suchende Posted September 14, 2016 Share Posted September 14, 2016 Hey, I compiled and installed the latest kernel (4.7.3 and uboot 2016-09) but something went wrong. The dtb file was missing. while a manually correct the missing dtb from another run a flashed uboot in the wrong way. Instead of using the drive /dev/sdc I used the partition /dev/sdc1. I read this: https://linux-sunxi.org/Bootable_SD_card#SD_Card_Layoutand with these two commands I should have erased the first 1Mb dd if=/dev/zero of=/dev/sdc1 bs=1k count=1023 seek=1 dd if=u-boot-sunxi-with-spl.bin of=/dev/sdc1 bs=1024 seek=8 (Luckily there is no backup at all ) gpart gives me this: gpart -vg /mnt/veracrypt1/Armbian_5.14_Cubietruck_Debian_jessie_4.6.2.raw dev(/mnt/veracrypt1/Armbian_5.14_Cubietruck_Debian_jessie_4.6.2.raw) mss(512) Primary partition(1) type: 131(0x83)(Linux ext2 filesystem) size: 1525mb #s(3123200) s(2048-3125247) chs: (16/0/1)-(1023/3/32)d (0/0/0)-(0/0/0)r hex: 00 00 01 10 83 03 E0 FF 00 08 00 00 00 A8 2F 00 ---------------------------------------------------------------------------------------- gpart -vg /mnt/veracrypt1/broken_cubietruck.img dev(/mnt/veracrypt1/broken_cubietruck.img) mss(512) Primary partition(1) type: 131(0x83)(Linux ext2 filesystem) size: 14991mb #s(30701568) s(2048-30703615) chs: (0/56/33)-(913/88/8)d (0/0/0)-(0/0/0)r hex: 00 38 21 00 83 58 C8 91 00 08 00 00 00 78 D4 01 I try to use the values from the raw image to recover at least some data, but fsch.ext4 fails. Do you see an opportunity to restore the partition table? Or to recover the filesystem? Edit: Topic can be deleted. I wasn't capable of restoring the filesystem. Link to comment Share on other sites More sharing options...
