NicoD Posted August 5, 2022 Share Posted August 5, 2022 Hi guys. I'm the maintainer for the Khadas VIM3. There are 2 small issue's with the Armbian images for VIM3, and also for VIM2. armbianmonitor -u http://ix.io/46L9 First off, the VIM3 has all its cores clocked to 1.5Ghz by default. I created a Jira for that a while ago. https://armbian.atlassian.net/browse/AR-1094 My simple fix is in /etc/default/cpufrequtils MAX_SPEED=15xxxxxxx → MAX_SPEED=2400000 But I have no idea how/where to adjust this so it is correct for all VIM3 images. Then for VIM2 and VIM3 (maybe VIM3L and VIM1 too) the HDMI audio isn't working as it should. https://armbian.atlassian.net/browse/AR-1095 I once was able to make it work. But I can't remember how. So the device is enabled at boot, but not directed to be used by pulseaudio. Thank you. 0 Quote Link to comment Share on other sites More sharing options...
TonyMac32 Posted August 5, 2022 Share Posted August 5, 2022 40 minutes ago, NicoD said: First off, the VIM3 has all its cores clocked to 1.5Ghz by default. https://github.com/armbian/build/blob/master/config/sources/families/include/meson64_common.inc#L20 This is the default for Meson64. No one added the actual top speeds for the Vims apparently https://github.com/armbian/build/blob/master/config/sources/families/meson-g12a.conf#L5 is the override for the Meson G12A. G12B needs something similar in here: https://github.com/armbian/build/blob/master/config/sources/families/meson-g12b.conf 1 Quote Link to comment Share on other sites More sharing options...
Lennyz1988 Posted October 12, 2022 Share Posted October 12, 2022 Hi @NicoD do you know if the NPU is working on the Vim3 using Armbian? I received my Vim3 yesterday so I still have a lot of reading to do. 0 Quote Link to comment Share on other sites More sharing options...
NicoD Posted October 12, 2022 Author Share Posted October 12, 2022 2 hours ago, Lennyz1988 said: Hi @NicoD do you know if the NPU is working on the Vim3 using Armbian? I received my Vim3 yesterday so I still have a lot of reading to do. I've not messed with the NPU, I should, but don't know a good use case. The things you'll have to read are probably this https://www.khadas.com/post/npu-toolkit-v6-4-0-10-for-vim3---vim3l-released And this https://forum.khadas.com/t/npu-demo-and-source-code/5938/13 0 Quote Link to comment Share on other sites More sharing options...
Dingo Posted February 4, 2023 Share Posted February 4, 2023 On 8/5/2022 at 11:30 PM, NicoD said: Then for VIM2 and VIM3 (maybe VIM3L and VIM1 too) the HDMI audio isn't working as it should. Hi @NicoD I'm not sure that it's a right solution you've been looking for but it works with my VIM 3 Pro. See this topic on Khadas forum: Twister OS Armbian 2.01 on VIM3! GL Acceleration Fan and AUDIO - Full HOWTO and Working Image DL The details described in UPDATE 2: (In which audio works with correct ALSA configurations) 0 Quote Link to comment Share on other sites More sharing options...
jimt Posted May 14, 2023 Share Posted May 14, 2023 I notice my VIM3 Pro negotiated 12V power when running the originally supplied Android image or the Rescue image, but when using Armbian 23.02.2 Jammy with Linux 6.1.11-meson64 it stays at 5V. 0 Quote Link to comment Share on other sites More sharing options...
