sbilevskiy Posted February 15, 2022 Share Posted February 15, 2022 (edited) Clean system does not start after migrating to SSD using armbian-config. Bootlog: Spoiler U-Boot SPL 2020.10-armbian (Aug 08 2021 - 14:54:07 +0200) DRAM: 2048 MiB CPU: 912000000Hz, AXI/AHB/APB: 3/2/2 Trying to boot from MMC1 U-Boot 2020.10-armbian (Aug 08 2021 - 14:54:07 +0200) Allwinner Technology CPU: Allwinner A20 (SUN7I) Model: Cubietech Cubietruck I2C: ready DRAM: 2 GiB MMC: mmc@1c0f000: 0, mmc@1c12000: 1 Loading Environment from FAT... Card did not respond to voltage select! Setting up a 1024x768 vga console (overscan 0x0) In: serial Out: vga Err: vga Allwinner mUSB OTG (Peripheral) Net: eth0: ethernet@1c50000, eth1: usb_ether 230454 bytes read in 18 ms (12.2 MiB/s) starting USB... Bus usb@1c14000: USB EHCI 1.00 Bus usb@1c14400: USB OHCI 1.0 Bus usb@1c1c000: USB EHCI 1.00 Bus usb@1c1c400: USB OHCI 1.0 scanning bus usb@1c14000 for devices... 1 USB Device(s) found scanning bus usb@1c14400 for devices... 1 USB Device(s) found scanning bus usb@1c1c000 for devices... 2 USB Device(s) found scanning bus usb@1c1c400 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Autoboot in 1 seconds switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3964 bytes read in 6 ms (644.5 KiB/s) ## Executing script at 43100000 U-boot loaded from SD Boot script loaded from mmc 203 bytes read in 4 ms (48.8 KiB/s) 9886418 bytes read in 549 ms (17.2 MiB/s) 7995296 bytes read in 445 ms (17.1 MiB/s) Found mainline kernel configuration 43983 bytes read in 18 ms (2.3 MiB/s) 5532 bytes read in 15 ms (359.4 KiB/s) Applying kernel provided DT fixup script (sun7i-a20-fixup.scr) ## Executing script at 45000000 ## Loading init Ramdisk from Legacy Image at 43300000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 9886354 Bytes = 9.4 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 43000000 Booting using the fdt blob at 0x43000000 EHCI failed to shut down host controller. Loading Ramdisk to 49692000, end 49fffa92 ... OK Loading Device Tree to 4961e000, end 49691fff ... OK Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 5.10.60-sunxi (root@runner7) (arm-linux-gnueabihf-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 2.32.0.20190321) #21.08.1 SMP Wed Aug 25 18:19:32 UTC 2021 [ 0.000000] CPU: ARMv7 Processor [410fc074] revision 4 (ARMv7), cr=50c5387d [ 0.000000] CPU: div instructions available: patching division code [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] OF: fdt: Machine model: Cubietech Cubietruck [ 0.000000] Memory policy: Data cache writealloc [ 0.000000] Reserved memory: created CMA memory pool at 0x4a000000, size 96 MiB [ 0.000000] OF: reserved mem: initialized node default-pool, compatible id shared-dma-pool [ 0.000000] Zone ranges: [ 0.000000] Normal [mem 0x0000000040000000-0x000000006fffffff] [ 0.000000] HighMem [mem 0x0000000070000000-0x00000000bfcfffff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000040000000-0x00000000bfcfffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x00000000bfcfffff] [ 0.000000] On node 0, zone HighMem: 768 pages in unavailable ranges [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: Using PSCI v0.1 Function IDs from DT [ 0.000000] percpu: Embedded 20 pages/cpu s50764 r8192 d22964 u81920 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 521792 [ 0.000000] Kernel command line: root=UUID=10b79594-d365-4cbc-8bfa-c372b11ded42 rootwait rootfstype=ext4 console=ttyS0,115200 console=tty1 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 consoleblank=0 loglevel=7 ubootpart=3fa73a0b-01 ubootsource=mmc usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 cgroup_enable=memory swapaccount=1 [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off [ 0.000000] Memory: 1950236K/2094080K available (9216K kernel code, 1460K rwdata, 3232K rodata, 1024K init, 333K bss, 45540K reserved, 98304K cma-reserved, 1307648K highmem) [ 0.000000] random: get_random_u32 called from __kmem_cache_create+0x1b/0x298 with crng_init=0 [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 [ 0.000000] ftrace: allocating 42134 entries in 83 pages [ 0.000000] ftrace: allocated 83 pages with 4 groups [ 0.000000] rcu: Hierarchical RCU implementation. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=2. [ 0.000000] Rude variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2 [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16 [ 0.000000] GIC: Using split EOI/Deactivate mode [ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 0.000007] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 0.000022] Switching to timer-based delay loop, resolution 41ns [ 0.000561] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns [ 0.000912] clocksource: hstimer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370868154 ns [ 0.001284] Console: colour dummy device 80x30 [ 0.001963] printk: console [tty1] enabled [ 0.002042] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000) [ 0.002080] pid_max: default: 32768 minimum: 301 [ 0.002347] LSM: Security Framework initializing [ 0.002435] Yama: becoming mindful. [ 0.002678] AppArmor: AppArmor initialized [ 0.002799] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear) [ 0.002836] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear) [ 0.004153] CPU: Testing write buffer coherency: ok [ 0.004649] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 [ 0.005573] Setting up static identity map for 0x40100000 - 0x40100054 [ 0.005773] rcu: Hierarchical SRCU implementation. [ 0.007196] smp: Bringing up secondary CPUs ... [ 0.018282] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001 [ 0.018473] smp: Brought up 1 node, 2 CPUs [ 0.018522] SMP: Total of 2 processors activated (96.00 BogoMIPS). [ 0.018540] CPU: All CPU(s) started in HYP mode. [ 0.018554] CPU: Virtualization extensions available. [ 0.020302] allocated 2097152 bytes of page_ext [ 0.021096] devtmpfs: initialized [ 0.031486] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 4 [ 0.031838] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.031907] futex hash table entries: 512 (order: 3, 32768 bytes, linear) [ 0.034995] pinctrl core: initialized pinctrl subsystem [ 0.036459] NET: Registered protocol family 16 [ 0.038573] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.039328] audit: initializing netlink subsys (disabled) [ 0.039743] audit: type=2000 audit(0.032:1): state=initialized audit_enabled=0 res=1 [ 0.040375] thermal_sys: Registered thermal governor 'fair_share' [ 0.040386] thermal_sys: Registered thermal governor 'bang_bang' [ 0.040413] thermal_sys: Registered thermal governor 'step_wise' [ 0.040753] cpuidle: using governor ladder [ 0.040813] cpuidle: using governor menu [ 0.041410] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.041439] hw-breakpoint: maximum watchpoint size is 8 bytes. [ 0.073996] cryptd: max_cpu_qlen set to 1000 [ 0.146789] raid6: neonx8 gen() 704 MB/s [ 0.214902] raid6: neonx8 xor() 520 MB/s [ 0.283069] raid6: neonx4 gen() 751 MB/s [ 0.351185] raid6: neonx4 xor() 567 MB/s [ 0.419336] raid6: neonx2 gen() 828 MB/s [ 0.487444] raid6: neonx2 xor() 590 MB/s [ 0.555596] raid6: neonx1 gen() 737 MB/s [ 0.623726] raid6: neonx1 xor() 511 MB/s [ 0.691921] raid6: int32x8 gen() 274 MB/s [ 0.760018] raid6: int32x8 xor() 162 MB/s [ 0.828179] raid6: int32x4 gen() 320 MB/s [ 0.896314] raid6: int32x4 xor() 186 MB/s [ 0.964463] raid6: int32x2 gen() 361 MB/s [ 1.032561] raid6: int32x2 xor() 193 MB/s [ 1.100729] raid6: int32x1 gen() 362 MB/s [ 1.168828] raid6: int32x1 xor() 173 MB/s [ 1.168846] raid6: using algorithm neonx2 gen() 828 MB/s [ 1.168862] raid6: .... xor() 590 MB/s, rmw enabled [ 1.168879] raid6: using neon recovery algorithm [ 1.170846] iommu: Default domain type: Translated [ 1.171366] SCSI subsystem initialized [ 1.172058] usbcore: registered new interface driver usbfs [ 1.172138] usbcore: registered new interface driver hub [ 1.172201] usbcore: registered new device driver usb [ 1.172325] mc: Linux media interface: v0.10 [ 1.172393] videodev: Linux video capture interface: v2.00 [ 1.172540] pps_core: LinuxPPS API ver. 1 registered [ 1.172558] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 1.172595] PTP clock support registered [ 1.173440] Advanced Linux Sound Architecture Driver Initialized. [ 1.174395] NetLabel: Initializing [ 1.174425] NetLabel: domain hash size = 128 [ 1.174440] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO [ 1.174579] NetLabel: unlabeled traffic allowed by default [ 1.175478] clocksource: Switched to clocksource arch_sys_counter [ 1.301269] VFS: Disk quotas dquot_6.6.0 [ 1.301432] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 1.302173] AppArmor: AppArmor Filesystem Enabled [ 1.303042] ------------[ cut here ]------------ [ 1.303095] WARNING: CPU: 1 PID: 1 at arch/arm/mm/ioremap.c:287 __arm_ioremap_pfn_caller+0x13f/0x14c [ 1.303119] Modules linked in: [ 1.303147] CPU: 1 PID: 1 Comm: swapper/0 Not tainted 5.10.60-sunxi #21.08.1 [ 1.303165] Hardware name: Allwinner sun7i (A20) Family [ 1.303210] [<c010ca1d>] (unwind_backtrace) from [<c010952d>] (show_stack+0x11/0x14) [ 1.303247] [<c010952d>] (show_stack) from [<c0978293>] (dump_stack+0x77/0x84) [ 1.303283] [<c0978293>] (dump_stack) from [<c011ae71>] (__warn+0xad/0xc0) [ 1.303312] [<c011ae71>] (__warn) from [<c09721a3>] (warn_slowpath_fmt+0x43/0x7c) [ 1.303343] [<c09721a3>] (warn_slowpath_fmt) from [<c01133bb>] (__arm_ioremap_pfn_caller+0x13f/0x14c) [ 1.303375] [<c01133bb>] (__arm_ioremap_pfn_caller) from [<c01133f7>] (__arm_ioremap_caller+0x2f/0x38) [ 1.303411] [<c01133f7>] (__arm_ioremap_caller) from [<c05bd6cb>] (simplefb_probe+0x19b/0x6b8) [ 1.303449] [<c05bd6cb>] (simplefb_probe) from [<c06554e3>] (platform_drv_probe+0x33/0x68) [ 1.303481] [<c06554e3>] (platform_drv_probe) from [<c065394d>] (really_probe+0x14d/0x364) [ 1.303512] [<c065394d>] (really_probe) from [<c0653d29>] (driver_probe_device+0xa9/0x16c) [ 1.303541] [<c0653d29>] (driver_probe_device) from [<c06523a5>] (bus_for_each_drv+0x4d/0x78) [ 1.303570] [<c06523a5>] (bus_for_each_drv) from [<c0653793>] (__device_attach+0x8f/0xf0) [ 1.303598] [<c0653793>] (__device_attach) from [<c0652d03>] (bus_probe_device+0x5b/0x60) [ 1.303631] [<c0652d03>] (bus_probe_device) from [<c065011b>] (device_add+0x2e7/0x564) [ 1.303665] [<c065011b>] (device_add) from [<c07d8385>] (of_platform_device_create_pdata+0x65/0x88) [ 1.303701] [<c07d8385>] (of_platform_device_create_pdata) from [<c0e1dde7>] (simplefb_init+0x4f/0x60) [ 1.303736] [<c0e1dde7>] (simplefb_init) from [<c0101c99>] (do_one_initcall+0x39/0x1b0) [ 1.303768] [<c0101c99>] (do_one_initcall) from [<c0e00f1b>] (kernel_init_freeable+0x1f3/0x238) [ 1.303802] [<c0e00f1b>] (kernel_init_freeable) from [<c097d3b9>] (kernel_init+0xd/0xe0) [ 1.303832] [<c097d3b9>] (kernel_init) from [<c0100159>] (ret_from_fork+0x11/0x38) [ 1.303854] Exception stack(0xc1529fb0 to 0xc1529ff8) [ 1.303874] 9fa0: 00000000 00000000 00000000 00000000 [ 1.303902] 9fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1.303928] 9fe0: 00000000 00000000 00000000 00000000 00000013 00000000 [ 1.304015] ---[ end trace 9165885744af364e ]--- [ 1.304064] simple-framebuffer: probe of bfd00000.framebuffer failed with error -12 [ 1.313692] NET: Registered protocol family 2 [ 1.313978] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 1.315383] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear) [ 1.315630] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear) [ 1.315779] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 1.315919] TCP: Hash tables configured (established 8192 bind 8192) [ 1.316144] UDP hash table entries: 512 (order: 2, 16384 bytes, linear) [ 1.316228] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear) [ 1.316596] NET: Registered protocol family 1 [ 1.317634] Trying to unpack rootfs image as initramfs... [ 2.075791] Freeing initrd memory: 9656K [ 2.076641] hw perfevents: no interrupt-affinity property for /pmu, guessing. [ 2.077005] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available [ 2.078610] Initialise system trusted keyrings [ 2.078700] Key type blacklist registered [ 2.079048] workingset: timestamp_bits=14 max_order=19 bucket_order=5 [ 2.085219] zbud: loaded [ 2.086982] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 2.088358] fuse: init (API version 7.32) [ 2.091814] integrity: Platform Keyring initialized [ 2.208262] xor: measuring software checksum speed [ 2.216710] arm4regs : 1175 MB/sec [ 2.228801] 8regs : 815 MB/sec [ 2.241580] 32regs : 770 MB/sec [ 2.249828] neon : 1197 MB/sec [ 2.249845] xor: using function: neon (1197 MB/sec) [ 2.249874] Key type asymmetric registered [ 2.249892] Asymmetric key parser 'x509' registered [ 2.250113] bounce: pool size: 64 pages [ 2.250226] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246) [ 2.250550] io scheduler mq-deadline registered [ 2.250584] io scheduler kyber registered [ 2.250931] io scheduler bfq registered [ 2.254736] sun4i-pinctrl 1c20800.pinctrl: supply vcc-pi not found, using dummy regulator [ 2.256973] sun4i-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver [ 2.270035] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled [ 2.273212] sun4i-pinctrl 1c20800.pinctrl: supply vcc-pb not found, using dummy regulator [ 2.273882] printk: console [ttyS0] disabled [ 2.274013] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 58, base_baud = 1500000) is a 16550A [ 3.453154] printk: console [ttyS0] enabled [ 3.459022] 1c28800.serial: ttyS2 at MMIO 0x1c28800 (irq = 59, base_baud = 1500000) is a 16550A [ 3.468084] serial serial0: tty port ttyS2 registered [ 3.480388] sun4i-drm display-engine: bound 1e00000.display-frontend (ops 0xc0a9d618) [ 3.488470] sun4i-drm display-engine: bound 1e20000.display-frontend (ops 0xc0a9d618) [ 3.496802] sun4i-drm display-engine: bound 1e60000.display-backend (ops 0xc0a9cdb8) [ 3.504630] sun4i-drm display-engine: attempt to add DMA range to existing map [ 3.512267] sun4i-drm display-engine: bound 1e40000.display-backend (ops 0xc0a9cdb8) [ 3.520644] sun4i-drm display-engine: No panel or bridge found... RGB output disabled [ 3.528574] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xc0a9b60c) [ 3.536808] sun4i-drm display-engine: No panel or bridge found... RGB output disabled [ 3.544730] sun4i-drm display-engine: bound 1c0d000.lcd-controller (ops 0xc0a9b60c) [ 3.553644] sun4i-drm display-engine: bound 1c16000.hdmi (ops 0xc0a9dfc4) [ 3.561556] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0 [ 3.569441] sun4i-drm display-engine: [drm] Cannot find any crtc or sizes [ 3.581878] brd: module loaded [ 3.715520] loop: module loaded [ 3.719890] ahci-sunxi 1c18000.sata: supply ahci not found, using dummy regulator [ 3.727684] ahci-sunxi 1c18000.sata: supply phy not found, using dummy regulator [ 3.737128] libphy: Fixed MDIO Bus: probed [ 3.742163] sun4i-pinctrl 1c20800.pinctrl: supply vcc-pa not found, using dummy regulator [ 3.750624] sun7i-dwmac 1c50000.ethernet: IRQ eth_wake_irq not found [ 3.757022] sun7i-dwmac 1c50000.ethernet: IRQ eth_lpi not found [ 3.763079] sun7i-dwmac 1c50000.ethernet: PTP uses main clock [ 3.768855] sun7i-dwmac 1c50000.ethernet: no reset control found [ 3.774915] sun7i-dwmac 1c50000.ethernet: no regulator found [ 3.780966] sun7i-dwmac 1c50000.ethernet: Version ID not available [ 3.787208] sun7i-dwmac 1c50000.ethernet: DWMAC1000 [ 3.792201] sun7i-dwmac 1c50000.ethernet: DMA HW capability register supported [ 3.799456] sun7i-dwmac 1c50000.ethernet: Normal descriptors [ 3.805138] sun7i-dwmac 1c50000.ethernet: Ring mode enabled [ 3.811532] libphy: stmmac: probed [ 3.829442] realtek: module verification failed: signature and/or required key missing - tainting kernel [ 3.849868] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 3.856511] ehci-platform: EHCI generic platform driver [ 3.862501] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 3.868791] ohci-platform: OHCI generic platform driver [ 3.875113] usbcore: registered new interface driver usb-storage [ 3.882376] sunxi-rtc 1c20d00.rtc: registered as rtc0 [ 3.887553] sunxi-rtc 1c20d00.rtc: setting system clock to 2022-02-15T18:49:18 UTC (1644950958) [ 3.896488] i2c /dev entries driver [ 3.901636] axp20x-i2c 1-0034: AXP20x variant AXP209 found [ 3.914857] input: axp20x-pek as /devices/platform/soc/1c2ac00.i2c/i2c-1/1-0034/axp20x-pek/input/input0 [ 3.933221] vdd-rtc: supplied by regulator-dummy [ 3.938737] avcc: supplied by regulator-dummy [ 3.944505] ldo3: supplied by regulator-dummy [ 3.949231] ldo4: supplied by regulator-dummy [ 3.954766] ldo5: supplied by regulator-dummy [ 3.959733] vdd-cpu: supplied by regulator-dummy [ 3.965160] vdd-int-dll: supplied by regulator-dummy [ 3.974823] random: fast init done [ 3.978810] axp20x-i2c 1-0034: Backup (RTC) battery charging is enabled [ 3.985626] axp20x-i2c 1-0034: AXP20X driver loaded [ 3.994347] sunxi-wdt 1c20c90.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0) [ 4.003685] sun4i-pinctrl 1c20800.pinctrl: supply vcc-pf not found, using dummy regulator [ 4.003935] sun4i-pinctrl 1c20800.pinctrl: supply vcc-ph not found, using dummy regulator [ 4.021698] ledtrig-cpu: registered to indicate activity on CPUs [ 4.021903] sunxi-mmc 1c0f000.mmc: Got CD GPIO [ 4.028180] sun4i-ss 1c15000.crypto-engine: Die ID 0 [ 4.039629] hid: raw HID events driver (C) Jiri Kosina [ 4.045056] usbcore: registered new interface driver usbhid [ 4.050663] usbhid: USB HID core driver [ 4.055901] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB [ 4.058031] debugfs: Directory '1c22c00.codec' with parent 'sun4i-codec' already present! [ 4.076367] Initializing XFRM netlink socket [ 4.081323] NET: Registered protocol family 10 [ 4.099228] mmc0: host does not support reading read-only switch, assuming write-enable [ 4.109601] mmc0: new high speed SDHC card at address 1234 [ 4.117132] mmcblk0: mmc0:1234 SA04G 3.64 GiB [ 4.126423] mmcblk0: p1 [ 4.154061] Segment Routing with IPv6 [ 4.157988] NET: Registered protocol family 17 [ 4.162509] NET: Registered protocol family 15 [ 4.167084] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this. [ 4.180270] 8021q: 802.1Q VLAN Support v1.8 [ 4.184632] Key type dns_resolver registered [ 4.189436] Registering SWP/SWPB emulation handler [ 4.194637] registered taskstats version 1 [ 4.198801] Loading compiled-in X.509 certificates [ 4.211241] Loaded X.509 cert 'Build time autogenerated kernel key: 8a253d6735cd65910a63c6d97c40747ce9ff7e4b' [ 4.224268] zswap: loaded using pool zstd/z3fold [ 4.229994] Key type ._fscrypt registered [ 4.234081] Key type .fscrypt registered [ 4.238038] Key type fscrypt-provisioning registered [ 4.249094] Btrfs loaded, crc32c=crc32c-generic [ 4.267731] Key type encrypted registered [ 4.271843] AppArmor: AppArmor sha1 policy hashing enabled [ 4.295643] ahci-sunxi 1c18000.sata: supply ahci not found, using dummy regulator [ 4.303417] ahci-sunxi 1c18000.sata: supply phy not found, using dummy regulator [ 4.363519] ahci-sunxi 1c18000.sata: controller can't do PMP, turning off CAP_PMP [ 4.371059] ahci-sunxi 1c18000.sata: forcing PORTS_IMPL to 0x1 [ 4.376977] ahci-sunxi 1c18000.sata: AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl platform mode [ 4.385973] ahci-sunxi 1c18000.sata: flags: ncq sntf pm led clo only pio slum part ccc [ 4.395213] scsi host0: ahci-sunxi [ 4.399151] ata1: SATA max UDMA/133 mmio [mem 0x01c18000-0x01c18fff] port 0x100 irq 45 [ 4.417295] of_cfs_init [ 4.419979] of_cfs_init: OK [ 4.423004] ALSA device list: [ 4.426051] #0: sun4i-codec [ 4.721895] ata1: SATA link down (SStatus 0 SControl 300) [ 4.731692] Freeing unused kernel memory: 1024K [ 4.736546] Run /init as init process [ 5.383291] sunxi-mmc 1c12000.mmc: allocated mmc-pwrseq [ 5.411620] sunxi-mmc 1c12000.mmc: initialized, max. request size: 16384 KB [ 5.442177] mmc1: queuing unknown CIS tuple 0x80 (2 bytes) [ 5.453763] mmc1: queuing unknown CIS tuple 0x80 (3 bytes) [ 5.466521] mmc1: queuing unknown CIS tuple 0x80 (3 bytes) [ 5.489277] mmc1: queuing unknown CIS tuple 0x80 (7 bytes) [ 5.523862] mmc1: new high speed SDIO card at address 0001 [ 5.641253] sun5i-a13-gpadc-iio: Failed to locate of_node [id: 0] [ 5.731373] axp20x-gpio axp20x-gpio: DMA mask not set [ 5.766046] axp20x-gpio axp20x-gpio: AXP209 pinctrl and GPIO driver loaded [ 5.792891] axp20x-usb-power-supply axp20x-usb-power-supply: DMA mask not set [ 13.799730] sun4i-drm display-engine: [drm] Cannot find any crtc or sizes [ 35.815530] vcc3v0: disabling [ 35.818552] vcc5v0: disabling [ 35.821590] usb0-vbus: disabling [ 35.824844] usb1-vbus: disabling [ 35.828095] usb2-vbus: disabling Edited February 26, 2022 by TRS-80 put long output inside spoiler (and code block) 0 Quote Link to comment Share on other sites More sharing options...
sbilevskiy Posted February 15, 2022 Author Share Posted February 15, 2022 Armbianmonitor output for normal loading http://ix.io/3PHG 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted February 15, 2022 Share Posted February 15, 2022 https://armbian.atlassian.net/browse/AR-191 0 Quote Link to comment Share on other sites More sharing options...
sbilevskiy Posted February 16, 2022 Author Share Posted February 16, 2022 In my case the power is good. If booting from SD then SSD works fine. [ 4.162423] ahci-sunxi 1c18000.sata: supply ahci not found, using dummy regulator [ 4.170208] ahci-sunxi 1c18000.sata: supply phy not found, using dummy regulator [ 4.235467] ahci-sunxi 1c18000.sata: controller can't do PMP, turning off CAP_PMP [ 4.243013] ahci-sunxi 1c18000.sata: forcing PORTS_IMPL to 0x1 [ 4.248930] ahci-sunxi 1c18000.sata: AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl platform mode [ 4.257929] ahci-sunxi 1c18000.sata: flags: ncq sntf pm led clo only pio slum part ccc [ 4.267230] scsi host0: ahci-sunxi [ 4.271169] ata1: SATA max UDMA/133 mmio [mem 0x01c18000-0x01c18fff] port 0x100 irq 45 [ 4.287675] of_cfs_init [ 4.290317] of_cfs_init: OK [ 4.293399] ALSA device list: [ 4.296428] #0: sun4i-codec [ 4.593884] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300) [ 4.600379] ata1.00: ATA-8: APPLE SSD TS128B, AGAA0206, max UDMA/100 [ 4.606779] ata1.00: 236978176 sectors, multi 16: LBA48 [ 4.612330] ata1.00: configured for UDMA/100 [ 4.617284] scsi 0:0:0:0: Direct-Access ATA APPLE SSD TS128B 0206 PQ: 0 ANSI: 5 [ 4.626411] sd 0:0:0:0: Attached scsi generic sg0 type 0 [ 4.626715] sd 0:0:0:0: [sda] 236978176 512-byte logical blocks: (121 GB/113 GiB) [ 4.639453] sd 0:0:0:0: [sda] Write Protect is off [ 4.644408] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 4.654860] sda: sda1 [ 4.658710] sd 0:0:0:0: [sda] Attached SCSI disk [ 4.668643] Freeing unused kernel memory: 1024K [ 4.675773] Run /init as init process 0 Quote Link to comment Share on other sites More sharing options...
sbilevskiy Posted February 17, 2022 Author Share Posted February 17, 2022 The problem persists on the Armbian 21.08.1 Hirsute with kernel 5.16.9 0 Quote Link to comment Share on other sites More sharing options...
