grek Posted April 1, 2022 Share Posted April 1, 2022 Hey guys. I have helios64 with 5x WD14tb red pro.... and ZFS fs. but currently im out of free space I want to extend somehow my storage pool. I'm wonder if it's possible to buy additional storage enclosure like from QNAP ( TL-D800C) - JBOD 1 x USB 3.2 Gen 2 type C and put additional 8x HDD I wanted to create additional ZFS pool raidz1 Do You think it will work? 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted April 1, 2022 Share Posted April 1, 2022 zfs expansion seems tricky:https://www.google.com/search?q=zfs+expand+pool+raidz1 0 Quote Link to comment Share on other sites More sharing options...
grek Posted April 1, 2022 Author Share Posted April 1, 2022 missunderstanding I want to create NEW ZFS pool from disks installed at external enclosure. I'm not sure if disks will be correctly exposed at OS level ....and if will work at all .... 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted April 1, 2022 Share Posted April 1, 2022 ahaa. Well possible for sure in theory. However various sources do not like the idea having disks connected via USB in a raid configuration... Did not experiment with that by myself yet so I cannot elaborate. 0 Quote Link to comment Share on other sites More sharing options...
TRS-80 Posted April 1, 2022 Share Posted April 1, 2022 I think you did not give the most pertinent information. It depends what is your current topology. As redundancy is done at the vdev level in ZFS (if I am remembering my terminology correctly). Depending on that, it can be possible to upgrade in place. Topology will dictate how much effort that takes. 0 Quote Link to comment Share on other sites More sharing options...
Krita Posted April 15, 2022 Share Posted April 15, 2022 the helios64 runs a jmicron JMB585 sata controller, in theory you should be able to run an external sata expander enclosure running a jmicron JMB575 chipset. I have all the hardware sitting here but haven't had the chance to test it yet. possibly over the weekend ill get a chance. last time i tried running the drives off the helios64 power supply...things didn't go well. 0 Quote Link to comment Share on other sites More sharing options...
Astra7525 Posted April 24, 2022 Share Posted April 24, 2022 I don't wanna be rude, but with you having already maxed out 70TB of capacity, this might be the time to consider moving to a larger storage device that also has active support behind it. The Helios64 always was a low-power hobbyist device which still has problems that probably will not get fixed. A larger device could also net you additional data protection features (hardware raid-controller, ECC-RAM, more CPU for checksums etc.). 0 Quote Link to comment Share on other sites More sharing options...
Krita Posted May 2, 2022 Share Posted May 2, 2022 On 4/15/2022 at 2:10 PM, Krita said: the helios64 runs a jmicron JMB585 sata controller, in theory you should be able to run an external sata expander enclosure running a jmicron JMB575 chipset. I have all the hardware sitting here but haven't had the chance to test it yet. possibly over the weekend ill get a chance. last time i tried running the drives off the helios64 power supply...things didn't go well. So had a crack at this again finally worked flawlessly, apparently a cheap 350mA USB power supply doesn't work. just plug it into the helios if required..... 0 Quote Link to comment Share on other sites More sharing options...
