Unable to boot NanoPi NEO3 after system upgrade
struthio
Hi,
I have 4 FriendlyElec NanoPi Neo 3 boards.
Till now they were working fine, but after today 'apt upgrade' none of them boot anymore.
I got one connected in debug mode and got this log:
=> DDR version 1.16 20190528
In
DDR4
333MHz
Bus Width=32 Col=10 Bank=4 Bank Group=2 Row=16 CS=1 Die Bus-Width=16 Size=2048MB
ddrconfig:14
OUT
Boot1 Release Time: May 13 2019 17:34:36, version: 2.50
ChipType = 0x11, 248
mmc2:cmd1,20
emmc reinit
mmc2:cmd1,20
emmc reinit
mmc2:cmd1,20
SdmmcInit=2 1
mmc0:cmd5,20
SdmmcInit=0 0
BootCapSize=0
UserCapSize=30436MB
FwPartOffset=2000 , 0
StorageInit ok = 33580
Raw SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit ret = 0, SecureMode = 0
atags_set_bootdev: ret:(0)
GPT 0x337a9f0 signature is wrong
recovery gpt...
recovery gpt fail!
LoadTrust Addr:0x4000
No find bl30.bin
No find bl32.bin
Load uboot, ReadLba = 2000
hdr 000000000337a3b0 + 0x0:0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
Load OK, addr=0x200000, size=0xab950
RunBL31 0x40000
INFO:    Preloader serial: 2
NOTICE:  BL31: v1.3(debug):403e0b816
NOTICE:  BL31: Built : 14:13:08, Aug 11 2020
NOTICE:  BL31:Rockchip release version: v1.3
INFO:    ARM GICv2 driver initialized
INFO:    Using opteed sec cpu_context!
INFO:    boot cpu mask: 1
INFO:    plat_rockchip_pmu_init: pd status 0xe
INFO:    BL31: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK
ERROR:   Error initializing runtime service opteed_fast
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x200000
INFO:    SPSR = 0x3c9
U-Boot 2020.10-armbian (May 06 2021 - 17:55:54 +0000)
Model: FriendlyElec NanoPi R2S
DRAM:  2 GiB
PMIC:  RK8050 (on=0x40, off=0x00)
MMC:   mmc@ff500000: 1
Loading Environment from MMC... MMC Device 0 not found
*** Warning - No MMC card found, using default environment
In:    serial@ff130000
Out:   serial@ff130000
Err:   serial@ff130000
Net:   eth0: ethernet@ff540000
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
3185 bytes read in 8 ms (388.7 KiB/s)
## Executing script at 00500000
Boot script loaded from mmc 1
261 bytes read in 4 ms (63.5 KiB/s)
14236833 bytes read in 623 ms (21.8 MiB/s)
30083584 bytes read in 1307 ms (22 MiB/s)
Failed to load '/boot/dtb/rockchip/rk3328-nanopi-neo3-rev02.dtb'
libfdt fdt_check_header(): FDT_ERR_BADMAGIC
No FDT memory address configured. Please configure
the FDT address via "fdt addr <address>" command.
Aborting!
1314 bytes read in 9 ms (142.6 KiB/s)
Applying kernel provided DT overlay rockchip-spi-jedec-nor.dtbo
Aborting!
1266 bytes read in 9 ms (136.7 KiB/s)
Applying kernel provided DT overlay rockchip-spi-spidev.dtbo
Aborting!
Error applying DT overlays, restoring original DT
Moving Image from 0x2080000 to 0x2200000, end=3f50000
## Loading init Ramdisk from Legacy Image at 06000000 ...
   Image Name:   uInitrd
   Image Type:   AArch64 Linux RAMDisk Image (gzip compressed)
   Data Size:    14236769 Bytes = 13.6 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
ERROR: Did not find a cmdline Flattened Device Tree
Could not find a valid device tree
SCRIPT FAILED: continuing...
no mmc device at slot 0
starting USB...
No working controllers found
USB is stopped. Please issue 'usb start' first.
starting USB...
ethernet@ff540000 Waiting for PHY auto negotiation to complete......... TIMEOUT !
Could not initialize PHY ethernet@ff540000
missing environment variable: pxeuuid
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/01-b6-20-d4-48-8b-b5
Retrieving file: pxelinux.cfg/00000000
SD card is good and I can read it in PC in normal SD-to-USB reader.
Is there a way to boot from this state ?
Is NEO3 still supported ?
Board: Not on the list
