Disctanger Posted June 17, 2022 Share Posted June 17, 2022 (edited) I am trying to get USB 2.0 port to reach maximum bandwidth with OTG port (Hi-Speed - 480 MegaBits/second) on PineCube device. Currently it is performing as Full-Speed (12.5 MegaBytes/second) usb port. I have measured the speed and performance using iperf + g_ether kernel mod + OTG port (details below) Official datasheet of PineCube (https://files.pine64.org/doc/datasheet/pinecube/S3_Datasheet_V1.1-20180123.pdf) tells that the port can perform up to 60 MegaBytes/second or 480 MegaBits/second. g_webcam mod is also performing at Full-Speed mode. Spoiler root@pinecube:~/uvs-gadget# iperf3 -c 192.168.10.5 -f M Connecting to host 192.168.10.5, port 5201 [ 5] local 192.168.10.2 port 38834 connected to 192.168.10.5 port 5201 [ ID] Interval Transfer Bitrate Retr Cwnd [ 5] 0.00-1.00 sec 14.0 MBytes 14.0 MBytes/sec 0 133 KBytes [ 5] 1.00-2.00 sec 12.9 MBytes 12.9 MBytes/sec 0 165 KBytes [ 5] 2.00-3.01 sec 13.3 MBytes 13.3 MBytes/sec 0 165 KBytes [ 5] 3.01-4.00 sec 13.7 MBytes 13.8 MBytes/sec 0 165 KBytes [ 5] 4.00-5.00 sec 13.0 MBytes 13.0 MBytes/sec 0 175 KBytes [ 5] 5.00-6.00 sec 13.6 MBytes 13.6 MBytes/sec 0 252 KBytes [ 5] 6.00-7.00 sec 12.7 MBytes 12.7 MBytes/sec 0 252 KBytes [ 5] 7.00-8.00 sec 12.6 MBytes 12.6 MBytes/sec 0 264 KBytes [ 5] 8.00-9.00 sec 13.1 MBytes 13.1 MBytes/sec 0 431 KBytes [ 5] 9.00-10.00 sec 12.9 MBytes 12.9 MBytes/sec 0 431 KBytes - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bitrate Retr [ 5] 0.00-10.00 sec 132 MBytes 13.2 MBytes/sec 0 sender [ 5] 0.00-10.00 sec 131 MBytes 13.1 MBytes/sec receiver iperf Done. lsusb output: Spoiler root@pinecube:~# lsusb -v Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Device Descriptor: bLength 18 bDescriptorType 1 bcdUSB 2.00 bDeviceClass 9 Hub bDeviceSubClass 0 bDeviceProtocol 1 Single TT bMaxPacketSize0 64 idVendor 0x1d6b Linux Foundation idProduct 0x0002 2.0 root hub bcdDevice 5.15 iManufacturer 3 Linux 5.15.43-sunxi musb-hcd iProduct 2 MUSB HDRC host driver iSerial 1 musb-hdrc.2.auto bNumConfigurations 1 Configuration Descriptor: bLength 9 bDescriptorType 2 wTotalLength 0x0019 bNumInterfaces 1 bConfigurationValue 1 iConfiguration 0 bmAttributes 0xe0 Self Powered Remote Wakeup MaxPower 0mA Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 0 bAlternateSetting 0 bNumEndpoints 1 bInterfaceClass 9 Hub bInterfaceSubClass 0 bInterfaceProtocol 0 Full speed (or root) hub iInterface 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x81 EP 1 IN bmAttributes 3 Transfer Type Interrupt Synch Type None Usage Type Data wMaxPacketSize 0x0004 1x 4 bytes bInterval 12 Hub Descriptor: bLength 9 bDescriptorType 41 nNbrPorts 1 wHubCharacteristic 0x0011 Per-port power switching No overcurrent protection TT think time 8 FS bits bPwrOn2PwrGood 5 * 2 milli seconds bHubContrCurrent 0 milli Ampere DeviceRemovable 0x02 PortPwrCtrlMask 0xff Hub Port Status: Port 1: 0000.0100 power can't get device qualifier: Resource temporarily unavailable can't get debug descriptor: Resource temporarily unavailable Device Status: 0x0001 Self Powered armbianmonitor tool output (detailed logs) : http://ix.io/40o2 OS info (neofetch): Spoiler root@pinecube ------------- OS: Armbian focal (22.02.0-trunk.0003) armv7l Host: PineCube IP Camera Kernel: 5.15.43-sunxi Packages: 808 (dpkg) Shell: bash 5.0.17 Terminal: /dev/pts/0 CPU: Allwinner sun8i Family (1) Memory: 46MiB / 111MiB My questions are: How can i reach high speed on USB 2.0 port. (probably too general) Could the issue be be related to USB drivers or Device Tree set up? Edited June 18, 2022 by Disctanger Add important log info 0 Quote Link to comment Share on other sites More sharing options...
Myron Posted June 17, 2022 Share Posted June 17, 2022 Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed. 1 Quote Link to comment Share on other sites More sharing options...
Disctanger Posted June 18, 2022 Author Share Posted June 18, 2022 @Myron Thanks for the advice/support. Here're the logs from armbianmonitor tool: http://ix.io/40o2 0 Quote Link to comment Share on other sites More sharing options...
schwar3kat Posted June 19, 2022 Share Posted June 19, 2022 Hello Disctanger. Have you measured the speeds that you get with OEM's officially supplied software, if the OEM supplies any? It been my experience that some 'open source' OEM's quote the theoretical maximum specs if hardware and software were optimized. Some OEM's provide very limited support for their 'open source' boards, and rely on the community to optimize the software and even the hardware. If this is one of those OEM's, then it's up to the community (people like you) to optimize the software (or even the hardware). You can search these forums to see if anyone has found solutions, and sometimes someone might answer with a suggestion or a solution. The Armbian build system is an ideal platform for you to develop solutions, providing an easy way to apply patches and stream improvements into the build via Github pull requests. I took a look at your logs, and I didn't spot anything obvious. Perhaps someone more familiar with your board will turn up. Good luck 1 Quote Link to comment Share on other sites More sharing options...
Disctanger Posted June 20, 2022 Author Share Posted June 20, 2022 On 6/19/2022 at 9:10 AM, schwar3kat said: Hello Disctanger. Have you measured the speeds that you get with OEM's officially supplied software, if the OEM supplies any? It been my experience that some 'open source' OEM's quote the theoretical maximum specs if hardware and software were optimized. Some OEM's provide very limited support for their 'open source' boards, and rely on the community to optimize the software and even the hardware. If this is one of those OEM's, then it's up to the community (people like you) to optimize the software (or even the hardware). You can search these forums to see if anyone has found solutions, and sometimes someone might answer with a suggestion or a solution. The Armbian build system is an ideal platform for you to develop solutions, providing an easy way to apply patches and stream improvements into the build via Github pull requests. I took a look at your logs, and I didn't spot anything obvious. Perhaps someone more familiar with your board will turn up. Good luck Thanks for your suggestions and instructions. I will try to reach out sunxi-linux and pinecube community asking about this matter. Quote Have you measured the speeds that you get with OEM's officially supplied software, if the OEM supplies any? I don't know anything about OEM's officially supplied software yet. I will research about this and test on officially supplied software if available. 0 Quote Link to comment Share on other sites More sharing options...
