Felix Posted April 30, 2022 Share Posted April 30, 2022 Hi, I am unable to build any images for orangepi SOCs specifically orangepilite, orangepilite2 and one plus. Always returned error halfeway. Following is a sample of log when I compile image for orange pi lite. Please me some guidance on how to resolve this. My steps: run sudo compile.sh -- "Do no tchnage the kernel..." --> "orangepilite"--> either current or legacy --> either "buster" -->"Image with console inter..." -->"Standard image with ..."compilation.log Quote CC [M] drivers/hwmon/tmp102.o CC [M] drivers/hwmon/tmp103.o CC [M] drivers/hwmon/tmp401.o CC [M] drivers/hwmon/tmp421.o CC [M] drivers/hwmon/tmp513.o CC [M] drivers/hwmon/vt1211.o CC [M] drivers/hwmon/w83627ehf.o CC [M] drivers/hwmon/w83l785ts.o CC [M] drivers/hwmon/w83l786ng.o AR drivers/hwmon/built-in.a scripts/sign-file.c: In function ‘display_openssl_errors’: scripts/sign-file.c:89:9: warning: ‘ERR_get_error_line’ is deprecated: Since OpenSSL 3.0 [-Wdeprecated-declarations] 89 | while ((e = ERR_get_error_line(&file, &line))) { 411 | unsigned long ERR_get_error_line(const char **file, int *line); scripts/sign-file.c: In function ‘drain_openssl_errors’: scripts/sign-file.c:102:9: warning: ‘ERR_get_error_line’ is deprecated: Since OpenSSL 3.0 [-Wdeprecated-declarations] 102 | while (ERR_get_error_line(&file, &line)) {} 411 | unsigned long ERR_get_error_line(const char **file, int *line); scripts/extract-cert.c: In function ‘display_openssl_errors’: scripts/extract-cert.c:46:9: warning: ‘ERR_get_error_line’ is deprecated: Since OpenSSL 3.0 [-Wdeprecated-declarations] 46 | while ((e = ERR_get_error_line(&file, &line))) { 411 | unsigned long ERR_get_error_line(const char **file, int *line); scripts/extract-cert.c: In function ‘drain_openssl_errors’: scripts/extract-cert.c:59:9: warning: ‘ERR_get_error_line’ is deprecated: Since OpenSSL 3.0 [-Wdeprecated-declarations] 59 | while (ERR_get_error_line(&file, &line)) {} 411 | unsigned long ERR_get_error_line(const char **file, int *line); drivers/power/supply/axp20x_battery.c:292:10: error: implicit declaration of function ‘axp20x_get_ocv_voltage’; did you mean ‘axp20x_battery_get_max_voltage’? [-Werror=implicit-function-declaration] drivers/power/supply/axp20x_battery.c:307:7: error: ‘info’ undeclared (first use in this function); did you mean ‘int’? cc1: some warnings being treated as errors make[3]: *** [scripts/Makefile.build:280: drivers/power/supply/axp20x_battery.o] Error 1 make[2]: *** [scripts/Makefile.build:497: drivers/power/supply] Error 2 make[1]: *** [scripts/Makefile.build:497: drivers/power] Error 2 make: *** [Makefile:1824: drivers] Error 2 [ error ] ERROR in function compile_kernel [ main.sh:589 -> main.sh:490 -> compilation.sh:507 -> general.sh:0 ] [ error ] Kernel was not built [ @host ] [ o.k. ] Process terminated 0 Quote Link to comment Share on other sites More sharing options...
lanefu Posted May 1, 2022 Share Posted May 1, 2022 for current use `AUFS=no` and it should build.. ran into that yesterday 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted May 1, 2022 Share Posted May 1, 2022 Forums are for issues running official Armbian images. Use Github to report building issues. 0 Quote Link to comment Share on other sites More sharing options...
Felix Posted May 1, 2022 Author Share Posted May 1, 2022 12 hours ago, lanefu said: for current use `AUFS=no` and it should build.. ran into that yesterday Thank you. This option solved the problem if I choose "current" branch. However, if I chose "legacy" branch (because I need to build 21.08/5.10.60-sunxi), I hit the same problem again. 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted May 1, 2022 Share Posted May 1, 2022 2 hours ago, Felix said: I hit the same problem again. Bug was introduced with last upstream kernel changes and was reported by several people, including you. With free support, this is it. With paid support - its holiday. 0 Quote Link to comment Share on other sites More sharing options...
Felix Posted May 1, 2022 Author Share Posted May 1, 2022 1 hour ago, Igor said: Bug was introduced with last upstream kernel changes and was reported by several people, including you. With free support, this is it. With paid support - its holiday. yeah, just saw the other threads that had similar problems. no problem, I could stick to the old version. Thanks for all the great efforts and dedications .. have a good weekend 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted May 1, 2022 Share Posted May 1, 2022 1 hour ago, Felix said: Thanks for all the great efforts and dedications Read this https://docs.armbian.com/User-Guide_FAQ/ and act responsibly. 0 Quote Link to comment Share on other sites More sharing options...
