Unable to locate package linux-headers-5.10.60-sunxi64
FRANK333
Armbianmonitor:
I wanted to install wireguard, I launched wireguard-monitor but the script did not work and gave me these errors,
Building dependency tree
E: Unable to locate package linux-headers-5.10.60-sunxi64
E: Couldn't find any package by glob 'linux-headers-5.10.60-sunxi64'
E: Couldn't find any package by regex 'linux-headers-5.10.60-sunxi64'
Reading package lists... Done
should I upgrade to a new kernel, or is there any other way?
hello igor, if i understand well then, wireguard client is already integrated, how do i pass the authentication data to connect to the server on the vps. using the wireguard-manager script i also have this anomaly
Spoiler
Job for unbound.service failed because the control process exited with error code.
See "systemctl status unbound.service" and "journalctl -xe" for details.
invoke-rc.d: initscript unbound, action "start" failed.
● unbound.service - Unbound DNS server
     Loaded: loaded (/lib/systemd/system/unbound.service; enabled; vendor preset: enabled)
     Active: activating (auto-restart) (Result: exit-code) since Sun 2021-11-21 13:34:03 CET; 38ms ago
       Docs: man:unbound(8)
    Process: 4747 ExecStartPre=/usr/lib/unbound/package-helper chroot_setup (code=exited, status=0/SUCCESS)
    Process: 4770 ExecStartPre=/usr/lib/unbound/package-helper root_trust_anchor_update (code=exited, status=0/SUCCESS)
    Process: 4777 ExecStart=/usr/sbin/unbound -d $DAEMON_OPTS (code=exited, status=1/FAILURE)
   Main PID: 4777 (code=exited, status=1/FAILURE)
Processing triggers for systemd (245.4-4ubuntu3.13) ...
Processing triggers for man-db (2.9.1-1) ...
Processing triggers for libc-bin (2.31-0ubuntu9.2) ...
659
Removed /etc/systemd/system/multi-user.target.wants/systemd-resolved.service.
Removed /etc/systemd/system/dbus-org.freedesktop.resolve1.service.
Not entirely. Kernel part is a part of our kernel. The thing you were trying to achieve by downloading kernel headers and making a module.
Spoiler
bananapim2plus:~:# modinfo wireguard
filename:       /lib/modules/5.10.75-sunxi/kernel/drivers/net/wireguard/wireguard.ko
alias:          net-pf-16-proto-16-family-wireguard
alias:          rtnl-link-wireguard
version:        1.0.0
author:         Jason A. Donenfeld <Jason@zx2c4.com>
description:    WireGuard secure network tunnel
license:        GPL v2
srcversion:     44D713150F1EA3D8C223362
depends:        libblake2s,udp_tunnel,curve25519-neon,libchacha20poly1305,ip6_udp_tunnel,libcurve25519-generic
intree:         Y
vermagic:       5.10.75-sunxi SMP mod_unload ARMv7 thumb2 p2v8
sig_id:         PKCS#7
signer:         Build time autogenerated kernel key
sig_key:        0C:2B:C9:2C:54:AA:85:41:F8:A9:46:F7:25:DD:40:3D:5F:02:CD:53
sig_hashalgo:   sha1
signature:      9E:B2:50:85:DF:4D:64:54:87:7A:C5:6E:C1:AF:F5:5D:48:66:F6:43:
		91:F4:26:85:38:19:3B:85:FE:8B:D4:9C:89:7A:69:F7:8F:56:CE:D7:
		C6:E0:9A:29:37:DE:2A:17:AE:AC:CC:51:91:84:BF:45:7A:AF:0F:B4:
		16:63:2B:8C:04:EB:0A:F1:3D:EF:4A:D9:18:55:42:6D:41:6B:B7:F7:
		2A:F7:05:BA:B3:FA:57:0D:55:22:A8:83:90:C9:BF:1F:DB:C7:5C:62:
		80:95:5B:9A:06:27:9F:55:2E:50:F1:EE:4F:7F:07:24:21:67:42:65:
		A4:F9:FA:66:36:0F:31:71:B0:49:BC:9E:EF:5B:DB:7D:78:A3:B8:F9:
		E0:5F:57:82:A6:D0:65:A0:72:7F:D6:7A:47:C1:4F:95:34:72:6D:01:
		38:E9:5E:84:9F:75:F3:0A:71:B4:EC:DB:4B:CF:15:CC:FC:3C:AA:7F:
		50:85:58:B6:ED:94:13:C9:3F:0B:56:F8:40:0D:20:B6:C6:85:DE:32:
		C8:B2:B9:FA:F9:83:C6:CE:F2:17:56:1A:A1:2F:1B:CD:FC:AC:18:B2:
		43:04:3F:B1:C5:4A:B7:2F:43:A8:88:6E:02:E5:76:43:B8:CE:41:44:
		D3:09:05:7B:5F:D8:1B:1B:3B:01:6C:BE:97:D3:66:61:82:AD:02:49:
		98:92:B1:A8:03:92:73:39:03:90:F9:9C:63:48:91:B1:89:D0:1E:2C:
		A7:C5:D1:EA:2C:3A:45:28:52:DA:1C:99:96:C8:D3:8B:2A:73:95:57:
		6D:E0:1C:EA:8A:F3:08:35:2B:D8:4B:46:63:B6:64:9A:BB:F7:97:44:
		B2:40:86:04:A6:00:8D:DC:59:C5:D5:63:01:28:CC:C0:0C:17:9D:C8:
		02:AB:59:22:67:68:D2:ED:B2:3F:CE:71:96:0C:53:A5:E6:C8:46:35:
		23:57:0D:30:27:B8:AD:99:93:BE:49:9D:6E:24:64:47:86:9B:FC:78:
		76:71:A7:3E:DE:C2:F5:D7:5B:D3:54:E6:46:C2:1E:39:9D:13:9F:F8:
		1B:82:0B:51:2B:7F:D8:68:9F:52:86:44:47:6B:E5:81:E4:4F:51:4A:
		59:20:68:AF:FA:A7:1C:92:30:74:0E:E3:AF:52:47:E8:9A:3B:82:E2:
		B2:03:E7:B5:AE:4A:ED:55:57:AD:C5:1E:A6:36:22:F2:91:07:20:B8:
		7E:96:1F:EB:E0:AC:64:D3:8B:B6:02:B0:FC:86:B8:81:2F:FA:04:91:
		E8:A2:95:6E:C1:73:86:0A:F1:8F:D1:FD:ED:6B:39:35:12:20:1D:70:
		11:8C:17:AD:71:86:E7:25:12:37:F7:29
Armbian helped you to save some time by integrating WG into the kernel, but how to deal with it from user perspective, no idea, check general public, perhaps someone could provide you some clues.
