DavidJS Posted April 4, 2022 Share Posted April 4, 2022 Yes, this is another rookie question: if I only modify the dts file of the kernel or a certain part of the driver code, I run ./compile.sh, need to wait a long time for the compilation process of uboot and various libraries. How can I only compile the kernel part? I see there is a compile option: KERNEL_ONLY, is this possible? How do I need to update the kenel part after compiling? 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted April 4, 2022 Share Posted April 4, 2022 If you use the menu to choose to build packages only it is the same as using KERNEL_ONLY. This will build kernel image, headers, dtb and uboot packages but not a whole image. Use these packages on your board and install them via dpkg. 0 Quote Link to comment Share on other sites More sharing options...
DavidJS Posted April 5, 2022 Author Share Posted April 5, 2022 @Werner, thank you . So I can config KERNEL_ONLY to be yes, and use dpkg to install the .debs. 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted April 5, 2022 Share Posted April 5, 2022 Yes. Keep in mind that user built images/packages are unsupported. So if you run into trouble like unexpected behavior after installation or inability to boot you are on your own. Create proper backups before tinkering. 0 Quote Link to comment Share on other sites More sharing options...
ning Posted April 5, 2022 Share Posted April 5, 2022 if your board is running armbian, and you want to rebuild kernel, I suggest to build kernel natively. 0 Quote Link to comment Share on other sites More sharing options...
ning Posted April 5, 2022 Share Posted April 5, 2022 here is handbook https://kernel-team.pages.debian.net/kernel-handbook/ you need to patch debian kernel before build. 0 Quote Link to comment Share on other sites More sharing options...
