Interface only get ip config if plugged on boot
JonatasPrust
Hi,
Nanopi R1 -  Kernel and Armbian version: 4.19.62-sunxi #5.92
I have the following problem:
If I put the ethernet cable on the interface, and then turn on the nano pi, the interface receives a valid ip.
But the problem is, if I start nanopi without the cable connected, and I connect after system boot, the interface does not receive ip configuration.
Configs and logs:
/etc/network/interfaces:
source /etc/network/interfaces.d/*
auto eth0
iface eth0 inet dhcp
auto eth1
iface eth1 inet static
        address 10.100.3.1
        netmask 255.255.255.0
        gateway 10.100.3.1
auto lo
iface lo inet loopback
up command iptables-restore < /scripts/iptables
/scripts/iptables
*nat
:PREROUTING ACCEPT [120:10027]
:INPUT ACCEPT [11:1747]
:OUTPUT ACCEPT [24:1848]
:POSTROUTING ACCEPT [4:304]
-A POSTROUTING -o eth0 -j MASQUERADE
COMMIT
journalctl  -b 0 -u NetworkManager | grep eth0
Mar 25 01:38:29 2-0211 NetworkManager[556]: <info>  [1648183109.1115] keyfile: add connection /run/NetworkManager/system-connections/eth0.nmconnection (91ae80f1-5092-4e36-8f48-72f86df06873,"eth0")
Mar 25 01:38:29 2-0211 NetworkManager[556]: <info>  [1648183109.1178] device (eth0): state change: unavailable -> disconnected (reason 'connection-assumed', sys-iface-state: 'external')
Mar 25 01:38:29 2-0211 NetworkManager[556]: <info>  [1648183109.1247] device (eth0): Activation: starting connection 'eth0' (91ae80f1-5092-4e36-8f48-72f86df06873)
Mar 25 01:38:29 2-0211 NetworkManager[556]: <info>  [1648183109.1258] device (eth0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'external')
Mar 25 01:38:29 2-0211 NetworkManager[556]: <info>  [1648183109.1287] device (eth0): state change: prepare -> config (reason 'none', sys-iface-state: 'external')
Mar 25 01:38:29 2-0211 NetworkManager[556]: <info>  [1648183109.1309] device (eth0): state change: config -> ip-config (reason 'none', sys-iface-state: 'external')
Mar 25 01:38:29 2-0211 NetworkManager[556]: <info>  [1648183109.1328] device (eth0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'external')
Mar 25 01:38:29 2-0211 NetworkManager[556]: <info>  [1648183109.1372] device (eth0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'external')
Mar 25 01:38:29 2-0211 NetworkManager[556]: <info>  [1648183109.1388] device (eth0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'external')
Mar 25 01:38:29 2-0211 NetworkManager[556]: <info>  [1648183109.1538] device (eth0): Activation: successful, device activated.
Mar 25 01:38:37 2-0211 NetworkManager[556]: <info>  [1648183117.8873] device (eth0): carrier: link connected
Mar 25 01:39:56 2-0211 NetworkManager[556]: <info>  [1648183196.5941] device (eth0): state change: activated -> unavailable (reason 'carrier-changed', sys-iface-state: 'external')
Mar 25 01:39:56 2-0211 NetworkManager[556]: <info>  [1648183196.7318] device (eth0): carrier: link connected
Mar 25 01:39:56 2-0211 NetworkManager[556]: <info>  [1648183196.7333] device (eth0): state change: unavailable -> disconnected (reason 'carrier-changed', sys-iface-state: 'external')
16 minutes ago, JonatasPrust said:
4.19.62-sunxi #5.92
Your firmware is WAY outdated. Resources of Armbian are limited and we can only cover the most recent version of Armbian which is 22.02 atm.
