MXQ MBX Model M201 amlogic s805
TV Box Name MXQ MBX Model M201
CPU (example: amlogic s805 Meson 8B 4 cores 1.5 Ghz
Armbian build file name:Armbian_5.67_Aml-s805_Ubuntu_bionic_default_3.10.108_desktop_20181207
DTB file used:
Kernel Version:3.10.108 #14 SMP preenpt
Distribution Installed (focal, buster, etc):Bionic
Working Ethernet  not tested
Max Ethernet Speed that works (100/1000):
Does wifi work Yes sort of, makes breaks connection continually, it will download updates
Does bluetooth work (Yes/No):NA I don't know if the box has it
Does HDMI audio work (Yes/No):Not tested
Additional Comments (provide any additional information you feel is important):
Headphone audio works although it is not perfect.
Keyboard and mouse work fine, I have no remote to test
Sound:AML8AUDIO
Video playback is slow, I'm not sure if accelerated video is working
Video:Mali-450 MP
Booted fine, and updated fine
815 available memory
Armbian_5.67_Aml-s805_Debian_stretch_default_3.10.108_desktop_20181207.img
DTB file used:
Distribution Installed (focal, buster, etc):Stretch
Does wifi work Yes
Does HDMI audio work Yes
Headphone audio not working
Sound:AML8AUDIO
Video:Mali-450 MP
Works better than Bionic
I have exactly the same device and I'm having trouble setting the resolution. The default is 1920x1080. I would like less because I have a preview via VNC on the tablet and the screen is too big and after a few hours of displaying the device freezes. Ram memory 41% temperature 40-50C, because I installed cooling for it.
After typing 'xrandr' it responds
" failed to get size of gamma for output default Screen 0: minimum 1920x1080, current 1920x1080, maximum 1920x1080
default connected 1920x1080+0+0 0mmx0mm
1920x1080 0.00* "
I already wrote.  The temperature is normal but the problem remains.  I had a copy of an almost clean system and ran it all night yesterday.  The system did not hang but vnc stopped working after 6 hours.  Interestingly, the session is active, the log says nothing about errors and you can't connect.  Restarting systemctl tightvncserver also doesn't help, is it a port sharing problem?  P.S.  Before installing the fan, the temperature was up to 72C!
Edited by Amarok4
