))
[   27.504472] [sw_udc]: alloc request: ep(0xffffffc000ac9938, ep1out-bulk, 512)
[   27.532447] [sw_udc]: alloc request: ep(0xffffffc000ac9938, ep1out-bulk, 512)
[   27.561907] [sw_udc]: alloc request: ep(0xffffffc000ac9b38, ep4-int, 512), r)
tulip-chiphd:/ $ [   27.585060] [sw_udc]: alloc request: ep(0xffffffc000ac9b38,)
[   27.608100] [sw_udc]: alloc request: ep(0xffffffc000ac9b38, ep4-int, 512), r)
[   27.618122] [sw_udc]: alloc request: ep(0xffffffc000ac9b38, ep4-int, 512), r)
[   27.628058] [sw_udc]: alloc request: ep(0xffffffc000ac9b38, ep4-int, 512), r)
[   27.638024] adb_bind_config
[   27.641114] [sw_udc]: alloc request: ep(0xffffffc000ac9a38, ep2out-bulk, 512)
[   27.651418] [sw_udc]: alloc request: ep(0xffffffc000ac99b8, ep2in-bulk, 512))
[   27.661622] [sw_udc]: alloc request: ep(0xffffffc000ac99b8, ep2in-bulk, 512))
[   27.680252] [sw_udc]: alloc request: ep(0xffffffc000ac99b8, ep2in-bulk, 512))
[   27.699674] [sw_udc]: alloc request: ep(0xffffffc000ac99b8, ep2in-bulk, 512))
[   27.729143] [sw_udc]: sunxi_udc_pullup, is_on = 1
[   27.734323] [sw_udc]: sunxi_udc_set_pullup_2337: usb device is not active
[   28.735849] [DISP] disp_ioctl,line:1612:para err in disp_ioctl, cmd = 0xb,sc0
[   28.752669] type=1400 audit(1262304025.720:34): avc: denied { write } for pi1
[   28.775871] type=1400 audit(1262304025.730:35): avc: denied { open } for pid1
[   28.902146] type=1400 audit(1262304025.880:36): avc: denied { write } for pi1
[   28.926842] type=1400 audit(1262304025.900:37): avc: denied { open } for pid1
[   29.025712] type=1400 audit(1262304026.000:38): avc: denied { write } for pi1
[   29.048849] type=1400 audit(1262304026.000:39): avc: denied { open } for pid1
[   31.319745] init: Starting service 'bootanim'...
[   32.131185] type=1400 audit(1262304029.160:40): avc: denied { write } for pi1
[   32.154379] type=1400 audit(1262304029.160:41): avc: denied { open } for pid1
[   34.948016] alloc_contig_range test_pages_isolated(9f96c, 9fbc4) failed
[   48.849981] warning: `main' uses 32-bit capabilities (legacy support in use)
[   50.636137] type=1400 audit(1262304047.960:42): avc: denied { sys_nice } for1
[   86.304386] healthd: battery none chg=a
[   88.929421] type=1400 audit(1262304086.880:43): avc: denied { dac_override }1
[   88.930592] healthd: battery none chg=a
[   91.162515] type=1400 audit(1262304089.150:44): avc: denied { write } for pi1
[   91.184490] type=1400 audit(1262304089.150:45): avc: denied { open } for pid1
[  126.011087] mmc0:mmc_do_erase: erase from 4362816 to 4599807 arg 0x00000000
[  126.070082] sunxi-mmc 1c0f000.sdmmc: *All wait r1 rdy 3 ms*
[  126.099618] mmc0:mmc_do_erase: erase from 4600208 to 4861951 arg 0x00000000
[  126.178320] sunxi-mmc 1c0f000.sdmmc: *All wait r1 rdy 4 ms*
[  126.207892] mmc0:mmc_do_erase: erase from 4894720 to 5124095 arg 0x00000000
[  126.267033] sunxi-mmc 1c0f000.sdmmc: *All wait r1 rdy 3 ms*
[  126.286612] mmc0:mmc_do_erase: erase from 5124488 to 5386239 arg 0x00000000
[  126.365268] sunxi-mmc 1c0f000.sdmmc: *All wait r1 rdy 4 ms*
[  126.394866] mmc0:mmc_do_erase: erase from 5386240 to 5648383 arg 0x00000000
[  126.453817] sunxi-mmc 1c0f000.sdmmc: *All wait r1 rdy 3 ms*
[  126.512936] mmc0:mmc_do_erase: erase from 5648776 to 5910527 arg 0x00000000
[  126.571949] sunxi-mmc 1c0f000.sdmmc: *All wait r1 rdy 3 ms*
[  126.578656] mmc0:mmc_do_erase: erase from 5978688 to 6172671 arg 0x00000000
[  126.640808] sunxi-mmc 1c0f000.sdmmc: *All wait r1 rdy 3 ms*
[  126.719557] mmc0:mmc_do_erase: erase from 6250496 to 6434807 arg 0x00000000
[  126.758883] sunxi-mmc 1c0f000.sdmmc: *All wait r1 rdy 2 ms*
[  126.876972] mmc0:mmc_do_erase: erase from 6469208 to 6484023 arg 0x00000000
[  126.916331] sunxi-mmc 1c0f000.sdmmc: *All wait r1 rdy 2 ms*
[  126.924766] mmc0:mmc_do_erase: erase from 6494544 to 6533119 arg 0x00000000
[  126.965503] sunxi-mmc 1c0f000.sdmmc: *All wait r1 rdy 2 ms*
[  126.975402] mmc0:mmc_do_erase: erase from 6545896 to 6557687 arg 0x00000000
[  126.995071] sunxi-mmc 1c0f000.sdmmc: *All wait r1 rdy 1 ms*
[  127.004909] mmc0:mmc_do_erase: erase from 6620904 to 6696959 arg 0x00000000
[  127.044268] sunxi-mmc 1c0f000.sdmmc: *All wait r1 rdy 2 ms*
[  127.063979] mmc0:mmc_do_erase: erase from 6697480 to 6959103 arg 0x00000000
[  127.122956] sunxi-mmc 1c0f000.sdmmc: *All wait r1 rdy 3 ms*
[  127.132820] mmc0:mmc_do_erase: erase from 7024640 to 7221247 arg 0x00000000
[  127.191819] sunxi-mmc 1c0f000.sdmmc: *All wait r1 rdy 3 ms*
[  127.201762] mmc0:mmc_do_erase: erase from 7221768 to 7483391 arg 0x00000000
[  127.260746] sunxi-mmc 1c0f000.sdmmc: *All wait r1 rdy 3 ms*
[  127.270680] mmc0:mmc_do_erase: erase from 7483392 to 7745535 arg 0x00000000
[  127.329587] sunxi-mmc 1c0f000.sdmmc: *All wait r1 rdy 3 ms*
[  127.349310] mmc0:mmc_do_erase: erase from 7746056 to 8007679 arg 0x00000000
[  127.408344] sunxi-mmc 1c0f000.sdmmc: *All wait r1 rdy 3 ms*
[  127.428060] mmc0:mmc_do_erase: erase from 8007680 to 8269823 arg 0x00000000
[  127.487038] sunxi-mmc 1c0f000.sdmmc: *All wait r1 rdy 3 ms*
[  127.506851] mmc0:mmc_do_erase: erase from 8270344 to 8531967 arg 0x00000000
[  127.585470] sunxi-mmc 1c0f000.sdmmc: *All wait r1 rdy 4 ms*
[  127.605190] mmc0:mmc_do_erase: erase from 8531968 to 8794111 arg 0x00000000
[  127.664159] sunxi-mmc 1c0f000.sdmmc: *All wait r1 rdy 3 ms*
[  127.703604] mmc0:mmc_do_erase: erase from 8794112 to 9056255 arg 0x00000000
[  127.801958] sunxi-mmc 1c0f000.sdmmc: *All wait r1 rdy 5 ms*
[  127.831491] mmc0:mmc_do_erase: erase from 9056256 to 9318399 arg 0x00000000
[  127.949546] sunxi-mmc 1c0f000.sdmmc: *All wait r1 rdy 6 ms*
[  128.018448] mmc0:mmc_do_erase: erase from 9318400 to 9580543 arg 0x00000000
[  128.077465] sunxi-mmc 1c0f000.sdmmc: *All wait r1 rdy 3 ms*
[  128.116653] acc_open
[  128.119102] acc_release
[  128.126693] mmc0:mmc_do_erase: erase from 9580544 to 9842687 arg 0x00000000
[  128.185679] sunxi-mmc 1c0f000.sdmmc: *All wait r1 rdy 3 ms*
[  128.225104] mmc0:mmc_do_erase: erase from 9842688 to 10104831 arg 0x00000000
[  128.284105] sunxi-mmc 1c0f000.sdmmc: *All wait r1 rdy 3 ms*
[  128.296000] mmc0:mmc_do_erase: erase from 10172248 to 10366975 arg 0x00000000
[  128.343148] sunxi-mmc 1c0f000.sdmmc: *All wait r1 rdy 2 ms*
[  128.362875] mmc0:mmc_do_erase: erase from 10367000 to 10629119 arg 0x00000000
[  128.421833] sunxi-mmc 1c0f000.sdmmc: *All wait r1 rdy 3 ms*
[  128.431705] mmc0:mmc_do_erase: erase from 10629120 to 10891263 arg 0x00000000
[  128.480911] sunxi-mmc 1c0f000.sdmmc: *All wait r1 rdy 2 ms*
[  128.500612] mmc0:mmc_do_erase: erase from 10891264 to 11153407 arg 0x00000000
[  128.559621] sunxi-mmc 1c0f000.sdmmc: *All wait r1 rdy 3 ms*
[  128.638338] mmc0:mmc_do_erase: erase from 11153408 to 11415551 arg 0x00000000
[  128.697342] sunxi-mmc 1c0f000.sdmmc: *All wait r1 rdy 3 ms*
[  128.707303] mmc0:mmc_do_erase: erase from 11415552 to 11677695 arg 0x00000000
[  128.707640] type=1400 audit(1262304127.310:46): avc: denied { read write } f1
[  128.707761] type=1400 audit(1262304127.310:47): avc: denied { open } for pid1
[  128.707940] type=1400 audit(1262304127.310:48): avc: denied { ioctl } for pi1
[  128.785108] HDMI hdmi_cec_thread started
[  128.788912] [HDMI_CEC] set logical_address=15
[  128.844947] hdmi_cec_finish_send: msg_len=1 tx_answer=CEC_TX_NACK
[  128.844954] sunxi-mmc 1c0f000.sdmmc: *All wait r1 rdy 3 ms*
[  128.884359] mmc0:mmc_do_erase: erase from 11677696 to 11939839 arg 0x00000000
[  128.894148] hdmi_cec_finish_send: msg_len=1 tx_answer=CEC_TX_NACK
[  128.933509] hdmi_cec_finish_send: msg_len=1 tx_answer=CEC_TX_NACK
[  128.943503] sunxi-mmc 1c0f000.sdmmc: *All wait r1 rdy 3 ms*
[  128.963099] mmc0:mmc_do_erase: erase from 11939840 to 12201983 arg 0x00000000
[  129.022102] sunxi-mmc 1c0f000.sdmmc: *All wait r1 rdy 3 ms*
[  129.189391] mmc0:mmc_do_erase: erase from 12201984 to 12464127 arg 0x00000000
[  129.248394] sunxi-mmc 1c0f000.sdmmc: *All wait r1 rdy 3 ms*
[  129.277975] mmc0:mmc_do_erase: erase from 12464648 to 12726271 arg 0x00000000
[  129.336958] sunxi-mmc 1c0f000.sdmmc: *All wait r1 rdy 3 ms*
[  129.366506] mmc0:mmc_do_erase: erase from 12726272 to 12988415 arg 0x00000000
[  129.425506] sunxi-mmc 1c0f000.sdmmc: *All wait r1 rdy 3 ms*
[  129.435419] mmc0:mmc_do_erase: erase from 12988936 to 13250559 arg 0x00000000
[  129.494391] sunxi-mmc 1c0f000.sdmmc: *All wait r1 rdy 3 ms*
[  129.500913] mmc0:mmc_do_erase: erase from 13250560 to 13512703 arg 0x00000000
[  129.563281] sunxi-mmc 1c0f000.sdmmc: *All wait r1 rdy 3 ms*
[  129.569664] mmc0:mmc_do_erase: erase from 13512704 to 13774847 arg 0x00000000
[  129.651863] sunxi-mmc 1c0f000.sdmmc: *All wait r1 rdy 4 ms*
[  129.655040] libphy: 1c30000.eth: probed
[  129.662703] mmc0:mmc_do_erase: erase from 13774848 to 14036991 arg 0x00000000
[  129.691368] sunxi-gmac 1c30000.eth eth0: eth0: PHY ID 001cc915 at 0 IRQ poll)
[  129.740401] sunxi-mmc 1c0f000.sdmmc: *All wait r1 rdy 4 ms*
[  129.760308] mmc0:mmc_do_erase: erase from 14036992 to 14299135 arg 0x00000000
[  129.828955] sunxi-mmc 1c0f000.sdmmc: *All wait r1 rdy 3 ms*
[  130.025824] mmc0:mmc_do_erase: erase from 14319872 to 14561279 arg 0x00000000
[  130.038306] RTL871X: module init start
[  130.042406] RTL871X: rtl8723bs v4.3.16_13854.20150410_BTCOEX20150119-5844
[  130.050446] RTL871X: build time: Oct  5 2016 12:09:30
[  130.056150] RTL871X: rtl8723bs BT-Coex version = BTCOEX20150119-5844
[  130.063248] sunxi-wlan wlan.28: bus_index: 1
[  130.068378] sunxi-wlan wlan.28: check wlan io_regulator voltage: 1800000
[  130.084877] sunxi-mmc 1c0f000.sdmmc: *All wait r1 rdy 3 ms*
[  130.091951] mmc0:mmc_do_erase: erase from 14561280 to 14823423 arg 0x00000000
[  130.153769] sunxi-mmc 1c0f000.sdmmc: *All wait r1 rdy 3 ms*
[  130.160186] mmc0:mmc_do_erase: erase from 14823424 to 15085567 arg 0x00000000
[  130.185731] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21B
[  130.197377] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[  130.198657] RTL871X: module init ret=0
[  130.212751] sunxi-mmc 1c0f000.sdmmc: *All wait r1 rdy 2 ms*
[  130.219763] mmc0:mmc_do_erase: erase from 15085568 to 15347711 arg 0x00000000
[  130.222577] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vB
[  130.243018] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[  130.250500] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[  130.257876] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vB
[  130.271744] sunxi-mmc 1c0f000.sdmmc: *All wait r1 rdy 2 ms*
[  130.274148] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vB
[  130.275977] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[  130.276790] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[  130.277751] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[  130.278557] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[  130.279361] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[  130.280175] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[  130.281991] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[  130.282806] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[  130.283613] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[  130.283631] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vB
[  130.284500] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 1, RTO !!
[  130.284515] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0B
[  130.389920] mmc0:mmc_do_erase: erase from 15347712 to 15523839 arg 0x00000000
[  130.429207] sunxi-mmc 1c0f000.sdmmc: *All wait r1 rdy 2 ms*
[  130.438710] init: Starting service 'p2p_supplicant'...
[  131.013811] SELinux: initialized (dev fuse, type fuse), uses genfs_contexts
[  131.033884] SELinux: initialized (dev fuse, type fuse), uses genfs_contexts
[  131.049436] SELinux: initialized (dev fuse, type fuse), uses genfs_contexts
[  131.151442] init: Service 'p2p_supplicant' (pid 7712) exited with status 255
[  132.991826] type=1400 audit(1262304131.660:49): avc: denied { read } for pid1
[  133.015264] type=1400 audit(1262304131.660:50): avc: denied { open } for pid1
[  133.492375] type=1401 audit(1262304132.170:51): SELinux: unrecognized netlin2
[  133.492375]
[  133.526047] type=1401 audit(1262304132.170:52): SELinux: unrecognized netlin2
[  133.526047]
[  133.935566] type=1400 audit(1262304132.620:53): avc: denied { ioctl } for pi1
[  133.935719] [HDMI_CEC] set logical_address=4
[  134.099570] hdmi_cec_finish_send: msg_len=5 tx_answer=CEC_TX_DONE
[  134.247591] hdmi_cec_finish_send: msg_len=5 tx_answer=CEC_TX_DONE
[  134.611437] libphy: 1c30000.eth-0:00 - Link is Up - 1000/Full
[  134.642470] type=1401 audit(1262304133.330:54): SELinux: unrecognized netlin2
[  134.642470]
[  134.815713] sunxi-bt bt.29: block state already is 1
[  135.019427] sunxi-bt bt.29: set block: 0
[  135.024794] sunxi-bt bt.29: check bluetooth io_regulator voltage: 1800000
[  135.087115] alloc_contig_range test_pages_isolated(a0445, a069d) failed
[  136.229713] alloc_contig_range test_pages_isolated(9ff94, a01bc) failed
[  139.967142] sunxi-bt bt.29: set block: 1
[  140.169873] sunxi-bt bt.29: set block: 0
[  140.174377] sunxi-bt bt.29: check bluetooth io_regulator voltage: 1800000
[  142.338281] init: Service 'bootanim' (pid 1896) exited with status 0
[  142.518689] usbcore: registered new interface driver uvcvideo
[  142.525480] USB Video Class driver (1.1.1)
[  142.558404] gspca_main: v2.14.0 registered
[  142.563536] init: write_file: Unable to open '/sys/devices/soc.0/cpu_budget_y
[  144.935511] CPU2: shutdown
[  144.938651] psci: CPU2 killed.
[  145.330459] CPU2: Booted secondary processor
[  145.335179] CPU2: update cpu_power 1968128
[  145.344358] healthd: battery none chg=a
[  145.528679] RTL871X: module exit start
[  145.533364] sunxi-wlan wlan.28: bus_index: 1
[  145.553300] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21B
[  145.573045] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[  145.592622] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vB
[  145.622952] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[  145.630418] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[  145.638623] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vB
[  145.652749] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vB
[  145.666047] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[  145.674336] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[  145.682156] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[  145.689543] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[  145.696938] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[  145.704941] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[  145.712491] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[  145.719997] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[  145.727528] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[  145.734272] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vB
[  145.746809] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 1, RTO !!
[  145.753727] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0B
[  145.996088] RTL871X: module exit success
[  146.754020] sunxi-bt bt.29: set block: 1
[  146.902633] CPU2: shutdown
[  146.905640] psci: CPU2 killed.
[  146.974514] sunxi-bt bt.29: set block: 0
[  146.978987] sunxi-bt bt.29: check bluetooth io_regulator voltage: 1800000
[  147.692222] CPU2: Booted secondary processor
[  147.696936] CPU2: update cpu_power 1968128
[  149.265073] CPU3: shutdown
[  149.268130] psci: CPU3 killed.
[  150.053654] CPU3: Booted secondary processor
[  150.058347] CPU3: update cpu_power 1968128
[  150.281166] RTL871X: module init start
[  150.285266] RTL871X: rtl8723bs v4.3.16_13854.20150410_BTCOEX20150119-5844
[  150.294319] RTL871X: build time: Oct  5 2016 12:09:30
[  150.299918] RTL871X: rtl8723bs BT-Coex version = BTCOEX20150119-5844
[  150.306967] sunxi-wlan wlan.28: bus_index: 1
[  150.311946] sunxi-wlan wlan.28: check wlan io_regulator voltage: 1800000
[  150.428582] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21B
[  150.439952] RTL871X: module init ret=0
[  150.440037] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[  150.453640] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vB
[  150.466730] init: Starting service 'p2p_supplicant'...
[  150.493832] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[  150.501643] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[  150.508337] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vB
[  150.524899] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vB
[  150.539803] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[  150.547211] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[  150.554675] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[  150.562047] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[  150.569865] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[  150.577308] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[  150.584874] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[  150.592342] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[  150.599802] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[  150.606515] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vB
[  150.619112] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 1, RTO !!
[  150.625816] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0B
[  150.646014] init: Service 'p2p_supplicant' (pid 9722) exited with status 255
[  151.625811] CPU3: shutdown
[  151.628802] psci: CPU3 killed.
[  152.809106] CPU3: Booted secondary processor
[  152.813856] CPU3: update cpu_power 1968128
[  155.562570] CPU3: shutdown
[  155.565539] psci: CPU3 killed.
[  155.760886] CPU3: Booted secondary processor
[  155.765602] CPU3: update cpu_power 1968128
[  156.841684] sunxi-bt bt.29: set block: 1
[  157.045894] sunxi-bt bt.29: set block: 0
[  157.051059] sunxi-bt bt.29: check bluetooth io_regulator voltage: 1800000
[  157.332975] CPU3: shutdown
[  157.335944] psci: CPU3 killed.
[  157.728941] CPU3: Booted secondary processor
[  157.733647] CPU3: update cpu_power 1968128
[  159.300884] CPU3: shutdown
[  159.303865] psci: CPU3 killed.
[  159.894325] CPU3: Booted secondary processor
[  159.899061] CPU3: update cpu_power 1968128
[  161.860728] CPU3: shutdown
[  161.864427] psci: CPU3 killed.
[  162.279727] sunxi-bt bt.29: set block: 1
[  162.482850] sunxi-bt bt.29: set block: 0
[  162.487348] sunxi-bt bt.29: check bluetooth io_regulator voltage: 1800000
[  162.845860] CPU3: Booted secondary processor
[  162.850587] CPU3: update cpu_power 1968128
[  164.417715] CPU3: shutdown
[  164.421418] psci: CPU3 killed.
[  164.617143] CPU3: Booted secondary processor
[  164.621912] CPU3: update cpu_power 1968128
[  165.509531] type=1400 audit(1475757529.794:55): avc: denied { write } for pi1
[  165.533045] type=1400 audit(1475757529.794:56): avc: denied { open } for pid1
[  165.589718] RTL871X: module exit start
[  165.594352] sunxi-wlan wlan.28: bus_index: 1
[  165.599899] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21B
[  165.611116] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[  165.636743] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vB
[  165.667086] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[  165.674661] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[  165.681343] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vB
[  165.695766] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vB
[  165.709459] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[  165.717062] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[  165.724464] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[  165.731910] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[  165.739345] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[  165.746776] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[  165.754316] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[  165.761810] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[  165.769343] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[  165.776073] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vB
[  165.788949] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 1, RTO !!
[  165.795566] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0B
[  166.099328] RTL871X: module exit success
[  166.188964] CPU3: shutdown
[  166.192883] psci: CPU3 killed.
[  166.781651] CPU3: Booted secondary processor
[  166.786356] CPU3: update cpu_power 1968128
[  167.419312] sunxi-bt bt.29: set block: 1
[  167.622054] sunxi-bt bt.29: set block: 0
[  167.629393] sunxi-bt bt.29: check bluetooth io_regulator voltage: 1800000
[  169.140949] CPU3: shutdown
[  169.143931] psci: CPU3 killed.
[  169.341251] CPU3: Booted secondary processor
[  169.345975] CPU3: update cpu_power 1968128
[  170.348369] RTL871X: module init start
[  170.352549] RTL871X: rtl8723bs v4.3.16_13854.20150410_BTCOEX20150119-5844
[  170.360142] RTL871X: build time: Oct  5 2016 12:09:30
[  170.366448] RTL871X: rtl8723bs BT-Coex version = BTCOEX20150119-5844
[  170.373858] sunxi-wlan wlan.28: bus_index: 1
[  170.378776] sunxi-wlan wlan.28: check wlan io_regulator voltage: 1800000
[  170.499956] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21B
[  170.501019] RTL871X: module init ret=0
[  170.516486] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[  170.524889] init: Starting service 'p2p_supplicant'...
[  170.546906] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vB
[  170.577227] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[  170.585089] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[  170.591777] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vB
[  170.605943] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vB
[  170.619406] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[  170.623623] init: Service 'p2p_supplicant' (pid 11414) exited with status 255
[  170.634610] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[  170.642022] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[  170.649446] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[  170.656849] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[  170.664369] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[  170.671870] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[  170.679370] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[  170.686856] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[  170.693568] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vB
[  170.707281] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 1, RTO !!
[  170.713960] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0B
[  171.108968] CPU3: shutdown
[  171.112154] psci: CPU3 killed.
[  172.695959] sunxi-bt bt.29: set block: 1
[  172.899510] sunxi-bt bt.29: set block: 0
[  172.904019] sunxi-bt bt.29: check bluetooth io_regulator voltage: 1800000
[  174.063500] CPU3: Booted secondary processor
[  174.068238] CPU3: update cpu_power 1968128
[  175.832202] CPU3: shutdown
[  175.835182] psci: CPU3 killed.
Edit: Due to lack of time I only tested shortly with the LCD and maybe I suffered from bad PSU or anything else.
Also received a replacement board, but same basic problems with GbE, so unfortunately no further help from my side possible
Please get back to TL Lim and ask what to do. I can send you one of the working boards but need it here for some time to do a few tests before.
They really should start with a quick QA round at least for the replacement boards (they sent 4 boards out to us and 2 are defective -- huh?). But it seems they really don't care that much about what's happening...
BTW: Had a short look into pine64 forums after weeks. Unbelievable that a specific person is still moderator and now tries to tell @ssvb about Mali -- too funny (if I would ever have a question regarding Mali I would always ask Siarhei first)
For me this is fine, will be in hospital till beginning of November, so don't need a new board till that time.
Will also check with tllim the next steps, but it seems they didn't even test those boards they sent out and still they have no real idea whats wrong with their boards....
Its a real pain board.
Well, a few hardware flaws (shitty Micro USB, no custom led, the GbE issue, the HDMI drama, now the LCD mess) combined with pretty careless after-sales behaviour (still no real 'getting started guide', moderators enabled to act as censors, no wiki updates, a clueless 'moderator elite' responsible for the moronic Mali hype, no QA at least for hardware replacements and so on) and Pine64 turns into Pain64. Everything as expected ;)
BTW: this poor guy here also suffers from the GbE issue and now the PoE adapter (from Pine64 only capable of Fast Ethernet) masks the symptoms: http://forum.pine64.org/showthread.php?tid=1068&pid=20973#pid20973(and now the poor guy buys a new PSU for no reason or let's say it more clear: since the forum over there and documentation of well known issues still so much sucks)
Get well soon!
tkaiser, I have to ask, what HDMI drama?
Please see post #1 here or N°4 there. Given the similarities of HDMI drivers in H3 and A64 BSP I still wonder why there were so many issues with no display output at all but maybe that's just because the majority of Pine64 users had no idea about the SBC concept at all or simply believed in the marketing claims to get a '$15 supercomputer'?
If I understand correctly, those issues also exists on H3, due to same HDMI IP and basically the same driver code?
From my experience, A64 HDMI blob can be reproduced from H3 HDMI source + one function, which I published in OrangePi forum. So if anyone would like to play with it, it's possible, but license issues still remain. Currently I'm trying to port most HDMI patches from linux-sunxi repo to H3 kernel with some of my own fixes, so EDID negotiation and non 16:9 resolutions would be possible. It will take some time, though. I imagine that it would solve most of those issues?
To be honest: while testing with A64 a few hundred hours (unattended of course) I might have connected a display to the Pine64+ I had here maybe one or two times. IIRC I tried out whether the HDMI-to-DVI fixes known from A83T and H3 also match with A64 BSP kernel.
So I'm definitely the wrong person to ask for display issues. But I highly appreciate that you look into. It can't be overestimated what you've done for H3 already. Do you have access to A64 hardware already?
