Image won't boot for Orangepi Zero 2
RayChang
Just tried the latest image for Orangepi Zero2, the Armbian Focal Image(Armbian_22.02.2_Orangepizero2_focal_edge_5.16.11.img Built March 7 2022)
The board has startup issue, the serial output seems to load some files in wrong format:
U-Boot SPL 2021.10-armbian (Feb 26 2022 - 17:45:38 +0000)
DRAM: 1024 MiB
Trying to boot from MMC1
NOTICE:  BL31: v2.6(debug):510155aa-dirty
NOTICE:  BL31: Built : 17:45:34, Feb 26 2022
NOTICE:  BL31: Detected Allwinner H616 SoC (1823)
NOTICE:  BL31: Found U-Boot DTB at 0x4a082570, model: OrangePi Zero2
INFO:    ARM GICv2 driver initialized
INFO:    Configuring SPC Controller
INFO:    PMIC: Probing AXP305 on RSB
INFO:    PMIC: aldo1 voltage: 3.300V
INFO:    PMIC: aldo2 voltage: 3.300V
INFO:    PMIC: aldo3 voltage: 3.300V
INFO:    PMIC: bldo1 voltage: 1.800V
INFO:    PMIC: dcdcd voltage: 1.500V
INFO:    PMIC: dcdce voltage: 3.300V
INFO:    Changed devicetree to reserve BL31 memory.
INFO:    BL31: Platform setup done
INFO:    BL31: Initializing runtime services
INFO:    BL31: cortex_a53: CPU workaround for 855873 was applied
INFO:    BL31: cortex_a53: CPU workaround for 1530924 was applied
INFO:    PSCI: Suspend is unavailable
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x4a000000
INFO:    SPSR = 0x3c9
U-Boot 2021.10-armbian (Feb 26 2022 - 17:45:38 +0000) Allwinner Technology
CPU:   Allwinner H616 (SUN50I)
Model: OrangePi Zero2
I2C:   ready
DRAM:  1 GiB
MMC:   mmc@4020000: 0
Loading Environment from FAT... Unable to use mmc 0:1... In:    serial@5000000
Out:   serial@5000000
Err:   serial@5000000
Net:   phy interface7
eth0: ethernet@5020000
Autoboot in 1 seconds, press <Space> to stop
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
2612 bytes read in 2 ms (1.2 MiB/s)
U-boot loaded from SD
Boot script loaded from mmc
131 bytes read in 1 ms (127.9 KiB/s)
No FDT memory address configured. Please configure
the FDT address via "fdt addr <address>" command.
Aborting!
Aborting!
Aborting!
Aborting!
Aborting!
Aborting!
Aborting!
12522800 bytes read in 518 ms (23.1 MiB/s)
Failed to load '/boot/uImage'
Wrong Image Format for bootm command
ERROR: can't get kernel image!
SCRIPT FAILED: continuing...
libfdt fdt_check_header(): FDT_ERR_BADMAGIC
Scanning disk mmc@4020000.blk...
Found 2 disks
No EFI system partition
BootOrder not defined
EFI boot manager: Cannot load any image
ethernet@5020000 Waiting for PHY auto negotiation to complete......... TIMEOUT !
missing environment variable: pxeuuid
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/01-02-00-86-a3-61-86
Retrieving file: pxelinux.cfg/00000000
I tried another image: Armbian_22.02.2_Orangepizero2_focal_legacy_4.9.255.img.xz
This one works okay
I bought OrangePi Zero 2w month ago (newest board similar size to Raspberry Pi Zero 2w) and have 4GB ram built in.  I downloaded OrangePi OS (Arch) image and installed it. Booted up just fine but the issue is that it seem Software Repository and Pacman software repository is broken.  Cannot update to current and unable to download some software such as Widevine, nala ect.   I wanted to be able to use up to date programs ect so I can turn it to mini desktop or as a Kiosk ect.  it will not connect to Arch server.  I also installed Debian as well and it would not connect to USA Debian server (It only 'locked' to Shanghai server even I rooted and tried to change it but it revert back to that server).  Is it because it's brand new and still working on it or restricted for now?
