Ntemis Posted September 6, 2016 Share Posted September 6, 2016 Hi, as the title says while building this image i had this console reported error: E: Unable to locate package mali-sunxi-utils Also i would like to ask if there is hw acceleration(gpu) on xenial desktop images Thanks Link to comment Share on other sites More sharing options...
Igor Posted September 6, 2016 Share Posted September 6, 2016 There are few files missing from repository so the only way is to compile all ... which takes some time. Will be fixed asap. 1 Link to comment Share on other sites More sharing options...
Ntemis Posted September 7, 2016 Author Share Posted September 7, 2016 Hi I have now started a new build and i have a lot of E: Write error - write (32: Broken pipe)E: Write error - write (32: Broken pipe)E: Write error - write (32: Broken pipe)E: Write error - write (32: Broken pipe)E: Write error - write (32: Broken pipe)E: Write error - write (32: Broken pipe)E: Write error - write (32: Broken pipe)E: Write error - write (32: Broken pipe)E: Write error - write (32: Broken pipe)E: Write error - write (32: Broken pipe) Before the [ o.k. ] Downloading toolchain [ gcc-linaro-4.9-2016.02-x86_64_aarch64-linux-gnu ] Also i had to delete the repo and clone again because it couldnt git pull even with sudo Edit: i have now rm -rf armbian folder and re clone and re-started building and write error is not there...weird issue Edit2: Build process went successfully but previously reported error still there: http://paste.ubuntu.com/23147682/ Link to comment Share on other sites More sharing options...
