xatatol160 Posted December 12, 2021 Share Posted December 12, 2021 I have a mini computer with ubuntu installed, I forgot my system password, how can I restart it? The Mini PC does not use grub, only U-boot I ran the printenv command and I wonder where I should add the variable to be able to change the root password boot_a_script=load ${devtype} ${devnum}:${distro_bootpart} ${scriptaddr} ${prefix}${script}; source ${scriptaddr} boot_extlinux=sysboot ${devtype} ${devnum}:${distro_bootpart} any ${scriptaddr} ${prefix}extlinux/extlinux.conf boot_net_usb_start=usb start boot_prefixes=/ /boot/ boot_script_dhcp=boot.scr.uimg boot_scripts=boot.scr.uimg boot.scr boot_targets=mmc1 mmc0 usb0 pxe dhcp bootargs=storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal androidboot.dtb_idx=0 androidboot.dtbo_idx=0 bootcmd=boot_fit;boot_android ${devtype} ${devnum};run distro_bootcmd; bootcmd_dhcp=run boot_net_usb_start; if dhcp ${scriptaddr} ${boot_script_dhcp}; then source ${scriptaddr}; fi; bootcmd_mmc0=setenv devnum 0; run mmc_boot bootcmd_mmc1=setenv devnum 1; run mmc_boot bootcmd_pxe=run boot_net_usb_start; dhcp; if pxe get; then pxe boot; fi bootcmd_usb0=setenv devnum 0; run usb_boot bootdelay=0 cpu=armv8 devnum=0 devtype=mmc distro_bootcmd=for target in ${boot_targets}; do run bootcmd_${target}; done mmc_boot=if mmc dev ${devnum}; then setenv devtype mmc; run scan_dev_for_boot_part; fi 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted December 13, 2021 Share Posted December 13, 2021 Moved to Common issues / peer to peer technical support 0 Quote Link to comment Share on other sites More sharing options...
Myron Posted February 1, 2022 Share Posted February 1, 2022 I wonder if this may help from a u-boot cheat sheet I found at http://nerveware.org/u-boot-cheat-sheet/1.html Boot into single user mode Single user mode is mostly used to reset forgotten passwords, but the command below might be usefull for debug purposes as well (omit init). U-Boot > setenv bootargs "${bootargs} reboot=cold,hard emergency init=/bin/sh" For embedded devices, the root partition is frequently mounted read only. $ mount -t proc none /proc $ mount -o remount,rw / $ passwd root Enter new UNIX password: Retype new UNIX password: passwd: password updated successfully $ sync I am guessing that to do this you will need to connect a RS232 to TTL UART board to the debug serial port on the board to get to the U-Boot command prompt. I've yet tried this method on my board, but I have got myself to the U-Boot>_ prompt. 1 Quote Link to comment Share on other sites More sharing options...
SergioAiello Posted January 17, 2023 Share Posted January 17, 2023 Hi, is the single user login an option with Orange Pi? I need to recover the root password. I'm used to login as a user and I can't figure out the root password anymore. Is it possible to remove the password so to recover setting a new one at next bootstrap? Thank you, Best regards, S. ps: in case it helps, I can load an image to an additional SD card, boot and log as root so to try to modify the former SD connected with a USB reader/port. 0 Quote Link to comment Share on other sites More sharing options...
SteeMan Posted January 17, 2023 Share Posted January 17, 2023 @SergioAiello If I understand you correctly, you still have access to the system via a regular user account. It is likely that this regular user account was the one created during your first boot, in which case that user will have sudo permissions. So you can sudo su root to become the root user, and from there you can reset the root password. 0 Quote Link to comment Share on other sites More sharing options...
SergioAiello Posted January 17, 2023 Share Posted January 17, 2023 Thank you The case is as you properly described. According to my knowledge only the RPi allows to issue the "sudo" cmd without prompting for "root" password. In my case ("Armbian") after "sudo" I have to in the "root" password. Do you agree? 0 Quote Link to comment Share on other sites More sharing options...
SteeMan Posted January 17, 2023 Share Posted January 17, 2023 sudo prompts for the users password (not roots password) - that is the whole point of sudo, allowing a user with sudo privilege to issue commands as root, but first requiring they re-authenticate themselves. 0 Quote Link to comment Share on other sites More sharing options...
SergioAiello Posted January 18, 2023 Share Posted January 18, 2023 (edited) I mean if i need to launch or open a file owned by root (I write: -> sudo <filename>) then I am asked to insert the root password. Unfortunately I can't modify the file "passwd". I can only open it in "read-only" mode. But also if I write "su" I'm prompted to insert the root password. How can I reset root password? thank you. Edited January 18, 2023 by SergioAiello 0 Quote Link to comment Share on other sites More sharing options...
CryBaby Posted January 18, 2023 Share Posted January 18, 2023 You are mistaken. Please reread Steeman's last post until you understand it. 0 Quote Link to comment Share on other sites More sharing options...
SergioAiello Posted January 22, 2023 Share Posted January 22, 2023 Thank you, Clear, now. Apologies for the mistake. In case there is no chance to login, is there a recovery procedure? Maybe using another OPi and a SD card reader? Is it possible to access the file system in that way? Thank you, 0 Quote Link to comment Share on other sites More sharing options...
Myron Posted January 22, 2023 Share Posted January 22, 2023 https://docs.armbian.com/User-Guide_Recovery/ 0 Quote Link to comment Share on other sites More sharing options...
