Werner Posted July 9, 2022 Share Posted July 9, 2022 PI-co ITX form factor(2.5 inch, 100 x 72mm) RK3588 powered, 8nm manufacturing process Quad A76 2.4Ghz + Quad A55 1.8Ghz Mali G610MC4 GPU(up to 5 channel 4K UI) 6T NPU 8K 10bit decoder, 8K encoder Support WiFi 6E and BT5.2 Support PCIe 3.0 x4 NVMe SSD Triple display support(with HDR) Two HDMI 2.1up to 8K@60FPS One USB C with DP up to 8K@30FPS HDMI in support up to 4K@60FPS 2.5G Ethernet with PoE support Offer 4GB/8GB/16GB(LPDDR4x) ram options Link to comment Share on other sites More sharing options...
