cxrider Posted April 17, 2022 Share Posted April 17, 2022 Before I file a bug for this, I want to make sure I'm not doing something wrong. I am trying to enable PPS on GPIO pin PD14 of an Orange Pi PC2. I've enabled the pps-gpio and uart overlays in my /boot/armbianEnv.txt file and rebooted. root@ntp0:~# cat /boot/armbianEnv.txt verbosity=1 bootlogo=false console=both disp_mode=1920x1080p60 overlay_prefix=sun50i-h5 rootdev=UUID=20dbbd2a-5783-4f98-b467-62fa62990ac8 rootfstype=ext4 overlays=pps-gpio uart1 param_pps_pin=PD14 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u root@ntp0:~# On reboot I see the following problem in dmesg: [ 5.542593] pps-gpio pps@0: failed to map GPIO to IRQ: -22 [ 5.542626] pps-gpio: probe of pps@0 failed with error -22 If I 'rmmod/modprobe' the pps-gpio/pps-ldisc modules I see pps0 created: [ 54.983158] pps pps0: new PPS source serial1 [ 54.983284] pps pps0: source "/dev/ttyS1" added Yet I am not getting PPS data on pps0 even with the gps locked as measured by cgps/gpsmon. root@ntp0:~# ppstest /dev/pps0 trying PPS source "/dev/pps0" found PPS source "/dev/pps0" ok, found 1 source(s), now start fetching data... time_pps_fetch() error -1 (Connection timed out) time_pps_fetch() error -1 (Connection timed out) time_pps_fetch() error -1 (Connection timed out) ^C root@ntp0:~# lqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqklqqqqqqqqqqqqqqqqqqSeen 12/Used 9k x Time: 2022-04-17T18:35:49.000Z (0) xxGNSS PRN Elev Azim SNR Usex x Latitude: xx.xxxxxxxx N xxGP 1 1 26.0 49.0 15.0 Y x x Longitude: yy.yyyyyyyy W xxGP 6 6 23.0 169.0 18.0 Y x x Alt (HAE, MSL): 6353.675, 6407.480 ft xxGP 13 13 28.0 235.0 18.0 Y x x Speed: 0.11 mph xxGP 14 14 54.0 72.0 21.0 Y x x Track (true, var): 332.6, 11.0 deg xxGP 15 15 18.0 270.0 23.0 Y x x Climb: 0.00 ft/min xxGP 17 17 84.0 23.0 22.0 Y x x Status: 3D FIX (9 secs) xxGP 19 19 70.0 231.0 21.0 Y x x Long Err (XDOP, EPX): 0.61, +/- 30.1 ft xxGP 24 24 21.0 314.0 28.0 Y x x Lat Err (YDOP, EPY): 0.64, +/- 31.6 ft xxGP 30 30 26.0 151.0 16.0 Y x x Alt Err (VDOP, EPV): 0.81, +/- 61.1 ft xxGP 7 7 2.0 146.0 0.0 N x x 2D Err (HDOP, CEP): 0.87, +/- 54.2 ft xxGP 21 21 3.0 32.0 0.0 N x x 3D Err (PDOP, SEP): 1.19, +/- 74.2 ft xxSB134 47 0.0 0.0 0.0 N x x Time Err (TDOP): 0.88 xx x x Geo Err (GDOP): 1.87 xx x x ECEF X, VX: n/a n/a xx x x ECEF Y, VY: n/a n/a xx x x ECEF Z, VZ: n/a n/a xx x x Speed Err (EPS): +/- 43.0 mph xx x x Track Err (EPD): n/a xx x x Time offset: 0.551504007 s xx x x Grid Square: AABBCCDD xx x mqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqjmqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqj (location/grid square redacted) Looking at what the kernel thinks it has for gpio pins enabled I see this: root@ntp0:~# cat /sys/kernel/debug/gpio gpiochip1: GPIOs 0-223, parent: platform/1c20800.pinctrl, 1c20800.pinctrl: gpio-20 ( |orangepi:red:status ) out lo gpio-102 ( |gmac-3v3 ) out hi gpio-166 ( |cd ) in lo IRQ ACTIVE LOW gpio-204 ( |usb0_id_det ) in hi IRQ gpiochip0: GPIOs 352-383, parent: platform/1f02c00.pinctrl, 1f02c00.pinctrl: gpio-354 ( |usb0-vbus ) out lo gpio-355 ( |sw4 ) in hi IRQ ACTIVE LOW gpio-362 ( |orangepi:green:pwr ) out hi root@ntp0:~# Is this indeed a case of the pin not being assigned an interrupt or is the pps-gpio IRQ mapping message unrelated to the problem? Thanks 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted April 17, 2022 Share Posted April 17, 2022 Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed. 0 Quote Link to comment Share on other sites More sharing options...
cxrider Posted April 19, 2022 Author Share Posted April 19, 2022 On 4/17/2022 at 1:03 PM, Werner said: Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed. Thanks for the reply While I wasn't necessarily asking for assistance I won't say no to help http://ix.io/3Vo9 It seems as if I am only able to post one message a day here so please understand the delayed replies. I walked the log file and noticed that it has three different reboots captured; two are with the overlay included and the last is without it. I wondered whether or not there may have been a conflict with r-gpio-keys so I removed pps-gpio; no change. I also downloaded kernel source but I haven't quite figured out where I should start debugging the code. From what I can tell the message in dmesg is coming from line 177 of drivers/pps/client/pps-gpio.c. That seems to be the result of a return from gpiod_to_irq which seems to be defined in the include file linux/gpio/consumer.h. It seems the only thing this function does is warn and return -EINVAL which I see EINVAL is defined as 22 in uapi/asm-generic/errno-base.h. We drop into pps-gpio.c from a call to pps_gpio_probe. I'm guessing that this is called when kernel loads the pps-gpio module from a modprobe. Other than looking at the overlays in arch/arm64/boot/dts/allwinner/* I haven't made much headway in figuring out the problem. 0 Quote Link to comment Share on other sites More sharing options...
