Ryanfab Posted December 25, 2021 Share Posted December 25, 2021 my board S902x I have download Armbian_20.10_Arm-64_bionic_current_5.9.0.xz from https://disk.yandex.ru/d/_rQgn_FosYuW0g/20.10/20201014 I extract xz -d Armbian_20.10_Arm-64_bionic_current_5.9.0.xz then burn using balena some changes are extlinux/extlinux.conf LABEL Armbian LINUX /zImage INITRD /uInitrd FDT /dtb/amlogic/meson-gxl-s905x-p212.dtb APPEND root=LABEL=ROOTFS rootflags=data=writeback rw console=ttyAML0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 boot.ini become ODROIDN2-UBOOT-CONFIG if test "${devtype}" = ""; then setenv devtype "/dtb/amlogic/meson-gxl-s905x-p212.dtb"; fi if fatload ${devtype} ${devnum} 0x1000000 u-boot.ext; then go 0x1000000; fi; rename u-boot-s905x-s912 to u-boot.ext when I put on reboot_mode=cold_boot InUsbBurn [MSG]sof Set Addr 6 Get DT cfg Get DT cfg Get DT cfg set CFG then I send command from windows cli updater c:\update bulkcmd "run start_mmc_autoscript;" I can running linux I need advice to install to emmc, appreciate your response. thank you 0 Quote Link to comment Share on other sites More sharing options...
Ryanfab Posted December 25, 2021 Author Share Posted December 25, 2021 root@arm-64:~# fdisk -l /dev/mmcblk1 Disk /dev/mmcblk1: 7.3 GiB, 7818182656 bytes, 15269888 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: dos Disk identifier: 0x8b04b650 Device Boot Start End Sectors Size Id Type /dev/mmcblk1p1 1953792 2953215 999424 488M c W95 FAT32 (LBA) /dev/mmcblk1p2 2955264 15269887 12314624 5.9G 83 Linux root@arm-64:~# fdisk -l /dev/mmcblk0 Disk /dev/mmcblk0: 14.9 GiB, 15931539456 bytes, 31116288 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: dos Disk identifier: 0x7272c9e5 Device Boot Start End Sectors Size Id Type /dev/mmcblk0p1 32768 1081343 1048576 512M e W95 FAT16 (LBA) /dev/mmcblk0p2 1081344 30805119 29723776 14.2G 83 Linux 0 Quote Link to comment Share on other sites More sharing options...
ning Posted December 26, 2021 Share Posted December 26, 2021 if you don't want to keep vendor OS, just simply install mainline uboot, and install https://packages.debian.org/bullseye/u-boot-menu it will generate extlinux.conf which similar to grub.conf. 0 Quote Link to comment Share on other sites More sharing options...
Ryanfab Posted December 26, 2021 Author Share Posted December 26, 2021 how to do that ? i install using install-aml.sh is failed it's 1gb ram and 8 gb emmc. should I change the dtb ? here is my armbian log http://ix.io/3JvI my trial on Armbian_20.10_Arm-64_focal_current_5.9.0_desktop.xz from https://disk.yandex.ru/d/_rQgn_FosYuW0g/20.10/20201014 0 Quote Link to comment Share on other sites More sharing options...
d4l170 Posted January 1, 2022 Share Posted January 1, 2022 hai...@Ryanfab, i have the same board. have you succeed installing armbian on this board? 0 Quote Link to comment Share on other sites More sharing options...
Ryanfab Posted January 4, 2022 Author Share Posted January 4, 2022 still can't install to emmc but run well on micro SD 0 Quote Link to comment Share on other sites More sharing options...
Eddy_T Posted January 10, 2022 Share Posted January 10, 2022 I have a T95 Minimx+ (Amlogic s905x) with 1 GB ram and 8GB flash I followed balbes150 posts and downloaded Armbian_20.10_Arm-64_buster_current_5.9.0.img burnt it to flash and renamed u-boot-s905x-s912 to u-boot.ext. I also edited extlinux.conf I nserted the sd card into the TV box, and it booted but stopped at 'Starting Kernel' I have attached the extlinux.conf file and a screenshot of the booting sequence. Any help would be appreciatwed as I have 10 of these boxes that i need to instal Armbian on. Thank you very much extlinux.conf extlinux.conf-menu 0 Quote Link to comment Share on other sites More sharing options...
boxmeister Posted January 11, 2022 Share Posted January 11, 2022 Hey im running Armbian_20.10_Arm-64_buster_current_5.9.0.img on an X96 Max (S905x2) and it works fine from sd-card but since this build is command line only, im not sure how to copy it to eMMc, so far all my attempts ended in me reinstalling armbian alltogether. (i used to run a desktop build and copying to eMMc was easy by mouseclick but now i need buster to run open media vault and i need to do it via command line) If anyone can point me to what fille/script i need to run id be more than happy. 0 Quote Link to comment Share on other sites More sharing options...
SteeMan Posted January 11, 2022 Share Posted January 11, 2022 2 hours ago, boxmeister said: If anyone can point me to what fille/script i need to run id be more than happy. This is covered in the last paragraph of the TV Box FAQ entry: Installation Instructions for TV Boxes with Amlogic CPUs 0 Quote Link to comment Share on other sites More sharing options...
boxmeister Posted January 11, 2022 Share Posted January 11, 2022 Thanks a lot for the pointer SteeMan, "sudo /root/install-aml.sh" did the trick and i now got an open media vault up and running. 1000*Thanks! 0 Quote Link to comment Share on other sites More sharing options...
Eddy_T Posted January 20, 2022 Share Posted January 20, 2022 On 12/25/2021 at 8:00 PM, ning said: if you don't want to keep vendor OS, just simply install mainline uboot, and install https://packages.debian.org/bullseye/u-boot-menu it will generate extlinux.conf which similar to grub.conf. hello Ning.. Can you point to a detailed step by step instructions? I am running (bullseye) with Linux 5.9.0-arm-64 on a Amlogic s905x (1G+8G T95x) from the sd card and want to run it from the emmc. I dont care about the vendor android OS that came on the box Thank you! 0 Quote Link to comment Share on other sites More sharing options...
ccs1664 Posted February 1, 2022 Share Posted February 1, 2022 On 1/4/2022 at 9:48 AM, Ryanfab said: still can't install to emmc but run well on micro SD 0 Quote Link to comment Share on other sites More sharing options...
ccs1664 Posted February 1, 2022 Share Posted February 1, 2022 Hi, after the boot, there´s a script called install-aml.sh, maybe located in /boot or / system, run it to install in emmc! Run it using the bash command: sh install-aml.sh. Once copied to emmc, reboot the box soon and install all the packages that you need. This file does a physical copy of whole system to emmc, it uses the "dd" command, precisely. 2 Quote Link to comment Share on other sites More sharing options...
wyim Posted March 15, 2023 Share Posted March 15, 2023 Quote On 2/2/2022 at 2:45 AM, ccs1664 said: Hi, after the boot, there´s a script called install-aml.sh, maybe located in /boot or / system, run it to install in emmc! Run it using the bash command: sh install-aml.sh. Once copied to emmc, reboot the box soon and install all the packages that you need. This file does a physical copy of whole system to emmc, it uses the "dd" command, precisely. Hi ccs1664: I am new to the Armbian. I am thinking of installing my Armbian from SD card to the emmc on my TV Box but worrying that might lose my multiboot (or the "toothpick method") from the SD card. Can I still able to boot into LibreElec/CoreElec/Batocera from SD card once I have installed my Armbian into my TV box with S905X3? 0 Quote Link to comment Share on other sites More sharing options...
SteeMan Posted March 15, 2023 Share Posted March 15, 2023 @wyim Have you read: It may or may not work. For example the installs for coreelec and armbian are incompatible. 0 Quote Link to comment Share on other sites More sharing options...
wyim Posted March 15, 2023 Share Posted March 15, 2023 (edited) @SteeMan Yes, I have read the post that you have mentioned. That's why I know about the "toothpick method" for activating the multiboot function.😀 Quote It may or may not work. For example the installs for coreelec and armbian are incompatible. I was thinking of using the EmuElec/LibraElec and Armbian in my TV box. I have drilled on how to do this from various sources. I know that coreelec use a different way to boot up the system from Armbian, but I am not sure if Eumelec/LibraElec may have the same problem. Maybe I am going to use both Armbian and Emuelec solely on external drives instead. Wouldn't it be possible if I have installed Armbian on emmc and boot with Batocera on SD card/USB? Edited March 15, 2023 by wyim 0 Quote Link to comment Share on other sites More sharing options...
SteeMan Posted April 8, 2023 Share Posted April 8, 2023 On 3/15/2023 at 10:34 AM, wyim said: Wouldn't it be possible if I have installed Armbian on emmc and boot with Batocera on SD card/USB? I don't know if this is possible or not since I don't know anything about what Batocera is. Unless Batocera uses the same booting process as Armbian, it is unlikely. 0 Quote Link to comment Share on other sites More sharing options...
Tu N Posted October 15, 2023 Share Posted October 15, 2023 Hi, I'm newbier. I installed armbian on Sdcard, it ran very well but when I installed on emmc, after reboot my box, it will appear deleting on boot screen, and can't boot armbian. How can I handle this? Please help. 0 Quote Link to comment Share on other sites More sharing options...
SteeMan Posted October 15, 2023 Share Posted October 15, 2023 @Tu N You have provided almost no information for anyone to help you. Please provide the following basic information: what box do you have, what build are you using (exact filename of image), what steps did you perform to install to emmc? 0 Quote Link to comment Share on other sites More sharing options...
