Pi zero 2 first boot problem
Hello. I try to install ambian https://www.armbian.com/orange-pi-zero-2/ to orange pi zero 2 and get there on first start:
▒[100]HELLO! BOOT0 is starting May 13 2020 14:10:04!
[105]BOOT0 commit : 593cf83
[107]set pll start
[110]periph0 has been enabled
[113]set pll end
[115]unknow PMU
[117]PMU: AXP806
[124]vaild para:8  select dram para0
[127]board init ok
[129]DRAM BOOT DRIVE INFO: V0.52
[132]the chip id is 0x5000
[135]chip id check OK
[137]DRAM_VCC set to 1500 mv
[141]read_calibration error
[145]read_calibration error
[149]read_calibration error
[153]read_calibration error
[157]read_calibration error
[161]read_calibration error
[165]read_calibration error
[169]read_calibration error
[173]read_calibration error
[177]read_calibration error
[180]retraining final error
[184][AUTO DEBUG]32bit,1 ranks training success!
[192]DRAM CLK =720 MHZ
[194]DRAM Type =3 (3:DDR3,4:DDR4,7:LPDDR3,8:LPDDR4)
[200]Actual DRAM SIZE =1024 M
[203]DRAM SIZE =1024 MBytes, para1 = 30fa, para2 = 4000000, dram_tpr13 = 6041
[216]DRAM simple test OK.
[219]rtc standby flag is 0x0, super standby flag is 0x0
[224]dram size =1024
[226]*****dram handle ok****
[230]card no is 0
[231]sdcard 0 line count 4
[234][mmc]: mmc driver ver 2019-12-19 10:41
[238][mmc]: sdc0 spd mode error, 2
[242][mmc]: set f_max to 50M, set f_max_ddr to 25M
[247][mmc]: mmc 0 bias 0
[255][mmc]: Wrong media type 0x0
[258][mmc]: ***Try SD card 0***
[267][mmc]: HSSDR52/SDR25 4 bit
[270][mmc]: 50000000 Hz
[272][mmc]: 15200 MB
[274][mmc]: ***SD/MMC 0 init OK!!!***
[373]Loading boot-pkg Succeed(index=0).
[377]Entry_name        = u-boot
[386]Entry_name        = monitor
[390]Entry_name        = dtbo
[393]Entry_name        = dtb
[397]Jump to second Boot.
NOTICE:  BL3-1: v1.0(debug):9fecd83
NOTICE:  BL3-1: Built : 17:08:29, 2020-05-28
NOTICE:  BL3-1 commit: 8
ERROR:   Error initializing runtime service tspd_fast
NOTICE:  BL3-1: Preparing for EL3 exit to normal world
NOTICE:  BL3-1: Next image address = 0x4a000000
NOTICE:  BL3-1: Next image spsr = 0x1d3
U-Boot 2018.05-orangepi (Mar 31 2022 - 11:47:20 +0800) Xunlong Software
[00.474]CPU:   Allwinner H616
[00.477]Model: Orange Pi Zero 2
I2C:   ready
[00.482]DRAM:  1 GiB
Relocation Offset is: 35ec7000
[00.522]secure enable bit: 0
[00.525]PMU: AXP806
[00.530]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=400Mhz
[00.717]sunxi overlay merged okqv
[00.720]drv_disp_init
[00.748]__clk_enable: clk is null.
tv_init()950 fetch tv0 err.
[00.753]drv_disp_init finish
[00.756]gic: sec monitor mode
[00.761]flash init start
[00.763]workmode = 0,storage type = 1
[00.767]MMC:     0
[00.768][mmc]: mmc driver ver uboot2018:2021-07-19 14:09:00
[00.774][mmc]: get sdc_type fail and use default host:tm1.
[00.785][mmc]: Using default timing para
[00.788][mmc]: SUNXI SDMMC Controller Version:0x40200
[00.806][mmc]: card_caps:0x3000000a
[00.809][mmc]: host_caps:0x3000003f
[00.813]sunxi flash init ok
[00.816]Loading Environment from FAT...
[00.820][mmc]: mmc driver ver uboot2018:2021-07-19 14:09:00
[00.826][mmc]: get sdc_type fail and use default host:tm1.
[00.836][mmc]: Using default timing para
[00.840][mmc]: SUNXI SDMMC Controller Version:0x40200
** Bad device mmc 1 **
Failed (-5)
[00.851]usb burn from boot
delay time 0
weak:otg_phy_config
[00.864]usb prepare ok
[01.667]overtime
[01.671]do_burn_from_boot usb : no usb exist
[01.675]boot_gui_init:start
206 bytes read in 8 ms (24.4 KiB/s)
Set HDMI disp_mode to 1080p60
Set fb0_width to 1920
Set fb0_height to 1080
[01.976]boot_gui_init:finish
[01.978]bmp_name=/boot/boot.bmp
230456 bytes read in 105 ms (2.1 MiB/s)
[02.098]update dts
Net:   [02.101]No ethernet found.
Hit any key to stop autoboot:  0
no mmc device at slot 1
[03.128][mmc]: card_caps:0x3000000a
[03.131][mmc]: host_caps:0x3000003f
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
2771 bytes read in 10 ms (270.5 KiB/s)
## Executing script at 43100000
U-boot loaded from SD
Boot script loaded from mmc
8484924 bytes read in 3769 ms (2.1 MiB/s)
24129608 bytes read in 4252 ms (5.4 MiB/s)
## Booting kernel from Legacy Image at 41000000 ...
   Image Name:
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    24129544 Bytes = 23 MiB
   Load Address: 41000000
   Entry Point:  41000000
   Verifying Checksum ... OK
## Loading init Ramdisk from Legacy Image at 43300000 ...
   Image Name:   uInitrd
   Image Type:   ARM Linux RAMDisk Image (gzip compressed)
   Data Size:    8484860 Bytes = 8.1 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Loading Ramdisk to 497e8000, end 49fff7fc ... OK
   reserving fdt memory region: addr=48000000 size=1000000
## Linux machid: 00000000, FDT addr: 7be86d60
Starting kernel ...
▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒&[100]HELLO! BOOT0 is starting May 13 2020 14:10:04!
[107]set pll start
[113]set pll end
[115]unknow PMU
[117]PMU: AXP806
[127]board init ok
[133]the chip id is 0x5000
[230]card no is 0
[232]sdcard 0 line count 4
[375]Loading boot-pkg Succeed(index=0).
[378]Entry_name        = u-boot
[387]Entry_name        = monitor
[391]Entry_name        = dtbo
[394]Entry_name        = dtb
[398]Jump to second Boot.
[00.475]CPU:   Allwinner H616
I2C:   ready
[00.482]DRAM:  1 GiB
[00.523]secure enable bit: 0
[00.525]PMU: AXP806
[00.721]drv_disp_init
[00.754]drv_disp_init finish
[00.762]flash init start
[00.764]workmode = 0,storage type = 1
[00.767]MMC:     0
[00.769][mmc]: mmc driver ver uboot2018:2021-07-19 14:09:00
[00.775][mmc]: get sdc_type fail and use default host:tm1.
[00.789][mmc]: SUNXI SDMMC Controller Version:0x40200
[00.807][mmc]: card_caps:0x3000000a
[00.810][mmc]: host_caps:0x3000003f
[00.817]Loading Environment from FAT...
[00.837][mmc]: Using default timing para
Failed (-5)
[00.852]usb burn from boot
delay time 0
weak:otg_phy_config
[00.865]usb prepare ok
[01.668]overtime
[01.672]do_burn_from_boot usb : no usb exist
[01.676]boot_gui_init:start
206 bytes read in 15 ms (12.7 KiB/s)
206 bytes read in 9 ms (21.5 KiB/s)
[01.984]boot_gui_init:finish
[01.986]bmp_name=/boot/boot.bmp
230456 bytes read in 127 ms (1.7 MiB/s)
[02.128]update dts
Net:   [02.131]No ethernet found.
orangepi# ls -l /dev | grep -E 'sd|hd'
syntax error
orangep
orangepi# fdisk
Unknown command 'fdisk' - try 'help'
orangepi# help
?       - alias for 'help'
base    - print or set address offset
bdinfo  - print Board Info structure
boot    - boot default, i.e., run 'bootcmd'
bootd   - boot default, i.e., run 'bootcmd'
bootm   - boot application image from memory
bootp   - boot image via network using BOOTP/TFTP protocol
bootz   - boot Linux zImage image from memory
cmp     - memory compare
colorbar- show colorbar
coninfo - print console devices and information
cp      - memory copy
crc32   - checksum calculation
dhcp    - boot image via network using DHCP/TFTP protocol
echo    - echo args to console
editenv - edit environment variable
efex    - run to efex
env     - environment handling commands
erase   - erase FLASH memory
exit    - exit script
ext2load- load binary file from a Ext2 filesystem
ext2ls  - list files in a directory (default /)
ext4load- load binary file from a Ext4 filesystem
ext4ls  - list files in a directory (default /)
ext4size- determine a file's size
ext4write- create a file in the root directory
false   - do nothing, unsuccessfully
fastboot- fastboot - enter USB Fastboot protocol
fatinfo - print information about filesystem
fatload - load binary file from a dos filesystem
fatls   - list files in a directory (default /)
fatsize - determine a file's size
fatwrite- write file into a dos filesystem
fdt     - flattened device tree utility commands
flinfo  - print FLASH memory information
fstype  - Look up a filesystem type
go      - start application at address 'addr'
gpt     - GUID Partition Table
help    - print command description/usage
i2c     - I2C sub-system
itest   - return true/false on integer compare
load    - load binary file from a filesystem
loadb   - load binary file over serial line (kermit mode)
loads   - load S-Record file over serial line
loadx   - load binary file over serial line (xmodem mode)
loady   - load binary file over serial line (ymodem mode)
logo    - show default logo
loop    - infinite loop on address range
md      - memory display
memtester- start application at address 'addr'
mii     - MII utility commands
mm      - memory modify (auto-incrementing address)
mmc     - MMC sub system
mmcinfo - display MMC info
mw      - memory write (fill)
nfs     - boot image via network using NFS protocol
nm      - memory modify (constant address)
part    - disk partition related commands
pbread  - read data from private data
ping    - send ICMP ECHO_REQUEST to network host
poweroff- Perform POWEROFF of the device
printenv- print environment variables
protect - enable or disable FLASH write protection
pxe     - commands to get and boot from pxe files
reset   - Perform RESET of the CPU
run     - run commands in an environment variable
save    - save file to a filesystem
saveenv - save environment variables to persistent storage
screen_char- show default screen chars
setenv  - set environment variables
setexpr - set environment variable as the result of eval expression
showvar - print local hushshell variables
sleep   - delay execution for some time
source  - run script from memory
sprite_test- do a sprite test
sunxi_axp- sunxi_axp sub-system
sunxi_bmp_info- manipulate BMP image data
sunxi_bmp_show- manipulate BMP image data
sunxi_card0_probe- probe sunxi card0 device
sunxi_flash- sunxi_flash sub-system
sunxi_nand_test- sunxi_nand_test sub systerm
sysboot - command to get and boot from syslinux files
test    - minimal test like /bin/sh
tftpboot- boot image via network using TFTP protocol
timer_test- do a timer and int test
timer_test1- do a timer and int test
true    - do nothing, successfully
uburn   - do a burn from boot
version - print monitor, compiler and linker version
orangepi# fsck
Unknown command 'fsck' - try 'help'
orangepi# ls
Usage:
ls <interface> [<dev[:part]> [directory]]
    - List files in directory 'directory' of partition 'part' on
      device type 'interface' instance 'dev'.
orangepi# cd /
Unknown command 'cd' - try 'help'
orangepi# ls /
** No device specified **
orangepi# fstab
Unknown command 'fstab' - try 'help'
orangepi# tune2fs
Unknown command 'tune2fs' - try 'help'
orangepi# touch /forcefsck
Unknown command 'touch' - try 'help'
orangepi# help
cp      - memory copy
efex    - run to efex
exit    - exit script
md      - memory display
orangepi# reboot
Unknown command 'reboot' - try 'help'
orangepi# ▒▒[100]HELLO! BOOT0 is starting May 13 2020 14:10:04!
[107]set pll start
[113]set pll end
[115]unknow PMU
[117]PMU: AXP806
[127]board init ok
[230]card no is 0
[00.476]Model: Orange Pi Zero 2
I2C:   ready
[00.481]DRAM:  1 GiB
[00.524]PMU: AXP806
[00.529]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=400Mhz
[00.716]sunxi overlay merged okqv
[00.747]__clk_enable: clk is null.
[00.755]gic: sec monitor mode
[00.766]MMC:     0
[00.784][mmc]: Using default timing para
[00.812]sunxi flash init ok
[00.819][mmc]: mmc driver ver uboot2018:2021-07-19 14:09:00
[00.825][mmc]: get sdc_type fail and use default host:tm1.
[00.839][mmc]: SUNXI SDMMC Controller Version:0x40200
Failed (-5)
delay time 0
weak:otg_phy_config
[01.667]overtime
230456 bytes read in 83 ms (2.6 MiB/s)
[02.076]update dts
Net:   [02.080]No ethernet found.
[03.106][mmc]: card_caps:0x3000000a
[03.109][mmc]: host_caps:0x3000003f
Scanning mmc 0:1...
2771 bytes read in 11 ms (245.1 KiB/s)
8484924 bytes read in 3720 ms (2.2 MiB/s)
24129608 bytes read in 4498 ms (5.1 MiB/s)
   Image Name:
   Image Name:   uInitrd
Starting kernel ...
▒[96]HELLO! BOOT0 is starting May 13 2020 14:10:04!
[101]BOOT0 commit : 593cf83
[103]set pll start
[106]periph0 has been enabled
[109]set pll end
[111]unknow PMU
[113]PMU: AXP806
[120]vaild para:1  select dram para0
[123]board init ok
[125]DRAM BOOT DRIVE INFO: V0.52
[128]the chip id is 0x5000
[131]chip id check OK
[133]DRAM_VCC set to 1500 mv
[137]read_calibration error
[175]retraining final error
[180][AUTO DEBUG]32bit,1 ranks training success!
[187]DRAM CLK =720 MHZ
[190]DRAM Type =3 (3:DDR3,4:DDR4,7:LPDDR3,8:LPDDR4)
[196]Actual DRAM SIZE =1024 M
[199]DRAM SIZE =1024 MBytes, para1 = 30fa, para2 = 4000000, dram_tpr13 = 6041
[212]DRAM simple test OK.
[215]rtc standby flag is 0x0, super standby flag is 0x0
[220]dram size =1024
[222]*****dram handle ok****
[226]card no is 0
[227]sdcard 0 line count 4
[230][mmc]: mmc driver ver 2019-12-19 10:41
[234][mmc]: sdc0 spd mode error, 2
[238][mmc]: set f_max to 50M, set f_max_ddr to 25M
[243][mmc]: mmc 0 bias 0
[251][mmc]: Wrong media type 0x0
[254][mmc]: ***Try SD card 0***
[263][mmc]: HSSDR52/SDR25 4 bit
[266][mmc]: 50000000 Hz
[268][mmc]: 15200 MB
[270][mmc]: ***SD/MMC 0 init OK!!!***
[369]Loading boot-pkg Succeed(index=0).
[373]Entry_name        = u-boot
[382]Entry_name        = monitor
[386]Entry_name        = dtbo
[389]Entry_name        = dtb
[393]Jump to second Boot.
U-Boot 2018.05-armbian (Jun 22 2022 - 07:19:38 +0000) Xunlong Software
[00.468]CPU:   Allwinner H616
[00.471]Model: Orange Pi Zero 2
I2C:   ready
[00.476]DRAM:  1 GiB
[00.516]secure enable bit: 0
[00.519]PMU: AXP806
[00.524]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=400Mhz
[00.706]sunxi overlay merged okqv
[00.709]drv_disp_init
[00.738]__clk_enable: clk is null.
[00.744]drv_disp_init finish
[00.746]gic: sec monitor mode
[00.752]flash init start
[00.754]workmode = 0,storage type = 1
[00.757]MMC:     0
[00.759][mmc]: mmc driver ver uboot2018:2021-07-19 14:09:00
[00.765][mmc]: get sdc_type fail and use default host:tm1.
[00.775][mmc]: Using default timing para
[00.779][mmc]: SUNXI SDMMC Controller Version:0x40200
[00.796][mmc]: card_caps:0x3000000a
[00.799][mmc]: host_caps:0x3000003f
[00.803]sunxi flash init ok
[00.806]Loading Environment from FAT...
[00.810][mmc]: mmc driver ver uboot2018:2021-07-19 14:09:00
[00.816][mmc]: get sdc_type fail and use default host:tm1.
[00.827][mmc]: Using default timing para
[00.830][mmc]: SUNXI SDMMC Controller Version:0x40200
Failed (-5)
[00.841]usb burn from boot
delay time 0
weak:otg_phy_config
[00.855]usb prepare ok
[01.658]overtime
[01.662]do_burn_from_boot usb : no usb exist
[01.666]boot_gui_init:start
141 bytes read in 9 ms (14.6 KiB/s)
141 bytes read in 8 ms (16.6 KiB/s)
Set fb0_width to 1280
Set fb0_height to 720
[01.967]boot_gui_init:finish
[01.970]bmp_name=/boot/boot.bmp
230454 bytes read in 30 ms (7.3 MiB/s)
[02.013]update dts
Net:   [02.016]No ethernet found.
[03.043][mmc]: card_caps:0x3000000a
[03.046][mmc]: host_caps:0x3000003f
Scanning mmc 0:1...
3202 bytes read in 10 ms (312.5 KiB/s)
262144 bytes read in 35 ms (7.1 MiB/s)
** File not found /boot/dtb/allwinner/overlay/-fixup.scr **
6995219 bytes read in 595 ms (11.2 MiB/s)
** File not found /boot/Image **
Unknown command 'booti' - try 'help'
SCRIPT FAILED: continuing...
No ethernet found.
missing environment variable: pxeuuid
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/00000000
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Retrieving file: pxelinux.cfg/default-arm-sunxi
No ethernet found.
No ethernet found.
No ethernet found.
Config file not found
No ethernet found.
armbian# ** Bad device mmc 1 **
Unknown command '**' - try 'help'
armbian# mmc rescan
[63.143][mmc]: card_caps:0x3000000a
[63.146][mmc]: host_caps:0x3000003f
armbian# fatls mmc 0:0
** Unrecognized filesystem type **
armbian# fatls mmc 1:0
armbian# fatls mmc 0:1
armbian# [90]HELLO! BOOT0 is starting May 13 2020 14:10:04!
[95]BOOT0 commit : 593cf83
[97]set pll start
[100]periph0 has been enabled
[103]set pll end
[105]unknow PMU
[106]PMU: AXP806
[114]vaild para:1  select dram para0
[117]board init ok
[119]DRAM BOOT DRIVE INFO: V0.52
[122]the chip id is 0x5000
[125]chip id check OK
[127]DRAM_VCC set to 1500 mv
[131]read_calibration error
[135]read_calibration error
[139]read_calibration error
[143]read_calibration error
[147]read_calibration error
[151]read_calibration error
[155]read_calibration error
[159]read_calibration error
[163]read_calibration error
[166]read_calibration error
[169]retraining final error
[174][AUTO DEBUG]32bit,1 ranks training success!
[181]DRAM CLK =720 MHZ
[183]DRAM Type =3 (3:DDR3,4:DDR4,7:LPDDR3,8:LPDDR4)
[190]Actual DRAM SIZE =1024 M
[193]DRAM SIZE =1024 MBytes, para1 = 30fa, para2 = 4000000, dram_tpr13 = 6041
[206]DRAM simple test OK.
[208]rtc standby flag is 0x0, super standby flag is 0x0
[214]dram size =1024
[216]*****dram handle ok****
[220]card no is 0
[221]sdcard 0 line count 4
[224][mmc]: mmc driver ver 2019-12-19 10:41
[228][mmc]: sdc0 spd mode error, 2
[232][mmc]: set f_max to 50M, set f_max_ddr to 25M
[237][mmc]: mmc 0 bias 0
[245][mmc]: Wrong media type 0x0
[248][mmc]: ***Try SD card 0***
[257][mmc]: HSSDR52/SDR25 4 bit
[260][mmc]: 50000000 Hz
[262][mmc]: 15200 MB
[264][mmc]: ***SD/MMC 0 init OK!!!***
[363]Loading boot-pkg Succeed(index=0).
[367]Entry_name        = u-boot
[376]Entry_name        = monitor
[380]Entry_name        = dtbo
[383]Entry_name        = dtb
[386]Jump to second Boot.
[00.463]CPU:   Allwinner H616
[00.466]Model: Orange Pi Zero 2
I2C:   ready
[00.471]DRAM:  1 GiB
[00.511]secure enable bit: 0
[00.514]PMU: AXP806
[00.519]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=400Mhz
[00.701]sunxi overlay merged okqv
[00.704]drv_disp_init
[00.733]__clk_enable: clk is null.
[00.739]drv_disp_init finish
[00.741]gic: sec monitor mode
[00.747]flash init start
[00.749]workmode = 0,storage type = 1
[00.752]MMC:     0
[00.754][mmc]: mmc driver ver uboot2018:2021-07-19 14:09:00
[00.760][mmc]: get sdc_type fail and use default host:tm1.
[00.770][mmc]: Using default timing para
[00.774][mmc]: SUNXI SDMMC Controller Version:0x40200
[00.792][mmc]: card_caps:0x3000000a
[00.795][mmc]: host_caps:0x3000003f
[00.798]sunxi flash init ok
[00.802]Loading Environment from FAT...
[00.805][mmc]: mmc driver ver uboot2018:2021-07-19 14:09:00
[00.811][mmc]: get sdc_type fail and use default host:tm1.
[00.822][mmc]: Using default timing para
[00.825][mmc]: SUNXI SDMMC Controller Version:0x40200
Failed (-5)
[00.837]usb burn from boot
delay time 0
weak:otg_phy_config
[00.850]usb prepare ok
[01.653]overtime
[01.657]do_burn_from_boot usb : no usb exist
[01.661]boot_gui_init:start
[01.962]boot_gui_init:finish
[01.965]bmp_name=/boot/boot.bmp
230454 bytes read in 29 ms (7.6 MiB/s)
[02.008]update dts
Net:   [02.011]No ethernet found.
[03.038][mmc]: card_caps:0x3000000a
[03.041][mmc]: host_caps:0x3000003f
Scanning mmc 0:1...
3202 bytes read in 11 ms (284.2 KiB/s)
6995219 bytes read in 594 ms (11.2 MiB/s)
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
armbian# File not found /boot/Imageprintenv
Unknown command 'File' - try 'help'
armbian# printenv
arch=arm
baudrate=115200
board=sunxi
board_name=sunxi
boot_a_script=load ${devtype} ${devnum}:${distro_bootpart} ${scriptaddr} ${prefix}${script}; source ${scriptaddr}
boot_disp=1034
boot_disp1=0
boot_disp2=0
boot_extlinux=sysboot ${devtype} ${devnum}:${distro_bootpart} any ${scriptaddr} ${prefix}extlinux/extlinux.conf
boot_fb0=7bf4fcc0,500,2d0,20,1400,1e0,f0,320,1e0
boot_prefixes=/ /boot/
boot_script_dhcp=boot.scr.uimg
boot_scripts=boot.scr.uimg boot.scr
boot_targets=fel mmc_auto pxe dhcp
bootargs=root=UUID=7af2b6ff-a1ee-4678-af7e-2271601e558c rootwait rootfstype=ext4 console=ttyS0,115200 consoleblank=0 loglevel=1 ubootpart=f9fc421d-01 usb-storage.quirks=   cgroup_enable=memory swapaccount=1
bootcmd=run distro_bootcmd
bootcmd_dhcp=if dhcp ${scriptaddr} ${boot_script_dhcp}; then source ${scriptaddr}; fi;
bootcmd_fel=if test -n ${fel_booted} && test -n ${fel_scriptaddr}; then echo '(FEL boot)'; source ${fel_scriptaddr}; fi
bootcmd_mmc0=setenv devnum 0; run mmc_boot
bootcmd_mmc1=setenv devnum 1; run mmc_boot
bootcmd_mmc_auto=if test ${mmc_bootdev} -eq 1; then run bootcmd_mmc1; run bootcmd_mmc0; elif test ${mmc_bootdev} -eq 0; then run bootcmd_mmc0; run bootcmd_mmc1; fi
bootcmd_pxe=dhcp; if pxe get; then pxe boot; fi
bootdelay=1
bootfstype=ext4
bootlogo=false
bootm_size=0xa000000
bootreason=unknow
console=serial
consoleargs=console=ttyS0,115200
cpu=armv7
devnum=0
devplist=1
devtype=mmc
dfu_alt_info_ram=kernel ram 0x41000000 0x1000000;fdt ram 0x43000000 0x100000;ramdisk ram 0x43300000 0x4000000
disp_mode=1080p60
disp_reserve=3686400,0x7bf4fcc0
distro_bootcmd=for target in ${boot_targets}; do run bootcmd_${target}; done
docker_optimizations=on
fb0_height=720
fb0_width=1280
fdt_addr_r=0x43000000
fdtaddr=43000000
fdtcontroladdr=7be87560
fdtfile=sunxi/sun50i-h616-orangepi-zero2.dtb
fileaddr=43300000
filesize=6abd13
kernel_addr_r=0x41000000
load_addr=0x45000000
mmc_boot=if mmc dev ${devnum}; then setenv devtype mmc; run scan_dev_for_boot_part; fi
overlay_error=false
partitions=name=loader1,start=8k,size=32k,uuid=${uuid_gpt_loader1};name=loader2,size=984k,uuid=${uuid_gpt_loader2};name=esp,size=128M,bootable,uuid=${uuid_gpt_esp};name=system,size=-,uuid=${uuid_gpt_system};
partuuid=f9fc421d-01
pxefile_addr_r=0x43200000
ramdisk_addr_r=0x43300000
rootdev=UUID=7af2b6ff-a1ee-4678-af7e-2271601e558c
rootfstype=ext4
scan_dev_for_boot=echo Scanning ${devtype} ${devnum}:${distro_bootpart}...; for prefix in ${boot_prefixes}; do run scan_dev_for_extlinux; run scan_dev_for_scripts; done;
scan_dev_for_boot_part=part list ${devtype} ${devnum} -bootable devplist; env exists devplist || setenv devplist 1; for distro_bootpart in ${devplist}; do if fstype ${devtype} ${devnum}:${distro_bootpart} bootfstype; then run scan_dev_for_boot; fi; done
scan_dev_for_extlinux=if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}extlinux/extlinux.conf; then echo Found ${prefix}extlinux/extlinux.conf; run boot_extlinux; echo SCRIPT FAILED: continuing...; fi
scan_dev_for_scripts=for script in ${boot_scripts}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${script}; then echo Found U-Boot script ${prefix}${script}; run boot_a_script; echo SCRIPT FAILED: continuing...; fi; done
scriptaddr=0x43100000
snum=ac00143c519446f23ce
soc=sunxi
stderr=serial
stdin=serial
stdout=serial
tv_vdid=2078814848
uuid_gpt_esp=c12a7328-f81f-11d2-ba4b-00a0c93ec93b
uuid_gpt_system=69dad710-2ce4-4e3c-b16c-21a1d49abed3
verbosity=1
Environment size: 3588/131068 bytes
armbian# clear
Unknown command 'clear' - try 'help'
armbian# cls
Unknown command 'cls' - try 'help'
armbian# clsscr
Unknown command 'clsscr' - try 'help'
armbian# printenv
arch=arm
baudrate=115200
board=sunxi
board_name=sunxi
boot_disp=1034
boot_disp1=0
boot_disp2=0
bootdelay=1
bootfstype=ext4
bootlogo=false
bootreason=unknow
console=serial
cpu=armv7
devnum=0
devplist=1
devtype=mmc
disp_mode=1080p60
fb0_height=720
fb0_width=1280
fdtaddr=43000000
fileaddr=43300000
filesize=6abd13
overlay_error=false
rootfstype=ext4
soc=sunxi
stderr=serial
stdin=serial
stdout=serial
tv_vdid=2078814848
verbosity=1
armbian# mtest
Unknown command 'mtest' - try 'help'
armbian# ls
Usage:
armbian#
Doesn't look Armbian, seems to be Legacy image from Orangepi.
Oh ok interesting yes could be, do know about vendor source - haven't spent much time with Armbian legacy, still thought its debug was different to above output though.
Anyway not helping!
Back to @Werner 's question, if OP lets us know the exact image, perhaps some guidance can be given.
After testing a few images in a bid to try and get a working image where wireless works, I can confirm that this issue happens with the current 'supported' Bullseye image: Armbian_22.05.3_Orangepizero2_bullseye_legacy_4.9.255.img
As well as a bunch of other 'current' images in the archive.
Edited by gyrex
Boot log from Armbian_22.05.3_Orangepizero2_bullseye_legacy_4.9.255.img
[64]HELLO! BOOT0 is starting May 13 2020 14:10:04!
[69]BOOT0 commit : 593cf83
[72]set pll start
[74]periph0 has been enabled
[78]set pll end
[79]unknow PMU
[81]PMU: AXP806
[88]vaild para:1  select dram para0
[91]board init ok
[93]DRAM BOOT DRIVE INFO: V0.52
[96]the chip id is 0x5000
[99]chip id check OK
[101]DRAM_VCC set to 1500 mv
[105]read_calibration error
[109]read_calibration error
[113]read_calibration error
[117]read_calibration error
[121]read_calibration error
[125]read_calibration error
[128]read_calibration error
[132]read_calibration error
[136]read_calibration error
[140]read_calibration error
[143]retraining final error
[148][AUTO DEBUG]32bit,1 ranks training success!
[155]DRAM CLK =720 MHZ
[157]DRAM Type =3 (3:DDR3,4:DDR4,7:LPDDR3,8:LPDDR4)
[164]Actual DRAM SIZE =1024 M
[167]DRAM SIZE =1024 MBytes, para1 = 30fa, para2 = 4000000, dram_tpr13 = 6041
[180]DRAM simple test OK.
[182]rtc standby flag is 0x0, super standby flag is 0x0
[188]dram size =1024
[190]*****dram handle ok****
[193]card no is 0
[195]sdcard 0 line count 4
[198][mmc]: mmc driver ver 2019-12-19 10:41
[202][mmc]: sdc0 spd mode error, 2
[205][mmc]: set f_max to 50M, set f_max_ddr to 25M
[210][mmc]: mmc 0 bias 0
[218][mmc]: Wrong media type 0x0
[221][mmc]: ***Try SD card 0***
[231][mmc]: HSSDR52/SDR25 4 bit
[234][mmc]: 50000000 Hz
[236][mmc]: 29818 MB
[238][mmc]: ***SD/MMC 0 init OK!!!***
[338]Loading boot-pkg Succeed(index=0).
[342]Entry_name        = u-boot
[351]Entry_name        = monitor
[355]Entry_name        = dtbo
[357]Entry_name        = dtb
[361]Jump to second Boot.
[00.437]CPU:   Allwinner H616
[00.440]Model: Orange Pi Zero 2
I2C:   ready
[00.445]DRAM:  1 GiB
[00.485]secure enable bit: 0
[00.488]PMU: AXP806
[00.493]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=400Mhz
[00.675]sunxi overlay merged okqv
[00.678]drv_disp_init
[00.707]__clk_enable: clk is null.
[00.713]drv_disp_init finish
[00.715]gic: sec monitor mode
[00.721]flash init start
[00.723]workmode = 0,storage type = 1
[00.726]MMC:	 0
[00.728][mmc]: mmc driver ver uboot2018:2021-07-19 14:09:00
[00.734][mmc]: get sdc_type fail and use default host:tm1.
[00.744][mmc]: Using default timing para
[00.748][mmc]: SUNXI SDMMC Controller Version:0x40200
[00.766][mmc]: card_caps:0x3000000a
[00.769][mmc]: host_caps:0x3000003f
[00.773]sunxi flash init ok
[00.776]Loading Environment from FAT...
[00.780][mmc]: mmc driver ver uboot2018:2021-07-19 14:09:00
[00.786][mmc]: get sdc_type fail and use default host:tm1.
[00.796][mmc]: Using default timing para
[00.800][mmc]: SUNXI SDMMC Controller Version:0x40200
Failed (-5)
[00.811]usb burn from boot
delay time 0
weak:otg_phy_config
[00.824]usb prepare ok
[01.627]overtime
[01.631]do_burn_from_boot usb : no usb exist
[01.635]boot_gui_init:start
141 bytes read in 20 ms (6.8 KiB/s)
[01.961]boot_gui_init:finish
[01.963]bmp_name=/boot/boot.bmp
230454 bytes read in 44 ms (5 MiB/s)
[02.021]update dts
Net:   [02.024]No ethernet found.
[03.051][mmc]: card_caps:0x3000000a
[03.054][mmc]: host_caps:0x3000003f
Scanning mmc 0:1...
3202 bytes read in 26 ms (120.1 KiB/s)
141 bytes read in 19 ms (6.8 KiB/s)
262144 bytes read in 52 ms (4.8 MiB/s)
6995219 bytes read in 622 ms (10.7 MiB/s)
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
armbian# %
Hi @gyrex, I haven't read all your posts, perhaps you have already tried. (EDIT: see you have!)
Last working legacy image I booted from: Armbian_22.02.2_Orangepizero2_bullseye_legacy_4.9.255.img
Have various images in various states of experimental chaos, but have used this above for legacy where all was working, well, I mainly use headless, and minimal builds and then add what needed for purpose, so stand to be corrected on features.
