blutme Posted September 9, 2022 Share Posted September 9, 2022 Hello friends, I installed the latest version of ARMBIAN compatible with ORANGEPI 3 LTS. But on the login screen, the username and password fields are pixelated, change color unstable when moving the mouse or trying to enter the password. This error only occurs on the login screen, once the desktop starts everything is normal. Thanks for your help. 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted September 19, 2022 Share Posted September 19, 2022 On 9/9/2022 at 3:48 AM, blutme said: latest version of ARMBIAN compatible with ORANGEPI 3 LTS There are many different version of images for download and you didn't specify with which you have issues with. You have to read how to documentation and see if you can help yourself as you don't want to make additional damages. Also start from here https://www.armbian.com/faq as without all information, bug doesn't exists. On 9/9/2022 at 3:48 AM, blutme said: Thanks for your help. After you https://forum.armbian.com/subscriptions/ 0 Quote Link to comment Share on other sites More sharing options...
Whoo Posted December 26, 2022 Share Posted December 26, 2022 I have the same problem kernel info: Linux OrPi 5.15.80-sunxi64 #22.11.1 SMP Wed Nov 30 11:23:00 UTC 2022 aarch64 aarch64 aarch64 GNU/Linux Getting errors in like in dmesg and journalctl Is it normal? And my login screen is lagging like that https://cdn.discordapp.com/attachments/857944478269702214/1056127122197987388/VID_20221224_092824.mp4 (it's short video) 0 Quote Link to comment Share on other sites More sharing options...
