Maybe Harddrive Error at boot time ?
Schlotze83!
Hi Mates,
when i check my device with the dmesg command it looks like that my harddrive (connected WD Red Hard Drive via SATA) has an issue:
   3.404949] mmc1: new high speed SDIO card at address 0001
[    7.204630] ata1.00: exception Emask 0x0 SAct 0x2 SErr 0x0 action 0x0
[    7.204662] ata1.00: irq_stat 0x40000000
[    7.204676] ata1.00: failed command: READ FPDMA QUEUED
[    7.204686] ata1.00: cmd 60/08:08:00:66:54/00:00:57:00:00/40 tag 1 ncq dma 4096 in
                        res 41/40:00:00:66:54/00:00:57:00:00/40 Emask 0x409 (media error) <F>
[    7.204718] ata1.00: status: { DRDY ERR }
[    7.204728] ata1.00: error: { UNC }
[    7.206016] ata1.00: configured for UDMA/133
[    7.206081] sd 0:0:0:0: [sda] tag#1 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=DRIVER_OK cmd_age=4s
[    7.206097] sd 0:0:0:0: [sda] tag#1 Sense Key : 0x3 [current]
[    7.206109] sd 0:0:0:0: [sda] tag#1 ASC=0x11 ASCQ=0x4
[    7.206124] sd 0:0:0:0: [sda] tag#1 CDB: opcode=0x28 28 00 57 54 66 00 00 00 08 00
[    7.206134] blk_update_request: I/O error, dev sda, sector 1465148928 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
this is the smartctl test of the Device:
=== START OF INFORMATION SECTION ===
Model Family:     Western Digital Red
Device Model:     WDC WD7500BFCX-68N6GN0
Serial Number:    WD-WX51E85ASKYJ
LU WWN Device Id: 5 0014ee 6b103c0ae
Firmware Version: 82.00A82
User Capacity:    750.156.374.016 bytes [750 GB]
Sector Sizes:     512 bytes logical, 4096 bytes physical
Rotation Rate:    5400 rpm
Device is:        In smartctl database [for details use: -P show]
ATA Version is:   ACS-2 (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is:    Mon Apr 18 10:37:22 2022 CEST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
                                        was never started.
                                        Auto Offline Data Collection: Disabled.
Self-test execution status:      (   0) The previous self-test routine completed
                                        without error or no self-test has ever
                                        been run.
Total time to complete Offline
data collection:                (13680) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        Auto Offline data collection on/off support.
                                        Suspend Offline collection upon new
                                        command.
                                        Offline surface scan supported.
                                        Self-test supported.
                                        Conveyance Self-test supported.
                                        Selective Self-test supported.
SMART capabilities:            (0x0003) Saves SMART data before entering
                                        power-saving mode.
                                        Supports SMART auto save timer.
Error logging capability:        (0x01) Error logging supported.
                                        General Purpose Logging supported.
Short self-test routine
recommended polling time:        (   2) minutes.
Extended self-test routine
recommended polling time:        ( 155) minutes.
Conveyance self-test routine
recommended polling time:        (   5) minutes.
SCT capabilities:              (0x703d) SCT Status supported.
                                        SCT Error Recovery Control supported.
                                        SCT Feature Control supported.
                                        SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       33
  3 Spin_Up_Time            0x0027   188   178   021    Pre-fail  Always       -       1583
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       86
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   200   200   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   072   072   000    Old_age   Always       -       20880
 10 Spin_Retry_Count        0x0032   100   253   000    Old_age   Always       -       0
 11 Calibration_Retry_Count 0x0032   100   253   000    Old_age   Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       85
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       62
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       130
194 Temperature_Celsius     0x0022   117   105   000    Old_age   Always       -       30
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       3
198 Offline_Uncorrectable   0x0030   100   253   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0008   200   200   000    Old_age   Offline      -       0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Extended offline    Completed without error       00%     20871         -
# 2  Short offline       Completed without error       00%     20868         -
# 3  Short offline       Completed without error       00%     20868         -
# 4  Conveyance offline  Completed without error       00%     20198         -
# 5  Conveyance offline  Completed without error       00%     20196         -
# 6  Conveyance offline  Completed without error       00%     20196         -
# 7  Conveyance offline  Completed without error       00%     20195         -
# 8  Short offline       Completed without error       00%     20060         -
# 9  Short offline       Completed without error       00%     19317         -
#10  Short offline       Completed without error       00%     18575         -
#11  Short offline       Completed without error       00%     17856         -
#12  Short offline       Completed without error       00%     17112         -
#13  Short offline       Completed without error       00%     16392         -
SMART Selective self-test log data structure revision number 1
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
Someone can explain what to do? Will the drive die soon? - Thanks and happy Eastern!
From what I can tell from the smartctl output there should be no reason why any data would be lost. Every hard drive has an area reserved where if a write is attempted on a part of the disk and fails, the drive reallocated the wrote to a reserved area for this purpose, so at the moment your hard drive is functioning.  the problems start when an extended S.M.A.R.T. self-test fails.
Make sure you have a backup in case it does fail.
