DavidJS Posted May 17, 2022 Share Posted May 17, 2022 I have built my armbian system on a Renegade board, and I need to back up the entire system so that I can copy it to other sdcards. I tried to use Win32DiskImager.exe to read out the system, but the size of the image read out is much larger than the space occupied by the system, which is basically equal to the size of the card. Any good suggestions? 0 Quote Link to comment Share on other sites More sharing options...
Solution Werner Posted May 17, 2022 Solution Share Posted May 17, 2022 With MS Windows you can also try https://gitlab.com/bztsrc/usbimager With Linux I'd simply go for dd if to create an image from an sdcard. 0 Quote Link to comment Share on other sites More sharing options...
ReverseAffect Posted June 18, 2022 Share Posted June 18, 2022 When you install Armbian..you did see the image was compressed .as it's installing it's resizing for the sd.....some are larger then the sd but are compressed..... keep us updated on your journey....) 0 Quote Link to comment Share on other sites More sharing options...
schwar3kat Posted June 18, 2022 Share Posted June 18, 2022 On Windows and I'm not sure if there is a good method, but you can always compress the image. This will not help if you want to fit it on a smaller sd card. On Linux you can resize the image to a smaller image by removing unused space, and it can then be expanded to fit the size of your sd card. This is an old tutorial but it works: https://web.archive.org/web/20200602173912/https://softwarebakery.com/shrinking-images-on-linux 0 Quote Link to comment Share on other sites More sharing options...
lanefu Posted June 19, 2022 Share Posted June 19, 2022 The Armbian images shrink the filesystem down to a minimal footprint that then expand to the max of the sdcard on first boot. You're cloning the image after it's been expanded from first boot stage You'll want to shrink the root file system and the partition before imagine. Rather than making a golden image, using the Armbian build tool and the customize image hooks to install your packages would be a more appropriate solution 0 Quote Link to comment Share on other sites More sharing options...
Turbine Posted June 17, 2023 Share Posted June 17, 2023 None of the above solutions work for Windows. However I found a way to clone the entire drive to a compressed image file and have successfully restored it and booted back into Armbian. AOMEI Backupper Free -> Backup -> Disk Backup (bottom is folder to store backup, top is the sdcard/drive you want to select to backup) 0 Quote Link to comment Share on other sites More sharing options...
